A2505 SERIES
2.50mm pitch wire to board connector
Specifications
Current rating:3A AC,DC
Voltage rating:250V AC,DC
Temperature range:-40°C~+105°C
Contact resistance:20mΩMax.
Insulation resistance:1000MΩMin.
Withstanding voltage:1000V AC/minute
*Compliant with RoHS and REACH*
*Meet the HF/Halogen Free,need to
customize*
*Contact CJT for details*
Standards
E326732
E326732
4.90
1.60
1.60
10.90.REF
4.90
11.45.REF
CHANGJIANG CONNECTORS TEL:+86-755-29959119 29959129 FAX:+86-755-29959139 Http://www.CJT.cn
A-306
A2505 SERIES
A2505-T
2.50mm pitch Crimp Terminal
Reference Informations:
*Used in CJT A2505H-XP series Housing
0.20
B
2.30±0.25
B
1.70
A
6.95±0.25
A
2.18±0.25
0.80
2.30±0.25
0.55
SEC:A-A
2.00±0.25
0.65
1.40
C
2.00±0.20
C
2.00
1.65±0.25
SEC:C-C
0.60
SEC:B-B
Unit:mm
Ordering information & Specifications:
Wire Range
Insulation O.D.
Material
Finish
Qty/reel
A2505-TP
AWG#22-#28
1.90mm(max)
Phosphor Bronze
Tin over Nickel
10,000 PCS
A2505-GP
AWG#22-#28
1.90mm(max)
Phosphor Bronze
Gold over Nickel
10,000 PCS
Part NO.
Optional Gold plating available but MOQ requested
A2505H-XP
2.50mm pitch Housing
*Material:Nylon 66,UL94V-0
*Suitable CJT A2505-T series Terminal
*Mates with CJT A2505WV,WR,WVT-XP series Wafer
*Color:Beige
Ordering Information:
A2505H-XP - ***
1
2
1.Part No.
2.Material:
(Blank):Nylon 66,UL94V-0
GWT :Nylon 66,UL94V-0 GWT 750 ℃
Circuit 1
Ordering Information & Dimensions:
PART NO.
2.50±0.10
A±0.20
3.30±0.25
4.30±0.25
8.00±0.25
9.00±0.25
B±0.25
4.70±0.25
2P
3P
4P
5P
6P
7P
8P
9P
10P
11P
12P
13P
14P
15P
16P
17P
18P
19P
20P
Dimensions
A
B
2.50
5.80
5.00
8.30
7.50
10.80
10.00
13.30
12.50
15.80
15.00
18.30
17.50
20.80
20.00
23.30
22.50
25.80
25.00
28.30
27.50
30.80
30.00
33.30
32.50
35.80
35.00
38.30
37.50
40.80
40.00
43.30
42.50
45.80
45.00
48.30
47.50
50.80
Unit: mm
A-307
A2505 SERIES
A2505WV-XP
2.50mm pitch 180° Wafer
A2505WV-XP - *** - **
1
2 3
1.Part No.
2.Material:
46:Nylon 46,UL94V-0
LCP:Nylon LCP,UL94V-0
GWT:Nylon 66,UL94V-0,GWT 750 ℃
3.Finish:
(blank):Tin over Nickel
G:Gold over Nickel
*Material:Pin:Brass/Tin over Nickel
Insulator:Nylon 66,UL94V-0
*Mates with CJT A2505H-XP series Housing
*Color:Beige
Circuit 1
2.50±0.10
PART NO.
2.50±0.10
Ø0.85±0.05
A±0.20
P.C.B LAYOUT
4.90±0.25
B±0.25
3.50±0.20
5.90±0.25
1.85±0.20
PIN ∅0.70
2P
3P
4P
5P
6P
7P
8P
9P
10P
11P
12P
13P
14P
15P
16P
17P
18P
19P
20P
Dimensions
A
B
2.50
7.50
5.00
10.00
7.50
12.50
10.00
15.00
12.50
17.50
15.00
20.00
17.50
22.50
20.00
25.00
22.50
27.50
25.00
30.00
27.50
32.50
30.00
35.00
32.50
37.50
35.00
40.00
37.50
42.50
40.00
45.00
42.50
47.50
45.00
50.00
47.50
52.50
Unit: mm
A2505WR-XP
2.50mm pitch 90° Wafer
A2505WR-XP - *** - **
1
2 3
1.Part No.
2.Material:
46:Nylon 46,UL94V-0
3.Finish:
G:Gold over Nickel
*Color:Beige
PIN ∅0.70
2.50±0.10
PART NO.
Ø0.85±0.05
2.50±0.10
P.C.B LAYOUT
Circuit 1
A±0.20
B±0.25
6.45±0.25
5.90±0.25
7.90±0.25
4.90±0.20
3.50±0.20
2P
3P
4P
5P
6P
7P
8P
9P
10P
11P
12P
13P
14P
15P
16P
17P
18P
19P
20P
Dimensions
A
B
2.50
7.50
5.00
10.00
7.50
12.50
10.00
15.00
12.50
17.50
15.00
20.00
17.50
22.50
20.00
25.00
22.50
27.50
25.00
30.00
27.50
32.50
30.00
35.00
32.50
37.50
35.00
40.00
37.50
42.50
40.00
45.00
42.50
47.50
45.00
50.00
47.50
52.50
Unit: mm
A-308
A2505 SERIES
A2505WVT-XP
*Color:Beige
A±0.20
2.50±0.05
A±0.20
2.50±0.10
A±0.20
2.50±0.10
+0.10
∅0.90-0.00
B±0.25
4.90±0.25
B±0.25
A2505WVT-XP - *** - **
1
2 3
1.Part No.
2.Material:
3.Finish:
G:Gold over Nickel
17.20±0.25
5.90±0.25
3.50
B±0.25
P.C.B LAYOUT
Circuit 1
Circuit 1
Circuit 1
PIN ∅0.70
2P
3P
5P
4P
6P
7P
8P
11.00
18.10
20.00
12.70
18.10
20.00
11.00
5.00
2.50
3.85
∅4.00
12.70
12.70
12.70
25.40
20.00
12.70
3P
11.00
2P
PART NO.
18.00
5.00
3.85
12.70
∅4.00
12.70
2P
3P
4P
5P
6P
7P
8P
∅4.00
12.70
4P~8P
Dimensions
A
B
2.50
7.50
5.00
10.00
7.50
12.50
10.00
15.00
12.50
17.50
15.00
20.00
17.50
22.50
Unit: mm
A-309
很抱歉,暂时无法提供与“A2505WV-4P”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 10+0.28860
- 100+0.26460
- 300+0.24050
- 国内价格
- 10+0.31991
- 100+0.29927
- 500+0.27863
- 2000+0.24767
- 5000+0.23735
- 10000+0.23116
- 国内价格
- 10+0.28851
- 100+0.21857
- 300+0.19671
