RV2512FK-07750RL
RV2512FK-07750RL
    YAGEO(国巨)
    高压电阻 2512 750Ω ±1% 1W ±200ppm/℃
RV2512FK-07750RL 数据手册
DATA SHEET HIGH VOLTAGE CHIP RESISTORS RV series 0.5%, 1%, 5% sizes 0603/0805/1206/2010/2512 RoHS compliant IEC 62368-1 Safety Certificate issued by UL Demko: Product specification – July 02, 2017 V.7 sizes 0603/0805/1206 Product specification Chip Resistor Surface Mount RV 0603/0805/1206/2010/2512 (RoHS Compliant) SERIES ji3 SCOPE ORDERING INFORMATION - GLOBAL PART NUMBER & 12NC This specification describes RV0603/0805/1206/2010/2512 high voltage chip resistors with lead-free terminations made by thick film process. Both part numbers are identified by the series, size, tolerance, packing type, temperature coefficient, taping reel and resistance value. YAGEO BRAND ordering code GLOBAL PART NUMBER (PREFERRED ) APPLICATIONS  Converter  Printer equipment  Battery charger  Computer  Power supply FEATURES  RoHS compliant  Reducing environmentally hazardous wastes  High component and equipment reliability  Non-forbidden materials used in products/production  Halogen Free Epoxy  Moisture sensitivity level: MSL 1  IEC 62368-1:2014 safety certificate (G.10.2) issued by UL Demko for the following sizes and resistance ranges: - 0603: 100KΩ to 10MΩ - 0805: 100KΩ to 22MΩ - 1206: 100KΩ to 27MΩ 2 9 RV XXXX X X X XX XXXX L (1) (2) (3) (4) (5) (6) (7) (1) SIZE 0603/0805/1206/2010/2512 (2) TOLERANCE D = ± 0.5% F = ± 1% J = ± 5% (3) PACKAGING TYPE R = Paper/PE taping reel K = Embossed taping reel (4) TEMPERATURE COEFFICIENT OF RESISTANCE – = Base on spec (5) TAPING REEL 07 = 7 inch dia. Reel (6) RESISTANCE VALUE There are 2~4 digits indicated the resistor value. Letter R/K/M is decimal point, no need to mention the last zero after R/K/M, e.g.1K2, not 1K20. Detailed resistance rules show in table of “Resistance rule of global part number”. (7) DEFAULT CODE Letter L is system default code for ordering only (Note) Resistance rule of global part number Resistance code rule Example XXKX (10 to 97.6 KΩ) 10K = 10,000 Ω 97K6 = 97,600 Ω XXXK (100 to 976 KΩ) 100K = 10,000Ω 976K = 976,000Ω XMXX (1 to 9.76 MΩ) 1M = 1,000,000 Ω 9M76 = 9,760,000 Ω XXMX (10 to 16 MΩ) 10M = 10,000,000 Ω 27M = 27,000,000 Ω O RDERING EXAMPLE The ordering code of a RV1206 chip resistor, value 1 MΩ with ± 5% tolerance, supplied in 7-inch tape reel is: RV1206JR-071ML. NOTE 1. All our R-Chip products meet RoHS compliant. "LFP" of the internal 2D reel label mentions "Lead Free Process" 2. On customized label, "LFP" or specific symbol printed and the optional "L" at the end of GLOBAL PART NUMBER / 12NC can be added (both are on customer request) www.yageo.com Jul. 02, 2017 V.7 Product specification Chip Resistor Surface Mount RV SERIES 3 9 0603/0805/1206/2010/2512 (RoHS Compliant) PHYCOMP BRAND ordering codes Both GLOBAL PART NUMBER (preferred) and 12NC (traditional) codes are acceptable to order Phycomp brand products. GLOBAL PART NUMBER (PREFERRED ) For detailed information of GLOBAL PART NUMBER and ordering example, please refer to page 2. 12NC CODE 2322 XXX XXXXX L (1) SIZE TYPE (2) (3) Last digit of 12NC Resistance decade (3) (4) START TOL. RESISTANCE IN (1) (%) RANGE Last digit EMBOSSED (2) PAPER/PE (2) TAPE ON REEL TAPE ON REEL (units) 0.01 to 0.0976 Ω 0 0.1 to 0.976 Ω 4,000 7 5,000 1 to 9.76 Ω 0805 VRC11 ± 5% 47 to 10M Ω 8 2322 - 792 61xxx VRC12 ± 1% 47 to 10M Ω 10 to 97.6 Ω 9 2322 - 793 6xxxx 1206 VRC01 2322 ± 5% 47 to 27M Ω - 790 61xxx 100 to 976 Ω 1 VRC02 2322 ± 1% 47 to 10M Ω - 791 6xxxx 1 to 9.76 KΩ 2 2512 VPRC221 2322 ± 5% 47 to 16M Ω 762 98xxx 10 to 97.6 KΩ 3 100 to 976 KΩ 4 1 to 9.76 MΩ 5 10 to 97.6 MΩ 6 (1) The resistors have a 12-digit ordering code starting with 2322. (2) The subsequent 4 or 5 digits indicate the resistor tolerance and packaging. (3) The remaining 4 or 3 digits represent the resistance value with the last digit indicating the multiplier as shown in the table of “Last digit of 12NC”. (4) "L" is optional symbol (Note) . O RDERING EXAMPLE The ordering code of a VRC01 resistor, value 1 MΩ with ± 5% tolerance, supplied in tape of 5,000 units per reel is: 232279061105L or RV1206JR-071ML. - Example: 0.02 Ω = 0200 or 200 0.3 Ω = 3007 or 307 1Ω = 1008 or 108 33 KΩ = 3303 or 333 10 MΩ = 1006 or 106 NOTE 1. All our R-Chip products are RoHS compliant. "LFP" of the internal 2D reel label mentions "Lead Free Process" 2. On customized label, "LFP" or specific symbol printed and the optional "L" at the end of GLOBAL PART NUMBER / 12NC can be added (both are on customer request) www.yageo.com Jul. 02, 2017 V.7 Product specification Chip Resistor Surface Mount RV SERIES 0603/0805/1206/2010/2512 (RoHS Compliant) 4 9 MARKING RV0603/0805/1206/2010/2512 03 Fig. 1 Value=10 KΩ E-24 series: 3 digits, ±5% First two digits for significant figure and 3rd digit for number of zeros RV0603 0 Fig. 2 Value=24Ω E-24 series: 3 digits, ±0.5% & ±1% Exception values 10/11/13/15/20/75 of E24 series One short bar under marking letter E-96 series: 3 digits, ±0.5% & ±1% Fig. 3 Value=12.4 KΩ Including values 10/11/13/15/20/75 of E24 series First two digits for E-96 marking rule and 3rd letter for number of zeros RV0805/1206/2010/2512 00 Fig. 4 Value=10 KΩ Both E-24 and E-96 series: 4 digits, ±0.5% & ±1% First three digits for significant figure and 4th digit for number of zeros For further marking information, please refer to data sheet “Chip resistors marking”. CONSTRUCTION The resistor is constructed on top of a high-grade ceramic body. Internal metal electrodes are added on each end to make the contacts to the thick film resistive element. The composition of the resistive element is a noble metal imbedded into a glass and covered by a second glass to prevent environment influences. The resistor is laser trimmed to the rated resistance value. The resistor is covered with a protective epoxy coat, finally the two external terminations (matte tin on Nibarrier) are added. See fig.5 OUTLINES For dimension see Table 1 DIMENSIONS Table 1 For outlines see fig. 5 TYPE L (mm) W (mm) H (mm) I1 (mm) I2 (mm) RV0603 1.60 ± 0.10 0.80 ± 0.10 0.45 ± 0.10 0.25 ± 0.15 0.25 ± 0.15 RV0805 2.00 ± 0.10 1.25 ± 0.10 0.50 ± 0.10 0.35 ± 0.20 0.35 ± 0.20 RV1206 3.10 ± 0.10 1.60 ± 0.10 0.55 ± 0.10 0.40 ± 0.20 0.45 ± 0.20 RV2010 5.00± 0.10 2.50± 0.15 0.55± 0.10 0.45± 0.15 0.50± 0.20 RV2512 6.35 ± 0.10 3.10 ± 0.15 0.55 ± 0.10 0.60 ± 0.20 0.50 ± 0.20 Fig. 5 Chip resistor outlines www.yageo.com Jul. 02, 2017 V.7 Product specification Chip Resistor Surface Mount RV SERIES 0603/0805/1206/2010/2512 (RoHS Compliant) 5 9 ELECTRICAL CHARACTERISTICS Table 2 RESISTANCE RANGE TYPE Rated Power Operating Temperature Range CHARACTERISTICS Max. Max. Working Overload Voltage Voltage Dielectric Withstanding Voltage Temperature Coefficient of Resistance 5% (E-24) 47Ω to 10MΩ RV0603 1% (E-24/E-96) 47Ω to 10MΩ 0.5% (E-24/E-96) 47Ω to 10MΩ 1/10W 350V 500V 500V 400 V 800 V 800 V 500 V 1,000 V 1,000 V 3/4W 500 V 1,000 V 1,000 V 1W 500 V 1,000 V 1,000 V RV0805 5% (E-24) 47Ω to 22MΩ 1% (E-24/E-96) 47Ω to 22MΩ 0.5% (E-24/E-96) 47Ω to 10MΩ 1/8 W RV1206 5% (E-24) 47Ω to 27MΩ 1% (E-24/E-96) 47Ω to 27MΩ 0.5% (E-24/E-96) 47Ω to 15MΩ 1/4 W –55 °C to +155 °C ± 200 ppm/°C 5% (E-24) 47Ω to 22MΩ RV2010 RV2512 1% (E-24/E-96) 47Ω to 22MΩ 0.5% (E-24/E-96) 47Ω to 10MΩ 5% (E-24) 47Ω to 16MΩ 1% (E-24/E-96) 47Ω to 16MΩ 0.5% (E-24/E-96) 47Ω to 10MΩ FOOTPRINT AND SOLDERING PROFILES For recommended footprint and soldering profiles, please refer to data sheet “Chip resistors mounting”. PACKING STYLE AND PACKAGING QUANTITY Table 3 Packing style and packaging quantity PACKING STYLE REEL DIMENSION RV0603 RV0805 RV1206 RV2010 RV2512 Paper/PE taping reel (R) 7" (178 mm) 5,000 5,000 5,000 --- --- Embossed taping reel (K) 7" (178 mm) --- --- --- 4,000 4,000 NOTE 1. For Paper/PE/Embossed tape and reel specification/dimensions, please refer to data sheet “Chip resistors packing”. www.yageo.com Jul. 02, 2017 V.7 Product specification Chip Resistor Surface Mount RV SERIES 0603/0805/1206/2010/2512 (RoHS Compliant) 6 9 FUNCTIONAL DESCRIPTION O PERATING TEMPERATURE RANGE Range: –55 °C to +155 °C P OWER RATING Each type rated power at 70 °C: RV0603=1/10W; RV0805=1/8W; RV1206=1/4W; RV2010=3/4W; RV2512=1W R ATED VOLTAGE The DC or AC (rms) continuous working voltage corresponding to the rated power is determined by the following formula: V= or max. working voltage whichever is less Fig. 6 Maximum dissipation (P max ) in percentage of rated power as a function of the operating ambient temperature (T amb) Where V = Continuous rated DC or AC (rms) working voltage (V) P = Rated power (W) R = Resistance value (Ω) Maximum working voltage can be applicable to resistors only if the resistance value is equal to or higher than the critical resistance value. www.yageo.com Jul. 02, 2017 V.7 Product specification Chip Resistor Surface Mount RV SERIES 0603/0805/1206/2010/2512 (RoHS Compliant) 7 9 TESTS AND REQUIREMENTS Table 4 Test condition, procedure and requirements TEST TEST METHOD PROCEDURE Life/ Operational Life/ Endurance MIL-STD-202G-method 108A 1,000 hours at 70± 5 °C applied RCWV 1.5 hours on, 0.5 hour off, still air required High Temperature Exposure/ Endurance at upper category temperature MIL-STD-202G-method 108A Moisture Resistance MIL-STD-202G-method 106F IEC 60115-1 4.24.2 IEC 60115-1 4.25.1 REQUIREMENTS ± (2%+0.05 Ω) JIS C 5202-7.10 IEC 60115-1 4.25.3 1,000 hours at maximum operating temperature depending on specification, unpowered JIS C 5202-7.11 No direct impingement of forced air to the parts ± (1%+0.05 Ω) Tolerances: 155± 3 °C Each temperature / humidity cycle is defined at 8 hours (method 106F), 3 cycles / 24 hours for 10d with 25 °C / 65 °C 95% R.H, without steps 7a & 7b, unpowered ± (2%+0.05 Ω) Parts mounted on test-boards, without condensation on parts Measurement at 24± 2 hours after test conclusion Thermal Shock MIL-STD-202G-method 107G -55/+125 °C Note: Number of cycles required is 300. Maximum transfer time is 20 seconds. Dwell time is 15 minutes. Air – Air Short time overload MIL-R-55342D-para 4.7.5 Board Flex/ Bending IEC60115-1 4.33 IEC60115-1 4.13 ± (0.5%+0.05 Ω) for 10 KΩ to 10 MΩ ± (1%+0.05 Ω) for others 2.5 times RCWV or maximum overload voltage whichever is less for 5 sec at room temperature ± (2%+0.05 Ω) Device mounted on PCB test board as described, only 1 board bending required Bending for 0603 & 0805: 3mm 1206 & above: 2mm Holding time: minimum 60 seconds ± (1%+0.05 Ω) No visible damage No visible damage Ohmic value checked during bending Humidity IEC 60115-1 4.24.8 Steady state for 1,000 hours at 40℃ / 95% R.H. RCWV applied for 1.5 hours on and 0.5 hour off ± (3.0%+0.05Ω ) www.yageo.com Jul. 02, 2017 V.7 Product specification Chip Resistor Surface Mount RV SERIES 0603/0805/1206/2010/2512 (RoHS Compliant) 8 9 TEST TEST METHOD PROCEDURE REQUIREMENTS Solderability - Wetting IPC/JEDECJ-STD-002B test B Electrical Test not required Well tinned (≥95% covered) IEC 60068-2-58 Magnification 50X No visible damage SMD conditions: 1st step: method B, aging 4 hours at 155 °C dry heat 2nd step: leadfree solder bath at 245± 3 °C Dipping time: 3± 0.5 seconds - Leaching - Resistance to Soldering Heat IPC/JEDECJ-STD-002B test D No visible damage IEC 60068-2-58 Leadfree solder, 260 °C, 30 seconds immersion time MIL-STD-202G-method 210F Condition B, no pre-heat of samples ± (1%+0.05 Ω) IEC 60068-2-58 Leadfree solder, 260 °C, 10 seconds immersion time No visible damage Procedure 2 for SMD: devices fluxed and cleaned with isopropanol www.yageo.com Jul. 02, 2017 V.7 Product specification Chip Resistor Surface Mount RV SERIES 0603/0805/1206/2010/2512 (RoHS Compliant) 9 9 REVISION HISTORY REVISION DATE CHANGE NOTIFICATION DESCRIPTION Version 7 Jul. 06, 2017 - - Add IEC62368-1 safety certificate declaration for sizes 0603/0805/1206 Version 6 Dec. 01, 2016 - - Extend resistor value of RV1206 0.5% Version 5 Aug. 27, 2015 - - Extend resistor range and add 0.5% Version 4 Jan. 27, 2014 - - RV0603 resistance range extend to 10MΩ - Add RV2010 Version 3 Aug. 26, 2013 - - Add RV0603 Version 2 Sep 29, 2011 - - Type error correction Version 1 Nov 19, 2008 - - Change to dual brand datasheet that describes RV0805/1206/2512 with RoHS compliant - Description of "Halogen Free Epoxy" added - Define global part number Version 0 Feb 14, 2006 - - New datasheet for high voltage chip resistors sizes of 0805/1206/2512, 5%, 1% tolerance with lead-free terminations - Replace the 0805/1206/2512 parts of pdf files: VRC01_02_11_12_51_3.pdf, VPRC221_5_3.pdf, and combine into a document. - Test method and procedure updated - PE tape added (paper tape will be replaced by PE tape) “ Yageo reserves all the rights for revising the content of this datasheet without further notification, as long as the products itself are unchanged. Any product change will be announced by PCN.” www.yageo.com Jul. 02, 2017 V.7 Mouser Electronics Authorized Distributor Click to View Pricing, Inventory, Delivery & Lifecycle Information: Yageo: RV1206JR-071ML RV1206JR-0710ML RV1206JR-0722ML RV1206JR-07750KL RV1206FR-071ML RV1206FR072ML RV1206JR-07220KL RV1206JR-07470KL RV1206FR-07200KL RV1206JR-073M3L RV0805FR-07750KL RV1206JR-071M5L RV0805FR-071M2L RV0805FR-071M5L RV0805FR-071M62L RV0805FR-071M8L RV0805FR071ML RV0805FR-07255KL RV0805FR-07301KL RV0805FR-07499KL RV0805FR-07619KL RV0805FR-07665KL RV0805JR-071ML RV0805JR-07300KL RV1206FR-07150KL RV1206FR-071M3L RV1206FR-071M62L RV1206FR071M8L RV1206FR-072M26L RV1206FR-07316KL RV1206FR-07392KL RV1206FR-073ML RV1206FR-07470KL RV1206FR-07499KL RV1206FR-07510KL RV1206FR-07549KL RV1206FR-07560KL RV1206FR-07590KL RV1206FR-07681KL RV1206FR-07825KL RV1206JR-07180KL RV1206JR-071M8L RV1206JR-0727ML RV1206JR07360KL RV1206JR-07390KL RV1206JR-075M6L RV1206JR-07620KL RV1206JR-076M8L RV1206JR-07910KL RV1206JR-079M1L RV1206FR-071M4L RV0805JR-074M7L RV0805FR-07390KL RV1206FR-071M5L RV1206JR0751KL RV1206FR-07680KL RV1206FR-0751K1L RV1206FR-073M01L RV1206FR-073M6L RV1206JR-07100KL RV1206FR-072M7L RV1206JR-072ML RV0805FR-07180KL RV1206FR-07806KL RV1206FR-07249KL RV1206FR07221KL RV0805FR-072M7L RV1206FR-07402KL RV1206JR-073M9L RV1206FR-071M1L RV1206FR-07280KL RV1206FR-075M11L RV0805FR-075M11L RV1206JR-073M6L RV1206FR-071M33L RV0805JR-07680KL RV1206FR-0710KL RV0603FR-07243KL RV0805FR-07200KL RV1206FR-07562KL RV1206FR-07274KL RV0805FR-073M9L RV0805FR-07150KL RV1206FR-074M3L RV0805FR-07560KL RV1206FR-076M2L RV1206FR07332KL RV0805FR-071M3L RV0805JR-0710ML RV1206FR-07165KL RV1206FR-07243KL RV1206FR-072M4L RV0805FR-07787KL RV1206FR-07390KL RV1206FR-07475KL RV1206FR-07511KL RV1206FR-0775KL RV1206FR-071M2L RV1206JR-07270KL RV1206FR-07750KL
RV2512FK-07750RL
物料型号:RV系列,包括0603、0805、1206、2010和2512尺寸。
器件简介:这些是高电压芯片电阻器,采用无铅端接的厚膜工艺制造,符合RoHS标准,具有高组件和设备可靠性。
引脚分配:文档中没有提供具体的引脚分配图,但通常这类电阻是对称的,两边各有一个端接。
参数特性: - 公差:±0.5%(D级)、±1%(F级)、±5%(J级) - 温度系数:基于规格书 - 额定功率:根据尺寸不同,从1/10W到1W不等 - 最大工作电压和过载电压:根据尺寸和公差不同,从350V到1000V不等 - 湿度敏感等级:MSL 1
功能详解: - 电阻器构建在高级陶瓷基板上,内部金属电极接触厚膜电阻元件。 - 电阻元件由嵌入玻璃中的贵金属组成,上面覆盖第二层玻璃以防止环境影响。 - 电阻通过激光修调至额定电阻值。 - 电阻覆盖有保护性环氧涂层,最后添加两个外部端接(Ni屏障上的亚锡)。
应用信息:适用于转换器、打印机设备、电池充电器、电源、计算机等。
封装信息:提供卷带包装,包括纸带(R)、压花带(K)等,具体包装尺寸和数量见文档表格。
RV2512FK-07750RL 价格&库存
很抱歉,暂时无法提供与“RV2512FK-07750RL”相匹配的价格&库存,您可以联系我们找货
