SS12G THRU SS120G
Surface Mount Schottky Barrier Rectifier
Reverse Voltage - 20 to 200 V Forward Current - 1.0A
PINNING
Features
• Metal silicon junction, majority carrier conduction
• For surface mounted applications
• Low power loss, high efficiency
• High forward surge current capability
• For use in low voltage, high frequency inverters,
free wheeling, and polarity protection applications
PIN
DESCRIPTION
1
Cathode
2
Anode
1
MECHANICAL DATA
• Case: SMA
• Terminals: Solderable per MIL-STD-750, Method 2026
• Approx. Weight: 70mg / 0.0025oz
2
Top View
Marking Code: SS12 ~ SS120
Simplified outline SMA and symbol
Absolute Maximum Ratings and Electrical characteristics
Ratings at 25 °C ambient temperature unless otherwise specified.Single phase, half wave, 60Hz resistive or inductive load,
for capacitive load, derate by 20 %
Symbols
Parameter
SS12G
SS14 G
SS16 G
SS18G
SS110 G SS112 G SS115 G SS120G
Units
Maximum Repetitive Peak Reverse Voltage
V RRM
60
80
100
120
150
200
V
Maximum RMS voltage
V RMS
14
28
42
56
70
84
105
140
V
Maximum DC Blocking Voltage
V DC
60
80
100
120
150
200
V
Maximum Average Forward Rectified Current
at Tc = 85 °C
Peak Forward Surge Current,8.3ms
Single Half Sine-wave Superimposed
on Rated Load (JEDEC method)
Max Instantaneous Forward Voltage at 1 A
Maximum DC Reverse Current
T a = 25°C
at Rated DC Reverse Voltage
T a =100°C
Typical Junction Capacitance (1)
Typical Thermal Resistance
(2)
Operating Junction Temperature Range
Storage Temperature Range
I F(AV)
I FSM
VF
40
0.55
30
0.70
0.85
A
0.90
V
0.1
2
mA
0.2
5
0.3
10
IR
Cj
A
1.0
110
80
pF
RθJA
90
°C/W
Tj
-55 ~ +125
°C
T stg
-55 ~ +150
°C
(1)Measured at 1MHz and applied reverse voltage of 4 V D.C.
(2)P.C.B. mounted with 2.0" X 2.0" (5 X 5 cm) copper pad areas.
1 of 3
SS12G THRU SS120G
Fig.2 Typical Reverse Characteristics
Instaneous Reverse Current ( μA)
Fig.1 Forward Current Derating Curve
Average Forward Current (A)
1.5
1.0
0.5
Single phase half-wave 60 Hz
0.0
25
50
75
100
125
150
10 4
T J =75°C
10 2
SS12G /SS14G
10
SS16G -SS120 G
1
T J =25°C
10 0
Case Temperature (°C)
60
80
100
Fig.4 Typical Junction Capacitance
500
Junction Capacitance ( pF)
1.0
SS12G /SS14G
SS16 G /SS18 G
SS110 G /SS112 G
SS115G /SS120G
0.1
0.4
0.6
0.8
1.0
1.2
1.4
1.6
T J =25°C
200
100
50
SS12G /SS14G
SS16G -SS120 G
10
1.8
0.1
Transient Thermal Impedance( °C /W)
Fig.5 Maximum Non-Repetitive Peak
Forward Surage Current
60
50
SS12G /SS18G
SS110G -SS120 G
40
30
8.3 ms Single Half Sine Wave
(JEDEC Method)
00
1
10
1
10
100
Reverse Voltage (V)
Instaneous Forward Voltage (V)
Peak Forward Surage Current (A)
40
Percent of Rated Peak Reverse Voltage(%)
Fig.3 Typical Forward Characteristic
Instaneous Forward Current (A)
T J =100°C
10 3
100
Number of Cycles at 60Hz
Fig.6- Typical Transient Thermal Impedance
100
10
1
0.01
0.1
1
10
t, Pulse Duration(sec)
2 of 3
100
SS12G THRU SS120G
PACKAGE OUTLINE
Plastic surface mounted package; 2 leads
A
SMA
c
VM
A
HE
g
e
E
g
A
c
D
E
e
g
HE
max
2.2
0.31
4.7
2.9
1.7
1.5
5.4
min
1.9
0.12
4.2
2.3
1.2
0.8
4.7
UNIT
mm
e
A
D
The recommended mounting pad size
Marking
Type number
2.2
(86)
SS12G
SS12
SS14G
SS14
1.8
(71)
1.8
(71)
1.8
(71)
Marking code
mm
Unit :
(mil)
3 of 3
SS16 G
SS16
SS18G
SS18
SS110 G
SS110
SS112G
SS112
SS115G
SS115
SS120G
SS120
很抱歉,暂时无法提供与“SS14G”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 20+0.07810
- 200+0.07260
- 600+0.06710
- 3000+0.06160
- 国内价格
- 1+0.34210
- 500+0.11330
- 2500+0.07579
- 5000+0.06215
- 国内价格
- 50+0.08253
- 500+0.07428
- 5000+0.06878
- 10000+0.06602
- 30000+0.06327
- 50000+0.06162
