HH15N1R0B500CT
HH15N1R0B500CT
    WALSIN(华新科)
    贴片电容(MLCC) 0402 1pF ±0.1pF 50V C0G(NP0)
HH15N1R0B500CT 数据手册
Multilayer Ceramic Capacitors Approval Sheet MULTILAYER CERAMIC CAPACITORS High Q / Low ESR Series (HH) 0201 to 0805 Sizes NP0 Dielectric Halogen Free & RoHS Compliance *Contents in this sheet are subject to change without prior notice. Page 1 of 11 ASC_ HQ_Low ESR_(HH)_006U_AS Oct. 2017 Multilayer Ceramic Capacitors Approval Sheet 1. INTRODUCTION MLCC consists of a conducting material and electrodes. To manufacture a chip-type SMT and achieve miniaturization, high density and high efficiency, ceramic condensers are used. WTC HH series MLCC is used at high frequencies generally have a small temperature coefficient of capacitance, typical within the ±30ppm/°C required for NP0 (C0G) classification and have excellent conductivity internal electrode. Thus, WTC HH series MLCC will be with the feature of low ESR and high Q characteristics. 2. FEATURES 3. APPLICATIONS a. b. a. b. c. High Q and low ESR performance at high frequency. Quality improvement of telephone calls for low power loss and better performance. Mobile telecommunication: Mobile phone, WLAN. RF module: Power amplifier, VCO. Tuners. 4. HOW TO ORDER HH 15 N 100 G 500 C T Series Size Dielectric Capacitance Tolerance Rated voltage Termination Packaging HH=High Q/ Low ESR 03=0201 (0603) 15=0402 (1005) 18=0603 (1608) 21=0805 (2012) N=NP0 (C0G) Two significant digits followed by no. of zeros. And R is in place of decimal point. eg.: R47=0.47pF 0R5=0.5pF 1R0=1.0pF 100=10x100 =10pF Page 2 of 11 A=±0.05pF B=±0.1pF C=±0.25pF D=±0.5pF F=±1% G=±2% J=±5% Two significant C=Cu/Ni/Sn digits followed by no. of zeros. And R is in place of decimal point. T=7” reeled G=13” reeled 100=10 VDC 160=16 VDC 250=25 VDC 500=50 VDC 101=100 VDC 201=200 VDC 251=250 VDC 501=500 VDC 631=630 VDC ASC_ HQ_Low ESR_(HH)_006U_AS Oct. 2017 Multilayer Ceramic Capacitors Approval Sheet 5. EXTERNAL DIMENSIONS Size Inch (mm) L (mm) W (mm) 0201 (0603) 0.6±0.03 0.3±0.03 0.3±0.03 0402 (1005) 1.00±0.05 0.50±0.05 1.60±0.10 0.80±0.10 0603 (1608) 0805 (2012) 1.60 +0.15/-0.10 2.00±0.15 T (mm)/Symbol 0.80 +0.15/-0.10 1.25±0.10 L Remark MB (mm) L # 0.15±0.05 0.50±0.05 N # 0.25 +0.05/-0.10 0.80±0.07 S T W MB MB Fig. 1 The outline of MLCC 0.40±0.15 0.80 +0.15/-0.10 X 0.60±0.10 A 0.80±0.10 B 1.25±0.10 D 0.50±0.20 # # Reflow soldering only is recommended. 6. GENERAL ELECTRICAL DATA Dielectric NP0 Size 0201, 0402, 0603, 0805 Capacitance* 0.5pF to 3300pF #1 Cap≤5pF : A (±0.05pF), B (±0.1pF), C (±0.25pF) 5pF
HH15N1R0B500CT
物料型号: - 该文档描述的是Walsin Technology Corporation的HH系列多层陶瓷电容器,这些电容器具有高Q值和低ESR(等效串联电阻)特性。
器件简介: - 多层陶瓷电容器(MLCC)由导电材料和电极组成,用于实现小型化、高密度和高效率的表面贴装技术(SMT)。 - WTC HH系列MLCC通常在高频应用中使用,具有小的温度系数,典型值在±30ppm/°C以内,符合NP0(C0G)分类,并具有出色的导电内电极。
引脚分配: - 文档中没有直接提到引脚分配,但通常MLCC是无引脚的表面贴装元件。
参数特性: - 高Q值和高频下的低ESR性能。 - 尺寸范围从0201到0805。 - 电容值从0.5pF到3300pF。 - 电容公差、额定电压、Q值、绝缘电阻、工作温度范围和电容变化等参数。
功能详解: - 这些电容器适用于移动通信(如手机、无线局域网)、射频模块(如功率放大器、压控振荡器)和调谐器。
应用信息: - 移动通信设备、RF模块和调谐器。
封装信息: - 提供了不同尺寸(0201、0402、0603、0805)的外部尺寸和一般电气数据。 - 封装类型包括纸带和塑料带,以及7英寸和13英寸的卷轴尺寸。
HH15N1R0B500CT 价格&库存
很抱歉,暂时无法提供与“HH15N1R0B500CT”相匹配的价格&库存,您可以联系我们找货
HH15N1R0B500CT
    • 50+0.08273
    • 500+0.06718
    • 1500+0.05854
    • 10000+0.04752
    • 20000+0.04310
    • 50000+0.04061
    库存:5551
