8205A
8205A
    HOTTECH(合科泰)
    TSSOP-8
    场效应管 2个N沟道 19.5V 6A
8205A 数据手册
Plastic-Encapsulate Mosfets N-Channel Enhancement Mode Power MOSFET 8205A Description The 8205A uses advanced trench technology to provide excellent RDS(ON), low gate charge and operation with gate voltages as low as 2.5V. This device is suitable for use as a Battery protection or in other Switching application. General Features ● VDS = 19.5V,ID = 6A RDS(ON) < 37mΩ @ VGS=2.5V RDS(ON) < 27mΩ @ VGS=4.5V TSSOP-8 top view ● High Power and current handing capability ● Lead free product is acquired ● Surface Mount Package D1 Application D2 G2 G1 ●Battery protection ●Load switch S2 S1 ●Power management pin Assignment Absolute Maximum Ratings (TA=25℃unless otherwise noted) Parameter Symbol Drain-Source Voltage VDS Gate-Source Voltage VGS Drain Current-Continuous ID Drain Current-Pulsed (Note 1) IDM Maximum Power Dissipation PD Operating Junction and Storage Temperature Range TJ,TSTG Schematic diagram Limit Unit 19.5 V ±10 V 6 A 25 A 1.5 W -55 To 150 ℃ 83 ℃/W Thermal Characteristic Thermal Resistance,Junction-to-Ambient (Note 2) RθJA Electrical Characteristics (TA=25℃unless otherwise noted) Parameter Symbol Condition Min Typ 19.5 21 Max Unit Off Characteristics Drain-Source Breakdown Voltage BVDSS VGS=0V ID=250μA Zero Gate Voltage Drain Current IDSS VDS=19.5V,VGS=0V GUANGDONG HOTTECH INDUSTRIAL CO., LTD V 1 μA Page:P5 -P1 Plastic-Encapsulate Mosfets 8205A Gate-Body Leakage Current IGSS VGS=±10V,VDS=0V ±100 nA Gate Threshold Voltage VGS(th) VDS=VGS,ID=250μA 0.7 1.2 V Drain-Source On-State Resistance RDS(ON) VGS=4.5V, ID=4.5A 21 27 mΩ VGS=2.5V, ID=3.5A 27 37 mΩ VDS=5V,ID=4.5A 10 S 600 PF 330 PF 140 PF On Characteristics (Note 3) Forward Transconductance gFS 0.5 Dynamic Characteristics (Note4) Input Capacitance Clss Output Capacitance Coss Reverse Transfer Capacitance Crss VDS=8V,VGS=0V, F=1.0MHz Switching Characteristics (Note 4) Turn-on Delay Time td(on) Turn-on Rise Time tr td(off) Turn-Off Delay Time Turn-Off Fall Time tf Total Gate Charge Qg Gate-Source Charge Qgs Gate-Drain Charge Qgd 10 20 nS VDD=10V,ID=1A 11 25 nS VGS=4.5V,RGEN=6Ω 35 70 nS 30 60 nS 10 15 nC VDS=10V,ID=6A, VGS=4.5V 2.3 nC 1.5 nC Drain-Source Diode Characteristics Diode Forward Voltage (Note 3) VSD Diode Forward Current (Note 2) IS VGS=0V,IS=1.7A 0.75 1.2 V 1.7 A Notes: 1. Repetitive Rating: Pulse width limited by maximum junction temperature. 2. Surface Mounted on FR4 Board, t ≤ 10 sec. 3. Pulse Test: Pulse Width ≤ 300μs, Duty Cycle ≤ 2%. 4. Guaranteed by design, not subject to production GUANGDONG HOTTECH INDUSTRIAL CO., LTD Page:P5 -P2 Plastic-Encapsulate Mosfets 8205A TYPICAL ELECTRICAL AND THERMAL CHARACTERISTICS Vdd Vgs Rgen td(on) Rl Vin D ton tr td(off) Vout 90% VOUT G toff tf 90% INVERTED 10% 10% 90% S VIN 50% 50% 10% PULSE WIDTH Figure 2:Switching Waveforms PD Power(W) ID- Drain Current (A) Figure 1:Switching Test Circuit TJ-Junction Temperature(℃) TJ-Junction Temperature(℃) Figure 4 Drain Current ID- Drain Current (A) Rdson On-Resistance(mΩ) Figure 3 Power Dissipation Vds Drain-Source Voltage (V) Figure 5 Output CHARACTERISTICS GUANGDONG HOTTECH ID- Drain Current (A) Figure 6 Drain-Source On-Resistance INDUSTRIAL CO., LTD Page:P5 -P3 Plastic-Encapsulate Mosfets ID- Drain Current (A) Normalized On-Resistance 8205A TJ-Junction Temperature(℃) Vgs Gate-Source Voltage (V) Figure 8 Drain-Source On-Resistance C Capacitance (pF) Rdson On-Resistance(mΩ) Figure 7 Transfer Characteristics Vgs Gate-Source Voltage (V) Vds Drain-Source Voltage (V) Figure 10 Capacitance vs Vds Vgs Gate-Source Voltage (V) Is- Reverse Drain Current (A) Figure 9 Rdson vs Vgs Qg Gate Charge (nC) Figure 11 Gate Charge GUANGDONG HOTTECH Vsd Source-Drain Voltage (V) Figure 12 Source- Drain Diode Forward INDUSTRIAL CO., LTD Page:P5 -P4 Plastic-Encapsulate Mosfets ID- Drain Current (A) 8205A Vds Drain-Source Voltage (V) Safe Operation Area r(t),Normalized Effective Transient Thermal Impedance Figure 13 Square Wave Pluse Duration(sec) Figure 14 Normalized Maximum Transient Thermal Impedance GUANGDONG HOTTECH INDUSTRIAL CO., LTD Page:P5 -P5
8205A
物料型号:8205A 器件简介:8205A是一款采用先进沟槽技术的N沟道增强型功率MOSFET,具有优异的RDS(ON)、低栅极电荷,并且能在低至2.5V的栅极电压下工作。适用于电池保护或其他开关应用。
引脚分配:文档中提供了Schematic diagram和TSSOP-8封装的顶视图,但没有详细列出每个引脚的功能。
参数特性: - 漏源电压(Vos):19.5V - 栅源电压(VGs):±10V - 连续漏电流(lo):6A - 脉冲漏电流(IOM):25A - 最大功率耗散(Po):1.5W - 工作结温和存储温度范围(TJ,TsTG):-55至150℃
功能详解: - 具有高功率和电流处理能力 - 无铅产品 - 表面安装封装
应用信息:适用于电池保护、负载开关、电源管理等应用。
封装信息:表面安装型封装,具体封装类型为TSSOP-8。
8205A 价格&库存
很抱歉,暂时无法提供与“8205A”相匹配的价格&库存,您可以联系我们找货
