SS34AD
SS34AD
    ST(先科)
    SMA(DO-214AC)
    表面贴装肖特基势垒整流器,反向电压-20至100 V,正向电流-3 A
SS34AD 数据手册
SS32AD THRU SS310AD Surface Mount Schottky Barrier Rectifiers Reverse Voltage - 20 to 100 V Forward Current - 3 A Features • Plastic package has Underwriters Laboratory Flammability Classification 94V-0 • For surface mounted applications • Metal silicon junction, majority carrier conduction • Low power loss, high efficiency. • High current capability, low forward voltage drop H C Mechanical Data • Case: SMA (DO-214AC) molded plastic body • Terminals: leads solderable per MIL-STD-750, Method 2026 • Polarity: color band denotes cathode end E T M E S Maximum Ratings and Electrical Characteristics Ratings at 25℃ ambient temperature unless otherwise specified. Single phase, half wave, resistive or inductive load, for capacitive load, derate by 20 % Parameter Symbols SS32AD SS33AD SS34AD SS35AD SS36AD SS38AD SS310AD Unit Maximum Repetitive Peak Reverse Voltage VRRM 20 30 40 50 60 80 100 V Maximum RMS Voltage VRMS 14 21 28 35 42 56 70 V Maximum DC Blocking Voltage VDC 20 30 40 50 60 80 100 V Maximum Average Forward Rectified Current IF(AV) 3 A Peak Forward Surge Current 8.3 ms Single Half Sine-wave Superimposed on Rated Load (JEDEC Method) IFSM 100 A Maximum Instantaneous Forward Voltage at 3 A VF Maximum DC Reverse Current at Rated DC Blocking Voltage Ta = 25℃ Ta = 100℃ Typical Thermal Resistance 1) Operating Junction Temperature Range Storage Temperature Range 1) 0.55 0.7 0.85 V IR 0.5 20 RθJA RθJL 55 17 Tj - 55 to + 125 O Tstg - 55 to + 150 O mA C/W O C C P.C.B. mounted with 0.55 X 0.55 " (14 X 14 mm) copper pad areas. SEMTECH ELECTRONICS LTD. Subsidiary of Sino-Tech International (BVI) Limited ® Dated:11/05/2013 T Rev:03 SS32AD THRU SS310AD H C E T M E S SEMTECH ELECTRONICS LTD. Subsidiary of Sino-Tech International (BVI) Limited ® Dated:11/05/2013 T Rev:03
SS34AD
物料型号: - SS32AD - SS33AD - SS34AD - SS35AD - SS36AD - SS38AD - SS310AD
器件简介: - 这些整流器是表面安装肖特基势垒整流器,具有20至100V的反向电压和3A的正向电流。 - 它们具有UL94V-0的塑料封装,适用于表面安装应用。 - 由金属硅结和多数载流子导电组成,具有低功耗和高效率。 - 具有高电流能力和低正向电压降。
引脚分配: - 封装类型为SMA(DO-214AC)塑料体。 - 引脚按照MIL-STD-750方法2026可焊接。 - 极性通过色带表示阴极端。
参数特性: - 最大重复峰值反向电压:20V至100V。 - 最大RMS电压:14V至70V。 - 最大直流阻断电压:与重复峰值反向电压相同。 - 最大平均正向整流电流:对于SS34AD为3A。 - 正向浪涌电流:对于SS34AD为100A(8.3毫秒单半正弦波叠加在额定负载上)。 - 最大瞬时正向电压:对于SS32AD至SS34AD为0.55V至0.85V。 - 最大直流反向电流:对于SS34AD在25°C和100°C下为0.5mA至20mA。 - 典型热阻:对于SS34AD为55°C/W至17°C/W。
功能详解: - 提供了正向电流降额曲线,显示了在不同铜垫尺寸下的最大非重复性峰值正向电流。 - 提供了典型瞬时正向电压特性图表,显示了在不同负载下的特性。 - 提供了典型瞬态热阻抗图表,显示了在不同反向电压和脉冲持续时间下的特性。
应用信息: - 这些整流器适用于需要高效率和低功耗的应用。
封装信息: - 封装类型为SMA(DO-214AC),尺寸为0.087(2.21)×0.110(2.80)英寸,引脚间距为0.039(1.0)×0.086(2.18)英寸。
SS34AD 价格&库存
很抱歉,暂时无法提供与“SS34AD”相匹配的价格&库存,您可以联系我们找货
SS34AD
  • 1+0.62350
  • 30+0.60200
  • 100+0.55900
  • 500+0.51600
  • 1000+0.49450
SS34AD
  • 10+1.83100
  • 300+1.09230
  • 1000+0.76460
  • 5000+0.54610
  • 10000+0.51890
  • 50000+0.48060
