SS14D
SS14D
    ST(先科)
    SMA(DO-214AC)
    肖特基二极管 Single VR=40V IF=1A SMA
SS14D 数据手册
SS12D THRU SS110D SURFACE MOUNT SCHOTTKY BARRIER RECTIFIERS Reverse Voltage - 20 to 100 V Forward Current - 1 A Features • Plastic package has Underwriters Laboratory Flammability Classification 94V-0 • For surface mounted applications • Metal silicon junction, majority carrier conduction • Built-in strain relief, ideal for automated placement • Low power loss, high efficiency. • High forward surge current capability Mechanical Data • Case: SMA (DO-214AC) molded plastic body • Terminals: leads solderable per MIL-STD-750, Method 2026 • Polarity: color band denotes cathode end M E E T Maximum Ratings and Electrical Characteristics H C Ratings at 25℃ ambient temperature unless otherwise specified. Single phase, half wave, resistive or inductive load, for capacitive load, derate by 20 % Parameter Symbols SS12D SS13D SS14D SS15D SS16D SS18D SS110D Unit Maximum Repetitive Peak Reverse Voltage VRRM 20 30 40 50 60 80 100 V Maximum RMS Voltage VRMS 14 21 28 35 42 56 70 V Maximum DC Blocking Voltage VDC 20 30 40 50 60 80 100 V Maximum Average Forward Rectified Current IF(AV) 1 A Peak Forward Surge Current 8.3 ms Single Half Sine-wave Superimposed on Rated Load (JEDEC Method) IFSM 30 A Maximum Instantaneous Forward Voltage at 1 A VF S Maximum DC Reverse Current Ta = 25℃ at Rated DC Blocking Voltage Ta = 100℃ Typical Junction Capacitance 1) Typical Thermal Resistance 2) Operating Junction Temperature Range Storage Temperature Range 1) Measured at 1MHz and applied reverse voltage of 4 V D.C. 2) P.C.B. mounted with 0.2 X 0.2" (5 X 5 mm) copper pad areas. 0.55 IR 0.75 0.85 0.5 mA 20 Cj 110 pF RθJA 88 ℃/W Tj - 55 to + 125 ℃ Tstg - 55 to + 150 ℃ SEMTECH ELECTRONICS LTD. ® V Dated:03/01/2015 Rev:03 SS12D THRU SS110D M E S E T H C SEMTECH ELECTRONICS LTD. ® Dated:03/01/2015 Rev:03
SS14D 价格&库存
很抱歉,暂时无法提供与“SS14D”相匹配的价格&库存,您可以联系我们找货
SS14D
  • 10+0.25641
  • 15+0.25256
库存:15
SS14D
    • 5000+0.05570
