GD8000
GD8000
    MICROINFINITY
    MODULE_32X32MM
    IMU运动传感器 32.0 x 32.0 Accelerometer, Gyroscope, 6 Axis 5~16V
GD8000 数据手册
Prepared by Checked by Approved by SPECIFICATION Customer Item CruizCore® GD8000 Description DR/GNSS MODULE Customer P/N Received by 20 . . Checked by 20 . . Copyright  Microinfinity Co., Ltd. http://www.minfinity.com Contact Info. EMAIL: support@minfinity.com, TEL: +82 31 546 7408 FAX: +82 31 546 7409 Approved by 20 . . CruizCore® GD8000 SPECIFICATION Contents 1. Functional Description ..............................................................................................................................3 1.1. Overview ............................................................................................................................................3 1.2. Block diagram ....................................................................................................................................3 1.3. Features.............................................................................................................................................4 1.4. System start-up ..................................................................................................................................4 1.5. Installation ..........................................................................................................................................5 2. Mechanical specification ...........................................................................................................................7 2.1. Outline drawing ..................................................................................................................................7 2.2. Specification .......................................................................................................................................7 3. Interface Specification ...............................................................................................................................8 3.1. Pin Configuration................................................................................................................................8 3.2. Pin Definition ......................................................................................................................................8 3.3. Speed & direction operation ...............................................................................................................9 4. Electrical and Physical Specification .......................................................................................................12 5. Performance Specification ......................................................................................................................13 6. Important Information ..............................................................................................................................14 2 CruizCore® GD8000 SPECIFICATION 1. Functional Description 1.1. Overview CruizCore®GD8000是DR / GNSS信号处理模块,可提供持续精确的导航 严酷的GNSS环境中的信息。该产品需要外部里程表和后退 用于DR / GNSS操作的信号(或通过RS-232C的速度信息)。该产品保证连续 位置报告甚至所有GNSS信号都被遮挡。在许多城市驾驶的情况下,高层建筑和 狭窄的街道掩盖了大部分或全部GNSS信号。这些城市峡谷也会降低其能见度 GNSS通过反射或多路径发出信号。在城市峡谷条件下,该产品具有 拒绝降级的信号条件。 GD8000提高了定位精度和可用性 航位推算功能。它通过联邦卡尔曼滤波器优化汽车的位置信息 方法。里程表,陀螺仪和加速度计的测量结果集成在产品中 与GNSS导航信息。里程表,陀螺仪和加速度计的测量是 与GNSS导航信息集成,提供更准确的位置估计 独立系统。该产品将在地图上报告地图辅助DR / GNSS导航解决方案 帮助消息从地图软件输入GD8000。 1.2. Block diagram Figure 1 Functional diagram. 3 CruizCore® GD8000 SPECIFICATION 1.3. Features           包含一个6轴MEMS惯性传感器 (3轴陀螺仪/ 3轴加速度计) 快速启动 低功耗 可靠性高 完全自我维持 直接连接里程表和后向信号 包括GNSS接收器(GPS / GLONASS /北斗) 连续位置和航向输出 RS-232C数字输出 1.4. System start-up Table 1 Start-up mode Start-up modes Description *DR cold start 在冷启动期间,系统需要稳定时间,这可能需要大约10分钟(GNSS修复和超过 40km / h的速度驾驶条件) DR warm start 设置参数后,DR / GNSS将以热启动模式启动。 * 在稳定时间期间,DR / GNSS的性能主要基于GNSS,一旦确定了参数,DR / GNSS将所有传感器 数据组合到估计位置。 4 CruizCore® GD8000 SPECIFICATION 1.5. Installation Mounting in the Vehicle GD8000 must be mounted securely in the vehicle so that it cannot move. Mounted angle of GD8000 is allowed within ±30deg. For the best performance of GD8000, zero mounted angle is recommended. Pay careful attention to the forward direction when installing the product. Figure 2 CruizCore® GD8000 coordinates system 5 CruizCore® GD8000 SPECIFICATION Data Output The CruizCore® DR/GNSS provides both integrated information and NMEA-0183 (Version 2.20) as defined by the National Marine Electronics Association. Microinfinity can provide customized formats as an option. The CruizCore® DR/GNSS communicates with external devices using a serial RS232 interface with following parameters. Table 2 Serial Default Setting Baud Rate per second 115,200 Data bits 8 Stop bits 1 Parity Check No The GD8000 provides information to external devices using NMEA like messages. Table 3 NMEA Message NMEA Record Function Description GPDRH Microinfinity DR data Transmit from CruizeCore® GPGGA Global positioning system fixed data Transmit from GNSS GPRMC Recommend minimum specific data Transmit from GNSS --GSV GNSS satellites in view Transmit from GNSS --GSA GNSS DOP and active satellites Transmit from GNSS All messages are NMEA compatible 6 CruizCore® GD8000 SPECIFICATION 2. Mechanical specification 2.1. Outline drawing Unit: millimeter Figure 3 Dimensions 2.2. Specification Table 4 Mechanical specification Parameter Specification Tolerance Length 32 ±0.2 Width 32 ±0.2 Height 9.5 ±0.5 Comment Unit : millimeter 7 CruizCore® GD8000 SPECIFICATION 3. Interface Specification 3.1. Pin Configuration Figure 4 Pin configuration of connectors *Connector : TFM-105-01-1-D-WT (SAMTEC) *Mates :SFSD(T)-05-xx-x-xx.xx-SR (SAMTEC) 3.2. Pin Definition Table 5 Pin definition of connector No Pin Name I/O Description 1 B+ - Battery power 2 GND - Ground 3 BOOT I Switch to Boot mode (Normal mode: Low) 4 ACC - Accessory power 5 PPS O GNSS 1PPS signal 6 TXA O Serial port (RS-232 TX) 7 RXA I Serial port (RS-232 RX) 8 SPEED I Odometer pulse signal input 9 DIRECTION I Backward signal input (Backward : high) 10 nRESET I System reset (Active low) 8 CruizCore® GD8000 SPECIFICATION 3.3. Antenna Configuration Table 6 Antenna Input Parameter Specification Type Active Antenna Connector MMCX1) MALE Frequency band 2) GPS L1 / GLONASS G1 / BeiDou B1 Antenna power 3.3V < 50mA at 25〬C Impedance 50 Ω 1) GD8000 antenna Connector : MMCX-J-P-H-ST-EM1 (SAMTEC) 2) GNSS combination : GPS + GLONASS or GPS + BeiDou 9 CruizCore® GD8000 SPECIFICATION 3.4. Speed & direction operation GD8000可以使用“命令模式”或“里程表脉冲模式”运行。 当同时执行串行输入和脉冲输入时,它以“命令模式”运行,并忽略脉冲。 至少有一个有效数据,它 在“命令模式”下运行。 一旦检测到模式,它将一直保持到发动机停止。 因此,如果在操作期间交替执行命令和脉冲输入,则可能会发生故障。 ■ Command mode Name Type Value Units STX unsigned char 0xAF Start of Packet MSG unsigned char 0x20 Message Type LEN unsigned char 0x03 Length of DATA INDEX unsigned char 0 ~ 255 Index of Packet SPEED unsigned short int (Byte order : Little endian) 0.01 Km/h Description Speed information Ex) 12345 = 123.45Km Backward Direction, DIR_BACK CS unsigned char 0x00 : Forward, 0x01 : Backward Exclusive-OR(XOR) of all the bytes in the message between the MSG and DIR_BACK. unsigned char The initial value of CS is 0x00. ETX unsigned char 0xEF End of Packet Input frequency : 50Hz (minimum 10 Hz required) 10 CruizCore® GD8000 SPECIFICATION ■ Odometer Pulse mode Table 7 Odometer, Backward signal example GD8000 Input Signal Odometer Backward Signal 11 CruizCore® GD8000 SPECIFICATION 4. Electrical and Physical Specification Table 8 Recommended operating conditions VALUE PARAMETER CONDITION UNIT Min. Supply voltage (B+/ACC) Absolute Maximum Rating -0.3 Operating 5 12 Max. 18 V 16 V 12 Recommended POWER Typ. V Run, Current (IDD) 15 Ta = 25°C, 25 mA 0.9 V B+ = 12V Input “L” Pins for communication (BOOT/PPS) Input “H” V Output “L” Output “H” Input / Output 1.8 0.6 2.4 V V 0.6 Input “L” V nRST Input “H” Car Info (SPEED /DIRECTION) OUTPUT RATE Operating Temperature 1.8 V Input “L” 1.0 V Input “H” 3.0 12 16 V Adjustable 1 5 10 Hz +85 °C -40 12 CruizCore® GD8000 SPECIFICATION 5. Performance Specification Table 9 DR/GNSS performance specification. Parameter Specification DR only
GD8000 价格&库存
很抱歉,暂时无法提供与“GD8000”相匹配的价格&库存,您可以联系我们找货
