SS22AD THRU SS210AD
SURFACE MOUNT SCHOTTKY BARRIER RECTIFIER
Reverse Voltage - 20 to 100 V
Forward Current - 2 A
Features
• Metal silicon junction, majority carrier conduction
• Low power loss, high efficiency
• The plastic package carries Underwriters Laboratory
flammability Classification 94V-0
• High forward surge current capability
• Built-in strain relief, ideal for automated placement
H
C
Mechanical Data
• Case: SMA (DO-214AC) molded plastic body
• Terminals: Leads solderable per MIL-STD-750,
Method 2026
• Polarity: Color band denotes cathode end
• Mounting Position: Any
E
T
M
E
S
Maximum Ratings and Electrical Characteristics
Ratings at 25 OC ambient temperature unless otherwise specified. Single phase, half wave 60 Hz, resistive or inductive load,
For capacitive load current derate by 20 %.
Parameter
Symbol SS22AD SS23AD SS24AD SS25AD SS26AD SS28AD SS210AD Unit
Maximum Repetitive Peak Reverse Voltage
VRRM
40
50
60
80
100
V
Maximum RMS Voltage
VRMS
14
21
28
35
42
56
70
V
Maximum DC Blocking Voltage
VDC
40
50
60
80
100
V
Maximum Average Forward Rectified Current
IF(AV)
2
A
Peak Forward Surge Current 8.3 ms Single Half
Sine Wave Superimposed on Rated Load
(JEDEC Method)
IFSM
50
A
Maximum Instantaneous Forward Voltage at 2 A
VF
Maximum DC Reverse Current at
Rated DC Blocking Voltage
IR
Ta = 25 OC
Ta = 100 OC
Typical Junction Capacitance 1)
Typical Thermal Resistance 2)
Operating Junction Temperature Range
Storage Temperature Range
1)
2)
0.55
0.85
V
0.5
Cj
220
180
RθJA
Tj
0.75
75
- 65 to + 125
Tstg
mA
pF
C/W
O
- 65 to + 150
- 65 to + 150
C
O
C
O
Measured at 1MHz and applied reverse voltage of 4 V DC.
P.C.B mounted with 0.2 X 0.2" (5 X 5 mm) copper pad areas.
SEMTECH ELECTRONICS LTD.
Subsidiary of Sino-Tech International (BVI) Limited
Dated:22/03/2012 C Rev:02
SS22AD THRU SS210AD
H
C
E
T
M
E
S
很抱歉,暂时无法提供与“SS24AD”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 3+0.56409
- 30+0.45015
- 90+0.39312
- 国内价格
- 1+0.27000
- 10+0.26000
- 100+0.23600
- 500+0.22400
