WK08S1R0JTL
WK08S1R0JTL
    WALSIN(华新科)
    贴片电阻 0805 1Ω ±5% 1/4W ±100ppm/℃
WK08S1R0JTL 数据手册
Approval sheet WK25S WK20S WK10S WK12S WK08S WK06S ±5%, 5%, ±10% 10%, ±20% 20% Thick Film Power Surge Chip Resistors Size 2512 , 2010 , 1210, 1206 , 0805, 0603 *Contents in this sheet are subject to change without prior notice. Page 1 of 7 ASC_WKxxS_V04 OCT 2015 Approval sheet FEATURE 1. High power rating and compact size 2. High reliability and stability 3. Reduced size of final equipment 4. High anti-surge protection 5. Halogen free APPLICATION • Power supply • Measurement instrument • Automotive industry • Medical or Military equipment DESCRIPTION The resistors are constructed in a high grade ceramic body (aluminum oxide). Internal electrodes are added at each end and connected by a resistive paste that is applied to the top surface of the substrate. The composition of the paste is adjusted to request resistance to nominal value within tolerance which controlled by printing process in this resistive layer. The resistive layer is covered with a protective coat. Finally, the two external end terminations are added. For ease of soldering the outer layer of these end terminations is a Tin (Pb free) alloy. Fig 1. Construction of Chip-R WKxxS Page 2 of 7 ASC_WKxxS_V04 OCT 2015 Approval sheet QUICK REFERENCE DATA Item General Specification Series No. WK25S WK20S WK10S WK12S WK08S WK06S Size code 2512(6432 ) 2010 (5025) 1210 (3225) 1206 ( 3216 ) 0805 (2012) 0603 (1608) ±5% ±10% ±20% (E24) Resistance Tolerance Resistance Range 0.27Ω ~ 22MΩ 1Ω ~ 1MΩ 1.1MΩ ~ 22MΩ ± 200 ppm /°C 10 - 1MΩ: ± 100 ppm /°C 1Ω ~ 1MΩ ± 100 ppm /°C 1 - 9.1Ω: ± 200 ppm /°C 0.27Ω ~ 0.91Ω ± 200 ppm /°C TCR (ppm/°C) Max. dissipation at Tamb=70°C 1W 3/4W 1/2W 1/3W 1/4W 1/4W Max. Operation Voltage 200V 200V 200V 200V 150V 150V Max. Overload Voltage 400V 400V 400V 400V 300V 300V Operation temperature - 55 ~ +155’C Note : 1. This is the maximum voltage that may be continuously supplied to the resistor element, see “IEC publication 60115-8” 2. Max. Operation Voltage : So called RCWV (Rated Continuous Working Voltage) is determined by RCWV = Rated Power × Resistance Value or Max. RCWV listed above, whichever is lower. MECHANICAL DATA(unit : mm) 101 Symbol WK25S WK20S WK10S WK12S WK08S WK06S L 6.30±0.15 5.00±0.15 3.10±0.15 3.10±0.15 2.00 ± 0.10 1.60 ± 0.10 W 3.20±0.15 2.50±0.15 2.50±0.15 1.60±0.15 1.25 ± 0.10 0.80 +0.15/-0.05 T 0.55±0.15 0.55±0.15 0.55±0.15 0.55±0.10 0.55 ± 0.10 0.45 ± 0.10 Tt 0.30±0.15 0.30±0.15 0.30±0.20 0.30±0.20 0.30 ± 0.20 0.30 ± 0.20 Tb 0.60±0.20 0.60±0.20 0.50±0.25 0.50±0.25 0.40 ± 0.20 0.30 ± 0.10 Page 3 of 7 ASC_WKxxS_V04 OCT 2015 Approval sheet MARKING 1. Each resistor is marked with a three-digit code on the protective coating to designate the nominal resistance value. Single pulse limiting power chart WKxxS Surge resistor single pulse chart 10000 WK25S WK20S WK10S WK12S WK08S WK06S Pulse power ( W) 1000 100 10 1 1 10 100 1000 Duration time (msec) De-rating curve The power that the resistor can dissipate depends on the operating temperature; see Fig.2 Page 4 of 7 ASC_WKxxS_V04 OCT 2015 Approval sheet MOUNTING Due to their rectangular shapes and small tolerances, Surface Mountable Resistors are suitable for handling by automatic placement systems. Chip placement can be on ceramic substrates and printed-circuit boards (PCBs). Electrical connection to the circuit is by individual soldering condition. The end terminations guarantee a reliable contact. SOLDERING CONDITION The robust construction of chip resistors allows them to be completely immersed in a solder bath of 260°C for 10 seconds. Therefore, it is possible to mount Surface Mount Resistors on one side of a PCB and other discrete components on the reverse (mixed PCBs). Surface Mount Resistors are tested for solderability at 235°C during 2 seconds. The test condition for no leaching is 260°C for 30 seconds. Typical examples of soldering processes that provide reliable joints without any damage are given in Fig 3. Fig 3. Infrared soldering profile for Chip Resistors CATALOGUE NUMBERS The resistors have a catalogue number starting with . WK25 S Size code Type code Resistance code Tolerance Packaging code Termination code WK25 : 2512 S : surge E24 : 3 significant digits followed by no. of zeros and a blank J: ±5% T : 7” Reeled taping L = Sn base (lead free) WK20 : 2010 WK10 : 1210 WK12 : 1206 472_ 472 = 4K7ohm R820 = 0.82ohm J K: ±10% T L M: ±20% WK08 : 0805 WK06 : 0603 Taping quantity - 1210, 1206, 0805, 0603 Chip resistors 5,000 pcs paper tape per reel. - 2010, 2512 Chip resistors 4,000 pcs plastic tape per reel. Page 5 of 7 ASC_WKxxS_V04 OCT 2015 Approval sheet TEST AND REQUIREMENTS(JIS C 5201-1 : 1998) TEST Temperature Coefficient of Resistance(T.C.R) Clause 4.8 PROCEDURE Natural resistance change per change in degree centigrade. R2 − R1 × 106 R1 (t2 − t1 ) (ppm/°C) REQUIREMENT Refer to “QUICK REFERENCE DATA” t1 : 20°C+5°C-1°C R1 : Resistance at reference temperature R2 : Resistance at test temperature Short time overload (S.T.O.L) Clause 4.13 Permanent resistance change after a 2 second application of ∆R/R max. ±(1%+0.05Ω) a voltage 2.5 times RCWV or the maximum overload voltage no visible damage specified in the above list, whichever is less. Resistance to soldering heat(R.S.H) Clause 4.18 Un-mounted chips completely immersed for 10±1second in a no visible damage solder bath at 260℃±5ºC ∆ R/R max. ±(1%+0.05Ω) Solderability Un-mounted chips completely immersed for 2±0.5second in good tinning (>95% covered) a solder bath at 235℃±5℃ no visible damage Clause 4.17 Temperature cycling Clause 4.19 Load life (endurance) Clause 4.25 Load life in Humidity Clause 4.24 Endurance at high temperature 30 minutes at -55°C±3°C, 2~3 minutes at 20°C+5°C-1°C, 30 minutes at +155°C±3°C, 2~3 minutes at 20°C+5°C-1°C, total 5 cycles Clause 4.33 ∆R/R max. ±(1%+0.05Ω) 70±2ºC, 1000 hours, loaded with RCWV or Vmax,1.5 hours ∆R/R max. ±(5%+0.1Ω) on and 0.5 hours off no visible damage 1000 hours, at rated continuous working voltage in humidity ∆R/R max. ±(5%+0.1Ω) chamber controller at 40°C±2°C and 90~95% relative no visible damage humidity, 1.5hours on and 0.5 hours off 155ºC, no load, 1000hours ∆R/R max. ±(5%+0.1Ω) no visible damage Clause 4.25.3 Bending strength no visible damage Resistors mounted on a 90mm glass epoxy resin PCB(FR4); ∆R/R max. ±(1%+0.05Ω) 2512, 2010 bending : 1 mm, once for 10 seconds 1210, 1206, 0805 bending : 3 mm, once for 10 seconds Adhesion Pressurizing force: 5N, Test time: 10±1sec. No remarkable damage or removal of the terminations Insulation Resistance Apply the maximum overload voltage (DC) for 1minute R≧1GΩ Clause 4.6 Dielectric Withstand Apply the maximum overload voltage (AC) for 1 minute No breakdown or flashover Clause 4.32 Voltage Clause 4.7 Page 6 of 7 ASC_WKxxS_V04 OCT 2015 Approval sheet PACKAGING Tape specifications (unit :mm) Series No. A B W F E WK25S 6.90±0.20 3.60±0.20 WK20S 5.50±0.20 3.100±0.20 12.00±0.30 5.50±0.05 1.75±0.10 WK10S 3.50±0.20 2.85±0.20 8.00±0.30 3.50±0.05 1.75±0.10 WK12S 3.60±0.20 2.00±0.15 WK08S 2.50±0.20 1.65±0.15 8.00±0.20 3.50±0.05 1.75±0.10 WK06S 1.90±0.20 1.15±0.15 8.00±0.30 3.50±0.05 1.75±0.10 Series No. P1 P0 ΦD T WK25S 1.1±0.15 WK20S WK10S 4.00±0.10 1.0±0.20 Φ1.50 +−00..10 4.00±0.10 WK12S Max. 1.0 WK08S Max. 1.0 WK06S Max. 0.8 Reel dimensions Reel / Tape 7” reel for 8mm tape 7” reel for 12mm tape A B C Φ180.0+0/-1.5 Φ60.0+1/0 13.0±0.2 D 9+1.0/0 13+1.0/0 Taping quantity - 1210, 1206 0805, 0603 Chip resistors 5,000 pcs paper tape per reel. - 2010, 2512 Chip resistors 4,000 pcs plastic tape per reel. Page 7 of 7 ASC_WKxxS_V04 OCT 2015
WK08S1R0JTL 价格&库存
很抱歉,暂时无法提供与“WK08S1R0JTL”相匹配的价格&库存,您可以联系我们找货
