0805N391F500CT
0805N391F500CT
    WALSIN(华新科)
    贴片电容(MLCC) 0805 390pF ±1% 50V C0G(NP0)
0805N391F500CT 数据手册
Approval sheet General Purpose Capacitors MULTILAYER CERAMIC CAPACITORS General Purpose Series (4V to 100V) 0201 to 1812 Sizes NP0, X7R, Y5V, X6S, X7S & X5R Dielectrics RoHS Compliance *Contents in this sheet are subject to change without prior notice. Page 1 of 20 ASC_ General Purpose_001AB_AS Dec. 2016 Approval sheet General Purpose Capacitors 1. DESCRIPTION MLCC consists of a conducting material and electrodes. To manufacture a chip-type SMT and achieve miniaturization, high density and high efficiency, ceramic condensers are used. WTC’s MLCC is made by NP0, X7R, X6S, X5R and Y5V dielectric material and which provides product with high electrical precision, stability and reliability. 2. FEATURES 3. APPLICATIONS a. b. c. a. b. c. d. A wide selection of sizes is available (0201 to 1812). High capacitance in given case size. Capacitor with lead-free termination (pure Tin). For general digital circuit. For power supply bypass capacitors. For consumer electronics. For telecommunication. 4. HOW TO ORDER 1206 Size Inch (mm) 0201 (0603) 0402 (1005) 0603 (1608) 0805 (2012) 1206 (3216) 1210 (3225) 1812 (4532) Page 2 of 20 B Dielectric N=NP0 (C0G) B=X7R F=Y5V X=X5R S=X6S A=X7S 104 Capacitance Two significant digits followed by no. of zeros. And R is in place of decimal point. eg.: 0R5=0.5pF 1R0=1.0pF 4 104=10x10 =100nF K Tolerance A=±0.05pF B=±0.1pF C=±0.25pF D=±0.5pF F=±1% G=±2% J=±5% K=±10% M=±20% Z=-20/+80% 500 Rated voltage Two significant digits followed by no. of zeros. And R is in place of decimal point. C Termination C=Cu/Ni/Sn T Packaging style T=7” reeled G=13” reeled 4R0=4 VDC 6R3=6.3 VDC 100=10 VDC 160=16 VDC 250=25 VDC 500=50 VDC 101=100 VDC ASC_ General Purpose_001AB_AS Dec. 2016 Approval sheet General Purpose Capacitors 5. EXTERNAL DIMENSIONS Outline Size Inch (mm) L (mm) W (mm) 01R5 (0402) 0.4±0.02 0.2±0.02 0.2±0.02 0.6±0.03 0.3±0.03 0.3±0.03 0.6±0.05#2 0.3±0.05#2 0.3±0.05#2 0.6±0.09#3 0.3±0.09#3 0.3±0.09#3 0201 (0603) 0402 (1005) L 0603 (1608) 1.00±0.05 Soldering Method * MB (mm) V R 0.10±0.03 L R 0.50±0.05 N R 0.50+0.02/-0.05 Q R E R T (mm)/Symbol 0.50±0.05 0.50±0.20 0.5±0.20 1.60±0.10 0.80±0.10 0.80±0.07 S R/W 0.50±0.10 H R/W X R/W 0.50±0.10 H R/W 0.60±0.10 A R/W 0.80±0.10 B R/W 1.25±0.10 D R 0.85±0.10 T R/W 0.80+0.15/-0.10 T 1.60±0.20#1 0.80±0.20#1 W MB MB Fig. 1 The outline of MLCC 2.00±0.15 1.25±0.10 0805 (2012) 2.00±0.20 3.20±0.15 1.25±0.20 1.60±0.15 1206 (3216) 3.20±0.20 1.60±0.20 3.20±0.30 1.25±0.20 I R 0.80±0.10 B R/W 0.95±0.10 C R 1.25±0.10 D R 1.15±0.15 J R 1.60±0.20 G R 0.85±0.10 T R/W P R 0.95±0.10 C R 0.85±0.10 T R 1.25±0.10 D R 1.60±0.20 G R 2.50±0.30 2.00±0.20 K R 2.50±0.50#4 2.50±0.30 2.50±0.50#4 M R 1.25±0.10 D R 1.40±0.15 F R 1.60±0.20 G R 2.00±0.20 K R 1.25±0.10 D R 1.60±0.20 G R 2.00±0.20 K R 2.50±0.30 M R U R 2.50±0.20 1210 (3225) 3.20±0.40 3.20±0.60#4 4.50±0.40 1808 (4520) 2.03±0.25 (4.5+0.5/-0.3)** 4.50±0.40 3.20±0.30 1812 (4532) (4.5+0.5/-0.3)** 3.20±0.40 2.80±0.30 * R = Reflow soldering process ; W = Wave soldering process. ** For 1808_200V ~3kV, 1812_200V~3kV and safety certificated products. *** For 1206_1000V ~3kV,1808_200V ~3kV, 1812_200V~3kV and safety certificated products. #1 : For 0603/Cap≧10µF or 0603/Cap≧4.7µF(≦6.3V) or 0603/Cap>1µF(>10V) products. #2 : For 0201/Cap≧0.68µF products. #3 : For 0201/Cap≧1µF products. #4 : For 1210_100V: Cap > 1µF, 250V: Cap >0. 47µF, 400V~630V: Cap >0.22µF. ASC_ General Purpose_001AB_AS 0.25 +0.05/-0.10 0.40±0.15 0.8±0.20#1 3.20+0.30/-0.10 1.60+0.30/-0.10 1.60+0.30/-0.10 Page 3 of 20 0.15+0.1/-0.05 1.00±0.20 1.60+0.15/-0.10 0.80+0.15/-0.10 0.15±0.05 0.50±0.20 0.60±0.20 (0.5±0.25)*** 0.75±0.25 0.75±0.25 (0.5±0.25)*** 0.75±0.25 (0.5±0.25)*** Dec. 2016 Approval sheet General Purpose Capacitors 6. GENERAL ELECTRICAL DATA Dielectric NP0 X7R Size Y5V X5R X6S X7S 0201, 0402, 0603, 0805, 1206, 1210, 1812 Capacitance range* 0.1pF to 0.1µF 100pF to 47µF 0.01µF to 100µF 100pF to 220µF 0.1µF to 100µF 1µF to 100µF J (±5%), K (±10%), M (±20%) M (±20%), Z (-20/+80%) K (±10%), M (±20%) K (±10%), M (±20%) K (±10%), M (±20%) #1 Capacitance tolerance** Cap≤5pF : A (±0.05pF), B (±0.1pF), C (±0.25pF) 5pF0.1µF; 0805≧1µF;1206≧2.2µF; 1210≧10µF; TT series ≦3.5% ≦10% ≦5% 0603≧1µF;0805≥2.2µF;1206≧2.2µF;1210≧10µF 0201≧0.01µF;0805≧1µF; 1210≧10µF ≦7% 25V 16V 10V 0603≧0.33µF; 1206≧4.7µF 0201≧0.1µF;0402≧0.10µF;0603≧0.47µF; 0805≧2.2µF; 1206≧6.8µF ; 1210≧22µF ; TT series ≦12.5% 0402≧0.47µF 0201≧0.01µF;0402≧0.033µF;0603≧0.15µF; ≦5% 0805≧0.68µF;1206≧2.2µF;1210≧4.7µF ≦3.5% 0201≧0.1uF(0201/X7R≧0.022µF); 0402≧ 0.22uF; 0603≧0 ≦10% 1206≧4.7µF; 1210≧22µF; TT series ≦3.5% ≦5% ≦10% 4V ≦15% ≦5% ≦10% ≦10% ≦15% 6.3V Exception of D.F.≦ ≦7% 0603≧0.1µF; 0805≧0.47µF; 1206≧4.7µF; TT series ≦12.5% 1210≧6.8µF 35V ≦7% ----0402≧0.047µF;0603≧0.1µF; 0805≧0.33µF; ≦7% 1206≧1µF; 1210≧4.7µF 25V ≦5% 0402≧0.068µF;0603≧0.47µF; 1206≧4.7µF; ≦9% 1210≧22µF; TT series 16V ≦9% 0402≧0.068µF; 0603≧0.68µF ≦7% (C0.1µF; 0805≧1µF;1206≧2.2µF; ≦10% 1210≧10µF; TT series 35V ≦3.5% ≦10% 0603≧1µF;0805≥2.2µF;1206≧2.2µF;1210≧10µF ≦5% 0201≧0.01µF;0805≧1µF; 1210≧10µF ≦7% 0603≧0.33µF; 1206≧4.7µF 25V ≦3.5% 0201≧0.1µF;0402≧0.10µF;0603≧0.47µF; 0805≧2.2µF; ≦10% 1206≧6.8µF ; 1210≧22µF ; TT series ≦12.5% 0402≧0.47µF 0201≧0.01µF;0402≧0.033µF;0603≧0.15µF; ≦5% 0805≧0.68µF;1206≧2.2µF;1210≧4.7µF 16V ≦3.5% 0201≧0.1uF(0201/X7R≧0.022µF); 0402≧ 0.22uF; ≦10% 0603≧0.68µF;0805≧2.2µF;1206≧4.7µF; 1210≧22µF; TT 10V 6.3V ≦5% ≦10% ≦10% 0201≧0.012µF;0402≧0.33µF(0402/X7R≧0.22µF); TT series 0603≧0.33µF; 0805≧2.2µF;1206≧2.2µF;1210≧22µF:01R5 ≦15% 0201≧0.1µF; 0402≧1µF 0201≧0.1µF;0402≧1µF;0603≧10µF; 0805≧4.7µF; 1206≧47µF :1210≧100µF; TT series 0402≧2.2µF --- ≦15% ≦20% *Before initial measurement (Class II only): 4V ≦15% --To apply de-aging at 150°C for 1hr then set Y5V: for 24±2 hrs at room temp. Rated vol. D.F. ≦ Exception of D.F.≦ 0603≧0.1µF; 0805≧0.47µF; 1206≧4.7µF; TT series ≦7% ≦12.5% 1210≧6.8µF --35V ≦7% --0402≧0.047µF;0603≧0.1µF; 0805≧0.33µF; ≦7% 1206≧1µF; 1210≧4.7µF 25V ≦5% 0402≧0.068µF;0603≧0.47µF; 1206≧4.7µF; ≦9% 1210≧22µF; TT series 0402≧0.068µF; 0603≧0.68µF 16V ≦9% ≦7% (C0.01µF;0603≥1µF;0805≥1µF;1206≥4.7µF;1210≥4.7µF 35V:0805≥2.2µF;1206≧2.2µF;1210≧10µF 25V:0402≥1µF;0603≥2.2µF;0805≥2.2µF;1206≥10µF;1210≥10µF 16V: 0201≥0.1µF,0402≥0.22µF;0603≥1µF; 0805≥2.2µF;1206≥10µF;1210≥47µF 10V:0201≥47nF;0402≥0.47µF;0603≥0.47µF;0805≥2.2µF; 1206≥4.7µF;1210≥47µF 6.3V ; 4V ; TT series; Size≥1812 Dielectric Page 13 of 20 * No evidence of damage or flash over during test. 10GΩ or RxC≧500Ω-F whichever is smaller. Insulation Resistance 10GΩ or RxC≧100 Ω-F whichever is smaller. Rated voltage Insulation Resistance All X6S items, All X7S items 100V: 1210≥3.3µF 50V: 0402≥0.1µF; 0603≥2.2µF; 0805≥10µF;1206≥10µF 35V: 0603≥1µF; 25V: 0201≥0.1µF; 0402≥2.2µF;0603≥10µF; 0805≥10µF;1206≥22µF 16V: 0603≥10µF; 0402≥1µF; 0201≥0.22µF 10V: 0201>0.1µF; 0402≥1µF; 0603≥10µF; 0805≥47µF; TT21>4.7µF 6.3V: 0201≥0.1µF; 0603>4.7µF; 0805≥47µF;1206≥10µF; TT15>1.0µF 4V:0603≥22µF; 0805≥47µF; 1206≥100µF RxC≧50 Ω-F. ASC_ General Purpose_001AB_AS Dec. 2016 Approval sheet General Purpose Capacitors No. 6. Item Temperature Coefficient Test Condition With no electrical load. T.C. Operating Temp NPO -55~125°C at 25°C X7R -55~125°C at 25°C X7S -55 ~ 125°C at 25°C X5R -55~ 85°C at 25°C X6S -55~105°C at 25°C Y5V -25~ 85°C at 20°C *Before initial measurement (Class II only): To apply de-aging at 150°C for 1hr then set for 24±2 hrs at room temp. * Measurement voltage for Class II: 01005 Cap≤0.01µF: 0.5V Cap>0.01µF: 0.2V 0402 Cap1.0µF TT18 Y5V 6.3V,10V C≧2.2µF Y5V 6.3V C≧10µF TT21 X5R/X7R/X6S ≦10V C≧10µF TT31 Y5V 6.3V C≧22µF Requirements * No remarkable damage. Cap change: NP0: ±3.0% or ±0.3pF whichever is larger X7R, X5R, X6S, X7S: ≥10V**,within ±12.5%; ≦6.3V within ±25%; TT series & C≥ 1uF,within ±25% **10V: 0603≧4.7µF;0402≧1µF;0201≧0.1µF, within ±25%; Y5V: ≥10V, within ±30%; ≦6.3V, within +30/-40% Q/D.F. value: NP0: More than 30pF, Q≥350 10pF≤C1µF;1210≧2.2µF;TT series ≦20% 0805>0.22µF;1210≧3.3µF ≦6% 0201(50V);0603≧0.047µF; 0805≧0.18µF; 1206≧0.47µF ≧50V ≦3% ≦10% 0201≧0.01uF;1210≧4.7µF ≦20% 0402≧0.012µF; 0603>0.1µF; 0805≧1µF; 1206≧2.2µF; 1210≧10µF; TT series 35V ≦5% ≦20% 0603≧1µF;0805≥2.2µF;1206≧2.2µF;1210≧10µF ≦10% 0201≧0.01µF;0805≧1µF; 1210≧10µF ≦14% 0603≧0.33µF;1206≧4.7µF 25V ≦5% ≦15% 0201≧0.1µF;0402≧0.10µF;0603≧0.47µF;0805≧2.2µF; 1206≧6.8µF;1210≧22µF; TT series ≦20% 0402≧0.47µF ≦10% 0603≧0.15µF;0805≧0.68µF;1206≧2.2µF;1210≧4.7µF 16V ≦5% ≦15% 0201≧0.01µF(0201/X7R≧0.022µF);0402≧0.033µF; 0603≧0.68µF;0805≧2.2µF;1206≧4.7µF; 1210≧22µF; TT series ≦15% 0201≧0.012µF; 0402≧0.33µF(0402/X7R≧0.22µF); 10V ≦7.5% 0603≧0.33µF;0805≧2.2µF;1206≧2.2µF; 1210≧22µF ≦20% 0201≧0.1µF ;0402≧1µF; TT series; 01R5 **1WV items must follow de-rating conditions 6.3V ≦15% ≦30% 0201≧0.1µF;0402≧1µF;0603≧10µF; (6) 150% of rated voltage for below range. 0805≧4.7µF;1206≧47µF;1210≧100µF;TT series Rated ≦20% ----Size Dielectric Capacitance4V voltage X5R/X7R/X6 16V/25V C≧0.1µF Y5V: 0201 S X7R 16V C≧0.022µF Rated vol. D.F.≦ Exception of D.F.≦ 50V C≧0.1µF X5R/X7R/X6 ≦10% 0603≧0.1µF; 0805≧0.47µF;1206≧4.7µF S 0402 10~25V C≧0.22µF ≧50V ≦7.5% ≦20% 1210≧6.8µF Y5V 16V C≧0.47µF 35V ≦10% ----X7R 50V C>0.1µF 0402≧0.047µF;0603≧0.1µF; X5R/X7R/ 10V,16V, ≦10% C ≧ 1.0µF 0603 0805≧0.33µF;1206≧1µF; 1210≧4.7µF X6S/X7S 50V 25V ≦7.5% 0402≧0.068µF;0603≧0.47µF; Y5V 16V C≧2.2µF ≦15% 1206≧4.7µF; 1210≧22µF X5R/X7R/ 10~50V C≧4.7µF 16V ≦12.5%0402≧0.068µF; 0603≧0.68µF X6S/X7S ≦10% ≦20% 0402≧0.22µF 50V C≧2.2µF (C1.0µF S ≦30% ----1210 X5R/X7R/X6 50V~100V C≧2.2µF 6.3V S 1825 X7R 100V~250V C≧1.0µF 2220 *I.R.: ≥10V, 1GΩ or 50 Ω-F whichever is smaller. 2225 *Test time: 1000+24/-0 hrs. Class II (X7R, X5R, X6S, X7S, Y5V) *Before initial measurement (Class II only): To Insulation apply de-aging at 150°C for 1hr then set for 24±2 Rated voltage Resistance hrs at room temp. 100V: All X7R;1210≥3.3µF * Cap. / DF(Q) / I.R. Measurement to be made after de-aging at 150°C for 1hr then set for 24±2 50V: 0402>0.01µF;0603≥1µF;0805≥1µF;1206≥4.7µF;1210≥4.7µF 35V:0603≥1µF;0805≥2.2µF; 1206≧2.2µF;1210≧10µF hrs at room temp. ** De-rating conditions: Page 17 of 20 ≧100V≦3% 25V:0201≧0.1uF; 0402≥0.22µF; 0603≥2.2µF;0805≥2.2µF; 1206≥10µF;1210≥10µF 16V: 0201≧0.1uF;0402≥0.22µF;0603≥1µF;0805≥2.2µF; 1206≥10µF;1210≥47µF 10V:0201≥47nF;0402≥0.47µF;0603≥0.47µF;0805≥2.2µF; 1206≥4.7µF;1210≥47µF 6.3V ; 4V ; TT series ; All X6S/X7S items; Size≥1812 ASC_ General Purpose_001AB_AS 1GΩ or RxC ≧10 Ω-F whichever is smaller. Dec. 2016 Approval sheet General Purpose Capacitors APPENDIXES ◙ Tape & reel dimensions Fig. 2 The dimension of paper tape Fig. 3 The dimension of plastic tape Size 0201 0402 0603 0805 1206 Thickness L N,E S,H,X A,H B,T A0 B0 0.39 +/-0.07 0.69 +/-0.07 0.70 +/-0.2 1.20 +/-0.2 1.05 +/-0.30 1.80 +/-0.30 1.50 +/-0.20 2.30 +/-0.20 1.50 +/-0.20 2.30 +/-0.20 D,I T ≦0.50 ≦0.80 ≦1.20 ≦1.15 ≦1.30 0.23 +/-0.1 < 1.80 < 2.70 B,T 1.90 +/-0.50 3.50 +/-0.50 1210 1808 1812 C,J,D G,P T C,D,G, K < 2.00
0805N391F500CT
物料型号:文档中没有明确列出具体的物料型号,但提到了华新科技股份有限公司(Walsin Technology Corporation)生产的多层陶瓷电容器(MLCC)。
器件简介:MLCC由导电材料和电极组成,采用片式SMT技术实现小型化、高密度和高效率。WTC的MLCC使用NP0、X7R、X6S、X5R和Y5V等介质材料制造,提供高电气精度、稳定性和可靠性。
引脚分配:文档中没有提及具体的引脚分配信息,因为MLCC是无引脚的表面贴装元件。
参数特性:MLCC提供了多种尺寸(0201至1812),在给定的封装尺寸下具有高电容值,并且具有无铅端子(纯锡)。
功能详解:文档详细列出了不同尺寸MLCC的电容值、公差、额定电压、端子材料和包装风格。例如,1206尺寸的MLCC,其电容值范围从100pF到100uF,公差有B(+0.1pF)、C(+0.25pF)、D(+0.5pF)、F(+1%)、G(+2%)、J(±5%)、K(±10%)、M(+20%)和Z(-20/+80%)等。
应用信息:MLCC适用于一般数字电路、电源旁路电容器、消费电子和电信设备。
封装信息:文档提供了MLCC的外部尺寸和焊接方法,包括回流焊(R)和波峰焊(W)。
0805N391F500CT 价格&库存
很抱歉,暂时无法提供与“0805N391F500CT”相匹配的价格&库存,您可以联系我们找货
0805N391F500CT
    • 20+0.17054
    • 200+0.13749
    • 600+0.11913
    • 4000+0.10811
    • 8000+0.09850
    • 20000+0.09342
    库存:2024
