B5817WL
B5817WL
    SK(時科)
    SMF(SOD-123FL)
    肖特基二极管 Single VR=20V IF=1A IR=1mA SOD123FL
B5817WL 数据手册
SCHOTTKY BARRIER RECTIFIERS Features • Metal silicon junction, majority carrier conduction • Guarding for overvoltage protection • Low power loss, high efficiency • High current capability • low forward voltage drop • High surge capability • For use in low voltage, high frequency inverters, free wheeling, and polarity protection applications Maximum Ratings and Electrical characteristics Ratings at 25 °C ambient temperature unless otherwise specified. 1 of 4 2 of 4 PACKAGE OUTLINE Plastic surface mounted package; 2 leads SOD123FL Marking Type number marking code B5817WL SJ B5818WL SK B5819WL SL 3 of 4 Recommended peak temperature is over 245 °C. C. If peak temperature is below 245 °C, you may adjust the following parameters; time length of peak temperature (longer), time length of soldering (longer), • Condition of hand soldering Temperature: 320°C Time: 3s max. Times: one time • Remark: Lead free solder paste (96.5Sn/3.0Ag/0.5Cu) 4 of 4 thickness of solder paste (thicker)
B5817WL 价格&库存
很抱歉,暂时无法提供与“B5817WL”相匹配的价格&库存,您可以联系我们找货
B5817WL
  • 5+0.11050
  • 20+0.10075
  • 100+0.09100
  • 500+0.08125
  • 1000+0.07670
  • 2000+0.07345
库存:371
