Approval sheet
WW25P, WW20P, WW12P
±1%, ±5%
Thick Film High Power Low Ohm Chip Resistors
Size 2512 2W, 2010 1W, 1206 1/2W
*Contents in this sheet are subject to change without prior notice.
Page 1 of 7
ASC_WW25P-20P-12P_V10
Sep.2013
Approval sheet
FEATURE
1.
2.
3.
4.
High power rating and compact size
High reliability and stability
Reduced size of final equipment
RoHS compliant and lead free products.
APPLICATION
Power supply
PDA
Digital meter
Computer
Automotives
Battery charger
DC-DC power converter
DESCRIPTION
The resistors are constructed in a high grade ceramic body (aluminum oxide). Internal metal electrodes are
added at each end and connected by a resistive paste that is applied to the top surface of the substrate.
The composition of the paste is adjusted to give the approximate resistance required and the value is trimmed to
nominated value within tolerance which controlled by laser trimming of this resistive layer.
The resistive layer is covered with a protective coat. Finally, the two external end terminations are added.
For ease of soldering the outer layer of these end terminations is Tin (lead free) alloy.
Fig 1. Construction of Chip-R
Page 2 of 7
Sep.2013
Approval sheet
QUICK REFERENCE DATA
Item
General Specification
Series No.
WW25P
WW20P
WW12P
Size code
2512 (6432)
2010 (5025)
1206 (3216)
±1%, ±5%
Resistance Tolerance
Resistance Range
0.040Ω ~ 0.976Ω
0.020Ω ~ 0.976Ω
±100ppm
±150ppm
±200ppm
±100ppm
±150ppm
±200ppm
±100ppm
±200ppm
±1000ppm
Max. dissipation at Tamb=70°C
2W
1W
1/2 W
Max. Operation Voltage
300V
200V
200V
Max. Overload Voltage
500V
400V
400V
TCR (ppm/°C)
100mohm ~ 976mohm
47mohm ~ 97.6mohm
20 mohm ~ 43mohm
Climatic category (IEC 60068)
55/155/56
Note :
1.
This is the maximum voltage that may be continuously supplied to the resistor element, see “IEC publication
60115-8”
2.
Max. Operation Voltage : So called RCWV (Rated Continuous Working Voltage) is determined by
RCWV = Rated Power × Resistance Value or Max. RCWV listed above, whichever is lower.
3.
4.
2
2W loading with total solder-pad and trace size of 300 mm
Resistance value will be changed by soldering condition and design of soldering pad, please design products in
consideration of this change of resistance value.
MECHANICAL DATA
Unit: mm
Page 3 of 7
Symbol
WW25P
WW20P
WW12P
L
6.30 ± 0.20
5.00 ± 0.20
3.10 ± 0.15
W
3.10 ± 0.20
2.50 ± 0.20
1.60 ± 0.15
T
0.60 ± 0.15
0.60 ± 0.10
0.55 ± 0.10
Tt
0.60 ± 0.25
0.60 ± 0.25
0.50 ± 0.25
Tb
1.80 ± 0.25
0.60 ± 0.25
0.50 ± 0.25
Sep.2013
Approval sheet
Recommended Solder Pad Dimensions
D
Type
WW25P
W
W
3.7mm
D
2.45mm
L
7.6mm
L
MARKING
Each resistor is marked with a four-digit code on the protective coating to designate the nominal resistance
value.
Example:
R100 = 0.100Ω
R910 = 0.910Ω
FUNCTIONAL DESCRIPTION
Product characterization
Standard values of nominal resistance are taken from the E96 & E24 series for resistors with a tolerance of
±5% & ±1%. The values of the E24/E96 series are in accordance with “IEC publication 60063”.
Derating curve
The power that the resistor can dissipate depends on the operating temperature; see Fig.2
Figure 2
Maximum dissipation in percentage of rated power as a
function of the ambient temperature
MOUNTING
Due to their rectangular shapes and small tolerances, Surface Mountable Resistors are suitable for handling by
automatic placement systems.
Chip placement can be on ceramic substrates and printed-circuit boards (PCBs).
Electrical connection to the circuit is by individual soldering condition.
The end terminations guarantee a reliable contact.
Page 4 of 7
Sep.2013
Approval sheet
SOLDERING CONDITION
The robust construction of chip resistors allows
them to be completely immersed in a solder bath
of 260°C for 10 seconds. Therefore, it is possible
to mount Surface Mount Resistors on one side of
a PCB and other discrete components on the
reverse (mixed PCBs).
Surface Mount Resistors are tested for
solderability at 235°C during 2 seconds. The test
condition for no leaching is 260°C for 30 seconds.
Typical examples of soldering processes that
provide reliable joints without any damage are
given in Fig 3.
Fig 3. Infrared soldering profile for Chip Resistors
CATALOGUE NUMBERS
The resistors have a catalogue number starting with.
WW25
P
R100
J
T
L
Size code
Type code
Resistance code
Tolerance
Packaging code
Termination code
WW25 : 2512
P :Power
E96 +E24:
J : ±5%
T : 7” Reel taping
WW20 : 2010
2512 size=2 watt
“R”
F : ±1%
G : 13” Reel taping
L = Sn base (lead
free)
WW12 : 1206
2010 size=1 watt
1206 size=0.5 watt
is first digit followed by 3
significant digits.
e.g.:
0.1ohm
Tape packaging
R100
R047
0.56ohm
R560
WW12 : 8mm width paper taping 5,000pcs per 7” reel. 20,000pcs per 13” reel.
WW25;WW20:
Page 5 of 7
0.047ohm =
12mm width plastic taping 4,000pcs per reel.
Sep.2013
Approval sheet
TEST AND REQUIREMENTS
Basic specification : JIS C 5201-1 : 1998
TEST
Clause 4.8
Temperature
Coefficient of
Resistance (TCR )
PROCEDURE
REQUIREMENT
Natural resistance change per change in degree Refer to quick reference data for T.C.R
centigrade.
specification
R2 − R1
× 106
R1 (t2 − t1 )
(ppm/°C)
R1 : Resistance at reference temperature
R2 : Resistance at test temperature
t1 : 20°C+5°C-1°C
Clause 4.13
Short time
overload
Clause 4.18
Resistance to
soldering
heat(R.S.H)
Clause 4.17
Solderability
Clause 4.19
Temperature
cycling
Clause 4.25
Load life
(endurance)
Clause 4.24
Permanent resistance change after 5 second application ∆R/R max. J:≦ ±(2%+0.5mΩ)
of a power 5.0 times of rated power or the maximum
F:≦ ±(1%+0.5mΩ)
overload voltage specified in the above list, whichever is
less.
Un-mounted chips completely immersed for 10±1second No visible damage
in a SAC solder bath at 260℃±5ºC
∆R/R max. J:≦ ±(1%+0.5mΩ)
F:≦ ±(0.5%+0.5mΩ)
Un-mounted chips completely immersed for 2±0.5second Good tinning (>95% covered)
in a SAC solder bath at 235℃±5℃
No visible damage
30 minutes at -55°C±3°C, 2~3 minutes at 20°C+5°C-1°C, No visible damage
30 minutes at +155°C±3°C, 2~3 minutes at ∆R/R max. J≦ ±(1%+1mΩ)
20°C+5°C-1°C, total 5 continuous cycles
F≦ ±(0.5%+1mΩ)
1000 +48/-0 hours, loaded with RCWV or Vmax in No visible damage
chamber controller 70±2ºC, 1.5 hours on and 0.5 hours ∆R/R max. J≦ ±(3%+0.5mΩ)
off
F≦ ±(1%+0.5mΩ)
Load life in
Humidity
humidity chamber controller at 40°C±2°C and 90~95% ∆R/R max. J≦ ±(3%+0.5mΩ)
relative humidity, 1.5hours on and 0.5 hours off
F≦ ±(1%+0.5mΩ)
Clause 4.33
Bending strength
Resistors mounted on a 90mm glass epoxy resin No visible damage
PCB(FR4); bending : 2 mm(2512;2010)
F≦ ±(0.5%+1mΩ)
3mm(1206), once for 10 seconds
Clause 4.32
Pressurizing force: 5N, Test time: 10±1sec
No remarkable damage or removal of the
terminations
Apply the maximum overload voltage (DC) for 1minutes
R≧10GΩ
Adhesion
Insulation
Resistance
Clause 4.6
Dielectric Withstand Apply the maximum overload voltage (AC) for 1 minutes
Voltage
No breakdown or flashover
Clause 4.7
Page 6 of 7
Sep.2013
Approval sheet
PACKAGING
Paper Tape(WW12P) & Plastic Tape(WW25P;WW20P) specifications
(unit :mm)
Series No.
A
B
W
F
WW25P
6.90±0.20
3.60±0.20
WW20P
5.50±0.20
2.80±0.20
12.00±0.30
5.50±0.10
WW12P
3.60±0.20
2.00±0.20
8.00±0.30
3.50±0.20
Series No.
P1
P0
ΦD
T
4.00±0.10
Φ1.50 +−00..10
Max. 1.2
4.00±0.10
E
1.75±0.10
WW25P
WW20P
Max. 1.0
WW12P
Reel dimensions
(unit : mm)
Reel / Tape
7” reel for 8mm tape
A
B
C
Φ178.0±2.0
Φ60.0±1.0
13.0±0.2
9.00±0.50
12.4±1.00
7” reel for 12mm tape
13” reel for 8mm tape
Page 7 of 7
D
Φ330.0±2.00
Φ
100.0±1.00
13.0±0.2
9.00±0.50
Sep.2013
很抱歉,暂时无法提供与“WW12PR300FTL”相匹配的价格&库存,您可以联系我们找货
