A2505WR-8P
A2505WR-8P
    CJT(长江连接器)
    弯插,P=2.5mm
    线对板针座 1x8P 弯插 间距:2.5mm
A2505WR-8P 数据手册
A2505 SERIES 2.50mm pitch wire to board connector Specifications Current rating:3A AC,DC Voltage rating:250V AC,DC Temperature range:-40°C~+105°C Contact resistance:20mΩMax. Insulation resistance:1000MΩMin. Withstanding voltage:1000V AC/minute *Compliant with RoHS and REACH* *Meet the HF/Halogen Free,need to customize* *Contact CJT for details* Standards E326732 E326732 4.90 1.60 1.60 10.90.REF 4.90 11.45.REF CHANGJIANG CONNECTORS TEL:+86-755-29959119 29959129 FAX:+86-755-29959139 Http://www.CJT.cn A-306 A2505 SERIES A2505-T 2.50mm pitch wire to board connector 2.50mm pitch Crimp Terminal Reference Informations: *Used in CJT A2505H-XP series Housing 0.20 B 2.30±0.25 B 1.70 A 6.95±0.25 A 2.18±0.25 0.80 2.30±0.25 0.55 SEC:A-A 2.00±0.25 0.65 1.40 C 2.00±0.20 C 2.00 1.65±0.25 SEC:C-C 0.60 SEC:B-B Unit:mm Ordering information & Specifications: Wire Range Insulation O.D. Material Finish Qty/reel A2505-TP AWG#22-#28 1.90mm(max) Phosphor Bronze Tin over Nickel 10,000 PCS A2505-GP AWG#22-#28 1.90mm(max) Phosphor Bronze Gold over Nickel 10,000 PCS Part NO. Optional Gold plating available but MOQ requested A2505H-XP 2.50mm pitch Housing Reference Informations: *Material:Nylon 66,UL94V-0 *Suitable CJT A2505-T series Terminal *Mates with CJT A2505WV,WR,WVT-XP series Wafer *Color:Beige Ordering Information: A2505H-XP - *** 1 2 1.Part No. 2.Material: (Blank):Nylon 66,UL94V-0 GWT :Nylon 66,UL94V-0 GWT 750 ℃ Circuit 1 Ordering Information & Dimensions: PART NO. 2.50±0.10 A±0.20 3.30±0.25 4.30±0.25 8.00±0.25 9.00±0.25 B±0.25 4.70±0.25 2P 3P 4P 5P 6P 7P 8P 9P 10P 11P 12P 13P 14P 15P 16P 17P 18P 19P 20P Dimensions A B 2.50 5.80 5.00 8.30 7.50 10.80 10.00 13.30 12.50 15.80 15.00 18.30 17.50 20.80 20.00 23.30 22.50 25.80 25.00 28.30 27.50 30.80 30.00 33.30 32.50 35.80 35.00 38.30 37.50 40.80 40.00 43.30 42.50 45.80 45.00 48.30 47.50 50.80 Unit: mm CHANGJIANG CONNECTORS TEL:+86-755-29959119 29959129 FAX:+86-755-29959139 Http://www.CJT.cn A-307 A2505 SERIES A2505WV-XP 2.50mm pitch wire to board connector 2.50mm pitch 180° Wafer Ordering Information: A2505WV-XP - *** - ** 1 2 3 1.Part No. 2.Material: (Blank):Nylon 66,UL94V-0 46:Nylon 46,UL94V-0 LCP:Nylon LCP,UL94V-0 GWT:Nylon 66,UL94V-0,GWT 750 ℃ 3.Finish: (blank):Tin over Nickel G:Gold over Nickel Reference Informations: *Material:Pin:Brass/Tin over Nickel Insulator:Nylon 66,UL94V-0 *Mates with CJT A2505H-XP series Housing *Color:Beige Circuit 1 2.50±0.10 Ordering Information & Dimensions: PART NO. 2.50±0.10 Ø0.85±0.05 A±0.20 P.C.B LAYOUT 4.90±0.25 B±0.25 3.50±0.20 5.90±0.25 1.85±0.20 PIN ∅0.70 2P 3P 4P 5P 6P 7P 8P 9P 10P 11P 12P 13P 14P 15P 16P 17P 18P 19P 20P Dimensions A B 2.50 7.50 5.00 10.00 7.50 12.50 10.00 15.00 12.50 17.50 15.00 20.00 17.50 22.50 20.00 25.00 22.50 27.50 25.00 30.00 27.50 32.50 30.00 35.00 32.50 37.50 35.00 40.00 37.50 42.50 40.00 45.00 42.50 47.50 45.00 50.00 47.50 52.50 Unit: mm A2505WR-XP 2.50mm pitch 90° Wafer Ordering Information: A2505WR-XP - *** - ** 1 2 3 1.Part No. 2.Material: (Blank):Nylon 66,UL94V-0 46:Nylon 46,UL94V-0 LCP:Nylon LCP,UL94V-0 GWT:Nylon 66,UL94V-0,GWT 750 ℃ 3.Finish: (blank):Tin over Nickel G:Gold over Nickel Reference Informations: *Material:Pin:Brass/Tin over Nickel Insulator:Nylon 66,UL94V-0 *Mates with CJT A2505H-XP series Housing *Color:Beige PIN ∅0.70 Ordering Information & Dimensions: 2.50±0.10 PART NO. Ø0.85±0.05 2.50±0.10 P.C.B LAYOUT Circuit 1 A±0.20 B±0.25 6.45±0.25 5.90±0.25 7.90±0.25 4.90±0.20 3.50±0.20 2P 3P 4P 5P 6P 7P 8P 9P 10P 11P 12P 13P 14P 15P 16P 17P 18P 19P 20P Dimensions A B 2.50 7.50 5.00 10.00 7.50 12.50 10.00 15.00 12.50 17.50 15.00 20.00 17.50 22.50 20.00 25.00 22.50 27.50 25.00 30.00 27.50 32.50 30.00 35.00 32.50 37.50 35.00 40.00 37.50 42.50 40.00 45.00 42.50 47.50 45.00 50.00 47.50 52.50 Unit: mm CHANGJIANG CONNECTORS TEL:+86-755-29959119 29959129 FAX:+86-755-29959139 Http://www.CJT.cn A-308 A2505 SERIES A2505WVT-XP 2.50mm pitch wire to board connector 2.50mm pitch 180° Wafer Reference Informations: *Material:Pin:Brass/Tin over Nickel Insulator:Nylon 66,UL94V-0 *Mates with CJT A2505H-XP series Housing *Color:Beige A±0.20 2.50±0.05 A±0.20 2.50±0.10 A±0.20 2.50±0.10 +0.10 ∅0.90-0.00 B±0.25 4.90±0.25 B±0.25 Ordering Information: A2505WVT-XP - *** - ** 1 2 3 1.Part No. 2.Material: (Blank):Nylon 66,UL94V-0 GWT:Nylon 66,UL94V-0,GWT 750 ℃ 3.Finish: (blank):Tin over Nickel G:Gold over Nickel 17.20±0.25 5.90±0.25 3.50 B±0.25 P.C.B LAYOUT Circuit 1 Circuit 1 Circuit 1 PIN ∅0.70 2P 3P 5P 4P 6P 7P 8P 11.00 18.10 20.00 12.70 18.10 20.00 11.00 5.00 2.50 3.85 ∅4.00 12.70 12.70 12.70 25.40 20.00 12.70 3P 11.00 2P Ordering Information & Dimensions: PART NO. 18.00 5.00 3.85 12.70 ∅4.00 12.70 2P 3P 4P 5P 6P 7P 8P ∅4.00 12.70 4P~8P Dimensions A B 2.50 7.50 5.00 10.00 7.50 12.50 10.00 15.00 12.50 17.50 15.00 20.00 17.50 22.50 Unit: mm CHANGJIANG CONNECTORS TEL:+86-755-29959119 29959129 FAX:+86-755-29959139 Http://www.CJT.cn A-309
A2505WR-8P 价格&库存
很抱歉,暂时无法提供与“A2505WR-8P”相匹配的价格&库存,您可以联系我们找货
A2505WR-8P
  • 1+0.71760
  • 10+0.69000
  • 100+0.60720
  • 500+0.59064
库存:760
