Approval sheet
WF12G, WF08G, WF06G, WF04G
±1%, ±5%, 11MΩ~100MΩ
High ohm chip resistors
Size 1206, 0805, 0603, 0402
*Contents in this sheet are subject to change without prior notice
Page 1 of 7
ASC_WFxxG_V13
Feb - 2015
Approval sheet
FEATURE
1. Small size and light weight
2. High reliability and stability
3. Reduced size of final equipment
4. Higher component and equipment reliability
5. RoHS compliant and lead free products.
APPLICATION
Power supply
PDA
Digital meter
Computer
Palmtop computers
DESCRIPTION
The resistors are constructed in a high grade ceramic body (aluminum oxide). Internal metal electrodes are
added at each end and connected by a resistive paste that is applied to the top surface of the substrate. The
composition of the paste is adjusted to give the approximate resistance required and the value is trimmed to
nominated value within tolerance which controlled by laser trimming of this resistive layer.
The resistive layer is covered with a protective coat. Finally, the two external end terminations are added. For
ease of soldering the outer layer of these end terminations is Tin (lead free) alloy.
Fig 1. Construction of Chip-R
Page 2 of 7
ASC_WFxxG_V13
Feb - 2015
Approval sheet
QUICK REFERENCE DATA
Item
General Specification
Series No.
WF12G
WF08G
WF06G
WF04G
Size code
1206 ( 3216 )
0805 ( 2125 )
0603 ( 1608 )
0402 ( 1005 )
±1%, ±5%
Resistance Tolerance
Resistance Range
TCR (ppm/°C)
10MΩ < R ≤ 100MΩ
10MΩ < R ≤ 30MΩ
( E24 series)
≤ ± 200 ppm/°C
≤ ± 300 ppm/°C
Max. dissipation at Tamb=70°C
1/4 W
1/8 W
1/10 W
1/16W
Max. Operation Voltage (DC or RMS)
200V
150V
50V
50V
Climatic category (IEC 60068)
55/155/56
Note :
1.
This is the maximum voltage that may be continuously supplied to the resistor element, see “IEC publication
60115-8”
2.
Max. Operation Voltage : So called RCWV (Rated Continuous Working Voltage) is determined by
RCWV = Rated Power × Resistance Value or Max. RCWV listed above, whichever is lower.
DIMENSIONS(unit : mm)
series
WF12G
WF08G
WF06G
WF04G
L
3.10 ± 0.15
2.00 ± 0.10
1.60 ± 0.10
1.00 ± 0.05
W
1.60 ± 0.15
1.25 ± 0.10
0.80 ± 0.10
0.50 ± 0.05
Tt
0.50 ±0.25
0.40 ± 0.20
0.30 ± 0.10
0.20 ± 0.10
Tb
0.50 ± 0.25
0.40 ± 0.20
0.30 ± 0.15
0.25 ± 0.10
T
0.55 ± 0.10
0.50 ± 0.15
0.45 ± 0.15
0.35 ± 0.05
MARKING
3-digits marking
Each resistor is marked with a three digits code on the protective coating to designate the nominal resistance
value.
Example
306 = 30 MΩ
186 = 18 MΩ
Page 3 of 7
ASC_WFxxG_V13
Feb - 2015
Approval sheet
FUNCTIONAL DESCRIPTION
Product characterization
Standard values of nominal resistance are taken from the E96 & E24 series for resistors with a tolerance of
±1%, ±5%. The values of the E24/E96 series are in accordance with “IEC publication 60063”.
Derating
The power that the resistor can dissipate depends on the operating temperature; see Fig.2
Figure 2. Maximum dissipation in percentage of rated power
As a function of the ambient temperature
SOLDERING CONDITION
The robust construction of chip resistors allows them to be completely immersed in a solder bath of 260°C for 10
seconds. Therefore, it is possible to mount Surface Mount Resistors on one side of a PCB and other discrete
components on the reverse (mixed PCBs).
Surface Mount Resistors are tested for solderability at 235°C during 2 seconds. The test condition for no
leaching is 260°C for 30 seconds. Typical examples of soldering processes that provide reliable joints without
any damage are given in below. WF04G is not guaranteed with wave soldering process due to its 0402 size.
Page 4 of 7
ASC_WFxxG_V13
Feb - 2015
Approval sheet
CATALOGUE NUMBERS
The resistors have a catalogue number starting with :
WF06
G
226_
J
T
L
Size code
Type code
Resistance code
Tolerance
Packaging code
Termination code
WF12
: 1206
G : High ohmic >10MΩ
J : ±5%
T
: 7” Reeled taping
WF08
: 0805
1206 size=0.25W
5% E24: 2 significant digits
followed by no. of zeros
and a blank
F : ±1%
B
: Bulk
L = Sn base (lead
free)
WF06
: 0603
0805 size=0.125W
WF04
: 0402
0603 size=0.10W
11MΩ
=116_
22MΩ
=226_
30MΩ
=306_
(“_” means a blank)
1%, E24+E96: 3 significant
digits followed by no. of
zeros
100Ω
=1000
37.4KΩ
=3742
1.
Reeled tape packaging
: 8mm width paper taping 5000pcs per 7” reel for 1206, 0805, 0603 ( 10,000pcs for 0402 )
2.
Bulk packaging
: 5000pcs per polybag
TEST AND REQUIREMENTS(JIS C 5201-1 : 1998)
TEST
Temperature
Coefficient of
Resistance (T.C.R)
Clause 4.8
PROCEDURE
Natural resistance change per change in degree centigrade.
R2 − R1
× 106
R1 (t2 − t1 )
REQUIREMENT
Refer to quick reference data for
T.C.R specification.
(ppm/°C)
R1 : Resistance at reference temperature
R2 : Resistance at test temperature
t1 : 20°C+5°C-1°C
t2 : Test temperature.
Short time overload
(S.T.O.L)
Permanent resistance change after a 5 second application of a No visible damage.
voltage 2.5xUR or max. Overload voltage, whichever is less.
∆R/R max. J:≦ ±(2%+0.1Ω)
Clause 4.13
Solderability
Clause 4.17
Resistance to
soldering
heat(R.S.H)
F:≦ ±(1%+0.05Ω)
Un-mounted chips completely immersed for 2±0.5 second in a SAC good tinning (>95% covered)
solder bath at 235℃±5℃.
no visible damage
Un-mounted chips completely immersed for 10±1second in a SAC No visible damage.
solder bath at 260℃±5ºC
∆R/R max. J:≦ ±(1%+0.1Ω)
F:≦ ±(0.5%+0.05Ω)
Clause 4.18
Page 5 of 7
ASC_WFxxG_V13
Feb - 2015
Approval sheet
TEST
PROCEDURE
REQUIREMENT
Temperature cycling 1.
30 minutes at -55°C±3°C,
No visible damage.
Clause 4.19
2.
2~3 minutes at 20°C+5°C-1°C,
∆R/R max. J≦ ±(1%+0.1Ω)
3.
30 minutes at +155°±3°C,
4.
F≦ ±(0.5%+0.05Ω)
Total 5 continuous cycles.
Load life
(endurance)
1000 +48/-0 hours, loaded with RCWV or Vmax in chamber No visible damage.
controller 70±2ºC, 1.5 hours on and 0.5 hours off
∆R/R max. J≦ ±(3%+0.1Ω)
Clause 4.25
F≦ ±(1%+0.05Ω)
Load life in Humidity 1000 +48/-0 hours, loaded with RCWV or Vmax in humidity chamber No visible damage.
controller at 40°C±2°C and 90~95% relative humidity, 1.5hours on
Clause 4.24
and 0.5 hours off
F≦ ±(1%+0.05Ω)
Bending strength
Clause 4.33
Adhesion
Resistors mounted on a 90mm glass epoxy resin PCB(FR4); ∆R/R max. ±(1%+0.10Ω)
bending : 3 mm, once for 10 seconds
Pressurizing force: 5N, Test time: 10±1sec.
Clause 4.32
Insulation Resistance Apply the maximum overload voltage (DC) for 1minute
No remarkable damage or
removal of the terminations.
R≧10GΩ
Clause 4.6
Dielectric Withstand
Apply the maximum overload voltage (AC) for 1 minute
No breakdown or flashover
Voltage
Clause 4.7
Page 6 of 7
ASC_WFxxG_V13
Feb - 2015
Approval sheet
PACKAGING
Paper Tape specifications (unit :mm)
Series No.
A
B
W
F
E
WF12G
3.60±0.20
2.00±0.20
8.00±0.30
3.50±0.2
1.75±0.10
WF08G
2.40±0.20
1.65±0.20
8.00±0.30
3.50±0.2
1.75±0.10
WF06G
1.90±0.20
1.10±0.20
8.00±0.30
3.50±0.2
1.75±0.10
WF04G
1.20±0.10
0.70±0.10
8.00±0.30
3.50±0.2
1.75±0.10
P1
P0
ΦD
T
WF12G
4.00±0.10
4.00±0.10
WF08G
4.00±0.10
4.00±0.10
WF06G
4.00±0.10
4.00±0.10
WF04G
2.00±0.10
4.00±0.10
Series No.
Max. 1.0
Φ1.50 +−00..10
0.65±0.1
0.40±0.05
Reel dimensions
Symbol
A
B
C
D
(unit : mm)
Φ178.0±2.0
Φ60.0±1.0
13.0±0.2
9.0±0.5
Taping quantity
Chip resistors 5,000 pcs/reel for 1206, 0805, 0603 ( 10,000 pcs/reel for 0402 )
Page 7 of 7
ASC_WFxxG_V13
Feb - 2015
很抱歉,暂时无法提供与“WF06G206JTL”相匹配的价格&库存,您可以联系我们找货
