ZMM1B...ZMM75B
Silicon Epitaxial Planar Zener Diodes
MiniMELF case especially for automatic insertion.
LL-34
These diodes are also available in DO-35 case with the
type designation BZX55B...
Parameter
Power Dissipation
Symbol
Ptot
Junction Temperature
Tj
Storage Temperature Range
1)
H
C
E
T
M
E
S
Absolute Maximum Ratings (Ta = 25 OC)
Tstg
Valid provided that electrodes are kept at ambient temperature
Value
Unit
1)
mW
500
C
175
O
- 55 to + 175
O
C
Characteristics at Ta = 25 OC
Parameter
Thermal Resistance Junction to Ambient Air
Forward Voltage
at IF = 100 mA
1)
Symbol
RθJA
VF
Max.
0.3
1
1)
Unit
K/mW
V
SEMTECH ELECTRONICS LTD.
Subsidiary of Sino-Tech International (BVI) Limited
Dated : 17/08/2011 Rev: 03
ZMM1B...ZMM75B
Zener Voltage Range
Type
ZMM1B
2)
1)
Dynamic Resistance
Reverse Leakage Current
VZnom
VZT
at IZT
ZZT
ZZK
at IZK
Ta = 25 OC
Ta = 125 C
at VR
Temp coefficient
of Zener Voltage
(V)
(V)
(mA)
Max. (Ω)
Max. (Ω)
(mA)
Max. (µA)
Max. (µA)
(V)
TKvz (%/K)
o
0.75
0.73…0.77
5
8
50
1
-0.26...-0.23
ZMM2B0
2
1.96…2.04
5
85
600
1
100
200
1
-0.09...-0.06
ZMM2B2
2.2
2.16…2.24
5
85
600
1
75
160
1
-0.09...-0.06
ZMM2B4
2.4
2.35…2.45
5
85
600
1
50
100
1
-0.09...-0.06
ZMM2B7
2.7
2.65…2.75
5
85
600
1
10
50
1
-0.09...-0.06
ZMM3B0
3
2.94…3.06
5
85
600
1
4
40
1
-0.08...-0.05
ZMM3B3
3.3
3.23…3.37
5
85
600
1
2
40
1
-0.08...-0.05
ZMM3B6
3.6
3.53…3.67
5
85
600
1
2
40
1
-0.08...-0.05
ZMM3B9
3.9
3.82…3.98
5
85
600
1
2
40
1
-0.08...-0.05
ZMM4B3
4.3
4.21…4.39
5
75
600
1
1
-0.06...-0.03
ZMM4B7
4.7
4.61…4.79
5
60
600
1
0.5
10
1
-0.05...+0.02
ZMM5B1
5.1
5…5.2
5
35
550
1
0.1
2
1
-0.02...+0.02
ZMM5B6
5.6
5.49…5.71
5
25
450
1
0.1
2
1
-0.05...+0.05
ZMM6B2
6.2
6.08…6.32
5
10
200
1
0.1
2
2
0.03...0.06
ZMM6B8
6.8
6.66…6.94
5
8
150
1
0.1
2
3
0.03...0.07
ZMM7B5
7.5
7.35…7.65
5
7
50
1
0.1
2
5
0.03...0.07
ZMM8B2
8.2
8.04…8.36
5
7
50
1
0.1
2
6.2
0.03...0.08
ZMM9B1
9.1
8.92…9.28
5
10
50
1
0.1
2
6.8
0.03...0.09
ZMM10B
10
9.8…10.2
5
15
70
1
0.1
2
7.5
0.03...0.1
ZMM11B
11
10.78…11.22
5
1
0.1
2
8.2
0.03...0.11
ZMM12B
12
11.76…12.24
5
1
0.1
ZMM13B
13
12.74…13.26
5
26
110
1
0.1
ZMM15B
15
14.7…15.3
5
30
110
1
ZMM16B
16
15.68…16.32
5
40
170
ZMM18B
18
17.64…18.36
5
50
ZMM20B
19.6…20.4
5
55
ZMM22B
22
21.56…22.44
5
ZMM24B
24
23.52…24.48
ZMM27B
27
26.46…27.54
ZMM30B
30
ZMM33B
33
E
T
M
E
S
H
C
2
9.1
0.03...0.11
2
10
0.03...0.11
0.1
2
11
0.03...0.11
1
0.1
2
12
0.03...0.11
170
1
0.1
2
13
0.03...0.11
220
1
0.1
2
15
0.03...0.11
55
220
1
0.1
2
16
0.04...0.12
5
80
220
1
0.1
2
18
0.04...0.12
5
80
220
1
0.1
2
29.4…30.6
5
80
220
1
0.1
2
22
0.04...0.12
32.34…33.66
5
80
220
1
0.1
2
24
0.04...0.12
ZMM36B
36
35.28…36.72
5
80
220
1
0.1
2
27
0.04...0.12
ZMM39B
39
38.22…39.78
2.5
90
500
0.5
0.1
5
30
0.04...0.12
ZMM43B
43
42.14…43.86
2.5
90
500
0.5
0.1
5
33
0.04...0.12
ZMM47B
47
46.06…47.94
2.5
110
600
0.5
0.1
5
36
0.04...0.12
ZMM51B
51
49.98…52.02
2.5
125
700
0.5
0.1
10
39
0.04...0.12
ZMM56B
56
54.88…57.12
2.5
135
700
0.5
0.1
10
43
0.04...0.12
ZMM62B
62
60.76…63.24
2.5
150
1000
0.5
0.1
10
47
0.04...0.12
ZMM68B
68
66.64…69.36
2.5
200
1000
0.5
0.1
10
51
0.04...0.12
ZMM75B
75
73.5…76.5
2.5
250
1000
0.5
0.1
10
56
0.04...0.12
1)
Tested with pulses tp = 20 ms.
2)
The ZMM1B is a silicon diode with operation in forward direction. Hence, the index of all parameters should be "F" instead of "Z". Connect the cathode
electrode to the negative pole.
ZMM1B...ZMM75B
Breakdown characteristics
Tj = constant (pulsed)
mA
50
ZMM3B3 ZMM3B9 ZMM4B7
Tj=25o C
ZMM6B8
ZMM...
ZMM2B7
ZMM1B
Iz
40
ZMM8B2
ZMM5B6
30
H
C
Test current Iz
5mA
10
E
T
M
E
S
2
3
5
4
7
6
Vz
mA
30
ZMM10B
8
10 V
9
ZMM...
Tj=25o C
ZMM12B
Iz
ZMM15B
ZMM18B
ZMM22B
ZMM27B
Test current Iz
5mA
10
ZMM33B
ZMM36B
30
40 V
Vz
ZMM1B...ZMM75B
mA
10
Iz
ZMM...
Tj=25o C
ZMM39B
ZMM51B
ZMM43B
ZMM47B
8
Test current Iz
5mA
H
C
6
4
E
T
M
E
S
2
40
50
60
70
Vz
80
90
100 V
Admissible power dissipation
versus ambient temperature
Forward characteristics
at ambient temperature.
mA
10
ZMM...
mW
500
ZMM...
3
10 2
iF
P tot
400
10
o
Tj=100 C
1
300
o
Tj=25 C
10
10
10
10
-1
200
-2
-3
100
-4
10 -5
0.4
0.6
0.8
1V
VF
200o C
100
Tamb
很抱歉,暂时无法提供与“ZMM3B3”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 20+0.15045
- 200+0.11772
- 600+0.09958
- 2500+0.08619
- 10000+0.07679
- 20000+0.07172
