1XXA26000MAA
1XXA26000MAA
    KDS(大真空)
    SMD2520_4P
    有源晶振 10pF 26MHz 2.8V ±2ppm SMD2520_4P
1XXA26000MAA 数据手册
Serial No. : 2014-1356 DATE : 2014/11/18 MediaTek Inc. CRYSTAL OSCILLATOR ITEM : DSA221SDN TYPE : ---------------------- - - - - - - -- - - - - - - -- - - - - - - -- - - - - - - -- - - - - - - -- - - - - - - -- - - - - - - -- - - - - - - -- - - - - - - -- - - - - - - -- - - - - - - -- - - - - - - -- - - - - - - -- -- - 26.000MHz NOMINAL FREQUENCY : ---------------------- - - - - - -- - - - - - - -- - - - - - - -- - - - - - - -- - - - - - - -- - - - - - - -- - - - - - - -- - - - - - - -- - - - - - - -- - - - - - - -- - - - - - - -- - - - - - - -- - - - - - - -- - - - 1XXA26000MAA SPEC No. : ---------------------- - - - - - - -- - - - - - - -- - - - - - - -- - - - - - - -- - - - - - - -- - - - - - - -- - - - - - - -- - - - - - - -- - - - - - - -- - - - - - - -- - - - - - - -- - - - - - - -- - - - - - - -- -- - ---------------------- - - - - - - -- - - - - - - -- - - - - - - -- - - - - - - -- - - - - - - -- - - - - - - -- - - - - - - -- - - - - - - -- - - - - - - -- - - - - - - -- - - - - - - -- - - - - - - -- - - - - - - -- -- - RECEIPT DATE RECEIVED (signature) (name) General Manufacture of Quartz Devices 1389 Shinzaike, Hiraoka-cho, Kakogawa, Hyogo 675-0194 Japan Phone (81)79-425-3141 Fax (81)79-425-1134 http://www.kds.info/index_en.htm C.ENG. ENG. Serial No.2014-1356 1. Device Name VC-TCXO 2. Model Name DSA221SDN 3. Nominal Frequency 26.000 MHz 4. Mass 0.02g max. 5. Absolute Maximum Ratings 1 2 Item Supply Voltage Storage Temperature Range Symbol VCC T_STG Rating -0.3~+4.6 -40~+85 unit V C 6. Recommended Operating Conditions 1 2 3 4 Item Supply Voltage Load Impedance (resistance part) (parallel capacitance) Control Voltage Range Operating Temperature Range TITLE Symbol VCC LOAD_R LOAD_C VCONT T_OPR min. +2.66 9 9 +0.4 -40 typ. +2.8 10 10 +1.4 - max. +2.94 11 11 +2.4 +85 unit V kΩ pF V C Remark DSA221SDN TYPE SPECIFICATION Date 2014/11/18 Spec. No. Rev. 1XXA26000MAA DAISHINKU CORP. - Page 1/14 DM-Z0002: Style-010 Ver.1 Serial No.2014-1356 7. Electrical Characteristics (TA=-40~+85C, LOAD_R//C=10kΩ//10pF, VCC=+2.8V, VCONT=+1.4V, unless otherwise noted) Item 1 2 3 4 5 Current Consumption Output Level Symmetry Harmonics Frequency Stability 1.Tolerance 2.vs Temperature 3.vs Slope 4.vs Hysteresis 5.vs Supply Voltage 6.vs Load Variation 7.vs Aging 6 Start Up Time 7 8 G Sensitivity Frequency Control 1.Control Range 2.Input Resistance SSB Phase Noise 9 10 Notes Root Allan Variance Conditions GND level (DC cut) After 2 times reflow Ref. to nominal frequency TA=-30~+85C VCONT=+1.4V Ref. to frequency (TA=+25C) TA=-40~-30C VCONT=+1.4V Ref. to frequency (TA=+25C) TA=-20~+65C TA=-30~+85C TA=-40~-30C VCC=+2.8V±0.14V LOAD_R//C=(10kΩ//10pF)±10% TA=Room ambient TA=Room ambient TA=Room ambient TA=Room ambient @90% of final Vout level Within ±0.5ppm of final frequency within 30 to 1500Hz VCONT=+1.4V±1.0V Relative to f0 level offset 1Hz Relative to f0 level offset 10Hz Relative to f0 level offset 100Hz Relative to f0 level offset 1kHz Relative to f0 level offset 10kHz Relative to f0 level offset 100kHz Tau=1sec min. 0.8 40/60 - Limits typ - max. +1.5 60/40 -8 mA VP-P % dBc - - ±2.0 ppm - - ±0.5 ppm - - ±3.0 ppm - - ±0.05 ±0.1 ±0.35 ±0.6 ±0.1 ±0.1 ±1.0 ±1.5 ±2.5 ±5.0 2.0 2.0 2.0 ppm/C ppm/C ppm/C ppm ppm ppm ppm/year ±9 100 - - ±15 -50 -80 -105 -130 -145 -150 0.3 ppm kΩ dBc/Hz dBc/Hz dBc/Hz dBc/Hz dBc/Hz dBc/Hz ppb unit Notes 1 2,3 ppm/2years ppm/5years ppm/10years ms ms ppb/G 4 1. Clipped sine wave (DC-coupled) 2. TA=+25C 3. Please leave after reflow in 2h or more at room ambient. 4. Positive slope (Frequency becomes high in proportion to frequency control voltage.) TITLE Remark DSA221SDN TYPE SPECIFICATION Date 2014/11/18 Spec. No. Rev. 1XXA26000MAA DAISHINKU CORP. - Page 2/14 DM-Z0002: Style-010 Ver.1 Serial No.2014-1356 8. Outline, Pin Connections Outline Pin Connections #4 Pin No. #1 #2 #3 #4 #3 (1) (3) (2) Connection VCONT GND Output VCC Marking (4) #1 #2 #1 Index (1) Model code AN (2) Frequency 26.0 (MHz, 3digits) (3) Logo D (4) Date code Year (1digit) +Week (2digits) 401 e.g.2014/1/1 unit: mm Dimensional Tolerance: ±0.15 (Unless otherwise noted) #1 #2 #4 #3 9. Measurement Circuit 1000pF T.P. mA #3 #4 + 10000pF Power Supply Vcc VC-TCXO V VCONT - Output GND #1 VCONT TITLE LOAD_C LOAD_R #2 LOAD_R=10kΩ LOAD_C=10pF (Include Jig stray capacitance) Remark DSA221SDN TYPE SPECIFICATION Date 2014/11/18 Spec. No. Rev. 1XXA26000MAA DAISHINKU CORP. - Page 3/14 DM-Z0002: Style-010 Ver.1 Serial No.2014-1356 10. Mechanical Characteristics All test is performed after 3times reflow (Clause.13) except 10.10 (Resistance to soldering heat) Item 1 2 3 4 5 Drop Vibration Shock PCB bend strength Adherence nature 6 Package strength 7 Gross leak 8 Fine leak 9 Solderability 10 Resistance to soldering heat Description Requirements Natural drop (On concrete) Mounting on the set or test fixture.(Total weight 100g) Height : 150cm Direction : X,Y,Z, 6directions Test cycle : 3cycles Reference specification : EIAJ-ED-4702A Method5 Sweep range : 10~500Hz Sweep speed : 11min/cycle Amplitude : 1.5mm (10~55Hz) 2 Acceleration : 200m/s (55~500Hz) Direction : X,Y,Z, 3directions Test cycle : 10cycles Reference specification : IEC 60068-2-6 2 Acceleration : 1000m/s Direction : X,Y,Z, 6directions Duration : 6ms Test cycle : 3cycles/each directions Reference specification : IEC 60068-2-27 PWB : t=1.6mm Pressure speed : 1.0mm/s Bend width : 1 2 3mm Duration : 10±1s Reference specification : IEC 60068-2-21 Ue1 PWB : t=1.6mm Direction : X,Y, 2directions Pressure : 10N Duration : 10±1s Reference specification : IEC 60068-2-21 Ue3 Pressure : 10N Duration : 10±1s Reference specification : IEC 60068-2-77 It is immersed for 3min into +125±5C Chlorofluorocarbon (CFCs) liquid. Reference specification : IEC 60068-2-17 It shall be measured by the helium leak detector after pressurization for 60min by the pressure 5 of (3.92±0.49) x10 Pa in a helium gas atmosphere. Reference specification : IEC 60068-2-17 Solder bath temperature : +245±5C Duration : 3±0.3s Reference specification : IEC 60068-2-58 1) Solder iron method Bit size : B(φ3) Bit temperature : +350±10C Duration : 3+1/-0s /each terminal It shall be measured after 2h at room temperature, humidity. Reference specification : IEC 60068-2-20 2) Reflow In refer to temperature profile shown in clause13. Test cycle : 3cycles It shall be measured after 2h at room temperature, humidity. Reference specification : IEC 60068-2-58 TITLE df/f=
1XXA26000MAA 价格&库存
很抱歉,暂时无法提供与“1XXA26000MAA”相匹配的价格&库存,您可以联系我们找货
1XXA26000MAA
    • 1+3.86640
    • 10+3.11040
    • 30+2.74320
    • 100+2.35224
    • 500+2.12771
    • 1000+2.02079
    库存:1257
