M7D
M7D
    ST(先科)
    SMA(DO-214AC)
    整流二极管 VRRM=1KV VF=1V SMA
M7D 数据手册
M1D THRU M7D Surface Mount General Purpose Plastic Rectifier Reverse Voltage - 50 to 1000 V Forward Current - 1 A Features • For surface mounted applications • Low profile package • Built-in strain relief • Easy pick and place • Plastic package has Underwriters Laboratory Flammability Classification 94V-0 Mechanical Data • Case: SMA (DO-214AC), molded plastic • Terminals: Solder plated, solderable per MIL-STD-750, method 2026 • Polarity: Indicated by cathode band Absolute Maximum Ratings and Characteristics Ratings at 25OC ambient temperature unless otherwise specified. Single phase, half wave, 60 Hz, resistive or inductive load. For capacitive load, derate current by 20%. Parameter Symbols M1D M2D M3D M4D M5D M6D M7D Units Maximum Repetitive Peak Reverse Voltage VRRM 50 100 200 400 600 800 1000 V Maximum RMS Voltage VRMS 35 70 140 280 420 560 700 V Maximum DC Blocking Voltage VDC 50 100 200 400 600 800 1000 V Maximum Average Forward Rectified Current at Ta = 50 OC IF(AV) 1 A Peak Forward Surge Current 8.3 ms Single Half Sine-wave Superimposed on Rated Load (JEDEC method) IFSM 30 A Maximum Instantaneous Forward Voltage at 1 A VF 1 V Maximum DC Reverse Current at Rated DC Blocking Voltage IR 5 50 µA Typical Thermal Resistance, Junction to Ambient RθJA 55 O Typical Thermal Resistance, Junction to Lead RθJL 25 O TJ, TStg - 55 to + 150 Ta = 25 C Ta = 125 OC Junction and Storage Temperature Range O C/W C/W SEMTECH ELECTRONICS LTD. ® Dated : 21/09/2015 YJ Rev:03 C O M1D THRU M7D SEMTECH ELECTRONICS LTD. ® Dated : 21/09/2015 YJ Rev:03
很抱歉,暂时无法提供与“M7D”相匹配的价格&库存,您可以联系我们找货
M7D
  • 1+0.07150
  • 30+0.06900
  • 100+0.06400
  • 500+0.05900
  • 1000+0.05650
库存:19
