C2504WV-3P
C2504WV-3P
    CJT(长江连接器)
    插件,P=2.5mm
    线对板针座 1x3P 直插 间距:2.5mm
C2504WV-3P 数据手册
C2504 SERIES 2.50mm pitch wire to wire and wire to board connector Specifications Current rating:3A AC,DC Voltage rating:250V AC,DC Temperature range:-40°C~+105°C Contact resistance:20mΩ Max. Insulation resistance:1000MΩ Min. Withstanding voltage:1000V AC/minute *Compliant with RoHS and REACH* *Meet the HF/Halogen Free,need to customize* *Contact CJT for details* Standards E326732 E326732 6.70 17.06 REF. 13.30 REF. 1.60 9.23 1.60 11.70 REF. 6.32 PART NO. 8.50±0.10 A±0.10 C2504HM-2P C2504HM-3P C2504HM-4P C2504HM-5P C2504HM-6P C2504HM-7P C2504HM-8P C2504HM-9P C2504HM-10P C2504HM-11P C2504HM-12P Dimensions A 12.40 14.90 17.40 19.90 22.40 24.90 27.40 29.90 32.40 34.90 37.40 Unit:mm CHANGJIANG CONNECTORS TEL:+86-755-29959119 29959129 FAX:+86-755-29959139 Http://www.CJT.cn C-58 C2504 SERIES C2504HFA-XP 2.50mm pitch wire to wire and wire to board connector 2.50mm Pitch Housing Reference Informations: *Material:Nylon 66,UL94V-0 *Suitable CJT A2509-T-A series Terminal *Mates with CJT C2504HM,HMA,HMB-XP series Housing or C2504WV,WR-XP,C2504WVR-XP series Wafer *Color:Beige 1.10 1.30 Circuit 1 2.50±0.10 A±0.20 Ordering Information: C2504HFA-XP - *** - ** 1 2 3 1.Part No. 2.Material: (blank):Nylon 66,UL94V-0 GWT:Nylon 66,UL94V-0,GWT 750°C 3.Color: (blank):Beige WH:White 6.55±0.25 1.00 0.95 10.00±0.25 4.80±0.20 7.40±0.20 B±0.25 Ordering Information & Dimensions: PART NO. 2P 3P 4P 5P 6P 7P 8P 9P 10P 11P 12P 13P 14P 15P 16P 17P 18P 19P 20P Dimensions A B 2.50 5.60 5.00 8.10 7.50 10.60 10.00 13.10 12.50 15.60 15.00 18.10 17.50 20.60 23.10 20.00 22.50 25.60 25.00 28.10 27.50 30.60 30.00 33.10 32.50 35.60 35.00 38.10 37.50 40.60 40.00 43.10 42.50 45.60 45.00 48.10 47.50 50.60 Unit: mm C2504AH-XP 2.50mm Pitch Housing Reference Informations: *Material:Nylon 66,UL94V-0 *Suitable CJT A2543-T series Terminal *Mates with CJT C2504WV,WR-XP, C2504WVR-XP series Wafer *Color:Beige Circuit 1 2.50±0.10 A±0.20 Ordering Information: C2504AH-XP - *** - ** 1 2 3 1.Part No. 2.Material: (blank):Nylon 66,UL94V-0 GWT:Nylon 66,UL94V-0,GWT 750°C 3.Color: (blank):Beige WH:White 6.30±0.25 4.85±0.20 12.70±0.25 B±0.25 Ordering Information & Dimensions: PART NO. 2P 3P 4P 5P 6P 7P 8P 9P 10P 11P 12P 13P 14P 15P 16P 17P 18P 19P 20P Dimensions A B 2.50 5.50 5.00 8.00 7.50 10.50 10.00 13.00 12.50 15.50 15.00 18.00 17.50 20.50 20.00 23.00 22.50 25.50 25.00 28.00 27.50 30.50 30.00 33.00 32.50 35.50 35.00 38.00 37.50 40.50 40.00 43.00 42.50 45.50 45.00 48.00 47.50 50.50 Unit: mm CHANGJIANG CONNECTORS TEL:+86-755-29959119 29959129 FAX:+86-755-29959139 Http://www.CJT.cn C-59 C2504 SERIES C2504HM-XP 2.50mm pitch wire to wire and wire to board connector 2.50mm Pitch Housing Reference Informations: *Material:Nylon 66, UL94V-0 *Suitable CJT A2501M-T series Terminal *Mates with CJT C2504HFA-XP series Housing *Color:Beige Ordering Information: C2504HM-XP - *** - ** 1 2 3 1.Part No. 2.Material: (blank):Nylon 66,UL94V-0 GWT:Nylon 66,UL94V-0,GWT 750°C 3.Color: (blank):Beige WH:White 5.00±0.20 Circuit 1 2.50±0.10 A±0.20 B±0.25 7.90±0.25 A Ordering Information & Dimensions: 18.50±0.25 PART NO. A 5.00±0.20 C±0.25 SEC:A-A C2504HMA-XP Reference Informations: *Material:Nylon 66, UL94V-0 *Suitable CJT A2501M-T series Terminal *Mates with CJT C2504HFA-XP series Housing *Color:Beige B±0.25 A±0.20 2.50±0.10 2P 3P 4P 5P 6P 7P 8P 9P 10P 11P 12P A 2.50 5.00 7.50 10.00 12.50 15.00 17.50 20.00 22.50 25.00 27.50 Dimensions B 8.60 11.10 13.60 16.10 18.60 21.10 23.60 26.10 28.60 31.10 33.60 C 5.80 8.30 10.80 13.30 15.80 18.30 20.80 23.30 25.80 28.30 30.80 Unit: mm 2.50mm Pitch Housing Ordering Information: C2504HMA-XP - *** - ** 1 2 3 1.Part No. 2.Material: (blank):Nylon 66,UL94V-0 GWT:Nylon 66,UL94V-0,GWT 750°C 3.Color: (blank):Beige WH:White 7.90±0.25 Circuit 1 Ordering Information & Dimensions: 18.70±0.25 PART NO. C±0.25 5.00±0.25 2P 3P 4P 5P 6P 7P 8P 9P 10P 11P 12P A 2.50 5.00 7.50 10.00 12.50 15.00 17.50 20.00 22.50 25.00 27.50 Dimensions B 8.60 11.10 13.60 16.10 18.60 21.10 23.60 26.10 28.60 31.10 33.60 C 5.80 8.30 10.80 13.30 15.80 18.30 20.80 23.30 25.80 28.30 30.80 Unit: mm CHANGJIANG CONNECTORS TEL:+86-755-29959119 29959129 FAX:+86-755-29959139 Http://www.CJT.cn C-60 C2504 SERIES C2504HMB-XP 2.50mm pitch wire to wire and wire to board connector 2.50mm Pitch Housing Ordering Information: C2504HMB-XP - *** 1 2 1.Part No. 2.Material: (blank):Nylon 66,UL94V-0 GWT:Nylon 66,UL94V-0,GWT 750°C Reference Informations: *Material:Nylon 66, UL94V-0 *Suitable CJT A2501M-T series Terminal *Mates with CJT C2504HFA-XP series Housing *Color:White 5.00±0.20 8.95±0.25 2.50±0.10 2.50±0.10 Circuit 1 Circuit 1 18.75±0.25 4.25±0.25 6.36±0.25 6.05±0.20 18.70±0.25 8.05±0.20 11.50±0.25 8.50±0.25 2P 8.05±0.20 6.05±0.20 4.25±0.25 3P C2504WV-XP 2.50mm Pitch 180° Wafer Ordering Information: C2504WV-XP - *** - ** 1 2 3 1.Part No. 2.Material: (blank):Nylon 66,UL94V-0 GWT:Nylon 66,UL94V-0,GWT 750°C 3.Finish: (blank):Tin over Nickel G:Gold over Nickel Reference Informations: *Material:Pin:Brass/Tin over Nickel Insulator:Nylon 66,UL94V-0 *Mates with CJT C2504HFA,AH-XP series Housing *Color:Beige Circuit 1 2.50±0.10 Ordering Information & Dimensions: PART NO. Ø1.20±0.05 2.50±0.10 P.C.B LAYOUT A±0.20 5.80±0.20 B±0.25 PIN 0.64 SQ 11.70±0.25 7.50±0.20 3.40±0.20 3.30±0.20 3.20 4.90±0.20 2P 3P 4P 5P 6P 7P 8P 9P 10P 11P 12P 13P 14P 15P 16P 17P 18P 19P 20P Dimensions A B 2.50 5.00 5.00 7.50 7.50 10.00 10.00 12.50 12.50 15.00 15.00 17.50 17.50 20.00 20.00 22.50 22.50 25.00 25.00 27.50 27.50 30.00 30.00 32.50 32.50 35.00 35.00 37.50 37.50 40.00 40.00 42.50 42.50 45.00 45.00 47.50 47.50 50.00 Unit: mm CHANGJIANG CONNECTORS TEL:+86-755-29959119 29959129 FAX:+86-755-29959139 Http://www.CJT.cn C-61 C2504 SERIES C2504WR-XP 2.50mm pitch wire to wire and wire to board connector 2.50mm Pitch 90° Wafer Ordering Information: C2504WR-XP - *** - ** 1 2 3 1.Part No. 2.Material: (blank):Nylon 66,UL94V-0 GWT:Nylon 66,UL94V-0,GWT 750°C 3.Finish: (blank):Tin over Nickel G:Gold over Nickel 2.50±0.10 13.30±0.25 4.90±0.25 Reference Informations: *Material:Pin:Brass/Tin over Nickel Insulator:Nylon 66,UL94V-0 *Mates with CJT C2504HFA,AH-XP series Housing *Color:Beige Ordering Information & Dimensions: PART NO. Ø1.20±0.05 P.C.B LAYOUT 2.50±0.10 Circuit 1 A±0.20 7.50±0.25 6.00±0.20 3.40±0.20 6.30±0.25 B±0.25 3.20±0.20 PIN 0.64 SQ 2P 3P 4P 5P 6P 7P 8P 9P 10P 11P 12P 13P 14P 15P 16P 17P 18P 19P 20P Dimensions A B 2.50 5.00 5.00 7.50 7.50 10.00 10.00 12.50 12.50 15.00 15.00 17.50 17.50 20.00 20.00 22.50 22.50 25.00 25.00 27.50 27.50 30.00 30.00 32.50 32.50 35.00 35.00 37.50 37.50 40.00 40.00 42.50 42.50 45.00 45.00 47.50 47.50 50.00 Unit: mm C2504WVR-XP 2.50mm Pitch 90° Wafer Reference Informations: *Material:Pin:Brass/Tin over Nickel Insulator:Nylon 66,UL94V-0 *Mates with CJT C2504HFA,AH-XP series Housing *Color:Beige PIN 0.64 SQ Ordering Information: C2504WVR-XP - *** - ** 1 2 3 1.Part No. 2.Material: (blank):Nylon 66,UL94V-0 GWT:Nylon 66,UL94V-0,GWT 750°C 3.Finish: (blank):Tin over Nickel G:Gold over Nickel 2.50±0.10 Circuit 1 Ordering Information & Dimensions: Ø1.20±0.05 PART NO. P.C.B LAYOUT 2.50±0.10 A±0.20 5.80±0.20 B±0.25 7.30±0.20 11.50±0.25 3.30±0.20 3.20 5.10±0.20 3.40±0.20 2P 3P 4P 5P 6P 7P 8P 9P 10P 11P 12P 13P 14P 15P 16P 17P 18P 19P 20P Dimensions A B 2.50 5.00 5.00 7.50 7.50 10.00 10.00 12.50 12.50 15.00 15.00 17.50 17.50 20.00 20.00 22.50 22.50 25.00 25.00 27.50 27.50 30.00 30.00 32.50 32.50 35.00 35.00 37.50 37.50 40.00 40.00 42.50 42.50 45.00 45.00 47.50 47.50 50.00 Unit: mm CHANGJIANG CONNECTORS TEL:+86-755-29959119 29959129 FAX:+86-755-29959139 Http://www.CJT.cn C-62
C2504WV-3P 价格&库存
很抱歉,暂时无法提供与“C2504WV-3P”相匹配的价格&库存,您可以联系我们找货
C2504WV-3P
  • 1+0.35277
  • 30+0.34017
  • 100+0.32757
  • 500+0.30237
  • 1000+0.28977
  • 2000+0.28221
