Features
Applications
■ Surface Mount Devices
Almost anywhere there is a low voltage
■ Lead free device
power supply, up to 15V and a load to be
■ Size 1.5*0.8 mm / 0.06*0.03 inch
protected, including:
■ Surface Mount packaging
■ Computer mother board, Modem. USB hub
for automated assembly
■ PDAs & Charger, Analog & digital line card
SMD0603 Series
■ Digital cameras, Disk drivers, CD-ROMs,
Alpha-Top (Sea & Land Alliance)
Performance Specification
Pd
Ihold
Itrip
Model
Marking
@25°C
@25°C
Typ.
(Vdc)
(A)
(A)
(A)
(W)
SMD0603-010
1
15.0
40
0.10
0.30
0.5
SMD0603-020
2
9.0
40
0.20
0.50
0.5
SMD0603-025
2
9.0
40
0.25
0.55
0.5
6.0
40
0.35
0.75
0.5
SMD0603-035
3
6.0
40
0.50
1.00
0.5
SMD0603-050
5
6.0
40
0.75
1.40
0.5
SMD0603-075
7
6.0
40
1.00
2.00
0.5
SMD0603-100
Ihold = Hold Current. Maximum current device will not trip in 25°C still air.
Itrip = Trip Current. Minimum current at which the device will always trip in 25°C still air.
Vmax = Maximum operating voltage device can withstand without damage at rated current (Imax).
Imax = Maximum fault current device can withstand without damage at rated voltage (Vmax).
Pd
= Power dissipation when device is in the tripped state in 25°C still air environment at rated voltage.
Rimin/max = Minimum/Maximum device resistance prior to tripping at 25°C.
R1max = Maximum device resistance is measured one hour post reflow.
CAUTION : Operation beyond the specified ratings may result in damage and possible arcing and flame.
Vmax
Imax
Maximum
Time To Trip
Current
Time
(A)
(Sec)
0.5
1.00
1.0
0.60
8.0
0.08
8.0
0.10
8.0
0.10
8.0
0.10
8.0
0.10
Environmental Specifications
Test
Conditions
Passive aging
+85°C, 1000 hrs.
Humidity aging
+85°C, 85% R.H. , 168 hours
Thermal shock
+85°C to -40°C, 20 times
Resistance to solvent
MIL-STD-202,Method 215
Vibration
MIL-STD-202,Method 201
Ambient operating conditions : - 40 °C to +85 °C
Maximum surface temperature of the device in the tripped state is 125 °C
AGENCY APPROVALS :
UL pending
Regulation/Standard:
2002/95/EC
Resistance
Rimin
(Ω)
0.900
0.550
0.500
0.200
0.100
0.060
0.040
Resistance change
±5% typical
±5% typical
±33% typical
No change
No change
EN14582
Ihold Versus Temperature
Model
SMD0603-010
SMD0603-020
SMD0603-025
SMD0603-035
SMD0603-050
SMD0603-075
SMD0603-100
Maximum ambient operating temperature (T mao ) vs. hold current (Ihold)
-40°C
0.13
0.27
0.32
0.47
0.67
0.98
1.30
-20°C
0.12
0.25
0.29
0.41
0.59
0.85
1.12
0°C
0.11
0.23
0.27
0.38
0.54
0.81
1.08
25°C
0.10
0.20
0.25
0.35
0.50
0.75
1.00
40°C
0.08
0.17
0.21
0.29
0.41
0.60
0.80
第2页
50°C
0.07
0.14
0.18
0.26
0.37
0.54
0.72
60°C
0.06
0.12
0.16
0.24
0.34
0.44
0.58
70°C
0.05
0.10
0.05
0.20
0.29
0.40
0.53
85°C
0.03
0.07
0.03
0.14
0.20
0.31
0.42
R1max
(Ω)
6.000
3.500
3.000
1.400
0.800
0.450
0.300
SMD0603 Series
Construction And Dimension (Unit:mm)
A
Model
Min.
SMD0603-010
1.45
SMD0603-020
1.45
SMD0603-025
1.45
SMD0603-035
1.45
SMD0603-050
1.45
1.45
SMD0603-075
1.45
SMD0603-100
B
Max.
1.85
1.85
1.85
1.85
1.85
1.85
1.85
Min.
0.65
0.65
0.65
0.65
0.65
0.65
0.65
Dimensions & Marking
A
Min.
0.40
0.40
0.40
0.40
0.50
0.50
0.50
Max.
1.00
1.00
1.00
1.00
1.10
1.10
1.10
E
Min.
0.10
0.10
0.10
0.10
0.10
0.10
0.10
Recommended Pad Layout (mm)
0.7 士0.1
1.0士0.1
0.7士0.1
1
B
D
Min.
0.15
0.15
0.15
0.15
0.15
0.15
0.15
C
Max.
1.05
1.05
1.05
1.05
1.05
1.05
1.05
1 = Part identification
D
E
1.0士0.1
C
Termination Pad Characteristics
Terminal pad materials:
Terminal pad solderability:
Tin-plated Nickel-Copper
Meets EIA specification RS186-9E and ANSI/J-STD-002 Category 3.
Rework
Use standard industry practices, the removal device must be replaced with a fresh one.
Thermal Derating Curve
Typical Time-To-Trip At 25°C
Derating Curves for SMD0603 Series
Average Time Current Curves
140
0.10A
120
0.20A
100
100
0.25A
80
60
0.35A
40
0.50A
0.75A
-20
60
1.00A
80
Temperature (°C)
Time In Seconds
Percentage of Derated Current
160
10
1
0.1
0.01
0.001
0.1
1 Current In Amperes 10
· Use PPTC beyond the maximum ratings or improper use may result in device damage and possible electrical arcing and flame.
· PPTC are intended for protection against occasional over current or over temperature fault conditions and should not be used when repeated fault conditions or prolonged trip events are anticipated.
· Device performance can be impacted negatively if devices are handled in a manner inconsistent with recommended electronic, thermal, and mechanical procedures for electronic components.
· Use PPTC with a large inductance in circuit will generate a circuit voltage (L di/dt) above the rated voltage of the PPTC.
· Avoid impact PPTC device its thermal expansion like placed under pressure or installed in limited space.
· Contamination of the PPTC material with certain silicon based oils or some aggressive solvents can adversely impact the performance of the devices. PPTC SMD can be cleaned by standard
methods.
· Requests that customers comply with our recommended solder pad layouts and recommended reflow profile. Improper board layouts or reflow profile could negatively impact solderability
performance of our devices.
第3页
SMD0603 Series
Recommended Solder Reflow Conditions
300
Preheating
Soldering
‧Recommended reflow methods:IR, vapor phase oven, hot air oven.
Cooling
‧Devices are not designed to be wave soldered to the bottom side
250
of the board.
200
‧Recommended maximum paste thickness is 0.25 mm (0.010 inch).
190
‧Devices can be cleaned using standard method and solvents.
160
Note:If reflow temperatures exceed the recommended profile,
100
devices may not meet the performance requirements.
60-120 sec.
30~60sec.
120 sec.
Tape And Reel Specifications (mm)
Paper Tape Component Dimensions
P0
Governing Specifications
W
P0
8.0 ± 0.2
4.0 ± 0.10
P1
4.0 ± 0.10
P2
2.0 ± 0.05
A0
1.05 ± 0.10
B0
1.85 ± 0.10
D0
1.55 + 0.05
F
E1
3.5 ± 0.05
1.75 ± 0.10
E2min.
6.25
T
0.75
T1max.
K0
D0
T
E1
Cover tape
A0
F
K0
B0
P1
EIA Reel Dimensions
0.75/0.95 ± 0.1
390
Trailer min.
160
W2(m easured at hub)
Reel Dimensions
W2
E2
B0
T1
W
0.1
Leader min.
A max.
N min.
W1
P2
178
60
9.0 ± 0.5
12.0 ± 0.05
A
N(hub dia.)
Cover tape
W1(m easured at hub)
Carrier tape
Emboss ed cavity
Storage And Handling
‧ Storage conditions:40°C max, 70% R.H.
‧ Devices may not meet specified performance
if storage conditions are exceeded.
Order Information
Packaging
SMD0603
Product name
Size 1508 mm / 0603 inch
SMD:surface mount device
Tape & reel packaging per EIA481-1
010
Hold
Current
0.10A
Labeling Information
Sea & Land Electronic Corp.
Pb
RoHS
Model:
Part no.:
Spec.:
Lot no.:
Q'ty:
倉儲:密封!溫度:18~33℃/濕度:30~60% A
第4页
Tape & Reel Quantity
5,000 pcs/reel
很抱歉,暂时无法提供与“SMD0603-010-24V”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 20+0.16001
- 200+0.15001
- 500+0.14001
- 1000+0.13001
- 3000+0.12501
- 6000+0.11801
- 国内价格
- 20+0.26615
- 200+0.21403
- 600+0.18509
- 5000+0.15340
- 10000+0.13831
- 20000+0.13020
- 国内价格
- 20+0.53020
- 100+0.31620
- 1000+0.22140
- 5000+0.15810
- 10000+0.15020
- 50000+0.13910
