Approval sheet
WR10X(W)
±1%, ±5%
Thick film Technology
General purpose chip resistors
Size 1210
Page 1 of 8
ASC_WR10X(W)_V13
Oct.- 2011
Approval sheet
FEATURE
1. High reliability and stability
2. Reduced size of final equipment
3. Lower assembly costs
4. Higher component and equipment reliability
5. RoHS compliant and Lead free products
APPLICATION
Consumer electrical equipment
Automotive application
EDP, Computer application
Telecom application
DESCRIPTION
The resistors are constructed in a high grade ceramic body (aluminum oxide). Internal metal electrodes are
added at each end and connected by a resistive paste that is applied to the top surface of the substrate. The
composition of the paste is adjusted to give the approximate resistance required and the value is trimmed to
nominated value within tolerance which controlled by laser trimming of this resistive layer.
The resistive layer is covered with a protective coat. Finally, the two external end terminations are added. For
ease of soldering the outer layer of these end terminations is Tin (lead free) alloy.
Fig 1. Construction of Chip-R
Page 2 of 8
ASC_WR10X(W)_V13
Oct.- 2011
Approval sheet
QUICK REFERENCE DATA
Item
General Specification
Series No.
WR10X(W)
Size code
1210 ( 3225 )
±1% ( E96/E24 ), ±5% ( E24 )
Resistance Tolerance
Resistance Range
Jumper, 1Ω ~ 10MΩ ( E96+E24 series)
TCR (ppm/°C)
> 10R , ≤ ± 100 ppm/°C
-55°C ~ +155°C
1R ~ 10R, ≤ ± 200 ppm/°C
Max. dissipation at Tamb=70°C
1/3 W ( 0.33 W )
Max. Operation Voltage (DC or RMS)
200V
Max. Overload Voltage (DC or RMS)
400V
Climatic category
Type
55/155/56
WR10X
Power Rating At 70C
1/3 W
Resistance
Max. 50mR
Rated Current
2.5 A
Peak Current
6A
Operating Temperature
-55C ~ 155C
Note :
1.
This is the maximum voltage that may be continuously supplied to the resistor element, see “IEC publication
60115-8”
2.
Max. Operation Voltage : So called RCWV (Rated Continuous Working Voltage) is determined by
RCWV = Rated Power × Resistance Value or Max. RCWV listed above, whichever is lower.
DIMENSIONS(unit : mm)
Part No
WR10X
L
3.10 ± 0.10
W
2.60 ± 0.10
Tt
0.50 ± 0.20
Tb
0.50 ± 0.20 *1
T
0.55 ± 0.10
*1 original 0.45+/-0.20
Page 3 of 8
ASC_WR10X(W)_V13
Oct.- 2011
Approval sheet
MARKING
3-digits marking(±5%)
Each resistor is marked with a three digits code on the protective coating to designate the nominal resistance
value.
4-digits marking(±1%)
Each resistor is marked with a four digits code on the protective coating to designate the nominal resistance value.
Example
RESISTANCE
90Ω
100Ω
6800Ω
47000Ω
4-digits marking
90R0
1000
6801
4702
3-digits marking
101
682
473
FUNCTIONAL DESCRIPTION
Product characterization
Standard values of nominal resistance are taken from the E96 & E24 series for resistors with a tolerance of
±1%, ±5%. The values of the E24/E96 series are in accordance with “IEC publication 60063”.
Derating
The power that the resistor can dissipate depends on the operating temperature; see Fig.2
Figure 2
Maximum dissipation in percentage of rated power
as a function of the ambient temperature
MOUNTING
Due to their rectangular shapes and small tolerances, Surface Mountable Resistors are suitable for handling by
automatic placement systems.
Chip placement can be on ceramic substrates and printed-circuit boards (PCBs).
Electrical connection to the circuit is by individual soldering condition.
The end terminations guarantee a reliable contact.
Page 4 of 8
ASC_WR10X(W)_V13
Oct.- 2011
Approval sheet
SOLDERING CONDITION
The robust construction of chip resistors allows them
to be completely immersed in a solder bath of 260°C
for 10 seconds. Therefore, it is possible to mount
Surface Mount Resistors on one side of a PCB and
other discrete components on the reverse (mixed
PCBs).
Surface Mount Resistors are tested for solderability
at 235°C during 2 seconds. The test condition for no
leaching is 260°C for 30 seconds. Typical examples
of soldering processes that provide reliable joints
without any damage are given in Fig 3.
Fig 3. Infrared soldering profile for Chip Resistors
CATALOGUE NUMBERS
The resistors have a catalogue number starting with .
WR10
X
4702
Size code
Type code
Resistance code
Tolerance
Packaging code
Termination code
WR10: 1210
X :
5%, E24: 2 significant digits
followed by no. of zeros
J: ± 5%
T: 7” Reeled taping
L = Sn base (lead
free)
5%: 1R ~ 10M
1%: 10R ~ 1M
W:
1%: < 10R; > 1M0
100Ω
= 101_
10KΩ
= 103
F
T
F: ± 1%
L
P: Jumper
1% E24+E96: 3 significant
digits followed by no. of
zeros
102Ω
=1020
37.4KΩ
=3742
220Ω
=2200
Reeled tape packaging : 8mm width paper taping 5000pcs per 7” reel.
Page 5 of 8
ASC_WR10X(W)_V13
Oct.- 2011
Approval sheet
TEST AND REQUIREMENTS(JIS C 5201-1 : 1998)
The tests are carried out in accordance with IEC publication 68, "Recommended basic climatic and mechanical
robustness testing procedure for electronic components" and under standard atmospheric conditions according
to IEC 68-1, subclause 5.3, unless otherwise specified.
Temperature: 15ºC to 35ºC.
Relative humidity: 45% to 75%.
Air pressure: 86kPa to 106 kPa (860 mbar to 1060 mbar).
TEST
DC resistance
DC resistance values measured at the test voltages specified below :
Clause 4.5
很抱歉,暂时无法提供与“WR10X154JTL”相匹配的价格&库存,您可以联系我们找货
