RS1A THRU RS1M
FAST RECOVERY RECTIFIER DIODE
FEATURES
Glass Passivated Die Construction
Low reverse leakage current
Low forward voltage drop
High current capability
Surface Mount device
MECHANICAL DATA
Case: SMA(DO-214AC)
Case Material: Molded Plastic. UL flammability
Classification Rating: 94V-0
Weight: 0.065 grams (approximate)
MAXIMUM RATINGS AND CHARACTERISTICS(TA = 25°C unless otherwise noted)
Parameter
Symbol RS1A RS1B RS1D RS1G RS1J RS1K RS1M Unit
Maximum Recurrent Peak Reverse Voltage
DC Blocking Reverse Voltage
RMS Reverse Voltage
Maximum Average Forward Rectified Current
Non-Repetitive Peak Forward Surge Current
@t=8.3ms
Reverse Recovery Time
(@IF=0.5A, IR=1.0A,IRR=0.25A)
VRRM
50
100 200 400 600 800 1000
V
VR
50
V
VR(RMS)
35
70
V
140 280 420 560
700
IF
1
A
IFSM
30
A
250
150
trr
500
nS
RθJA
50
°C/W
Junction Temperature
TJ
-55 ~+150
°C
Storage Temperature
TSTG
-55 ~+150
°C
Thermal Resistance From Junction To Ambient
ELECTRICAL CHARACTERISTICS (TA = 25°C unless otherwise specified)
Parameter
Symbol Min
Typ
Max Unit
Conditions
Forward voltage
VF
1.3
V
IF=1A
Reverse current
IR
5
uA
VR=VRRM
Diode capacitance
CD
pF
VR=4V,f=1MHz
©GUANGDONG HOTTECH INDUSTRIAL CO.,LTD
10
E-mail:hkt@heketai.com
1/4
RS1A THRU RS1M
Typical Characteristics
IF, INSTANTANEOUS FORWARD CURRENT (A)
IO, AVERAGE RECTIFIED CURRENT (A)
1.2
1.0
0.8
0.6
0.4
0.2
10
1.0
0.1
Tj = 25°C
IF Pulse Width: 300µs
0.01
50
75
100
125
150
30
Single Half-Sine-Wave
(JEDEC Method)
Tj = 150°C
10
0.8
1.2
1.6
VF, INSTANTANEOUS FORWARD VOLTAGE (V)
Fig. 2 Typical Forward Characteristics
IR, INSTANTANEOUS REVERSE CURRENT (µA)
IFSM, PEAK FORWARD SURGE CURRENT (A)
TL , LEAD TEMPERATURE
( ° C)
Fig. 1 Forward Current Derating Curve
0.4
1000
Tj = 125°C
100
10
0.1
NUMBER OF CYCLES AT 60Hz
Fig. 3 Forward Surge Current Derating Curve
Tj = 25°C
1.0
60
80
100
120
140
PERCENT OF RATED PEAK REVERSE VOLTAGE (%)
Fig. 4 Typical Reverse Characteristics
trr
+0.5A
50Ω NI (Non-inductive)
10Ω NI
Device
Under
Test
0A
Pulse
Generator
(Note 2)
50V DC
Approx
1.0Ω
NI
Oscilloscope
(Note 1)
-0.25A
Notes:
1. Rise Time = 7.0ns max. Input Impedance = 1.0MΩ, 22pF.
2. Rise Time = 10ns max. Input Impedance = 50Ω.
-1.0A
Set time base for 10ns/cm
Fig. 5 Reverse Recovery Time Characteristic and Test Circuit
2/4
RS1A THRU RS1M
SMA Package Outline Dimensions
Symbol
Dimensions In Millimeters
Min.
Max.
A
2.20
B
Dimensions In Inches
Max.
2.80
Min.
0.086
1.30
1.70
0.051
0.067
C
4.70
5.30
0.185
0.209
D
1.70
2.55
0.067
0.100
E
0.90
1.50
0.035
0.059
F
0.90
1.50
0.035
0.059
0.110
SMA Suggested Pad Layout
Note:
1.Controlling dimension: in millimeters
2.General tolerance: ±0.05mm
3.The pad layout is for reference purposes only
3/4
RS1A THRU RS1M
SMA Tape and Reel
SMA Embossed Carrier Tape
DIMENSIONS ARE IN MILLIMETER
TYPE
A
B
C
d
E
F
P0
P
P1
W
SMA
2.89
5.35
2.68
Ø1.50
1.75
5.50
4.00
4.00
2.00
12.00
TOLERANCE
±0.1
±0.1
±0.1
±0.1
±0.1
±0.1
±0.1
±0.1
±0.1
±0.1
SMA Tape Leader and Trailer
SMA Reel
REEL OPTION
7’’ DIA
TOLERANCE
D
D1
D2
G
H
I
W1
W2
Ø178
54.40
13.00
R78
R25.60
R6.50
12.40
17.60
±2
±1
±1
±1
±1
±1
±1
±1
4/4
很抱歉,暂时无法提供与“RS1M”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 50+0.04438
- 400+0.03479
- 800+0.03427
- 2000+0.02949
- 国内价格
- 50+0.08311
- 500+0.06444
- 2000+0.05643
- 4000+0.05018
- 24000+0.04474
- 50000+0.04186
- 国内价格
- 1+0.07689
- 50+0.03850
- 2000+0.02926
- 国内价格
- 5+0.05420
- 20+0.05050
- 100+0.04690
- 500+0.04340
- 1000+0.03980
- 2000+0.03610
- 国内价格
- 50+0.04073
- 500+0.03981
- 2000+0.03931
- 4000+0.03868
