C3030 SERIES
3.00mm pitch wire to wire and wire to board connector
Specifications
Current rating:5A AC,DC
Voltage rating:250V AC,DC
Temperature range:-40°C~+105°C
Contact resistance:10mΩ Max.
Insulation resistance:1000MΩ Min.
Withstanding voltage:1500V AC/minute
*Compliant with RoHS and REACH*
*Meet the HF/Halogen Free,GWT/Glow wire Test
(IEC60335-1) request,need to customize*
*Contact CJT for details*
Standards
E326732
E326732
CHANGJIANG CONNECTORS TEL:+86-755-29959119 29959129 FAX:+86-755-29959139 Http://www.CJT.cn
C-72
C3030 SERIES
5.29
1.60
1.60
0.74
17.54 REF.
1.60
1.60
1.60
7.68
17.71 REF.
18.42 REF.
7.68
0.74
17.49 REF.
24.56 REF.
24.49 REF.
7.05
1.60
10.24
7.05
WIRE TO WIRE
7.68
5.29
7.68
17.71 REF.
17.66 REF.
17.54 REF.
17.51 REF.
1.60
16.86 REF.
5.29
1.96
1.60
BOARD TO BOARD
1.60
1.60
1.60
1.60
0.74
1.60
WIRE TO BOARD
0.69
4.20±0.10
3.05±0.10
5.50±0.20
3.20±0.20
A±0.10
+0.05
B-0.10
SINGLE ROW
RECOMMENDED PANEL CUT-OUT
(DESIGNED FOR 1.57mm TO 2.30mm THICK
STAMPED PANEL OR PRINTED CIRCUIT BOARD)
PART NO.
4.05±0.10
SINGLE ROW
DUAL ROW
C3030HM-2X1P(-A)
--------------C3030HM-2X2P(-A)
C3030HM-2P
C3030HM-2X3P(-A)
C3030HM-3P
C3030HM-2X4P(-A)
C3030HM-4P
C3030HM-2X5P(-A)
C3030HM-5P
C3030HM-2X6P(-A)
C3030HM-6P
C3030HM-2X7P(-A)
C3030HM-7P
C3030HM-2X8P(-A)
C3030HM-8P
C3030HM-2X9P(-A)
C3030HM-9P
C3030HM-10P C3030HM-2X10P(-A)
C3030HM-11P C3030HM-2X11P(-A)
C3030HM-12P C3030HM-2X12P(-A)
8.70±0.20
7.10±0.10
2.00±0.20
A±0.10
B±0.10
DUAL ROW
(DESIGNED FOR 1.40mm TO 2.54mm THICK
Dimensions
A
4.20
7.20
10.20
13.20
16.20
19.20
22.20
25.20
28.20
31.20
34.20
37.20
B
7.90
10.90
13.90
16.90
19.90
22.90
25.90
28.90
31.90
34.90
37.90
40.90
Unit:mm
C-73
C3030 SERIES
C3030HF
2P
3P
4P
5P
9P
C3030HF
6P
10P
7P
8P
11P
12P
C3030HM C3030HMA
7P
C3030HM
C3030HMA
6P
5P
4P
3P
2P
9P
8P
12P
11P
10P
C3030WV C3030WV-S C3030WV-S-F
2P
3P
4P
7P
C3030WV
8P
10P
C3030WV-S
5P
6P
9P
11P
12P
C3030WV-S-F
C3030WR C3030WR-S C3030WR-S-F
2P
3P
4P
5P
6P
C3030WR
7P
8P
9P
C3030WR-S
10P
11P
12P
C3030WR-S-F
C-74
C3030 SERIES
C3030HF-2
2x1P
C3030HF-2
2x2P
2x3P
2x7P
2x4P
2x5P
2x8P
2x6P
2x9P
2x10P
2x11P
2x12P
C3030HM-2 C3030HMA-2 C3030HMC-2
2x1P
2x2P
2x3P
2x7P
C3030HM-2
2x5P
2x8P
2x10P
C3030HMC-2
2x4P
2x6P
2x9P
2x11P
2x12P
C3030HMA-2
C3030WV-2 C3030WV-S-2 C3030WV-S-F-2
2x1P
2x2P
2x3P
2x7P
C3030WV-2
2x4P
2x8P
2x10P
C3030WV-S-2
2x5P
2x6P
2x9P
2x11P
2x12P
C3030WV-S-F-2
C3030WR-2 C3030WRA-2 C3030WRA-F-2 C3030WR-S-2 C3030WR-S-F-2
2x1P
C3030WR-2
C3030WRA-2
2x2P
2x7P
2x3P
2x4P
2x8P
2x6P
2x9P
C3030WRA-F-2
2x10P
C3030WR-S-2
2x5P
2x11P
2x12P
C3030WR-S-F-2
C-75
C3030 SERIES
C3030HFB-2
2x1P
2x12P
2x2P
2x11P
2x3P
2x10P
2x4P
2x9P
2x5P
2x8P
2x6P
2x7P
2x1P
2x12P
2x2P
2x11P
2x3P
2x10P
2x4P
2x9P
2x5P
2x8P
2x6P
2x7P
C3030HFB-2
C3030HMB-2
C3030HMB-2
C-76
C3030 SERIES
C3030F-T-A
3.00mm pitch Crimp Terminal
Ordering Information:
C3030F-GP-A (-L) - ***
1
2
1.Part No.
2.Finish:
(blank): Gold-flash
100μin (2.54μm) MIN.Select Tin
G15:15μin (0.38μm) MIN.Select Gold
G30:30μin (0.76μm) MIN.Select Gold
Reference Informations:
*Used in CJT C3030HF-2P~12P,C3030HF-2x1P~2x6P series Housing
0.80±0.20
0.20
0.56±0.05
Gold-flash
SEC:A-A
SEC:B-B
Minmum Area Of
Select Gold Plating
2 Places
(Inside Only)
(Plating G15 and G30 Only)
1.35±0.10
1.12±0.10
Ordering information & Specifications:
Wire Range Insulation O.D.
Part NO.
C3030F-TP-A
AWG#20-#24 1.85mm(max)
C3030F-GP-A
C3030F-TP-A-L AWG#26-#30 1.27mm(max)
C3030F-GP-A-L AWG#26-#30 1.27mm(max)
E±0.20
C±0.20
F±0.20
2.18±0.20
D±0.20
B
11.00±0.25
B
2.05
A
6.70±0.20
A
Unit:mm
Material
Finish
Phosphor Bronze Tin over Nickel
Phosphor Bronze
Gold-flash
Phosphor Bronze
Gold-flash
C
2.54
2.54
2.10
2.10
D
2.30
2.30
1.90
1.90
E
2.08
2.08
1.65
1.65
Qty/reel
10,000 PCS
10,000 PCS
10,000 PCS
10,000 PCS
F
1.90
1.90
1.46
1.46
Optional Gold plating available but MOQ requested
C3030F-T-C
*Used in CJT C3030HF-2x7P~2x12P,C3030HFB-2xXP series Housing
Gold-flash
2.50±0.25
SEC:A-A
0.30±0.10
1.12±0.10
1.75±0.25
2.20±0.25
Optional Lubed Contact Area
2.05
B
7.00±0.25
B
A
11.50±0.25
A
Select Gold Area(Inside Only)
1.00
0.15
2.30±0.25
C3030F-GP-C - ***
1
2
1.Part No.
2.Finish:
(blank): Gold-flash
1.90±0.25
SEC:B-B
1.35±0.10
Unit:mm
Part NO.
Wire Range
Insulation O.D.
Material
Finish
Qty/reel
C3030F-TP-C
AWG#20-#24
1.85mm(max)
Phosphor Bronze
Tin over Nickel
10,000 PCS
C3030F-GP-C
AWG#20-#24
1.85mm(max)
Phosphor Bronze
Gold-flash
10,000 PCS
C-77
C3030 SERIES
C3030M-T
*Used in CJT C3030HM,HMA-XP,C3030HM,HMA,HMC-2xXP,
C3030HM-2xXP-A,C3030HMB-2xXP series Housing
C3030M-GP(-L) - ***
1
2
1.Part No.
2.Finish:
(blank): Gold-flash
G15: 15μin (0.38μm) MIN.Select Gold
G30: 30μin (0.76μm) MIN.Select Gold
0.90±0.20
0.20
Gold-flash
SEC:A-A
0.67±0.05
Part NO.
C3030M-TP
C3030M-GP
C3030M-TP-L
C3030M-GP-L
F±0.20
E±0.20
C±0.20
D±0.20
2.48±0.25
8.41±0.20
B
12.46±0.25
B
Select Gold Area
(Outsde Only)
A
2.07±0.20
A
SEC:B-B
0.67±0.05
Unit:mm
Material
Finish
Phosphor Bronze
Gold-flash
Phosphor Bronze
Gold-flash
C
2.54
2.54
2.10
2.10
D
2.30
2.30
1.90
1.90
E
2.08
2.08
1.65
1.65
F
1.90
1.90
1.46
1.46
Qty/reel
10,000 PCS
10,000 PCS
10,000 PCS
10,000 PCS
C-78
C3030 SERIES
C3030HF-XP
3.00mm Pitch Single Row Housing
*Material:Nylon 66,UL94V-0
*Suitable CJT C3030F-T-A(-L) series Terminal
*Mates with CJT C3030HM,HMA-XP series Housing or
C3030WV,WR-XP,C3030WV-S,WR-S-XP,C3030WV-F,WR-F-XP,
C3030WV-S-F,WR-S-F-XP series Single Row Wafer
*Color:Black
C3030HF-XP(-A) - ***
1
2
1.Part No.
2.Material:
(blank):Nylon 66,UL94V-0
GWT:Nylon 66,UL94V-0,GWT 750 ℃
Circuit 1
5.26±0.25
Circuit 1
3.00±0.10
3.00±0.10
A±0.20
8.20±0.25
Ordering Information & Dimensions:
B±0.25
6.80±0.25
2P
3P
4P
5P
6P
7P
8P
9P
10P
11P
12P
14.00±0.25
14.00±0.25
PART NO.
C3030HF-2P~12P
C3030HF-2P-A
C3030HM-XP
*Suitable CJT C3030M-T(-L) series Terminal
*Mates with CJT C3030HF-XP,C3030HF-2P-A
series Housing
*Color:Black
Circuit 1
Dimensions
A
B
3.00
6.80
6.00
9.80
9.00
12.80
12.00
15.80
15.00
18.80
18.00
21.80
21.00
24.80
24.00
27.80
27.00
30.80
30.00
33.80
33.00
36.80
Unit: mm
C3030HM-XP - ***
1
2
1.Part No.
2.Material:
3.00±0.10
A±0.20
3.90±0.25
B±0.25
2.54
16.89±0.25
PART NO.
5.25±0.25
2P
3P
4P
5P
6P
7P
8P
9P
10P
11P
12P
Dimensions
A
B
3.00
6.85
6.00
9.85
9.00
12.85
12.00
15.85
15.00
18.85
18.00
21.85
21.00
24.85
24.00
27.85
27.00
30.85
30.00
33.85
33.00
36.85
Unit: mm
C-79
C3030 SERIES
C3030HMA-XP
3.00mm pitch Single Row Housing
series Housing
*Color:Black
C3030HMA-XP - ***
1
2
1.Part No.
2.Material:
Circuit 1
3.00±0.10
A±0.20
3.90±0.25
B±0.25
PART NO.
16.89±0.25
2P
3P
4P
5P
6P
7P
8P
9P
10P
11P
12P
5.25±0.25
Dimensions
A
B
3.00
6.85
6.00
9.85
9.00
12.85
12.00
15.85
15.00
18.85
18.00
21.85
21.00
24.85
24.00
27.85
27.00
30.85
30.00
33.85
33.00
36.85
Unit: mm
C3030HF-2xXP
3.00mm pitch Dual Row Housing
6.96±0.25
3.00±0.10
Last Circuit
Circuit 1
Circuit 2
Circuit 1
3.00±0.10
6.85±0.25
6.90±0.25
14.10±±0.25
3.85±0.20
14.10±0.25
7.65±0.25
B±0.25
C3030HF-2x1P~2x12P
Mates with CJT C3030 series Housing or Wafer :
Housing C3030HM-2xXP,C3030HMA-2xXP,C3030HM-2xXP-A,C3030HMC-2xXP
C3030WV-2xXP,C3030WV-S-2xXP,C3030WV-F-2xXP
C3030WV-S-F-2xXP,C3030WR-2xXP,C3030WR-S-2xXP
C3030WR-F-2xXP,C3030WR-S-F-2xXP,C3030WVA-2xXP
Wafer
C3030WVA-S-2xXP,C3030WRA-F-2xXP,C3030WRA-F1-2xXP
C3030WRA-S-2xXP,C3030WRA-S-F-2xXP
C3030WRA-S-F1-2xXP,C3030WVC-2xXP
Circuit 2
3.00±0.10
3.00±0.10
A±0.20
C3030HF-2xXP(-A) - ***
1
2
1.Part No.
2.Material:
6.96±0.25
Circuit 1
Circuit 2
6.96±0.25
Last Circuit
3.00±0.10
*Suitable CJT C3030F-T-A(-L),
C3030F-T-C series Terminal
*Mates with CJT C3030HM series Housing
or C3030 series dual row Wafer
*Color:Black
C3030HF-2x1P~2x2P-A
PART NO.
2x1P
2x2P
2x3P
2x4P
2x5P
2x6P
2x7P
2x8P
2x9P
2x10P
2x11P
2x12P
Dimensions
A
B
---3.85
3.00
6.85
6.00
9.85
9.00
12.85
12.00
15.85
15.00
18.85
18.00
21.85
21.00
24.85
24.00
27.85
27.00
30.85
30.00
33.85
33.00
36.85
Unit: mm
C-80
C3030 SERIES
C3030HM-2xXP
*Mates with CJT C3030HF-2xXP,
C3030HF-2xXP-A series Housing
*Color:Black
Last Circuit
Circuit 1
Circuit 2
3.00±0.10
A±0.20
3.00±0.10
C3030HM-2xXP - ***
1
2
1.Part No.
2.Material:
6.90±0.25
B±0.25
3.56
PART NO.
17.10±0.25
2x1P
2x2P
2x3P
2x4P
2x5P
2x6P
2x7P
2x8P
2x9P
2x10P
2x11P
2x12P
8.25±0.25
Dimensions
A
B
---3.85
3.00
6.85
6.00
9.85
9.00
12.85
12.00
15.85
15.00
18.85
18.00
21.85
21.00
24.85
24.00
27.85
27.00
30.85
30.00
33.85
33.00
36.85
Unit: mm
C3030HM-2xXP-A
*Color:Black
Last Circuit
Circuit 1
Circuit 2
3.00±0.10
A±0.20
3.00±0.10
C3030HM-2xXP-A - ***
1
2
1.Part No.
2.Material:
6.90±0.25
B±0.25
3.56
17.10±0.25
PART NO.
8.25±0.25
2x1P
2x2P
2x3P
2x4P
2x5P
2x6P
2x7P
2x8P
2x9P
2x10P
2x11P
2x12P
Dimensions
A
B
---3.85
3.00
6.85
6.00
9.85
9.00
12.85
12.00
15.85
15.00
18.85
18.00
21.85
21.00
24.85
24.00
27.85
27.00
30.85
30.00
33.85
33.00
36.85
Unit: mm
C-81
C3030 SERIES
C3030HMA-2xXP
*Color:Black
Last Circuit
A±0.20
3.00±0.10
Circuit 1
Circuit 2
3.00±0.10
C3030HMA-2xXP - ***
1
2
1.Part No.
2.Material:
6.90±0.25
B±0.25
PART NO.
17.10±0.25
2x1P
2x2P
2x3P
2x4P
2x5P
2x6P
2x7P
2x8P
2x9P
2x10P
2x11P
2x12P
8.25±0.25
Dimensions
A
B
---3.85
3.00
6.85
6.00
9.85
9.00
12.85
12.00
15.85
15.00
18.85
18.00
21.85
21.00
24.85
24.00
27.85
27.00
30.85
30.00
33.85
33.00
36.85
Unit: mm
C3030HMC-2xXP
*Color:Black
A±0.20
Circuit 2
3.00±0.10
3.00±0.10
Circuit 1
B±0.25
B±0.25
C3030HMC-2xXP - ***
1
2
1.Part No.
2.Material:
Last Circuit
B±0.25
6.85±0.25
16.90±0.25
PART NO.
2x1P
2x2P
8.30±0.25
2x3P~2x12P
2x1P
2x2P
2x3P
2x4P
2x5P
2x6P
2x7P
2x8P
2x9P
2x10P
2x11P
2x12P
Dimensions
A
B
---3.85
3.00
6.85
6.00
9.85
9.00
12.85
12.00
15.85
15.00
18.85
18.00
21.85
21.00
24.85
24.00
27.85
27.00
30.85
30.00
33.85
33.00
36.85
Unit: mm
C-82
C3030 SERIES
C3030HFB-2xXP
C3030HFB-2xXP - ***
1
2
1.Part No.
2.Material:
*Suitable CJT C3030F-T-C series Terminal
*Mates with CJT C3030HMB-2xXP series Housing
or C3030WVB,WRB-2xXP Series Wafer
*Color:Black
4.52
R0.38
A±0.25
FACE
2.65
9.78±0.20
3.00±0.10
3.00±0.10
Last Circuit
PANEL
16.30±0.25
B±0.20
3.76
C±0.20
D±0.25
PANEL OPENING
RECOMMENDED PANEL THICKNESS
1.57/1.27
Circuit 1
Circuit 2
15.20±0.25
16.03±0.25
6.86±0.20
PART
NO.
2x2P
2x3P
2x4P
2x5P
2x6P
2x7P
2x8P
2x9P
2x10P
2x11P
2x12P
A
24.70
27.70
30.70
33.70
36.70
39.70
42.70
45.70
48.70
51.70
54.70
Dimensions
B
C
3.00
13.46
6.00
16.46
9.00
19.46
12.00
22.46
15.00
25.46
18.00
28.46
21.00
31.46
24.00
34.46
27.00
37.46
30.00
40.46
33.00
43.46
D
22.10
25.10
28.10
31.10
34.10
37.10
40.10
43.10
46.10
49.10
52.10
Unit: mm
C3030HMB-2xXP
C3030HMB-2xXP - ***
1
2
1.Part No.
2.Material:
*Mates with CJT C3030HFB-2xXP series Housing
or C3030HFWV,HFWR-2xXP Receptacle Header
*Color:Black
A±0.25
D±0.25
B±0.20
C±0.20
3.00±0.10
4.45
2.39
PANEL
17.13±0.25
13.34±0.20
16.20±0.25
3.00±0.10
Last Circuit
FACE
3.05
Circuit 2
Circuit 1
R0.38
R0.25
PANEL OPENING
1.57/1.27
19.10±0.25
19.86±0.25
PART
NO.
2x2P
2x3P
2x4P
2x5P
2x6P
2x7P
2x8P
2x9P
2x10P
2x11P
2x12P
A
22.84
25.84
28.84
31.84
34.84
37.84
40.84
43.84
46.84
49.84
52.84
Dimensions
B
C
3.00
14.85
6.00
17.85
9.00
20.85
12.00
23.85
15.00
26.85
18.00
29.85
21.00
32.85
24.00
35.85
27.00
38.85
30.00
41.85
33.00
44.85
D
20.85
23.85
26.85
29.85
32.85
35.85
38.85
41.85
44.85
47.85
50.85
Unit: mm
C-83
C3030 SERIES
C3030WV-XP
3.00mm pitch 180° Single Row Wafer
Optional Voided CKT
See Chart For Location
1.96±0.05
*Material:Pin:Brass/Tin over Nickel
Insulator:Nylon 66,UL94V-0
C3030HF-2P-A series Housing
*Color:Black
A±0.05
A±0.05
3.00±0.05
3.01±0.05
Ø1.02±0.05
Circuit 1
Ø1.02±0.05
3.00±0.05
Ø1.27±0.05
P.C.B LAYOUT
(Type 3)
P.C.B LAYOUT
(Type 1~Type 2)
4.37±0.25
4.37±0.25
4.37±0.25
3.20±0.20
3.20±0.20
11.00±0.25
PART NO.
1.10
B±0.25
3.20±0.20
Gold(G15,G30)
A±0.20
9.90±0.25
3.00±0.10
0.65 0.96
Type 1
PIN 0.64 SQ
C3030WV-XP - * - *** - ***
1
2 3
4
1.Part No.
2.Style:
(blank) :Type 1
2 :Type 2
3 :Type 3
3.Material:
LCP:LCP,UL94V-0
GWT:LCP,UL94V-0,GWT 750 ℃
4.Finish
(blank):Tin over Nickel
G:Gold-flash
Type 2
Type 3
2P
3P
4P
5P
6P
7P
8P
9P
10P
11P
12P
Dimensions
A
B
3.00
9.65
6.00
12.65
9.00
15.65
12.00
18.65
15.00
21.65
18.00
24.65
21.00
27.65
24.00
30.65
27.00
33.65
30.00
36.65
33.00
39.65
Unit: mm
C3030WR-XP
3.00mm pitch 90° Single Row Wafer
4.32±0.08
Optional Voided CKT
4.32±0.08
*Color:Black
3.00±0.05
3.00±0.05
Ø1.02±0.05
Ø1.02±0.05
Circuit 1
Ø3.00±0.05
3.00±0.10
Ø3.00±0.05
1.50±0.05
A±0.20
C3030WR-XP - *** - ***
1
2 3
1.Part No.
2.Material:
(blank):Nylon 66, UL94V-0
LCP:LCP,UL94V-0
3.Finish
G:Gold-flash
3P
2P
P.C.B LAYOUT
PIN 0.64 SQ
A±0.05
3.20±0.20
PART NO.
3.00±0.05
Ø1.02±0.05
Ø3.00±0.05
4.32±0.08
4.60±0.25
1.80
Gold(G15,G30)
4.37±0.25
9.80±0.25
B±0.20
2.15±0.05
4~12P
P.C.B LAYOUT
2P
3P
4P
5P
6P
7P
8P
9P
10P
11P
12P
Dimensions
A
B
3.00
9.65
6.00
12.65
9.00
15.65
12.00
18.65
15.00
21.65
18.00
24.65
21.00
27.65
24.00
30.65
27.00
33.65
30.00
36.65
33.00
39.65
Unit: mm
C-84
C3030 SERIES
C3030WV-F-XP
*Color:Black
A±0.10
A±0.20
Circuit 1
3.00±0.10
2.15±0.05
3.00±0.05
Ø1.02±0.05
Ø2.41±0.05
C3030WV-F-XP - *** - ***
1
2 3
1.Part No.
2.Material:
LCP:LCP,UL94V-0
GWT:LCP, UL94V-0,GWT 750 ℃
3.Finish
G:Gold-flash
4.37±0.25
B±0.25
PART NO.
2P
3P
4P
5P
6P
7P
8P
9P
10P
11P
12P
2.00
3.20±0.20
9.90±0.25
1.20
Gold(G15,G30)
P.C.B LAYOUT
Optional Voided CKT
PIN 0.64 SQ
Dimensions
A
B
3.00
9.65
6.00
12.65
9.00
15.65
12.00
18.65
15.00
21.65
18.00
24.65
21.00
27.65
24.00
30.65
27.00
33.65
30.00
36.65
33.00
39.65
Unit: mm
C3030WR-F-XP
*Color:Black
3.00±0.10
A±0.05
4.32±0.08
A±0.20
3.00±0.05
Ø1.02±0.05
2.15±0.05
Optional Voided CKT
Ø2.41±0.05
P.C.B LAYOUT
4.37±0.25
1.20
9.90±0.25
B±0.25
2.00±0.20
4.60±0.20
Gold(G15,G30)
Circuit 1
C3030WR-F-XP - *** - ***
1
2 3
1.Part No.
2.Material:
LCP:LCP,UL94V-0
3.Finish
G:Gold-flash
3.20±0.20
PART NO.
2P
3P
4P
5P
6P
7P
8P
9P
10P
11P
12P
Dimensions
A
B
3.00
9.65
6.00
12.65
9.00
15.65
12.00
18.65
15.00
21.65
18.00
24.65
21.00
27.65
24.00
30.65
27.00
33.65
30.00
36.65
33.00
39.65
Unit: mm
C-85
C3030 SERIES
C3030WV-S-XP
3.00mm pitch 180° Single Row Wafer-SMT TYPE
C3030WV-S-XP - *** - ***
1
2 3
1.Part No.
2.Material:
(blank):LCP,UL94V-0
3.Finish
G:Gold-flash
Insulator:LCP,UL94V-0
*Color:Black
A±0.10
A±0.20
3.00±0.10
2.54
2.15
4.10±0.25
3.00±0.10
Circuit 1
3.43
5.60±0.05
1.65
1.50
1.27
C±0.10
Optional Voided CKT
P.C.B LAYOUT
B±0.25
PART NO.
Gold(G15,G30)
4.37±0.25
2P
3P
4P
5P
6P
7P
8P
9P
10P
11P
12P
9.90±0.25
1.20
1.70
A
3.00
6.00
9.00
12.00
15.00
18.00
21.00
24.00
27.00
30.00
33.00
Dimensions
B
9.65
12.65
15.65
18.65
21.65
24.65
27.65
30.65
33.65
36.65
39.65
C
14.20
17.20
20.20
23.20
26.20
29.20
32.20
35.20
38.20
41.20
44.20
Unit: mm
C3030WR-S-XP
3.00mm pitch 90° Single Row Wafer-SMT TYPE
*Color:Black
C3030WR-S-XP - *** - ***
1
2
3
1.Part No.
2.Material:
(blank):LCP,UL94V-0
3.Finish
G:Gold-flash
A±0.10
3.00±0.10
Circuit 1
1.27
3.43
5.60±0.05
Optional Voided CKT
C±0.10
P.C.B LAYOUT
1.20
4.37±0.25
9.90±0.25
Gold(G15,G30)
1.70
1.50
B±0.25
1.65
6.93±0.10
3.00±0.10
2.92
A±0.20
PART NO.
2P
3P
4P
5P
6P
7P
8P
9P
10P
11P
12P
A
3.00
6.00
9.00
12.00
15.00
18.00
21.00
24.00
27.00
30.00
33.00
Dimensions
B
9.65
12.65
15.65
18.65
21.65
24.65
27.65
30.65
33.65
36.65
39.65
C
14.20
17.20
20.20
23.20
26.20
29.20
32.20
35.20
38.20
41.20
44.20
Unit: mm
C-86
C3030 SERIES
C3030WV-S-F-XP
*Color:Black
C3030WV-S-F-XP - *** - ***
1
2
3
1.Part No.
2.Material:
(blank):LCP,UL94V-0
3.Finish
G:Gold-flash
A±0.10
3.00±0.10
2.15
3.00±0.10
2.54
A±0.20
Circuit 1
1.27
Ø2.41±0.05
2.15±0.05
C±0.10
Optional Voided CKT
P.C.B LAYOUT
B±0.25
Gold(G15,G30)
4.37±0.25
PART NO.
2P
3P
4P
5P
6P
7P
8P
9P
10P
11P
12P
2.00
9.90±0.25
1.20
A
3.00
6.00
9.00
12.00
15.00
18.00
21.00
24.00
27.00
30.00
33.00
Dimensions
B
9.65
12.65
15.65
18.65
21.65
24.65
27.65
30.65
33.65
36.65
39.65
C
7.30
10.30
13.30
16.30
19.30
22.30
25.30
28.30
31.30
34.30
37.30
Unit: mm
C3030WR-S-F-XP
*Color:Black
C3030WR-S-F-XP - *** - **
1
2 3
1.Part No.
2.Material:
(blank):LCP,UL94V-0
3.Finish
G:Gold-flash
A±0.10
3.00±0.10
6.92±0.10
A±0.20
2.92
3.00±0.10
1.27
Ø2.41±0.05
2.15±0.05
C±0.10
Circuit 1
Optional Voided CKT
Gold(G15,G30)
P.C.B LAYOUT
4.37±0.25
1.20
2.00±0.20
4.60±0.20
9.90±0.25
B±0.25
0.64
PART NO.
2P
3P
4P
5P
6P
7P
8P
9P
10P
11P
12P
A
3.00
6.00
9.00
12.00
15.00
18.00
21.00
24.00
27.00
30.00
33.00
Dimensions
B
9.65
12.65
15.65
18.65
21.65
24.65
27.65
30.65
33.65
36.65
39.65
C
7.30
10.30
13.30
16.30
19.30
22.30
25.30
28.30
31.30
34.30
37.30
Unit: mm
C-87
C3030 SERIES
C3030WV-2xXP
3.00mm pitch 180° Dual Row Wafer
*Color:Black
3.00±0.10
PART NO.
3.20±0.25
1.10
Ø0.65
Type 1
PIN 0.64 SQ
C3030WR-2xXP
B±0.25
3.00±0.10
4.32±0.08
3.00±0.10
Ø1.02
Ø3.00
Unit: mm
C3030WR-2xXP - *** - ***
1
2
3
1.Part No.
2.Material:
LCP:LCP,UL94V-0
3.Finish
(blank) :Tin over Nickel
G:Gold-flash
3.00±0.10
Ø1.02
Ø3.00
1.50±0.05
2x1P
2x2P
2x3P
A±0.10
7.36±0.25
3.00±0.10
1.80
3.20±0.20
4.32±0.08
3.00±0.10
9.89±0.25
3.00±0.20
11.88±0.25
Ø1.02±0.05
PIN 0.64 SQ
PART NO.
P.C.B LAYOUT
4.60
A±0.20
3.00±0.10
Ø3.00
Gold(G15,G30)
3.00±0.10
4.32±0.08
3.00±0.10
4.32±0.08
6.85±0.25
Ø1.02
3.00±0.10
Circuit 2
Dimensions
A
B
---6.65
3.00
9.65
6.00
12.65
9.00
15.65
12.00
18.65
15.00
21.65
18.00
24.65
21.00
27.65
24.00
30.65
27.00
33.65
30.00
36.65
33.00
39.65
3.00mm pitch 90° Dual Row Wafer With Foot
Optional Voided CKT
Circuit 1
2x1P
2x2P
2x3P
2x4P
2x5P
2x6P
2x7P
2x8P
2x9P
2x10P
2x11P
2x12P
Type 2
*Color:Black
Last Circuit
7.36±0.25
3.20±0.25
7.36±0.25
A±0.10
P.C.B LAYOUT
(Type 1~Type 2)
9.90±0.25
Type 3
B±0.25
0.94±0.05
9.90±0.25
Gold(G15,G30)
A±0.20
3.20±0.25
6.85±0.25
Circuit 2
3.00±0.10
Circuit 1
3.00±0.10
3.00±0.10
7.36±0.25
Optional Voided CKT
Last Circuit
C3030WV-2xXP - * - *** - ***
1
2 3
4
1.Part No.
3.00±0.10
2.Style:
(blank) :Type 1
A±0.10
2 :Type 2
P.C.B LAYOUT
3.Material:
(Type 3)
LCP:LCP,UL94V-0
3.00±0.08 Ø1.02±0.05
4.Finish
G:Gold-flash
3.00±0.10
Ø1.02±0.05
Ø3.00±0.05
2.15±0.05
2x4~2x12P
P.C.B LAYOUT
2x1P
2x2P
2x3P
2x4P
2x5P
2x6P
2x7P
2x8P
2x9P
2x10P
2x11P
2x12P
Dimensions
A
B
---6.85
3.00
9.85
6.00
12.85
9.00
15.85
12.00
18.85
15.00
21.85
18.00
24.85
21.00
27.85
24.00
30.85
27.00
33.85
30.00
36.85
33.00
39.85
Unit: mm
C-88
C3030 SERIES
C3030WVC-2xXP
3.00mm pitch Dual Row 180° Compliant Pin Interface Wafer
C3030WVC-2xXP - *** - ***
1
2
3
1.Part No.
2.Material:
(blank):LCP,UL94V-0
3.Finish
G:Gold-flash
A
0.94±0.05
Ø1.02±0.10
0.94/1.07 DIA
FINESHED PLATED
HOLE
0.01 Max Tin Plate
Ø1.09±0.10
0.03 Min
ELECTRO-DEPOSITED
COPPER
3.00±0.10
A±0.10
P.C.B LAYOUT
Ø1.02±0.10
7.36±0.25
2x1P
2x2P
2x3P
2x4P
2x5P
2x6P
2x7P
2x8P
2x9P
2x10P
2x11P
2x12P
0.94±0.05
3.00±0.10
2x1P
P.C.B LAYOUT
Ø0.65
Dimensions
A
B
---6.65
3.00
9.65
6.00
12.65
9.00
15.65
12.00
18.65
15.00
21.65
18.00
24.65
21.00
27.65
24.00
30.65
27.00
33.65
30.00
36.65
33.00
39.65
PART NO.
Ø1.09±0.10
1.10
SEC:A-A
2x2P~2x12P
3.20±0.25
B±0.25
A
3.00±0.10
Circuit 2
3.00±0.08
3.00±0.10
Circuit 1
A±0.20
Gold-flash(G15,G30)
3.00±0.10
3.00±0.10
6.85±0.25
Optional Voided CKT
9.90±0.25
Last Circuit
1.09 DIA
DRILLED HOLE
2.36
*Color:Black
0.64
Unit: mm
C3030WV-S-2xXP
3.00mm pitch 180° Dual Row Wafer-SMT TYPE
*Color:Black
A±0.10
3.00±0.10
A±0.20
5.61±0.10
3.43±0.10
Circuit 2
Last Circuit
0.64
2.54
1.65±0.10
1.50
Circuit 1
1.27±0.10
C±0.10
P.C.B LAYOUT
Optional Voided CKT
1.40
1.70
7.37±0.25
9.91±0.25
B±0.25
11.25±0.25
Gold(G15,G30)
3.00±0.10
C3030WV-S-2xXP - *** - ***
1
2 3
1.Part No.
2.Material:
(blank):LCP,UL94V-0
3.Finish
G:Gold-flash
PART NO.
2x1P
2x2P
2x3P
2x4P
2x5P
2x6P
2x7P
2x8P
2x9P
2x10P
2x11P
2x12P
A
---3.00
6.00
9.00
12.00
15.00
18.00
21.00
24.00
27.00
30.00
33.00
Dimensions
B
6.65
9.65
12.65
15.65
18.65
21.65
24.65
27.65
30.65
33.65
36.65
39.65
C
11.20
14.20
17.20
20.20
23.20
26.20
29.20
32.20
35.20
38.20
41.20
44.20
Unit: mm
C-89
C3030 SERIES
C3030WR-S-2xXP
3.00mm pitch 90° Dual Row Wafer-SMT TYPE
11.56±0.10
3.43
P.C.B LAYOUT
Last Circuit
A±0.20
B±0.25
1.70
PART NO.
2x1P
2x2P
2x3P
2x4P
2x5P
2x6P
2x7P
2x8P
2x9P
2x10P
2x11P
2x12P
9.90±0.25
15.40±0.25
1.50
7.37±0.25
Gold(G15,G30)
3.00±0.10
C±0.10
1.65
1.27
5.60±0.05
3.00±0.10
3.00±0.10
2.92
Circuit 2
A±0.10
6.93±0.10
C3030WR-S-2xXP - *** - ***
1
2
3
1.Part No.
2.Material:
(blank):LCP,UL94V-0
3.Finish
Optional Voided CKT
G:Gold-flash
*Color:Black
Circuit 1
A
---3.00
6.00
9.00
12.00
15.00
18.00
21.00
24.00
27.00
30.00
33.00
Dimensions
B
6.65
9.65
12.65
15.65
18.65
21.65
24.65
27.65
30.65
33.65
36.65
39.65
C
11.20
14.20
17.20
20.20
23.20
26.20
29.20
32.20
35.20
38.20
41.20
44.20
Unit: mm
C3030WV-F-2xXP
3.00mm pitch 180° Dual Row Wafer With Foot
*Color:Black
C±0.10
Optional Voided CKT
2.15±0.05
1.50
Last Circuit
Circuit 2
3.00±0.10
A±0.10
P.C.B LAYOUT
B±0.25
3.20±0.25
2.00
9.90±0.25
7.36±0.25
PIN 0.64 SQ
Gold(G15,G30)
A±0.20
Ø2.41±0.05
3.00±0.10
Circuit 1
3.00±0.10
3.00±0.10
6.85±0.25
Ø1.02±0.05
C3030WV-F-2xXP - *** - ***
1
2 3
1.Part No.
2.Material:
LCP:LCP,UL94V-0
3.Finish
G:Gold-flash
PART NO.
2x1P
2x2P
2x3P
2x4P
2x5P
2x6P
2x7P
2x8P
2x9P
2x10P
2x11P
2x12P
A
---3.00
6.00
9.00
12.00
15.00
18.00
21.00
24.00
27.00
30.00
33.00
Dimensions
B
6.65
9.65
12.65
15.65
18.65
21.65
24.65
27.65
30.65
33.65
36.65
39.65
C
4.30
7.30
10.30
13.30
16.30
19.30
22.30
25.30
28.30
31.30
34.30
37.30
Unit: mm
C-90
C3030 SERIES
C3030WR-F-2xXP
*Color:Black
C3030WR-F-2xXP - *** - ***
1
2 3
1.Part No.
2.Material:
LCP:LCP,UL94V-0
3.Finish
G:Gold-flash
A±0.10
3.00±0.10
PIN 0.64 SQ
3.00
4.32±0.10
Circuit 2
Circuit 1
Ø1.02±0.05
Ø2.41±0.05
C±0.10
Optional Voided CKT
A±0.20
7.37±0.25
2.00
PART NO.
3.00±0.20
9.91±0.25
B±0.25
P.C.B LAYOUT
11.92±0.25
3.00±0.10
Gold(G15,G30)
Last Circuit
4.60±0.20
3.00±0.10
2.15±0.05
2x1P
2x2P
2x3P
2x4P
2x5P
2x6P
2x7P
2x8P
2x9P
2x10P
2x11P
2x12P
A
---3.00
6.00
9.00
12.00
15.00
18.00
21.00
24.00
27.00
30.00
33.00
Dimensions
B
6.65
9.65
12.65
15.65
18.65
21.65
24.65
27.65
30.65
33.65
36.65
39.65
C
4.30
7.30
10.30
13.30
16.30
19.30
22.30
25.30
28.30
31.30
34.30
37.30
Unit: mm
C3030WV-S-F-2xXP
*Color:Black
A±0.10
3.00±0.10
2.54
6.85
3.00±0.10
Circuit 1
3.43
A±0.20
Circuit 2
C3030WV-S-F-2xXP - *** - ***
1
2
3
1.Part No.
2.Material:
(blank):LCP,UL94V-0
3.Finish
G:Gold-flash
2.54
Ø2.41±0.05
2.15±0.05
1.27
C±0.10
Last Circuit
Optional Voided CKT
7.37±0.25
B±0.25
2.00
9.90±0.25
1.40
11.25±0.25
Gold(G15,G30)
0.64
P.C.B LAYOUT
PART NO.
2x1P
2x2P
2x3P
2x4P
2x5P
2x6P
2x7P
2x8P
2x9P
2x10P
2x11P
2x12P
A
---3.00
6.00
9.00
12.00
15.00
18.00
21.00
24.00
27.00
30.00
33.00
Dimensions
B
6.65
9.65
12.65
15.65
18.65
21.65
24.65
27.65
30.65
33.65
36.65
39.65
C
4.30
7.30
10.30
13.30
16.30
19.30
22.30
25.30
28.30
31.30
34.30
37.30
Unit: mm
C-91
C3030 SERIES
Unit: mm
C3030WR-S-F-2xXP
Optional Voided CKT
2.92
Circuit 2
A±0.10
3.00±0.10
6.92±0.10
Circuit 1
C3030WR-S-F-2xXP - *** - ***
1
2
3
1.Part No.
2.Material:
(blank):LCP,UL94V-0
3.Finish
G:Gold-flash
11.56±0.10
*Color:Black
1.27
Ø2.41±0.05
C±0.10
P.C.B LAYOUT
Last Circuit
A±0.20
2.00
7.37±0.25
9.91±0.25
15.40±0.25
PART NO.
2x1P
2x2P
2x3P
2x4P
2x5P
2x6P
2x7P
2x8P
2x9P
2x10P
2x11P
2x12P
4.60
B±0.25
0.64±0.05
C3030WR-S-F1-2xXP
C
4.30
7.30
10.30
13.30
16.30
19.30
22.30
25.30
28.30
31.30
34.30
37.30
C3030WR-S-F1-2xXP - *** - ***
1
2
3
1.Part No.
2.Material:
(blank):LCP,UL94V-0
3.Finish
G:Gold-flash
A±0.10
3.00
1.50
3.00
2.92
Circuit 2
Dimensions
B
6.65
9.65
12.65
15.65
18.65
21.65
24.65
27.65
30.65
33.65
36.65
39.65
Unit: mm
11.56±0.10
Circuit 1
3.00±0.05
*Color:Black
A
---3.00
6.00
9.00
12.00
15.00
18.00
21.00
24.00
27.00
30.00
33.00
6.92±0.10
3.00±0.10
Gold(G15,G30)
3.00±0.10
2.15±0.05
2.15±0.05
2x1P
2x2P
1.27
Ø3.00±0.05
C±0.10
2x3P
Optional Voided CKT
7.36±0.25
3.20±0.20
PART NO.
1.35
9.90±0.25
15.90±0.25
9.90±0.25
B±0.25
4.60
Last Circuit
A±0.20
0.64±0.05
6.00±0.25
3.00±0.05
Gold(G15,G30)
P.C.B LAYOUT
(2x4P~2x12P)
2x1P
2x2P
2x3P
2x4P
2x5P
2x6P
2x7P
2x8P
2x9P
2x10P
2x11P
2x12P
A
---3.00
6.00
9.00
12.00
15.00
18.00
21.00
24.00
27.00
30.00
33.00
Dimensions
B
6.65
9.65
12.65
15.65
18.65
21.65
24.65
27.65
30.65
33.65
36.65
39.65
C
4.30
7.30
10.30
13.30
16.30
19.30
22.30
25.30
28.30
31.30
34.30
37.30
Unit: mm
C-92
C3030 SERIES
C3030WVA-2xXP
A±0.20
Optional Voided CKT
A±0.10
3.00 3.00
3.00±0.10
0.94
3.00
Last Circuit
Circuit 2
Circuit 1
3.00±0.10
Ø1.02
P.C.B LAYOUT
7.36±0.25
B±0.25
Type 1
Dimensions
A
B
---6.70
3.00
9.70
6.00
12.70
9.00
15.70
12.00
18.70
15.00
21.70
18.00
24.70
21.00
27.70
24.00
30.70
27.00
33.70
30.00
36.70
33.00
39.70
PART NO.
3.20±0.20
1.40
Gold(G15,G30)
3.20±0.20
9.90±0.25
∅0.65
7.36±0.25
1.40
1.10
PIN 0.64 SQ
C3030WVA-2xXP - * - *** - ***
1
2 3
4
1.Part No.
2.Style:
(blank): Type 1
3: Type 3
3.Material:
4.Finish:
G:Gold-flash
9.90±0.25
*Color:Black
Type 3
2x1P
2x2P
2x3P
2x4P
2x5P
2x6P
2x7P
2x8P
2x9P
2x10P
2x11P
2x12P
Unit: mm
C3030WVA-S-2xXP
3.00mm pitch 180° Dual Row Wafer - SMT TYPE
*Color:Black
A±0.10
3.00
Optional Voided CKT
3.43
Last Circuit
1.65
3.00±0.10
2.54
1.27
A±0.20
C3030WVA-S-2xXP - *** - ***
1
2
3
1.Part No.
2.Material:
(blank):LCP,UL94V-0
3.Finish
G:Gold-flash
Gold-flash(G15,G30)
5.61
B±0.25
1.70
PART NO.
7.36±0.25
1.40
0.70
C
P.C.B LAYOUT
11.40±0.20
9.90±0.25
Circuit 1
Circuit 2
3.00±0.10
1.50
3.43
2x1P
2x2P
2x3P
2x4P
2x5P
2x6P
2x7P
2x8P
2x9P
2x10P
2x11P
2x12P
A
---3.00
6.00
9.00
12.00
15.00
18.00
21.00
24.00
27.00
30.00
33.00
Dimensions
B
6.70
9.70
12.70
15.70
18.70
21.70
24.70
27.70
30.70
33.70
36.70
39.70
C
6.60
6.60
6.60
6.60
6.60
6.60
6.60
12.00
12.00
12.00
12.00
12.00
Unit: mm
C-93
C3030 SERIES
C3030WVA-F-2xXP
*Color:Black
C3030WVA-F-2xXP - *** - ***
1
2
3
1.Part No.
2.Material:
(blank):LCP,UL94V-0
3.Finish
G:Gold-flash
A±0.20
A
3.00±0.10
3.00±0.10
Last Circuit
2.15
3.00
Ø2.41
Circuit 2
Circuit 1
Ø1.02
P.C.B LAYOUT
1.40
PIN 0.64 SQ
C3030WVA-S-F-2xXP
2x1P
2x2P
2x3P
2x4P
2x5P
2x6P
2x7P
2x8P
2x9P
2x10P
2x11P
2x12P
Unit: mm
*Color:Black
A±0.10
3.00
3.43
Optional Voided CKT
1.27
2.54
2.15
A±0.20
3.00±0.10
Last Circuit
Gold-flash(G15,G30)
7.36±0.25
11.40±0.20
PART NO.
9.90±0.25
1.40
0.70
C
C3030WVA-S-F-2xXP - *** - ***
1
2 3
1.Part No.
2.Material:
(blank):LCP,UL94V-0
3.Finish
G:Gold-flash
P.C.B LAYOUT
3.10
B±0.25
Circuit 1
3.00±0.10
Ø2.41
Circuit 2
Dimensions
A
B
---6.70
3.00
9.70
6.00
12.70
9.00
15.70
12.00
18.70
15.00
21.70
18.00
24.70
21.00
27.70
24.00
30.70
27.00
33.70
30.00
36.70
33.00
39.70
PART NO.
Gold-flash(G15,G30)
3.10
9.90±0.25
7.36±0.25
3.20±0.20
B±0.25
2x1P
2x2P
2x3P
2x4P
2x5P
2x6P
2x7P
2x8P
2x9P
2x10P
2x11P
2x12P
A
---3.00
6.00
9.00
12.00
15.00
18.00
21.00
24.00
27.00
30.00
33.00
Dimensions
B
6.70
9.70
12.70
15.70
18.70
21.70
24.70
27.70
30.70
33.70
36.70
39.70
C
6.60
6.60
6.60
6.60
6.60
6.60
6.60
12.00
12.00
12.00
12.00
12.00
Unit: mm
C-94
C3030 SERIES
C3030WRA-F-2xXP
*Color:Black
C±0.10
A±0.10
A±0.20
3.0±0.05
3.00±0.05
2.15
P.C.B LAYOUT
3.10
B±0.25
Ø1.02
7.36±0.25
2x1P
2x2P
2x3P
2x4P
2x5P
2x6P
2x7P
2x8P
2x9P
2x10P
2x11P
2x12P
4.60
3.00±0.10
1.40
9.90±0.25
PART NO.
Gold(G15,G30)
Optional Voided CKT
Circuit 1
Circuit 2
Ø2.41
3.00±0.05
3.00±0.05
4.32±0.05
Last Circuit
3.20±0.20
PIN 0.64 SQ
C3030WRA-F-2xXP - *** - ***
1
2
3
1.Part No.
2.Material:
3.Finish
G:Gold-flash
A
---3.00
6.00
9.00
12.00
15.00
18.00
21.00
24.00
27.00
30.00
33.00
Dimensions
B
6.65
9.65
12.65
15.65
18.65
21.65
24.65
27.65
30.65
33.65
36.65
39.65
C
4.30
7.30
10.30
13.30
16.30
19.30
22.30
25.30
28.30
31.30
34.30
37.30
Unit: mm
C3030WRA-F1-2xXP
Optional Voided CKT
3.00±0.10
2x4P~2x12P
Circuit 1
Circuit 2
1.80
3.00±0.10
9.90±0.25
Ø1.02
2.15±0.05
Ø3.00
2x1P~2x3P
C±0.25
PIN 0.64 SQ
3.00±0.05
P.C.B LAYOUT
2x4P~2x12P
7.36±0.25
1.40
PART NO.
A
3.00
4.60
Last Circuit
3.00±0.10
A±0.20
Gold(G15,G30)
B±0.30
A±0.10
4.30±0.05
C3030WRA-F1-2xXP - *** - ***
1
2
3
1.Part No.
2.Material:
3.Finish
G:Gold-flash
*Color:Black
3.00±0.05
3.20±0.20
P.C.B LAYOUT
2x1P~2x3P
2x1P
2x2P
2x3P
2x4P
2x5P
2x6P
2x7P
2x8P
2x9P
2x10P
2x11P
2x12P
A
---3.00
6.00
9.00
12.00
15.00
18.00
21.00
24.00
27.00
30.00
33.00
Dimensions
B
6.65
9.65
12.65
15.65
18.65
21.65
24.65
27.65
30.65
33.65
36.65
39.65
C
2.90
2.90
2.90
7.60
10.60
13.60
16.60
19.60
22.60
25.60
28.60
31.60
Unit: mm
C-95
C3030 SERIES
C3030WRA-S-2xXP
3.00mm pitch 90° Dual Row Wafer - SMT TYPE
*Color:Black
2.92±0.05
A±0.10
0.64±0.05
1.70±0.10
3.00±0.05
11.56
1.65±0.05
0.90
1.27±0.05
3.43
5.61
C3030WRA-S-2xXP - *** - ***
1
2
3
1.Part No.
2.Material:
(blank):LCP,UL94V-0
3.Finish
G:Gold-flash
P.C.B LAYOUT
PART NO.
Last Circuit
3.00±0.10
A±0.20
3.00±0.10
1.70
Gold(G15,G30)
1.35
Circuit 1
Optional Voided CKT
2x1P
2x2P
2x3P
2x4P
2x5P
2x6P
2x7P
2x8P
2x9P
2x10P
2x11P
2x12P
9.90±0.25
1.40
7.36±0.25
B±0.30
6.00±0.20
Circuit 2
Dimensions
A
B
---6.70
3.00
9.70
6.00
12.70
9.00
15.70
12.00
18.70
15.00
21.70
18.00
24.70
21.00
27.70
24.00
30.70
27.00
33.70
30.00
36.70
33.00
39.70
Unit: mm
C3030WRA-S-F-2xXP
*Color:Black
11.56
1.27±0.05
1.70±0.10
3.00±0.05
2.92±0.05
A±0.10
0.64±0.05
C3030WRA-S-F-2xXP - *** - ***
1
2
3
1.Part No.
2.Material:
(blank):LCP,UL94V-0
3.Finish
G:Gold-flash
2.15
Ø2.41
P.C.B LAYOUT
PART NO.
B±0.30
9.90±0.25
7.36±0.25
Gold(G15,G30)
1.35
2.14
Optional Voided CKT
Circuit 1
Circuit 2
3.10
3.00±0.10
Last Circuit
1.40
A±0.20
3.00±0.10
4.60
6.00±0.20
2x1P
2x2P
2x3P
2x4P
2x5P
2x6P
2x7P
2x8P
2x9P
2x10P
2x11P
2x12P
Dimensions
A
B
---6.70
3.00
9.70
6.00
12.70
9.00
15.70
12.00
18.70
15.00
21.70
18.00
24.70
21.00
27.70
24.00
30.70
27.00
33.70
30.00
36.70
33.00
39.70
Unit: mm
C-96
C3030 SERIES
C3030WRA-S-F1-2xXP
0.64±0.05
2.92±0.05
A±0.10
3.00±0.05
1.27±0.05
11.56
C3030WRA-S-F1-2xXP - *** - ***
1
2
3
1.Part No.
2.Material:
(blank):LCP,UL94V-0
3.Finish
G:Gold-flash
*Color:Black
1.70±0.10
2.15
3.00±0.05
Ø3.00
P.C.B LAYOUT
(2x4P~2x12P)
Ø3.00
2x1P~2x3P
A±0.20
3.00±0.10
9.90±0.25
Gold-flash(G15,G30)
1.35
Circuit 1
3.20
3.00±0.10
Last Circuit
1.40
7.36±0.25
B±0.30
Circuit 2
2x4P~2x12P
6.00±0.20
4.60
Dimensions
A
B
---6.70
3.00
9.70
6.00
12.70
9.00
15.70
12.00
18.70
15.00
21.70
18.00
24.70
21.00
27.70
24.00
30.70
27.00
33.70
30.00
36.70
33.00
39.70
PART NO.
P.C.B LAYOUT
(2x1P~2x3P)
2x1P
2x2P
2x3P
2x4P
2x5P
2x6P
2x7P
2x8P
2x9P
2x10P
2x11P
2x12P
Unit: mm
C3030HFWV-2xXP
3.00mm pitch Dual Row Receptacle Header
3.00±0.10
*Material:LCP,UL94V-0
*Color:Black
3.00±0.05
Circuit 1
Circuit 2
3.00
Ø2.36±0.05
3.00±0.10
P.C.B LAYOUT
6.25±0.20
6.50±0.25
A±0.20
3.00±0.10
Ø1.02±0.05
C3030HFWV-2xXP - *** - ***
1
2 3
1.Part No.
2.Material:
(blank):LCP,UL94V-0
3.Finish:
G:Gold-flash
B±0.25
8.40±0.25
2x3~2x12P
2x2P
13.60±0.25
3.40±0.20
2.25 Max
Gold(G15,G30)
C±0.25
6.50±0.25
2.30±0.20
PART NO.
2x2P
2x3P
2x4P
2x5P
2x6P
2x7P
2x8P
2x9P
2x10P
2x11P
2x12P
A
3.00
6.00
9.00
12.00
15.00
18.00
21.00
24.00
27.00
30.00
33.00
Dimensions
B
12.00
15.00
18.00
21.00
24.00
27.00
30.00
33.00
36.00
39.00
42.00
C
9.00
12.00
15.00
18.00
21.00
24.00
27.00
30.00
33.00
36.00
39.00
Unit: mm
C-97
C3030 SERIES
C3030HFWR-2xXP
Ø1.02±0.05
Ø1.02±0.05
1.50±0.05
C±0.10
1.50±0.05
2x4~2x12P
21.00±0.25
2x2P
2x3P
2x4P
2x5P
2x6P
2x7P
2x8P
2x9P
2x10P
2x11P
2x12P
10.20±0.25
3.95±0.20
14.50±0.25
0.25
Terminal
positioning strip
2.29
A±0.20
5.00
3.05
3.00±0.10
2x4~2x12P
A
3.00
6.00
9.00
12.00
15.00
18.00
21.00
24.00
27.00
30.00
33.00
3.05±0.08
3.00±0.10
Dimensions
B
6.70
9.70
12.70
15.70
18.70
21.70
24.70
27.70
30.70
33.70
36.70
C
------6.00
9.00
12.00
15.00
18.00
21.00
24.00
27.00
30.00
Unit: mm
C3030WVB-2xXP
3.00mm pitch Dual Row 180° Wafer
Insulator:LCP,UL94-V0
*Mates with CJT C3030HFB-2xXP Series Housing
*Color:Black
C3030WVB-2xXP - *** - ***
1
2 3
1.Part No.
2.Material:
(blank):LCP,UL94V-0
3.Finish:
G:Gold-flash
Optional Voided CKT
Last Circuit
4.50±0.08
A±0.20
Ø1.02±0.05
3.00±0.10
Circuit 2
P.C.B LAYOUT
11.90±0.25
11.60±0.25
3.30±0.20
B±0.30
PIN 0.64 SQ
1.45±0.08
Circuit 1
3.00±0.10
3.00±0.10
Ø1.57±0.05
Gold(G15,G30)
3.00±0.10
2x2P
PART NO.
Circuit 1
Circuit 2
3.00±0.10
Ø1.02±0.05
2x3P
Gold(G15,G30)
4.44±0.20
3.00±0.10
B±0.25
3.00±0.10
Ø2.36±0.05
P.C.B LAYOUT
C3030HFWR-2xXP - *** - ***
1
2
3
1.Part No.
2.Material:
(blank):LCP,UL94V-0
GWT:LCP,UL94V-0,GWT 750°C
3.Finish:
G:Gold-flash
Ordering
2x2P
2x3P
A±0.10
3.05±0.08
3.00±0.10
3.00±0.10
A±0.10
3.00±0.10
3.05±0.08
*Color:Black
3.00±0.10
PART NO.
2x2P
2x3P
2x4P
2x5P
2x6P
2x7P
2x8P
2x9P
2x10P
2x11P
2x12P
Dimensions
A
B
3.00
13.00
6.00
16.00
9.00
19.00
12.00
22.00
15.00
25.00
18.00
28.00
21.00
31.00
24.00
34.00
27.00
37.00
30.00
40.00
33.00
43.00
Unit: mm
C-98
C3030 SERIES
C3030WRB-2xXP
3.00mm pitch Dual Row 90° Wafer
C3030WRB-2xXP - *** - ***
1
2
3
1.Part No.
2.Material:
(blank):LCP,UL94V-0
3.Finish
G:Gold-flash
Terminal positioning strip:Mylar(Natural)
*Color:Black
Circuit 2
3.35
3.50±0.20
3.00±0.10
Gold(G15,G30)
Circuit 1
Circuit 2
3.00±0.10
A±0.20
B±0.25
6.10
14.43±0.20
Ø1.02±0.05
6.00±0.20
2x2P
7.11±0.20
5.60±0.20
7.11±0.20
2x3P
5.60±0.20
Terminal
positioning
strip
8.53±0.08
Terminal
positioning
strip
3.00±0.10
8.53±0.08
11.60±0.25
11.60±0.25
3.00±0.10
3.00±0.10
B±0.25
A±0.10
9.00±0.20
3.00±0.10
3.00±0.10
3.00±0.10
3.00±0.10
11.90±0.25
Circuit 1
Last Circuit
11.90±0.25
Optional Voided CKT
Last Circuit
Ø1.02±0.05
2x3P
2x2P
P.C.B LAYOUT
Circuit 2
3.50±0.20
6.10
14.43±0.20
A±0.20
3.00±0.10
3.00±0.10
3.00±0.10
3.35
11.90±0.25
Circuit 1
3.00±0.10
Optional Voided CKT
Gold(G15,G30)
Last Circuit
A±0.10
B±0.25
3.00±0.10
Terminal
positioning
strip
Ø1.02±0.05
8.53±0.08
11.60±0.25
2.16±0.05
7.11±0.20
2x4~2x12P
5.60±0.20
C±0.10
12.00±0.20
2x4~2x12P
P.C.B LAYOUT
PART NO.
2x2P
2x3P
2x4P
2x5P
2x6P
2x7P
2x8P
2x9P
2x10P
2x11P
2x12P
A
3.00
6.00
9.00
12.00
15.00
18.00
21.00
24.00
27.00
30.00
33.00
Dimensions
B
13.00
16.00
19.00
22.00
25.00
28.00
31.00
34.00
37.00
40.00
43.00
C
------4.68
7.68
10.68
13.68
16.68
19.68
22.68
25.68
28.68
Unit: mm
C-99
