ZMM9V1
ZMM9V1
    ST(先科)
    LL-34(SOD-80)
    硅平面齐纳二极管 Vz=9.1V 8.5V~9.6V IZT=5mA P=500mW
ZMM9V1 数据手册
ZMM 1...ZMM200 SILICON PLANAR ZENER DIODES LL-34 in MiniMELF case especially for automatic insertion. The Zener voltages are graded according to the international E 24 standard. Smaller voltage tolerances and higher Zener voltages are upon request. These diodes are also available in DO-35 case with the type designation BZX55C... Absolute Maximum Ratings (Ta = 25oC) Symbol Value Unit Ptot 500 1) mW Junction Temperature Tj 175 O Storage Temperature Range TS -55 to +175 O Power Dissipation 1) C C Valid provided that electrodes are kept at ambient temperature Characteristics at Tamb = 25oC Thermal Resistance Junction to Ambient Air Forward Voltage at IF = 100mA 1) Symbol Min. Typ. Max. Unit RthA - - 0.31) K/mW VF - - 1 V Valid provided that electrodes are kept at ambient temperature SEMTECH ELECTRONICS LTD. ® (Subsidiary of Sino-Tech International Holdings Limited, a company listed on the Hong Kong Stock Exchange, Stock Code: 724) Dated : 20/09/2005 ZMM 1...ZMM200 Zener Voltage Range1) Type for VZT 2) rZJK at IZK Ω mA Reverse Leakage Current Ta =25oC Ta = 125oC μA Temp coefficient of Zener Voltage TKvz %/K -0.26...-0.23 mA V rZJT Ω μA IR at VR V ZMM 13) 0.75 5 0.7...0.8
ZMM9V1 价格&库存
很抱歉,暂时无法提供与“ZMM9V1”相匹配的价格&库存,您可以联系我们找货
ZMM9V1
  • 1+0.05144
库存:158
ZMM9V1
  • 10+0.22400
  • 200+0.13360
  • 800+0.09350
  • 2500+0.06680
  • 5000+0.06350
  • 25000+0.05880
库存:35000
