A2005WR-2x7P
A2005WR-2x7P
    CJT(长江连接器)
    弯插,P=2mm
    排针 间距:P=2mm 2x7P 方针 弯插
A2005WR-2x7P 数据手册
A2005 SERIES 2.00mm pitch wire to board connector Specifications Current rating:2A AC,DC Voltage rating:250V AC,DC Temperature range:-40°C~+105°C Contact resistance:20m Max. Insulation resistance:1000M Min. Withstanding voltage:500V AC/minute *Compliant with RoHS and REACH* *Meet the HF/Halogen Free,need to customize* *Contact CJT for details* Standards E326732 E326732 4.00 4.00 10.35.REF 1.60 1.60 1.60 1.60 1.60 10.60.REF 9.10.REF 9.10.REF 2.10 2.10 14.35.REF 4.00 6.50 11.50.REF 9.52.REF 1.60 1.60 1.60 1.60 10.95.REF 6.00 9.50.REF 6.50 6.50 CHANGJIANG CONNECTORS TEL:+86-755-29959119 29959129 FAX:+86-755-29959139 Http://www.CJT.cn A-158 A2005 SERIES A2005-T 2.00mm pitch wire to board connector 2.00mm pitch Crimp Terminal 2.00±0.25 0.75 0.20 SEC:A-A 1.40±0.10 1.25±0.25 B 3.30±0.20 B 0.90 A 6.10±0.25 A 1.85±0.25 Reference Informations: *Used in CJT A2005H,H-N,HB-N-FI-XP,A2005H-2xXP series Housing 1.65±0.25 1.40±0.10 1.35±0.10 SEC:B-B Ordering information & Specifications: Unit:mm Part NO. Wire Range Insulation O.D. Material Finish Qty/reel A2005-TP AWG#26-#30 1.40mm(max) Phosphor Bronze Tin over Nickel 10,000 PCS AWG#26-#30 1.40mm(max) Phosphor Bronze Gold over Nickel 10,000 PCS A2005-GP Optional Gold plating available but MOQ requested A2005-T-B 2.00mm pitch Crimp Terminal 2.05±0.25 Reference Informations: *Used in CJT A2005HA,HC-2xXP,A2005HA-2xXP-A, A2005HB-N-2xXP-A(B,C,D,E,F,G,J,FI) series Dual Row Housing 0.15 0.60 1.90±0.25 1.30±0.20 3.35±0.20 B 0.80 B 2.35±0.20 A 6.25±0.25 A SEC:A-A 1.35±0.20 1.35±0.10 SEC:B-B 1.20±0.10 +0.15 1.750 Ordering information & Specifications: Unit:mm Part NO. Wire Range Insulation O.D. Material Finish Qty/reel A2005-GP-B AWG#24-#30 1.40mm(max) Phosphor Bronze Gold over Nickel 10,000 PCS CHANGJIANG CONNECTORS TEL:+86-755-29959119 29959129 FAX:+86-755-29959139 Http://www.CJT.cn A-159 A2005 SERIES A2005H-XP 2.00mm pitch wire to board connector 2.00mm pitch Single Row Housing Reference Informations: *Material:PBT,UL94V-0 *Suitable CJT A2005-T series Terminal *Mates with CJT A2005WV,WR,WVA,WRA-XP, A2005WV-S,WR-S,WVA-S-XP series Single Row Wafer *Color:Black Circuit 1 Ordering Information: A2005H-XP - *** 1 2 1.Part No. 2.Material: (Blank):PBT,UL94V-0 GWT:PBT,UL94V-0,GWT 750 ℃ 2.00±0.10 A±0.20 B±0.25 7.10±0.25 2.10±0.20 Ordering Information & Dimensions: PART NO. 2P 3P 4P 5P 6P 7P 8P 9P 10P 11P 12P 13P 14P 15P 16P 17P 18P 19P 20P 21P Dimensions A B 2.00 4.20 4.00 6.20 6.00 8.20 8.00 10.20 10.00 12.20 12.00 14.20 14.00 16.20 16.00 18.20 18.00 20.20 20.00 22.20 22.00 24.20 24.00 26.20 26.00 28.20 28.00 30.20 30.00 32.20 32.00 34.20 34.00 36.20 36.00 38.20 38.00 40.20 40.00 42.20 PART NO. 22P 23P 24P 25P 26P 27P 28P 29P 30P 31P 32P 33P 34P 35P 36P 37P 38P 39P 40P Dimensions A B 42.00 44.20 44.00 46.20 46.00 48.20 48.00 50.20 50.00 52.20 52.00 54.20 54.00 56.20 56.00 58.20 58.00 60.20 60.00 62.20 62.00 64.20 64.00 66.20 66.00 68.20 68.00 70.20 70.00 72.20 72.00 74.20 74.00 76.20 76.00 78.20 78.00 80.20 Unit: mm A2005H-N-XP 2.00mm pitch Single Row Housing Reference Informations: *Material:PBT,UL94V-0 *Suitable CJT A2005-T series Terminal *Mates with CJT A2005WV,WR,WVA,WRA-XP, A2005WV-S,WR-S,WVA-S-XP series Single Row Wafer *Color:Black A±0.20 Ordering Information: A2005H-N-XP - *** 1 2 1.Part No. 2.Material: (Blank):PBT,UL94V-0 GWT:PBT,UL94V-0,GWT 750 ℃ 2.00±0.10 Circuit 1 B±0.25 2.10±0.20 7.10±0.25 1.56±0.20 2.00±0.20 2.00±0.20 Ordering Information & Dimensions: PART NO. 2P 3P 4P 5P 6P 7P 8P 9P 10P 11P 12P 13P 14P 15P 16P 17P 18P 19P 20P 21P Dimensions A B 2.00 4.20 4.00 6.20 6.00 8.20 8.00 10.20 10.00 12.20 12.00 14.20 14.00 16.20 16.00 18.20 18.00 20.20 20.00 22.20 22.00 24.20 24.00 26.20 26.00 28.20 28.00 30.20 30.00 32.20 32.00 34.20 34.00 36.20 36.00 38.20 38.00 40.20 40.00 42.20 PART NO. 22P 23P 24P 25P 26P 27P 28P 29P 30P 31P 32P 33P 34P 35P 36P 37P 38P 39P 40P Dimensions A B 42.00 44.20 44.00 46.20 46.00 48.20 48.00 50.20 50.00 52.20 52.00 54.20 54.00 56.20 56.00 58.20 58.00 60.20 60.00 62.20 62.00 64.20 64.00 66.20 66.00 68.20 68.00 70.20 70.00 72.20 72.00 74.20 74.00 76.20 76.00 78.20 78.00 80.20 Unit: mm CHANGJIANG CONNECTORS TEL:+86-755-29959119 29959129 FAX:+86-755-29959139 Http://www.CJT.cn A-160 A2005 SERIES A2005HB-N-XP-FI 2.00mm pitch wire to board connector 2.00mm Pitch Single Row Housing Reference Informations: *Material:PBT,UL94V-0 *Suitable CJT A2005-T-B series Terminal *Mates with CJT A2005WV,WR,WVA,WRA-XP, A2005WV-S,WR-S,WVA-S-XP,A2005WR-N-F-XP-FI, A2005WR-N-S-F-XP-FI series Single Row Wafer *Color:White Odering Information: A2005HB-N-XP-FI - *** - ** 1 2 3 1.Part No. 2.Material: (blank):PBT,UL94V-0 GWT:PBT,UL94V-0,GWT 750 ℃ 3.Color: (blank):White BK:Black Circuit 1 2.00±0.10 Ordering Information & Dimensions: A±0.20 PART NO. B±0.25 B±0.25 4.00±0.20 2.80 2.00±0.20 2.00 1.40 7.10±0.25 3.10 1.00 3P~17P 2P 2P 3P 4P 5P 6P 7P 8P 9P 10P 11P 12P 13P 14P 15P 16P 17P Dimensions A B 2.00 4.35 4.00 6.35 6.00 8.35 8.00 10.35 10.00 12.35 12.00 14.35 14.00 16.35 16.00 18.35 18.00 20.35 20.00 22.35 22.00 24.35 24.00 26.35 26.00 28.35 28.00 30.35 30.00 32.35 32.00 34.35 Unit: mm A2005H-2xXP 2.00mm Pitch Dual Row Housing 2.00±0.10 2.00±0.10 Reference Informations: *Material:PBT,UL94V-0 *Suitable CJT A2005-T series Terminal *Mates with CJT A2005WV,WR,WVA,WRA-2xXP, A2005WV-S,WR-S,WVA-S,WVA-S-F-2xXP series Dual Row Wafer *Color:Black Ordering Information: A2005H-2xXP - *** 1 2 1.Part No. 2.Material: (Blank):PBT,UL94V-0 GWT:PBT,UL94V-0,GWT 750 ℃ A±0.20 B±0.25 4.00±0.25 7.10±0.25 Circuit 1 Ordering Information & Dimensions: PART NO. 2x2P 2x3P 2x4P 2x5P 2x6P 2x7P 2x8P 2x9P 2x10P 2x11P 2x12P 2x13P 2x14P 2x15P 2x16P 2x17P 2x18P 2x19P 2x20P 2x21P Dimensions A B 2.00 4.20 4.00 6.20 6.00 8.20 8.00 10.20 10.00 12.20 12.00 14.20 14.00 16.20 16.00 18.20 18.00 20.20 20.00 22.20 22.00 24.20 24.00 26.20 26.00 28.20 28.00 30.20 30.00 32.20 32.00 34.20 34.00 36.20 36.00 38.20 38.00 40.20 40.00 42.20 PART NO. 2x22P 2x23P 2x24P 2x25P 2x26P 2x27P 2x28P 2x29P 2x30P 2x31P 2x32P 2x33P 2x34P 2x35P 2x36P 2x37P 2x38P 2x39P 2x40P Dimensions A B 42.00 44.20 44.00 46.20 46.00 48.20 48.00 50.20 50.00 52.20 52.00 54.20 54.00 56.20 56.00 58.20 58.00 60.20 60.00 62.20 62.00 64.20 64.00 66.20 66.00 68.20 68.00 70.20 70.00 72.20 72.00 74.20 74.00 76.20 76.00 78.20 78.00 80.20 Unit: mm CHANGJIANG CONNECTORS TEL:+86-755-29959119 29959129 FAX:+86-755-29959139 Http://www.CJT.cn A-161 A2005 SERIES A2005H-N-2xXP-A 2.00mm pitch wire to board connector 2.00mm Pitch Dual Row Housing Reference Informations: *Material:PBT,UL94V-0 *Suitable CJT A2005 series Terminal *Mates with CJT A2005WV-N-2xXP-A,A2005WR-N-2xXP-A A2005WV-N-S-2xXP-A,A2005WV-N-S-F-2xXP-A series Dual Row Wafer *Color:Black Ordering Information: A2005H-N-2xXP-A - *** 1 2 1.Part No. 2.Material: (Blank):PBT,UL94V-0 GWT:PBT,UL94V-0,GWT 750 ℃ 2.00±0.10 Ciccuit 2 2.00±0.20 1.40 Circuit 1 Ordering Information & Dimensions: 2.00±0.10 A±0.20 B±0.25 4.10±0.25 7.10±0.25 2.00 C±0.20 PART NO. 2x7P 2x8P 2x9P 2x10P 2x11P 2x12P 2x13P 2x14P 2x15P 2x16P 2x17P 2x18P 2x19P 2x20P 2x21P 2x22P 2x23P Dimensions A B C 12.00 14.20 8.00 14.00 16.20 10.00 16.00 18.20 12.00 18.00 20.20 14.00 20.00 22.20 16.00 22.00 24.20 18.00 24.00 26.20 20.00 26.00 28.20 22.00 28.00 30.20 24.00 30.00 32.20 26.00 32.00 34.20 28.00 34.00 36.20 30.00 36.00 38.20 32.00 38.00 40.20 34.00 40.00 42.20 36.00 42.00 44.20 38.00 44.00 46.20 40.00 PART NO. 2x24P 2x25P 2x26P 2x27P 2x28P 2x29P 2x30P 2x31P 2x32P 2x33P 2x34P 2x35P 2x36P 2x37P 2x38P 2x39P 2x40P Dimensions A B C 46.00 48.20 42.00 48.00 50.20 44.00 50.00 52.20 46.00 52.00 54.20 48.00 54.00 56.20 50.00 56.00 58.20 52.00 58.00 60.20 54.00 60.00 62.20 56.00 62.00 64.20 58.00 64.00 66.20 60.00 66.00 68.20 62.00 68.00 70.20 64.00 70.00 72.20 66.00 72.00 74.20 68.00 74.00 76.20 70.00 76.00 78.20 72.00 78.00 80.20 74.00 Unit: mm A2005H-N-2xXP-B 2.00mm Pitch Dual Row Housing Reference Informations: *Material:PBT,UL94V-0 *Suitable CJT A2005 series Terminal *Mates with CJT A2005WV-N,WR-N-2xXP, A2005WV-N-S-2xXP series Dual Row Wafer *Color:Black Ordering Information: A2005H-N-2xXP-B - *** 1 2 1.Part No. 2.Material: (Blank):PBT,UL94V-0 GWT:PBT,UL94V-0,GWT 750 ℃ Circuit 2 Ordering Information & Dimensions: Circuit 1 2.00±0.10 2.00±0.10 PART NO. A±0.20 B±0.25 1.50±0.10 2.00 4.00±0.25 7.10±0.25 Circuit 1 2x2P 2x3P 2x4P 2x5P 2x6P 2x7P 2x8P 2x9P 2x10P 2x11P 2x12P 2x13P 2x14P 2x15P 2x16P 2x17P 2x18P 2x19P 2x20P 2x21P Dimensions A B 2.00 4.20 4.00 6.20 6.00 8.20 8.00 10.20 10.00 12.20 12.00 14.20 14.00 16.20 16.00 18.20 18.00 20.20 20.00 22.20 22.00 24.20 24.00 26.20 26.00 28.20 28.00 30.20 30.00 32.20 32.00 34.20 34.00 36.20 36.00 38.20 38.00 40.20 40.00 42.20 PART NO. 2x22P 2x23P 2x24P 2x25P 2x26P 2x27P 2x28P 2x29P 2x30P 2x31P 2x32P 2x33P 2x34P 2x35P 2x36P 2x37P 2x38P 2x39P 2x40P Dimensions A B 42.00 44.20 44.00 46.20 46.00 48.20 48.00 50.20 50.00 52.20 52.00 54.20 54.00 56.20 56.00 58.20 58.00 60.20 60.00 62.20 62.00 64.20 64.00 66.20 66.00 68.20 68.00 70.20 70.00 72.20 72.00 74.20 74.00 76.20 76.00 78.20 78.00 80.20 Unit: mm CHANGJIANG CONNECTORS TEL:+86-755-29959119 29959129 FAX:+86-755-29959139 Http://www.CJT.cn A-162 A2005 SERIES A2005H-N-2xXP-D 2.00mm Pitch Dual Row Housing Reference Informations: *Material:PBT,UL94V-0 *Suitable CJT A2005 series Terminal *Mates with CJT A2005WV-N,WR-N-2xXP, A2005WV-N-S2xXP series Dual Row Wafer *Color:Black Ordering Information: A2005H-N-2xXP-D - *** 1 2 1.Part No. 2.Material: (Blank):PBT,UL94V-0 GWT:PBT,UL94V-0,GWT 750 ℃ 2.00±0.10 A±0.20 2.00±0.10 2.00 Circuit 2 2.00mm pitch wire to board connector Circuit 1 B±0.25 4.10±0.25 1.50 7.10±0.25 3.50 Ordering Information & Dimensions: PART NO. 2x2P 2x3P 2x4P 2x5P 2x6P 2x7P 2x8P 2x9P 2x10P 2x11P 2x12P 2x13P 2x14P 2x15P 2x16P 2x17P 2x18P 2x19P 2x20P 2x21P 2x22P 2x23P 2x24P 2x25P Dimensions A B 2.00 4.20 4.00 6.20 6.00 8.20 8.00 10.20 10.00 12.20 12.00 14.20 14.00 16.20 16.00 18.20 18.00 20.20 20.00 22.20 22.00 24.20 24.00 26.20 26.00 28.20 28.00 30.20 30.00 32.20 32.00 34.20 34.00 36.20 36.00 38.20 38.00 40.20 40.00 42.20 42.00 44.20 44.00 46.20 46.00 48.20 48.00 50.20 Unit: mm A2005HA-2xXP 2.00mm Pitch Dual Row Housing Reference Informations: *Material:PBT,UL94V-0 *Suitable CJT A2005-T-B series Terminal *Mates with CJT A2005WV-N-2xXP-B,A2005WR-N-2xXP-B A2005WV-N-S-2xXP-B,A2005WV-N-S-F-2xXP-B series Dual Row Wafer *Color:Black Ordering Information & Dimensions: Circuit 2 Circuit 1 Ordering Information: A2005HA-2xXP - *** 1 2 1.Part No. 2.Material: (Blank):PBT,UL94V-0 GWT:PBT,UL94V-0,GWT 750 ℃ 2.00±0.10 2.00±0.10 PART NO. A±0.20 7.00±0.25 2.00 11.90±0.25 2.00 1.20±0.10 B±0.25 3.25±0.20 4.80±0.25 2x2P 2x3P 2x4P 2x5P 2x6P 2x7P 2x8P 2x9P 2x10P 2x11P 2x12P 2x13P 2x14P 2x15P 2x16P 2x17P 2x18P 2x19P 2x20P 2x21P 2x22P 2x23P 2x24P 2x25P Dimensions A B 2.00 4.35 4.00 6.35 6.00 8.35 8.00 10.35 10.00 12.35 12.00 14.35 14.00 16.35 16.00 18.35 18.00 20.35 20.00 22.35 22.00 24.35 24.00 26.35 26.00 28.35 28.00 30.35 30.00 32.35 32.00 34.35 34.00 36.35 36.00 38.35 38.00 40.35 40.00 42.35 42.00 44.35 44.00 46.35 48.35 46.00 48.00 50.35 Unit: mm CHANGJIANG CONNECTORS TEL:+86-755-29959119 29959129 FAX:+86-755-29959139 Http://www.CJT.cn A-163 A2005 SERIES A2005HA-2xXP-A 2.00mm pitch wire to board connector 2.00mm Pitch Dual Row Housing Reference Informations: *Material:PBT,UL94V-0 *Suitable CJT A2005-T-B series Terminal *Mates with CJT A2005WV-N-2xXP-B,A2005WR-N-2xXP-B A2005WV-N-S-2xXP-B,A2005WV-N-S-F-2xXP-B series Dual Row Wafer *Color:Black Ordering Information: A2005HA-2xXP-A - *** 1 2 1.Part No. 2.Material: (Blank):PBT,UL94V-0 GWT:PBT,UL94V-0,GWT 750 ℃ 2.00±0.10 2.00±0.10 A±0.20 Circuit 2 Ordering Information & Dimensions: Circuit 1 1.20±0.25 11.90±0.25 7.00±0.25 2.00 2.00 B±0.25 3.30±0.20 5.35±0.25 Dimensions A B 12.00 14.35 14.00 16.35 16.00 18.35 18.00 20.35 20.00 22.35 22.00 24.35 24.00 26.35 26.00 28.35 28.00 30.35 30.00 32.35 32.00 34.35 34.00 36.35 36.00 38.35 38.00 40.35 PART NO. 2x7P 2x8P 2x9P 2x10P 2x11P 2x12P 2x13P 2x14P 2x15P 2x16P 2x17P 2x18P 2x19P 2x20P Unit: mm A2005HC-2xXP 2.00mm Pitch Dual Row Housing Ordering Information: A2005HC-2xXP - *** 1 2 1.Part No. 2.Material: (Blank):PBT,UL94V-0 GWT:PBT,UL94V-0,GWT 750 ℃ Reference Informations: *Material:PBT,UL94V-0 *Suitable CJT A2005-T-B series Terminal *Mates with CJT A2005WV-N-2xXP-A, A2005WR-N-2xXP-A, A2005WV-N-S-2xXP-A, A2005WV-N-S-F-2xXP-A series Dual Row Wafer *Color:Black Ordering Information & Dimensions: PART NO. A±0.20 2.00±0.10 Circuit 1 B±0.25 2.00±0.10 Circuit 2 2x2P~2x6P 4.25±0.20 C±0.20 11.90±0.25 2.00 7.05±0.25 2.00 1.20 3.25±0.20 2x7P~2x25P 4.80±0.25 2x2P 2x3P 2x4P 2x5P 2x6P 2x7P 2x8P 2x9P 2x10P 2x11P 2x12P 2x13P 2x14P 2x15P 2x16P 2x17P 2x18P 2x19P 2x20P 2x21P 2x22P 2x23P 2x24P 2x25P A 2.00 4.00 6.00 8.00 10.00 12.00 14.00 16.00 18.00 20.00 22.00 24.00 26.00 28.00 30.00 32.00 34.00 36.00 38.00 40.00 42.00 44.00 46.00 48.00 Dimensions B 4.35 6.35 8.35 10.35 12.35 14.35 16.35 18.35 20.35 22.35 24.35 26.35 28.35 30.35 32.35 34.35 36.35 38.35 40.35 42.35 44.35 46.35 48.35 50.35 C ---------------- 8.00 10.00 12.00 14.00 16.00 18.00 20.00 22.00 24.00 26.00 28.00 30.00 32.00 34.00 36.00 38.00 40.00 42.00 44.00 Unit: mm CHANGJIANG CONNECTORS TEL:+86-755-29959119 29959129 FAX:+86-755-29959139 Http://www.CJT.cn A-164 A2005 SERIES A2005HI-2xXP 2.00mm pitch wire to board connector 2.00mm Pitch Dual Row Housing Reference Informations: *Material:Pin:Phosphor Bronze/Tin over Nickel Insulator:PBT+30%GF,UL94V-0 *Color:Black 2.00±0.10 Circuit 2 Circuit 1 5.75±0.15 A±0.20 4.20±0.15 2.00±0.10 B±0.25 Ordering Information: A2005HI-2xXP - * - *** - ** - *** 1 2 3 4 5 1.Part No. 2.Style: (blank):Type 1 2:Type 2 3:Type 3 3.Material: (blank):PBT+30%GF,UL94V-0 GWT:PBT,UL94V-0,GWT 750 ℃ 4.Color: (blank):Black GY:Gray 5.Finish: (blank):Tin over Nickel G:Gold-flash G15:15μin (0.38μm) MIN.Select Gold(Mating Area) 100μin (2.54μm) MIN.Select Tin G30:30μin (0.76μm) MIN.Select Gold(Mating Area) 100μin (2.54μm) MIN.Select Tin 5.40±0.15 8.60±0.15 Type 1 2x5P~2x6P 1.00±0.10 Type 1 2x7P~2x25P C±0.20 3.70±0.15 6.10±0.15 Type 2 2x5P~2x25P Type 3 2x7P~2x25P D±0.25 Ordering Information & Dimensions: 4.76±0.15 8.45±0.20 PART NO. 2x5P 2x6P 2x7P 2x8P 2x9P 2x10P 2x11P 2x12P 2x13P 2x14P 2x15P 2x16P 2x17P 2x18P 2x19P 2x20P 2x21P 2x22P 2x23P 2x24P 2x25P E±0.25 A 8.00 10.00 12.00 14.00 16.00 18.00 20.00 22.00 24.00 26.00 28.00 30.00 32.00 34.00 36.00 38.00 40.00 42.00 44.00 46.00 48.00 B 16.65 18.65 20.65 22.65 24.65 26.65 28.65 30.65 32.65 34.65 36.65 38.65 40.65 42.65 44.65 46.65 48.65 50.65 52.65 54.65 56.65 Dimensions C D 11.65 14.90 13.65 16.90 15.65 18.90 17.65 20.90 19.65 22.90 21.65 24.90 23.65 26.90 25.65 28.90 27.65 30.90 29.65 32.90 31.65 34.90 33.65 36.90 35.65 38.90 37.65 40.90 39.65 42.90 41.65 44.90 43.65 46.90 45.65 48.90 47.65 50.90 49.65 52.90 51.65 54.90 E 15.95 17.95 19.95 21.95 23.95 25.95 27.95 29.95 31.95 33.95 35.95 37.95 39.95 41.95 43.95 45.95 47.95 49.95 51.95 53.95 55.95 Unit: mm CHANGJIANG CONNECTORS TEL:+86-755-29959119 29959129 FAX:+86-755-29959139 Http://www.CJT.cn A-165 A2005 SERIES A2005HB-N-2xXP-A 2.00mm pitch wire to board connector 2.00mm Pitch Dual Row Housing Reference Informations: *Material:PBT,UL94V-0 *Suitable CJT A2005-T-B series Terminal *Mates with CJT A2005WV-N-2xXP-A(B),A2005WR-N-2xXP-A(B) A2005WV-N-S-2xXP-A(B),A2005WV-N-S-F-2xXP-A(B) series Dual Row Wafer *Color:Black Ordering Information & Dimensions: Circuit 2 2.00±0.10 Circuit 1 2.00±0.10 Ordering Information: A2005HB-N-2xXP-A - *** 1 2 1.Part No. 2.Material: (Blank):PBT,UL94V-0 GWT:PBT,UL94V-0,GWT 750 ℃ PART NO. 2x2P 2x3P 2x4P 2x5P 2x6P 2x7P 2x8P 2x9P 2x10P 2x11P 2x12P 2x13P 2x14P 2x15P 2x16P 2x17P 2x18P 2x19P 2x20P 2x21P 2x22P 2x23P 2x24P 2x25P A±0.20 B±0.25 2x2P~2x6P C±0.20 5.30±0.20 4.20±0.20 7.00±0.25 2.00 2.00 4.80±0.20 2x7P~2x25P A 2.00 4.00 6.00 8.00 10.00 12.00 14.00 16.00 18.00 20.00 22.00 24.00 26.00 28.00 30.00 32.00 34.00 36.00 38.00 40.00 42.00 44.00 46.00 48.00 Dimensions B 4.35 6.35 8.35 10.35 12.35 14.35 16.35 18.35 20.35 22.35 24.35 26.35 28.35 30.35 32.35 34.35 36.35 38.35 40.35 42.35 44.35 46.35 48.35 50.35 C ---------------8.00 10.00 12.00 14.00 16.00 18.00 20.00 22.00 24.00 26.00 28.00 30.00 32.00 34.00 36.00 38.00 40.00 42.00 44.00 Unit: mm A2005HB-N-2xXP-B 2.00mm Pitch Dual Row Housing Reference Informations: *Material:PBT,UL94V-0 *Suitable CJT A2005-T-B series Terminal *Mates with CJT A2005WV-N-2xXP-B,A2005WR-N-2xXP-B, A2005WV-N-S-2xXP-B,A2005WV-N-S-F-2xXP-B series Dual Row Wafer *Color:Black Circuit 2 Ordering Information: A2005HB-N-2xXP-B - *** 1 2 1.Part No. 2.Material: (Blank):PBT,UL94V-0 GWT:PBT,UL94V-0,GWT 750 ℃ Circuit 1 2.00±0.10 A±0.20 B±0.25 0.90 4.20±0.20 2.00 0.65 7.00±0.25 Ordering Information & Dimensions: PART NO. 2x2P 2x3P 2x4P 2x5P 2x6P 4.80±0.20 Dimensions A B 2.00 4.35 4.00 6.35 6.00 8.35 10.35 8.00 10.00 12.35 Unit: mm CHANGJIANG CONNECTORS TEL:+86-755-29959119 29959129 FAX:+86-755-29959139 Http://www.CJT.cn A-166 A2005 SERIES A2005HB-N-2xXP-C 2.00mm pitch wire to board connector 2.00mm Pitch Dual Row Housing Reference Informations: *Material:PBT,UL94V-0 *Suitable CJT A2005-T-B series Terminal *Mates with CJT A2005WV-N-2xXP-B,A2005WR-N-2xXP-B, A2005WV-N-S-2xXP-B,A2005WV-N-S-F-2xXP-B series Dual Row Wafer *Color:Black Circuit 2 Ordering Information: A2005HB-N-2xXP-C - *** 1 2 1.Part No. 2.Material: (Blank):PBT,UL94V-0 GWT:PBT,UL94V-0,GWT 750 ℃ 0.90 0.70 Circuit 1 2.00±0.10 A±0.20 B±0.25 0.90 4.20±0.20 0.65 2.00 7.00±0.25 Ordering Information & Dimensions: Dimensions A B 2.00 4.35 4.00 6.35 6.00 8.35 8.00 10.35 10.00 12.35 PART NO. 2x2P 2x3P 2x4P 2x5P 2x6P 4.80±0.20 A2005HB-N-2xXP-D(-E) 2.00mm Pitch Dual Row Housing Reference Informations: *Material:PBT,UL94V-0 *Suitable CJT A2005-T-B series Terminal *Mates with CJT A2005WV-N-2xXP-A(B), A2005WR-N-2xXP-A(B),A2005WV-N-S-2xXP-A(B), A2005WV-N-S-F-2xXP-A(B) series Dual Row Wafe r *Color:Black Ordering Information: A2005HB-N-2xXP-D(-E) - *** 1 2 1.Part No. 2.Material: (Blank):PBT,UL94V-0 GWT:PBT,UL94V-0,GWT 750 ℃ Circuit 1 A±0.20 2x2P~2x25P A2005HB-N-2xXP-E B±0.25 4.20±0.20 1.10 2.00 7.00±0.25 1.00 C±0.20 2x7P~2x25P A2005HB-N-2xXP-D Ordering Information & Dimensions: PART NO. Circuit 2 2.00±0.10 Unit: mm 4.80±0.20 2x2P 2x3P 2x4P 2x5P 2x6P 2x7P 2x8P 2x9P 2x10P 2x11P 2x12P 2x13P 2x14P 2x15P 2x16P 2x17P 2x18P 2x19P 2x20P 2x21P 2x22P 2x23P 2x24P 2x25P A 2.00 4.00 6.00 8.00 10.00 12.00 14.00 16.00 18.00 20.00 22.00 24.00 26.00 28.00 30.00 32.00 34.00 36.00 38.00 40.00 42.00 44.00 46.00 48.00 Dimensions B 4.35 6.35 8.35 10.35 12.35 14.35 16.35 18.35 20.35 22.35 24.35 26.35 28.35 30.35 32.35 34.35 36.35 38.35 40.35 42.35 44.35 46.35 48.35 50.35 C ---------------8.00 10.00 12.00 14.00 16.00 18.00 20.00 22.00 24.00 26.00 28.00 30.00 32.00 34.00 36.00 38.00 40.00 42.00 44.00 Unit: mm CHANGJIANG CONNECTORS TEL:+86-755-29959119 29959129 FAX:+86-755-29959139 Http://www.CJT.cn A-167 A2005 SERIES A2005HB-N-2xXP-F 2.00mm pitch wire to board connector 2.00mm Pitch Dual Row Housing Reference Informations: *Material:PBT,UL94V-0 *Suitable CJT A2005-T-B series Terminal *Mates with CJT A2005WV-N-2xXP-B,A2005WR-N-2xXP-B, A2005WV-N-S-2xXP-B,A2005WV-N-S-F-2xXP-B series Dual Row Wafer *Color:Black Circuit 2 Circuit 1 2.00±0.10 Ordering Information: A2005HB-N-2xXP-F - *** 1 2 1.Part No. 2.Material: (Blank):PBT,UL94V-0 GWT:PBT,UL94V-0,GWT 750 ℃ A±0.20 B±0.25 1.00 4.20±0.20 2.00 1.00 7.00±0.25 Ordering Information & Dimensions: PART NO. 2x2P 2x3P 2x4P 2x5P 2x6P 4.80±0.20 Dimensions A B 2.00 4.35 4.00 6.35 6.00 8.35 8.00 10.35 10.00 12.35 Unit: mm CHANGJIANG CONNECTORS TEL:+86-755-29959119 29959129 FAX:+86-755-29959139 Http://www.CJT.cn A-168 A2005 SERIES A2005HB-N-2xXP-G 2.00mm pitch wire to board connector 2.00mm Pitch Dual Row Housing Reference Informations: *Material:PBT,UL94V-0 *Suitable CJT A2005-T-B series Terminal *Color:Black Ordering Information: A2005HB-N-2xXP-G - *** 1 2 1.Part No. 2.Material: (Blank):PBT,UL94V-0 GWT:PBT,UL94V-0,GWT 750 ℃ F F G H Circuit 1 Circuit 2 J 2.20±0.10 J 2.40±0.10 K Last Circuit K L 2.00±0.10 L 2x4P~2x10P 2x3P 1.90 panel hole layout C±0.25 8.35±0.25 C±0.25 6.40±0.25 1.00 D 11.00±0.25 10.00±0.25 4.20±0.25 D E±0.25 E±0.25 2x4P~2x10P 2x3P 10.30±0.25 Ordering Information & Dimensions: PART NO. 2x3P Dimensions A B C D E F G H J K L 2.00 2.00 8.20 2.40 10.20 10.30 2.40 4.80 2.50 5.00 7.00 2x4P 2.00 2.00 8.20 4.40 10.20 11.30 2.40 5.60 2.50 5.00 8.80 2x5P 3.00 3.00 10.40 6.40 12.20 13.30 2.60 6.70 2.60 6.10 10.90 2x6P 4.00 4.00 12.40 8.40 14.20 15.30 2.60 7.70 2.60 7.10 12.90 2x7P 5.00 5.00 14.40 10.40 16.20 17.30 2.60 8.70 2.60 8.10 14.90 2x8P 6.00 6.00 16.40 12.40 18.20 19.30 2.60 9.70 2.60 9.10 16.90 2x9P 7.00 7.00 18.40 14.40 20.20 21.30 2.60 10.70 2.60 10.10 18.90 2x10P 8.00 8.00 20.40 16.40 22.20 23.30 2.60 11.70 2.60 11.10 20.90 Unit: mm CHANGJIANG CONNECTORS TEL:+86-755-29959119 29959129 FAX:+86-755-29959139 Http://www.CJT.cn A-169 7.30±0.10 5.10±0.10 8.90±0.10 7.30±0.10 8.90±0.10 2.00±0.10 5.10±0.10 B 2.00 A G H A2005 SERIES A2005HB-N-2xXP-J 2.00mm pitch wire to board connector 2.00mm Pitch Dual Row Housing Reference Informations: *Material:PBT,UL94V-0 *Suitable CJT A2005-T-B series Terminal *Mates with CJT A2005WV-N-2xXP-B,A2005WR-N-2xXP-B, A2005WV-N-S-2xXP-B,A2005WV-N-S-F-2xXP-B series Dual Row Wafer *Color:Black Ordering Information & Dimensions: Circuit 2 PART NO. Ordering Information: A2005HB-N-2xXP-J - *** 1 2 1.Part No. 2.Material: (Blank):PBT,UL94V-0 GWT:PBT,UL94V-0,GWT 750 ℃ Circuit 1 2.00±0.10 A±0.20 B±0.25 7.00±0.25 4.20±0.20 4.80±0.20 2x2P 2x3P 2x4P 2x5P 2x6P 2x7P 2x8P 2x9P 2x10P 2x11P 2x12P 2x13P 2x14P 2x15P 2x16P 2x17P 2x18P 2x19P 2x20P 2x21P 2x22P 2x23P 2x24P 2x25P Dimensions A B 2.00 4.35 4.00 6.35 6.00 8.35 8.00 10.35 10.00 12.35 12.00 14.35 14.00 16.35 16.00 18.35 18.00 20.35 20.00 22.35 22.00 24.35 24.00 26.35 26.00 28.35 28.00 30.35 30.00 32.35 32.00 34.35 34.00 36.35 36.00 38.35 38.00 40.35 40.00 42.35 42.00 44.35 44.00 46.35 46.00 48.35 48.00 50.35 Unit: mm A2005HB-N-2xXP-FI 2.00mm Pitch Dual Row Housing Reference Informations: *Material:PBT,UL94V-0 *Suitable CJT A2005-T-B series Terminal *Mates with CJT A2005WV-N-2xXP-FI,A2005WR-N-2xXP-FI, A2005WV-N-S-2xXP-FI series Dual Row Wafer *Color:Black Ordering Information & Dimensions: 2.00±0.10 Circuit 2 2.00±0.10 PART NO. Circuit 1 2x2P A±0.20 Ordering Information: A2005HB-N-2xXP-FI - *** 1 2 1.Part No. 2.Material: (Blank):PBT,UL94V-0 GWT:PBT,UL94V-0,GWT 750 ℃ B±0.25 4.00±0.20 2x3P~2x25P 7.00±0.25 2.60 2.00 4.20±0.20 0.50 4.80±0.20 2x2P 2x3P 2x4P 2x5P 2x6P 2x7P 2x8P 2x9P 2x10P 2x11P 2x12P 2x13P 2x14P 2x15P 2x16P 2x17P 2x18P 2x19P 2x20P 2x21P 2x22P 2x23P 2x24P 2x25P Dimensions A B 2.00 4.35 4.00 6.35 6.00 8.35 8.00 10.35 10.00 12.35 12.00 14.35 14.00 16.35 16.00 18.35 18.00 20.35 20.00 22.35 22.00 24.35 24.00 26.35 26.00 28.35 28.00 30.35 30.00 32.35 32.00 34.35 34.00 36.35 36.00 38.35 38.00 40.35 40.00 42.35 42.00 44.35 44.00 46.35 48.35 46.00 48.00 50.35 Unit: mm CHANGJIANG CONNECTORS TEL:+86-755-29959119 29959129 FAX:+86-755-29959139 Http://www.CJT.cn A-170 A2005 SERIES A2005WR-N-F-XP-FI 2.00mm Pitch 90° Single Row Box Header Ordering Information: A2005WR-N-F-XP-FI - *** - *** 1 2 3 1.Part No. 2.Material: (blank):LCP,UL94V-0 GWT:LCP,UL94V-0,GWT 750 ℃ 3.Finish: (blank):Gold-flash G15:15μin (0.38μm) MIN.Select Gold(Mating Area) 100μin (2.54μm) MIN.Select Tin G30:30μin (0.76μm) MIN.Select Gold(Mating Area) 100μin (2.54μm) MIN.Select Tin T:Tin over Nickel Reference Informations: *Material:Pin:Brass/Gold over Nickel Insulator:LCP,UL94V-0 *Mates with CJT A2005HB-N-XP-FI series Single Row Housing *Color:Beige A±0.20 2.00±0.10 2.00mm pitch wire to board connector Circuit 1 B+3.30 2.50 1.60 2.60 1.05 C C±0.25 3.00±0.25 2.00 A 3.75±0.25 8.40±0.25 ∅1.60 1.20 ∅0.95 Ordering Information & Dimensions: A 6.00 10.00 14.00 4P 6P 8P Dimensions B 10.60 14.60 18.60 C 6.40 10.40 14.40 Unit: mm A2005WR-N-S-F-XP-FI 2.00mm Pitch 90° Single Row Box Header - SMT TYPE Ordering Information: A2005WR-N-S-F-XP-FI - *** - *** 1 2 3 1.Part No. 2.Material: (blank):LCP,UL94V-0 GWT:LCP,UL94V-0,GWT 750 ℃ 3.Finish: (blank):Gold-flash G15:15μin (0.38μm) MIN.Select Gold(Mating Area) 100μin (2.54μm) MIN.Select Tin G30:30μin (0.76μm) MIN.Select Gold(Mating Area) 100μin (2.54μm) MIN.Select Tin T:Tin over Nickel Reference Informations: *Material:Pin:Brass/Gold over Nickel Insulator:LCP,UL94V-0 *Mates with CJT A2005HB-N-XP-FI series Single Row Housing *Color:Beige PIN 0.50 SQ P.C.B LAYOUT PART NO. 1.20±0.20 B±0.25 3.75 1.20 PIN 0.50 SQ ∅1.80 KAPTON TAPE (FOR PICK AND PLACE SYSTEMS) A 2.00 4.00 1.90 0.90 ∅1.70 C B±0.25 8.40±0.25 A±0.20 2.30±0.20 Circuit 1 PART NO. ∅1.60 C±0.25 P.C.B LAYOUT Ordering Information & Dimensions: 1.20 3.00±0.25 2.00±0.10 3.40±0.25 4P 6P 8P A 6.00 10.00 14.00 Dimensions B 10.60 14.60 18.60 C 6.40 10.40 14.40 Unit: mm CHANGJIANG CONNECTORS TEL:+86-755-29959119 29959129 FAX:+86-755-29959139 Http://www.CJT.cn A-171 A2005 SERIES A2005WV-N-2xXP 2.00mm Pitch 180° Dual Row Box Header Reference Informations: *Material:Pin:Brass/Gold over Nickel Insulator:PBT,UL94V-0 *Mates with CJT A2005H-N-2xXP-B(D) series Dual Row Housing *Color:Black 2.00±0.10 2.00±0.05 2.00±0.10 4.40±0.20 Circuit 2 Circuit 1 2.00mm pitch wire to board connector Ordering Information: A2005WV-N-2xXP - *** - *** 1 2 3 1.Part No. 2.Material: (blank):PBT,UL94V-0 6T:Nylon 6T,UL94V-0 GWT:Nylon 6T,UL94V-0,GWT 750 ℃ 3.Finish: (blank):Gold-flash G15:15μin (0.38μm) MIN.Select Gold(Mating Area) 100μin (2.54μm) MIN.Select Tin G30:30μin (0.76μm) MIN.Select Gold(Mating Area) 100μin (2.54μm) MIN.Select Tin T:Tin over Nickel 2.00±0.05 Ordering Information & Dimensions: PART NO. A±0.20 ∅0.80±0.05 P.C.B LAYOUT B±0.20 5.50±0.25 2.80±0.10 5.70±0.25 4.00 2.00±0.10 PIN 0.50 SQ 2x4P 2x5P 2x6P 2x7P 2x8P 2x9P 2x10P 2x11P 2x12P 2x13P 2x14P 2x15P 2x16P 2x17P 2x18P 2x19P Dimensions A B 6.00 15.30 8.00 17.30 10.00 19.30 12.00 21.30 14.00 23.30 16.00 25.30 18.00 27.30 20.00 29.30 22.00 31.30 24.00 33.30 26.00 35.30 28.00 37.30 30.00 39.30 32.00 41.30 34.00 43.30 36.00 45.30 PART NO. 2x20P 2x21P 2x22P 2x23P 2x24P 2x25P 2x26P 2x27P 2x28P 2x29P 2x30P 2x31P 2x32P 2x33P 2x34P Dimensions A B 38.00 47.30 40.00 49.30 42.00 51.30 44.00 53.30 46.00 55.30 48.00 57.30 50.00 59.30 52.00 61.30 54.00 63.30 56.00 65.30 58.00 67.30 60.00 69.30 62.00 71.30 64.00 73.30 66.00 75.30 Unit: mm A2005WR-N-2xXP 2.00mm Pitch 90° Dual Row Box Header Reference Informations: *Material:Pin:Brass/Gold over Nickel Insulator:PBT,UL94V-0 *Mates with CJT A2005H-N-2xXP-B(D) series Dual Row Housing *Color:Black Ordering Information & Dimensions: PART NO. A±0.20 ∅0.80±0.05 P.C.B LAYOUT B±0.20 5.50±0.25 1.00 5.70±0.25 4.00 PIN 0.50 SQ 2.00±0.05 2.00±0.10 Circuit 1 2.00±0.10 2.00±0.05 2.00±0.10 4.40±0.20 Circuit 2 Ordering Information: A2005WR-N-2xXP - *** - *** 1 2 3 1.Part No. 2.Material: (Blank):PBT,UL94V-0 6T:Nylon 6T,UL94V-0 GWT:Nylon 6T,UL94V-0,GWT 750 ℃ 3.Finish: (blank):Gold-flash G15:15μin (0.38μm) MIN.Select Gold(Mating Area) 100μin (2.54μm) MIN.Select Tin G30:30μin (0.76μm) MIN.Select Gold(Mating Area) 100μin (2.54μm) MIN.Select Tin T:Tin over Nickel 2.80±0.20 2x4P 2x5P 2x6P 2x7P 2x8P 2x9P 2x10P 2x11P 2x12P 2x13P 2x14P 2x15P 2x16P 2x17P 2x18P 2x19P Dimensions A B 6.00 15.30 17.30 8.00 10.00 19.30 12.00 21.30 14.00 23.30 16.00 25.30 18.00 27.30 20.00 29.30 22.00 31.30 33.30 24.00 26.00 35.30 28.00 37.30 30.00 39.30 32.00 41.30 34.00 43.30 36.00 45.30 PART NO. 2x20P 2x21P 2x22P 2x23P 2x24P 2x25P 2x26P 2x27P 2x28P 2x29P 2x30P 2x31P 2x32P 2x33P 2x34P Dimensions A B 38.00 47.30 49.30 40.00 42.00 51.30 44.00 53.30 46.00 55.30 48.00 57.30 50.00 59.30 52.00 61.30 54.00 63.30 65.30 56.00 58.00 67.30 60.00 69.30 62.00 71.30 64.00 73.30 66.00 75.30 Unit: mm CHANGJIANG CONNECTORS TEL:+86-755-29959119 29959129 FAX:+86-755-29959139 Http://www.CJT.cn A-172 A2005 SERIES A2005WV-N-2xXP-A 2.00mm Pitch 180° Dual Row Box Header - A TYPE Ordering Information: A2005WV-N-2xXP-A - *** - *** 1 2 3 1.Part No. 2.Material: (Blank):Nylon 6T,UL94V-0 GWT:Nylon 6T,UL94V-0,GWT 750 ℃ 3.Finish: (blank):Gold-flash G15:15μin (0.38μm) MIN.Select Gold(Mating Area) 100μin (2.54μm) MIN.Select Tin G30:30μin (0.76μm) MIN.Select Gold(Mating Area) 100μin (2.54μm) MIN.Select Tin T:Tin over Nickel Reference Informations: *Material:Pin:Brass/Gold over Nickel Insulator:Nylon 6T,UL94V-0 *Mates with CJT A2005HB-N-2xXP-A(D) series Dual Row Housing *Color:Black A±0.20 Circuit 2 Circuit 1 2.00±0.10 2.00±0.10 2.00±0.10 A±0.10 2.00mm pitch wire to board connector Circuit 2 Circuit 1 B±0.25 4.70±0.25 6.30±0.25 2.50 6.40±0.25 B±0.25 PIN 0.50 SQ C±0.25 2x2P C±0.25 2x3P~2x6P A±0.20 2.00±0.10 2.00±0.10 Circuit 2 2.00±0.05 PIN 0.50 SQ 2.00±0.05 PART NO. Ø0.80±0.05 P.C.B LAYOUT Circuit 1 6.40±0.25 2.50 PIN 0.50 SQ C±0.25 2x7P~2x25P 4.70±0.25 6.30±0.25 B±0.25 Ordering Information & Dimensions: 2x2P 2x3P 2x4P 2x5P 2x6P 2x7P 2x8P 2x9P 2x10P 2x11P 2x12P 2x13P 2x14P 2x15P 2x16P 2x17P 2x18P 2x19P 2x20P 2x21P 2x22P 2x23P 2x24P 2x25P A 2.00 4.00 6.00 8.00 10.00 12.00 14.00 16.00 18.00 20.00 22.00 24.00 26.00 28.00 30.00 32.00 34.00 36.00 38.00 40.00 42.00 44.00 46.00 48.00 Dimensions B 6.65 8.65 10.65 12.65 14.65 16.65 18.65 20.65 22.65 24.65 26.65 28.65 30.65 32.65 34.65 36.65 38.65 40.65 42.65 44.65 46.65 48.65 50.65 52.65 C 5.00 7.00 9.00 11.00 13.00 15.00 17.00 19.00 21.00 23.00 25.00 27.00 29.00 31.00 33.00 35.00 37.00 39.00 41.00 43.00 45.00 47.00 49.00 51.00 Unit: mm CHANGJIANG CONNECTORS TEL:+86-755-29959119 29959129 FAX:+86-755-29959139 Http://www.CJT.cn A-173 A2005 SERIES A2005WV-N-2xXP-B 2.00mm Pitch 180° Dual Row Box Header - B TYPE Ordering Information: A2005WV-N-2xXP-B - *** - *** 1 2 3 1.Part No. 2.Material: (Blank):Nylon 6T,UL94V-0 GWT:Nylon 6T,UL94V-0,GWT 750 ℃ 3.Finish: (blank):Gold-flash G15:15μin (0.38μm) MIN.Select Gold(Mating Area) 100μin (2.54μm) MIN.Select Tin G30:30μin (0.76μm) MIN.Select Gold(Mating Area) 100μin (2.54μm) MIN.Select Tin T:Tin over Nickel Reference Informations: *Material:Pin:Brass/Gold over Nickel Insulator:Nylon 6T,UL94V-0 *Mates with CJT A2005HB-N-2xXP-A(D,F) series Dual Row Housing *Color:Black 2.00±0.10 A±0.10 Circuit 2 2.00mm pitch wire to board connector Circuit 1 B±0.25 2.50 6.40±0.25 4.70±0.25 6.30±0.25 PIN 0.50 SQ 2.00±0.05 C±0.25 2x2P A±0.20 Ø0.80±0.05 2.00±0.10 2.00±0.10 Circuit 2 2.00±0.05 Ordering Information & Dimensions: P.C.B LAYOUT PART NO. Circuit 1 B±0.25 2.50 PIN 0.50 SQ C±0.25 2x3P~2x25P 4.70±0.25 6.40±0.25 6.30±0.25 2x2P 2x3P 2x4P 2x5P 2x6P 2x7P 2x8P 2x9P 2x10P 2x11P 2x12P 2x13P 2x14P 2x15P 2x16P 2x17P 2x18P 2x19P 2x20P 2x21P 2x22P 2x23P 2x24P 2x25P A 2.00 4.00 6.00 8.00 10.00 12.00 14.00 16.00 18.00 20.00 22.00 24.00 26.00 28.00 30.00 32.00 34.00 36.00 38.00 40.00 42.00 44.00 46.00 48.00 Dimensions B 6.65 8.65 10.65 12.65 14.65 16.65 18.65 20.65 22.65 24.65 26.65 28.65 30.65 32.65 34.65 36.65 38.65 40.65 42.65 44.65 46.65 48.65 50.65 52.65 C 5.00 7.00 9.00 11.00 13.00 15.00 17.00 19.00 21.00 23.00 25.00 27.00 29.00 31.00 33.00 35.00 37.00 39.00 41.00 43.00 45.00 47.00 49.00 51.00 Unit: mm CHANGJIANG CONNECTORS TEL:+86-755-29959119 29959129 FAX:+86-755-29959139 Http://www.CJT.cn A-174 A2005 SERIES A2005WV-N-S-2xXP-A 2.00mm pitch wire to board connector 2.00mm Pitch 180° Dual Row Box Header - SMT A TYPE Ordering Information: A2005WV-N-S-2xXP-A - *** - *** 1 2 3 1.Part No. 2.Material: (Blank):LCP,UL94V-0 6T:Nylon 6T,UL94V-0 GWT:LCP,UL94V-0,GWT 750 ℃ 3.Finish: (blank):Gold-flash G15:15μin (0.38μm) MIN.Select Gold(Mating Area) 100μin (2.54μm) MIN.Select Tin G30:30μin (0.76μm) MIN.Select Gold(Mating Area) 100μin (2.54μm) MIN.Select Tin T:Tin over Nickel Reference Informations: *Material:Pin:Brass/Gold over Nickel Insulator:LCP,UL94V-0 *Mates with CJT A2005HB-N-2xXP-A(B,C,D) series Dual Row Housing *Color:Black A±0.20 A±0.10 2.00±0.10 2.00±0.10 2.00±0.10 Circuit 2 Circuit 2 Circuit 1 Circuit 1 B±0.25 B±0.25 1.00±0.05 6.30±0.25 PIN 0.50 SQ PIN 0.50 SQ C±0.25 2x2P C±0.25 3.00 6.00±0.20 A±0.10 P.C.B LAYOUT 2x3P~2x6P A±0.20 Ordering Information & Dimensions: 2.00±0.10 Circuit 2 1.50 4.70±0.25 6.40±0.25 7.80±0.25 2.00±0.05 2.00±0.10 PART NO. Circuit 1 B±0.25 4.70±0.25 6.40±0.25 7.80±0.25 6.30±0.25 PIN 0.50 SQ 6.00±0.20 C±0.25 2x7P~2x25P 2x2P 2x3P 2x4P 2x5P 2x6P 2x7P 2x8P 2x9P 2x10P 2x11P 2x12P 2x13P 2x14P 2x15P 2x16P 2x17P 2x18P 2x19P 2x20P 2x21P 2x22P 2x23P 2x24P 2x25P A 2.00 4.00 6.00 8.00 10.00 12.00 14.00 16.00 18.00 20.00 22.00 24.00 26.00 28.00 30.00 32.00 34.00 36.00 38.00 40.00 42.00 44.00 46.00 48.00 Dimensions B 6.65 8.65 10.65 12.65 14.65 16.65 18.65 20.65 22.65 24.65 26.65 28.65 30.65 32.65 34.65 36.65 38.65 40.65 42.65 44.65 46.65 48.65 50.65 52.65 C 5.00 7.00 9.00 11.00 13.00 15.00 17.00 19.00 21.00 23.00 25.00 27.00 29.00 31.00 33.00 35.00 37.00 39.00 41.00 43.00 45.00 47.00 49.00 51.00 Unit: mm CHANGJIANG CONNECTORS TEL:+86-755-29959119 29959129 FAX:+86-755-29959139 Http://www.CJT.cn A-175 A2005 SERIES A2005WV-N-S-2xXP-B 2.00mm Pitch 180° Dual Row Box Header - SMT B TYPE Ordering Information: A2005WV-N-S-2xXP-B - *** - *** 1 2 3 1.Part No. 2.Material: (Blank):LCP,UL94V-0 6T:Nylon 6T,UL94V-0 GWT:LCP,UL94V-0,GWT 750 ℃ 3.Finish: (blank):Gold-flash G15:15μin (0.38μm) MIN.Select Gold(Mating Area) 100μin (2.54μm) MIN.Select Tin G30:30μin (0.76μm) MIN.Select Gold(Mating Area) 100μin (2.54μm) MIN.Select Tin T:Tin over Nickel 2.00±0.10 Reference Informations: *Material:Pin:Brass/Gold over Nickel Insulator:LCP,UL94V-0 *Mates with CJT A2005HB-N-2xXP-A(D,E,F) series Dual Row Housing *Color:Black A±0.10 Circuit 2 2.00mm pitch wire to board connector Circuit 1 7.80±0.25 1.00±0.05 6.00±0.20 3.00 C±0.25 2.00±0.05 1.50 PIN 0.50 SQ 4.70±0.25 6.30±0.25 6.40±0.25 B±0.25 2x2P A±0.10 P.C.B LAYOUT A±0.20 2.00±0.10 2.00±0.10 Circuit 2 Ordering Information & Dimensions: PART NO. Circuit 1 B±0.25 PIN 0.50 SQ 7.80±0.25 4.70±0.25 6.40±0.25 6.30±0.25 6.00±0.20 C±0.25 2x3P~2x25P 2x2P 2x3P 2x4P 2x5P 2x6P 2x7P 2x8P 2x9P 2x10P 2x11P 2x12P 2x13P 2x14P 2x15P 2x16P 2x17P 2x18P 2x19P 2x20P 2x21P 2x22P 2x23P 2x24P 2x25P A 2.00 4.00 6.00 8.00 10.00 12.00 14.00 16.00 18.00 20.00 22.00 24.00 26.00 28.00 30.00 32.00 34.00 36.00 38.00 40.00 42.00 44.00 46.00 48.00 Dimensions B 6.65 8.65 10.65 12.65 14.65 16.65 18.65 20.65 22.65 24.65 26.65 28.65 30.65 32.65 34.65 36.65 38.65 40.65 42.65 44.65 46.65 48.65 50.65 52.65 C 5.00 7.00 9.00 11.00 13.00 15.00 17.00 19.00 21.00 23.00 25.00 27.00 29.00 31.00 33.00 35.00 37.00 39.00 41.00 43.00 45.00 47.00 49.00 51.00 Unit: mm CHANGJIANG CONNECTORS TEL:+86-755-29959119 29959129 FAX:+86-755-29959139 Http://www.CJT.cn A-176 A2005 SERIES A2005WV-N-S-F-2xXP-A 2.00mm pitch wire to board connector 2.00mm Pitch 180° Dual Row Box Header - SMT A TYPE Reference Informations: *Material:Pin:Brass/Gold over Nickel Insulator:LCP,UL94V-0 *Mates with CJT A2005HB-N-2xXP-A(D) series Dual Row Housing *Color:Black Ordering Information: A2005WV-N-S-F-2xXP-A - *** - *** 1 2 3 1.Part No. 2.Material: (Blank):LCP,UL94V-0 6T:Nylon 6T,UL94V-0 GWT:LCP,UL94V-0,GWT 750 ℃ 3.Finish: (blank):Gold-flash G15:15μin (0.38μm) MIN.Select Gold(Mating Area) 100μin (2.54μm) MIN.Select Tin G30:30μin (0.76μm) MIN.Select Gold(Mating Area) 100μin (2.54μm) MIN.Select Tin T:Tin over Nickel A±0.20 2.00±0.10 2.00±0.10 Circuit 2 Circuit 1 B±0.25 6.30±0.25 2.20±0.20 6.00±0.20 C±0.25 3.00 Ø1.00±0.05 1.00±0.10 PIN 0.50 SQ 1.00±0.05 1.50 4.70±0.25 6.40±0.25 7.80±0.25 2.00±0.05 1.00±0.05 1.00±0.05 A±0.10 P.C.B LAYOUT 2x3P~2x6P A±0.20 2.00±0.10 Circuit 2 Ordering Information & Dimensions: 2.00±0.10 PART NO. Circuit 1 B±0.25 PIN 0.50 SQ 4.70±0.25 6.00±0.20 C±0.25 2x7P~2x25P 2.20±0.20 1.00±0.10 6.40±0.25 7.80±0.25 6.30±0.25 2x3P 2x4P 2x5P 2x6P 2x7P 2x8P 2x9P 2x10P 2x11P 2x12P 2x13P 2x14P 2x15P 2x16P 2x17P 2x18P 2x19P 2x20P 2x21P 2x22P 2x23P 2x24P 2x25P A 4.00 6.00 8.00 10.00 12.00 14.00 16.00 18.00 20.00 22.00 24.00 26.00 28.00 30.00 32.00 34.00 36.00 38.00 40.00 42.00 44.00 46.00 48.00 Dimensions B 8.65 10.65 12.65 14.65 16.65 18.65 20.65 22.65 24.65 26.65 28.65 30.65 32.65 34.65 36.65 38.65 40.65 42.65 44.65 46.65 48.65 50.65 52.65 C 7.00 9.00 11.00 13.00 15.00 17.00 19.00 21.00 23.00 25.00 27.00 29.00 31.00 33.00 35.00 37.00 39.00 41.00 43.00 45.00 47.00 49.00 51.00 Unit: mm CHANGJIANG CONNECTORS TEL:+86-755-29959119 29959129 FAX:+86-755-29959139 Http://www.CJT.cn A-177 A2005 SERIES A2005WV-N-S-F-2xXP-B 2.00mm pitch wire to board connector 2.00mm Pitch 180° Dual Row Box Header - SMT B TYPE Reference Informations: *Material:Pin:Brass/Gold over Nickel Insulator:LCP,UL94V-0 *Mates with CJT A2005HB-N-2xXP-A(D,E,F) series Dual Row Housing *Color:Black 2.00±0.10 A±0.20 2.00±0.10 Circuit 2 Ordering Information: A2005WV-N-S-F-2xXP-B - *** - *** 1 2 3 1.Part No. 2.Material: (Blank):LCP,UL94V-0 6T:Nylon 6T,UL94V-0 GWT:LCP,UL94V-0,GWT 750 ℃ 3.Finish: (blank):Gold-flash G15:15μin (0.38μm) MIN.Select Gold(Mating Area) 100μin (2.54μm) MIN.Select Tin G30:30μin (0.76μm) MIN.Select Gold(Mating Area) 100μin (2.54μm) MIN.Select Tin T:Tin over Nickel Circuit 1 2.20±0.20 4.70±0.25 6.40±0.25 PIN 0.50 SQ 1.00±0.10 7.80±0.25 6.30±0.25 B±0.25 6.00±0.20 C±0.25 Ordering Information & Dimensions: 1.00±0.05 PART NO. 2x3P 2x4P 2x5P 2x6P 2x7P 2x8P 2x9P 2x10P 2x11P 2x12P 2x13P 2x14P 2x15P 2x16P 2x17P 2x18P 2x19P 2x20P 2x21P 2x22P 2x23P 2x24P 2x25P 3.00 1.50 2.00±0.05 Ø1.00±0.05 1.00±0.05 1.00±0.05 A±0.10 P.C.B LAYOUT A 4.00 6.00 8.00 10.00 12.00 14.00 16.00 18.00 20.00 22.00 24.00 26.00 28.00 30.00 32.00 34.00 36.00 38.00 40.00 42.00 44.00 46.00 48.00 Dimensions B 8.65 10.65 12.65 14.65 16.65 18.65 20.65 22.65 24.65 26.65 28.65 30.65 32.65 34.65 36.65 38.65 40.65 42.65 44.65 46.65 48.65 50.65 52.65 C 7.00 9.00 11.00 13.00 15.00 17.00 19.00 21.00 23.00 25.00 27.00 29.00 31.00 33.00 35.00 37.00 39.00 41.00 43.00 45.00 47.00 49.00 51.00 Unit: mm CHANGJIANG CONNECTORS TEL:+86-755-29959119 29959129 FAX:+86-755-29959139 Http://www.CJT.cn A-178 A2005 SERIES A2005WR-N-2xXP-A 2.00mm pitch wire to board connector 2.00mm Pitch 90° Dual Row Box Header - A TYPE Ordering Information: A2005WR-N-2xXP-A - *** - *** 1 2 3 1.Part No. 2.Material: (Blank):Nylon 6T,UL94V-0 GWT:Nylon 6T,UL94V-0,GWT 750 ℃ 3.Finish: (blank):Gold-flash G15:15μin (0.38μm) MIN.Select Gold(Mating Area) 100μin (2.54μm) MIN.Select Tin G30:30μin (0.76μm) MIN.Select Gold(Mating Area) 100μin (2.54μm) MIN.Select Tin T:Tin over Nickel Reference Informations: *Material:Pin:Brass/Gold over Nickel Insulator:Nylon 6T,UL94V-0 *Mates with CJT A2005HB-N-2xXP-A(B,C,D) series Dual Row Housing *Color:Black A±0.20 2.00±0.10 Circuit 2 2.00±0.10 2.00±0.10 A±0.10 Circuit 2 Circuit 1 6.30±0.25 B±0.25 PIN 0.50 SQ PIN 0.50 SQ 2.00±0.10 4.70±0.25 B±0.25 2.50±0.20 C±0.25 C±0.25 2x2P 2x3P~2x6P 6.40±0.20 Circuit 1 A±0.20 Circuit 2 2.00±0.05 2.00±0.10 2.00±0.10 Ordering Information & Dimensions: 2.00±0.05 PART NO. Ø0.80±0.05 P.C.B LAYOUT Circuit 1 B±0.25 PIN 0.50 SQ 2.50±0.20 C±0.25 2x7P~2x25P 6.40±0.20 2.00±0.10 4.70±0.25 6.30±0.25 2x2P 2x3P 2x4P 2x5P 2x6P 2x7P 2x8P 2x9P 2x10P 2x11P 2x12P 2x13P 2x14P 2x15P 2x16P 2x17P 2x18P 2x19P 2x20P 2x21P 2x22P 2x23P 2x24P 2x25P A 2.00 4.00 6.00 8.00 10.00 12.00 14.00 16.00 18.00 20.00 22.00 24.00 26.00 28.00 30.00 32.00 34.00 36.00 38.00 40.00 42.00 44.00 46.00 48.00 Dimensions B 6.65 8.65 10.65 12.65 14.65 16.65 18.65 20.65 22.65 24.65 26.65 28.65 30.65 32.65 34.65 36.65 38.65 40.65 42.65 44.65 46.65 48.65 50.65 52.65 C 5.00 7.00 9.00 11.00 13.00 15.00 17.00 19.00 21.00 23.00 25.00 27.00 29.00 31.00 33.00 35.00 37.00 39.00 41.00 43.00 45.00 47.00 49.00 51.00 Unit: mm CHANGJIANG CONNECTORS TEL:+86-755-29959119 29959129 FAX:+86-755-29959139 Http://www.CJT.cn A-179 A2005 SERIES A2005WR-N-2xXP-B 2.00mm pitch wire to board connector 2.00mm Pitch 90° Dual Row Box Header - B TYPE Ordering Information: A2005WR-N-2xXP-B - *** - *** 1 2 3 1.Part No. 2.Material: (Blank):Nylon 6T,UL94V-0 GWT:Nylon 6T,UL94V-0,GWT 750 ℃ 3.Finish: (blank):Gold-flash G15:15μin (0.38μm) MIN.Select Gold(Mating Area) 100μin (2.54μm) MIN.Select Tin G30:30μin (0.76μm) MIN.Select Gold(Mating Area) 100μin (2.54μm) MIN.Select Tin T:Tin over Nickel Reference Informations: *Material:Pin:Brass/Gold over Nickel Insulator:Nylon 6T,UL94V-0 *Mates with CJT A2005HB-N-2xXP-A(D,F) series Dual Row Housing *Color:Black Circuit 2 2.00±0.05 2.00±0.10 A±0.10 2.00±0.05 Ø0.80±0.05 P.C.B LAYOUT Circuit 1 B±0.25 PIN 0.50 SQ 2.50±0.20 C±0.25 6.40±0.20 2.00±0.10 4.70±0.25 6.30±0.25 2x2P A±0.20 2.00±0.10 2.00±0.10 Circuit 2 Ordering Information & Dimensions: PART NO. Circuit 1 B±0.25 PIN 0.50 SQ 2.50±0.20 C±0.25 2x3P~2x25P 6.40±0.20 2.00±0.10 4.70±0.25 6.30±0.25 2x2P 2x3P 2x4P 2x5P 2x6P 2x7P 2x8P 2x9P 2x10P 2x11P 2x12P 2x13P 2x14P 2x15P 2x16P 2x17P 2x18P 2x19P 2x20P 2x21P 2x22P 2x23P 2x24P 2x25P A 2.00 4.00 6.00 8.00 10.00 12.00 14.00 16.00 18.00 20.00 22.00 24.00 26.00 28.00 30.00 32.00 34.00 36.00 38.00 40.00 42.00 44.00 46.00 48.00 Dimensions B 6.65 8.65 10.65 12.65 14.65 16.65 18.65 20.65 22.65 24.65 26.65 28.65 30.65 32.65 34.65 36.65 38.65 40.65 42.65 44.65 46.65 48.65 50.65 52.65 C 5.00 7.00 9.00 11.00 13.00 15.00 17.00 19.00 21.00 23.00 25.00 27.00 29.00 31.00 33.00 35.00 37.00 39.00 41.00 43.00 45.00 47.00 49.00 51.00 Unit: mm CHANGJIANG CONNECTORS TEL:+86-755-29959119 29959129 FAX:+86-755-29959139 Http://www.CJT.cn A-180 A2005 SERIES A2005WV-N-2xXP-FI 2.00mm pitch wire to board connector 2.00mm Pitch 180° Dual Row Box Header Ordering Information: A2005WV-N-2xXP-FI - *** - ** - *** 1 2 3 4 1.Part No. 2.Material: (Blank):Nylon 9T,UL94V-0 6T:Nylon 6T,UL94V-0 GWT:Nylon 6T,UL94V-0,GWT 750 ℃ 3.Color: (Blank):Black IV:Ivory 4.Finish: (blank):Gold-flash G15:15μin (0.38μm) MIN.Select Gold(Mating Area) 100μin (2.54μm) MIN.Select Tin G30:30μin (0.76μm) MIN.Select Gold(Mating Area) 100μin (2.54μm) MIN.Select Tin T:Tin over Nickel Reference Informations: *Material:Pin:Brass/Gold over Nickel Insulator:Nylon 9T,UL94V-0 *Mates with CJT A2005HB-N-2xXP-FI series Dual Row Housing *Color:Black Circuit 2 A±0.10 Circuit 1 2.00±0.10 5.85±0.20 2.00±0.05 2.00±0.10 A±0.20 Ø0.80±0.05 P.C.B LAYOUT Ordering Information & Dimensions: B±0.25 4.20±0.20 PART NO. 6.10±0.25 3.70±0.20 2.00±0.10 Pin 0.50 SQ A2005WR-N-2xXP-FI 2.80±0.20 6.05±0.25 2.80 Unit: mm 2.00mm Pitch 90° Dual Row Box Header Ordering Information: A2005WR-N-2xXP-FI - *** - ** - *** 1 2 3 4 1.Part No. 2.Material: (Blank):Nylon 9T,UL94V-0 6T:Nylon 6T,UL94V-0 GWT:Nylon 6T,UL94V-0,GWT 750 ℃ 3.Color: (Blank):Black IV:Ivory 4.Finish: (blank):Gold-flash G15:15μin (0.38μm) MIN.Select Gold(Mating Area) 100μin (2.54μm) MIN.Select Tin G30:30μin (0.76μm) MIN.Select Gold(Mating Area) 100μin (2.54μm) MIN.Select Tin T:Tin over Nickel Reference Informations: *Material:Pin:Brass/Gold over Nickel Insulator:Nylon 9T,UL94V-0 *Mates with CJT A2005HB-N-2xXP-FI series Dual Row Housing *Color:Black Circuit 2 A±0.10 2.00±0.10 2.00±0.10 2.00±0.05 Circuit 1 2x5P 2x7P 2x8P 2x10P 2x13P 2x15P 2x17P 2x20P 2x22P 2x25P 2x30P Dimensions A B 8.00 12.00 12.00 16.00 14.00 18.00 18.00 22.00 24.00 28.00 28.00 32.00 32.00 36.00 36.00 42.00 42.00 46.00 48.00 52.00 58.00 62.00 A±0.20 Ø0.80±0.05 P.C.B LAYOUT Ordering Information & Dimensions: B±0.25 Pin 0.50 SQ 0.80 6.05±0.25 2.80 PART NO. 2.50±0.20 2.00±0.10 6.10±0.25 3.70±0.20 4.20 2x5P 2x7P 2x8P 2x10P 2x13P 2x15P 2x17P 2x20P 2x22P 2x25P 2x30P Dimensions A B 8.00 12.00 12.00 16.00 14.00 18.00 18.00 22.00 24.00 28.00 28.00 32.00 32.00 36.00 36.00 42.00 42.00 46.00 48.00 52.00 58.00 62.00 Unit: mm CHANGJIANG CONNECTORS TEL:+86-755-29959119 29959129 FAX:+86-755-29959139 Http://www.CJT.cn A-181 A2005 SERIES A2005WV-N-S-2xXP-FI 2.00mm pitch wire to board connector 2.00mm Pitch 180° Dual Row Box Header - SMT TYPE Ordering Information: A2005WV-N-S-2xXP-FI - *** - ** - *** 1 2 3 4 1.Part No. 2.Material: (Blank):Nylon 9T,UL94V-0 6T:Nylon 6T,UL94V-0 GWT:Nylon 6T,UL94V-0,GWT 750 ℃ 3.Color: (Blank):Black IV:Ivory 4.Finish: (blank):Gold-flash G15:15μin (0.38μm) MIN.Select Gold(Mating Area) 100μin (2.54μm) MIN.Select Tin G30:30μin (0.76μm) MIN.Select Gold(Mating Area) 100μin (2.54μm) MIN.Select Tin T:Tin over Nickel Reference Informations: *Material:Pin:Brass/Gold over Nickel Insulator:Nylon 9T,UL94V-0 *Mates with CJT A2005HB-N-2xXP-FI series Dual Row Housing *Color:Black Circuit 2 A±0.10 Circuit 1 2.00±0.10 3.00±0.10 2.00±0.10 7.50±0.10 2.00±0.05 0.89±0.10 A±0.20 P.C.B LAYOUT Ordering Information & Dimensions: B±0.25 Dimensions A B 8.00 12.00 12.00 16.00 14.00 18.00 18.00 22.00 24.00 28.00 28.00 32.00 32.00 36.00 36.00 42.00 42.00 46.00 48.00 52.00 58.00 62.00 4.20 6.10±0.25 6.20±0.25 6.05±0.25 2.80 3.70±0.20 PART NO. 2.50 Pin 0.50 SQ 6.50±0.25 2x5P 2x7P 2x8P 2x10P 2x13P 2x15P 2x17P 2x20P 2x22P 2x25P 2x30P Unit: mm A2005WV-N-S-2xXP 2.00mm Pitch 180° Dual Row Box Header - SMT TYPE Reference Informations: *Material:Pin:Brass/Gold over Nickel Insulator:Nylon 6T,UL94V-0 *Mates with CJT A2005H-N-2xXP-B(D) series Dual Row Housing *Color:Black A±0.10 2.00 7.50 3.00 0.89 Circuit 2 4.00 Ordering Information & Dimensions: 4.40±0.20 Circuit 1 2.00±0.10 P.C.B LAYOUT PART NO. 2.00±0.10 A±0.20 5.50±0.25 PIN 0.50 SQ L±0.20 5.70±0.25 B±0.20 Ordering Information: A2005WV-N-S-2xXP - *** - *** - *** 1 2 3 4 1.Part No. 2.Size(L): (Blank):1.25mm L08:0.80mm 3.Material: (Blank):Nylon 6T,UL94V-0 GWT:Nylon 6T,UL94V-0,GWT 750 ℃ 4.Finish: (blank):Gold-flash G15:15μin (0.38μm) MIN.Select Gold(Mating Area) 100μin (2.54μm) MIN.Select Tin G30:30μin (0.76μm) MIN.Select Gold(Mating Area) 100μin (2.54μm) MIN.Select Tin T:Tin over Nickel 6.50±0.25 2x4P 2x5P 2x6P 2x7P 2x8P 2x9P 2x10P 2x11P 2x12P 2x13P 2x14P 2x15P 2x16P 2x17P 2x18P 2x19P Dimensions A B 6.00 15.30 17.30 8.00 10.00 19.30 12.00 21.30 14.00 23.30 16.00 25.30 18.00 27.30 20.00 29.30 22.00 31.30 33.30 24.00 26.00 35.30 28.00 37.30 30.00 39.30 32.00 41.30 34.00 43.30 36.00 45.30 PART NO. 2x20P 2x21P 2x22P 2x23P 2x24P 2x25P 2x26P 2x27P 2x28P 2x29P 2x30P 2x31P 2x32P 2x33P 2x34P Dimensions A B 38.00 47.30 49.30 40.00 42.00 51.30 44.00 53.30 46.00 55.30 48.00 57.30 50.00 59.30 52.00 61.30 54.00 63.30 65.30 56.00 58.00 67.30 60.00 69.30 62.00 71.30 64.00 73.30 66.00 75.30 Unit: mm CHANGJIANG CONNECTORS TEL:+86-755-29959119 29959129 FAX:+86-755-29959139 Http://www.CJT.cn A-182 A2005 SERIES A2005WV-XP 2.00mm pitch wire to board connector 2.00mm pitch 180° Single Row Pin Header 2.00±0.10 2.00±0.20 Reference Informations: *Material:Pin:Brass/Gold over Nickel Insulator:PBT,UL94V-0 *Mates with CJT A2005 series Single Row Female Header *Optional Dim. available but MOQ requested *Color:Black 2.00±0.10 A±0.20 Ordering Information: A2005WV-XP - *** - *** - *** 1 2 3 4 1.Part No. 2.Type(H): (Blank):2.00mm H15:1.50mm 3.Material: (Blank):PBT,UL94V-0 6T:Nylon 6T,UL94V-0 GWT:Nylon 6T,UL94V-0,GWT 750 ℃ 4.Finish: (blank):Gold-flash G15:15μin (0.38μm) MIN.Select Gold(Mating Area) 100μin (2.54μm) MIN.Select Tin G30:30μin (0.76μm) MIN.Select Gold(Mating Area) 100μin (2.54μm) MIN.Select Tin T:Tin over Nickel C(2.80) H D(4.00) B±0.25 ∅0.80±0.05 PIN 0.50 SQ P.C.B LAYOUT Ordering Information & Dimensions: PART NO. 1P 2P 3P 4P 5P 6P 7P 8P 9P 10P 11P 12P 13P 14P 15P 16P 17P 18P 19P 20P PART NO. 21P 22P 23P 24P 25P 26P 27P 28P 29P 30P 31P 32P 33P 34P 35P 36P 37P 38P 39P 40P Dimensions A B 40.00 42.00 42.00 44.00 44.00 46.00 46.00 48.00 48.00 50.00 50.00 52.00 52.00 54.00 54.00 56.00 56.00 58.00 58.00 60.00 60.00 62.00 62.00 64.00 64.00 66.00 66.00 68.00 68.00 70.00 70.00 72.00 72.00 74.00 74.00 76.00 76.00 78.00 78.00 80.00 Unit: mm A2005WR-XP 2.00mm pitch 90° Single Row Pin Header Reference Informations: *Material:Pin:Brass/Gold over Nickel Insulator:PBT,UL94V-0 *Mates with CJT A2005 series Single Row Female Header *Optional Dim. available but MOQ requested *Color:Black 2.00±0.20 Circuit 1 2.00±0.10 A±0.20 2.00±0.10 ∅0.80±0.05 Ordering Information: A2005WR-XP - *** - *** - *** 1 2 3 4 1.Part No. 2.Type(H): (Blank):2.00mm H15:1.50mm 3.Material: (Blank):PBT,UL94V-0 6T:Nylon 6T,UL94V-0 GWT:Nylon 6T,UL94V-0,GWT 750 ℃ 4.Finish: (blank):Gold-flash G15:15μin (0.38μm) MIN.Select Gold(Mating Area) 100μin (2.54μm) MIN.Select Tin G30:30μin (0.76μm) MIN.Select Gold(Mating Area) 100μin (2.54μm) MIN.Select Tin T:Tin over Nickel D(1.50) H E(4.00) B±0.25 PIN 0.50 SQ Dimensions A B 2.00 ----2.00 4.00 4.00 6.00 6.00 8.00 8.00 10.00 10.00 12.00 12.00 14.00 14.00 16.00 16.00 18.00 18.00 20.00 20.00 22.00 22.00 24.00 24.00 26.00 26.00 28.00 28.00 30.00 30.00 32.00 32.00 34.00 34.00 36.00 36.00 38.00 38.00 40.00 C(2.80) P.C.B LAYOUT Ordering Information & Dimensions: PART NO. 1P 2P 3P 4P 5P 6P 7P 8P 9P 10P 11P 12P 13P 14P 15P 16P 17P 18P 19P 20P Dimensions A B ----2.00 2.00 4.00 4.00 6.00 6.00 8.00 8.00 10.00 10.00 12.00 12.00 14.00 14.00 16.00 16.00 18.00 18.00 20.00 20.00 22.00 22.00 24.00 24.00 26.00 26.00 28.00 28.00 30.00 30.00 32.00 32.00 34.00 34.00 36.00 36.00 38.00 38.00 40.00 PART NO. 21P 22P 23P 24P 25P 26P 27P 28P 29P 30P 31P 32P 33P 34P 35P 36P 37P 38P 39P 40P Dimensions A B 40.00 42.00 42.00 44.00 44.00 46.00 46.00 48.00 48.00 50.00 50.00 52.00 52.00 54.00 54.00 56.00 56.00 58.00 58.00 60.00 60.00 62.00 62.00 64.00 64.00 66.00 66.00 68.00 68.00 70.00 70.00 72.00 72.00 74.00 74.00 76.00 76.00 78.00 78.00 80.00 Unit: mm CHANGJIANG CONNECTORS TEL:+86-755-29959119 29959129 FAX:+86-755-29959139 Http://www.CJT.cn A-183 A2005 SERIES A2005WV-S-XP-A 2.00mm pitch wire to board connector 2.00mm Pitch 180° Single Row Pin Header-SMT TYPE 5.00±0.10 P.C.B LAYOUT 2.00±0.20 A±0.20 10P 11P 12P 13P 14P 15P 16P 17P 18P 19P 20P 21P 1.00 H 4.00±0.20 B±0.25 4.40±0.20 PIN 0.50 SQ 20.00 22.00 24.00 26.00 28.00 30.00 32.00 34.00 36.00 38.00 40.00 42.00 30P 31P 32P 33P 34P 35P 36P 37P 38P 39P 40P 2.00mm Pitch 180° Single Row Pin Header-SMT TYPE 2.00±0.05 Circuit 1 2.00±0.20 Ordering Information: A2005WV-S-XP-B - *** - *** - *** 1 2 3 4 1.Part No. 2.Type(H): (Blank):2.00mm H15:1.50mm 3.Material: (Blank):Nylon 6T,UL94V-0 GWT:Nylon 6T,UL94V-0,GWT 750 ℃ 4.Finish: (blank):Gold-flash G15:15μin (0.38μm) MIN.Select Gold(Mating Area) 100μin (2.54μm) MIN.Select Tin G30:30μin (0.76μm) MIN.Select Gold(Mating Area) 100μin (2.54μm) MIN.Select Tin T:Tin over Nickel A±0.20 1.00 H 4.00±0.20 B±0.25 4.40±0.20 1.00±0.10 Circuit 1 5.00±0.10 2.50±0.10 Reference Informations: *Material:Pin:Brass/Gold over Nickel Insulator:Nylon 6T,UL94V-0 *Mates with CJT A2005 series Single Row Female Header *Optional Dim. available but MOQ requested *Color:Black PIN 0.50 SQ 18.00 20.00 22.00 24.00 26.00 28.00 30.00 32.00 34.00 36.00 38.00 40.00 Dimensions A B 42.00 44.00 44.00 46.00 46.00 48.00 48.00 50.00 50.00 52.00 52.00 54.00 54.00 56.00 56.00 58.00 58.00 60.00 60.00 62.00 62.00 64.00 64.00 66.00 66.00 68.00 68.00 70.00 70.00 72.00 72.00 74.00 74.00 76.00 76.00 78.00 78.00 80.00 Unit: mm A2005WV-S-XP-B 2.00±0.10 Circuit 1 Ordering Information: A2005WV-S-XP-A - *** - *** - *** Ordering Information & Dimensions: 1 2 3 4 1.Part No. Dimensions 2.Type(H): PART NO. PART NO. (Blank):2.00mm A B H15:1.50mm 2.00 4.00 2P 22P 3.Material: 3P 4.00 6.00 23P (Blank):Nylon 6T,UL94V-0 GWT :Nylon 6T,UL94V-0 GWT 750 ℃ 4P 6.00 8.00 24P 4.Finish: 5P 8.00 10.00 25P (blank):Gold-flash 6P 10.00 12.00 26P G15:15μin (0.38μm) MIN.Select Gold(Mating Area) 100μin (2.54μm) MIN.Select Tin 7P 12.00 14.00 27P G30:30μin (0.76μm) MIN.Select Gold(Mating Area) 8P 14.00 16.00 28P 100μin (2.54μm) MIN.Select Tin 9P 29P 16.00 18.00 T:Tin over Nickel Circuit 1 2.00±0.10 1.00±0.10 2.50±0.10 2.00±0.05 Reference Informations: *Material:Pin:Brass/Gold over Nickel Insulator:Nylon 6T,UL94V-0 *Mates with CJT A2005 series Single Row Female Header *Optional Dim. available but MOQ requested *Color:Black P.C.B LAYOUT Ordering Information & Dimensions: PART NO. 2P 3P 4P 5P 6P 7P 8P 9P 10P 11P 12P 13P 14P 15P 16P 17P 18P 19P 20P 21P Dimensions A B 2.00 4.00 4.00 6.00 6.00 8.00 8.00 10.00 10.00 12.00 12.00 14.00 14.00 16.00 16.00 18.00 18.00 20.00 20.00 22.00 22.00 24.00 24.00 26.00 26.00 28.00 28.00 30.00 30.00 32.00 32.00 34.00 34.00 36.00 36.00 38.00 38.00 40.00 40.00 42.00 PART NO. 22P 23P 24P 25P 26P 27P 28P 29P 30P 31P 32P 33P 34P 35P 36P 37P 38P 39P 40P Dimensions A B 42.00 44.00 44.00 46.00 46.00 48.00 48.00 50.00 50.00 52.00 52.00 54.00 54.00 56.00 56.00 58.00 58.00 60.00 60.00 62.00 62.00 64.00 64.00 66.00 66.00 68.00 68.00 70.00 70.00 72.00 72.00 74.00 74.00 76.00 76.00 78.00 78.00 80.00 Unit: mm CHANGJIANG CONNECTORS TEL:+86-755-29959119 29959129 FAX:+86-755-29959139 Http://www.CJT.cn A-184 A2005 SERIES A2005WVA-XP 2.00mm pitch wire to board connector 2.00mm pitch 180° Single Row Pin Header 2.00 Reference Informations: *Material:Pin:Brass/Gold over Nickel Insulator:PBT,UL94V-0 *Mates with CJT A2005 series Single Row Female Header *Optional Dim. available but MOQ requested *Color:Black 2.00±0.10 A±0.20 Ordering Information: A2005WVA-XP - *** - *** - *** 1 2 3 4 1.Part No. 2.Type(H): (Blank):2.00mm H15:1.50mm 3.Material: (Blank):PBT,UL94V-0 6T:Nylon 6T,UL94V-0 GWT:Nylon 6T,UL94V-0,GWT 750 ℃ 4.Finish: (blank):Gold-flash G15:15μin (0.38μm) MIN.Select Gold(Mating Area) 100μin (2.54μm) MIN.Select Tin G30:30μin (0.76μm) MIN.Select Gold(Mating Area) 100μin (2.54μm) MIN.Select Tin T:Tin over Nickel C(2.80) H E(6.00) H D(4.00) B±0.25 2.00±0.10 ∅0.80±0.05 P.C.B LAYOUT Ordering Information & Dimensions: PART NO. 1P 2P 3P 4P 5P 6P 7P 8P 9P 10P 11P 12P 13P 14P 15P 16P 17P 18P 19P 20P Dimensions A B 2.00 ----2.00 4.00 4.00 6.00 6.00 8.00 8.00 10.00 10.00 12.00 12.00 14.00 14.00 16.00 16.00 18.00 18.00 20.00 20.00 22.00 22.00 24.00 24.00 26.00 26.00 28.00 28.00 30.00 30.00 32.00 32.00 34.00 34.00 36.00 36.00 38.00 38.00 40.00 PART NO. 21P 22P 23P 24P 25P 26P 27P 28P 29P 30P 31P 32P 33P 34P 35P 36P 37P 38P 39P 40P PIN 0.50 SQ Dimensions A B 40.00 42.00 42.00 44.00 44.00 46.00 46.00 48.00 48.00 50.00 50.00 52.00 52.00 54.00 54.00 56.00 56.00 58.00 58.00 60.00 60.00 62.00 62.00 64.00 64.00 66.00 66.00 68.00 68.00 70.00 70.00 72.00 72.00 74.00 74.00 76.00 76.00 78.00 78.00 80.00 Unit: mm A2005WRA-XP 2.00mm pitch 90° Single Row Pin Header Reference Informations: *Material:Pin:Brass/Gold over Nickel Insulator:PBT,UL94V-0 *Mates with CJT A2005 series Single Row Female Header *Optional Dim. available but MOQ requested *Color:Black 2.00±0.20 Circuit 1 2.00±0.10 2.00±0.10 ∅0.80±0.05 Ordering Information: P.C.B LAYOUT A2005WRA-XP - *** - *** - *** 1 2 3 4 1.Part No. 2.Type(H): Ordering Information & Dimensions: (Blank):2.00mm H15:1.50mm Dimensions 3.Material: PART NO. PART NO. (Blank):PBT,UL94V-0 A B 6T:Nylon 6T,UL94V-0 ----2.00 1P 21P GWT:Nylon 6T,UL94V-0,GWT 750 ℃ 2P 2.00 4.00 22P 4.Finish: (blank):Gold-flash 3P 23P 4.00 6.00 G15:15μin (0.38μm) MIN.Select Gold(Mating Area) 6.00 8.00 4P 24P 100μin (2.54μm) MIN.Select Tin 5P 8.00 10.00 25P G30:30μin (0.76μm) MIN.Select Gold(Mating Area) 100μin (2.54μm) MIN.Select Tin 6P 26P 10.00 12.00 T:Tin over Nickel A±0.20 B±0.25 C(2.80) D(0.75) H E(4.00) PIN 0.50 SQ 7P 8P 9P 10P 11P 12P 13P 14P 15P 16P 17P 18P 19P 20P 12.00 14.00 16.00 18.00 20.00 22.00 24.00 26.00 28.00 30.00 32.00 34.00 36.00 38.00 14.00 16.00 18.00 20.00 22.00 24.00 26.00 28.00 30.00 32.00 34.00 36.00 38.00 40.00 27P 28P 29P 30P 31P 32P 33P 34P 35P 36P 37P 38P 39P 40P Dimensions A B 40.00 42.00 42.00 44.00 44.00 46.00 46.00 48.00 48.00 50.00 50.00 52.00 52.00 54.00 54.00 56.00 56.00 58.00 58.00 60.00 60.00 62.00 62.00 64.00 64.00 66.00 66.00 68.00 68.00 70.00 70.00 72.00 72.00 74.00 74.00 76.00 76.00 78.00 78.00 80.00 Unit: mm CHANGJIANG CONNECTORS TEL:+86-755-29959119 29959129 FAX:+86-755-29959139 Http://www.CJT.cn A-185 A2005 SERIES A2005WR-S-XP 2.00mm Pitch 90 Single Row Pin Header-SMT TYPE Reference Informations: *Material:Pin:Brass/Gold over Nickel Insulator:Nylon 6T,UL94V-0 *Mates with CJT A2005 series Single Row Female Header *Optional Dim. available but MOQ requested *Color:Black A±0.20 2.00±0.20 Circuit 1 2.00±0.10 2.00mm pitch wire to board connector 2.03 0.89±0.05 Ordering Information: P.C.B LAYOUT A2005WR-S-XP - *** - *** - *** 1 2 3 4 1.Part No. 2.Type(H): Ordering Information & Dimensions: (Blank):2.00mm H15:1.50mm Dimensions 3.Material: PART NO. PART NO. A B (Blank):Nylon 6T,UL94V-0 GWT:Nylon 6T,UL94V-0,GWT 750 ℃ 2.00 4.00 2P 22P 4.Finish: 3P 4.00 6.00 23P (blank):Gold-flash 4P 6.00 8.00 24P G15:15μin (0.38μm) MIN.Select Gold(Mating Area) 100μin (2.54μm) MIN.Select Tin 5P 8.00 10.00 25P G30:30μin (0.76μm) MIN.Select Gold(Mating Area) 6P 10.00 12.00 26P 100μin (2.54μm) MIN.Select Tin 7P 12.00 14.00 27P T:Tin over Nickel 8P 9P 10P 11P 12P 13P 14P 15P 16P 17P 18P 19P 20P 21P C(2.80) H D(4.00) B±0.25 2.00±0.05 PIN 0.50 SQ 14.00 16.00 18.00 20.00 22.00 24.00 26.00 28.00 30.00 32.00 34.00 36.00 38.00 40.00 16.00 18.00 20.00 22.00 24.00 26.00 28.00 30.00 32.00 34.00 36.00 38.00 40.00 42.00 28P 29P 30P 31P 32P 33P 34P 35P 36P 37P 38P 39P 40P Dimensions A B 42.00 44.00 44.00 46.00 46.00 48.00 48.00 50.00 50.00 52.00 52.00 54.00 54.00 56.00 56.00 58.00 58.00 60.00 60.00 62.00 62.00 64.00 64.00 66.00 66.00 68.00 68.00 70.00 70.00 72.00 72.00 74.00 74.00 76.00 76.00 78.00 78.00 80.00 Unit: mm A2005WVA-XP-R 2.00mm pitch 180° Single Row Pin Header 2.00±0.10 2.00 Reference Informations: *Material:Pin:Brass/Gold over Nickel Insulator:PBT,UL94V-0 *Mates with CJT A2005 series Single Row Female Header *Optional Dim. available but MOQ requested *Color:Black 2.00±0.10 A±0.20 Ordering Information: A2005WVA-XP-R - *** - *** - *** 1 2 3 4 1.Part No. 2.Type(H): (Blank):2.00mm ∅0.80±0.05 H15:1.50mm 3.Material: P.C.B LAYOUT (Blank):PBT,UL94V-0 6T:Nylon 6T,UL94V-0 GWT:Nylon 6T,UL94V-0,GWT 750 ℃ 4.Finish: Ordering Information & Dimensions: (blank):Gold-flash G15:15μin (0.38μm) MIN.Select Gold(Mating Area) Dimensions 100μin (2.54μm) MIN.Select Tin PART NO. PART NO. G30:30μin (0.76μm) MIN.Select Gold(Mating Area) A B 100μin (2.54μm) MIN.Select Tin 2.00 4.00 2P 22P T:Tin over Nickel 3P 4P 5P 6P 7P 8P 9P 10P 11P 12P 13P 14P 15P 16P 17P 18P 19P 20P 21P C(2.80) H E(6.00) H D(4.00) B±0.25 4.00 6.00 8.00 10.00 12.00 14.00 16.00 18.00 20.00 22.00 24.00 26.00 28.00 30.00 32.00 34.00 36.00 38.00 40.00 6.00 8.00 10.00 12.00 14.00 16.00 18.00 20.00 22.00 24.00 26.00 28.00 30.00 32.00 34.00 36.00 38.00 40.00 42.00 23P 24P 25P 26P 27P 28P 29P 30P 31P 32P 33P 34P 35P 36P 37P 38P 39P 40P Dimensions A B 42.00 44.00 44.00 46.00 46.00 48.00 48.00 50.00 50.00 52.00 52.00 54.00 54.00 56.00 56.00 58.00 58.00 60.00 60.00 62.00 62.00 64.00 64.00 66.00 66.00 68.00 68.00 70.00 70.00 72.00 72.00 74.00 74.00 76.00 76.00 78.00 78.00 80.00 Unit: mm PIN 0.50 SQ CHANGJIANG CONNECTORS TEL:+86-755-29959119 29959129 FAX:+86-755-29959139 Http://www.CJT.cn A-186 A2005 SERIES A2005WRD-XP 2.00mm pitch wire to board connector 2.00mm pitch 90° Single Row Pin Header Reference Informations: *Material:Pin:Brass/Gold over Nickel Insulator:PBT,UL94V-0 *Mates with CJT A2005 series Single Row Female Header *Optional Dim. available but MOQ requested *Color:Black 2.00±0.20 H H P.C.B LAYOUT F(1.00) ∅0.80 A±0.20 E(6.00) C(4.00) 2.00±0.10 Ordering Information: A2005WRD-XP - *** - *** - *** 1 2 3 4 1.Part No. 2.Type(H): (Blank):2.00mm H15:1.50mm 3.Material: (Blank):PBT,UL94V-0 6T:Nylon 6T,UL94V-0 GWT:Nylon 6T,UL94V-0,GWT 750 ℃ 4.Finish: (blank):Gold-flash G15:15μin (0.38μm) MIN.Select Gold(Mating Area) 100μin (2.54μm) MIN.Select Tin G30:30μin (0.76μm) MIN.Select Gold(Mating Area) 100μin (2.54μm) MIN.Select Tin T:Tin over Nickel D(2.80) 2.00±0.10 PIN 0.50 SQ B±0.25 Ordering Information & Dimensions: PART NO. 2P 3P 4P 5P 6P 7P 8P 9P 10P 11P 12P 13P 14P 15P 16P 17P 18P 19P 20P 21P Dimensions A B 2.00 4.00 4.00 6.00 6.00 8.00 8.00 10.00 10.00 12.00 12.00 14.00 14.00 16.00 16.00 18.00 18.00 20.00 20.00 22.00 22.00 24.00 24.00 26.00 26.00 28.00 28.00 30.00 30.00 32.00 32.00 34.00 34.00 36.00 36.00 38.00 38.00 40.00 40.00 42.00 PART NO. 22P 23P 24P 25P 26P 27P 28P 29P 30P 31P 32P 33P 34P 35P 36P 37P 38P 39P 40P Dimensions A B 42.00 44.00 44.00 46.00 46.00 48.00 48.00 50.00 50.00 52.00 52.00 54.00 54.00 56.00 56.00 58.00 58.00 60.00 60.00 62.00 62.00 64.00 64.00 66.00 66.00 68.00 68.00 70.00 70.00 72.00 72.00 74.00 74.00 76.00 76.00 78.00 78.00 80.00 Unit: mm A2005WRD-XP-R 2.00mm pitch 90° Single Row Pin Header Reference Informations: *Material:Pin:Brass/Gold over Nickel Insulator:PBT,UL94V-0 *Mates with CJT A2005 series Single Row Female Header *Optional Dim. available but MOQ requested *Color:Black H H 2.00±0.20 A±0.20 P.C.B LAYOUT F(1.00) ∅0.80 E(6.00) C(4.00) 2.00±0.10 Ordering Information: A2005WRD-XP-R - *** - *** - *** 1 2 3 4 1.Part No. 2.Type(H): (Blank): 2.00mm H15:1.50mm 3.Material: (Blank):PBT,UL94V-0 6T:Nylon 6T,UL94V-0 GWT:Nylon 6T,UL94V-0,GWT 750 ℃ 4.Finish: (blank):Gold-flash G15:15μin (0.38μm) MIN.Select Gold(Mating Area) 100μin (2.54μm) MIN.Select Tin G30:30μin (0.76μm) MIN.Select Gold(Mating Area) 100μin (2.54μm) MIN.Select Tin T:Tin over Nickel D(2.80) 2.00±0.10 PIN 0.50 SQ B±0.25 Ordering Information & Dimensions: PART NO. 2P 3P 4P 5P 6P 7P 8P 9P 10P 11P 12P 13P 14P 15P 16P 17P 18P 19P 20P 21P Dimensions A B 2.00 4.00 4.00 6.00 6.00 8.00 8.00 10.00 10.00 12.00 12.00 14.00 14.00 16.00 16.00 18.00 18.00 20.00 20.00 22.00 22.00 24.00 24.00 26.00 26.00 28.00 28.00 30.00 30.00 32.00 32.00 34.00 34.00 36.00 36.00 38.00 38.00 40.00 40.00 42.00 PART NO. 22P 23P 24P 25P 26P 27P 28P 29P 30P 31P 32P 33P 34P 35P 36P 37P 38P 39P 40P Dimensions A B 42.00 44.00 44.00 46.00 46.00 48.00 48.00 50.00 50.00 52.00 52.00 54.00 54.00 56.00 56.00 58.00 58.00 60.00 60.00 62.00 62.00 64.00 64.00 66.00 66.00 68.00 68.00 70.00 70.00 72.00 72.00 74.00 74.00 76.00 76.00 78.00 78.00 80.00 Unit: mm CHANGJIANG CONNECTORS TEL:+86-755-29959119 29959129 FAX:+86-755-29959139 Http://www.CJT.cn A-187 A2005 SERIES A2005WVA-S-XP-A 2.00mm Pitch 180° Single Row Pin Header-SMT A TYPE 2.00±0.05 Reference Informations: *Material:Pin:Brass/Gold over Nickel Insulator:Nylon 6T,UL94V-0 *Mates with CJT A2005 series Single Row Female Header *Optional Dim. available but MOQ requested *Color:Black Ordering Information: 2.00±0.20 A±0.20 A2005WVA-S-XP-A - *** - *** - *** 1 2 3 4 1.Part No. 2.Type(H): (Blank):2.00mm H15:1.50mm 3.Material: (Blank):Nylon 6T,UL94V-0 GWT:Nylon 6T,UL94V-0,GWT 750 ℃ 4.Finish: (blank):Gold-flash G15:15μin (0.38μm) MIN.Select Gold(Mating Area) 100μin (2.54μm) MIN.Select Tin G30:30μin (0.76μm) MIN.Select Gold(Mating Area) 100μin (2.54μm) MIN.Select Tin T:Tin over Nickel PART NO. 2P 3P 4P 5P 6P 7P 8P 9P 10P 11P 12P 13P 14P 15P 16P 17P 18P 19P 20P 21P D(6.00) C(1.00) H H A2005WVA-S-XP-B Dimensions A B 2.00 4.00 4.00 6.00 6.00 8.00 8.00 10.00 10.00 12.00 12.00 14.00 14.00 16.00 16.00 18.00 18.00 20.00 20.00 22.00 22.00 24.00 24.00 26.00 26.00 28.00 28.00 30.00 30.00 32.00 32.00 34.00 34.00 36.00 36.00 38.00 38.00 40.00 40.00 42.00 2.00±0.20 Circuit 1 Circuit 1 5.00±0.10 2.50±0.10 D(6.00) C(1.00) H H 1.00±0.10 A2005WVA-S-XP-B - *** - *** - *** 1 2 3 4 P.C.B LAYOUT 1.Part No. 2.Type(H): Ordering Information & Dimensions: (Blank):2.00mm H15:1.50mm Dimensions 3.Material: PART NO. PART NO. (Blank):Nylon 6T,UL94V-0 A B GWT:Nylon 6T,UL94V-0,GWT 750 ℃ 2.00 4.00 2P 22P 4.Finish: 3P 4.00 6.00 23P (blank):Gold-flash G15:15μin (0.38μm) MIN.Select Gold(Mating Area) 4P 6.00 8.00 24P 100μin (2.54μm) MIN.Select Tin 5P 8.00 10.00 25P G30:30μin (0.76μm) MIN.Select Gold(Mating Area) 6P 10.00 12.00 26P 100μin (2.54μm) MIN.Select Tin T:Tin over Nickel 7P 12.00 14.00 27P E(4.00) B±0.25 PIN 0.50 SQ 22P 23P 24P 25P 26P 27P 28P 29P 30P 31P 32P 33P 34P 35P 36P 37P 38P 39P 40P Dimensions A B 42.00 44.00 44.00 46.00 46.00 48.00 48.00 50.00 50.00 52.00 52.00 54.00 54.00 56.00 56.00 58.00 58.00 60.00 60.00 62.00 62.00 64.00 64.00 66.00 66.00 68.00 68.00 70.00 70.00 72.00 72.00 74.00 74.00 76.00 76.00 78.00 78.00 80.00 Unit: mm 2.00±0.05 A±0.20 PART NO. 2.00mm Pitch 180° Single Row Pin Header-SMT B TYPE Reference Informations: *Material:Pin:Brass/Gold over Nickel Insulator:Nylon 6T,UL94V-0 *Mates with CJT A2005 series Single Row Female Header *Optional Dim. available but MOQ requested *Color:Black Ordering Information: 2.00±0.10 2.50±0.10 Ordering Information & Dimensions: F(4.40) PIN 0.50 SQ Circuit 1 P.C.B LAYOUT E(4.00) B±0.25 1.00±0.10 5.00±0.10 Circuit 1 2.00±0.10 2.00mm pitch wire to board connector F(4.40) 8P 9P 10P 11P 12P 13P 14P 15P 16P 17P 18P 19P 20P 21P 14.00 16.00 18.00 20.00 22.00 24.00 26.00 28.00 30.00 32.00 34.00 36.00 38.00 40.00 16.00 18.00 20.00 22.00 24.00 26.00 28.00 30.00 32.00 34.00 36.00 38.00 40.00 42.00 28P 29P 30P 31P 32P 33P 34P 35P 36P 37P 38P 39P 40P Dimensions A B 42.00 44.00 44.00 46.00 46.00 48.00 48.00 50.00 50.00 52.00 52.00 54.00 54.00 56.00 56.00 58.00 58.00 60.00 60.00 62.00 62.00 64.00 64.00 66.00 66.00 68.00 68.00 70.00 70.00 72.00 72.00 74.00 74.00 76.00 76.00 78.00 78.00 80.00 Unit: mm CHANGJIANG CONNECTORS TEL:+86-755-29959119 29959129 FAX:+86-755-29959139 Http://www.CJT.cn A-188 A2005 SERIES A2005WRR-XP 2.00mm pitch wire to board connector Reference Informations: *Material:Pin:Brass/Gold over Nickel Insulator:PBT+30%GF,UL94V-0 *Mates with CJT A2005 series Single Row Female Header *Color:Black 2.00±0.20 B±0.25 PIN 0.50 SQ 2.00±0.05 ∅0.80±0.05 Ordering Information: A2005WRR-XP - *** - *** 1 2 3 1.Part No 2.Material: (Blank):PBT,UL94V-0 6T:Nylon 6T,UL94V-0 GWT:Nylon 6T,UL94V-0,GWT 750 ℃ 3.Finish: (blank):Gold-flash G15:15μin (0.38μm) MIN.Select Gold(Mating Area) 100μin (2.54μm) MIN.Select Tin G30:30μin (0.76μm) MIN.Select Gold(Mating Area) 100μin (2.54μm) MIN.Select Tin T:Tin over Nickel 2.00±0.20 2.80±0.20 Circuit 1 1.20±0.20 2.00±0.10 1.20±0.20 A±0.20 4.90±0.10 2.00mm pitch 90° Single Row Pin Header P.C.B LAYOUT Ordering Information & Dimensions: PART NO. 2P 3P 4P 5P 6P 7P 8P 9P 10P 11P 12P 13P 14P 15P 16P 17P 18P 19P 20P 21P Dimensions A B 2.00 4.00 4.00 6.00 6.00 8.00 8.00 10.00 10.00 12.00 12.00 14.00 14.00 16.00 16.00 18.00 18.00 20.00 20.00 22.00 22.00 24.00 24.00 26.00 26.00 28.00 28.00 30.00 30.00 32.00 32.00 34.00 34.00 36.00 36.00 38.00 38.00 40.00 40.00 42.00 PART NO. 22P 23P 24P 25P 26P 27P 28P 29P 30P 31P 32P 33P 34P 35P 36P 37P 38P 39P 40P Dimensions A B 42.00 44.00 44.00 46.00 46.00 48.00 48.00 50.00 50.00 52.00 52.00 54.00 54.00 56.00 56.00 58.00 58.00 60.00 60.00 62.00 62.00 64.00 64.00 66.00 66.00 68.00 68.00 70.00 70.00 72.00 72.00 74.00 74.00 76.00 76.00 78.00 78.00 80.00 Unit: mm 2.00mm pitch 180° Dual Row Pin Header 4.00±0.20 Reference Informations: *Material:Pin:Brass/Gold over Nickel Insulator:PBT,UL94V-0 *Mates with CJT A2005 series Dual Row Female Header *Optional Dim. available but MOQ requested *Color:Black Ordering Information: 2.00±0.10 A±0.20 2.00±0.10 A2005WV-2xXP - *** - *** - *** 1 2 3 4 1.Part No. 2.Type(H): (Blank):2.00mm H15:1.50mm 3.Material: (Blank):PBT,UL94V-0 6T:Nylon 6T,UL94V-0 GWT:Nylon 6T,UL94V-0,GWT 750 ℃ 4.Finish: (blank):Gold-flash G15:15μin (0.38μm) MIN.Select Gold(Mating Area) 100μin (2.54μm) MIN.Select Tin G30:30μin (0.76μm) MIN.Select Gold(Mating Area) 100μin (2.54μm) MIN.Select Tin T:Tin over Nickel 2.00±0.10 C(2.80) H D(4.00) B±0.25 2.00±0.10 A2005WV-2xXP PIN 0.50 SQ ∅0.80±0.05 P.C.B LAYOUT Ordering Information & Dimensions: PART NO. 2x1P 2x2P 2x3P 2x4P 2x5P 2x6P 2x7P 2x8P 2x9P 2x10P 2x11P 2x12P 2x13P 2x14P 2x15P 2x16P 2x17P 2x18P 2x19P 2x20P Dimensions A B ----2.00 2.00 4.00 4.00 6.00 6.00 8.00 8.00 10.00 10.00 12.00 12.00 14.00 14.00 16.00 16.00 18.00 18.00 20.00 20.00 22.00 22.00 24.00 24.00 26.00 26.00 28.00 28.00 30.00 30.00 32.00 32.00 34.00 34.00 36.00 36.00 38.00 38.00 40.00 PART NO. 2x21P 2x22P 2x23P 2x24P 2x25P 2x26P 2x27P 2x28P 2x29P 2x30P 2x31P 2x32P 2x33P 2x34P 2x35P 2x36P 2x37P 2x38P 2x39P 2x40P Dimensions A B 40.00 42.00 42.00 44.00 44.00 46.00 46.00 48.00 48.00 50.00 50.00 52.00 52.00 54.00 54.00 56.00 56.00 58.00 58.00 60.00 60.00 62.00 62.00 64.00 64.00 66.00 66.00 68.00 68.00 70.00 70.00 72.00 72.00 74.00 74.00 76.00 76.00 78.00 78.00 80.00 Unit: mm CHANGJIANG CONNECTORS TEL:+86-755-29959119 29959129 FAX:+86-755-29959139 Http://www.CJT.cn A-189 A2005 SERIES A2005WR-2xXP 2.00mm pitch wire to board connector 4.00±0.25 Reference Informations: *Material:Pin:Brass/Gold over Nickel Insulator:PBT,UL94V-0 *Mates with CJT A2005 series Dual Row Female Header *Optional Dim. available but MOQ requested *Color:Black 2.00±0.10 A±0.20 2.00±0.10 Ordering Information: A2005WR-2xXP - *** - *** - *** 1 2 3 4 1.Part No. 2.Type(H): (Blank):2.00mm H15:1.50mm 3.Material: (Blank):PBT,UL94V-0 6T:Nylon 6T,UL94V-0 GWT:Nylon 6T,UL94V-0,GWT 750 ℃ 4.Finish: (blank):Gold-flash G15:15μin (0.38μm) MIN.Select Gold(Mating Area) 100μin (2.54μm) MIN.Select Tin G30:30μin (0.76μm) MIN.Select Gold(Mating Area) 100μin (2.54μm) MIN.Select Tin T:Tin over Nickel B±0.25 2.00 H D(1.50) E(4.00) 2.00±0.10 C(2.80) PIN 0.50 SQ 2.00±0.10 2.00mm pitch 90° Dual Row Pin Header ∅0.80±0.05 P.C.B LAYOUT Ordering Information & Dimensions: PART NO. 2x1P 2x2P 2x3P 2x4P 2x5P 2x6P 2x7P 2x8P 2x9P 2x10P 2x11P 2x12P 2x13P 2x14P 2x15P 2x16P 2x17P 2x18P 2x19P 2x20P Dimensions A B 2.00 ----2.00 4.00 4.00 6.00 6.00 8.00 8.00 10.00 10.00 12.00 12.00 14.00 14.00 16.00 16.00 18.00 18.00 20.00 20.00 22.00 22.00 24.00 24.00 26.00 26.00 28.00 28.00 30.00 30.00 32.00 32.00 34.00 34.00 36.00 36.00 38.00 38.00 40.00 PART NO. 2x21P 2x22P 2x23P 2x24P 2x25P 2x26P 2x27P 2x28P 2x29P 2x30P 2x31P 2x32P 2x33P 2x34P 2x35P 2x36P 2x37P 2x38P 2x39P 2x40P Dimensions A B 40.00 42.00 42.00 44.00 44.00 46.00 46.00 48.00 48.00 50.00 50.00 52.00 52.00 54.00 54.00 56.00 56.00 58.00 58.00 60.00 60.00 62.00 62.00 64.00 64.00 66.00 66.00 68.00 68.00 70.00 70.00 72.00 72.00 74.00 74.00 76.00 76.00 78.00 78.00 80.00 Unit: mm 2.00mm pitch 180° Dual Row Pin Header 4.00±0.20 Reference Informations: *Material:Pin:Brass/Gold over Nickel Insulator:PBT,UL94V-0 *Mates with CJT A2005 series Dual Row Female Header *Optional Dim. available but MOQ requested *Color:Black Ordering Information: 2.00±0.10 A±0.20 2.00±0.10 A2005WVA-2xXP - *** - *** - *** 1 2 3 4 1.Part No. 2.Type(H): (Blank):2.00mm H15:1.50mm 3.Material: (Blank):PBT,UL94V-0 6T:Nylon 6T,UL94V-0 GWT:Nylon 6T,UL94V-0,GWT 750 ℃ 4.Finish: (blank):Gold-flash G15:15μin (0.38μm) MIN.Select Gold(Mating Area) 100μin (2.54μm) MIN.Select Tin G30:30μin (0.76μm) MIN.Select Gold(Mating Area) 100μin (2.54μm) MIN.Select Tin T:Tin over Nickel B±0.25 2.00±0.10 A2005WVA-2xXP C(2.80) H E(6.00) H D(4.00) 2.00±0.10 PIN 0.50 SQ ∅0.80±0.05 P.C.B LAYOUT Ordering Information & Dimensions: PART NO. 2x1P 2x2P 2x3P 2x4P 2x5P 2x6P 2x7P 2x8P 2x9P 2x10P 2x11P 2x12P 2x13P 2x14P 2x15P 2x16P 2x17P 2x18P 2x19P 2x20P Dimensions A B ----2.00 2.00 4.00 4.00 6.00 6.00 8.00 8.00 10.00 10.00 12.00 12.00 14.00 14.00 16.00 16.00 18.00 18.00 20.00 20.00 22.00 22.00 24.00 24.00 26.00 26.00 28.00 28.00 30.00 30.00 32.00 32.00 34.00 34.00 36.00 36.00 38.00 38.00 40.00 PART NO. 2x21P 2x22P 2x23P 2x24P 2x25P 2x26P 2x27P 2x28P 2x29P 2x30P 2x31P 2x32P 2x33P 2x34P 2x35P 2x36P 2x37P 2x38P 2x39P 2x40P Dimensions A B 40.00 42.00 42.00 44.00 44.00 46.00 46.00 48.00 48.00 50.00 50.00 52.00 52.00 54.00 54.00 56.00 56.00 58.00 58.00 60.00 60.00 62.00 62.00 64.00 64.00 66.00 66.00 68.00 68.00 70.00 70.00 72.00 72.00 74.00 74.00 76.00 76.00 78.00 78.00 80.00 Unit: mm CHANGJIANG CONNECTORS TEL:+86-755-29959119 29959129 FAX:+86-755-29959139 Http://www.CJT.cn A-190 A2005 SERIES A2005WVA-2xXP-R 2.00mm pitch wire to board connector 4.00±0.20 Reference Informations: *Material:Pin:Brass/Gold over Nickel Insulator:PBT,UL94V-0 *Mates with CJT A2005 series Dual Row Female Header *Optional Dim. available but MOQ requested *Color:Black Ordering Information: 2.00±0.10 A±0.20 2.00±0.10 A2005WVA-2xXP-R - *** - *** - *** 1 2 3 4 1.Part No. 2.Type(H): (Blank):2.00mm H15:1.50mm 3.Material: (Blank):PBT,UL94V-0 6T:Nylon 6T,UL94V-0 GWT:Nylon 6T,UL94V-0,GWT 750 ℃ 4.Finish: (blank):Gold-flash G15:15μin (0.38μm) MIN.Select Gold(Mating Area) 100μin (2.54μm) MIN.Select Tin G30:30μin (0.76μm) MIN.Select Gold(Mating Area) 100μin (2.54μm) MIN.Select Tin T:Tin over Nickel 2.00±0.10 C(2.80) H E(6.00) H D(4.00) B±0.25 PIN 0.50 SQ ∅0.80±0.05 P.C.B LAYOUT Ordering Information & Dimensions: PART NO. 2x2P 2x3P 2x4P 2x5P 2x6P 2x7P 2x8P 2x9P 2x10P 2x11P 2x12P 2x13P 2x14P 2x15P 2x16P 2x17P 2x18P 2x19P 2x20P 2x21P Dimensions A B 2.00 4.00 4.00 6.00 6.00 8.00 8.00 10.00 10.00 12.00 12.00 14.00 14.00 16.00 16.00 18.00 18.00 20.00 20.00 22.00 22.00 24.00 24.00 26.00 26.00 28.00 28.00 30.00 30.00 32.00 32.00 34.00 34.00 36.00 36.00 38.00 38.00 40.00 40.00 42.00 PART NO. 2x22P 2x23P 2x24P 2x25P 2x26P 2x27P 2x28P 2x29P 2x30P 2x31P 2x32P 2x33P 2x34P 2x35P 2x36P 2x37P 2x38P 2x39P 2x40P Dimensions A B 42.00 44.00 44.00 46.00 46.00 48.00 48.00 50.00 50.00 52.00 52.00 54.00 54.00 56.00 56.00 58.00 58.00 60.00 60.00 62.00 62.00 64.00 64.00 66.00 66.00 68.00 68.00 70.00 70.00 72.00 72.00 74.00 74.00 76.00 76.00 78.00 78.00 80.00 Unit: mm A2005WRA-2xXP 2.00±0.10 2.00mm pitch 90° Dual Row Pin Header Reference Informations: *Material:Pin:Brass/Gold over Nickel Insulator:PBT+30%GF,UL94V-0 *Mates with CJT A2005 series Dual Row Female Header *Optional Dim. available but MOQ requested *Color:Black Ordering Information: 4.00±0.25 A2005WRA-2xXP - *** - *** - *** 1 2 3 4 1.Part No. 2.Type(H): (Blank):2.00mm H15:1.50mm 3.Material: (Blank):PBT,UL94V-0 6T:Nylon 6T,UL94V-0 GWT:Nylon 6T,UL94V-0,GWT 750 ℃ 4.Finish: (blank):Gold-flash G15:15μin (0.38μm) MIN.Select Gold(Mating Area) 100μin (2.54μm) MIN.Select Tin G30:30μin (0.76μm) MIN.Select Gold(Mating Area) 100μin (2.54μm) MIN.Select Tin T:Tin over Nickel 2.00±0.10 2.00±0.10 A±0.20 E(2.80±0.20) C(4.00±0.20) D(1.50±0.25) H B±0.25 PIN 0.50 SQ 2.00±0.10 2.00mm pitch 180° Dual Row Pin Header 2.00±0.10 2.00±0.10 ∅0.80±0.05 P.C.B LAYOUT Ordering Information & Dimensions: PART NO. 2x1P 2x2P 2x3P 2x4P 2x5P 2x6P 2x7P 2x8P 2x9P 2x10P 2x11P 2x12P 2x13P 2x14P 2x15P 2x16P 2x17P 2x18P 2x19P 2x20P Dimensions A B ----2.00 2.00 4.00 4.00 6.00 6.00 8.00 8.00 10.00 10.00 12.00 12.00 14.00 14.00 16.00 16.00 18.00 18.00 20.00 20.00 22.00 22.00 24.00 24.00 26.00 26.00 28.00 28.00 30.00 30.00 32.00 32.00 34.00 34.00 36.00 36.00 38.00 38.00 40.00 PART NO. 2x21P 2x22P 2x23P 2x24P 2x25P 2x26P 2x27P 2x28P 2x29P 2x30P 2x31P 2x32P 2x33P 2x34P 2x35P 2x36P 2x37P 2x38P 2x39P 2x40P Dimensions A B 40.00 42.00 42.00 44.00 44.00 46.00 46.00 48.00 48.00 50.00 50.00 52.00 52.00 54.00 54.00 56.00 56.00 58.00 58.00 60.00 60.00 62.00 62.00 64.00 64.00 66.00 66.00 68.00 68.00 70.00 70.00 72.00 72.00 74.00 74.00 76.00 76.00 78.00 78.00 80.00 Unit: mm CHANGJIANG CONNECTORS TEL:+86-755-29959119 29959129 FAX:+86-755-29959139 Http://www.CJT.cn A-191 A2005 SERIES A2005WVB-2xXP 2.00mm pitch wire to board connector Reference Informations: *Material:Pin:Brass/Gold over Nickel Insulator:PBT,UL94V-0 *Mates with CJT A2005 series Dual Row Female Header *Optional Dim. available but MOQ requested *Color:Black Ordering Information: 2.00±0.10 B±0.25 2.00±0.10 Circuit 2 Circuit 1 2.00±0.05 2.00±0.05 2.00mm pitch 180° Dual Row Pin Header A2005WVB-2xXP - *** - *** ∅0.80±0.05 1 2 3 P.C.B LAYOUT 1.Part No 2.Material: (Blank):PBT,UL94V-0 Ordering Information & Dimensions: 6T:Nylon 6T,UL94V-0 GWT:Nylon 6T,UL94V-0,GWT 750 ℃ Dimensions 3.Finish: PART NO. PART NO. (blank):Gold-flash A B G15:15μin (0.38μm) MIN.Select Gold(Mating Area) 2.00 4.00 2x2P 2x22P 100μin (2.54μm) MIN.Select Tin 2x3P 4.00 6.00 2x23P G30:30μin (0.76μm) MIN.Select Gold(Mating Area) 100μin (2.54μm) MIN.Select Tin 2x4P 6.00 8.00 2x24P T:Tin over Nickel D(2.80±0.25) C(4.00±0.25) 4.00±0.25 4.30±0.25 PIN 0.5 SQ A±0.20 2x5P 2x6P 2x7P 2x8P 2x9P 2x10P 2x11P 2x12P 2x13P 2x14P 2x15P 2x16P 2x17P 2x18P 2x19P 2x20P 2x21P 8.00 10.00 12.00 14.00 16.00 18.00 20.00 22.00 24.00 26.00 28.00 30.00 32.00 34.00 36.00 38.00 40.00 10.00 12.00 14.00 16.00 18.00 20.00 22.00 24.00 26.00 28.00 30.00 32.00 34.00 36.00 38.00 40.00 42.00 2x25P 2x26P 2x27P 2x28P 2x29P 2x30P 2x31P 2x32P 2x33P 2x34P 2x35P 2x36P 2x37P 2x38P 2x39P 2x40P Dimensions A B 42.00 44.00 44.00 46.00 46.00 48.00 48.00 50.00 50.00 52.00 52.00 54.00 54.00 56.00 56.00 58.00 58.00 60.00 60.00 62.00 62.00 64.00 64.00 66.00 66.00 68.00 68.00 70.00 70.00 72.00 72.00 74.00 74.00 76.00 76.00 78.00 78.00 80.00 Unit: mm 2.00mm pitch 90° Dual Row Pin Header Reference Informations: *Material:Pin:Brass/Gold over Nickel Insulator:PBT,UL94V-0 *Mates with CJT A2005 series Dual Row Female Header *Optional Dim. available but MOQ requested *Color:Black Circuit 1 2.00±0.10 A±0.20 2.00±0.10 Circuit 2 2.00±0.05 Ordering Information: A2005WRB-2xXP - *** - *** 1 2 3 1.Part No 2.Material: (Blank):PBT,UL94V-0 6T:Nylon 6T,UL94V-0 GWT:Nylon 6T,UL94V-0,GWT 750 ℃ 3.Finish: (blank):Gold-flash G15:15μin (0.38μm) MIN.Select Gold(Mating Area) 100μin (2.54μm) MIN.Select Tin G30:30μin (0.76μm) MIN.Select Gold(Mating Area) 100μin (2.54μm) MIN.Select Tin T:Tin over Nickel B±0.35 4.30±0.20 4.00±0.20 4.00±0.20 PIN 0.50 SQ 2.80±0.20 2.00±0.05 A2005WRB-2xXP ∅0.80±0.05 P.C.B LAYOUT Ordering Information & Dimensions: PART NO. 2x2P 2x3P 2x4P 2x5P 2x6P 2x7P 2x8P 2x9P 2x10P 2x11P 2x12P 2x13P 2x14P 2x15P 2x16P 2x17P 2x18P 2x19P 2x20P 2x21P Dimensions A B 2.00 4.00 4.00 6.00 6.00 8.00 8.00 10.00 10.00 12.00 12.00 14.00 14.00 16.00 16.00 18.00 18.00 20.00 20.00 22.00 22.00 24.00 24.00 26.00 26.00 28.00 28.00 30.00 30.00 32.00 32.00 34.00 34.00 36.00 36.00 38.00 38.00 40.00 40.00 42.00 PART NO. 2x22P 2x23P 2x24P 2x25P 2x26P 2x27P 2x28P 2x29P 2x30P 2x31P 2x32P 2x33P 2x34P 2x35P 2x36P 2x37P 2x38P 2x39P 2x40P Dimensions A B 42.00 44.00 44.00 46.00 46.00 48.00 48.00 50.00 50.00 52.00 52.00 54.00 54.00 56.00 56.00 58.00 58.00 60.00 60.00 62.00 62.00 64.00 64.00 66.00 66.00 68.00 68.00 70.00 70.00 72.00 72.00 74.00 74.00 76.00 76.00 78.00 78.00 80.00 Unit: mm CHANGJIANG CONNECTORS TEL:+86-755-29959119 29959129 FAX:+86-755-29959139 Http://www.CJT.cn A-192 A2005 SERIES A2005WRD-2xXP 2.00mm pitch wire to board connector 2.00mm pitch 90° Dual Row Pin Header 2.00±0.10 2.00±0.10 A±0.20 B±0.25 PIN 0.50 SQ D(4.00±0.20) F(6.00±0.20) C(0.45) 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.10 E(2.80±0.20) A2005WRD-2xXP-R 4.00±0.25 2.00±0.10 A±0.20 PART NO. 2x2P 2x3P 2x4P 2x5P 2x6P 2x7P 2x8P 2x9P 2x10P 2x11P 2x12P 2x13P 2x14P 2x15P 2x16P 2x17P 2x18P 2x19P 2x20P 2x21P Dimensions A B 2.00 4.00 4.00 6.00 6.00 8.00 8.00 10.00 10.00 12.00 12.00 14.00 14.00 16.00 16.00 18.00 18.00 20.00 20.00 22.00 22.00 24.00 24.00 26.00 26.00 28.00 28.00 30.00 30.00 32.00 32.00 34.00 34.00 36.00 36.00 38.00 38.00 40.00 40.00 42.00 PART NO. 2x22P 2x23P 2x24P 2x25P 2x26P 2x27P 2x28P 2x29P 2x30P 2x31P 2x32P 2x33P 2x34P 2x35P 2x36P 2x37P 2x38P 2x39P 2x40P Dimensions A B 42.00 44.00 44.00 46.00 46.00 48.00 48.00 50.00 50.00 52.00 52.00 54.00 54.00 56.00 56.00 58.00 58.00 60.00 60.00 62.00 62.00 64.00 64.00 66.00 66.00 68.00 68.00 70.00 70.00 72.00 72.00 74.00 74.00 76.00 76.00 78.00 78.00 80.00 2.00±0.10 Ordering Information: A2005WRD-2xXP-R - *** - *** 1 2 3 1.Part No. 2.Material: (Blank):PBT,UL94V-0 6T:Nylon 6T,UL94V-0 GWT:Nylon 6T,UL94V-0,GWT 750 ℃ 3.Finish: (blank):Gold-flash G15:15μin (0.38μm) MIN.Select Gold(Mating Area) 100μin (2.54μm) MIN.Select Tin G30:30μin (0.76μm) MIN.Select Gold(Mating Area) 100μin (2.54μm) MIN.Select Tin T:Tin over Nickel D(4.00±0.20) F(6.00±0.20) C(0.45) 2.00±0.20 2.00±0.20 2.00±0.10 2.00±0.20 Ordering Information & Dimensions: 2.00mm pitch 90° Dual Row Pin Header B±0.25 PIN 0.50 SQ ∅0.80±0.05 P.C.B LAYOUT Unit: mm Reference Informations: *Material:Pin:Brass/Gold over Nickel Insulator:PBT,UL94V-0 *Mates with CJT A2005 series Dual Row Female Header *Optional Dim. available but MOQ requested *Color:Black 2.00±0.10 2.00±0.10 Ordering Information: A2005WRD-2xXP - *** - *** 1 2 3 1.Part No. 2.Material: (Blank):PBT,UL94V-0 6T:Nylon 6T,UL94V-0 GWT:Nylon 6T,UL94V-0,GWT 750 ℃ 3.Finish: (blank):Gold-flash G15:15μin (0.38μm) MIN.Select Gold(Mating Area) 100μin (2.54μm) MIN.Select Tin G30:30μin (0.76μm) MIN.Select Gold(Mating Area) 100μin (2.54μm) MIN.Select Tin T:Tin over Nickel E(2.80±0.20) 2.00±0.10 2.00±0.10 4.00±0.25 Reference Informations: *Material:Pin:Brass/Gold over Nickel Insulator:PBT,UL94V-0 *Mates with CJT A2005 series Dual Row Female Header *Optional Dim. available but MOQ requested *Color:Black ∅0.80±0.05 P.C.B LAYOUT Ordering Information & Dimensions: PART NO. 2x2P 2x3P 2x4P 2x5P 2x6P 2x7P 2x8P 2x9P 2x10P 2x11P 2x12P 2x13P 2x14P 2x15P 2x16P 2x17P 2x18P 2x19P 2x20P 2x21P Dimensions A B 2.00 4.00 4.00 6.00 6.00 8.00 8.00 10.00 10.00 12.00 12.00 14.00 14.00 16.00 16.00 18.00 18.00 20.00 20.00 22.00 22.00 24.00 24.00 26.00 26.00 28.00 28.00 30.00 30.00 32.00 32.00 34.00 34.00 36.00 36.00 38.00 38.00 40.00 40.00 42.00 PART NO. 2x22P 2x23P 2x24P 2x25P 2x26P 2x27P 2x28P 2x29P 2x30P 2x31P 2x32P 2x33P 2x34P 2x35P 2x36P 2x37P 2x38P 2x39P 2x40P Dimensions A B 42.00 44.00 44.00 46.00 46.00 48.00 48.00 50.00 50.00 52.00 52.00 54.00 54.00 56.00 56.00 58.00 58.00 60.00 60.00 62.00 62.00 64.00 64.00 66.00 66.00 68.00 68.00 70.00 70.00 72.00 72.00 74.00 74.00 76.00 76.00 78.00 78.00 80.00 Unit: mm CHANGJIANG CONNECTORS TEL:+86-755-29959119 29959129 FAX:+86-755-29959139 Http://www.CJT.cn A-193 A2005 SERIES A2005WRR-2xXP 2.00mm pitch wire to board connector 2.00mm pitch 180° Dual Row Pin Header 4.00±0.25 2.00±0.10 A±0.20 Ø0.80 Ordering Information: A2005WRR-2xXP - *** - *** 1 2 3 1.Part No. 2.Material: (Blank):PBT,UL94V-0 6T:Nylon 6T,UL94V-0 GWT:Nylon 6T,UL94V-0,GWT 750 ℃ 3.Finish: (blank):Gold-flash G15:15μin (0.38μm) MIN.Select Gold(Mating Area) 100μin (2.54μm) MIN.Select Tin G30:30μin (0.76μm) MIN.Select Gold(Mating Area) 100μin (2.54μm) MIN.Select Tin T:Tin over Nickel 2.00±0.10 E(11.80±0.25) 2.00±0.25 B±0.25 D(2.80±0.20) PIN 0.50 SQ 2.00±0.10 11.80±0.10 Reference Informations: *Material:Pin:Brass/Gold over Nickel Insulator:PBT,UL94V-0 *Mates with CJT A2005 series Dual Row Female Header *Optional Dim. available but MOQ requested *Color:Black 2.00±0.10 P.C.B LAYOUT Ordering Information & Dimensions: PART NO. 2x2P 2x3P 2x4P 2x5P 2x6P 2x7P 2x8P 2x9P 2x10P 2x11P 2x12P 2x13P 2x14P 2x15P 2x16P 2x17P 2x18P 2x19P 2x20P 2x21P Dimensions A B 2.00 4.00 4.00 6.00 6.00 8.00 8.00 10.00 10.00 12.00 12.00 14.00 14.00 16.00 16.00 18.00 18.00 20.00 20.00 22.00 22.00 24.00 24.00 26.00 26.00 28.00 28.00 30.00 30.00 32.00 32.00 34.00 34.00 36.00 36.00 38.00 38.00 40.00 40.00 42.00 PART NO. 2x22P 2x23P 2x24P 2x25P 2x26P 2x27P 2x28P 2x29P 2x30P 2x31P 2x32P 2x33P 2x34P 2x35P 2x36P 2x37P 2x38P 2x39P 2x40P Dimensions A B 42.00 44.00 44.00 46.00 46.00 48.00 48.00 50.00 50.00 52.00 52.00 54.00 54.00 56.00 56.00 58.00 58.00 60.00 60.00 62.00 62.00 64.00 64.00 66.00 66.00 68.00 68.00 70.00 70.00 72.00 72.00 74.00 74.00 76.00 76.00 78.00 78.00 80.00 Unit: mm A2005WV-S-2xXP 2.00±0.05 4.00±0.20 2.00±0.10 A±0.20 Ordering Information: A2005WV-S-2xXP - *** - *** - *** 1 2 3 4 1.Part No. 2.Type(H): (Blank):2.00mm H15:1.50mm 3.Material: (Blank):Nylon 6T,UL94V-0 GWT:Nylon 6T,UL94V-0,GWT 750 ℃ 4.Finish: (blank):Gold-flash G15:15μin (0.38μm) MIN.Select Gold(Mating Area) 100μin (2.54μm) MIN.Select Tin G30:30μin (0.76μm) MIN.Select Gold(Mating Area) 100μin (2.54μm) MIN.Select Tin T:Tin over Nickel C(1.00) H D(4.00) 2.00±0.10 B±0.25 PIN 0.50 SQ 7.00±0.10 Reference Informations: *Material:Pin:Brass/Gold over Nickel Insulator:Nylon 6T,UL94V-0 *Mates with CJT A2005 series Dual Row Female Header *Optional Dim. available but MOQ requested *Color:Black E(6.40) 2.50±0.05 2.00mm pitch 180° Dual Row Pin Header-SMT TYPE 1.00±0.05 P.C.B LAYOUT Ordering Information & Dimensions: PART NO. 2x2P 2x3P 2x4P 2x5P 2x6P 2x7P 2x8P 2x9P 2x10P 2x11P 2x12P 2x13P 2x14P 2x15P 2x16P 2x17P 2x18P 2x19P 2x20P 2x21P Dimensions A B 2.00 4.00 4.00 6.00 6.00 8.00 8.00 10.00 10.00 12.00 12.00 14.00 14.00 16.00 16.00 18.00 18.00 20.00 20.00 22.00 22.00 24.00 24.00 26.00 26.00 28.00 28.00 30.00 30.00 32.00 32.00 34.00 34.00 36.00 36.00 38.00 38.00 40.00 40.00 42.00 PART NO. 2x22P 2x23P 2x24P 2x25P 2x26P 2x27P 2x28P 2x29P 2x30P 2x31P 2x32P 2x33P 2x34P 2x35P 2x36P 2x37P 2x38P 2x39P 2x40P Dimensions A B 42.00 44.00 44.00 46.00 46.00 48.00 48.00 50.00 50.00 52.00 52.00 54.00 54.00 56.00 56.00 58.00 58.00 60.00 60.00 62.00 62.00 64.00 64.00 66.00 66.00 68.00 68.00 70.00 70.00 72.00 72.00 74.00 74.00 76.00 76.00 78.00 78.00 80.00 Unit: mm CHANGJIANG CONNECTORS TEL:+86-755-29959119 29959129 FAX:+86-755-29959139 Http://www.CJT.cn A-194 A2005 SERIES A2005WR-S-2xXP 2.00mm pitch wire to board connector 2.00mm pitch 90° Dual Row Pin Header-SMT TYPE Reference Informations: *Material:Pin:Brass/Gold over Nickel Insulator:Nylon 6T,UL94V-0 *Mates with CJT A2005 series Dual Row Female Header *Optional Dim. available but MOQ requested *Color:Black 2.00±0.05 1.78 5.30 0.89±0.05 4.00±0.25 2.03 Ordering Information: A2005WR-S-2xXP - *** - *** - *** 1 2 3 4 P.C.B LAYOUT 1.Part No. 2.Type(H): (Blank):2.00mm Ordering Information & Dimensions: H15:1.50mm Dimensions 3.Material: PART NO. PART NO. (Blank):Nylon 6T,UL94V-0 A B GWT:Nylon 6T,UL94V-0,GWT 750 ℃ 2.00 4.00 2x2P 2x22P 4.Finish: 2x3P 4.00 6.00 2x23P (blank):Gold-flash G15:15μin (0.38μm) MIN.Select Gold(Mating Area) 2x4P 6.00 8.00 2x24P 100μin (2.54μm) MIN.Select Tin 2x5P 8.00 10.00 2x25P G30:30μin (0.76μm) MIN.Select Gold(Mating Area) 2x6P 10.00 12.00 2x26P 100μin (2.54μm) MIN.Select Tin T:Tin over Nickel 2x7P 12.00 14.00 2x27P 2.00±0.10 A±0.20 B±0.25 D(4.00) 2x8P 2x9P 2x10P 2x11P 2x12P 2x13P 2x14P 2x15P 2x16P 2x17P 2x18P 2x19P 2x20P 2x21P 6.22±0.20 C(2.80) H 2.00±0.10 14.00 16.00 18.00 20.00 22.00 24.00 26.00 28.00 30.00 32.00 34.00 36.00 38.00 40.00 16.00 18.00 20.00 22.00 24.00 26.00 28.00 30.00 32.00 34.00 36.00 38.00 40.00 42.00 2x28P 2x29P 2x30P 2x31P 2x32P 2x33P 2x34P 2x35P 2x36P 2x37P 2x38P 2x39P 2x40P PIN 0.50 SQ Unit: mm A2005WV-S-F-2xXP 2.00mm pitch 180° Dual Row Pin Header-SMT TYPE 4.00±0.20 2.00±0.10 A±0.20 Ordering Information: A2005WV-S-F-2xXP - *** - *** - *** 1 2 3 4 1.Part No. 2.Type(H): (Blank):2.00mm H15:1.50mm 3.Material: (Blank):Nylon 6T,UL94V-0 GWT:Nylon 6T,UL94V-0,GWT 750 ℃ 4.Finish: (blank):Gold-flash G15:15μin (0.38μm) MIN.Select Gold(Mating Area) 100μin (2.54μm) MIN.Select Tin G30:30μin (0.76μm) MIN.Select Gold(Mating Area) 100μin (2.54μm) MIN.Select Tin T:Tin over Nickel 2.20 C(1.00) H ∅1.00 D(4.00) 2.00±0.10 B±0.25 2.00±0.05 7.00±0.10 ∅1.20 2.50±0.05 Reference Informations: *Material:Pin:Brass/Gold over Nickel Insulator:Nylon 6T,UL94V-0 *Mates with CJT A2005 series Dual Row Female Header *Optional Dim. available but MOQ requested *Color:Black PIN 0.50 SQ Dimensions A B 42.00 44.00 44.00 46.00 46.00 48.00 48.00 50.00 50.00 52.00 52.00 54.00 54.00 56.00 56.00 58.00 58.00 60.00 60.00 62.00 62.00 64.00 64.00 66.00 66.00 68.00 68.00 70.00 70.00 72.00 72.00 74.00 74.00 76.00 76.00 78.00 78.00 80.00 E(6.40) 1.00±0.05 P.C.B LAYOUT Ordering Information & Dimensions: PART NO. 2x2P 2x3P 2x4P 2x5P 2x6P 2x7P 2x8P 2x9P 2x10P 2x11P 2x12P 2x13P 2x14P 2x15P 2x16P 2x17P 2x18P 2x19P 2x20P 2x21P Dimensions A B 2.00 4.00 4.00 6.00 6.00 8.00 8.00 10.00 10.00 12.00 12.00 14.00 14.00 16.00 16.00 18.00 18.00 20.00 20.00 22.00 22.00 24.00 24.00 26.00 26.00 28.00 28.00 30.00 30.00 32.00 32.00 34.00 34.00 36.00 36.00 38.00 38.00 40.00 40.00 42.00 PART NO. 2x22P 2x23P 2x24P 2x25P 2x26P 2x27P 2x28P 2x29P 2x30P 2x31P 2x32P 2x33P 2x34P 2x35P 2x36P 2x37P 2x38P 2x39P 2x40P Dimensions A B 42.00 44.00 44.00 46.00 46.00 48.00 48.00 50.00 50.00 52.00 52.00 54.00 54.00 56.00 56.00 58.00 58.00 60.00 60.00 62.00 62.00 64.00 64.00 66.00 66.00 68.00 68.00 70.00 70.00 72.00 72.00 74.00 74.00 76.00 76.00 78.00 78.00 80.00 Unit: mm CHANGJIANG CONNECTORS TEL:+86-755-29959119 29959129 FAX:+86-755-29959139 Http://www.CJT.cn A-195 A2005 SERIES A2005WV-S-F1-2xXP-H15 2.00mm pitch wire to board connector 2.00mm pitch 180° Dual Row Pin Header-SMT TYPE 2.00 0.89 1.50 7.50±0.10 Reference Informations: *Material:Pin:Brass/Gold over Nickel Insulator:Nylon 6T,UL94V-0 *Mates with CJT A2005 series Dual Row Female Header *Optional Dim. available but MOQ requested *Color:Black ∅1.20 2.00±0.10 2.00±0.10 4.00±0.25 P.C.B LAYOUT A±0.20 Ordering Information: A2005WV-S-F1-2xXP-H15 - *** - *** 1 2 3 1.Part No. 2.Material: (Blank):Nylon 6T,UL94V-0 GWT:Nylon 6T,UL94V-0,GWT 750 ℃ 3.Finish: (blank):Gold-flash G15:15μin (0.38μm) MIN.Select Gold(Mating Area) 100μin (2.54μm) MIN.Select Tin G30:30μin (0.76μm) MIN.Select Gold(Mating Area) 100μin (2.54μm) MIN.Select Tin T:Tin over Nickel B±0.25 ∅1.00 D(4.00±0.20) 1.50 PIN 0.50 SQ 1.30 E(6.50±0.20) Ordering Information & Dimensions: PART NO. 2x2P 2x3P 2x4P 2x5P 2x6P 2x7P 2x8P 2x9P 2x10P 2x11P 2x12P 2x13P 2x14P 2x15P 2x16P 2x17P 2x18P 2x19P 2x20P 2x21P Dimensions A B 2.00 4.00 4.00 6.00 6.00 8.00 8.00 10.00 10.00 12.00 12.00 14.00 14.00 16.00 16.00 18.00 18.00 20.00 20.00 22.00 22.00 24.00 24.00 26.00 26.00 28.00 28.00 30.00 30.00 32.00 32.00 34.00 34.00 36.00 36.00 38.00 38.00 40.00 40.00 42.00 PART NO. 2x22P 2x23P 2x24P 2x25P 2x26P 2x27P 2x28P 2x29P 2x30P 2x31P 2x32P 2x33P 2x34P 2x35P 2x36P 2x37P 2x38P 2x39P 2x40P Dimensions A B 42.00 44.00 44.00 46.00 46.00 48.00 48.00 50.00 50.00 52.00 52.00 54.00 54.00 56.00 56.00 58.00 58.00 60.00 60.00 62.00 62.00 64.00 64.00 66.00 66.00 68.00 68.00 70.00 70.00 72.00 72.00 74.00 74.00 76.00 76.00 78.00 78.00 80.00 Unit: mm A2005WVA-S-2xXP 2.00±0.05 4.00±0.20 2.00±0.10 A±0.20 7.00±0.10 Reference Informations: *Material:Pin:Brass/Gold over Nickel Insulator:Nylon 6T,UL94V-0 *Mates with CJT A2005 series Dual Row Female Header *Optional Dim. available but MOQ requested *Color:Black Ordering Information: A2005WVA-S-2xXP - *** - *** - *** 1 2 3 4 1.Part No. 2.Type(H): (Blank):2.00mm H15:1.50mm 3.Material: (Blank):Nylon 6T,UL94V-0 GWT:Nylon 6T,UL94V-0,GWT 750 ℃ 4.Finish: (blank):Gold-flash G15:15μin (0.38μm) MIN.Select Gold(Mating Area) 100μin (2.54μm) MIN.Select Tin G30:30μin (0.76μm) MIN.Select Gold(Mating Area) 100μin (2.54μm) MIN.Select Tin T:Tin over Nickel 2.00±0.10 PIN 0.50 SQ E(6.00) C(1.00) H H D(4.00) B±0.25 F(6.40) 2.50±0.05 2.00mm pitch 180° Dual Row Pin Header-SMT TYPE 1.00±0.05 P.C.B LAYOUT Ordering Information & Dimensions: PART NO. 2x2P 2x3P 2x4P 2x5P 2x6P 2x7P 2x8P 2x9P 2x10P 2x11P 2x12P 2x13P 2x14P 2x15P 2x16P 2x17P 2x18P 2x19P 2x20P 2x21P Dimensions A B 2.00 4.00 4.00 6.00 6.00 8.00 8.00 10.00 10.00 12.00 12.00 14.00 14.00 16.00 16.00 18.00 18.00 20.00 20.00 22.00 22.00 24.00 24.00 26.00 26.00 28.00 28.00 30.00 30.00 32.00 32.00 34.00 34.00 36.00 36.00 38.00 38.00 40.00 40.00 42.00 PART NO. 2x22P 2x23P 2x24P 2x25P 2x26P 2x27P 2x28P 2x29P 2x30P 2x31P 2x32P 2x33P 2x34P 2x35P 2x36P 2x37P 2x38P 2x39P 2x40P Dimensions A B 42.00 44.00 44.00 46.00 46.00 48.00 48.00 50.00 50.00 52.00 52.00 54.00 54.00 56.00 56.00 58.00 58.00 60.00 60.00 62.00 62.00 64.00 64.00 66.00 66.00 68.00 68.00 70.00 70.00 72.00 72.00 74.00 74.00 76.00 76.00 78.00 78.00 80.00 Unit: mm CHANGJIANG CONNECTORS TEL:+86-755-29959119 29959129 FAX:+86-755-29959139 Http://www.CJT.cn A-196 A2005 SERIES A2005WVA-S-2xXP-H15-R 2.00mm pitch 180° Dual Row Pin Header - SMT TYPE 2.00±0.10 E(6.00) 1.50±0.20 C(1.00) D(4.00) 1.50±0.20 B±0.25 PIN 0.50 SQ 7.50±0.10 Ordering Information: A2005WVA-S-2xXP-H15-R - *** - *** 1 2 3 1.Part No. 2.Material: (Blank):Nylon 6T,UL94V-0 GWT:Nylon 6T,UL94V-0,GWT 750 ℃ 3.Finish: (blank):Gold-flash G15:15μin (0.38μm) MIN.Select Gold(Mating Area) 100μin (2.54μm) MIN.Select Tin G30:30μin (0.76μm) MIN.Select Gold(Mating Area) 100μin (2.54μm) MIN.Select Tin T:Tin over Nickel F(6.50) 4.00±0.20 PART NO. 2x22P 2x23P 2x24P 2x25P 2x26P 2x27P 2x28P 2x29P 2x30P 2x31P 2x32P 2x33P 2x34P 2x35P 2x36P 2x37P 2x38P 2x39P 2x40P Dimensions A B 42.00 44.00 44.00 46.00 46.00 48.00 48.00 50.00 50.00 52.00 52.00 54.00 54.00 56.00 56.00 58.00 58.00 60.00 60.00 62.00 62.00 64.00 64.00 66.00 66.00 68.00 68.00 70.00 70.00 72.00 72.00 74.00 74.00 76.00 76.00 78.00 78.00 80.00 1.00 7.00±0.10 2.20 E(6.00) C(1.00) H D(4.00) 2.00±0.10 H 2x2P 2x3P 2x4P 2x5P 2x6P 2x7P 2x8P 2x9P 2x10P 2x11P 2x12P 2x13P 2x14P 2x15P 2x16P 2x17P 2x18P 2x19P 2x20P 2x21P Dimensions A B 2.00 4.00 4.00 6.00 6.00 8.00 8.00 10.00 10.00 12.00 12.00 14.00 14.00 16.00 16.00 18.00 18.00 20.00 20.00 22.00 22.00 24.00 24.00 26.00 26.00 28.00 28.00 30.00 30.00 32.00 32.00 34.00 34.00 36.00 36.00 38.00 38.00 40.00 40.00 42.00 2.00±0.05 A2005WVA-S-F-2xXP - *** - *** - *** 1 2 3 4 1.Part No. 2.Type(H): (Blank):2.00mm H15:1.50mm 3.Material: (Blank):Nylon 6T,UL94V-0 GWT:Nylon 6T,UL94V-0,GWT 750 ℃ 4.Finish: (blank):Gold-flash G15:15μin (0.38μm) MIN.Select Gold(Mating Area) 100μin (2.54μm) MIN.Select Tin G30:30μin (0.76μm) MIN.Select Gold(Mating Area) 100μin (2.54μm) MIN.Select Tin T:Tin over Nickel B±0.25 PIN 0.50 SQ PART NO. 2.00mm pitch 180° Dual Row Pin Header-SMT TYPE Reference Informations: *Material:Pin:Brass/Gold over Nickel Insulator:Nylon 6T,UL94V-0 *Mates with CJT A2005 series Dual Row Female Header *Optional Dim. available but MOQ requested *Color:Black Ordering Information: A±0.20 Ordering Information & Dimensions: Unit: mm A2005WVA-S-F-2xXP 2.00±0.10 1.00±0.05 P.C.B LAYOUT 2.50±0.05 4.00±0.20 A±0.20 3.00±0.05 2.00±0.05 Reference Informations: *Material:Pin:Brass/Gold over Nickel Insulator:Nylon 6T,UL94V-0 *Mates with CJT A2005 series Dual Row Female Header *Optional Dim. available but MOQ requested *Color:Black 2.00±0.10 2.00mm pitch wire to board connector ∅1.00 F(6.40) ∅1.20 1.00±0.05 P.C.B LAYOUT Ordering Information & Dimensions: PART NO. 2x2P 2x3P 2x4P 2x5P 2x6P 2x7P 2x8P 2x9P 2x10P 2x11P 2x12P 2x13P 2x14P 2x15P 2x16P 2x17P 2x18P 2x19P 2x20P 2x21P Dimensions A B 2.00 4.00 4.00 6.00 6.00 8.00 8.00 10.00 10.00 12.00 12.00 14.00 14.00 16.00 16.00 18.00 18.00 20.00 20.00 22.00 22.00 24.00 24.00 26.00 26.00 28.00 28.00 30.00 30.00 32.00 32.00 34.00 34.00 36.00 36.00 38.00 38.00 40.00 40.00 42.00 PART NO. 2x22P 2x23P 2x24P 2x25P 2x26P 2x27P 2x28P 2x29P 2x30P 2x31P 2x32P 2x33P 2x34P 2x35P 2x36P 2x37P 2x38P 2x39P 2x40P Dimensions A B 42.00 44.00 44.00 46.00 46.00 48.00 48.00 50.00 50.00 52.00 52.00 54.00 54.00 56.00 56.00 58.00 58.00 60.00 60.00 62.00 62.00 64.00 64.00 66.00 66.00 68.00 68.00 70.00 70.00 72.00 72.00 74.00 74.00 76.00 76.00 78.00 78.00 80.00 Unit: mm CHANGJIANG CONNECTORS TEL:+86-755-29959119 29959129 FAX:+86-755-29959139 Http://www.CJT.cn A-197 A2005 SERIES A2005WVA-S-F-2xXP-H15-R 2.00mm pitch wire to board connector 2.00mm pitch 180° Dual Row Pin Header - SMT TYPE 2.00±0.05 4.00±0.20 Ordering Information: A2005WVA-S-F-2xXP-H15-R - *** - *** 1 2 3 1.Part No. 2.Material: (Blank):Nylon 6T,UL94V-0 GWT:Nylon 6T,UL94V-0,GWT 750 ℃ 3.Finish: (blank):Gold-flash G15:15μin (0.38μm) MIN.Select Gold(Mating Area) 100μin (2.54μm) MIN.Select Tin G30:30μin (0.76μm) MIN.Select Gold(Mating Area) 100μin (2.54μm) MIN.Select Tin T:Tin over Nickel 2.00±0.10 A±0.20 2.00±0.10 PIN 0.50 SQ 1.50±0.20 2.20 E(6.00) C(1.00) D(4.00) 1.50±0.20 B±0.25 ∅1.00 F(6.50) 3.00 3.75 ∅1.20 7.50±0.10 Reference Informations: *Material:Pin:Brass/Gold over Nickel Insulator:Nylon 6T,UL94V-0 *Mates with CJT A2005 series Dual Row Female Header *Optional Dim. available but MOQ requested *Color:Black 1.00±0.05 1.00 P.C.B LAYOUT Ordering Information & Dimensions: PART NO. 2x2P 2x3P 2x4P 2x5P 2x6P 2x7P 2x8P 2x9P 2x10P 2x11P 2x12P 2x13P 2x14P 2x15P 2x16P 2x17P 2x18P 2x19P 2x20P 2x21P Dimensions A B 2.00 4.00 4.00 6.00 6.00 8.00 8.00 10.00 10.00 12.00 12.00 14.00 14.00 16.00 16.00 18.00 18.00 20.00 20.00 22.00 22.00 24.00 24.00 26.00 26.00 28.00 28.00 30.00 30.00 32.00 32.00 34.00 34.00 36.00 36.00 38.00 38.00 40.00 40.00 42.00 PART NO. 2x22P 2x23P 2x24P 2x25P 2x26P 2x27P 2x28P 2x29P 2x30P 2x31P 2x32P 2x33P 2x34P 2x35P 2x36P 2x37P 2x38P 2x39P 2x40P Dimensions A B 42.00 44.00 44.00 46.00 46.00 48.00 48.00 50.00 50.00 52.00 52.00 54.00 54.00 56.00 56.00 58.00 58.00 60.00 60.00 62.00 62.00 64.00 64.00 66.00 66.00 68.00 68.00 70.00 70.00 72.00 72.00 74.00 74.00 76.00 76.00 78.00 78.00 80.00 Unit: mm A2005WV-3xXP 2.00mm Pitch 180° Triple Row Pin Header 2.00 2.00 Reference Informations: *Material:Pin:Brass/Gold over Nickel Insulator:PBT,UL94V-0 *Mates with CJT A2005 series Triple Row Female Header *Optional Dim. available but MOQ requested *Color:Black 2.00±0.10 ∅0.80±0.05 6.00±0.20 A±0.10 Circuit 3 Circuit 1 B±0.25 2.00±0.10 Circuit 2 Ordering Information: A2005WV-3xXP - *** - *** P.C.B LAYOUT 1 2 3 1.Part No. 2.Material: Ordering Information & Dimensions: (Blank):PBT,UL94V-0 6T:Nylon 6T,UL94V-0 Dimensions PART NO. PART NO. GWT:Nylon 6T,UL94V-0,GWT 750 ℃ A B 3.Finish: 3x2P 3x22P 2.00 4.00 (blank):Gold-flash G15:15μin (0.38μm) MIN.Select Gold(Mating Area) 3x3P 4.00 6.00 3x23P 100μin (2.54μm) MIN.Select Tin 3x4P 3x24P 6.00 8.00 G30:30μin (0.76μm) MIN.Select Gold(Mating Area) 3x5P 8.00 10.00 3x25P 100μin (2.54μm) MIN.Select Tin T:Tin over Nickel 3x6P 10.00 12.00 3x26P 3x7P 3x8P 3x9P 3x10P 3x11P 3x12P 3x13P 3x14P 3x15P 3x16P 3x17P 3x18P 3x19P 3x20P 3x21P A±0.20 C(2.80±0.20) 2.00±0.10 D(4.00±0.20) 2.00 PIN 0.50 SQ 12.00 14.00 16.00 18.00 20.00 22.00 24.00 26.00 28.00 30.00 32.00 34.00 36.00 38.00 40.00 14.00 16.00 18.00 20.00 22.00 24.00 26.00 28.00 30.00 32.00 34.00 36.00 38.00 40.00 42.00 3x27P 3x28P 3x29P 3x30P 3x31P 3x32P 3x33P 3x34P 3x35P 3x36P 3x37P 3x38P 3x39P 3x40P Dimensions A B 42.00 44.00 44.00 46.00 46.00 48.00 48.00 50.00 50.00 52.00 52.00 54.00 54.00 56.00 56.00 58.00 58.00 60.00 60.00 62.00 62.00 64.00 64.00 66.00 66.00 68.00 68.00 70.00 70.00 72.00 72.00 74.00 74.00 76.00 76.00 78.00 78.00 80.00 Unit: mm CHANGJIANG CONNECTORS TEL:+86-755-29959119 29959129 FAX:+86-755-29959139 Http://www.CJT.cn A-198 A2005 SERIES A2005WR-3xXP 2.00mm pitch wire to board connector 2.00mm Pitch 90° Triple Row Pin Header 6.00±0.20 Circuit 3 Circuit 1 B±0.25 2.00±0.10 Circuit 2 2.00 2.00 Reference Informations: *Material:Pin:Brass/Gold over Nickel Insulator:PBT,UL94V-0 *Mates with CJT A2005 series Triple Row Female Header *Optional Dim. available but MOQ requested *Color:Black 2.00±0.10 C(4.00±0.20) D(1.15) PIN 0.50 SQ 2.00±0.20 ∅0.80±0.05 Ordering Information: A±0.10 A2005WR-3xXP - *** - *** 1 2 3 P.C.B LAYOUT 1.Part No. 2.Material: (Blank):PBT,UL94V-0 Ordering Information & Dimensions: 6T:Nylon 6T,UL94V-0 Dimensions GWT:Nylon 6T,UL94V-0,GWT 750 ℃ PART NO. PART NO. 3.Finish: A B (blank):Gold-flash 2.00 4.00 3x2P 3x22P G15:15μin (0.38μm) MIN.Select Gold(Mating Area) 3x3P 4.00 6.00 3x23P 100μin (2.54μm) MIN.Select Tin G30:30μin (0.76μm) MIN.Select Gold(Mating Area) 3x4P 3x24P 6.00 8.00 100μin (2.54μm) MIN.Select Tin 3x5P 8.00 10.00 3x25P T:Tin over Nickel 2.00±0.10 2.80±0.20 A±0.20 3x6P 3x7P 3x8P 3x9P 3x10P 3x11P 3x12P 3x13P 3x14P 3x15P 3x16P 3x17P 3x18P 3x19P 3x20P 3x21P 10.00 12.00 14.00 16.00 18.00 20.00 22.00 24.00 26.00 28.00 30.00 32.00 34.00 36.00 38.00 40.00 12.00 14.00 16.00 18.00 20.00 22.00 24.00 26.00 28.00 30.00 32.00 34.00 36.00 38.00 40.00 42.00 3x26P 3x27P 3x28P 3x29P 3x30P 3x31P 3x32P 3x33P 3x34P 3x35P 3x36P 3x37P 3x38P 3x39P 3x40P Unit: mm A2005WV-4xXP 2.00mm Pitch 180° Four Row Pin Header Circuit 3 8.00±0.20 2.00±0.10 Circuit 2 Circuit 1 B±0.25 2.00 2.00 2.00 Reference Informations: *Material:Pin:Brass/Gold over Nickel Insulator:PBT,UL94V-0 *Mates with CJT A2005 series Four Row Female Header *Optional Dim. available but MOQ requested *Color:Black Circuit 4 Ordering Information: 2.00±0.10 ∅0.80±0.05 A2005WV-4xXP - *** - *** A±0.10 1 2 3 P.C.B LAYOUT 1.Part No. 2.Material: Ordering Information & Dimensions: (Blank):PBT,UL94V-0 6T:Nylon 6T,UL94V-0 Dimensions Dimensions GWT:Nylon 6T,UL94V-0,GWT 750 ℃ PART NO. PART NO. A B A B 3.Finish: (blank):Gold-flash 2.00 4.00 42.00 44.00 4x2P 4x22P G15:15μin (0.38μm) MIN.Select Gold(Mating Area) 4x3P 4.00 6.00 4x23P 44.00 46.00 100μin (2.54μm) MIN.Select Tin 4x4P 6.00 8.00 4x24P 46.00 48.00 G30:30μin (0.76μm) MIN.Select Gold(Mating Area) 100μin (2.54μm) MIN.Select Tin 4x5P 8.00 10.00 4x25P 48.00 50.00 T:Tin over Nickel 4x6P 4x7P 4x8P 4x9P 4x10P 4x11P 4x12P 4x13P 4x14P 4x15P 4x16P 4x17P 4x18P 4x19P 4x20P 4x21P C(2.80±0.20) A±0.20 D(4.00±0.20) 2.00 PIN 0.50 SQ 2.00±0.10 Dimensions A B 42.00 44.00 44.00 46.00 46.00 48.00 48.00 50.00 50.00 52.00 52.00 54.00 54.00 56.00 56.00 58.00 58.00 60.00 60.00 62.00 62.00 64.00 64.00 66.00 66.00 68.00 68.00 70.00 70.00 72.00 72.00 74.00 74.00 76.00 76.00 78.00 78.00 80.00 10.00 12.00 14.00 16.00 18.00 20.00 22.00 24.00 26.00 28.00 30.00 32.00 34.00 36.00 38.00 40.00 12.00 14.00 16.00 18.00 20.00 22.00 24.00 26.00 28.00 30.00 32.00 34.00 36.00 38.00 40.00 42.00 4x26P 4x27P 4x28P 4x29P 4x30P 4x31P 4x32P 4x33P 4x34P 4x35P 4x36P 4x37P 4x38P 4x39P 4x40P 50.00 52.00 54.00 56.00 58.00 60.00 62.00 64.00 66.00 68.00 70.00 72.00 74.00 76.00 78.00 52.00 54.00 56.00 58.00 60.00 62.00 64.00 66.00 68.00 70.00 72.00 74.00 76.00 78.00 80.00 Unit: mm CHANGJIANG CONNECTORS TEL:+86-755-29959119 29959129 FAX:+86-755-29959139 Http://www.CJT.cn A-199 A2005 SERIES A2005WR-4xXP 2.00mm pitch wire to board connector 2.00mm Pitch 90° Four Row Pin Header 8.00±0.20 Circuit 4 Circuit 3 Circuit 1 B±0.25 2.00±0.10 Circuit 2 2.00 2.00 2.00 Reference Informations: *Material:Pin:Brass/Gold over Nickel Insulator:PBT,UL94V-0 *Mates with CJT A2005 series Four Row Female Header *Optional Dim. available but MOQ requested *Color:Black Ordering Information: A2005WR-4xXP - *** - *** 1 2 3 1.Part No. 2.Material: (Blank):PBT,UL94V-0 6T:Nylon 6T,UL94V-0 GWT:Nylon 6T,UL94V-0,GWT 750 ℃ 3.Finish: (blank):Gold-flash G15:15μin (0.38μm) MIN.Select Gold(Mating Area) 100μin (2.54μm) MIN.Select Tin G30:30μin (0.76μm) MIN.Select Gold(Mating Area) 100μin (2.54μm) MIN.Select Tin T:Tin over Nickel 2.00±0.10 C(4.00±0.20) 2.00±0.20 D(1.15) PIN 0.50 SQ 2.80±0.20 A±0.20 2.00±0.10 A±0.10 ∅0.80±0.05 P.C.B LAYOUT Ordering Information & Dimensions: PART NO. 4x2P 4x3P 4x4P 4x5P 4x6P 4x7P 4x8P 4x9P 4x10P 4x11P 4x12P 4x13P 4x14P 4x15P 4x16P 4x17P 4x18P 4x19P 4x20P 4x21P Dimensions A B 2.00 4.00 4.00 6.00 6.00 8.00 8.00 10.00 10.00 12.00 12.00 14.00 14.00 16.00 16.00 18.00 18.00 20.00 20.00 22.00 22.00 24.00 24.00 26.00 26.00 28.00 28.00 30.00 30.00 32.00 32.00 34.00 34.00 36.00 36.00 38.00 38.00 40.00 40.00 42.00 PART NO. 4x22P 4x23P 4x24P 4x25P 4x26P 4x27P 4x28P 4x29P 4x30P 4x31P 4x32P 4x33P 4x34P 4x35P 4x36P 4x37P 4x38P 4x39P 4x40P Dimensions A B 42.00 44.00 44.00 46.00 46.00 48.00 48.00 50.00 50.00 52.00 52.00 54.00 54.00 56.00 56.00 58.00 58.00 60.00 60.00 62.00 62.00 64.00 64.00 66.00 66.00 68.00 68.00 70.00 70.00 72.00 72.00 74.00 74.00 76.00 76.00 78.00 78.00 80.00 Unit: mm CHANGJIANG CONNECTORS TEL:+86-755-29959119 29959129 FAX:+86-755-29959139 Http://www.CJT.cn A-200 A2005 SERIES A2005HWV-XP 2.00mm pitch wire to board connector 2.00mm Pitch 180° Single Row Female Header Reference Informations: *Material:Pin:Phosphor Bronze/Gold over Nickel Insulator:PBT,UL94V-0 *Mates with CJT A2005 series Single Row Pin Header *Color:Black Ordering Information & Dimensions: 2.50±0.20 B±0.25 4.30±0.20 2.70±0.25 PART NO. Pin 0.50x0.20 2.00±0.10 A±0.20 ∅0.80±0.05 2.00±0.05 A±0.10 P.C.B LAYOUT Ordering Information: A2005HWV-XP - *** - *** 1 2 3 1.Part No. 2.Material: (Blank):PBT,UL94V-0 6T:Nylon 6T,UL94V-0 GWT:Nylon 6T,UL94V-0,GWT 750 ℃ 3.Finish: (blank):Gold-flash G15:15μin (0.38μm) MIN.Select Gold(Mating Area) 100μin (2.54μm) MIN.Select Tin G30:30μin (0.76μm) MIN.Select Gold(Mating Area) 100μin (2.54μm) MIN.Select Tin T:Tin over Nickel Reference Informations: *Material:Pin:Phosphor Bronze/Gold over Nickel Insulator:PBT,UL94V-0 *Mates with CJT A2005 series Single Row Pin Header *Color:Black ∅0.80±0.05 2.00±0.05 A±0.10 22P 23P 24P 25P 26P 27P 28P 29P 30P 31P 32P 33P 34P 35P 36P 37P 38P 39P 40P Dimensions A B 42.00 44.60 44.00 46.60 46.00 48.60 48.00 50.60 50.00 52.60 52.00 54.60 54.00 56.60 56.00 58.60 58.00 60.60 60.00 62.60 62.00 64.60 64.00 66.60 66.00 68.60 68.00 70.60 70.00 72.60 72.00 74.60 74.00 76.60 76.00 78.60 78.00 80.60 2.00mm Pitch 90° Single Row Female Header Ordering Information: A2005HWR-XP - * - *** - *** - *** 1 2 3 4 5 1.Part No. 2.Style: (blank):TYPE 1 2:TYPE 2 3.Size(H): (blank):4.30mm H40:4.00mm H46:4.60mm 4.Material: (blank):PBT,UL94V-0 6T:Nylon 6T,UL94V-0 GWT:Nylon 6T,UL94V-0,GWT 750°C 5.Finish: (blank):Gold-flash G15:15μin (0.38μm) MIN.Select Gold(Mating Area) 100μin (2.54μm) MIN.Select Tin G30:30μin (0.76μm) MIN.Select Gold(Mating Area) 100μin (2.54μm) MIN.Select Tin T:Tin over Nickel 2.80 P.C.B LAYOUT Pin 0.50x0.20 2.00 B±0.25 B±0.25 Pin 0.50x0.20 2.40 H±0.20 A±0.20 H±0.20 A±0.20 3.00±0.20 2.70±0.20 TYPE 1 PART NO. Unit: mm A2005HWR-XP 2.00 2P 3P 4P 5P 6P 7P 8P 9P 10P 11P 12P 13P 14P 15P 16P 17P 18P 19P 20P 21P Dimensions A B 2.00 4.60 4.00 6.60 6.00 8.60 8.00 10.60 10.00 12.60 12.00 14.60 14.00 16.60 16.00 18.60 18.00 20.60 20.00 22.60 22.00 24.60 24.00 26.60 26.00 28.60 28.00 30.60 30.00 32.60 32.00 34.60 34.00 36.60 36.00 38.60 38.00 40.60 40.00 42.60 TYPE 2 Ordering Information & Dimensions: PART NO. 2P 3P 4P 5P 6P 7P 8P 9P 10P 11P 12P 13P 14P 15P 16P 17P 18P 19P 20P 21P Dimensions A B 2.00 4.60 4.00 6.60 6.00 8.60 8.00 10.60 10.00 12.60 12.00 14.60 14.00 16.60 16.00 18.60 18.00 20.60 20.00 22.60 22.00 24.60 24.00 26.60 26.00 28.60 28.00 30.60 30.00 32.60 32.00 34.60 34.00 36.60 36.00 38.60 38.00 40.60 40.00 42.60 PART NO. 22P 23P 24P 25P 26P 27P 28P 29P 30P 31P 32P 33P 34P 35P 36P 37P 38P 39P 40P Dimensions A B 42.00 44.60 44.00 46.60 46.00 48.60 48.00 50.60 50.00 52.60 52.00 54.60 54.00 56.60 56.00 58.60 58.00 60.60 60.00 62.60 62.00 64.60 64.00 66.60 66.00 68.60 68.00 70.60 70.00 72.60 72.00 74.60 74.00 76.60 76.00 78.60 78.00 80.60 Unit: mm CHANGJIANG CONNECTORS TEL:+86-755-29959119 29959129 FAX:+86-755-29959139 Http://www.CJT.cn A-201 A2005 SERIES A2005HWV-XP-A 2.00mm pitch wire to board connector 2.00mm Pitch 180° Single Row Female Header - A TYPE Reference Informations: *Material:Pin:Phosphor Bronze/Gold over Nickel Insulator:PBT,UL94V-0 *Mates with CJT A2005 series Single Row Pin Header *Color:Black Circuit 1 Ordering Information: A2005HWV-XP-A - *** - *** 1 2 3 1.Part No. 2.Material: (Blank):PBT,UL94V-0 6T:Nylon 6T,UL94V-0 GWT:Nylon 6T,UL94V-0,GWT 750 ℃ 3.Finish: (blank):Gold-flash G15:15μin (0.38μm) MIN.Select Gold(Mating Area) 100μin (2.54μm) MIN.Select Tin G30:30μin (0.76μm) MIN.Select Gold(Mating Area) 100μin (2.54μm) MIN.Select Tin T:Tin over Nickel Ordering Information & Dimensions: PART NO. 0.50x0.20 2.00±0.10 A±0.20 B±0.25 4.00 2.70 4.30±0.20 2.50 ∅1.00 ∅0.80 2.00 P.C.B LAYOUT A2005HWV-XP-B 2.00±0.10 22P 23P 24P 25P 26P 27P 28P 29P 30P 31P 32P 33P 34P 35P 36P 37P 38P 39P 40P Dimensions A B 42.00 44.60 44.00 46.60 46.00 48.60 48.00 50.60 50.00 52.60 52.00 54.60 54.00 56.60 56.00 58.60 58.00 60.60 60.00 62.60 62.00 64.60 64.00 66.60 66.00 68.60 68.00 70.60 70.00 72.60 72.00 74.60 74.00 76.60 76.00 78.60 78.00 80.60 2.00mm Pitch 180° Single Row Female Header - B TYPE Ordering Information: A2005HWV-XP-B - *** - *** 1 2 3 1.Part No. 2.Material: (Blank):PBT,UL94V-0 6T:Nylon 6T,UL94V-0 GWT:Nylon 6T,UL94V-0,GWT 750 ℃ 3.Finish: (blank):Gold-flash G15:15μin (0.38μm) MIN.Select Gold(Mating Area) 100μin (2.54μm) MIN.Select Tin G30:30μin (0.76μm) MIN.Select Gold(Mating Area) 100μin (2.54μm) MIN.Select Tin Ordering T:Tin over Nickel Information & Dimensions: PART NO. 0.50x0.20 A±0.20 B±0.25 4.00 2.70 4.30±0.20 2.50 ∅1.00 ∅0.80 2.00 PART NO. Unit: mm Reference Informations: *Material:Pin:Phosphor Bronze/Gold over Nickel Insulator:PBT,UL94V-0 *Mates with CJT A2005 series Single Row Pin Header *Color:Black Circuit 1 2P 3P 4P 5P 6P 7P 8P 9P 10P 11P 12P 13P 14P 15P 16P 17P 18P 19P 20P 21P Dimensions A B 2.00 4.60 4.00 6.60 6.00 8.60 8.00 10.60 10.00 12.60 12.00 14.60 14.00 16.60 16.00 18.60 18.00 20.60 20.00 22.60 22.00 24.60 24.00 26.60 26.00 28.60 28.00 30.60 30.00 32.60 32.00 34.60 34.00 36.60 36.00 38.60 38.00 40.60 40.00 42.60 P.C.B LAYOUT 2P 3P 4P 5P 6P 7P 8P 9P 10P 11P 12P 13P 14P 15P 16P 17P 18P 19P 20P 21P Dimensions A B 2.00 4.60 4.00 6.60 6.00 8.60 8.00 10.60 10.00 12.60 12.00 14.60 14.00 16.60 16.00 18.60 18.00 20.60 20.00 22.60 22.00 24.60 24.00 26.60 26.00 28.60 28.00 30.60 30.00 32.60 32.00 34.60 34.00 36.60 36.00 38.60 38.00 40.60 40.00 42.60 PART NO. 22P 23P 24P 25P 26P 27P 28P 29P 30P 31P 32P 33P 34P 35P 36P 37P 38P 39P 40P Dimensions A B 42.00 44.60 44.00 46.60 46.00 48.60 48.00 50.60 50.00 52.60 52.00 54.60 54.00 56.60 56.00 58.60 58.00 60.60 60.00 62.60 62.00 64.60 64.00 66.60 66.00 68.60 68.00 70.60 70.00 72.60 72.00 74.60 74.00 76.60 76.00 78.60 78.00 80.60 Unit: mm CHANGJIANG CONNECTORS TEL:+86-755-29959119 29959129 FAX:+86-755-29959139 Http://www.CJT.cn A-202 A2005 SERIES A2005HWV-XP-C 2.00mm Pitch 180° Single Row Female Header - C TYPE Reference Informations: *Material:Pin:Phosphor Bronze/Gold over Nickel Insulator:PBT,UL94V-0 *Mates with CJT A2005 series Single Row Pin Header *Color:Black 0.50x0.20 Circuit 1 2.00mm pitch wire to board connector Ordering Information: A2005HWV-XP-C - *** - *** 1 2 3 1.Part No. 2.Material: (Blank):PBT,UL94V-0 6T:Nylon 6T,UL94V-0 GWT:Nylon 6T,UL94V-0,GWT 750 ℃ 3.Finish: (blank):Gold-flash G15:15μin (0.38μm) MIN.Select Gold(Mating Area) 100μin (2.54μm) MIN.Select Tin G30:30μin (0.76μm) MIN.Select Gold(Mating Area) 100μin (2.54μm) MIN.Select Tin T:Tin over Nickel Ordering Information & Dimensions: PART NO. 2.00±0.10 A±0.20 B±0.25 2.70 4.30±0.20 2.50 2.00 2.00 ∅0.80 ∅1.00 2.00 P.C.B LAYOUT 2P 3P 4P 5P 6P 7P 8P 9P 10P 11P 12P 13P 14P 15P 16P 17P 18P 19P 20P 21P Dimensions A B 2.00 4.60 4.00 6.60 6.00 8.60 8.00 10.60 10.00 12.60 12.00 14.60 14.00 16.60 16.00 18.60 18.00 20.60 20.00 22.60 22.00 24.60 24.00 26.60 26.00 28.60 28.00 30.60 30.00 32.60 32.00 34.60 34.00 36.60 36.00 38.60 38.00 40.60 40.00 42.60 PART NO. 22P 23P 24P 25P 26P 27P 28P 29P 30P 31P 32P 33P 34P 35P 36P 37P 38P 39P 40P Dimensions A B 42.00 44.60 44.00 46.60 46.00 48.60 48.00 50.60 50.00 52.60 52.00 54.60 54.00 56.60 56.00 58.60 58.00 60.60 60.00 62.60 62.00 64.60 64.00 66.60 66.00 68.60 68.00 70.60 70.00 72.60 72.00 74.60 74.00 76.60 76.00 78.60 78.00 80.60 Unit: mm A2005HWV-S-XP-A 2.00mm Pitch 180° Single Row Female Header - SMT A TYPE Ordering Information: A2005HWV-S-XP-A - *** - *** 1 2 3 1.Part No. 2.Material: (Blank):Nylon 6T,UL94V-0 GWT:Nylon 6T,UL94V-0,GWT 750 ℃ 3.Finish: (blank):Gold-flash G15:15μin (0.38μm) MIN.Select Gold(Mating Area) 100μin (2.54μm) MIN.Select Tin G30:30μin (0.76μm) MIN.Select Gold(Mating Area) 100μin (2.54μm) MIN.Select Tin T:Tin over Nickel Reference Informations: *Material:Pin:Phosphor Bronze/Gold over Nickel Insulator:Nylon 6T,UL94V-0 *Mates with CJT A2005 series Single Row Pin Header *Color:Black Circuit 1 Ordering Information & Dimensions: PART NO. 0.50x0.20 2.00±0.10 A±0.20 B±0.25 4.30±0.20 2.50 4.20±0.20 2.00±0.05 5.20±0.10 2.00 4.00±0.10 0.89 P.C.B LAYOUT 2P 3P 4P 5P 6P 7P 8P 9P 10P 11P 12P 13P 14P 15P 16P 17P 18P 19P 20P 21P Dimensions A B 2.00 4.60 4.00 6.60 6.00 8.60 8.00 10.60 10.00 12.60 12.00 14.60 14.00 16.60 16.00 18.60 18.00 20.60 20.00 22.60 22.00 24.60 24.00 26.60 26.00 28.60 28.00 30.60 30.00 32.60 32.00 34.60 34.00 36.60 36.00 38.60 38.00 40.60 40.00 42.60 PART NO. 22P 23P 24P 25P 26P 27P 28P 29P 30P 31P 32P 33P 34P 35P 36P 37P 38P 39P 40P Dimensions A B 42.00 44.60 44.00 46.60 46.00 48.60 48.00 50.60 50.00 52.60 52.00 54.60 54.00 56.60 56.00 58.60 58.00 60.60 60.00 62.60 62.00 64.60 64.00 66.60 66.00 68.60 68.00 70.60 70.00 72.60 72.00 74.60 74.00 76.60 76.00 78.60 78.00 80.60 Unit: mm CHANGJIANG CONNECTORS TEL:+86-755-29959119 29959129 FAX:+86-755-29959139 Http://www.CJT.cn A-203 A2005 SERIES A2005HWV-S-XP-B 2.00mm pitch wire to board connector 2.00mm Pitch 180° Single Row Female Header - SMT B TYPE Ordering Information: A2005HWV-S-XP-B - *** - *** 1 2 3 1.Part No. 2.Material: (Blank):Nylon 6T,UL94V-0 GWT:Nylon 6T,UL94V-0,GWT 750 ℃ 3.Finish: (blank):Gold-flash G15:15μin (0.38μm) MIN.Select Gold(Mating Area) 100μin (2.54μm) MIN.Select Tin G30:30μin (0.76μm) MIN.Select Gold(Mating Area) 100μin (2.54μm) MIN.Select Tin T:Tin over Nickel Reference Informations: *Material:Pin:Phosphor Bronze/Gold over Nickel Insulator:Nylon 6T,UL94V-0 *Mates with CJT A2005 series Single Row Pin Header *Color:Black Ordering Information & Dimensions: PART NO. 2.00±0.10 0.50x0.20 Circuit 1 A±0.20 2.50±0.25 4.30±0.20 B±0.25 4.20±0.20 5.20±0.10 2.00 4.00±0.10 0.89 2.00±0.05 P.C.B LAYOUT 2P 3P 4P 5P 6P 7P 8P 9P 10P 11P 12P 13P 14P 15P 16P 17P 18P 19P 20P 21P 22P 23P 24P 25P 26P 27P 28P 29P 30P 31P 32P 33P 34P 35P 36P 37P 38P 39P 40P Dimensions A B 42.00 44.60 44.00 46.60 46.00 48.60 48.00 50.60 50.00 52.60 52.00 54.60 54.00 56.60 56.00 58.60 58.00 60.60 60.00 62.60 62.00 64.60 64.00 66.60 66.00 68.60 68.00 70.60 70.00 72.60 72.00 74.60 74.00 76.60 76.00 78.60 78.00 80.60 2.00mm Pitch 90° Single Row Female Header - SMT TYPE A Reference Informations: *Material:Pin:Phosphor Bronze/Gold over Nickel Insulator:Nylon 6T,UL94V-0 *Mates with CJT A2005 series Single Row Pin Header *Color:Black 2.20 Ordering Information: A2005HWR-S-XP - *** - *** - *** 1 2 3 4 1.Part No. 2.Size(H): (blank):4.30mm H40:4.00mm 3.Material: (Blank):Nylon 6T,UL94V-0 GWT:Nylon 6T,UL94V-0,GWT 750 ℃ 4.Finish: (blank):Gold-flash G15:15μin (0.38μm) MIN.Select Gold(Mating Area) 100μin (2.54μm) MIN.Select Tin G30:30μin (0.76μm) MIN.Select Gold(Mating Area) 100μin (2.54μm) MIN.Select Tin T:Tin over Nickel B±0.25 0.89 2.00 2.40±0.25 2.00 H 3.50±0.20 2.00±0.10 PART NO. Unit: mm A2005HWR-S-XP A±0.20 Dimensions A B 2.00 4.60 4.00 6.60 6.00 8.60 8.00 10.60 10.00 12.60 12.00 14.60 14.00 16.60 16.00 18.60 18.00 20.60 20.00 22.60 22.00 24.60 24.00 26.60 26.00 28.60 28.00 30.60 30.00 32.60 32.00 34.60 34.00 36.60 36.00 38.60 38.00 40.60 40.00 42.60 Pin 0.50x0.20 P.C.B LAYOUT Ordering Information & Dimensions: PART NO. 2P 3P 4P 5P 6P 7P 8P 9P 10P 11P 12P 13P 14P 15P 16P 17P 18P 19P 20P 21P Dimensions A B 2.00 4.50 4.00 6.50 6.00 8.50 8.00 10.50 10.00 12.50 12.00 14.50 14.00 16.50 16.00 18.50 18.00 20.50 20.00 22.50 22.00 24.50 24.00 26.50 26.00 28.50 28.00 30.50 30.00 32.50 32.00 34.50 34.00 36.50 36.00 38.50 38.00 40.50 40.00 42.50 PART NO. 22P 23P 24P 25P 26P 27P 28P 29P 30P 31P 32P 33P 34P 35P 36P 37P 38P 39P 40P Dimensions A B 42.00 44.50 44.00 46.50 46.00 48.50 48.00 50.50 50.00 52.50 52.00 54.50 54.00 56.50 56.00 58.50 58.00 60.50 60.00 62.50 62.00 64.50 64.00 66.50 66.00 68.50 68.00 70.50 70.00 72.50 72.00 74.50 74.00 76.50 76.00 78.50 78.00 80.50 Unit: mm CHANGJIANG CONNECTORS TEL:+86-755-29959119 29959129 FAX:+86-755-29959139 Http://www.CJT.cn A-204 A2005 SERIES A2005HWRA-XP 2.00mm pitch wire to board connector 2.00mm Pitch 90° Single Row Female Header A Reference Informations: *Material:Pin:Phosphor Bronze/Gold over Nickel Insulator:PBT,UL94V-0 *Mates with CJT A2005 series Single Row Pin Header *Color:Black 2.00±0.20 4.50±0.25 3.00±0.20 2.00±0.10 4.70±0.20 Pin 0.50x0.20 4.70 ∅0.80 Ordering Information: A2005HWRA-XP - *** - *** 1 2 3 1.Part No. 2.Material: (Blank):PBT,UL94V-0 6T:Nylon 6T,UL94V-0 GWT:Nylon 6T,UL94V-0,GWT 750 ℃ 3.Finish: (blank):Gold-flash G15:15μin (0.38μm) MIN.Select Gold(Mating Area) 100μin (2.54μm) MIN.Select Tin G30:30μin (0.76μm) MIN.Select Gold(Mating Area) 100μin (2.54μm) MIN.Select Tin T:Tin over Nickel B±0.30 A±0.20 2.00 P.C.B LAYOUT Ordering Information & Dimensions: PART NO. 2P 3P 4P 5P 6P 7P 8P 9P 10P 11P 12P 13P 14P 15P 16P 17P 18P 19P 20P 21P Dimensions A B 2.00 4.60 4.00 6.60 6.00 8.60 8.00 10.60 10.00 12.60 12.00 14.60 14.00 16.60 16.00 18.60 18.00 20.60 20.00 22.60 22.00 24.60 24.00 26.60 26.00 28.60 28.00 30.60 30.00 32.60 32.00 34.60 34.00 36.60 36.00 38.60 38.00 40.60 40.00 42.60 PART NO. 22P 23P 24P 25P 26P 27P 28P 29P 30P 31P 32P 33P 34P 35P 36P 37P 38P 39P 40P Dimensions A B 42.00 44.60 44.00 46.60 46.00 48.60 48.00 50.60 50.00 52.60 52.00 54.60 54.00 56.60 56.00 58.60 58.00 60.60 60.00 62.60 62.00 64.60 64.00 66.60 66.00 68.60 68.00 70.60 70.00 72.60 72.00 74.60 74.00 76.60 76.00 78.60 78.00 80.60 Unit: mm A2005HWRA-S-XP 2.00mm Pitch 90° Single Row Female Header - SMT TYPE Reference Informations: *Material:Pin:Phosphor Bronze/Gold over Nickel Insulator:Nylon 6T,UL94V-0 *Mates with CJT A2005 series Single Row Pin Header *Color:Black Ordering Information: A2005HWRA-S-XP - *** - *** 1 2 3 1.Part No. 2.Material: (Blank):Nylon 6T,UL94V-0 GWT:Nylon 6T,UL94V-0,GWT 750 ℃ 3.Finish: (blank):Gold-flash G15:15μin (0.38μm) MIN.Select Gold(Mating Area) 100μin (2.54μm) MIN.Select Tin G30:30μin (0.76μm) MIN.Select Gold(Mating Area) 100μin (2.54μm) MIN.Select Tin T:Tin over Nickel Ordering Information & Dimensions: Pin 0.50x0.20 PART NO. 2.00 8.30 2.20 0.89 B±0.30 P.C.B LAYOUT 2.00±0.10 A±0.20 2.00±0.20 4.50±0.25 7.30±0.20 2P 3P 4P 5P 6P 7P 8P 9P 10P 11P 12P 13P 14P 15P 16P 17P 18P 19P 20P 21P Dimensions A B 2.00 4.60 4.00 6.60 6.00 8.60 8.00 10.60 10.00 12.60 12.00 14.60 14.00 16.60 16.00 18.60 18.00 20.60 20.00 22.60 22.00 24.60 24.00 26.60 26.00 28.60 28.00 30.60 30.00 32.60 32.00 34.60 34.00 36.60 36.00 38.60 38.00 40.60 40.00 42.60 PART NO. 22P 23P 24P 25P 26P 27P 28P 29P 30P 31P 32P 33P 34P 35P 36P 37P 38P 39P 40P Dimensions A B 42.00 44.60 44.00 46.60 46.00 48.60 48.00 50.60 50.00 52.60 52.00 54.60 54.00 56.60 56.00 58.60 58.00 60.60 60.00 62.60 62.00 64.60 64.00 66.60 66.00 68.60 68.00 70.60 70.00 72.60 72.00 74.60 74.00 76.60 76.00 78.60 78.00 80.60 Unit: mm CHANGJIANG CONNECTORS TEL:+86-755-29959119 29959129 FAX:+86-755-29959139 Http://www.CJT.cn A-205 A2005 SERIES A2005HWV-2xXP 2.00mm pitch wire to board connector 2.00mm Pitch 180° Dual Row Female Header Reference Informations: *Material:Pin:Phosphor Bronze/Gold over Nickel Insulator:PBT,UL94V-0 *Mates with CJT A2005 series Dual Row Pin Header *Color:Black 2.00±0.05 A±0.10 2.00±0.10 W±0.25 P.C.B LAYOUT 2.00±0.10 A±0.20 H B±0.30 Ordering Information: A2005HWV-2xXP - *** - *** - *** - *** - *** 1 2 3 4 5 6 1.Part No. 2.Size(H): (blank):4.30mm H40:4.00mm H46:4.60mm 3.Size(W): (blank):4.50mm W40:4.00mm 4.Size(L): (blank):2.80mm(H43,H40,H46) D24:2.40mm(H43,H46) 5.Material: (Blank):PBT,UL94V-0 6T:Nylon 6T,UL94V-0 GWT:Nylon 6T,UL94V-0,GWT 750 ℃ 6.Finish: (blank):Gold-flash G15:15μin (0.38μm) MIN.Select Gold(Mating Area) 100μin (2.54μm) MIN.Select Tin G30:30μin (0.76μm) MIN.Select Gold(Mating Area) 100μin (2.54μm) MIN.Select Tin T:Tin over Nickel D±0.20 2.00±0.05 ∅0.80±0.05 2.00±0.20 Ordering Information & Dimensions: PART NO. 2x2P 2x3P 2x4P 2x5P 2x6P 2x7P 2x8P 2x9P 2x10P 2x11P 2x12P 2x13P 2x14P 2x15P 2x16P 2x17P 2x18P 2x19P 2x20P 2x21P Dimensions A B 2.00 4.60 4.00 6.60 6.00 8.60 8.00 10.60 10.00 12.60 12.00 14.60 14.00 16.60 16.00 18.60 18.00 20.60 20.00 22.60 22.00 24.60 24.00 26.60 26.00 28.60 28.00 30.60 30.00 32.60 32.00 34.60 34.00 36.60 36.00 38.60 38.00 40.60 40.00 42.60 PART NO. 2x22P 2x23P 2x24P 2x25P 2x26P 2x27P 2x28P 2x29P 2x30P 2x31P 2x32P 2x33P 2x34P 2x35P 2x36P 2x37P 2x38P 2x39P 2x40P Dimensions A B 42.00 44.60 44.00 46.60 46.00 48.60 48.00 50.60 50.00 52.60 52.00 54.60 54.00 56.60 56.00 58.60 58.00 60.60 60.00 62.60 62.00 64.60 64.00 66.60 66.00 68.60 68.00 70.60 70.00 72.60 72.00 74.60 74.00 76.60 76.00 78.60 78.00 80.60 Unit: mm A2005HWR-2xXP 2.00mm Pitch 90° Dual Row Female Header Reference Informations: *Material:Pin:Phosphor Bronze/Gold over Nickel Insulator:PBT,UL94V-0 *Mates with CJT A2005 series Dual Row Pin Header *Color:Black Ordering Information: A2005HWR-2xXP - *** - *** 1 2 3 1.Part No. 2.Material: (Blank):PBT,UL94V-0 6T:Nylon 6T,UL94V-0 GWT:Nylon 6T,UL94V-0,GWT 750 ℃ 3.Finish: (blank):Gold-flash G15:15μin (0.38μm) MIN.Select Gold(Mating Area) 100μin (2.54μm) MIN.Select Tin G30:30μin (0.76μm) MIN.Select Gold(Mating Area) 100μin (2.54μm) MIN.Select Tin Ordering T:Tin over Nickel B±0.25 PART NO. 0.50x0.20 4.90±0.20 2.70±0.25 2.00±0.10 5.15±0.20 2.00±0.10 Information & Dimensions: 4.65±0.20 A±0.20 2.00±0.05 A±0.10 4.65±0.05 ∅0.80±0.05 P.C.B LAYOUT 2x2P 2x3P 2x4P 2x5P 2x6P 2x7P 2x8P 2x9P 2x10P 2x11P 2x12P 2x13P 2x14P 2x15P 2x16P 2x17P 2x18P 2x19P 2x20P 2x21P Dimensions A B 2.00 4.60 4.00 6.60 6.00 8.60 8.00 10.60 10.00 12.60 12.00 14.60 14.00 16.60 16.00 18.60 18.00 20.60 20.00 22.60 22.00 24.60 24.00 26.60 26.00 28.60 28.00 30.60 30.00 32.60 32.00 34.60 34.00 36.60 36.00 38.60 38.00 40.60 40.00 42.60 PART NO. 2x22P 2x23P 2x24P 2x25P 2x26P 2x27P 2x28P 2x29P 2x30P 2x31P 2x32P 2x33P 2x34P 2x35P 2x36P 2x37P 2x38P 2x39P 2x40P Dimensions A B 42.00 44.60 44.00 46.60 46.00 48.60 48.00 50.60 50.00 52.60 52.00 54.60 54.00 56.60 56.00 58.60 58.00 60.60 60.00 62.60 62.00 64.60 64.00 66.60 66.00 68.60 68.00 70.60 70.00 72.60 72.00 74.60 74.00 76.60 76.00 78.60 78.00 80.60 Unit: mm CHANGJIANG CONNECTORS TEL:+86-755-29959119 29959129 FAX:+86-755-29959139 Http://www.CJT.cn A-206 A2005 SERIES A2005HWVA-2xXP 2.00mm pitch wire to board connector 2.00mm Pitch 180° Dual Row Female Header 2.00±0.10 Ordering Information: A2005HWVA-2xXP - *** *** - *** - *** 1 2 3 4 5 1.Part No. 2.Size(H): (blank):4.30mm Ordering Information & Dimensions: H40:4.00mm Dimensions 3.Size(E): PART NO. PART NO. E50:5.00mm(H43,H40) A B E60:6.00mm(H43) 2.00 4.50 2x2P 2x22P 4.Material: 2x3P 4.00 6.50 2x23P (Blank):PBT,UL94V-0 6T:Nylon 6T,UL94V-0 2x4P 6.00 8.50 2x24P GWT:Nylon 6T,UL94V-0,GWT 750 ℃ 2x5P 8.00 10.50 2x25P 5.Finish: 2x6P 10.00 12.50 2x26P (blank):Gold-flash 2x7P 12.00 14.50 2x27P G15:15μin (0.38μm) MIN.Select Gold(Mating Area) 100μin (2.54μm) MIN.Select Tin 2x8P 14.00 16.50 2x28P G30:30μin (0.76μm) MIN.Select Gold(Mating Area) 2x9P 2x29P 16.00 18.50 100μin (2.54μm) MIN.Select Tin 2x10P 18.00 20.50 2x30P T:Tin over Nickel ∅0.80±0.05 E 2.00±0.10 Reference Informations: *Material:Pin:Phosphor Bronze/Gold over Nickel Insulator:PBT,UL94V-0 *Mates with CJT A2005 series Dual Row Pin Header *Color:Black ∅1.00 4.50±0.20 2.00±0.10 P.C.B LAYOUT 2.00±0.10 A±0.20 2x11P 2x12P 2x13P 2x14P 2x15P 2x16P 2x17P 2x18P 2x19P 2x20P 2x21P H±0.20 3.00±0.20 B±0.30 E±0.20 Pin 0.50x0.20 20.00 22.00 24.00 26.00 28.00 30.00 32.00 34.00 36.00 38.00 40.00 22.50 24.50 26.50 28.50 30.50 32.50 34.50 36.50 38.50 40.50 42.50 2x31P 2x32P 2x33P 2x34P 2x35P 2x36P 2x37P 2x38P 2x39P 2x40P Dimensions A B 42.00 44.50 44.00 46.50 46.00 48.50 48.00 50.50 50.00 52.50 52.00 54.50 54.00 56.50 56.00 58.50 58.00 60.50 60.00 62.50 62.00 64.50 64.00 66.50 66.00 68.50 68.00 70.50 70.00 72.50 72.00 74.50 74.00 76.50 76.00 78.50 78.00 80.50 Unit: mm A2005HWRA-2xXP 2.00mm Pitch 90° Dual Row Female Header Reference Informations: *Material:Pin:Phosphor Bronze/Gold over Nickel Insulator:PBT,UL94V-0 *Mates with CJT A2005 series Dual Row Pin Header *Color:Black P.C.B LAYOUT ∅0.80±0.05 2.00 2.00±0.10 2.00 Circuit 2 Circuit 1 2.00±0.10 Ordering Information: A2005HWRA-2xXP - *** - *** - *** 1 2 3 4 1.Part No. 2.Size(W): (blank):4.50mm W40:4.00mm Ordering Information & Dimensions: 3.Material: (Blank):PBT,UL94V-0 Dimensions 6T:Nylon 6T,UL94V-0 PART NO. PART NO. A B GWT:Nylon 6T,UL94V-0,GWT 750 ℃ 4.Finish: 2.00 4.50 2x2P 2x22P (blank):Gold-flash 2x3P 4.00 6.50 2x23P G15:15μin (0.38μm) MIN.Select Gold(Mating Area) 2x4P 6.00 8.50 2x24P 100μin (2.54μm) MIN.Select Tin 2x5P 8.00 10.50 2x25P G30:30μin (0.76μm) MIN.Select Gold(Mating Area) 100μin (2.54μm) MIN.Select Tin 2x6P 10.00 12.50 2x26P T:Tin over Nickel 0.50x0.20 A±0.20 W±0.25 7.40±0.25 2.00±0.10 4.30±0.25 B±0.30 2.60±0.20 2x7P 2x8P 2x9P 2x10P 2x11P 2x12P 2x13P 2x14P 2x15P 2x16P 2x17P 2x18P 2x19P 2x20P 2x21P 12.00 14.00 16.00 18.00 20.00 22.00 24.00 26.00 28.00 30.00 32.00 34.00 36.00 38.00 40.00 14.50 16.50 18.50 20.50 22.50 24.50 26.50 28.50 30.50 32.50 34.50 36.50 38.50 40.50 42.50 2x27P 2x28P 2x29P 2x30P 2x31P 2x32P 2x33P 2x34P 2x35P 2x36P 2x37P 2x38P 2x39P 2x40P Dimensions A B 42.00 44.50 44.00 46.50 46.00 48.50 48.00 50.50 50.00 52.50 52.00 54.50 54.00 56.50 56.00 58.50 58.00 60.50 60.00 62.50 62.00 64.50 64.00 66.50 66.00 68.50 68.00 70.50 70.00 72.50 72.00 74.50 74.00 76.50 76.00 78.50 78.00 80.50 Unit: mm CHANGJIANG CONNECTORS TEL:+86-755-29959119 29959129 FAX:+86-755-29959139 Http://www.CJT.cn A-207 A2005 SERIES A2005HWV-S-2xXP 2.00mm pitch wire to board connector 2.00mm Pitch 180° Dual Row Female Header - SMT TYPE Reference Informations: *Material:Pin:Phosphor Bronze/Gold over Nickel Insulator:Nylon 6T,UL94V-0 *Mates with CJT A2005 series Dual Row Pin Header *Color:Black 0.80±0.05 Ordering Information: A2005HWV-S-2xXP - *** - *** - *** - *** - *** 1 2 3 4 5 6 1.Part No. 2.Size(H): Ordering Information & Dimensions: (blank):4.30mm H40:4.00mm Dimensions H46:4.60mm PART NO. PART NO. A B 3.Size(W): (blank):4.50mm(H43,H40) 2.00 4.60 2x2P 2x22P W40:4.00mm(H43,H40,H46) 2x3P 4.00 6.60 2x23P 4.Size(E): 2x4P 6.00 8.60 2x24P (blank):6.50mm(H43,H46) E62:6.20mm(H43,H40) 2x5P 8.00 10.60 2x25P 5.Material: 2x6P 10.00 12.60 2x26P (Blank):Nylon 6T,UL94V-0 2x7P 12.00 14.60 2x27P GWT:Nylon 6T,UL94V-0,GWT 750 ℃ 2x8P 14.00 16.60 2x28P 6.Finish: (blank):Gold-flash 2x9P 2x29P 16.00 18.60 G15:15μin (0.38μm) MIN.Select Gold(Mating Area) 2x10P 18.00 20.60 2x30P 100μin (2.54μm) MIN.Select Tin 2x11P 20.00 22.60 2x31P G30:30μin (0.76μm) MIN.Select Gold(Mating Area) 100μin (2.54μm) MIN.Select Tin 2x32P 2x12P 22.00 24.60 T:Tin over Nickel E+1.00 2.65 2.00±0.10 P.C.B LAYOUT 2.00±0.10 Pin 0.50x0.20 2.00±0.10 A±0.20 B±0.30 2x13P 2x14P 2x15P 2x16P 2x17P 2x18P 2x19P 2x20P 2x21P H±0.20 W±0.25 E±0.20 24.00 26.00 28.00 30.00 32.00 34.00 36.00 38.00 40.00 26.60 28.60 30.60 32.60 34.60 36.60 38.60 40.60 42.60 2x33P 2x34P 2x35P 2x36P 2x37P 2x38P 2x39P 2x40P Dimensions A B 42.00 44.60 44.00 46.60 46.00 48.60 48.00 50.60 50.00 52.60 52.00 54.60 54.00 56.60 56.00 58.60 58.00 60.60 60.00 62.60 62.00 64.60 64.00 66.60 66.00 68.60 68.00 70.60 70.00 72.60 72.00 74.60 74.00 76.60 76.00 78.60 78.00 80.60 Unit: mm A2005HWV-S-F-2xXP 2.00mm Pitch 180° Dual Row Female Header - SMT TYPE Reference Informations: *Material:Pin:Phosphor Bronze/Gold over Nickel Insulator:Nylon 6T,UL94V-0 *Mates with CJT A2005 series Dual Row Pin Header *Color:Black 7.40±0.10 ∅1.20±0.05 0.89±0.05 2.10 2.00±0.10 Ordering Information: Ordering Information & Dimensions: A2005HWV-S-F-2xXP - *** - *** - *** 1 2 3 4 Dimensions 1.Part No. PART NO. PART NO. A B 2.Size(H): 2.00 4.60 2x2P 2x22P (blank):4.30mm H40:4.00mm 2x3P 4.00 6.60 2x23P H46:4.60mm 2x4P 6.00 8.60 2x24P 3.Material: 2x5P 8.00 10.60 2x25P (blank):Nylon 6T,UL94V-0 LCP:LCP,UL94V-0 2x6P 10.00 12.60 2x26P GWT:Nylon 6T,UL94V-0,GWT 750 ℃ 2x7P 12.00 14.60 2x27P 4.Finish: 2x8P 14.00 16.60 2x28P (blank):Gold-flash G15:15μin (0.38μm) MIN.Select Gold(Mating Area) 2x9P 16.00 18.60 2x29P 100μin (2.54μm) MIN.Select Tin 2x10P 2x30P 18.00 20.60 G30:30μin (0.76μm) MIN.Select Gold(Mating Area) 2x11P 20.00 22.60 2x31P 100μin (2.54μm) MIN.Select Tin T:Tin over Nickel 2x32P 2x12P 22.00 24.60 P.C.B LAYOUT 2.00±0.10 Pin 0.50x0.20 2.00±0.10 A±0.20 B±0.30 1.00 4.50±0.25 H±0.20 ∅0.90 2x13P 2x14P 2x15P 2x16P 2x17P 2x18P 2x19P 2x20P 2x21P 6.50±0.20 24.00 26.00 28.00 30.00 32.00 34.00 36.00 38.00 40.00 26.60 28.60 30.60 32.60 34.60 36.60 38.60 40.60 42.60 2x33P 2x34P 2x35P 2x36P 2x37P 2x38P 2x39P 2x40P Dimensions A B 42.00 44.60 44.00 46.60 46.00 48.60 48.00 50.60 50.00 52.60 52.00 54.60 54.00 56.60 56.00 58.60 58.00 60.60 60.00 62.60 62.00 64.60 64.00 66.60 66.00 68.60 68.00 70.60 70.00 72.60 72.00 74.60 74.00 76.60 76.00 78.60 78.00 80.60 Unit: mm CHANGJIANG CONNECTORS TEL:+86-755-29959119 29959129 FAX:+86-755-29959139 Http://www.CJT.cn A-208 A2005 SERIES A2005HWR-S-2xXP 2.00mm pitch wire to board connector 2.00mm Pitch 90° Dual Row Female Header - SMT TYPE Reference Informations: *Material:Pin:Phosphor Bronze/Gold over Nickel Insulator:Nylon 6T,UL94V-0 *Mates with CJT A2005 series Dual Row Pin Header *Color:Black Ordering Information: A2005HWR-S-2xXP - *** - *** 1 2 3 1.Part No. 2.Material: (Blank):Nylon 6T,UL94V-0 GWT:Nylon 6T,UL94V-0,GWT 750 ℃ 3.Finish: (blank):Gold-flash G15:15μin (0.38μm) MIN.Select Gold(Mating Area) 100μin (2.54μm) MIN.Select Tin G30:30μin (0.76μm) MIN.Select Gold(Mating Area) 100μin (2.54μm) MIN.Select Tin T:Tin over Nickel Ordering Information & Dimensions: 9.20±0.05 5.00 PART NO. 2.00±0.10 1.00 2.00±0.05 A±0.20 A±0.10 P.C.B LAYOUT 5.15±0.20 5.10±0.25 4.90±0.25 B±0.25 0.50x0.20 8.00±0.20 2x2P 2x3P 2x4P 2x5P 2x6P 2x7P 2x8P 2x9P 2x10P 2x11P 2x12P 2x13P 2x14P 2x15P 2x16P 2x17P 2x18P 2x19P 2x20P 2x21P Dimensions A B 2.00 4.60 4.00 6.60 6.00 8.60 8.00 10.60 10.00 12.60 12.00 14.60 14.00 16.60 16.00 18.60 18.00 20.60 20.00 22.60 22.00 24.60 24.00 26.60 26.00 28.60 28.00 30.60 30.00 32.60 32.00 34.60 34.00 36.60 36.00 38.60 38.00 40.60 40.00 42.60 PART NO. 2x22P 2x23P 2x24P 2x25P 2x26P 2x27P 2x28P 2x29P 2x30P 2x31P 2x32P 2x33P 2x34P 2x35P 2x36P 2x37P 2x38P 2x39P 2x40P Dimensions A B 42.00 44.60 44.00 46.60 46.00 48.60 48.00 50.60 50.00 52.60 52.00 54.60 54.00 56.60 56.00 58.60 58.00 60.60 60.00 62.60 62.00 64.60 64.00 66.60 66.00 68.60 68.00 70.60 70.00 72.60 72.00 74.60 74.00 76.60 76.00 78.60 78.00 80.60 Unit: mm A2005HWR-S-F-2xXP 2.00mm Pitch 90° Dual Row Female Header - SMT TYPE Reference Informations: *Material:Pin:Phosphor Bronze/Gold over Nickel Insulator:Nylon 6T,UL94V-0 *Mates with CJT A2005 series Dual Row Pin Header *Color:Black Ordering Information: A2005HWR-S-F-2xXP - *** - *** 1 2 3 1.Part No. 2.Material: (Blank):Nylon 6T,UL94V-0 GWT:Nylon 6T,UL94V-0,GWT 750 ℃ 3.Finish: (blank):Gold-flash G15:15μin (0.38μm) MIN.Select Gold(Mating Area) 100μin (2.54μm) MIN.Select Tin G30:30μin (0.76μm) MIN.Select Gold(Mating Area) 100μin (2.54μm) MIN.Select Tin T:Tin over Nickel Ordering Information & Dimensions: ∅1.20 2.00±0.10 A±0.20 0.50 1.00 2.00±0.05 A±0.10 P.C.B LAYOUT 5.15±0.20 0.50x0.20 5.10±0.25 0.92 4.90±0.25 B±0.25 3.00 8.00±0.20 9.20±0.05 5.00 PART NO. 2x2P 2x3P 2x4P 2x5P 2x6P 2x7P 2x8P 2x9P 2x10P 2x11P 2x12P 2x13P 2x14P 2x15P 2x16P 2x17P 2x18P 2x19P 2x20P 2x21P Dimensions A B 2.00 4.60 4.00 6.60 6.00 8.60 8.00 10.60 10.00 12.60 12.00 14.60 14.00 16.60 16.00 18.60 18.00 20.60 20.00 22.60 22.00 24.60 24.00 26.60 26.00 28.60 28.00 30.60 30.00 32.60 32.00 34.60 34.00 36.60 36.00 38.60 38.00 40.60 40.00 42.60 PART NO. 2x22P 2x23P 2x24P 2x25P 2x26P 2x27P 2x28P 2x29P 2x30P 2x31P 2x32P 2x33P 2x34P 2x35P 2x36P 2x37P 2x38P 2x39P 2x40P Dimensions A B 42.00 44.60 44.00 46.60 46.00 48.60 48.00 50.60 50.00 52.60 52.00 54.60 54.00 56.60 56.00 58.60 58.00 60.60 60.00 62.60 62.00 64.60 64.00 66.60 66.00 68.60 68.00 70.60 70.00 72.60 72.00 74.60 74.00 76.60 76.00 78.60 78.00 80.60 Unit: mm CHANGJIANG CONNECTORS TEL:+86-755-29959119 29959129 FAX:+86-755-29959139 Http://www.CJT.cn A-209 A2005 SERIES A2005HWVC-2x10P-K20 2.00mm pitch 180° Box Female Header Reference Informations: *Material:Pin:Phosphor Bronze/Tin over Nickel Insulator:LCP,UL94V-0 *Color:Black Circuit 2 2.00±0.10 2.00±0.10 18.00±0.20 Circuit 20 Positions Omitted 2.00mm pitch wire to board connector 0.80 Circuit 1 Ordering Information: A2005HWVC-2x10P-K20 - *** - ** - *** 1 2 3 4 1.Part No. 2.Material: (blank):LCP,UL94V-0 6T:Nylon 6T,UL94V-0 GWT:LCP,UL94V-0,GWT 750 ℃ 3.Color: (blank):Black BL:Blue RD:Red 4.Finish: (blank):Tin over Nickel G:Gold-flash G15:15μin (0.38μm) MIN.Select Gold(Mating Area) 100μin (2.54μm) MIN.Select Tin G30:30μin (0.76μm) MIN.Select Gold(Mating Area) 100μin (2.54μm) MIN.Select Tin 20.50±0.25 5.15±0.20 2.00 23.10±0.25 11.30±0.25 2.20±0.20 Unit: mm A2005HWVD-2x10P-K20 2.00mm pitch 180° Box Female Header Reference Informations: *Material:Pin:Phosphor Bronze/Tin over Nickel Insulator:LCP,UL94V-0 *Color:Black 18.00±0.20 Circuit 2 2.00±0.10 Circuit 1 0.80 2.00 Circuit 20 Positions Omitted 1.00±0.10 1.80±0.10 9.10±0.25 3.90 4.90±0.20 Ordering Information: A2005HWVD-2x10P-K20 - *** - ** - *** 1 2 3 4 1.Part No. 2.Material: (blank):LCP,UL94V-0 6T:Nylon 6T,UL94V-0 GWT:LCP,UL94V-0,GWT 750 ℃ 3.Color: (blank):Black BL:Blue RD:Red 4.Finish: (blank):Tin over Nickel G:Gold-flash G15:15μin (0.38μm) MIN.Select Gold(Mating Area) 100μin (2.54μm) MIN.Select Tin G30:30μin (0.76μm) MIN.Select Gold(Mating Area) 100μin (2.54μm) MIN.Select Tin 5.15±0.20 2.00 4.90±0.20 11.30±0.25 2.20±0.20 1.50±0.10 1.80±0.10 9.10±0.25 3.90 20.50±0.25 23.10±0.25 Unit: mm CHANGJIANG CONNECTORS TEL:+86-755-29959119 29959129 FAX:+86-755-29959139 Http://www.CJT.cn A-210 A2005 SERIES A2005HWVE-2xXP 2.00mm Pitch 180° Dual Row Female Header A±0.20 2.00±0.10 Circuit 2 Ordering Information: A2005HWVE-2xXP - *** - *** 1 2 3 1.Part No. 2.Material: (Blank):PBT,UL94V-0 6T:Nylon 6T,UL94V-0 GWT:Nylon 6T,UL94V-0,GWT 750 ℃ 3.Finish: (blank):Gold-flash G15:15μin (0.38μm) MIN.Select Gold(Mating Area) 100μin (2.54μm) MIN.Select Tin G30:30μin (0.76μm) MIN.Select Gold(Mating Area) 100μin (2.54μm) MIN.Select Tin Ordering T:Tin over Nickel A 2.00 P.C.B LAYOUT Information & Dimensions: PART NO. 2x2P 2x3P 2x4P 2x5P 2x6P 2x7P 2x8P 2x9P 2x10P 2x11P 2x12P 2x13P 2x14P 2x15P 2x16P 2x17P 2x18P 2x19P 2x20P 2x21P Circuit 1 B±0.25 Pin 0.50x0.20 7.20±0.25 2.50±0.20 4.85±0.25 2.00±0.20 ∅0.80 2.00 Reference Informations: *Material:Pin:Phosphor Bronze/Gold over Nickel Insulator:PBT,UL94V-0 *Mates with CJT A2005 series Dual Row Pin Header *Color:Black 2.00±0.10 2.00mm pitch wire to board connector Dimensions A B 2.00 4.50 4.00 6.50 6.00 8.50 8.00 10.50 10.00 12.50 12.00 14.50 14.00 16.50 16.00 18.50 18.00 20.50 20.00 22.50 22.00 24.50 24.00 26.50 26.00 28.50 28.00 30.50 30.00 32.50 32.00 34.50 34.00 36.50 36.00 38.50 38.00 40.50 40.00 42.50 PART NO. 2x22P 2x23P 2x24P 2x25P 2x26P 2x27P 2x28P 2x29P 2x30P 2x31P 2x32P 2x33P 2x34P 2x35P 2x36P 2x37P 2x38P 2x39P 2x40P Dimensions A B 42.00 44.50 44.00 46.50 46.00 48.50 48.00 50.50 50.00 52.50 52.00 54.50 54.00 56.50 56.00 58.50 58.00 60.50 60.00 62.50 62.00 64.50 64.00 66.50 66.00 68.50 68.00 70.50 70.00 72.50 72.00 74.50 74.00 76.50 76.00 78.50 78.00 80.50 Unit: mm A2005HWRE-2xXP 2.00mm Pitch 90° Dual Row Female Header 2.00±0.10 A 2.00 P.C.B LAYOUT Information & Dimensions: PART NO. Pin 0.50x0.20 A±0.20 B±0.25 7.20±0.25 2.00±0.10 4.85±0.25 2.80±0.20 2x2P 2x3P 2x4P 2x5P 2x6P 2x7P 2x8P 2x9P 2x10P 2x11P 2x12P 2x13P 2x14P 2x15P 2x16P 2x17P 2x18P 2x19P 2x20P 2x21P ∅0.80 2.00 Ordering Information: A2005HWRE-2xXP - *** - *** 1 2 3 1.Part No. 2.Material: (Blank):PBT,UL94V-0 6T:Nylon 6T,UL94V-0 GWT:Nylon 6T,UL94V-0,GWT 750 ℃ 3.Finish: (blank):Gold-flash G15:15μin (0.38μm) MIN.Select Gold(Mating Area) 100μin (2.54μm) MIN.Select Tin G30:30μin (0.76μm) MIN.Select Gold(Mating Area) 100μin (2.54μm) MIN.Select Tin Ordering T:Tin over Nickel 2.00±0.10 Reference Informations: *Material:Pin:Phosphor Bronze/Gold over Nickel Insulator:PBT,UL94V-0 *Mates with CJT A2005 series Dual Row Pin Header *Color:Black Dimensions A B 2.00 4.50 4.00 6.50 6.00 8.50 8.00 10.50 10.00 12.50 12.00 14.50 14.00 16.50 16.00 18.50 18.00 20.50 20.00 22.50 22.00 24.50 24.00 26.50 26.00 28.50 28.00 30.50 30.00 32.50 32.00 34.50 34.00 36.50 36.00 38.50 38.00 40.50 40.00 42.50 PART NO. 2x22P 2x23P 2x24P 2x25P 2x26P 2x27P 2x28P 2x29P 2x30P 2x31P 2x32P 2x33P 2x34P 2x35P 2x36P 2x37P 2x38P 2x39P 2x40P Dimensions A B 42.00 44.50 44.00 46.50 46.00 48.50 48.00 50.50 50.00 52.50 52.00 54.50 54.00 56.50 56.00 58.50 58.00 60.50 60.00 62.50 62.00 64.50 64.00 66.50 66.00 68.50 68.00 70.50 70.00 72.50 72.00 74.50 74.00 76.50 76.00 78.50 78.00 80.50 Unit: mm CHANGJIANG CONNECTORS TEL:+86-755-29959119 29959129 FAX:+86-755-29959139 Http://www.CJT.cn A-211 A2005 SERIES A2005HWVB-2xXP 2.00mm pitch wire to board connector Reference Informations: *Material:Pin:Phosphor Bronze/Gold over Nickel Insulator:PBT,UL94V-0 *Mates with CJT A2005 series Dual Row Pin Header *Color:Black A±0.20 0.65 2.40±0.20 H 0.50 2.80±0.20 2.00 2.50 0.90 B±0.30 4.50±0.10 2.00±0.10 2.00±0.10 Ordering Information: A2005HWVB-2xXP - *** - * - *** - *** 1 2 3 4 5 1.Part No. 2.Size(H): (blank):4.30mm H40:4.00mm Circuit 2 H46:4.60mm H635:6.35mm Circuit 1 3.Type: (blank):Type 1 L:Type2 4.Material: (Blank):PBT,UL94V-0 6T:Nylon 6T,UL94V-0 GWT:Nylon 6T,UL94V-0,GWT 750 ℃ 5.Finish: (blank):Gold-flash G15:15μin (0.38μm) MIN.Select Gold(Mating Area) 100μin (2.54μm) MIN.Select Tin G30:30μin (0.76μm) MIN.Select Gold(Mating Area) 100μin (2.54μm) MIN.Select Tin T:Tin over Nickel 2.00±0.10 0.90 0.70 2.00±0.10 2.00mm Pitch 180° Dual Row Female Header 2.00±0.20 2.00±0.20 Type 2 Type 1 P.C.B LAYOUT ∅0.80±0.05 Ordering Information & Dimensions: PART NO. 2x2P 2x3P 2x4P 2x5P 2x6P 2x7P 2x8P 2x9P 2x10P 2x11P 2x12P 2x13P 2x14P 2x15P 2x16P 2x17P 2x18P 2x19P 2x20P 2x21P Dimensions A B 2.00 4.60 4.00 6.60 6.00 8.60 8.00 10.60 10.00 12.60 12.00 14.60 14.00 16.60 16.00 18.60 18.00 20.60 20.00 22.60 22.00 24.60 24.00 26.60 26.00 28.60 28.00 30.60 30.00 32.60 32.00 34.60 34.00 36.60 36.00 38.60 38.00 40.60 40.00 42.60 PART NO. 2x22P 2x23P 2x24P 2x25P 2x26P 2x27P 2x28P 2x29P 2x30P 2x31P 2x32P 2x33P 2x34P 2x35P 2x36P 2x37P 2x38P 2x39P 2x40P Dimensions A B 42.00 44.60 44.00 46.60 46.00 48.60 48.00 50.60 50.00 52.60 52.00 54.60 54.00 56.60 56.00 58.60 58.00 60.60 60.00 62.60 62.00 64.60 64.00 66.60 66.00 68.60 68.00 70.60 70.00 72.60 72.00 74.60 74.00 76.60 76.00 78.60 78.00 80.60 Unit: mm A2005HWV-N-2xXP-W40 Reference Informations: *Material:Pin:Phosphor Bronze/Gold over Nickel Insulator:PBT,UL94V-0 *Mates with CJT A2005 series Dual Row Pin Header *Color:Black Circuit 1 2.00±0.10 2.00±0.10 Circuit 2 2.00±0.10 Ordering Information: A2005HWV-N-2xXP-W40 - *** - *** 1 2 3 1.Part No. 2.Material: (Blank):PBT,UL94V-0 6T:Nylon 6T,UL94V-0 GWT:Nylon 6T,UL94V-0,GWT 750 ℃ 3.Finish: (blank):Gold-flash G15:15μin (0.38μm) MIN.Select Gold(Mating Area) 100μin (2.54μm) MIN.Select Tin G30:30μin (0.76μm) MIN.Select Gold(Mating Area) 100μin (2.54μm) MIN.Select Tin T:Tin over Nickel A±0.20 B±0.30 4.00±0.25 2.80±0.20 0.50 Pin 0.50x0.20 2.00±0.20 ∅0.80±0.05 2.00±0.10 2.00mm Pitch 180° Dual Row Female Header P.C.B LAYOUT Ordering Information & Dimensions: PART NO. 2x2P 2x3P 2x4P 2x5P 2x6P 2x7P 2x8P 2x9P 2x10P 2x11P 2x12P 2x13P 2x14P 2x15P 2x16P 2x17P 2x18P 2x19P 2x20P 2x21P Dimensions A B 2.00 4.50 4.00 6.50 6.00 8.50 8.00 10.50 10.00 12.50 12.00 14.50 14.00 16.50 16.00 18.50 18.00 20.50 20.00 22.50 22.00 24.50 24.00 26.50 26.00 28.50 28.00 30.50 30.00 32.50 32.00 34.50 34.00 36.50 36.00 38.50 38.00 40.50 40.00 42.50 PART NO. 2x22P 2x23P 2x24P 2x25P 2x26P 2x27P 2x28P 2x29P 2x30P 2x31P 2x32P 2x33P 2x34P 2x35P 2x36P 2x37P 2x38P 2x39P 2x40P Dimensions A B 42.00 44.50 44.00 46.50 46.00 48.50 48.00 50.50 50.00 52.50 52.00 54.50 54.00 56.50 56.00 58.50 58.00 60.50 60.00 62.50 62.00 64.50 64.00 66.50 66.00 68.50 68.00 70.50 70.00 72.50 72.00 74.50 74.00 76.50 76.00 78.50 78.00 80.50 Unit: mm CHANGJIANG CONNECTORS TEL:+86-755-29959119 29959129 FAX:+86-755-29959139 Http://www.CJT.cn A-212 A2005 SERIES A2005HWVA-N-2xXP-W40 2.00mm pitch wire to board connector Reference Informations: *Material:Pin:Phosphor Bronze/Gold over Nickel Insulator:PBT,UL94V-0 *Mates with CJT A2005 series Dual Row Pin Header *Color:Black Ordering Information: A2005HWVA-N-2xXP-W40 - *** - *** 1 2 3 1.Part No. 2.Material: (Blank):PBT,UL94V-0 6T:Nylon 6T,UL94V-0 GWT:Nylon 6T,UL94V-0,GWT 750 ℃ 3.Finish: (blank):Gold-flash G15:15μin (0.38μm) MIN.Select Gold(Mating Area) 100μin (2.54μm) MIN.Select Tin G30:30μin (0.76μm) MIN.Select Gold(Mating Area) 100μin (2.54μm) MIN.Select Tin T:Tin over Nickel Circuit 2 Circuit 1 2.00±0.10 2.00±0.10 A±0.20 B±0.30 4.00±0.25 2.80±0.20 0.50 2.00±0.20 Pin 0.50x0.20 ∅0.80±0.05 2.00±0.10 2.00mm Pitch 180° Dual Row Female Header P.C.B LAYOUT Ordering Information & Dimensions: PART NO. 2x2P 2x3P 2x4P 2x5P 2x6P 2x7P 2x8P 2x9P 2x10P 2x11P 2x12P 2x13P 2x14P 2x15P 2x16P 2x17P 2x18P 2x19P 2x20P 2x21P Dimensions A B 2.00 8.50 4.00 10.50 6.00 12.50 8.00 14.50 10.00 16.50 12.00 18.50 14.00 20.50 16.00 22.50 18.00 24.50 20.00 26.50 22.00 28.50 24.00 30.50 26.00 32.50 28.00 34.50 30.00 36.50 32.00 38.50 34.00 40.50 36.00 42.50 38.00 44.50 40.00 46.50 PART NO. 2x22P 2x23P 2x24P 2x25P 2x26P 2x27P 2x28P 2x29P 2x30P 2x31P 2x32P 2x33P 2x34P 2x35P 2x36P 2x37P 2x38P 2x39P 2x40P Dimensions A B 42.00 48.50 44.00 50.50 46.00 52.50 48.00 54.50 50.00 56.50 52.00 58.50 54.00 60.50 56.00 62.50 58.00 64.50 60.00 66.50 62.00 68.50 64.00 70.50 66.00 72.50 68.00 74.50 70.00 76.50 72.00 78.50 74.00 80.50 76.00 82.50 78.00 84.50 Unit: mm A2005HWV-XP-Y 2.00mm Pitch 180° Single Row Female Header Reference Informations: *Material:Pin:Phosphor Bronze/Gold over Nickel Insulator:PBT,UL94V-0 *Mates with CJT A2005 series Single Row Pin Header *Color:Black 2.00±0.10 ∅0.80±0.05 2.00±0.10 A±0.20 2.00±0.20 P.C.B LAYOUT Ordering Information: A2005HWV-XP-Y - *** - *** - *** 1 2 3 4 1.Part No. 2.Size(H): (Blank):6.35mm(L:2.8mm) H65:6.50mm(L:3.00mm) 3.Material: (Blank):PBT,UL94V-0 6T:Nylon 6T,UL94V-0 GWT:Nylon 6T,UL94V-0,GWT 750 ℃ 4.Finish: (blank):Gold-flash G15:15μin (0.38μm) MIN.Select Gold(Mating Area) 100μin (2.54μm) MIN.Select Tin G30:30μin (0.76μm) MIN.Select Gold(Mating Area) 100μin (2.54μm) MIN.Select Tin T:Tin over Nickel L±0.20 H±0.20 B±0.30 Pin 0.50x0.40 Ordering Information & Dimensions: PART NO. 2P 3P 4P 5P 6P 7P 8P 9P 10P 11P 12P 13P 14P 15P 16P 17P 18P 19P 20P 21P Dimensions A B 2.00 4.50 4.00 6.50 6.00 8.50 8.00 10.50 10.00 12.50 12.00 14.50 14.00 16.50 16.00 18.50 18.00 20.50 20.00 22.50 22.00 24.50 24.00 26.50 26.00 28.50 28.00 30.50 30.00 32.50 32.00 34.50 34.00 36.50 36.00 38.50 38.00 40.50 40.00 42.50 PART NO. 22P 23P 24P 25P 26P 27P 28P 29P 30P 31P 32P 33P 34P 35P 36P 37P 38P 39P 40P Dimensions A B 42.00 44.50 44.00 46.50 46.00 48.50 48.00 50.50 50.00 52.50 52.00 54.50 54.00 56.50 56.00 58.50 58.00 60.50 60.00 62.50 62.00 64.50 64.00 66.50 66.00 68.50 68.00 70.50 70.00 72.50 72.00 74.50 74.00 76.50 76.00 78.50 78.00 80.50 Unit: mm CHANGJIANG CONNECTORS TEL:+86-755-29959119 29959129 FAX:+86-755-29959139 Http://www.CJT.cn A-213 A2005 SERIES A2005HWR-XP-Y 2.00mm pitch wire to board connector 2.00mm Pitch 90° Single Row Female Header Reference Informations: *Material:Pin:Phosphor Bronze/Gold over Nickel Insulator:PBT,UL94V-0 *Mates with CJT A2005 series Single Row Pin Header *Color:Black 2.00±0.10 ∅0.80±0.05 Ordering Information: A2005HWR-XP-Y - *** - *** 1 2 3 1.Part No. 2.Material: (Blank):PBT,UL94V-0 6T:Nylon 6T,UL94V-0 GWT:Nylon 6T,UL94V-0,GWT 750 ℃ 3.Finish: (blank):Gold-flash G15:15μin (0.38μm) MIN.Select Gold(Mating Area) 100μin (2.54μm) MIN.Select Tin G30:30μin (0.76μm) MIN.Select Gold(Mating Area) 100μin (2.54μm) MIN.Select Tin T:Tin over Nickel 2.00±0.10 A±0.20 2.00±0.20 P.C.B LAYOUT 1.45±0.20 6.35±0.20 B±0.30 2.80±0.20 Pin 0.50x0.40 Ordering Information & Dimensions: PART NO. 2P 3P 4P 5P 6P 7P 8P 9P 10P 11P 12P 13P 14P 15P 16P 17P 18P 19P 20P 21P Dimensions A B 2.00 4.50 4.00 6.50 6.00 8.50 8.00 10.50 10.00 12.50 12.00 14.50 14.00 16.50 16.00 18.50 18.00 20.50 20.00 22.50 22.00 24.50 24.00 26.50 26.00 28.50 28.00 30.50 30.00 32.50 32.00 34.50 34.00 36.50 36.00 38.50 38.00 40.50 40.00 42.50 PART NO. 22P 23P 24P 25P 26P 27P 28P 29P 30P 31P 32P 33P 34P 35P 36P 37P 38P 39P 40P Dimensions A B 42.00 44.50 44.00 46.50 46.00 48.50 48.00 50.50 50.00 52.50 52.00 54.50 54.00 56.50 56.00 58.50 58.00 60.50 60.00 62.50 62.00 64.50 64.00 66.50 66.00 68.50 68.00 70.50 70.00 72.50 72.00 74.50 74.00 76.50 76.00 78.50 78.00 80.50 Unit: mm A2005HWR-S-XP-Y 2.00mm Pitch 90° Single Row Female Header-SMT TYPE A 2.00±0.10 A±0.20 2.00±0.20 Reference Informations: *Material:Pin:Phosphor Bronze/Gold over Nickel Insulator:Nylon 6T,UL94V-0 *Mates with CJT A2005 series Single Row Pin Header *Color:Black 2.00 1.90 0.89 Ordering Information: A2005HWR-S-XP-Y - *** - *** 1 2 3 1.Part No. 2.Material: (Blank):Nylon 6T,UL94V-0 GWT:Nylon 6T,UL94V-0,GWT 750 ℃ 3.Finish: (blank):Gold-flash G15:15μin (0.38μm) MIN.Select Gold(Mating Area) 100μin (2.54μm) MIN.Select Tin G30:30μin (0.76μm) MIN.Select Gold(Mating Area) 100μin (2.54μm) MIN.Select Tin T:Tin over Nickel 2.80±0.20 1.27 6.35±0.20 B±0.30 Pin 0.50x0.40 P.C.B LAYOUT Ordering Information & Dimensions: PART NO. 2P 3P 4P 5P 6P 7P 8P 9P 10P 11P 12P 13P 14P 15P 16P 17P 18P 19P 20P 21P Dimensions A B 2.00 4.50 4.00 6.50 6.00 8.50 8.00 10.50 10.00 12.50 12.00 14.50 14.00 16.50 16.00 18.50 18.00 20.50 20.00 22.50 22.00 24.50 24.00 26.50 26.00 28.50 28.00 30.50 30.00 32.50 32.00 34.50 34.00 36.50 36.00 38.50 38.00 40.50 40.00 42.50 PART NO. 22P 23P 24P 25P 26P 27P 28P 29P 30P 31P 32P 33P 34P 35P 36P 37P 38P 39P 40P Dimensions A B 42.00 44.50 44.00 46.50 46.00 48.50 48.00 50.50 50.00 52.50 52.00 54.50 54.00 56.50 56.00 58.50 58.00 60.50 60.00 62.50 62.00 64.50 64.00 66.50 66.00 68.50 68.00 70.50 70.00 72.50 72.00 74.50 74.00 76.50 76.00 78.50 78.00 80.50 Unit: mm CHANGJIANG CONNECTORS TEL:+86-755-29959119 29959129 FAX:+86-755-29959139 Http://www.CJT.cn A-214 A2005 SERIES A2005HWV-2xXP-Y 2.00mm pitch wire to board connector 2.00mm Pitch 180° Dual Row Female Header 2.00±0.10 A±0.20 2.00±0.10 2.00±0.10 Ordering Information: A2005HWV-2xXP-Y - *** - *** - *** 1 2 3 4 1.Part No. 2.Size(H): (Blank):6.35mm(L:2.8mm) H65:6.50mm(L:3.00mm) 3.Material: (Blank):PBT,UL94V-0 6T:Nylon 6T,UL94V-0 GWT :Nylon 6T,UL94V-0,GWT 750 ℃ 4.Finish: (blank):Gold-flash G15:15μin (0.38μm) MIN.Select Gold(Mating Area) 100μin (2.54μm) MIN.Select Tin G30:30μin (0.76μm) MIN.Select Gold(Mating Area) 100μin (2.54μm) MIN.Select Tin T:Tin over Nickel B±0.30 L±0.20 H±0.20 4.00±0.25 2.00±0.20 Pin 0.50x0.40 ∅0.80±0.05 2.00±0.10 Reference Informations: *Material:Pin:Phosphor Bronze/Gold over Nickel Insulator:PBT,UL94V-0 *Mates with CJT A2005 series Dual Row Pin Header *Color:Black P.C.B LAYOUT Ordering Information & Dimensions: PART NO. 2x2P 2x3P 2x4P 2x5P 2x6P 2x7P 2x8P 2x9P 2x10P 2x11P 2x12P 2x13P 2x14P 2x15P 2x16P 2x17P 2x18P 2x19P 2x20P 2x21P Dimensions A B 2.00 4.50 4.00 6.50 6.00 8.50 8.00 10.50 10.00 12.50 12.00 14.50 14.00 16.50 16.00 18.50 18.00 20.50 20.00 22.50 22.00 24.50 24.00 26.50 26.00 28.50 28.00 30.50 30.00 32.50 32.00 34.50 34.00 36.50 36.00 38.50 38.00 40.50 40.00 42.50 PART NO. 2x22P 2x23P 2x24P 2x25P 2x26P 2x27P 2x28P 2x29P 2x30P 2x31P 2x32P 2x33P 2x34P 2x35P 2x36P 2x37P 2x38P 2x39P 2x40P Dimensions A B 42.00 44.50 44.00 46.50 46.00 48.50 48.00 50.50 50.00 52.50 52.00 54.50 54.00 56.50 56.00 58.50 58.00 60.50 60.00 62.50 62.00 64.50 64.00 66.50 66.00 68.50 68.00 70.50 70.00 72.50 72.00 74.50 74.00 76.50 76.00 78.50 78.00 80.50 Unit: mm A2005HWR-2xXP-Y 2.00mm Pitch 90° Dual Row Female Header 2.00±0.10 ∅0.80±0.05 4.00±0.20 P.C.B LAYOUT 2.00±0.10 A±0.20 Ordering Information: A2005HWR-2xXP-Y - *** - *** 1 2 3 1.Part No. 2.Material: (Blank):PBT,UL94V-0 6T:Nylon 6T,UL94V-0 GWT:Nylon 6T,UL94V-0,GWT 750 ℃ 3.Finish: (blank):Gold-flash G15:15μin (0.38μm) MIN.Select Gold(Mating Area) 100μin (2.54μm) MIN.Select Tin G30:30μin (0.76μm) MIN.Select Gold(Mating Area) 100μin (2.54μm) MIN.Select Tin T:Tin over Nickel 2.00 1.25±0.20 6.35±0.20 B±0.30 Pin 0.50x0.40 4.00±0.20 2.00±0.10 Reference Informations: *Material:Pin:Phosphor Bronze/Gold over Nickel Insulator:PBT,UL94V-0 *Mates with CJT A2005 series Dual Row Pin Header *Color:Black Ordering Information & Dimensions: PART NO. 2x2P 2x3P 2x4P 2x5P 2x6P 2x7P 2x8P 2x9P 2x10P 2x11P 2x12P 2x13P 2x14P 2x15P 2x16P 2x17P 2x18P 2x19P 2x20P 2x21P Dimensions A B 2.00 4.50 4.00 6.50 6.00 8.50 8.00 10.50 10.00 12.50 12.00 14.50 14.00 16.50 16.00 18.50 18.00 20.50 20.00 22.50 22.00 24.50 24.00 26.50 26.00 28.50 28.00 30.50 30.00 32.50 32.00 34.50 34.00 36.50 36.00 38.50 38.00 40.50 40.00 42.50 PART NO. 2x22P 2x23P 2x24P 2x25P 2x26P 2x27P 2x28P 2x29P 2x30P 2x31P 2x32P 2x33P 2x34P 2x35P 2x36P 2x37P 2x38P 2x39P 2x40P Dimensions A B 42.00 44.50 44.00 46.50 46.00 48.50 48.00 50.50 50.00 52.50 52.00 54.50 54.00 56.50 56.00 58.50 58.00 60.50 60.00 62.50 62.00 64.50 64.00 66.50 66.00 68.50 68.00 70.50 70.00 72.50 72.00 74.50 74.00 76.50 76.00 78.50 78.00 80.50 Unit: mm CHANGJIANG CONNECTORS TEL:+86-755-29959119 29959129 FAX:+86-755-29959139 Http://www.CJT.cn A-215 A2005 SERIES A2005HWV-S-2xXP-Y 2.00mm pitch wire to board connector 2.00mm Pitch 180° Dual Row Female Header-SMT TYPE Ordering Information: A2005HWV-S-2xXP-Y - *** - *** 1 2 3 1.Part No. 2.Material: (Blank):Nylon 6T,UL94V-0 GWT:Nylon 6T,UL94V-0,GWT 750 ℃ 3.Finish: (blank):Gold-flash G15:15μin (0.38μm) MIN.Select Gold(Mating Area) 100μin (2.54μm) MIN.Select Tin G30:30μin (0.76μm) MIN.Select Gold(Mating Area) 100μin (2.54μm) MIN.Select Tin T:Tin over Nickel Ordering Reference Informations: *Material:Pin:Phosphor Bronze/Gold over Nickel Insulator:Nylon 6T,UL94V-0 *Mates with CJT A2005 series Dual Row Pin Header *Color:Black Circuit 2 2.00±0.10 2.00 2x2P 2x3P 2x4P 2x5P 2x6P 2x7P 2x8P 2x9P 2x10P 2x11P 2x12P 2x13P 2x14P 2x15P 2x16P 2x17P 2x18P 2x19P 2x20P 2x21P 7.40 A±0.20 P.C.B LAYOUT B±0.30 0.75 6.35±0.20 4.00±0.25 6.40±0.20 Pin 0.50x0.40 Information & Dimensions: PART NO. 0.80 1.30 Circuit 1 2.00±0.10 A Dimensions A B 2.00 4.50 4.00 6.50 6.00 8.50 8.00 10.50 10.00 12.50 12.00 14.50 14.00 16.50 16.00 18.50 18.00 20.50 20.00 22.50 22.00 24.50 24.00 26.50 26.00 28.50 28.00 30.50 30.00 32.50 32.00 34.50 34.00 36.50 36.00 38.50 38.00 40.50 40.00 42.50 PART NO. 2x22P 2x23P 2x24P 2x25P 2x26P 2x27P 2x28P 2x29P 2x30P 2x31P 2x32P 2x33P 2x34P 2x35P 2x36P 2x37P 2x38P 2x39P 2x40P Dimensions A B 42.00 44.50 44.00 46.50 46.00 48.50 48.00 50.50 50.00 52.50 52.00 54.50 54.00 56.50 56.00 58.50 58.00 60.50 60.00 62.50 62.00 64.50 64.00 66.50 66.00 68.50 68.00 70.50 70.00 72.50 72.00 74.50 74.00 76.50 76.00 78.50 78.00 80.50 Unit: mm A2005HWV-S-F-2xXP-Y 2.00mm Pitch 180° Dual Row Female Header-SMT TYPE Reference Informations: *Material:Pin:Phosphor Bronze/Gold over Nickel Insulator:Nylon 6T,UL94V-0 *Mates with CJT A2005 series Dual Row Pin Header *Color:Black Circuit 2 Ordering Information: A2005HWV-S-F-2xXP-Y - *** - *** 1 2 3 1.Part No. 2.Material: (Blank):Nylon 6T,UL94V-0 GWT:Nylon 6T,UL94V-0,GWT 750 ℃ 3.Finish: (blank):Gold-flash G15:15μin (0.38μm) MIN.Select Gold(Mating Area) 100μin (2.54μm) MIN.Select Tin G30:30μin (0.76μm) MIN.Select Gold(Mating Area) 100μin (2.54μm) MIN.Select Tin T:Tin over Nickel Ordering Information & Dimensions: A 2.00±0.10 PART NO. 1.30 0.80 ∅1.30 7.40 Circuit 1 2.00±0.10 2.00 A±0.20 1.00 P.C.B LAYOUT B±0.30 0.75 2.00 6.35±0.20 4.00±0.25 Pin 0.50x0.40 ∅1.10 6.40±0.20 2x2P 2x3P 2x4P 2x5P 2x6P 2x7P 2x8P 2x9P 2x10P 2x11P 2x12P 2x13P 2x14P 2x15P 2x16P 2x17P 2x18P 2x19P 2x20P 2x21P Dimensions A B 2.00 4.50 4.00 6.50 6.00 8.50 8.00 10.50 10.00 12.50 12.00 14.50 14.00 16.50 16.00 18.50 18.00 20.50 20.00 22.50 22.00 24.50 24.00 26.50 26.00 28.50 28.00 30.50 30.00 32.50 32.00 34.50 34.00 36.50 36.00 38.50 38.00 40.50 40.00 42.50 PART NO. 2x22P 2x23P 2x24P 2x25P 2x26P 2x27P 2x28P 2x29P 2x30P 2x31P 2x32P 2x33P 2x34P 2x35P 2x36P 2x37P 2x38P 2x39P 2x40P Dimensions A B 42.00 44.50 44.00 46.50 46.00 48.50 48.00 50.50 50.00 52.50 52.00 54.50 54.00 56.50 56.00 58.50 58.00 60.50 60.00 62.50 62.00 64.50 64.00 66.50 66.00 68.50 68.00 70.50 70.00 72.50 72.00 74.50 74.00 76.50 76.00 78.50 78.00 80.50 Unit: mm CHANGJIANG CONNECTORS TEL:+86-755-29959119 29959129 FAX:+86-755-29959139 Http://www.CJT.cn A-216 A2005 SERIES A2005HWR-S-2xXP-Y 2.00mm pitch wire to board connector 2.00mm Pitch 90° Dual Row Female Header-SMT TYPE A Reference Informations: *Material:Pin:Phosphor Bronze/Gold over Nickel Insulator:Nylon 6T,UL94V-0 *Mates with CJT A2005 series Dual Row Pin Header *Color:Black 2.00±0.10 A±0.20 B±0.30 3.40±0.20 4.00±0.25 1.27 1.27 6.35±0.20 0.80 Pin 0.50x0.40 5.80 1.70 Ordering Information: A2005HWR-S-2xXP-Y - *** - *** 1 2 3 1.Part No. 2.Material: (Blank):Nylon 6T,UL94V-0 GWT:Nylon 6T,UL94V-0,GWT 750 ℃ 3.Finish: (blank):Gold-flash G15:15μin (0.38μm) MIN.Select Gold(Mating Area) 100μin (2.54μm) MIN.Select Tin G30:30μin (0.76μm) MIN.Select Gold(Mating Area) 100μin (2.54μm) MIN.Select Tin T:Tin over Nickel 7.20±0.20 P.C.B LAYOUT Ordering Information & Dimensions: PART NO. 2x2P 2x3P 2x4P 2x5P 2x6P 2x7P 2x8P 2x9P 2x10P 2x11P 2x12P 2x13P 2x14P 2x15P 2x16P 2x17P 2x18P 2x19P 2x20P 2x21P Dimensions A B 2.00 4.50 4.00 6.50 6.00 8.50 8.00 10.50 10.00 12.50 12.00 14.50 14.00 16.50 16.00 18.50 18.00 20.50 20.00 22.50 22.00 24.50 24.00 26.50 26.00 28.50 28.00 30.50 30.00 32.50 32.00 34.50 34.00 36.50 36.00 38.50 38.00 40.50 40.00 42.50 PART NO. 2x22P 2x23P 2x24P 2x25P 2x26P 2x27P 2x28P 2x29P 2x30P 2x31P 2x32P 2x33P 2x34P 2x35P 2x36P 2x37P 2x38P 2x39P 2x40P Dimensions A B 42.00 44.50 44.00 46.50 46.00 48.50 48.00 50.50 50.00 52.50 52.00 54.50 54.00 56.50 56.00 58.50 58.00 60.50 60.00 62.50 62.00 64.50 64.00 66.50 66.00 68.50 68.00 70.50 70.00 72.50 72.00 74.50 74.00 76.50 76.00 78.50 78.00 80.50 Unit: mm A2005HWV-2xXP-H-Y 2.00mm Pitch 180° Dual Row Female Header 2.00 Reference Informations: *Material:Pin:Phosphor Bronze/Gold over Nickel Insulator:PBT,UL94V-0 *Mates with CJT A2005 series Dual Row Pin Header *Color:Black 2.00±0.10 A±0.20 Ordering Information: A2005HWV-2xXP-H-Y - *** - *** 1 2 3 1.Part No. 2.Material: (Blank):PBT,UL94V-0 6T:Nylon 6T,UL94V-0 GWT:Nylon 6T,UL94V-0,GWT 750 ℃ 3.Finish: (blank):Gold-flash G15:15μin (0.38μm) MIN.Select Gold(Mating Area) 100μin (2.54μm) MIN.Select Tin G30:30μin (0.76μm) MIN.Select Gold(Mating Area) 100μin (2.54μm) MIN.Select Tin Ordering T:Tin over Nickel 4.00±0.25 13.00±0.20 2.00 Pin 0.50x0.50 P.C.B LAYOUT Information & Dimensions: PART NO. 2x2P 2x3P 2x4P 2x5P 2x6P 2x7P 2x8P 2x9P 2x10P 2x11P 2x12P 2x13P 2x14P 2x15P 2x16P 2x17P 2x18P 2x19P 2x20P 2x21P 6.35±0.20 B±0.30 ∅0.80±0.05 2.00±0.10 2.00 Circuit 1 2.00±0.10 Circuit 2 2.00 Dimensions A B 2.00 4.50 4.00 6.50 6.00 8.50 8.00 10.50 10.00 12.50 12.00 14.50 14.00 16.50 16.00 18.50 18.00 20.50 20.00 22.50 22.00 24.50 24.00 26.50 26.00 28.50 28.00 30.50 30.00 32.50 32.00 34.50 34.00 36.50 36.00 38.50 38.00 40.50 40.00 42.50 PART NO. 2x22P 2x23P 2x24P 2x25P 2x26P 2x27P 2x28P 2x29P 2x30P 2x31P 2x32P 2x33P 2x34P 2x35P 2x36P 2x37P 2x38P 2x39P 2x40P Dimensions A B 42.00 44.50 44.00 46.50 46.00 48.50 48.00 50.50 50.00 52.50 52.00 54.50 54.00 56.50 56.00 58.50 58.00 60.50 60.00 62.50 62.00 64.50 64.00 66.50 66.00 68.50 68.00 70.50 70.00 72.50 72.00 74.50 74.00 76.50 76.00 78.50 78.00 80.50 Unit: mm CHANGJIANG CONNECTORS TEL:+86-755-29959119 29959129 FAX:+86-755-29959139 Http://www.CJT.cn A-217 A2005 SERIES A2005HWV-3xXP 2.00mm pitch wire to board connector 2.00mm Pitch 180° Triple Row Female Header Ordering Information: A2005HWV-3xXP - *** - *** 1 2 3 1.Part No. 2.Material: (Blank):PBT,UL94V-0 6T:Nylon 6T,UL94V-0 GWT:Nylon 6T,UL94V-0,GWT 750 ℃ 3.Finish: (blank):Gold-flash G15:15μin (0.38μm) MIN.Select Gold(Mating Area) 100μin (2.54μm) MIN.Select Tin G30:30μin (0.76μm) MIN.Select Gold(Mating Area) 100μin (2.54μm) MIN.Select Tin T:Tin over Nickel 2.00 2.00 Reference Informations: *Material:Pin:Phosphor Bronze/Gold over Nickel Insulator:PBT,UL94V-0 *Mates with CJT A2005 series Triple Row Pin Header *Color:Black 2.00±0.10 A±0.20 B±0.30 3.10±0.20 6.35±0.20 6.00±0.25 Pin 0.50x0.40 Ordering Information & Dimensions: ∅0.80±0.05 4.00±0.05 PART NO. A±0.10 2.00±0.05 2.00±0.05 3x2P 3x3P 3x4P 3x5P 3x6P 3x7P 3x8P 3x9P 3x10P 3x11P 3x12P 3x13P 3x14P 3x15P 3x16P 3x17P 3x18P 3x19P 3x20P 3x21P P.C.B LAYOUT Dimensions A B 2.00 4.30 4.00 6.30 6.00 8.30 8.00 10.30 10.00 12.30 12.00 14.30 14.00 16.30 16.00 18.30 18.00 20.30 20.00 22.30 22.00 24.30 24.00 26.30 26.00 28.30 28.00 30.30 30.00 32.30 32.00 34.30 34.00 36.30 36.00 38.30 38.00 40.30 40.00 42.30 PART NO. 3x22P 3x23P 3x24P 3x25P 3x26P 3x27P 3x28P 3x29P 3x30P 3x31P 3x32P 3x33P 3x34P 3x35P 3x36P 3x37P 3x38P 3x39P 3x40P Dimensions A B 42.00 44.30 44.00 46.30 46.00 48.30 48.00 50.30 50.00 52.30 52.00 54.30 54.00 56.30 56.00 58.30 58.00 60.30 60.00 62.30 62.00 64.30 64.00 66.30 66.00 68.30 68.00 70.30 70.00 72.30 72.00 74.30 74.00 76.30 76.00 78.30 78.00 80.30 Unit: mm CHANGJIANG CONNECTORS TEL:+86-755-29959119 29959129 FAX:+86-755-29959139 Http://www.CJT.cn A-218 A2005 SERIES A2005HWR-3xXP 2.00mm pitch wire to board connector 2.00mm Pitch 90° Triple Row Female Header Ordering Information: A2005HWR-3xXP - *** - *** 1 2 3 1.Part No. 2.Material: (Blank):PBT,UL94V-0 6T:Nylon 6T,UL94V-0 GWT:Nylon 6T,UL94V-0,GWT 750 ℃ 3.Finish: (blank):Gold-flash G15:15μin (0.38μm) MIN.Select Gold(Mating Area) 100μin (2.54μm) MIN.Select Tin G30:30μin (0.76μm) MIN.Select Gold(Mating Area) 100μin (2.54μm) MIN.Select Tin T:Tin over Nickel 2.00 2.00 Reference Informations: *Material:Pin:Phosphor Bronze/Gold over Nickel Insulator:PBT,UL94V-0 *Mates with CJT A2005 series Triple Row Pin Header *Color:Black 2.00±0.10 A±0.20 B±0.30 2.00 2.00 11.80±0.25 6.35±0.20 6.00±0.25 3.50±0.20 Pin 0.50x0.40 Ordering Information & Dimensions: PART NO. ∅0.80±0.05 2.00 2.00 2.00±0.10 3x2P 3x3P 3x4P 3x5P 3x6P 3x7P 3x8P 3x9P 3x10P 3x11P 3x12P 3x13P 3x14P 3x15P 3x16P 3x17P 3x18P 3x19P 3x20P 3x21P P.C.B LAYOUT Dimensions A B 2.00 4.50 4.00 6.50 6.00 8.50 8.00 10.50 10.00 12.50 12.00 14.50 14.00 16.50 16.00 18.50 18.00 20.50 20.00 22.50 22.00 24.50 24.00 26.50 26.00 28.50 28.00 30.50 30.00 32.50 32.00 34.50 34.00 36.50 36.00 38.50 38.00 40.50 40.00 42.50 PART NO. 3x22P 3x23P 3x24P 3x25P 3x26P 3x27P 3x28P 3x29P 3x30P 3x31P 3x32P 3x33P 3x34P 3x35P 3x36P 3x37P 3x38P 3x39P 3x40P Dimensions A B 42.00 44.50 44.00 46.50 46.00 48.50 48.00 50.50 50.00 52.50 52.00 54.50 54.00 56.50 56.00 58.50 58.00 60.50 60.00 62.50 62.00 64.50 64.00 66.50 66.00 68.50 68.00 70.50 70.00 72.50 72.00 74.50 74.00 76.50 76.00 78.50 78.00 80.50 Unit: mm CHANGJIANG CONNECTORS TEL:+86-755-29959119 29959129 FAX:+86-755-29959139 Http://www.CJT.cn A-219 A2005 SERIES A2005HWV-4xXP 2.00mm pitch wire to board connector 2.00mm Pitch 180° Four Row Female Header Ordering Information: A2005HWV-4xXP - *** - *** 1 2 3 1.Part No. 2.Material: (Blank):PBT,UL94V-0 6T:Nylon 6T,UL94V-0 GWT:Nylon 6T,UL94V-0,GWT 750 ℃ 3.Finish: (blank):Gold-flash G15:15μin (0.38μm) MIN.Select Gold(Mating Area) 100μin (2.54μm) MIN.Select Tin G30:30μin (0.76μm) MIN.Select Gold(Mating Area) 100μin (2.54μm) MIN.Select Tin T:Tin over Nickel 2.00 2.00 2.00 Reference Informations: *Material:Pin:Phosphor Bronze/Gold over Nickel Insulator:PBT,UL94V-0 *Mates with CJT A2005 series Four Row Pin Header *Color:Black 2.00±0.10 A±0.20 B±0.30 3.10±0.20 6.35±0.20 8.00±0.25 Pin 0.50x0.40 2.00 2.00 2.00 Ordering Information & Dimensions: ∅0.80±0.05 2.00±0.05 A±0.10 6.00±0.05 2.00±0.05 4.00±0.05 PART NO. P.C.B LAYOUT 4x2P 4x3P 4x4P 4x5P 4x6P 4x7P 4x8P 4x9P 4x10P 4x11P 4x12P 4x13P 4x14P 4x15P 4x16P 4x17P 4x18P 4x19P 4x20P 4x21P Dimensions A B 2.00 4.50 4.00 6.50 6.00 8.50 8.00 10.50 10.00 12.50 12.00 14.50 14.00 16.50 16.00 18.50 18.00 20.50 20.00 22.50 22.00 24.50 24.00 26.50 26.00 28.50 28.00 30.50 30.00 32.50 32.00 34.50 34.00 36.50 36.00 38.50 38.00 40.50 40.00 42.50 PART NO. 4x22P 4x23P 4x24P 4x25P 4x26P 4x27P 4x28P 4x29P 4x30P 4x31P 4x32P 4x33P 4x34P 4x35P 4x36P 4x37P 4x38P 4x39P 4x40P Dimensions A B 42.00 44.50 44.00 46.50 46.00 48.50 48.00 50.50 50.00 52.50 52.00 54.50 54.00 56.50 56.00 58.50 58.00 60.50 60.00 62.50 62.00 64.50 64.00 66.50 66.00 68.50 68.00 70.50 70.00 72.50 72.00 74.50 74.00 76.50 76.00 78.50 78.00 80.50 Unit: mm CHANGJIANG CONNECTORS TEL:+86-755-29959119 29959129 FAX:+86-755-29959139 Http://www.CJT.cn A-220 A2005 SERIES A2005HWVA-4xXP 2.00mm pitch wire to board connector 2.00mm Pitch 180° Four Row Female Header Ordering Information: A2005HWVA-4xXP - *** - *** 1 2 3 1.Part No. 2.Material: (Blank):PBT,UL94V-0 6T:Nylon 6T,UL94V-0 GWT:Nylon 6T,UL94V-0,GWT 750 ℃ 3.Finish: (blank):Gold-flash G15:15μin (0.38μm) MIN.Select Gold(Mating Area) 100μin (2.54μm) MIN.Select Tin G30:30μin (0.76μm) MIN.Select Gold(Mating Area) 100μin (2.54μm) MIN.Select Tin T:Tin over Nickel 2.00 2.00 2.00 Reference Informations: *Material:Pin:Phosphor Bronze/Gold over Nickel Insulator:PBT,UL94V-0 *Mates with CJT A2005 series Four Row Pin Header *Color:Black 2.00±0.10 A±0.20 B±0.30 11.40±0.20 6.35±0.20 8.00±0.25 Pin 0.50x0.50 2.00 2.00 2.00 Ordering Information & Dimensions: ∅0.80±0.05 2.00±0.05 A±0.10 6.00±0.05 2.00±0.05 4.00±0.05 PART NO. P.C.B LAYOUT 4x2P 4x3P 4x4P 4x5P 4x6P 4x7P 4x8P 4x9P 4x10P 4x11P 4x12P 4x13P 4x14P 4x15P 4x16P 4x17P 4x18P 4x19P 4x20P 4x21P Dimensions A B 2.00 4.50 4.00 6.50 6.00 8.50 8.00 10.50 10.00 12.50 12.00 14.50 14.00 16.50 16.00 18.50 18.00 20.50 20.00 22.50 22.00 24.50 24.00 26.50 26.00 28.50 28.00 30.50 30.00 32.50 32.00 34.50 34.00 36.50 36.00 38.50 38.00 40.50 40.00 42.50 PART NO. 4x22P 4x23P 4x24P 4x25P 4x26P 4x27P 4x28P 4x29P 4x30P 4x31P 4x32P 4x33P 4x34P 4x35P 4x36P 4x37P 4x38P 4x39P 4x40P Dimensions A B 42.00 44.50 44.00 46.50 46.00 48.50 48.00 50.50 50.00 52.50 52.00 54.50 54.00 56.50 56.00 58.50 58.00 60.50 60.00 62.50 62.00 64.50 64.00 66.50 66.00 68.50 68.00 70.50 70.00 72.50 72.00 74.50 74.00 76.50 76.00 78.50 78.00 80.50 Unit: mm CHANGJIANG CONNECTORS TEL:+86-755-29959119 29959129 FAX:+86-755-29959139 Http://www.CJT.cn A-221 A2005 SERIES A2005HWV-4xXP-H 2.00mm pitch wire to board connector 2.00mm Pitch 180° Four Row Female Header 2.00 2.00 2.00 Reference Informations: *Material:Pin:Phosphor Bronze/Gold over Nickel Insulator:PBT,UL94V-0 *Mates with CJT A2005 series Four Row Pin Header *Color:Black Ordering Information: A2005HWV-4xXP-H - *** - *** 1 2 3 1.Part No. 2.Material: (Blank):PBT,UL94V-0 6T:Nylon 6T,UL94V-0 GWT:Nylon 6T,UL94V-0,GWT 750 ℃ 3.Finish: (blank):Gold-flash G15:15μin (0.38μm) MIN.Select Gold(Mating Area) 100μin (2.54μm) MIN.Select Tin G30:30μin (0.76μm) MIN.Select Gold(Mating Area) 100μin (2.54μm) MIN.Select Tin T:Tin over Nickel 2.00±0.10 A±0.20 B±0.30 13.00±0.20 2.00 6.35±0.20 8.00±0.25 2.00 2.00 2.00 Pin 0.50x0.50 Ordering Information & Dimensions: ∅0.80±0.05 2.00±0.05 A±0.10 6.00±0.05 2.00±0.05 4.00±0.05 PART NO. P.C.B LAYOUT 4x2P 4x3P 4x4P 4x5P 4x6P 4x7P 4x8P 4x9P 4x10P 4x11P 4x12P 4x13P 4x14P 4x15P 4x16P 4x17P 4x18P 4x19P 4x20P 4x21P Dimensions A B 2.00 4.50 4.00 6.50 6.00 8.50 8.00 10.50 10.00 12.50 12.00 14.50 14.00 16.50 16.00 18.50 18.00 20.50 20.00 22.50 22.00 24.50 24.00 26.50 26.00 28.50 28.00 30.50 30.00 32.50 32.00 34.50 34.00 36.50 36.00 38.50 38.00 40.50 40.00 42.50 PART NO. 4x22P 4x23P 4x24P 4x25P 4x26P 4x27P 4x28P 4x29P 4x30P 4x31P 4x32P 4x33P 4x34P 4x35P 4x36P 4x37P 4x38P 4x39P 4x40P Dimensions A B 42.00 44.50 44.00 46.50 46.00 48.50 48.00 50.50 50.00 52.50 52.00 54.50 54.00 56.50 56.00 58.50 58.00 60.50 60.00 62.50 62.00 64.50 64.00 66.50 66.00 68.50 68.00 70.50 70.00 72.50 72.00 74.50 74.00 76.50 76.00 78.50 78.00 80.50 Unit: mm CHANGJIANG CONNECTORS TEL:+86-755-29959119 29959129 FAX:+86-755-29959139 Http://www.CJT.cn A-222
A2005WR-2x7P 价格&库存
很抱歉,暂时无法提供与“A2005WR-2x7P”相匹配的价格&库存,您可以联系我们找货
A2005WR-2x7P
  • 1+1.17235
  • 30+1.13193
  • 100+1.05108
  • 500+0.97022
  • 1000+0.92980
