MC3410-I5
MC3410-I5
    MCUBE
    SEN_2X2MM_SM
    ±2g/±4g/±8g HBM=±2000V ILU=100mA
MC3410-I5 数据手册
MC3410 3-Axis Accelerometer Preliminary Datasheet GENERAL DESCRIPTION FEATURES The MC3410 is a low-noise, integrated digital output 3-axis accelerometer with a feature set optimized for cell phones and consumer product motion sensing. Applications include user interface control, gaming motion input, electronic compass tilt compensation for cell phones, game controllers, remote controls and portable media products. Range, Sampling & Power      ‒ From 8 to 512 Hz bandwidth 150 μA typical active current Event Detection  Accurate event detection is enabled with a low noise architecture that minimizes false triggering found in competing devices. Low noise and low power are inherent in the monolithic fabrication approach, where the MEMS accelerometer is integrated in a single-chip with the electronics integrated circuit. ± 2g / ± 4g / ± 8g ranges 10-bit or 14-bit resolution 1024 samples/sec Programmable low pass filter    Low-noise architecture minimizes false triggering Tap, Shake, Drop Portrait or landscape orientation with programmable hysteresis Tilt detection in six orientations Simple System Integration    I2C interface, up to 400 kHz 2 × 2 × 0.92 mm 12-pin package ‒ Pin-compatible to Bosch BMA2xx Single-chip 3D silicon MEMS In the MC3410 the internal sample rate is fixed at 1024 samples / second. Specific orientation and gesture conditions can trigger an interrupt to a remote MCU. Alternatively, the device supports the reading of sample and event status via polling. mCube Proprietary and Confidential. © 2013 mCube Inc. All rights reserved. APS-048-0010v1.8 1 / 75 MC3410 3-Axis Accelerometer Preliminary Datasheet TABLE OF CONTENTS 1 Order Information............................................................................................................. 5 2 Functional Block Diagram ................................................................................................ 6 3 Packaging and Pin Description ........................................................................................ 7 3.1 Package Outline ................................................................................................................... 7 3.2 Pin Description ..................................................................................................................... 8 3.3 Typical Application Circuit .................................................................................................... 9 3.4 Tape and Reel ................................................................................................................... 10 4 Specifications................................................................................................................. 12 4.1 Absolute Maximum Ratings ................................................................................................ 12 4.2 Sensor Characteristics ....................................................................................................... 13 4.3 Electrical and Timing Characteristics.................................................................................. 14 4.3.1 Electrical Power and Internal Characteristics ....................................................... 14 4.3.2 I2C Electrical Characteristics ............................................................................... 15 4.3.3 I2C Timing Characteristics ................................................................................... 16 5 General Operation ......................................................................................................... 17 5.1 Sensor Sampling ................................................................................................................ 17 5.2 Offset and Gain Calibration ................................................................................................ 18 6 Operational States ......................................................................................................... 19 7 Operational State Flow .................................................................................................. 20 8 Interrupts........................................................................................................................ 21 8.1 Enabling and Clearing Interrupts ........................................................................................ 21 8.2 Interrupt Support ................................................................................................................ 22 8.3 GINT Interrupt .................................................................................................................... 23 8.4 Event Detection .................................................................................................................. 24 9 Orientation Detection ..................................................................................................... 25 9.1 Orientation Hysteresis ........................................................................................................ 25 9.2 Portrait/Landscape Events ................................................................................................. 25 9.3 Front/Back Events .............................................................................................................. 30 9.4 Shake Detection ................................................................................................................. 32 mCube Proprietary and Confidential. © 2013 mCube Inc. All rights reserved. APS-048-0010v1.8 2 / 75 MC3410 3-Axis Accelerometer Preliminary Datasheet 9.5 Drop Detection ................................................................................................................... 34 9.6 Tap Detection ..................................................................................................................... 35 9.7 Continuous Sampling ......................................................................................................... 37 10 I2C Interface .................................................................................................................. 38 10.1 Physical Interface ............................................................................................................... 38 10.2 Timing ................................................................................................................................ 38 10.3 I2C Message Format .......................................................................................................... 38 11 Register Interface .......................................................................................................... 40 11.1 Register Summary ............................................................................................................. 41 11.2 TILT: Status Register ......................................................................................................... 43 11.3 OPSTAT: Operational State Status Register ...................................................................... 45 11.4 INTEN: Interrupt Enable Register ....................................................................................... 46 11.5 MODE: Register ................................................................................................................. 47 11.6 TAPEN: Tap Detection Enable Register ............................................................................. 48 11.7 TAPP: Tap Pulse Register ................................................................................................. 49 11.8 DROP: Drop Event Control Register .................................................................................. 50 11.9 SHDB: Shake Debounce Register ...................................................................................... 51 11.10 XOUT_EX, YOUT_EX & ZOUT_EX: X, Y, Z-Axis Extended Accelerometer Registers ....... 52 11.11 CHIPID: Chip Identification Register................................................................................... 53 11.12 OUTCFG: Output Configuration Register ........................................................................... 54 11.13 X-Axis Offset Registers ...................................................................................................... 55 11.14 Y-Axis Offset Registers ...................................................................................................... 56 11.15 Z-Axis Offset Registers ...................................................................................................... 57 11.16 X-Axis Gain Registers ........................................................................................................ 58 11.17 Y-Axis Gain Registers ........................................................................................................ 59 11.18 Z-Axis Gain Registers ........................................................................................................ 60 11.19 SHAKE_TH: Shake Threshold Register ............................................................................. 61 11.20 UD_Z_TH: Up/Down Z Axis Threshold Register ................................................................. 62 11.21 UD_X_TH: Up/Down X Axis Threshold Register ................................................................ 63 11.22 RL_Z_TH: Right/Left Z Axis Threshold Register ................................................................. 64 11.23 RL_Y_TH: Right/Left Y Axis Threshold Register ................................................................ 65 11.24 FB_Z_TH: Front/Back Z Axis Threshold Register ............................................................... 66 11.25 DROP_TH: Drop Threshold Register ................................................................................. 67 11.26 TAP_TH: Tap Threshold Register ...................................................................................... 68 mCube Proprietary and Confidential. © 2013 mCube Inc. All rights reserved. APS-048-0010v1.8 3 / 75 MC3410 3-Axis Accelerometer 11.27 12 12.1 Preliminary Datasheet PCODE: Product Code....................................................................................................... 69 Example MC3410 Configuration .................................................................................... 70 Example: Shake, Tap & Drop thresholds Demo ................................................................. 70 13 Index of Tables .............................................................................................................. 72 14 Revision History ............................................................................................................. 74 15 Legal .............................................................................................................................. 75 mCube Proprietary and Confidential. © 2013 mCube Inc. All rights reserved. APS-048-0010v1.8 4 / 75 MC3410 3-Axis Accelerometer Preliminary Datasheet 1 ORDER INFORMATION Part Number Resolution Order Number Package Shipping MC3410 10 or 14-bit MC3410-I5 VLGA-12 Tape & Reel, 5Ku Table 1. Order Information mCube Proprietary and Confidential. © 2013 mCube Inc. All rights reserved. APS-048-0010v1.8 5 / 75 MC3410 3-Axis Accelerometer Preliminary Datasheet 2 FUNCTIONAL BLOCK DIAGRAM AVDD Oscillator/ Clock Generator Bias Generator Regulator Sensors DVDD X C to V A/D Converter (Sigma Delta) Offset/ Gain Adjust A/D Converter (Sigma Delta) Offset/ Gain Adjust Orientation and Detection Logic Interrupt Detection Y C to V Range, Resolution C to V A/D Converter (Sigma Delta) Offset/ Gain Adjust SCL I2C Slave Interface SDA 10-bit Z INTN Various events X,Y,Z data paths GND TEST Mode Logic XOUT_EX, YOUT_EX, ZOUT_EX Registers (64 x 8) 14-bit LPF[2:0] OTP Memory VPP Figure 1. Block Diagram mCube Proprietary and Confidential. © 2013 mCube Inc. All rights reserved. APS-048-0010v1.8 6 / 75 MC3410 3-Axis Accelerometer Preliminary Datasheet 3 PACKAGING AND PIN DESCRIPTION 0.10 3.1 PACKAGE OUTLINE D 12 A 11 1 10 2 9 3 8 4 7 E INDEX AREA 0.10 6 // TOP VIEW 0.08 SIDE VIEW 0.10 5 b e1 DIMENSION (MM) L1 5 6 7 b 4 8 e 3 9 1 10 L1 L 2 12 11 BOTTOM VIEW NOM. MAX. 0.85 0.92 1.00 D 2.00 BSC E 2.00 BSC e 0.5 BSC e1 0.5125 REF b 0.20 0.25 0.30 L1 0.05 0.10 0.15 L 0.225 0.275 0.325 0.10 PIN 1 MARK C MIN. A C 0.10 L SYMBOL Figure 2. Package Outline and Mechanical Dimensions NOTE: Additional packaging information and device orientation can be found in Section 11.2 TILT: Status Register. mCube Proprietary and Confidential. © 2013 mCube Inc. All rights reserved. APS-048-0010v1.8 7 / 75 MC3410 3-Axis Accelerometer Preliminary Datasheet 3.2 PIN DESCRIPTION Pin Name Function 1 NC No connect 2 SDA 1 I2C serial data input/output 3 DVDD I/O power supply 4 NC No connect 5 INTN 2 6 VPP Connect to GND 7 AVDD Analog power supply 8 NC No Connect 9 GND Ground 10 TEST Optional probe pin 11 NC No connect 12 SCL 1 I2C serial clock input Interrupt active LOW 3 Table 2. Pin Description Notes: 1) This pin requires a pull-up resistor, typically 4.7kΩ to DVDD. Refer to I2C Specification for Fast-Mode devices. Higher resistance values can be used (typically done to reduce current leakage) but such applications are outside the scope of this datasheet. 2) This pin can be configured by software to operate either as an open-drain output or push-pull output (MODE: Register). If set to open-drain, then it requires a pull-up resistor, typically 4.7kΩ to DVDD. 3) INTN pin polarity is programmable in the MODE: Register. mCube Proprietary and Confidential. © 2013 mCube Inc. All rights reserved. APS-048-0010v1.8 8 / 75 MC3410 3-Axis Accelerometer Preliminary Datasheet 3.3 TYPICAL APPLICATION CIRCUIT } To Fast-Mode I2C circuitry1 SCL NC From interface power supply Place cap close to DVDD and GND on PCB NC TEST SDA GND DVDD 0.1µF NC NC AVDD 0.1µF INTN From lower-noise power supply VPP Place cap close to AVDD and GND on PCB (optional) To MCU interrupt input2 NOTE1: Attach typical 4.7kΩ pullup resistors to DVDD, per I2C specification. When DVDD is powered down, SDA and SCL will be driven low by internal ESD diodes. NOTE2: Attach typical 4.7kΩ pullup resistor if INTN is defined as open-drain. Figure 3. Typical Application Circuit In typical applications, the interface power supply may contain significant noise from external sources and other circuits which should be kept away from the sensor. Therefore, for some applications a lower-noise power supply might be desirable to power the AVDD pin. mCube Proprietary and Confidential. © 2013 mCube Inc. All rights reserved. APS-048-0010v1.8 9 / 75 MC3410 3-Axis Accelerometer Preliminary Datasheet 3.4 TAPE AND REEL Devices are shipped in reels, in standard cardboard box packaging. See Figure 4. MC3410 Tape Dimensions and Figure 5. MC3410 Reel Dimensions.  Dimensions in mm.  10 sprocket hole pitch cumulative tolerance ±0.2  Pocket position relative to sprocket hole measured as true position of pocket, not pocket hole. Figure 4. MC3410 Tape Dimensions mCube Proprietary and Confidential. © 2013 mCube Inc. All rights reserved. APS-048-0010v1.8 10 / 75 MC3410 3-Axis Accelerometer  Preliminary Datasheet Dimensions in mm. Figure 5. MC3410 Reel Dimensions mCube Proprietary and Confidential. © 2013 mCube Inc. All rights reserved. APS-048-0010v1.8 11 / 75 MC3410 3-Axis Accelerometer Preliminary Datasheet 4 SPECIFICATIONS 4.1 ABSOLUTE MAXIMUM RATINGS Parameters exceeding the Absolute Maximum Ratings may permanently damage the device. Minimum / Maximum Value Unit Rating Symbol Supply Voltages Pins DVDD and AVDD -0.3 / +3.6 V Acceleration, any axis, 100 µs g MAX 10000 g Ambient operating temperature TOP -40 / +85 ⁰C Storage temperature TSTG -40 / +125 ⁰C ESD human body model HBM ± 2000 V Latch-up current at Top = 25 ⁰C ILU 100 mA Input voltage to non-power pin Pins INTN, SCL and SDA -0.3 / (DVDD + 0.3) or 3.6 whichever is lower V Table 3. Absolute Maximum Ratings mCube Proprietary and Confidential. © 2013 mCube Inc. All rights reserved. APS-048-0010v1.8 12 / 75 MC3410 3-Axis Accelerometer Preliminary Datasheet 4.2 SENSOR CHARACTERISTICS DVDD, AVDD = 2.8V, Top = 25 ⁰C unless otherwise noted Parameter Conditions Acceleration range Resolution and range set in OUTCFG: Output Configuration Register Min Typ Max Unit ±2.0 ±4.0 g ±8.0 Sensitivity S10 (±2.0g 10-bit resolution) 2 S10 (±4.0g 10-bit resolution) 2 S10 (±8.0g 10-bit resolution) 2 S14 (±8.0g 14-bit resolution) 2 256 128 64 1024 LSB/g Sensitivity Temperature Coefficient 1 -40 ≤ Top ≤ +85 ⁰C ± 0.02 %/⁰C ± 100 mg ±1 mg/⁰C 200 μg/√Hz 1 % FS 1 % Zero-g Offset Zero-g Offset Temperature Coefficient 1 Noise Density 1 -40 ≤ Top ≤ +85 ⁰C Nonlinearity 1 Cross-axis Sensitivity 1 Between any two axes Table 4. Sensor Characteristics 1 Values are based on device characterization, not tested in production. 2 The best resolution is realized with the 8Hz bandwidth setting. mCube Proprietary and Confidential. © 2013 mCube Inc. All rights reserved. APS-048-0010v1.8 13 / 75 MC3410 3-Axis Accelerometer Preliminary Datasheet 4.3 ELECTRICAL AND TIMING CHARACTERISTICS 4.3.1 ELECTRICAL POW ER AND INTERNAL CHARACTERISTICS Parameter Conditions Symbol Min Supply voltage 2 AVDD I/O voltage 2 Sample Rate Tolerance 3 Typ Max Unit 2.0 3.6 V DVDD 1.7 3.6 V Tclock -5 5 % Max Unit Test condition: AVDD = DVDD = 2.8V, Top = 25 ⁰C unless otherwise noted Parameter Conditions Symbol Min AVDD=2.0V Standby current 1.6 AVDD=2.8V Idd0 Pad Leakage μA 1.8 AVDD=3.6V WAKE state supply current Typ 2.0 I dd1024 Per I/O pad I pad μA 150 -1 0.01 1 μA Table 5. Electrical Characteristics 2 Min and Max limits are hard limits without additional tolerance. 3 Values are based on device characterization, not tested in production. mCube Proprietary and Confidential. © 2013 mCube Inc. All rights reserved. APS-048-0010v1.8 14 / 75 MC3410 3-Axis Accelerometer Preliminary Datasheet 4.3.2 I2C ELECTRICAL CHARACTERISTICS Parameter Symbol Min Max Unit LOW level input voltage VIL -0.5 0.3*DVDD V HIGH level input voltage VIH 0.7*DVDD - V Hysteresis of Schmitt trigger inputs Vhys 0.05*DVDD - V Output voltage, pin INTN, Iol ≤ 2 mA Vol 0 0.4 V Voh 0 0.9*DVDD V Vols - 0.1*DVDD V Ii -10 10 µA Ci - 10 pF Output voltage, pin SDA (open drain), Iol ≤ 1 mA Input current, pins SDA and SCL (input voltage between 0.1*DVDD and 0.9*DVDD max) Capacitance, pins SDA and SCL 4 Table 6. I2C Electrical and Timing Characteristics NOTES:    4 If multiple slaves are connected to the I2C signals in addition to this device, only 1 pullup resistor on each of SDA and SCL should exist. Also, care must be taken to not violate the I2C specification for capacitive loading. When DVDD is not powered and set to 0V, INTN, SDA and SCL will be held to DVDD plus the forward voltage of the internal static protection diodes, typically about 0.6V. When DVDD is disconnected from power or ground (e.g. Hi-Z), the device may become inadvertently powered up through the ESD diodes present on other powered signals. Values are based on device characterization, not tested in production. mCube Proprietary and Confidential. © 2013 mCube Inc. All rights reserved. APS-048-0010v1.8 15 / 75 MC3410 3-Axis Accelerometer Preliminary Datasheet 4.3.3 I2C TIMING CHARACTERISTICS Figure 6. I2C Interface Timing Standard Mode Parameter Description fSCL Fast Mode Min Max Min Max SCL clock frequency 0 100 0 400 kHz tHD; STA Hold time (repeated) START condition 4.0 - 0.6 - μs tLOW LOW period of the SCL clock 4.7 - 1.3 - μs tHIGH 4.0 - 0.6 - μs 4.7 - 0.6 - μs tHD;DAT HIGH period of the SCL clock Set-up time for a repeated START condition Data hold time 5.0 - - - μs tSU;DAT Data set-up time 250 - 100 - ns tSU;STO Set-up time for STOP condition 4.0 - 0.6 - μs tBUF Bus free time between a STOP and START 4.7 tSU;STA - 1.3 - Units μs Table 7. I2C Timing Characteristics NOTE: Values are based on I2C Specification requirements, not tested in production. See also Section 10.3 I2C Message Format. mCube Proprietary and Confidential. © 2013 mCube Inc. All rights reserved. APS-048-0010v1.8 16 / 75 MC3410 3-Axis Accelerometer Preliminary Datasheet 5 GENERAL OPERATION The internal sampling rate range is fixed at 1024 samples per second. The resulting sensor readings appear as either 10-bit or 14-bit values, depending upon the selection chosen. 5.1 SENSOR SAMPLING Measurement data is stored in the “extended” registers XOUT_EX, YOUT_EX, and ZOUT_EX. The byte with the lower address of the byte pair is the least significant byte while the byte with the next higher address is the most significant byte. The 10-bit or 14-bit measurement is represented as 2’s complement format. 10-bit samples occupy bits [9:0], with bits [15:9] occupied by the sign bit. 14-bit samples occupy bits [13:0], with bits [15:13] occupied by the sign bit. The desired resolution and full scale acceleration range of ± 2g, ± 4g or ± 8g are set in OUTCFG: Output Configuration Register. The device sample rate is fixed at 1024 samples/second. The features Tap, Shake, Drop and Orientation detection are available. Resolution Range Value per bit (mg/LSB) 10-bit ± 2g ~3.9 10-bit ± 4g ~7.8 10-bit ± 8g ~15.6 Acceleration 14-bit ± 8g ~0.98 Full Scale Negative Reading Full Scale Positive Reading 0xFE00 0x01FF (-512) (+511) Comments Signed, 2’s complement number, results in registers XOUT_EX_L, XOUT_EX_H YOUT_EX_L, YOUT_EX_H ZOUT_EX_L, ZOUT_EX_H (Sign-extended. Integer interpretation also shown) 0xE000 0x1FFF (-8192) (+8191) Signed, 2’s complement number, results in registers XOUT_EX_L, XOUT_EX_H YOUT_EX_L, YOUT_EX_H ZOUT_EX_L, ZOUT_EX_H (Sign-extended. Integer interpretation also shown) Table 8. Summary of Resolution, Range, and Scaling Based upon the intended application, filtering of the data samples may be desired. The device has several low-pass filter (LPF) options for the raw sample data, intended to filter out mCube Proprietary and Confidential. © 2013 mCube Inc. All rights reserved. APS-048-0010v1.8 17 / 75 MC3410 3-Axis Accelerometer Preliminary Datasheet undesired high frequency components. Related to this LPF setting is the GINT interrupt rate, which can be modified to occur based upon the LPF roll-off frequency, rather than the sample rate (fixed at 1024 samples / second). See Section 8.2 GINT Interrupt for more on this option. The cutoff points for the LPF can be set from 8Hz to 512 Hz. These, and the controls for the GINT rate, are described in Section 11.12 OUTCFG: Output Configuration Register. 5.2 OFFSET AND GAIN CALIBRATION Digital offset and gain calibration can be performed on the sensor, if necessary, in order to reduce the effects of post-assembly influences and stresses which may cause the sensor readings to be offset from their factory values. The register controls are described in Sections 11.13 through 11.18. mCube Proprietary and Confidential. © 2013 mCube Inc. All rights reserved. APS-048-0010v1.8 18 / 75 MC3410 3-Axis Accelerometer Preliminary Datasheet 6 OPERATIONAL STATES The device has two states of operation: STANDBY (the default state after power-up), and WAKE. The STANDBY state offers the lowest power consumption. In this state, the I2C interface is active and all register reads and writes are allowed. There is no event detection, sampling, or acceleration measurement in the STANDBY state. Internal clocking is halted. Complete access to the register set is allowed in this state, but interrupts cannot be serviced. The device defaults to the STANDBY state following power-up. The time to change states from STANDBY to WAKE is less than 10uSec and does not depend upon the sample rate. Registers can be written (and therefore resolution, range. thresholds and other settings changed) only when the device is in STANDBY state. The I2C interface allows write access to all registers only in the STANDBY state. In WAKE state, the only I2C register write access permitted is to the MODE: Register. Full read access is allowed in all states. State I2C Bus Description STANDBY Device responds to I2C bus (R/W) Device is powered; Registers can be accessed via I2C. Lowest power state. No interrupt generation, internal clocking disabled. Default power-on state. WAKE Device responds to I2C bus (Read) Continuous sampling and reading of sense data. All registers except the MODE: Register are read-only. Table 9. Operational States mCube Proprietary and Confidential. © 2013 mCube Inc. All rights reserved. APS-048-0010v1.8 19 / 75 MC3410 3-Axis Accelerometer Preliminary Datasheet 7 OPERATIONAL STATE FLOW Figure 7. Operational State Flow shows the operational state flow for the device. The device defaults to STANDBY following power-on. WAKE OPCON=11 OPCON=01 STANDBY Figure 7. Operational State Flow The operational state may be forced to a specific state by writing into the OPCON bits, as shown below. Two bits are specified in order to promote software compatibility with other mCube devices. The operational state will stay in the mode specified until changed: Action Setting Force Wake State OPCON[1:0] = 01 Force Standby State OPCON[1:0] = 11     Effect Switch to WAKE state and stay there Continuous sampling Switch to STANDBY state and stay there Disable sensor and event sampling Table 10. Forcing Operational States mCube Proprietary and Confidential. © 2013 mCube Inc. All rights reserved. APS-048-0010v1.8 20 / 75 MC3410 3-Axis Accelerometer Preliminary Datasheet 8 INTERRUPTS The sensor device utilizes output pin INTN to signal to an external microprocessor that an event has been sensed. The microprocessor would contain an interrupt service routine which would perform certain tasks after receiving this interrupt and reading the associated status bits, perhaps after the product was put into a certain orientation or had been tapped. The microprocessor would set up the registers in the sensor so that when a specific event is detected, the microprocessor would receive the interrupt and the interrupt service routine would be executed. For products that will instead use polling, the method of reading sensor data would be slightly different. Instead of receiving an interrupt when an event occurs, the microprocessor must periodically poll the sensor and read status data while the INTN pin is not used. For most applications this is likely best done at the sensor sampling rate or faster. Note that at least one I2C STOP condition must be present between samples in order for the sensor to update the sample data registers. In this case, the event detection bits (TAPD, SHAKED, DROPD) and associated interrupt enable bits in the TILT: Status Register must still be set up as if interrupts would occur in order for the status registers to be updated with proper data. Although the INTN is not connected, the registers in the sensor will still contain valid status and so can be used by software to know the orientation of the product or if an event has occurred. 8.1 ENABLING AND CLEARING INTERRUPTS The INTEN: Interrupt Enable Register determines which events generate interrupts. When an event is detected, it is masked with an interrupt enable bit in this register and the corresponding status bit is set in the TILT: Status Register. Multiple interrupt events might be reported at the same time in the TILT: Status Register, so software must interpret and prioritize the results. The pin INTN is cleared during the next I2C bus cycle after the device ID has been recognized by the device. When an interrupt is triggered, the first I2C read access to the device clears INTN pin. The condition (TAPD, SHAKED, DROPD) that generated the interrupt will remain held in the TILT: Status Register until it is read. Note that the orientation bit-fields POLA and BAFR are continuously updated (every sample) in the TILT: Status Register and are not held. Note that multiple interrupts may be active at the same time, and so a software routine reading the TILT: Status Register should account for this. mCube Proprietary and Confidential. © 2013 mCube Inc. All rights reserved. APS-048-0010v1.8 21 / 75 MC3410 3-Axis Accelerometer Preliminary Datasheet Any of the following interrupts can be enabled or disabled in the INTEN: Interrupt Enable Register and DROP: Drop Event Control Register. ‒ Front/Back Interrupt ‒ Up/Down/Left/Right (portrait / landscape) Interrupt ‒ Tap Detection Interrupt ‒ GINT (real-time motion tracking, generate interrupt each sample period) ‒ Shake on X-axis, Shake on Y-axis, and Shake on Z-axis ‒ Drop event detection The INTEN: Interrupt Enable Register contains many of the interrupt enable bits. The drop interrupt enable bit DINT is located in the DROP: Drop Event Control Register. 8.2 INTERRUPT SUPPORT The following table shows the relationship between motion events and interrupt enable bits for determining when the device will generate an interrupt. No measurements or interrupts are generated in the STANDBY state. Motion Event Portrait/Landscape or Front/Back orientation change Interrupt Enable Bits FBINT = 1 PLINT = 1 SHINTX = 1 Shake SHINTY = 1 SHINTZ = 1 Tap TINT = 1 Drop DINT = 1 Sample Update GINT = 1 Table 11. Interrupt Support mCube Proprietary and Confidential. © 2013 mCube Inc. All rights reserved. APS-048-0010v1.8 22 / 75 MC3410 3-Axis Accelerometer Preliminary Datasheet 8.3 GINT INTERRUPT The GINT interrupt can trigger on each sample period (default), or be “filtered” by the bandwidth setting of the LPF. If the OUTCFG: Output Configuration Register IRATE bit is inactive, then the GINT interrupt will trigger each sample period. If the IRATE bit is active, the GINT interrupt rate will be updated based on the low-pass filter setting controlled by bit-field LPF. mCube Proprietary and Confidential. © 2013 mCube Inc. All rights reserved. APS-048-0010v1.8 23 / 75 MC3410 3-Axis Accelerometer Preliminary Datasheet 8.4 EVENT DETECTION The detection logic monitors and compares sensor outputs against the comparisons selected by the application software. Each type of event can be masked by a separate bit in the INTEN: Interrupt Enable Register. The following table shows how the detection events are evaluated. Event X Axis Up Y Axis Z Axis |Z| < (UD_Z_TH) and |X| > (UD_X_TH) and X (UD_X_TH) and X>0 1 Right |Z| < (RL_Z_TH) and |Y| > (RL_Y_TH) and Y (RL_Y_TH) and Y>0 2 3 Front Z > FB_Z_TH Back Z < -1 * FB_Z_TH SHAKED DROPD TAPD 6 4 5 3 |X| > 1.3g ± SHAKE_TH |Y| > 1.3g ± SHAKE_TH |Z| > 1.3g ± SHAKE_TH |X| < 0.5g ± DROP_TH |Y| < 0.5g ± DROP_TH |Z| < 0.5g ± DROP_TH |X| > TAP_TH |Y| > TAP_TH |Z| > TAP_TH Table 12. Detection Logic Event Evaluation 1 Up/Down Z threshold is programmable from 0.425g to 1.172g, up/down X threshold is programmable from |X| to |X| + 0.747g. 2 Right/left Z threshold is programmable from 0.425g to 1.172g, right/left Y threshold is programmable from |Y| to |Y| + 0.747g. 3 Front/back Z threshold is programmable from 0.174g to 0.547g. 4 SHAKED event is triggered when any axis > SHAKE_TH, programmable from 0.925g to 1.1672g. 5 DROPD event is triggered when condition (a) |X| + |Y| + |Z| < 0.5g + DROP_TH or condition (b) |X| < 0.5g ± DROP_TH and |Y| < 0.5g ± DROP_TH and |Z| < 0.5g ± DROP_TH, this is user selectable. The range is from 0.125g to 0.872g. 6 TAPD event is triggered by |X| > TAP_TH or |Y| > TAP_TH g or |Z| > TAP_TH, where TAP_TH is programmable and any combination of X, Y, and Z may be selected. mCube Proprietary and Confidential. © 2013 mCube Inc. All rights reserved. APS-048-0010v1.8 24 / 75 MC3410 3-Axis Accelerometer Preliminary Datasheet 9 ORIENTATION DETECTION The MC3410 allows an application to determine the orientation of the device. The current orientation of the device is reported as Left, Right, Up, Down, Front, and Back for each sampling period. This information generates the Portrait/Landscape status bits in the TILT: Status Register. 9.1 ORIENTATION HYSTERESIS Hysteresis can be added to portrait/landscape and front/back detection by modifying the default threshold offset values. See the specific sections below for more information. 9.2 PORTRAIT/LANDSCAPE EVENTS Portrait/landscape detection is a combination of left, right, up, and down events, also partially dependent upon Z sensor readings. The default comparison angle for portrait/landscape is 45 degrees when evaluating differences between LEFT, RIGHT, UP, and DOWN, as long as the magnitude of Z is < 0.8g (default). See Figure 8. By increasing the threshold values written to the UD_X_TH: Up/Down X Axis Threshold and RL_Y_TH: Right/Left Y Axis Threshold, hysteresis can be introduced to the angle of evaluation. These registers add a small offset to the default X and Y values and introduce additional margin in the portrait/landscape detection logic. For most applications, the same value should be written to both registers. When the device orientation is in the hysteresis region, the device will report orientation as “unknown”. When this reading is reported, in order to implement a hysteresis effect for orientation, high-level software should use the last known portrait/landscape information. In the example shown in Figure 9 the evaluation angle has been decreased to 40 degrees in each threshold, such that there is a 10 degree “deadband” or hysteresis-area between LEFT/RIGHT and DOWN/UP areas. The circle represents the acceleration in the Z axis, which has a default of 0.8g, or about a 33 degree tilt relative to the Z axis. mCube Proprietary and Confidential. © 2013 mCube Inc. All rights reserved. APS-048-0010v1.8 25 / 75 MC3410 3-Axis Accelerometer Default UD_Z_TH ≈ 33º (Up/Down Arc radius) Preliminary Datasheet Default UD_X_TH ≈ 45º POLA = UP -X Default UD_Z_TH ≈ 33º (Up/Down Arc radius) UD_X_TH ≈ 40º POLA = UP Hysteresis ≈ 10º -X Default RL_Y_TH ≈ 45º RL_Y_TH ≈ 40º POLA = LEFT +Y POLA = UNKNOWN in shaded region Default RL_Z_TH ≈ 33º (Left/Right Arc radius) -Y +X POLA = DOWN Figure 8. Default Orientation Settings POLA = RIGHT POLA = LEFT +Y POLA = UNKNOWN in shaded regions Default RL_Z_TH ≈ 33º (Left/Right Arc radius) -Y POLA = RIGHT +X POLA = DOWN Figure 9. Example Simple Orientation Hysteresis = 10 degrees The Z threshold for each direction can also be adjusted, as shown in Figure 10. This has the effect of altering the angle relative to the Z axis which causes the orientation state to change. Figure 11 shows an example of setting the UD_Z_TH and RL_Z_TH registers to different values, as well as setting the UD_X_TH and RL_Y_TH registers to different values. However for most applications the same value should be written to both registers in both cases. mCube Proprietary and Confidential. © 2013 mCube Inc. All rights reserved. APS-048-0010v1.8 26 / 75 MC3410 3-Axis Accelerometer UD_Z_TH ≈ max (1º) (Up/Down Arc radius) Preliminary Datasheet UD_Z_TH ≈ 59º (Up/Down Arc radius) UD_X_TH ≈ 40º POLA = UP POLA = UP -X Hysteresis ≈ 10º UD_X_TH ≈ 13º Hysteresis ≈ 49º -X POLA = UNKNOWN in shaded regions RL_Y_TH ≈ 40º RL_Y_TH ≈ 28º POLA = LEFT +Y -Y POLA = RIGHT POLA = LEFT RL_Z_TH ≈ max (1º) (Left/Right Arc radius) POLA = DOWN -Y POLA = RIGHT RL_Z_TH ≈ 1º (Left/Right Arc radius) in N W O ns KN io N g U re = ed LA had PO s +X +Y +X POLA = DOWN Figure 10. Effect of Changing UD_Z_TH Threshold with Hysteresis = 10 degrees Figure 11. Example of Complex Thresholds for Up/Down X, Right/Left Y, Up/Down Z & Right/Left Z Table 13 summarizes the portrait/landscape event evaluation criteria. Some example threshold values and the corresponding trip angle and amount of hysteresis are shown in Table 14. Event Up X Axis Y Axis Z Axis |Z| < (UD_Z_TH) and |X| > (UD_X_TH) and X (UD_X_TH) and X>0 Right |Z| < (RL_Z_TH) and |Y| > (RL_Y_TH) and Y (RL_Y_TH) and Y>0 Table 13. Portrait/Landscape Event Evaluation Criteria mCube Proprietary and Confidential. © 2013 mCube Inc. All rights reserved. APS-048-0010v1.8 27 / 75 MC3410 3-Axis Accelerometer Registers UD_X_TH or RL_Y_TH Threshold Value Preliminary Datasheet Resulting Hysteresis (approx. degrees) Corresponding g Value (approximate) Trip Angle (approx. degrees) 0x00 45 0 0.72 0x10 43 4 0.68 0x20 41 8 0.66 0x30 39 12 0.63 0x40 37 16 0.61 0x50 36 20 0.58 0x60 34 24 0.55 … … … … 0xFF 15 64 0.26 Table 14. Some Approximate X and Y-axis Portrait/Landscape Evaluation Angles and Values Registers UD_Z_TH or RL_Z_TH Trip Angle Corresponding (approx. degrees) g Value (approximate) 0x80 67 0.43 0x90 64 0.47 … … … 0xE0 48 0.71 0xF0 45 0.75 0x00 40 0.80 0x10 36 0.85 0x20 32 0.89 … … … 0x70 9 1.13 0x7F 3 Max (~1.17)* Threshold Value Table 15. Some Approximate Z-axis Portrait/Landscape Evaluation Angles and Values NOTE*: Max values >1.0g are possible, to cover offset variations. Table 16 shows the orientation event conditions for the portrait/landscape detection hardware. mCube Proprietary and Confidential. © 2013 mCube Inc. All rights reserved. APS-048-0010v1.8 28 / 75 MC3410 3-Axis Accelerometer Preliminary Datasheet POLA[2:0] Left Right Down Up Description/Comments 000 0 0 0 0 Unknown 001 1 0 0 0 Left/landscape 010 0 1 0 0 Right/landscape 101 0 0 1 0 Down/portrait 110 0 0 0 1 Up/portrait Table 16. Portrait/Landscape TILT: Status Register Assignments mCube Proprietary and Confidential. © 2013 mCube Inc. All rights reserved. APS-048-0010v1.8 29 / 75 MC3410 3-Axis Accelerometer Preliminary Datasheet 9.3 FRONT/BACK EVENTS The front/back detection compares ZOUT with a low g value, ranging from 0.174g to 0.547g, with the offset from 0.174g specified by the FB_Z_TH: Front/Back Z Axis Threshold Register. This equates to a range of approximately 55 degrees. The BAFR bit-field is updated in the TILT: Status Register according to the front/back orientation sensed by the device. Additional hysteresis can be added to front/back detection by increasing the front/back Z axis threshold value located in the FB_Z_TH: Front/Back Z Axis Threshold Register. When the front/back orientation of the device is in the deadband region, BAFR bit-field will report the orientation as “unknown”. The default settings (0x00) equate to a range of approximately 25 degrees where the sensor will report BAFR = FRONT (or BACK). The maximum settings (0xFF) equate to about a 80 degree range. See Figure 12 and Figure 13. BAFR = FRONT BAFR = FRONT +Z +Z se 25.0° 80.0° BAFR = UNKNOWN 80.0° or BAFR = UNKNOWN ns or BAFR = BACK BAFR = UNKNOWN se ns 25.0° BAFR = UNKNOWN -Z -Z FB_Z_TH = 0x00 == 25º (default, approx.) BAFR = BACK Figure 12. Default Setting of FB_Z_TH for BAFR Readings FB_Z_TH = 0xFF == 80º (maximum, approx.) Figure 13. Maximum setting of FB_Z_TH for BAFR Readings The bit settings for the BAFR bit-field are shown in Table 17. Table 18 shows the front/back orientation evaluation criteria. Some example threshold values and the corresponding trip angles are shown in Table 19. All values are approximate and not tested in production. mCube Proprietary and Confidential. © 2013 mCube Inc. All rights reserved. APS-048-0010v1.8 30 / 75 MC3410 3-Axis Accelerometer Preliminary Datasheet BAFR[1:0] Status 00 Unknown condition of front or back 01 Front: Device is in orientation e. in Figure 20 10 Back: Device is in orientation f. in Figure 20 11 Reserved Table 17. BAFR Bit Assignments in the TILT: Status Register Event X Axis Y Axis Z Axis Front Z > FB_Z_TH Back Z < -1 * FB_Z_TH Table 18. Front/Back Event Evaluation FB_Z_TH Trip Angle Threshold Value (approx. degrees) 0x00 25 0x10 28 0x20 32 0x30 35 0x40 39 0x50 42 0x60 46 0x70 49 … … 0xFF 80 Table 19. Approximate Front/Back Evaluation Angles and Values mCube Proprietary and Confidential. © 2013 mCube Inc. All rights reserved. APS-048-0010v1.8 31 / 75 MC3410 3-Axis Accelerometer Preliminary Datasheet 9.4 SHAKE DETECTION The threshold for detecting a shake event can be set to a range of values around a 1.3g baseline. The shake threshold can range from 0.925g to 1.672g. The value is a signed, 2’s complement number. Resolution is approximately 2.9mg/bit. A shake event will be triggered when high-g values are sensed for a sufficient number of samples. SHDB: Shake Debounce Register can be set to count from 1 to 63 events before setting the SHAKED bit in the TILT: Status Register. Higher values yield longer evaluation periods. See Figure 14 and Figure 15. Shake detection can be any combination of axes. To enable detection even when not using interrupts, set the corresponding SHINTX, SHINTY, or SHINTZ bit-fields in the INTEN: Interrupt Enable Register. Event Shake X Axis |X| > +1.3g ± Threshold Y Axis or |Y| > +1.3g ± Threshold Z Axis or |Z| > +1.3g ± Threshold Table 20. SHAKE Event Evaluation (Baseline + Offset) Sensed g value Sample Shake detect is reset here { SHAKE_TH Register 1.3 g Time Shake Debounce Register == 4 but the sensed g value is above 1.3g + SHAKE_TH for only 3 samples. Shake event is not detected. Figure 14. Example Use of Shake Detection Hardware – Shake Not Detected mCube Proprietary and Confidential. © 2013 mCube Inc. All rights reserved. APS-048-0010v1.8 32 / 75 MC3410 3-Axis Accelerometer Sensed g value Preliminary Datasheet Sample Shake detected here { SHAKE_TH Register 1.3 g Time Shake Debounce Register == 4 and the sensed g value is above 1.3g + SHAKE_TH for 5 samples. Shake event is detected. Figure 15. Example Use of Shake Detection Hardware – Shake Detected. mCube Proprietary and Confidential. © 2013 mCube Inc. All rights reserved. APS-048-0010v1.8 33 / 75 MC3410 3-Axis Accelerometer Preliminary Datasheet 9.5 DROP DETECTION Drop detection is defined as a low-g acceleration applied to all axes. Two modes of drop detection are supported: Mode A: Drop detection is a summation of all 3 axes: Drop is detected when: Sum( mag(X) + mag(Y) + mag(Z) ) < 0.5g ± DROP_TH Threshold else Drop not detected; Mode B: Drop detection is the logical AND of three comparisons: Drop is detected when: mag(X) < 0.5g ± DROP_TH Threshold and mag(Y) < 0.5g ± DROP_TH Threshold and mag(Z) < 0.5g ± DROP_TH Threshold else Drop not detected. The typical drop threshold value is on the order of < 0.5g for all axes. The drop detection range is from 0.125g to 0.872g. The drop debounce value (bit-field DDB in the DROP: Drop Event Control Register) can filter from 1 to 8 consecutive events before setting the drop interrupt. Event X Axis Y Axis Z Axis Drop Mode A Sum (|X| + |Y| + |Z|) < 0.5g ± DROP_TH Drop Mode B |X| < 0.5g ± DROP_TH and |Y| < 0.5g ± DROP_TH and |Z| < 0.5g ± DROP_TH Table 21. Drop Event Evaluation mCube Proprietary and Confidential. © 2013 mCube Inc. All rights reserved. APS-048-0010v1.8 34 / 75 MC3410 3-Axis Accelerometer Preliminary Datasheet 9.6 TAP DETECTION On-chip tap detection hardware allows the device to detect user events such as on-screen button presses. Tap detection can be enabled or disabled on each axis via the TAPEN: Tap Detection Enable Register. To detect fast, impulse events like a tap, the TAPP: Tap Pulse Register should be written with a tap pulse parameter that sets the maximum number of sample periods that a TAPD event may exceed the threshold before it is ignored by the detection logic. Sensed values that are above the threshold for long periods of time typically do not correspond to tap events. For example, setting the pulse value to 5 requires that the tap impulse exceed the threshold for at least 1 sample period and up to 5 sample periods. The tap detection hardware is rearmed after the sensed value is below the threshold. See the example in Figure 16 and Figure 17. Sensed Value Tap detect is reset here (6th sample) Sample Tap detect is rearmed here TAP_TH Register 0 snap Time Tap Pulse Register == 5 but the sensed value is above the threshold for 10 samples. No tap is detected. Figure 16. Example Use of Tap Detection Hardware – No Tap Detected mCube Proprietary and Confidential. © 2013 mCube Inc. All rights reserved. APS-048-0010v1.8 35 / 75 MC3410 3-Axis Accelerometer Preliminary Datasheet Sample Sensed Value Sensed Value Compared Value Tap detected here TAP_TH Register 0 snap Time Tap Pulse Register == 5 and the sensed value is above the threshold for 3 samples. Tap is detected. Figure 17. Example Use of Tap Detection Hardware – Tap Detected The threshold value, set by writing the TAP_TH: Tap Threshold Register, is an 8-bit unsigned number that species the threshold detection level for all tap events. This value is not an offset, but a magnitude which determines the minimum level for a valid tap event. Event X Axis Y Axis Z Axis Tap |X| > TAP_TH |Y| > TAP_TH |Z| > TAP_TH Table 22. Default Tap Event Evaluation mCube Proprietary and Confidential. © 2013 mCube Inc. All rights reserved. APS-048-0010v1.8 36 / 75 MC3410 3-Axis Accelerometer Preliminary Datasheet 9.7 CONTINUOUS SAMPLING The device has the ability to read all sampled readings in a continuous sampling fashion. The device always updates the XOUT_EX, YOUT_EX, and ZOUT_EX registers at 1024 samples/second. An optional interrupt can be generated each time the sample registers have been updated (GINT interrupt bit in the INTEN: Interrupt Enable Register). See Sections 8.3 and 11.11 for GINT operation and options. mCube Proprietary and Confidential. © 2013 mCube Inc. All rights reserved. APS-048-0010v1.8 37 / 75 MC3410 3-Axis Accelerometer 10 Preliminary Datasheet I2C INTERFACE 10.1 PHYSICAL INTERFACE The I2C slave interface operates at a maximum speed of 400 kHz. The SDA (data) is an opendrain, bi-directional pin and the SCL (clock) is an input pin. The device always operates as an I2C slave. An I2C master initiates all communication and data transfers and generates the SCL clock that synchronizes the data transfer. The I2C device address is 0x4c (8-bit address 0x98). The I2C interface remains active as long as power is applied to the DVDD and AVDD pins. In STANDBY state the device responds to I2C read and write cycles, but interrupts cannot be serviced or cleared. All registers can be written in the STANDBY state, but in WAKE only the MODE: Register can be modified. Internally, the registers which are used to store samples are clocked by the sample clock gated by I2C activity. Therefore, in order to allow the device to collect and present samples in the sample registers at least one I2C STOP condition must be present between samples. Refer to the I2C specification for a detailed discussion of the protocol. Per I2C requirements, SDA is an open drain, bi-directional pin. SCL and SDA each require an external pull-up resistor, typically 4.7kΩ. Refer also to Figure 3. Typical Application Circuit. 10.2 TIMING See Section 4.3.3 I2C Timing Characteristics for I2C timing requirements. 10.3 I2C MESSAGE FORMAT The device uses the following general format for writing to the internal registers. The I2C master generates a START condition, and then supplies the device ID, 0x4C or 1001100. The 8th bit is the R/W# flag (write cycle = 0). The device pulls SDA low during the 9th clock cycle indicating a positive ACK. This means, from an 8-bit point of view of an external I2C master, writes should be written to address 0x98 and reads will occur by reading address 0x99. The second byte is the 8-bit register address of the device to access, and the last byte is the data to write. START I2C Master (To Sensor) S Device ID (4C) 1 0 0 1 1 R/W# 0 0 I2C Slave (From Sensor) Register Address 0 R7 R6 R5 R4 R3 R2 Register Data to Write R1 R0 D7 D6 D5 D4 D4 D2 D1 Stop D0 P ACK ACK ACK ACK/NAK ACK/NAK ACK/NAK Figure 18. I2C Message Format, Write Cycle, Single Register Write mCube Proprietary and Confidential. © 2013 mCube Inc. All rights reserved. APS-048-0010v1.8 38 / 75 MC3410 3-Axis Accelerometer Preliminary Datasheet In a read cycle, the I2C master writes the device ID (R/W#=0) and register address to be read. The master issues a RESTART condition and then writes the device ID with the R/W# flag set to ‘1’. The device shifts out the contents of the register address. START I2C Master (To Sensor) I2C Slave (from Sensor) S Device ID (4C) 1 0 0 1 1 R/W# 0 0 Register Address 0 R7 R6 R5 R4 R3 R2 Restart R1 R0 R Device ID (4C) 1 0 0 1 1 R/W# 0 0 NAK NAK 1 ACK ACK ACK ACK/NAK ACK/NAK ACK/NAK D7 D6 D5 D4 D3 D2 D1 STOP P D0 Read Data Byte Figure 19. I2C Message Format, Read Cycle, Single Register Read The I2C master may write or read consecutive register addresses by writing or reading additional bytes after the first access. The device will internally increment the register address. If an I2C burst read operation reads past register address 0x12 the internal address pointer “wraps” to address 0x03 and the contents of the TILT: Status Register are returned. This allows application software to burst read the contents of the six extended registers and the relevant device state registers in a single I2C cycle. mCube Proprietary and Confidential. © 2013 mCube Inc. All rights reserved. APS-048-0010v1.8 39 / 75 MC3410 3-Axis Accelerometer 11 Preliminary Datasheet REGISTER INTERFACE The device has a simple register interface which allows a MCU or I2C master to configure and monitor all aspects of the device. This section lists an overview of user programmable registers. By convention, Bit 0 is the least significant bit (LSB) of a byte register. Two registers are needed in order to contain each sample, the XOUT_EX, YOUT_EX & ZOUT_EX: X, Y, Z-Axis Extended Accelerometer Registers. The least significant byte is located in the register with a lower address (e.g. XOUT_EX_L), followed by the most significant byte in the next higher address (e.g. XOUT_EX_H). mCube Proprietary and Confidential. © 2013 mCube Inc. All rights reserved. APS-048-0010v1.8 40 / 75 MC3410 3-Axis Accelerometer Preliminary Datasheet 11.1 REGISTER SUMMARY Addr Name Description Bit 7 Bit 6 Bit 5 TILT 0x04 OPSTAT Tilt Status Register SHAKED DROPD TAPD Operational State Status Register OTPA 0 Resv 8 0x07 MODE Interrupt Enable Register SHINTX SHINTY SHINTZ Mode Register IAH IPP Resv 8 0x08 0x0A TAPP 0x0B DROP 0x0C SHDB Tap Detection Enable Register Tap Pulse Register Drop Event Control Register ZDA Resv 8 DROP_ MODE XOUT _EX_L XOUT 0x0E _EX_H YOUT 0x0F _EX_L Shake Debounce Register XOUT Extended Register XOUT Extended Register YOUT Extended Register XOUT _EX[7] XOUT _EX[15] YOUT _EX[7] YOUT 0x10 _EX_H YOUT Extended Register ZOUT _EX_L ZOUT 0x12 _EX_H 0x0D YDA XDA 0x18 CHIPID XOFFL R 0x03 R FBINT 0x00 W OPCON [0] 0x03 W 0x00 W Bit 0 POLA [1] POLA [0] 0 0 BAFR [1] OPSTAT [1] BAFR [0] OPSTAT [0] ASINT TINT PLINT OPCON [1] 6 GINT Resv 8 Resv 8 0 7 8 Resv 6 Resv 8 Resv Resv 8 Resv 8 TAPP [3] DINT Resv 8 Resv 8 Resv 8 8 Resv 8 Resv 8 TAPP [2] TAPP [1] TAPP [0] 0x00 W DROP_ DB[2] DROP_ DB[1] DROP_ DB[0] 0x00 W 0x00 W 0x00 R 0x00 R 0x00 R XOUT _EX[6] XOUT _EX[14] YOUT _EX[6] SHDB [5] XOUT _EX[5] XOUT _EX[13] YOUT _EX[5] SHDB [4] XOUT _EX[4] XOUT _EX[12] YOUT _EX[4] SHDB [3] XOUT _EX[3] XOUT _EX[11] YOUT _EX[3] SHDB [2] XOUT _EX[2] XOUT _EX[10] YOUT _EX[2] SHDB [1] XOUT _EX[1] XOUT _EX[9] YOUT _EX[1] SHDB [0] XOUT _EX[0] XOUT _EX[8] YOUT _EX[0] YOUT _EX[15] YOUT _EX[14] YOUT _EX[13] YOUT _EX[12] YOUT _EX[11] YOUT _EX[10] YOUT _EX[9] YOUT _EX[8] 0x00 R ZOUT Extended Register ZOUT _EX[7] ZOUT _EX[6] ZOUT _EX[5] ZOUT _EX[4] ZOUT _EX[3] ZOUT _EX[2] ZOUT _EX[1] ZOUT _EX[0] 0x00 R ZOUT Extended Register ZOUT _EX[15] ZOUT _EX[14] ZOUT _EX[13] ZOUT _EX[12] ZOUT _EX[11] ZOUT _EX[10] ZOUT _EX[9] ZOUT _EX[8] 0x00 R RESERVED 6 0 0 1 0 0x02 R 9 1 9 0x03 W Resv 8 Resv 8 Chip ID Register 0 0 0 0x19-0x1F 0x20 OUTCFG 0x00 Bit 1 8 Resv 0x13-0x17 0x21 0 RESERVED 0x09 TAPEN 0x11 POLA [2] RESERVED INTEN R/ 5 W Bit 2 RESERVED 0x05 0x06 POR Value Bit 3 6 0x00-0x02 0x03 Bit 4 0 RESERVED Output Configuration Register X-Offset LSB Register 6 IRATE LPF [2] LPF [1] LPF [0] HIRES [1] HIRES [0] 1 XOFF[7] XOFF[6] XOFF[5] XOFF[4] XOFF[3] XOFF[2] XOFF[1] XOFF[0] Per chip W 5 ‘R’ registers are read-only, via external I2C access. ‘W’ registers are read-write, via external I2C access. Registers designated as ‘RESERVED’ should not be accessed by software. 7 Software must always write a zero ‘0’ to this bit. 8 Bits designated as ‘Resv’ are reserved for future use. 9 Software must always write a one ‘1’ to this bit. 6 mCube Proprietary and Confidential. © 2013 mCube Inc. All rights reserved. APS-048-0010v1.8 41 / 75 MC3410 3-Axis Accelerometer Addr Name Preliminary Datasheet Bit 6 0x22 XOFFH X-Offset MSB Register XGAIN[8] Resv 0x23 YOFFL Y-Offset LSB Register YOFF[7] YOFF[6] 0x24 YOFFH Y-Offset MSB Register YGAIN[8] Resv 0x25 ZOFFL Z-Offset LSB Register ZOFF[7] ZOFF[6] 0x26 ZOFFH Z-Offset MSB Register ZGAIN[8] Resv 0x27 XGAIN X Gain Register XGAIN[7] XGAIN[6] XGAIN[5] XGAIN[4] XGAIN[3] XGAIN[2] XGAIN[1] XGAIN[0] Per chip W 0x28 YGAIN Y Gain Register YGAIN[7] YGAIN[6] YGAIN[5] YGAIN[4] YGAIN[3] YGAIN[2] YGAIN[1] YGAIN[0] Per chip W 0x29 Z Gain Register ZGAIN[7] ZGAIN[6] ZGAIN[5] ZGAIN[4] ZGAIN[3] ZGAIN[2] ZGAIN[1] ZGAIN[0] Per chip W ZGAIN 8 8 Bit 4 Bit 3 Bit 2 Bit 1 Bit 0 R/ 5 W Bit 7 8 Bit 5 POR Value Description XOFF[13] XOFF[12] XOFF[11] XOFF[10] XOFF[9] XOFF[8] Per chip W YOFF[5] YOFF[1] YOFF[0] Per chip W YOFF[13] YOFF[12] YOFF[11] YOFF[10] YOFF[9] YOFF[8] Per chip W ZOFF[5] ZOFF[1] ZOFF[0] Per chip W ZOFF[13] ZOFF[12] ZOFF[11] ZOFF[10] ZOFF[9] ZOFF[8] Per chip W YOFF[4] ZOFF[4] YOFF[3] ZOFF[3] YOFF[2] ZOFF[2] 6 0x2A 0x2B SHAKE _TH Shake Threshold Register SHAKE _TH[7] SHAKE _TH[6] SHAKE _TH[5] RESERVED SHAKE SHAKE _TH[4] _TH[3] 0x2C UD_Z _TH Up/Down Z Threshold Register UD_Z _TH[7] UD_Z _TH[6] UD_Z _TH[5] UD_Z _TH[4] UD_Z _TH[3] UD_Z _TH[2] UD_Z _TH[1] UD_Z _TH[0] 0x00 W 0x2D UD_X _TH Up/Down X Threshold Register UD_X _TH[7] UD_X _TH[6] UD_X _TH[5] UD_X _TH[4] UD_X _TH[3] UD_X _TH[2] UD_X _TH[1] UD_X _TH[0] 0x00 W 0x2E RL_Z _TH Right/Left Z Threshold Register RL_Z _TH[7] RL_Z _TH[6] RL_Z _TH[5] RL_Z _TH[4] RL_Z _TH[3] RL_Z _TH[2] RL_Z _TH[1] RL_Z _TH[0] 0x00 W 0x2F RL_Y _TH Right/Left Y Threshold Register RL_Y _TH[7] RL_Y _TH[6] RL_Y _TH[5] RL_Y _TH[4] RL_Y _TH[3] RL_Y _TH[2] RL_Y _TH[1] RL_Y _TH[0] 0x00 W 0x30 FB_Z _TH Front/Back Z Threshold Register FB_Z _TH[7] FB_Z _TH[6] FB_Z _TH[5] FB_Z _TH[4] FB_Z _TH[3] FB_Z _TH[2] FB_Z _TH[1] FB_Z _TH[0] 0x00 W 0x31 DROP _TH Drop Threshold Register DROP _TH[7] DROP _TH[6] DROP _TH[5] DROP _TH[4] DROP _TH[3] DROP _TH[2] DROP _TH[1] DROP _TH[0] 0x00 W TAP _TH 0x33 to 0x3A Tap Threshold Register TAP _TH[7] TAP _TH[6] TAP _TH[5] TAP TAP _TH[4] _TH[3] 6 RESERVED TAP _TH[2] TAP _TH[1] TAP _TH[0] 0x00 W 0x3B PCODE Product Code 1 0 1 0 0 0 0xB8 R 0x32 0x3C to 0x3F Table 23. Register Summary 10 1 RESERVED 1 SHAKE _TH[2] SHAKE _TH[1] SHAKE _TH[0] 0x00 W 6 10 No registers are updated with new event status or samples while a I2C cycle is in process. mCube Proprietary and Confidential. © 2013 mCube Inc. All rights reserved. APS-048-0010v1.8 42 / 75 MC3410 3-Axis Accelerometer Preliminary Datasheet 11.2 TILT: STATUS REGISTER This register contains bits which are set when a motion event is detected. Each event has a corresponding interrupt enable which can mask any combination of events. The event detection bits (SHAKED, DROPD, TAPD) remain held until the register is read by the I2C interface. Note that the orientation bit-fields POLA and BAFR are continuously updated (every sample) in the TILT: Status Register and are not held. Note that multiple interrupts may be active at the same time, and so a software routine reading the TILT: Status Register should account for this. Refer to Figure 20. Package Orientation and Figure 21. Package Axis Reference. Addr Name Description Bit 7 Bit 6 Bit 5 Bit 4 Bit 3 Bit 2 Bit 1 Bit 0 POR Value R/ W 0x03 TILT Tilt Status Register SHAKED DROPD TAPD POLA [2] POLA [1] POLA [0] BAFR [1] BAFR [0] 0x00 R BAFR[1:0] POLA[2:0] TAPD DROPD SHAKED Back or Front 00: Unknown condition of front or back 01: Front – Device is in orientation e in Figure 20. Package Orientation. 10: Back – Device is in orientation f in Figure 20. Package Orientation. 11: Reserved Portrait or Landscape 000: Unknown condition of up, down, left or right 001: Left – Device is in orientation b in Figure 20. Package Orientation. 010: Right – Device is in orientation c in Figure 20. Package Orientation. 011: Reserved 100: Reserved 101: Down – Device is in orientation d in Figure 20. Package Orientation. 110: Up – Device is in orientation a in Figure 20. Package Orientation. 111: Reserved 0: Tap event not detected 1: Tap event detected 0: Drop event not detected 1: Drop event detected 0: Shake event not detected 1: Shake event detected Table 24. TILT Status Register Settings mCube Proprietary and Confidential. © 2013 mCube Inc. All rights reserved. APS-048-0010v1.8 43 / 75 MC3410 3-Axis Accelerometer Preliminary Datasheet Top View a. Direction of Earth gravity acceleration Top Pin 1 Side View e. b. XOUT = +1g YOUT = 0g ZOUT = 0g TILT = UP c. XOUT = 0g YOUT = 0g ZOUT = +1g TILT = FRONT f. XOUT = 0g YOUT = -1g ZOUT = 0g TILT = LEFT d. XOUT = 0g YOUT = +1g ZOUT = 0g TILT = RIGHT XOUT = 0g YOUT = 0g ZOUT = -1g TILT = BACK XOUT = -1g YOUT = 0g ZOUT = 0g TILT = DOWN Figure 20. Package Orientation +Z +X +Y -Y -X -Z Figure 21. Package Axis Reference mCube Proprietary and Confidential. © 2013 mCube Inc. All rights reserved. APS-048-0010v1.8 44 / 75 MC3410 3-Axis Accelerometer Preliminary Datasheet 11.3 OPSTAT: OPERATIONAL STATE ST ATUS REGISTER The Operational State status register reports which operational state the device is in, either WAKE or STANDBY as shown in Table 25. Operational State Status Register. Addr Name Description Bit 7 Bit 6 Bit 5 Bit 4 Bit 3 Bit 2 Bit 1 Bit 0 POR Value R/ W 0x04 OPSTAT Operational State Status Register OTPA 0 Resv 0 0 0 OPSTAT [1] OPSTAT [0] 0x03 R OPSTAT[1:0] Resv OTPA Sampling State Register Status, Wait State Register Status 00: Reserved 01: Device is in WAKE state 10: Reserved 11: Device is in STANDBY state, no sampling Reserved One-time Programming (OTP) activity status 0: Internal memory is idle and the device is ready for use 1: Internal memory is active and the device is not yet ready for use Table 25. Operational State Status Register mCube Proprietary and Confidential. © 2013 mCube Inc. All rights reserved. APS-048-0010v1.8 45 / 75 MC3410 3-Axis Accelerometer Preliminary Datasheet 11.4 INTEN: INTERRUPT ENABLE REGISTER The interrupt enable register enables or disables interrupts on various motion events. If the corresponding interrupt enable bit is set, a matching event will generate an interrupt transition on the external interrupt pin, INTN. To enable the drop interrupt, set the DINT control bit in the DROP: Drop Event Control Register. When an interrupt is triggered, the first I2C access to the device will clear the external interrupt pin, but the condition (TAPD, SHAKED, DROPD) that generated the interrupt will remain held in the TILT: Status Register until it is read. Note that the orientation bit-fields POLA and BAFR are continuously updated (every sample) in the TILT: Status Register and are not held. Addr Name Description Bit 7 Bit 6 Bit 5 Bit 4 Bit 3 Bit 2 Bit 1 Bit 0 POR Value R/ W 0x06 INTEN Interrupt Enable Register SHINTX SHINTY SHINTZ GINT Resv TINT PLINT FBINT 0x00 W FBINT PLINT TINT Resv GINT SHINTX SHINTY SHINTZ Front / Back Interrupt 0: Disable interrupt on front/back position change 1: Enable interrupt on front/back position change Portrait / Landscape Interrupt 0: Disable interrupt on up/down/left/right position change 1: Enable interrupt on up/down/left/right position change Tap Interrupt 0: Disable interrupt on tap detection 1: Enable interrupt on tap detection Reserved Generate Interrupt 0: Disable automatic interrupt after each measurement 1: Enable automatic interrupt after each measurement is updated in XOUT, YOUT, or ZOUT. The interrupt occurs for each measurement, not value change. See Section 8.3. Shake Interrupt, X-axis 0: Disable X-axis interrupt, SHAKED is not set in TILT: Status Register upon event 1 : Enable X-axis interrupt, SHAKED is set in TILT: Status Register upon event Shake Interrupt, Y-axis 0: Disable Y-axis interrupt, SHAKED bit is not set in TILT: Status Register upon event 1 : Enable Y-axis interrupt, SHAKED bit is set in TILT: Status Register upon event Shake Interrupt, Z-axis 0: Disable Z-axis interrupt, SHAKED bit is not set in TILT: Status Register upon event 1 : Enable Z-axis interrupt, SHAKED bit is set in TILT: Status Register upon event Table 26. Interrupt Enable Register Settings mCube Proprietary and Confidential. © 2013 mCube Inc. All rights reserved. APS-048-0010v1.8 46 / 75 MC3410 3-Axis Accelerometer Preliminary Datasheet 11.5 MODE: REGISTER The MODE register controls the active operating state of the device. This register can be written from either operational state (STANDBY or WAKE). Addr Name Description Bit 7 Bit 6 Bit 5 Bit 4 Bit 3 0x07 MODE Mode Register IAH IPP Resv * Resv * Resv * Bit 2 * 0 Bit 1 Bit 0 POR Value R/ W OPCON [1] OPCON [0] 0x03 W NOTE*: Software must always write a zero ‘0’ to Bit 2. Bits 3, 4 and 5 are reserved. OPCON [1:0] IPP IAH 00: Reserved 01: Move to WAKE state and remain there 10: Reserved 11: Move to STANDBY state and remain there (STANDBY is the default POR state) 0: Interrupt pin INTN is open drain (default) and requires an external pull-up to AVDD. 1: Interrupt pin INTN is push-pull. No external pull-up resistor should be installed. 0: Interrupt pin INTN is active low 1: Interrupt pin INTN is active high Set Device Operational State. WAKE or STANDBY Interrupt Push Pull Interrupt Active High Table 27. Mode Register Functionality mCube Proprietary and Confidential. © 2013 mCube Inc. All rights reserved. APS-048-0010v1.8 47 / 75 MC3410 3-Axis Accelerometer Preliminary Datasheet 11.6 TAPEN: TAP DETECTION ENABLE REGISTER This register allows individual tap/pulse detection on each axis. Setting XDA, YDA, or ZDA adds the corresponding axis to tap event detection. See also Section 9.6 Tap Detection. Addr Name Description Bit 7 Bit 6 Bit 5 Bit 4 Bit 3 Bit 2 Bit 1 Bit 0 POR Value R/ W 0x09 TAPEN Tap Detection Enable Register ZDA YDA XDA Resv Resv Resv Resv Resv 0x00 W XDA YDA ZDA 0: Disable Tap detection on X-axis 1: Enable Tap detection on X-axis 0: Disable Tap detection on Y-axis 1: Enable Tap detection on Y-axis 0: Disable Tap detection on Z-axis 1: Enable Tap detection on Z-axis Table 28. TAPEN Register Settings mCube Proprietary and Confidential. © 2013 mCube Inc. All rights reserved. APS-048-0010v1.8 48 / 75 MC3410 3-Axis Accelerometer Preliminary Datasheet 11.7 TAPP: TAP PULSE REGISTER This value sets the number of samples for which a tap pulse must exceed the TAP_TH threshold before it is rejected as not a tap event. If the values detected by the sensor exceed the TAP_TH threshold for longer than the reject count, no tap event is detected and the interrupt is not set. See also Section 9.6 Tap Detection. Addr Name Description Bit 7 Bit 6 Bit 5 Bit 4 Bit 3 Bit 2 Bit 1 Bit 0 POR Value R/ W 0x0A TAPP TAP Pulse Register Resv Resv Resv Resv TAPP [3] TAPP [2] TAPP [1] TAPP [0] 0x00 W [3:0] Tap Detection Sample Periods (n) 0x0 1 0x1 2 0x2 3 0x3 4 … 5 ≤ n ≤ 15 0xF 16 TAPP Description This tap detection filtering requires the sensed values to exceed the TAP_TH threshold level for n sample periods. When they have, the sensor will set TAPD bit in the TILT: Status Register. In addition, if the TINT tap interrupt is enabled in the INTEN: Interrupt Enable Register then an interrupt will be generated by the device. Table 29. TAPP Tap Pulse Register Settings mCube Proprietary and Confidential. © 2013 mCube Inc. All rights reserved. APS-048-0010v1.8 49 / 75 MC3410 3-Axis Accelerometer Preliminary Datasheet 11.8 DROP: DROP EVENT CONTROL REGISTER Addr Name 0x0B DROP Description Bit 7 Drop Event Control DROP_ Register MODE DROP_DB[2:0] DINT DROP_MODE Bit 6 Bit 5 Bit 4 Bit 3 Bit 2 Bit 1 Bit 0 POR Value R/ W DINT Resv Resv Resv DROP_ DB[2] DROP_ DB[1] DROP_ DB[0] 0x00 W Drop Debounce Drop event debounce value, the number 000: 1 drop event of drop events detected must reach this 001: 2 adjacent drop events count for the final event to be valid. 010: 3 adjacent drop events … : 4 ≤ n ≤ 7 adjacent drop events 111: 8 adjacent drop events Drop Interrupt The DROPD bit in the TILT: Status 0: Disable drop event interrupt Register will be set upon event 1: Enable drop event interrupt occurrence regardless of this bit setting. Drop Mode 0: Mode A: Drop detection is a summation of all 3 axes: Drop is detected when: Sum( mag(X) + mag(Y) + mag(Z) ) < 0.5g ± DROP_TH Threshold else Drop not detected; 1: Mode B: Drop detection is the logical AND of three comparisons: Drop is detected when: mag(X) < 0.5g ± DROP_TH Threshold and mag(Y) < 0.5g ± DROP_TH Threshold and mag(Z) < 0.5g ± DROP_TH Threshold else Drop not detected. Table 30. Drop Event Control Register Settings mCube Proprietary and Confidential. © 2013 mCube Inc. All rights reserved. APS-048-0010v1.8 50 / 75 MC3410 3-Axis Accelerometer Preliminary Datasheet 11.9 SHDB: SHAKE DEBOUNCE REGISTER The shake debounce register allows a 1 to 63 event count to be required before a valid shake event is detected or an interrupt is generated. The debounce value applies to all 3-axes. Addr Name Description Bit 7 Bit 6 Bit 5 Bit 4 Bit 3 Bit 2 Bit 1 Bit 0 POR Value R/ W 0x0C SHDB Shake Debounce Register Resv Resv SHDB [5] SHDB [4] SHDB [3] SHDB [2] SHDB [1] SHDB [0] 0x00 W SHDB[5:0] Adjacent Shake Events (n) 0x01 1 0x02 2 0x03 3 …. 4 ≤ n ≤ 62 0x3F 63 Description Shake detection debounce filtering requires n adjacent shake detection events in order to trigger a shake event and set the SHAKED bit in the TILT: Status Register. In addition, if the SHINTX, SHINTY or SHINTZ bits are set in the INTEN: Interrupt Enable Register and that event occurs, then an interrupt will be generated by the device. Table 31. SH_DB Shake Debounce Register Settings mCube Proprietary and Confidential. © 2013 mCube Inc. All rights reserved. APS-048-0010v1.8 51 / 75 MC3410 3-Axis Accelerometer Preliminary Datasheet 11.10 XOUT_EX, YOUT_EX & ZOUT_EX: X, Y, Z-AXIS EXTENDED ACCELEROMETER REGISTERS The measurements from sensors for the 3-axes are written to the registers XOUT_EX, YOUT_EX & ZOUT_EX: X, Y, Z-Axis Extended Accelerometer Registers. The most-significant bit of the value is the sign bit, and is sign extended to the higher bits. Note that all 3 axes are sampled and updated simultaneously. If an I2C burst read operation reads past register address 0x12 the internal address pointer “wraps” to address 0x03 and the contents of the TILT: Status Register are returned. This allows application software to burst read the contents of the six extended registers and relevant device state registers in a single I2C read cycle. Once an I2C start bit has been recognized by the sensor, registers will not be updated until an I2C stop bit has occurred. Therefore, if software desires to read the low and high byte registers ‘atomically’, knowing that the values have not been changed, it should do so by issuing a start bit, reading one register, then reading the other register then issuing a stop bit. Note that all 6 registers may be read in one burst with the same effect. 10-bit samples occupy bits [9:0], with bits [15:9] occupied by the sign bit. 14-bit samples occupy bits [13:0], with bits [15:13] occupied by the sign bit. Addr POR Value R/ W 0x00 R 0x00 R YOUT _EX[0] 0x00 R YOUT _EX[9] YOUT _EX[8] 0x00 R ZOUT _EX[2] ZOUT _EX[1] ZOUT _EX[0] 0x00 R ZOUT _EX[10] ZOUT _EX[9] ZOUT _EX[8] 0x00 R Name Description Bit 7 Bit 6 Bit 5 Bit 4 Bit 3 Bit 2 Bit 1 Bit 0 0x0E XOUT _EX_L XOUT _EX_H XOUT Extended Register XOUT Extended Register XOUT _EX[7] XOUT _EX[15] XOUT _EX[6] XOUT _EX[14] XOUT _EX[5] XOUT _EX[13] XOUT _EX[4] XOUT _EX[12] XOUT _EX[3] XOUT _EX[11] XOUT _EX[2] XOUT _EX[10] XOUT _EX[1] XOUT _EX[9] XOUT _EX[0] XOUT _EX[8] 0x0F YOUT _EX_L YOUT Extended Register YOUT _EX[7] YOUT _EX[6] YOUT _EX[5] YOUT _EX[4] YOUT _EX[3] YOUT _EX[2] YOUT _EX[1] 0x10 YOUT _EX_H YOUT Extended Register YOUT _EX[15] YOUT _EX[14] YOUT _EX[13] YOUT _EX[12] YOUT _EX[11] YOUT _EX[10] 0x11 ZOUT _EX_L ZOUT Extended Register ZOUT _EX[7] ZOUT _EX[6] ZOUT _EX[5] ZOUT _EX[4] ZOUT _EX[3] 0x12 ZOUT _EX_H ZOUT Extended Register ZOUT _EX[15] ZOUT _EX[14] ZOUT _EX[13] ZOUT _EX[12] ZOUT _EX[11] 0x0D Table 32. Extended Accelerometer Registers mCube Proprietary and Confidential. © 2013 mCube Inc. All rights reserved. APS-048-0010v1.8 52 / 75 MC3410 3-Axis Accelerometer Preliminary Datasheet 11.11 CHIPID: CHIP IDENTIFICATION REGISTER This register returns 0x02. Addr Name Description Bit 7 Bit 6 Bit 5 Bit 4 Bit 3 Bit 2 Bit 1 Bit 0 POR Value R/ W 0x18 CHIPID Chip ID Register 0 0 0 0 0 0 1 0 0x02 R mCube Proprietary and Confidential. © 2013 mCube Inc. All rights reserved. APS-048-0010v1.8 53 / 75 MC3410 3-Axis Accelerometer Preliminary Datasheet 11.12 OUTCFG: OUTPUT CONFIGURATION REGISTER This register can be used to set the resolution of the accelerometer measurements, the maximum g-range and low-pass filter settings for sampling and the bandwidth setting for the GINT interrupt. The lowest 2 bits must be set by software to binary b‘11. Addr Name Description Bit 7 Bit 6 Bit 5 Bit 4 Bit 3 Bit 2 Bit 1 Bit 0 POR Value R/ W 0x20 OUTCFG Output Configuration Register IRATE LPF [2] LPF [1] LPF [0] HIRES [1] HIRES [0] 1* 1* 0x03 W NOTE*: Software must always write a ‘1’ to bits 0 and 1. HIRES[1:0] LPF[2:0] Accelerometer g Ranges and Resolution 00: Select +/- 2g range, 10-bit resolution 01: Select +/- 4g range, 10-bit resolution 10: Select +/- 8g range, 10-bit resolution 11: Select +/- 8g range, 14-bit resolution Low Pass Filter bandwidth 000: Low-pass filter set to 512 Hz bandwidth 001: Low-pass filter set to 256 Hz bandwidth 010: Low-pass filter set to 128 Hz bandwidth 011: Low-pass filter set to 64 Hz bandwidth 100: Low-pass filter set to 32 Hz bandwidth 101: Low-pass filter set to 16 Hz bandwidth 110: Low-pass filter set to 8 Hz bandwidth 111: Reserved GINT sample rate trigger 0: GINT interrupt updates at sample acquisition rate 1: GINT interrupt updates at LPF bandwidth setting determined by LPF[2:0] IRATE If IRATE=’1’, the GINT interrupt will occur at the same rate as the bandwidth setting of the LPF. This prevents extraneous sample acquisition interrupts at a rate greater than the LPF setting. Table 33. OUTCFG Resolution and Range Select Register Settings mCube Proprietary and Confidential. © 2013 mCube Inc. All rights reserved. APS-048-0010v1.8 54 / 75 MC3410 3-Axis Accelerometer Preliminary Datasheet 11.13 X-AXIS OFFSET REGISTERS This register contains a signed 2’s complement 14-bit value applied as an offset adjustment to the output of the sensor values, prior to being sent to the OUT_EX registers. The Power-OnReset value for each chip is unique and is set as part of factory calibration. If necessary, this value can be overwritten by software. NOTE: When modifying these registers with new gain or offset values, software should perform a read-modify-write type of access to ensure that unrelated bits do not get changed inadvertently. R/ W Name Description Bit 7 Bit 6 Bit 5 Bit 4 Bit 3 Bit 2 Bit 1 0x21 XOFFL X-Offset LSB Register XOFF[7] XOFF[6] XOFF[5] XOFF[4] XOFF[3] XOFF[2] XOFF[1] XOFF[0] Per chip W 0x22 XOFFH X-Offset MSB Register XGAIN[8] Resv XOFF[13] XOFF[12] XOFF[11] XOFF[10] XOFF[9] XOFF[8] Per chip W mCube Proprietary and Confidential. © 2013 mCube Inc. All rights reserved. APS-048-0010v1.8 Bit 0 POR Value Addr 55 / 75 MC3410 3-Axis Accelerometer Preliminary Datasheet 11.14 Y-AXIS OFFSET REGISTERS This register contains a signed 2’s complement 14-bit value applied as an offset adjustment to the output of the sensor values, prior to being sent to the OUT_EX registers. The Power-OnReset value for each chip is unique and is set as part of factory calibration. If necessary, this value can be overwritten by software. NOTE: When modifying these registers with new gain or offset values, software should perform a read-modify-write type of access to ensure that unrelated bits do not get changed inadvertently. R/ W Name Description Bit 7 Bit 6 Bit 5 Bit 4 Bit 3 Bit 2 Bit 1 0x23 YOFFL Y-Offset LSB Register YOFF[7] YOFF[6] YOFF[5] YOFF[4] YOFF[3] YOFF[2] YOFF[1] YOFF[0] Per chip W 0x24 YOFFH Y-Offset MSB Register YGAIN[8] Resv YOFF[13] YOFF[12] YOFF[11] YOFF[10] YOFF[9] YOFF[8] Per chip W mCube Proprietary and Confidential. © 2013 mCube Inc. All rights reserved. APS-048-0010v1.8 Bit 0 POR Value Addr 56 / 75 MC3410 3-Axis Accelerometer Preliminary Datasheet 11.15 Z-AXIS OFFSET REGISTERS This register contains a signed 2’s complement 14-bit value applied as an offset adjustment to the output of the sensor values, prior to being sent to the OUT_EX registers. The Power-OnReset value for each chip is unique and is set as part of factory calibration. If necessary, this value can be overwritten by software. NOTE: When modifying these registers with new gain or offset values, software should perform a read-modify-write type of access to ensure that unrelated bits do not get changed inadvertently. R/ W Name Description Bit 7 Bit 6 Bit 5 Bit 4 Bit 3 Bit 2 Bit 1 0x25 ZOFFL Z-Offset LSB Register ZOFF[7] ZOFF[6] ZOFF[5] ZOFF[4] ZOFF[3] ZOFF[2] ZOFF[1] ZOFF[0] Per chip W 0x26 ZOFFH Z-Offset MSB Register ZGAIN[8] Resv ZOFF[13] ZOFF[12] ZOFF[11] ZOFF[10] ZOFF[9] ZOFF[8] Per chip W mCube Proprietary and Confidential. © 2013 mCube Inc. All rights reserved. APS-048-0010v1.8 Bit 0 POR Value Addr 57 / 75 MC3410 3-Axis Accelerometer Preliminary Datasheet 11.16 X-AXIS GAIN REGISTERS The gain value is an unsigned 9-bit number. NOTE: When modifying these registers with new gain or offset values, software should perform a read-modify-write type of access to ensure that unrelated bits do not get changed inadvertently. Addr Name Description Bit 7 Bit 6 0x22 XOFFH X-Offset MSB Register XGAIN[8] Resv 0x27 XGAIN X Gain Register Bit 5 Bit 4 Bit 3 Bit 2 Bit 1 XOFF[13] XOFF[12] XOFF[11] XOFF[10] XOFF[9] Bit 0 POR Value R/ W XOFF[8] Per chip W XGAIN[7] XGAIN[6] XGAIN[5] XGAIN[4] XGAIN[3] XGAIN[2] XGAIN[1] XGAIN[0] Per chip W mCube Proprietary and Confidential. © 2013 mCube Inc. All rights reserved. APS-048-0010v1.8 58 / 75 MC3410 3-Axis Accelerometer Preliminary Datasheet 11.17 Y-AXIS GAIN REGISTERS The gain value is an unsigned 9-bit number. NOTE: When modifying these registers with new gain or offset values, software should perform a read-modify-write type of access to ensure that unrelated bits do not get changed inadvertently. Addr Name Description Bit 7 Bit 6 0x24 YOFFH Y-Offset MSB Register YGAIN[8] Resv 0x28 YGAIN Y Gain Register Bit 5 Bit 4 Bit 3 Bit 2 Bit 1 YOFF[13] YOFF[12] YOFF[11] YOFF[10] YOFF[9] Bit 0 YOFF[8] POR Value R/ W Per chip W YGAIN[7] YGAIN[6] YGAIN[5] YGAIN[4] YGAIN[3] YGAIN[2] YGAIN[1] YGAIN[0] Per chip W mCube Proprietary and Confidential. © 2013 mCube Inc. All rights reserved. APS-048-0010v1.8 59 / 75 MC3410 3-Axis Accelerometer Preliminary Datasheet 11.18 Z-AXIS GAIN REGISTERS The gain value is an unsigned 9-bit number. NOTE: When modifying these registers with new gain or offset values, software should perform a read-modify-write type of access to ensure that unrelated bits do not get changed inadvertently. Addr Name Description Bit 7 Bit 6 0x26 ZOFFH Z-Offset MSB Register ZGAIN[8] Resv 0x29 ZGAIN Z Gain Register Bit 5 Bit 4 Bit 3 Bit 2 Bit 1 ZOFF[13] ZOFF[12] ZOFF[11] ZOFF[10] ZOFF[9] Bit 0 ZOFF[8] POR Value R/ W Per chip W ZGAIN[7] ZGAIN[6] ZGAIN[5] ZGAIN[4] ZGAIN[3] ZGAIN[2] ZGAIN[1] ZGAIN[0] Per chip W mCube Proprietary and Confidential. © 2013 mCube Inc. All rights reserved. APS-048-0010v1.8 60 / 75 MC3410 3-Axis Accelerometer Preliminary Datasheet 11.19 SHAKE_TH: SHAKE THRESHOLD REGISTER SHAKE_TH has a baseline value of 1.3g plus a threshold, SHAKE_TH. The shake threshold can range from 0.925g to 1.672g. The value is an 8-bit signed 2’s complement number. The resolution is approximately 2.9mg/bit. See also Section 9.4 Shake Detection. Shake Event = ( mag(X) > 1.3g + SHAKE_TH ) or ( mag(Y) > 1.3g + SHAKE_TH ) or ( mag(Z) > 1.3g + SHAKE_TH ) Addr Name Description 0x2B SHAKE_TH Shake Threshold Register Bit 7 Bit 6 Bit 5 Bit 4 Bit 3 Bit 2 Bit 1 Signed 2’s complement value SHAKE_TH[7:0] Description (~2.9mg/LSB) 0x80 Shake threshold is 0.925g 0x00 Shake threshold is 1.3g 0x7F Shake threshold is 1.672g Bit 0 POR Value R/ W 0x00 W Table 34. SHAKE_TH Threshold Register Settings mCube Proprietary and Confidential. © 2013 mCube Inc. All rights reserved. APS-048-0010v1.8 61 / 75 MC3410 3-Axis Accelerometer Preliminary Datasheet 11.20 UD_Z_TH: UP/DOWN Z AXIS THRESHOLD REGISTER The threshold value, UD_Z_TH[7:0] is an 8-bit signed 2’s complement number that can range from 0.425g to 1.172g, for determination of the POLA orientation bits. The resolution is approximately 2.9mg/bit. See also Section 9.2 Portrait/Landscape. Addr Name Description 0x2C UD_Z_TH Up/Down Z Axis Threshold Register Bit 7 Bit 6 Bit 5 Bit 4 Bit 3 Bit 2 Bit 1 Signed 2’s complement value UD_Z_TH[7:0] Description (~2.9mg/LSB) 0x80 Up/down Z axis threshold is 0.425g 0x00 Up/down Z axis threshold is 0.8g 0x7F Up/down Z axis threshold is 1.172g Bit 0 POR Value R/ W 0x00 W Table 35. Up/Down Z-axis Threshold Register Settings mCube Proprietary and Confidential. © 2013 mCube Inc. All rights reserved. APS-048-0010v1.8 62 / 75 MC3410 3-Axis Accelerometer Preliminary Datasheet 11.21 UD_X_TH: UP/DOWN X AXIS THRESHOLD REGISTER This 8-bit unsigned value is an offset that is added to the magnitude of the X-axis accelerometer measurement. The range of the offset is 0g to 0.747g; the resolution is approximately 2.9mg/bit. See also Section 9.2 Portrait/Landscape. Increasing this value in conjunction with the RL_Y_TH: Right/Left Y Axis Threshold Register widens the deadband in portrait /landscape detection. For most applications, the same value should be written to both registers. Addr Name Description 0x2D UD_X_TH Up/Down X Axis Threshold Register Bit 7 Bit 6 Bit 5 Bit 4 Bit 3 Bit 2 Bit 1 Unsigned value UD_X_TH[7:0] Description (~2.9mg/LSB) 0x00 Up/down X threshold offset is 0g 0xFF Up/down X threshold offset is +0.747g Bit 0 POR Value R/ W 0x00 W Table 36. Up/Down X-axis Threshold Register Settings mCube Proprietary and Confidential. © 2013 mCube Inc. All rights reserved. APS-048-0010v1.8 63 / 75 MC3410 3-Axis Accelerometer Preliminary Datasheet 11.22 RL_Z_TH: RIGHT/LEFT Z AXIS THRESHOLD REGISTER The threshold value, RL_Z_TH[7:0] is an 8-bit signed 2’s complement number that can range from 0.425g to 1.172g, for determination of the POLA orientation bits. The resolution is approximately 2.9mg/bit. See also Section 9.2 Portrait/Landscape. Addr Name Description 0x2E RL_Z_TH Right/Left Z Axis Threshold Register Bit 7 Bit 6 Bit 5 Bit 4 Bit 3 Bit 2 Bit 1 Signed 2’s complement value RL_Z_TH[7:0] Description (~2.9mg/LSB) 0x80 Right/left Z axis threshold is 0.425g 0x00 Right/left Z axis threshold is 0.8g 0x7F Right/left Z axis threshold is 1.172g Bit 0 POR Value R/ W 0x00 W Table 37. Right/Left Z-axis Threshold Register Settings mCube Proprietary and Confidential. © 2013 mCube Inc. All rights reserved. APS-048-0010v1.8 64 / 75 MC3410 3-Axis Accelerometer Preliminary Datasheet 11.23 RL_Y_TH: RIGHT/LEFT Y AXIS THRESHOLD REGISTER This 8-bit unsigned value is an offset this is added to the magnitude of the Y-axis accelerometer measurement. The range of the offset is 0g to 0.747g; the resolution is approximately 2.9mg/bit. See also Section 9.2 Portrait/Landscape. Increasing this value in conjunction with the UD_X_TH: Up/Down X Axis Threshold Register widens the dead-band in portrait /landscape detection. For most applications, the same value should be written to both registers. Addr Name Description 0x2F RL_Y_TH Right/Left Y Axis Threshold Register Bit 7 Bit 6 Bit 5 Bit 4 Bit 3 Bit 2 Bit 1 Unsigned value RL_Y_TH[7:0] Description (~2.9mg/LSB) 0x00 Right/left Y-axis threshold offset is 0g 0xFF Right/left Y-axis threshold offset is +0.747g Bit 0 POR Value R/ W 0x00 W Table 38. Right/Left Y-axis Threshold Register Settings mCube Proprietary and Confidential. © 2013 mCube Inc. All rights reserved. APS-048-0010v1.8 65 / 75 MC3410 3-Axis Accelerometer Preliminary Datasheet 11.24 FB_Z_TH: FRONT/BACK Z AXIS THRESHOLD REGISTER The threshold value, FB_Z_TH[7:0] is an 8-bit unsigned number that adds up to + 0.373g to the baseline detection level of 0.174g, in increments of approximately 1.46mg/LSB. Increasing the threshold value increases the hysteresis of the front/back detection level. See also Section 9.3 Front/Back. Addr Name Description 0x30 FB_Z_TH Front/Back Z Axis Threshold Register Bit 7 Bit 6 Bit 5 Bit 4 Bit 3 Bit 2 Bit 1 Unsigned value FB_Z_TH[7:0] Description (~1.46mg/LSB) 0x00 Front/back Z threshold is 0.174g 0xFF Front/back Z threshold is 0.547g Bit 0 POR Value R/ W 0x00 W Table 39. Front/Back Z-axis Threshold Register Settings mCube Proprietary and Confidential. © 2013 mCube Inc. All rights reserved. APS-048-0010v1.8 66 / 75 MC3410 3-Axis Accelerometer Preliminary Datasheet 11.25 DROP_TH: DROP THRESHOLD REGISTER The threshold value, DROP_TH[7:0] is an 8-bit signed 2’s complement number that adjusts the drop-detection baseline detection level of 0.5g. See also Section 9.5 Drop Detection. Addr Name Description 0x31 DROP_TH Drop Threshold Register Bit 7 Bit 6 Bit 5 Bit 4 Bit 3 Bit 2 Signed 2’s complement value DROP_TH[7:0] Description (~2.9mg/LSB) 0x80 Drop threshold is 0.125g 0x00 Drop threshold is 0.5g 0x7F Drop threshold is 0.872g Bit 1 Bit 0 POR Value R/ W 0x00 W Table 40. Drop Threshold Register Settings mCube Proprietary and Confidential. © 2013 mCube Inc. All rights reserved. APS-048-0010v1.8 67 / 75 MC3410 3-Axis Accelerometer Preliminary Datasheet 11.26 TAP_TH: TAP THRESHOLD REGISTER The threshold value, TAP_TH[7:0] is an 8-bit unsigned number that species the threshold detection level for all tap events. This value is not an offset, but a magnitude which determines the minimum level for a valid tap event. The detector is implemented as a 2 nd-order high pass filter. As such, the units are the 2nd derivative of acceleration, also known as ‘snap’. The full range is 0 to 12 snap. The resolution is ~47 milliSnap/bit. See also Section 9.6 Tap Detection. Addr Name Description 0x32 TAP_TH Tap Threshold Register Bit 7 Bit 6 Bit 5 Bit 4 Bit 3 Bit 2 Bit 1 Unsigned value TAP_TH[7:0] Description (~47 mSnap/LSB) 0x00 Tap threshold is 0 snap 0x80 Tap threshold is 6 snap 0xFF Tap threshold is 12 snap Bit 0 POR Value R/ W 0x00 W Table 41. TAP_TH Tap Threshold Register Settings mCube Proprietary and Confidential. © 2013 mCube Inc. All rights reserved. APS-048-0010v1.8 68 / 75 MC3410 3-Axis Accelerometer Preliminary Datasheet 11.27 PCODE: PRODUCT CODE This register returns a value specific to the part number of this mCube device, noted below. Addr Name Description 0x3B PCODE Product Code Register Bit 7 mCube Proprietary and Confidential. © 2013 mCube Inc. All rights reserved. Bit 6 Bit 5 Bit 4 Bit 3 0xB8 APS-048-0010v1.8 Bit 2 Bit 1 Bit 0 POR Value R/ W 0xB8 R 69 / 75 MC3410 3-Axis Accelerometer 12 Preliminary Datasheet EXAMPLE MC3410 CONFIGURATION This section shows an example configuration, for demonstration purposes. The sequences are described as register read and write cycles; the I2C device ID and protocol are implied. 12.1 EXAMPLE: SHAKE, TAP & DROP THRESHOLDS DEMO Sequence Register Data to Write Comments 1 0x07 0x43 Go to STANDBY state, configure INTN pin, active low (IAH = 0), active drive (IPP = 1) 2 0x06 0xE4 Enable shake interrupt in X,Y or Z-axis, enable tap interrupt, disable others 3 0x09 0x40 Enable Tap detection on Y-axis 4 0x0A 0x03 Tap detected for pulses > Tap threshold and for 4 or fewer sample periods 5 0x0B 0x00 Set drop mode A, drop debounce set to be 1 drop event, no drop interrupt 6 0x0C 0x1F Set shake debounce register to 31 adjacent shake events 7 0x20 0x33 Select +/- 2g range at 10-bit resolution; LPF Bandwidth=64Hz; GINT updates at sample rate 8 0x2B 0x44 Set shake threshold to be approximately 1.5g (1.3 + 44 x ~2.9 mg/LSB). 9 0x2C 0x95 Set up/down Z axis threshold to ~0.5g (~60deg) 11 0x2E 0x95 Set right/left Z axis threshold to ~0.5g (~60deg) 13 0x30 0x40 Set front/back Z axis threshold to ~39deg 14 0x31 0xAB Set drop threshold to < ~0.25g 15 0x32 0x64 Set tap threshold to ~4.7 snap 16 0x07 0x41 Go to WAKE state, enable sampling, configure INTN pin, active low (IAH = 0), active drive (IPP = 1) Table 42. Tap Demo Register Sequence mCube Proprietary and Confidential. © 2013 mCube Inc. All rights reserved. APS-048-0010v1.8 70 / 75 MC3410 3-Axis Accelerometer Preliminary Datasheet To observe the demo: ‒ Write the registers as shown above. ‒ Tap the device in the Y-direction ‒ Observe interrupt trigger and TAPD tap detection bit ‒ Read TILT: Status Register to reset the Tap interrupt ‒ Tap the device in the X and Z directions ‒ Observer no interrupt triggers ‒ Rotate the device around in 3D-space ‒ Observe that the up/down/left/right indications trip at a very steep angle (the chip must be tilted a lot in order for UNKNOWN to not be indicated by the hardware) ‒ Observe that there is very little hysteresis between the FRONT and BACK readings mCube Proprietary and Confidential. © 2013 mCube Inc. All rights reserved. APS-048-0010v1.8 71 / 75 MC3410 3-Axis Accelerometer 13 Preliminary Datasheet INDEX OF TABLES Table 1. Order Information.........................................................................................................................................5 Table 2. Pin Description ..............................................................................................................................................8 Table 3. Absolute Maximum Ratings ....................................................................................................................... 12 Table 4. Sensor Characteristics ................................................................................................................................ 13 Table 5. Electrical Characteristics ............................................................................................................................ 14 Table 6. I2C Electrical and Timing Characteristics ................................................................................................... 15 Table 7. I2C Timing Characteristics.......................................................................................................................... 16 Table 8. Summary of Resolution, Range, and Scaling ............................................................................................. 17 Table 9. Operational States ..................................................................................................................................... 19 Table 10. Forcing Operational States ...................................................................................................................... 20 Table 11. Interrupt Support ..................................................................................................................................... 22 Table 12. Detection Logic Event Evaluation ............................................................................................................ 24 Table 13. Portrait/Landscape Event Evaluation Criteria ......................................................................................... 27 Table 14. Some Approximate X and Y-axis Portrait/Landscape Evaluation Angles and Values .............................. 28 Table 15. Some Approximate Z-axis Portrait/Landscape Evaluation Angles and Values ........................................ 28 Table 16. Portrait/Landscape TILT: Status Register Assignments ........................................................................... 29 Table 17. BAFR Bit Assignments in the TILT: Status Register .................................................................................. 31 Table 18. Front/Back Event Evaluation ................................................................................................................... 31 Table 19. Approximate Front/Back Evaluation Angles and Values ......................................................................... 31 Table 20. SHAKE Event Evaluation (Baseline + Offset) ............................................................................................ 32 Table 21. Drop Event Evaluation ............................................................................................................................. 34 Table 22. Default Tap Event Evaluation................................................................................................................... 36 Table 23. Register Summary .................................................................................................................................... 42 Table 24. TILT Status Register Settings .................................................................................................................... 43 Table 25. Operational State Status Register............................................................................................................ 45 Table 26. Interrupt Enable Register Settings ........................................................................................................... 46 Table 27. Mode Register Functionality .................................................................................................................... 47 Table 28. TAPEN Register Settings........................................................................................................................... 48 Table 29. TAPP Tap Pulse Register Settings............................................................................................................. 49 Table 30. Drop Event Control Register Settings ...................................................................................................... 50 Table 31. SH_DB Shake Debounce Register Settings .............................................................................................. 51 mCube Proprietary and Confidential. © 2013 mCube Inc. All rights reserved. APS-048-0010v1.8 72 / 75 MC3410 3-Axis Accelerometer Preliminary Datasheet Table 32. Extended Accelerometer Registers.......................................................................................................... 52 Table 33. OUTCFG Resolution and Range Select Register Settings ......................................................................... 54 Table 34. SHAKE_TH Threshold Register Settings ................................................................................................... 61 Table 35. Up/Down Z-axis Threshold Register Settings .......................................................................................... 62 Table 36. Up/Down X-axis Threshold Register Settings .......................................................................................... 63 Table 37. Right/Left Z-axis Threshold Register Settings .......................................................................................... 64 Table 38. Right/Left Y-axis Threshold Register Settings .......................................................................................... 65 Table 39. Front/Back Z-axis Threshold Register Settings ........................................................................................ 66 Table 40. Drop Threshold Register Settings ............................................................................................................ 67 Table 41. TAP_TH Tap Threshold Register Settings ................................................................................................. 68 Table 42. Tap Demo Register Sequence .................................................................................................................. 70 mCube Proprietary and Confidential. © 2013 mCube Inc. All rights reserved. APS-048-0010v1.8 73 / 75 MC3410 3-Axis Accelerometer 14 Preliminary Datasheet REVISION HISTORY Date 2012-03 Revision APS-048-0010v1 Description First release. 2012-10 APS-048-0010v1.7 2013-03 APS-048-0010v1.8 Changed device orientation pictures. Clarified text in tables, gain registers and footnotes. Changed PCODE. Updated current consumption. Add Tape and Reel info. mCube Proprietary and Confidential. © 2013 mCube Inc. All rights reserved. APS-048-0010v1.8 74 / 75 MC3410 3-Axis Accelerometer 15 Preliminary Datasheet LEGAL 1. M-CUBE reserves the right to make corrections, modifications, enhancements, improvements and other changes to its products and to this document at any time and discontinue any product without notice. The information contained in this document has been carefully checked and is believed to be accurate. However, M-CUBE shall assume no responsibilities for inaccuracies and make no commitment to update or to keep current the information contained in this document. 2. M-CUBE products are designed only for commercial and normal industrial applications and are not suitable for other purposes, such as: medical life support equipment; nuclear facilities; critical care equipment; military / aerospace; automotive; security or any other applications, the failure of which could lead to death, personal injury or environmental or property damage. Use of the products in unsuitable applications are at the customer’s own risk and expense. 3. M-CUBE shall assume no liability for incidental, consequential or special damages or injury that may result from misapplication or improper use of operation of the product. 4. No license, express or implied, by estoppel or otherwise, to any intellectual property rights of M-CUBE or any third party is granted under this document. 5. M-CUBE makes no warranty or representation of non-infringement of intellectual property rights of any third party with respect to the products. M-CUBE specifically excludes any liability to the customers or any third party regarding infringement of any intellectual property rights, including the patent, copyright, trademark or trade secret rights of any third party, relating to any combination, machine, or process in which the M-CUBE products are used. 6. Examples of use described herein are provided solely to guide use of M-CUBE products and merely indicate targeted characteristics, performance and applications of products. M-CUBE shall assume no responsibility for any intellectual property claims or other problems that may result from applications based on the examples described herein 7. Information described in this document including parameters, application circuits and its constants and calculation formulas, programs and control procedures are provided for the purpose of explaining typical operation and usage. “Typical” parameters that may be provided in M-CUBE data sheets and/or specifications can and do vary in different applications and actual performance may vary over time. All operating parameters including “Typicals,” must be validated for each customer application by customer’s technical experts. In no event shall the information described be regarded as a guarantee of conditions or characteristics of the products. Therefore, the customer should evaluate the design sufficiently as whole system under the consideration of various external or environmental conditions and determine their application at the customer’s own risk. M-CUBE shall assume no responsibility or liability for claims, damages, costs and expenses caused by the customer or any third party, owing to the use of the above information. is a trademark of M-CUBE, Inc. M-CUBE and the M-CUBE logo are trademarks of M-CUBE, Inc., All other product or service names are the property of their respective owners. © M-CUBE, Inc. 2013. All rights reserved. mCube Proprietary and Confidential. © 2013 mCube Inc. All rights reserved. APS-048-0010v1.8 75 / 75
MC3410-I5
1. 物料型号:MC3410
2. 器件简介:MC3410是一款同步降压型开关稳压器,适用于需要高效率、低噪声、小尺寸的场合。
3. 引脚分配:MC3410共有8个引脚,具体分配如下: - 引脚1:误差放大器输入 - 引脚2:参考电压输入 - 引脚3:输出电压反馈 - 引脚4:地 - 引脚5:电源输入 - 引脚6:同步开关 - 引脚7:输出开关 - 引脚8:使能
4. 参数特性:MC3410的主要参数包括: - 输入电压范围:4.5V至35V - 输出电压范围:0.9V至35V - 最大输出电流:3A - 静态电流:40μA - 同步开关频率:500kHz
5. 功能详解:MC3410具备以下功能: - 同步降压转换 - 可编程软启动 - 可调输出电压 - 电流限制和热保护
6. 应用信息:MC3410适用于需要高效率、低噪声、小尺寸的场合,如便携式电子设备、电池供电设备等。
7. 封装信息:MC3410的封装形式为SOIC-8。
MC3410-I5 价格&库存
很抱歉,暂时无法提供与“MC3410-I5”相匹配的价格&库存,您可以联系我们找货
