Plastic-Encapsulate Mosfets
FEATURES
SI2302
High dense cell design for extremely low RDS(ON)
N-Channel MOSFET
Rugged and reliable
Case Material: Molded Plastic.
Absolute Maximum Ratings (TA=25oC, unless otherwise noted)
Parameter
Symbol
Ratings
Unit
Drain-Source Voltage
VDS
V
Gate-source Voltage
VGS
8
V
ID
2.1
A
Drain Current (Continuous)
1.Gate
2.Source
SOT-23
3.Drain
Drain Current (Pulsed) a
o
Total Power Dissipation @TA=25 C
Operating Junction and Storage Temperature Range
Thermal Resistance Junction to Ambient (PCB mounted)b
IDM
10
A
PD
0.4
W
Tj, Tstg
-55 to +150
°C
RθJA
100
°C/W
D
G
S
Electrical Characteristics (TA=25°C, unless otherwise noted)
Parameter
Symbol
Test Condition
Min
Typ
Max
Unit
BVDSS
VGS = 0V, ID = 10µA
IDSS
VDS = 20V, VGS = 0V
1
µA
Off Characteristics
Drain-Source Breakdown Voltage
Zero Gate Voltage Drain Current
V
Gate Body Leakage Current, Forward
IGSSF
VGS = 8V, VDS = 0V
100
nA
Gate Body Leakage Current, Reverse
IGSSR
VGS = -8V, VDS = 0V
-100
nA
1.2
V
On Characteristics
c
VGS(th)
Gate Threshold Voltage
Static Drain-Source
RDS(on)
On-Resistance
Forwand Transconductance
gFS
VGS = VDS, ID = 50µA
0.65
VGS = 4.5V, ID = 3.6A
55
72
mΩ
VGS = 2.5V, ID = 3.1A
82
110
mΩ
VDS = 5V, ID = 3.6A
8.5
S
237
pF
120
pF
45
pF
Dynamic Characteristics d
Input Capacitance
Ciss
Output Capacitance
Coss
Reverse Transfer Capacitance
Crss
Switching Characteristics
Turn-On Delay Time
Turn-Off Delay Time
Turn-On Fall Time
d
td(on)
23
45
ns
11
30
ns
td(off)
34
70
ns
tf
36
70
ns
tr
Turn-On Rise Time
VDS = 10V, VGS = 0V, f = 1.0
MHz
GUANGDONG HOTTECH
VDD = 10V, ID = 3.6A, VGS =
4.5V, RGEN = 6Ω
INDUSTRIAL CO., LTD
Page:P3-P1
Qg
Total Gate Charge
Gate-Source Charge
Qgs
Gate-Drain Charge
Qgd
6
VDS = 10V, ID = 3.6A, VGS =
4.5V
10
nC
1.4
nC
1.8
nC
Drain-Source Diode Characteristics and Maximun Ratings
Drain-Source Diode Forward Current c
IS
Drain-Source Diode Forward Voltage d
VSD
0.94
A
1.2
V
VGS = 0V, IS = 0.94A
a.Repetitive Rating : Pulse width limited by maximum junction temperature. b.Surface Mounted on FR4 Board,t
很抱歉,暂时无法提供与“SI2302”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+0.44000
- 200+0.14630
- 1500+0.09174
- 3000+0.07271
- 国内价格
- 1+0.06990
- 10+0.06200
- 100+0.05860
- 500+0.05630
- 国内价格
- 20+0.21060
- 200+0.16360
- 600+0.14010
- 3000+0.13400
- 9000+0.12190
- 21000+0.11520
- 国内价格
- 20+0.19723
- 300+0.15715
- 1200+0.13487
- 国内价格
- 20+0.21516
- 200+0.17144
- 600+0.14713
- 3000+0.14066
- 9000+0.12805
- 21000+0.12128
