Approval sheet
WW08P, WW06P
±1%, ±5% 47mΩ~976mΩ
High Power Low Ohmic Chip Resistors
Size 0805 1/3W ; 0603 1/4W
*Contents in this sheet are subject to change without prior notice.
Page 1 of 7
ASC_WW08-06P_V08
Jul.2010
Approval sheet
FEATURE
1.
2.
3.
4.
5.
Small size and light weight
High reliability and stability
Reduced size of final equipment
High precision
RoHS compliant and Lead free products
APPLICATION
High accuracy dc-power supply
Digital multi-meter
Telecommunication
Computer
Automotive industry
Medical and military equipment
DESCRIPTION
The resistors are constructed in a high grade ceramic body (aluminum oxide). Internal metal electrodes are
added at each end and connected by a resistive paste that is applied to the top surface of the substrate. The
composition of the paste is adjusted to give the approximate resistance required and the value is trimmed to
nominated value within tolerance which controlled by laser trimming of this resistive layer.
The resistive layer is covered with a protective coat. Finally, the two external end terminations are added. For
ease of soldering the outer layer of these end terminations is Tin (lead free) alloy.
Fig 1. Consctruction of Chip-R
Page 2 of 7
ASC_WW08-06P_V08
Jul.2010
Approval sheet
QUICK REFERENCE DATA
Item
General Specification
Series No.
WW08P
WW06P
Size code
0805 (2012)
0603(1608)
±1%, ±5%
Resistance Tolerance
Resistance Range
0.047Ω~0.976Ω(E96+E24 series)
TCR (ppm/°C) -55°C ~ +155°C
0.047Ω~0.091Ω
0.100Ω~0.976Ω
≤ ± 200 ppm/°C
≤ ± 250 ppm/°C
≤ ± 150 ppm/°C
≤ ± 200 ppm/°C
Max. dissipation at Tamb=70°C
1/3 W
1/4 W
Max. Operation Voltage (DC or RMS)
150V
50V
Max. Overload Voltage (DC or RMS)
300V
100V
Climatic category (IEC 60068)
55/155/56
Basic specification
JIS C 5201-1:1998 / IEC 60068-2-58:2004
Note :
1.
This is the maximum voltage that may be continuously supplied to the resistor element, see “IEC publication
60115-8”
2.
Max. Operation Voltage : So called RCWV (Rated Continuous Working Voltage) is determined by
RCWV = Rated Power × Resistance Value or Max. RCWV listed above, whichever is lower.
DIMENSIONS(unit : mm)
Part No
WW08P
WW06P
L
2.00 ± 0.10
1.60 ± 0.10
W
1.25 ± 0.10
0.80 ± 0.10
T
0.50 ± 0.15
0.45 ± 0.15
Tb
0.40 ± 0.20
0.30 ± 0.15
Tt
0.40 ± 0.20
0.30 ± 0.10
MARKING
Each resistor is marked with a three-digit(WW06P ±1%;±5%) or four-digit(WW08P ±1%;±5%) code on the
protective coating to designate the nominal resistance value.
* Remark:0603 resistor value from 0.1Ω to 0.976Ω E48/E96 series use 2 significant digits followed by
letter.(Example R560 = R56 ; R402= 59Z)
** Remark:0603 resistor value from 0.047Ω to 0.091Ω use the last Two-digits followed by “M” equals “m”, means
1/1000(Example R047 = 47M ; R050= 50M)
Rated Resistance
Resistance
47mΩ
50mΩ
51mΩ
55mΩ
Page 3 of 7
Code
0805
R047
R050
R051
R055
Code
0603
47M
50M
51M
55M
Resistance
56mΩ
60mΩ
62mΩ
65mΩ
Code
0805
R056
R060
R062
R065
Code
0603
56M
60M
62M
65M
Resistance
68mΩ
70mΩ
75mΩ
80mΩ
ASC_WW08-06P_V08
Code
0805
R068
R070
R075
R080
Code
0603
68M
70M
75M
80M
Resistance
82mΩ
85mΩ
90mΩ
91mΩ
Code
0805
R082
R085
R090
R091
Code
0603
82M
85M
90M
91M
Jul.2010
Approval sheet
FUNCTIONAL DESCRIPTION
Product characterization
Standard values of nominal resistance are taken from the E96&E24 series for resistors with a tolerance of
±1%,±5%. The values of the E96/E24 series are in accordance with “IEC publication 60063”.
Derating
The power that the resistor can dissipate depends on the operating temperature; see Fig.2
MOUNTING
Due to their rectangular shapes and small tolerances, Surface Mountable Resistors are suitable for handling by
automatic placement systems.
Chip placement can be on ceramic substrates and printed-circuit boards (PCBs).
Electrical connection to the circuit is by individual soldering condition.
The end terminations guarantee a reliable contact.
SOLDERING CONDITION
The robust construction of chip resistors allows them
to be completely immersed in a solder bath of 260°C
for 10 seconds. Therefore, it is possible to mount
Surface Mount Resistors on one side of a PCB and
other discrete components on the reverse (mixed
PCBs).
Surface Mount Resistors are tested for solderability
at 235°C during 2 seconds. The test condition for no
leaching is 260°C for 30 seconds. Typical examples
of soldering processes that provide reliable joints
without any damage are given in Fig 3.
Fig 3. Infrared soldering profile for Chip Resistors
Page 4 of 7
ASC_WW08-06P_V08
Jul.2010
Approval sheet
CATALOGUE NUMBERS
The resistors have a catalogue number starting with.
WW08
P
R050
F
T
L
Size code
Type code
Resistance code
Tolerance
Packaging code
Termination code
WW08: 0805
P :Power
E96+E24:
J : ±5%
T
L = Sn base
WW06: 0603
0805 size=0.33W
“R” is first digit followed by 3
significant digits.(0805)
F : ±1%
0603 size=0.25W
50mΩ
=R050
510mΩ
=R510
: 7” Reeled taping
paper taping
5Kpcs/reel.
(lead free)
“R” is first digit followed by 2
Significant digit.(0603)
100mΩ
=R10
510mΩ
=R51
0603 0.1Ω~0.976Ω E48/E96
2 significant digits followed by letter
0603 0.047Ω~0.091Ω E24
2 significant digits followed by M
(M=milli Ω).
(R047=47m)
Reeled tape packaging
Page 5 of 7
: 8mm width paper taping 5000pcs per 7” reel.
ASC_WW08-06P_V08
Jul.2010
Approval sheet
TEST AND REQUIREMENTS
Basic specification : JIS C 5201-1 : 1998
TEST
Clause 4.8
Temperature
Coefficient of
Resistance (TCR )
REQUIREMENT
PROCEDURE
Natural resistance change per change in degree Refer to quick reference data for T.C.R
centigrade.
specification
R2 − R1
× 106
R1 (t2 − t1 )
(ppm/°C)
R1 : Resistance at reference temperature
R2 : Resistance at test temperature
t1 : 20℃+5℃-1℃.
Clause 4.13
Short time overload
Clause 4.18
Resistance to
soldering heat(R.S.H)
Clause4.17
Solderability
Clause 4.19
Temperature cycling
5.0× Rated power or Max. Overload Voltage
Measure resistance after 30 minutes.
for 5 sec. ∆R/R max. J:≦ ±(2%+0.5mΩ)
Un-mounted chips completely immersed for 10±1second No visible damage
in a SAC solder bath at 260℃±5ºC.
∆R/R max. J:≦ ±(1%+0.5mΩ)
F:≦ ±(0.5%+0.5mΩ)
Un-mounted chips completely immersed for 2±0.5 Good tinning (>95% covered)
second in a SAC solder bath at 235℃±5℃.
No visible damage
1.
2.
30 minutes at -55°C±3°C,
2~3 minutes at 20°C+5°C-1°C,
3. 30 minutes at +155°±3°C,
4. 2~3 minutes at 20°C+5°C-1°C,
Total 5 continuous cycles.
Clause 4.25
Load life (endurance)
Clause 4.24
Load life in Humidity
F:≦ ±(1%+0.5mΩ)
No visible damage
∆R/R max. J≦ ±(1%+1mΩ)
F≦ ±(0.5%+1mΩ)
1000 +48/-0 hours, loaded with RCWV or Vmax in No visible damage
chamber controller 70±2ºC, 1.5 hours on and 0.5 hours ∆R/R max. J≦ ±(3%+0.5mΩ)
off.
F≦ ±(1%+0.5mΩ)
humidity chamber controller at 40°C±2°C and 90~95% ∆R/R max. J≦ ±(3%+0.5mΩ)
relative humidity, 1.5hours on and 0.5 hours off.
F≦ ±(1%+0.5mΩ)
Bending strength
Resistors mounted on a 90mm glass epoxy resin No visible damage
PCB(FR4); bending : 3 mm, once for 10 seconds.
F≦ ±(0.5%+1mΩ)
Clause 4.32
Pressurizing force: 5N, Test time: 10±1sec.
No remarkable damage or removal of
the terminations
Apply the maximum overload voltage (DC) for 1minute.
R≧10GΩ
Apply the maximum overload voltage (AC) for 1 minute.
No breakdown or flashover
Clause 4.33
Adhesion
Clause 4.6
Insulation Resistance
Clause 4.7
Dielectric Withstand
Voltage
Page 6 of 7
ASC_WW08-06P_V08
Jul.2010
Approval sheet
PACKAGING
Paper Tape specifications (unit :mm)
Series No.
A
B
WW06P
1.90±0.20
1.10±0.20
WW08P
2.40±0.20
1.65±0.20
Series No.
P1
4.00±0.10
WW06P
W
F
E
8.00±0.30
3.50±0.20
1.75±0.10
P0
ΦD
T
4.00±0.10
Φ1.50 +−00..10
0.65±0.05
WW08P
Max. 1.0
Reel dimensions
Page 7 of 7
Symbol
A
B
C
D
(unit : mm)
Φ178.0±2.0
Φ60.0±1.0
13.0±0.2
9.0±0.5
ASC_WW08-06P_V08
Jul.2010
很抱歉,暂时无法提供与“WW06PR270FTL”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 20+0.23814
- 200+0.19052
- 600+0.16406
