SMD1812P050TF
SMD1812P050TF
    YENJI(台湾元基)
    表面贴装PTC可复位保险丝
SMD1812P050TF 数据手册
SMD1812 Series Positive Temperature Coefficient (PTC) Description The 1812 series provides surface mount resettable overcurrent protection with holding current from 0.1A to 3.0A. This series offers complete portfolio in terms of holding current and working voltage, and is suitable for wide range of applications. Features y RoHS compliant and lead-free y Low profile y Halogen-free y Fast response to fault current y Compact design saves board space y Compatible with high temperature solders Applications y USB hubs, ports and peripherals y Motherboard USB & IEEE 1394 protection y Set-top-box and HDMI y Optical disk drives y Game console port protection y General electronics Electrical Characteristics Maximum Time To Trip Current Time (A) (Sec.) I hold (A) Itrip (A) Vmax (Vdc) Imax (A) Pd typ (W) SMD1812P010TF SMD1812P010TF/60V 0.10 0.10 0.30 0.30 30 60 100 100 0.8 0.8 0.50 0.50 SMD1812P014TF SMD1812P020TF SMD1812P020TF/60 SMD1812P035TF/30 SMD1812P050TF SMD1812P050TF/30 SMD1812P075TF SMD1812P075TF/24 0.14 0.20 0.20 0.34 0.40 0.40 60 30 60 10 100 40 0.8 0.8 0.8 0.35 0.50 0.50 0.75 1.00 1.00 30 15 30 40 100 100 0.75 0.75 0.75 1.50 1.50 1.50 13.2 24 33 1.10 1.10 1.10 2.20 1.95 1.95 1.10 1.25 1.25 Part Number - SMD1812P075TF/33 SMD1812P110TF SMD1812P110TF/16 SMD1812P110TF/24 SMD1812P110TF/33 SMD1812P125TF/16 SMD1812P125TF SMD1812P150TF/8 SMD1812P150TF/12 SMD1812P150TF/16 SMD1812P150TF/24 SMD1812P160TF/8 SMD1812P160TF/16 SMD1812P200TFT SMD1812P200TF/12 SMD1812P200TF/16 SMD1812P260TFT SMD1812P260TF/12 SMD1812P260TF/16 SMD1812P300TFT Resistance Rmin () R1max () 1.50 1.50 1.600 1.600 15.000 15.000 1.50 8.00 1.00 0.15 0.02 2.00 1.500 0.800 1.400 6.000 5.000 4.400 0.8 0.8 0.8 8.00 8.00 8.00 0.15 0.15 0.15 0.400 0.150 0.150 1.700 1.000 1.000 100 100 20 0.8 0.8 0.8 8.00 8.00 8.00 0.20 0.20 0.20 0.100 0.110 0.110 0.450 0.290 0.400 8 16 24 100 100 20 0.8 0.8 0.8 8.00 8.00 8.00 0.30 0.30 0.50 0.040 0.060 0.060 0.210 0.180 0.200 1.95 2.50 2.50 33 16 6 20 100 100 0.8 0.8 0.8 8.00 8.00 8.00 0.50 0.40 0.40 0.060 0.050 0.050 0.200 0.140 0.140 1.50 1.50 1.50 3.00 3.00 2.80 8 12 16 100 100 100 0.8 0.8 0.8 8.00 8.00 8.00 0.30 0.50 0.50 0.040 0.040 0.040 0.110 0.110 0.110 1.50 1.60 1.60 2.00 3.00 2.80 2.80 3.50 24 8 16 8 20 100 100 100 0.8 0.8 0.8 0.8 8.00 8.00 8.00 8.00 1.50 1.00 0.50 2.00 0.040 0.030 0.030 0.020 0.120 0.100 0.100 0.070 2.00 2.00 3.50 3.50 12 16 100 100 1.0 1.0 8.00 8.00 2.00 2.00 0.020 0.020 0.070 0.070 2.60 2.60 2.60 5.00 5.00 5.00 8 12 16 100 100 100 0.8 0.8 1.2 8.00 8.00 8.00 2.50 5.00 5.00 0.015 0.015 0.015 0.047 0.055 0.050 3.00 5.00 6 100 0.8 8.00 4.00 0.012 0.040 1/7 SMD1812 Series Positive Temperature Coefficient (PTC) Note on Electrical Characteristics „ Vocabulary Ihold = Hold current: maximum current device will pass without tripping in 23ºC still air. Itrip = Trip current: minimum current at which the device will trip in 23 ºC still air. Vmax = Maximum voltage device can withstand without damage at rated current (I max) Imax = Maximum fault current device can withstand without damage at rated voltage (Vmax) Pd typ = Typical power dissipated from device when in the tripped state at 23 ºC still air. Rmin = Minimum resistance of device in initial (un-soldered) state. R1max = Maximum resistance of device at 23 ºC measured one hour after tripping or reflow soldering of 260 ºC for 20 sec. „ Value specified is determined by using the PWB with 0.030”*1.5oz copper traces. „ Caution: Operation beyond the specified rating may result in damage and possible arcing and flame. „ Specifications are subject to change without notice. Polymeric PTC Selecting Guide „ Determine the following operating parameters for the circuits: y Normal operating current (Ihold) Ɂ Maximum interrupt current (Imax) y Maximum circuit voltage (Vmax) Ɂ Normal operating temperature surrounding device (minºC/maxºC) y Surface Mount Device (SMD) Ɂ Axial Leaded Device (ALD) y Radial Leaded Device (RLD) Ɂ DISC Device !! !! „ Select the device form factor and dimension suitable for the application: !! Ɂ Other Customized Form Factors !! !! „ Compare the maximum rating for Vmax and Imax of the PPTC device with the circuit in application and make sure the circuit’s requirement does not exceed the device rating. „ Check that PPTC device’s trip time (time-to-trip) will protect the circuit. „ Verify that the circuit operating temperature is within the PPTC device’s normal operating temperature range. „ Verify the performance and suitability of the chosen PPTC device in the application. „ Mechanical Stress y PPTC devices will undergo a thermal expansion during fault condition. If PPTC devices are installed or placed in an application where the space between PPTC devices and the surrounding materials (e.g., covering materials, packaging materials, encapsulate materials and the like) is insufficient, it will cause an inhibiting effect upon the thermal expansion. Pressing, twisting, bending and other kinds of mechanical stress will also adversely affect the performance of the PPTC devices, and shall not be used or applied. „ Chemical Pollutants y Silicone-based oils, oils, solvents, gels, electrolytes, fuels, acids, and the like will adversely affect the properties of PPTC devices, and shall not be used or applied. „ Electronic and Thermal Effect y PPTC devices are secondary protection devices and are used solely for sporadic, accidental over-current or over-temperature error condition, and shall NOT be used if or when constant or repeated fault conditions (such fault conditions may be caused by, among others, incorrect pin-connection of a connector) or over-extensive trip events may occur. y PTTC devices are different from fuses and, when a fault condition occurs, will go into high-resistance state and do not open circuit, in which case the voltage at such PPTC devices may reach a hazardous level. y Operation over the maximum rating or other forms of improper use may cause failure, arcing, flame and/or other damage to the PPTC devices. y Conductive material contamination, such as metal particle, may induce shortage, flame or arcing. y Due to the inductance, the operation circuits may generate a circuit voltage (Ldi/dt) above the rated voltage of PPTC devices, which shall not be used under such circumstances. „ General y Customers shall evaluate and test the properties of PPTC devices independently to verify and ensure that their individual applications will be met. y The performance of PPTC devices will be adversely affected if they are improperly used under electronic, thermal and/or mechanical procedures and/or conditions non-conformant to those recommended by manufacturer. y Customers shall be responsible for determining whether it is necessary to have back-up, failsafe and/or fool-proof protection to avoid or minimize damage that may result from extra-ordinary, irregular function or failure of PPTC devices. y Any and all responsibilities and liabilities are disclaimed if any item under this notice of warning is not complied with. 2/7 SMD1812 Series Positive Temperature Coefficient (PTC) Thermal Derating Curve Percentage of Rated Current 200.00 150.00 100.00 50.00 0.00 -40.00 0.00 40.00 80.00 120.00 Device's Ambient Temperature (ɗ ) Thermal Derating Chart Recommended Hold Current (A) at Ambient Temperature (ºC) Part Number Ambient Operation Temperature -40 ºC -20 ºC 0 ºC 23 ºC 40 ºC 50 ºC 60 ºC 70 ºC 85 ºC SMD1812P010TF SMD1812P014TF SMD1812P020TF SMD1812P020TF-J SMD1812P035TF/30 SMD1812P050TF SMD1812P050TF/30 SMD1812P075TF SMD1812P075TF/24 SMD1812P075TF/33 SMD1812P110TF SMD1812P110TF/16 SMD1812P110TF/24 SMD1812P110TF/33 SMD1812P125TF/16 SMD1812P125TF/6,4L SMD1812P150TF/8 SMD1812P150TF/12 SMD1812P150TF/16 SMD1812P150TF/24 SMD1812P160TF/8(4L) SMD1812P160TF/16 SMD1812P200TFT SMD1812P200TF/12 0.16 0.23 0.29 0.29 0.50 0.77 0.77 1.15 1.06 1.10 1.59 1.58 1.55 1.55 2.00 2.00 2.06 2.04 2.04 2.05 2.20 2.20 2.60 2.60 0.14 0.19 0.26 0.26 0.45 0.68 0.68 1.01 0.95 1.00 1.43 1.43 1.40 1.40 1.75 1.75 1.93 1.88 1.88 1.87 2.06 2.06 2.44 2.44 0.12 0.17 0.23 0.23 0.40 0.59 0.59 0.88 0.84 0.88 1.26 1.27 1.25 1.25 1.52 1.52 1.79 1.68 1.68 1.67 1.91 1.91 2.22 2.22 0.10 0.14 0.20 0.20 0.35 0.50 0.50 0.75 0.75 0.75 1.10 1.10 1.10 1.10 1.25 1.25 1.50 1.50 1.50 1.50 1.60 1.60 2.00 2.00 0.08 0.12 0.17 0.17 0.30 0.44 0.44 0.65 0.60 0.66 0.95 0.95 0.93 0.93 1.00 1.00 1.28 1.25 1.25 1.25 1.36 1.36 1.78 1.78 0.07 0.10 0.15 0.15 0.26 0.40 0.40 0.60 0.55 0.60 0.87 0.85 0.83 0.83 0.95 0.95 1.10 1.10 1.10 1.08 1.17 1.17 1.67 1.67 0.06 0.09 0.14 0.14 0.24 0.37 0.37 0.55 0.50 0.56 0.80 0.77 0.73 0.73 0.90 0.90 1.02 1.00 1.00 0.95 1.09 1.09 1.50 1.50 0.05 0.08 0.12 0.12 0.20 0.33 0.33 0.49 0.45 0.47 0.71 0.71 0.63 0.63 0.75 0.75 0.80 0.80 0.80 0.77 0.85 0.85 1.45 1.45 0.03 0.06 0.10 0.10 0.16 0.29 0.29 0.43 0.37 0.36 0.60 0.58 0.50 0.50 0.53 0.53 0.68 0.60 0.60 0.60 0.72 0.72 1.29 1.29 SMD1812P200TF/16 2.60 2.44 2.22 2.00 1.78 1.67 1.50 1.45 1.29 SMD1812P260TFT SMD1812P260TF/12 SMD1812P260TF/16 SMD1812P300TFT 3.40 3.40 3.40 4.13 3.16 3.16 3.16 3.75 3.00 3.00 3.00 3.30 2.60 2.60 2.60 3.00 2.30 2.30 2.30 2.62 2.15 2.15 2.15 2.43 2.00 2.00 2.00 2.25 1.85 1.85 1.85 2.00 1.63 1.63 1.63 1.78 3/7 SMD1812 Series Positive Temperature Coefficient (PTC) Average Time-Current Curve AB C D 100.00 E FG A 炼SMD1812P110TF B 炼SMD1812P125TF/6,4L C 炼SMD1812P150TF/8 D 炼SMD1812P160TF/8(4L) 10.00 Time to Trip (Sec.) SMD1812P160TF/16 E 炼SMD1812P200TFT SMD1812P200TF/12 1.00 SMD1812P200TF/16 F 炼SMD1812P260TFT SMD1812P260TF/12 SMD1812P260TF/16 0.10 G 炼SMD1812P300TFT 0.01 1.00 10.00 Fault Current (Amp.) 100.00 Average Time-Current Curve AB 100.00 CD E A 炼SMD1812P050TF B 炼SMD1812P075TF C 炼SMD1812P110TF/16 D 炼SMD1812P125TF/16 10.00 Time to Trip (Sec.) E 炼SMD1812P150TF/12 SMD1812P150TF/16 1.00 0.10 0.01 0.10 1.00 10.00 Fault Current (Amp.) 4/7 100.00 SMD1812 Series Positive Temperature Coefficient (PTC) Average Time-Current Curve A 100.00 BC D E FGHI J A 炼SMD1812P010TF B 炼SMD1812P014TF C 炼SMD1812P020TF SMD1812P020TF-J 10.00 Time to Trip (Sec.) D 炼SMD1812P035TF/30 E 炼SMD1812P050TF/30 F 炼SMD1812P075TF/33 1.00 G 炼SMD1812P075TF/24 H 炼SMD1812P110TF/33 I 炼SMD1812P110TF/24 J 炼SMD1812P150TF/24 0.10 0.01 0.10 1.00 10.00 Fault Current (Amp.) 5/7 100.00 SMD1812 Series Positive Temperature Coefficient (PTC) Soldering Parameters Profile Feature Average Ramp-Up Rate (Tsmax to TP) Preheat -Temperature Min (Tsmin) -Temperature Max (Tsmax) -Time (Tsmin to Tsmax) Time maintained above: -Temperature (TL) -Time (tL) Peak Temperature (TP) Time within 5ºC of actual Peak Temperature (tP) Ramp-Down Rate Time 25ºC to Peak Temperature Storage Condition Pb-Free Assembly 3ºC/second max. 150ºC 200ºC 60-180 seconds 217ºC 60-150 seconds 260ºC 20-40 seconds 6 ºC /second max. 8 minutes max. 0ºC ~35ºC, ʀ70%RH y Recommended reflow methods: IR, vapor phase oven, hot air oven, N2 environment for lead-free y Recommended maximum paste thickness is 0.25mm (0.010 inch) y Devices can be cleaned using standard industry methods and solvents. Note 1: All temperature refer to topside of the package, measured on the package body surface. Note 2: If reflow temperatures exceed the recommended profile, devices may not meet the performance requirements. 6/7 SMD1812 Series Positive Temperature Coefficient (PTC) Physical Dimensions (mm.) Figure 2 Part Number SMD1812P010TF SMD1812P014TF SMD1812P020TF SMD1812P020TF-J SMD1812P035TF/30 SMD1812P050TF SMD1812P050TF/30 SMD1812P075TF SMD1812P075TF/24 SMD1812P075TF/33 SMD1812P110TF SMD1812P110TF/16 SMD1812P110TF/24 SMD1812P110TF/33 SMD1812P125TF/16 SMD1812P125TF/6,4L SMD1812P150TF/8 SMD1812P150TF/12 SMD1812P150TF/16 SMD1812P150TF/24 SMD1812P160TF/8(4L) SMD1812P160TF/16 SMD1812P200TFT SMD1812P200TF/12 SMD1812P200TF/16 SMD1812P260TFT SMD1812P260TF/12 SMD1812P260TF/16 SMD1812P300TFT A B C D E Min. Max. Min. Max. Min. Max. Min. Max. Min. Max. 4.37 4.37 4.37 4.37 4.37 4.37 4.37 4.37 4.37 4.37 4.37 4.37 4.37 4.37 4.37 4.37 4.37 4.37 4.37 4.37 4.37 4.37 4.37 4.37 4.37 4.37 4.37 4.54 4.37 4.73 4.73 4.73 4.73 4.73 4.73 4.73 4.73 4.73 4.73 4.73 4.73 4.73 4.73 4.73 4.73 4.73 4.73 4.73 4.73 4.73 4.73 4.73 4.73 4.73 4.73 4.73 4.90 4.73 3.07 3.07 3.07 3.07 3.07 3.07 3.07 3.07 3.07 3.07 3.07 3.07 3.07 3.07 3.07 3.07 3.07 3.07 3.07 3.07 3.07 3.07 3.07 3.07 3.07 3.07 3.07 3.16 3.07 3.41 3.41 3.41 3.41 3.41 3.41 3.41 3.41 3.41 3.41 3.41 3.41 3.41 3.41 3.41 3.41 3.41 3.41 3.41 3.41 3.41 3.41 3.41 3.41 3.41 3.41 3.41 3.50 3.41 0.75 0.75 0.55 0.75 0.65 0.50 0.50 0.50 0.75 0.75 0.30 0.75 0.55 1.20 0.75 0.45 0.40 0.75 0.75 0.80 0.40 0.75 0.20 0.80 0.80 0.50 0.80 1.20 0.50 1.25 1.95 1.00 1.25 1.25 0.75 1.00 0.75 1.55 1.55 0.71 1.25 1.07 2.00 1.25 0.75 0.71 1.25 1.25 1.80 0.75 1.25 0.60 1.20 1.20 1.00 1.34 2.00 1.00 0.30 0.30 0.30 0.30 0.30 0.30 0.30 0.30 0.30 0.30 0.30 0.30 0.30 0.30 0.30 0.30 0.30 0.30 0.30 0.30 0.30 0.30 0.30 0.30 0.30 0.30 0.30 0.30 0.30 1.20 1.20 1.20 1.20 1.20 1.20 1.20 1.20 1.20 1.20 1.20 1.20 1.20 1.20 1.20 1.20 1.20 1.20 1.20 1.20 1.20 1.20 1.20 1.20 1.20 1.20 1.20 1.20 1.20 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.65 0.65 0.65 0.65 0.65 0.50 0.65 0.50 0.65 0.65 0.65 0.65 0.65 0.65 0.65 0.65 0.65 0.65 0.65 0.65 0.65 0.65 0.65 0.65 0.65 0.65 0.65 0.65 0.65 7/7
SMD1812P050TF 价格&库存
很抱歉,暂时无法提供与“SMD1812P050TF”相匹配的价格&库存,您可以联系我们找货
SMD1812P050TF
  • 1+0.29998
  • 100+0.27998
  • 300+0.25998
  • 500+0.23998
  • 2000+0.22998
  • 5000+0.22398
