DSX321G 32MHz 12PF 10PPM
    KDS(大真空)
    SMD3225_4P
    无源晶振 32MHz 12pF ±10ppm 60Ω -40℃~+85℃ SMD3225_4P
DSX321G 32MHz 12PF 10PPM 数据手册
Serial No. 2004-0754 DATE : 2004/06/18 MESSRS.: QUARTZ CRYSTAL ITEM : ITEM : DSX321G NOMINAL FREQUENCY : 32.000000MHz SPEC No. : Please acknowledge receipt of the specification attached hereto signing and returning to us one copy thereof. RECEIVED OF SPECIFICATION DATE (signature) RECEIVED (name) Pioneering New Breakthroughs in Electronics DAISHINKU CORP. 1389 Shinzaike, Hiraoka-cho, Kakogawa, Hyogo 675-0194 Japan Phone(0794)25-3141 Fax(0794)25-1134 C.ENG. ENG. Serial No. 2004-0754 1. ELECTRICAL CHARACTERISTICS (This test shall be performed under the conditions of temp.at 25 +/- 3deg. C, humidity 60% max.) 1. 1 NOMINAL FREQUENCY 1. 2 MODE 32.000000 MHz Fundamental 1. 3 LOADING CAPACITANCE 1. 4 FREQUENCY TOLERANCE 1. 5 DRIVE LEVEL 12.0 pF +/- 10 10 1. 6 EQUIVALENT SERIES RESISTANCE 1. 7 OPERATING TEMPERATURE RANGE 1. 8 FREQUENCY TEMPERATURE CHARACTERISTICS ppm Max. at +25 deg.C +/- 3 deg.C uW +/60 -40 2 uW ohms Max. / Series deg.C +/-30 to +85 ppm Max. / deg.C -40 to 1. 9 SHUNT CAPACITANCE 2.0 pF Max. 1.10 INSULATION RESISTANCE 500 Mohms Min. / DC100V +/- 15V 1.11 STORAGE TEMPERATURE RANGE -40 deg.C to +85 +85 deg.C deg.C 2.CONSTRUCTION 2. 1 HOLDER DSX321G Ceramic Base 2. 2 DIMENSIONS AND MARKING Refer to Fig.-1 and Table-1. 3.OTHER SPECIFICATIONS 3. 1 EMBOSS CARRIER TAPE & REEL Refer to Fig.-2,3,4,5 and Table-2. 3. 2 SPECIAL MATTERS 1.REFLOW CONDITIONS (REFERENCE) 2.LAND PATTERN (REFERENCE) Refer to Fig.-6. Refer to Fig.-7. TITLE Trigonometry Unit Scale Drawing No. Rev. Page DSX321G TYPE SURFACE MOUNT TYPE QUARTZ CRYSTAL SPECIFICATION Date 2004/06/18 1 / 6 DM-Z0008:Style-108 < DIMENSIONS AND MARKING > 0 .15 2 .50+ / -0 .1 3 .20+ / -0 .1 D1 2 F requency Lo t No . 8 - (0 .10 ) 0 .75+ / -0 .15 Logo ## 11 # 22 ## 34 4 ## 3 0 .70 (0 .90 ) 0 .70 C0 .30( I NDEX) < T O P V I EW > 0 .90 (1 .20 ) 0 .90 # 4 # 3 # 1 # 2 un i t : mm Ma rk ing #2 ,#4 is no t connec ted w i th any th ing . To le rance : + / -0 .1 (Fig.-1) Marking is Laser Marking: Marking should be printed as follows: Logo , Nominal Frequency , manufactured year & month Nominal Frequency ( 1 ) = Mark two dights from upper ( ex. 32.000000 MHz --> 32 ) Manufacturing lot No.( 2 ) (year) ex. 2004 shall be marked as ‘ 4 ’ (The last digit of the year) (Month) ex. Jun. shall be marked as‘ F ’(As shown on the Table-1.) Jan. A Feb. B (Table-1) Mar. C Apr. D May. E Jun. F TITLE Jul. G Aug. H Sep. J Oct. K Nov. L Dec. M Trigonometry Unit Scale Drawing No. Rev. Page DSX321G TYPE SURFACE MOUNT TYPE QUARTZ CRYSTAL SPECIFICATION Date 2004/06/18 2 / 6 DM-Z0008:Style-108 < EMBOSS CARRIER TAPE & REEL > 1 .55d ia .+ / -0 .05 2 . 0+ / -0 . 05 4 . 0+ / -0 . 1 3 . 5+ / - 0 . 0 5 D249B 8 . 0+ / - 0 . 2 3 . 5+ / - 0 . 1 4 . 0+ / -0 . 1 0 . 25+ / -0 . 05 1 . 7 5+ / - 0 . 1 (1)Dimensions of carrier tape 1 .15d ia .+ / -0 .05 1 .0+ / -0 .1 User Direction of feed 2 .8+ / -0 .1 (Un i t :mm ) (Fig.-2) U E q 2 F q F3 (2)Dimensions of tape reel V B A C F1 W1 W2 (Fig.-3) TITLE Trigonometry Unit Scale Drawing No. Rev. Page DSX321G TYPE SURFACE MOUNT TYPE QUARTZ CRYSTAL SPECIFICATION Date 2004/06/18 3 / 6 DM-Z0008:Style-108 (Table-2) (UNIT:mm) Item Diameter Inside of Frange Outside of Frange Inside Diameter Flange Width Center Core Slit Center Core Length Angle Spindle Diameter Width Key Seats Length Angle Mark A W1 W2 B F1 F2 F3 V q C E U q Dimensions Angle 180 dia. +0.0 / -3.0 9.0 + / - 0.3 11.4 + / - 1.0 60 dia. +1.0 / -0.0 3.0 + / - 0.2 4.0 + / - 0.2 5.0 + / - 0.2 11.9 120 deg. 13 dia. + / - 0.2 2.0 + / - 0.5 10.5 + / - 0.4 120 deg. (3)Storage condition Temperature : +40 deg.C Max. Relative Humidity : 80% Max. (4)Standard packing quantity 3,000 pcs/reel for 180 dia. (5)Material of the tape Tape Carrier tape Top tape Material Polystyrene+Carbon Polyester (6)Label contents Type Our specification No. Your Part No. Lot No. Nominal Frequency Quantity Our Company Name Producting Country Stick a label on the each reel. TITLE Trigonometry Unit Scale Drawing No. Rev. Page DSX321G TYPE SURFACE MOUNT TYPE QUARTZ CRYSTAL SPECIFICATION Date 2004/06/18 4 / 6 DM-Z0008:Style-108 (7)Taping dimension Leader Cover-tape The length of cover-tape in the leader is more than 400mm including empty embossed area. Carrier-tape After all products were packaged, must remain more than twenty pieces or 400mm empty area, which should be sealed by cover-tape. Trailer Cover-tape The tip of cover-tape shall be fixed temporary by paper tape and roll around the core of reel one round. Carrier-tape The empty embossed area which are sealed by top cover-tape must remain more than 40mm. Trailer Components Empty components Unreeling direction Leader Empty components Top cover-tape Embossed carrier-tape (Fig.-4) (8)Joint of tape The carrier-tape and top cover-tape should not be jointed. (9)Release strength of cover tape It has to between 0.1N to 0.7N under following condition. Pulling direction 165 deg. to 180 deg. Speed 300mm/min. Otherwise unless specified. 165 to 180 deg. Pulling direction (Fig.-5) Other standards shall be based on JIS C 0806 -1990. TITLE Trigonometry Unit Scale Drawing No. Rev. Page DSX321G TYPE SURFACE MOUNT TYPE QUARTZ CRYSTAL SPECIFICATION Date 2004/06/18 5 / 6 DM-Z0008:Style-108 < REFLOW CONDITIONS (REFERENCE) > During the solder reflow process, please complete within following temperature, period. Reflow soldering shall be allowed only two(2) times. 260 deg. C +/- 5 deg.C 150 deg. C +/- 5 deg.C 120 s 10 s Total Time : 200s Max. Solder melting point : 183 deg.C (Fig.-6) < LAND PATTERN (REFERENCE) > 0 .8 1 .4 1 .2 0 .5 1 .2 1 .4 unit : mm (Fig.-7) TITLE Trigonometry Unit Scale Drawing No. Rev. Page DSX321G TYPE SURFACE MOUNT TYPE QUARTZ CRYSTAL SPECIFICATION Date 2004/06/18 6 / 6 DM-Z0008:Style-108 1.MECHANICAL ENDURANCE 1.1 SHOCK After the following test,parts shall conform para.3-1-3. of this specifications 10cycles(60times) drop from 150 [cm] heights to concrete. Further,parts shall be solderd on substrate, fixed bakelite materials(about 100[g]). Substrate materials : Glass Epoxy 1 cycle : each 1 times of 6 directions 1.2 VIBRATION After the following test,parts shall conform para.3-1-2. of this specifications, and no abnormal appearance shall be observed. (1)Frequency of Vibration : 10[Hz] to 55[Hz] (2)Amplitude(p-p) : Sine waves of 1.5[mm ] (3)Vibration axis : X.Y.Z (4)Vibration period : 2 [h] for each axis 1.3 SUBSTRATE BENDING After the following test,parts shall conform para.3-1-2. of this specifications and no abnormality shall be observed in external appearance and sealing tightnen and others shall be based on ET-7403 of EIAJ. Mount the specimen on substrate. Apply the following pressure Direction Speed Hours Amount of substrate : : : : see Fig.-1 0.5 [mm/s] 5 +/- 1 [s] 3 [mm] Max. 20 pressure jig R230 P.C.B. 45+/-2 45+/-2 (Fig.-1) TITLE Trigonometry Unit Drawing No. Rev. Scale DSX321G TYPE SURFACE MOUNT TYPE QUARTZ CRYSTAL SPECIFICATION Date 2004/06/18 Page Attached sheet 1 / 4 DM-Z0008:Style-108 1.4 SHEAR After the following test, parts shall conform para.3-1-2. of this specifications and no abnormality shall be observed in external appearance and sealing tightness and others shall be based on ET-7403 of EIAJ. Mount the specimen on substrate. Apply the following pressure Weight : 10 N Hours : 10 +/- 1 s Direction : see Fig.-2 P.C.B. pressure jig specimen R0.5 (Fig.-2) 1.5 BODY STRENGTH After the following test, parts shall conform para.3-1-2. of this specifications and no abnormality shall be observed in external appearance and sealing tightness and others shall be based on ET-7403 of EIAJ. Mount the specimen on substrate. Apply the following pressure Weight : 10 N Hours : 10 +/- 1 s Direction : see Fig.-3 pressure jig R0.5 specimen W L 0.5L L >= W L (Fig.-3) TITLE Trigonometry Unit Drawing No. Rev. Scale DSX321G TYPE SURFACE MOUNT TYPE QUARTZ CRYSTAL SPECIFICATION Date 2004/06/18 Page Attached sheet 2 / 4 DM-Z0008:Style-108 1.6 SEAL Less than 2.0×10-9 Pa m3/sec. by Helium leak detector. Also, no serial bubble is observed by Fluorinert tests. 1.7 SOLDERABILITY After the following test, more than 90% of lead shall be covered by new solder. 3 seconds +/- 1 second dip in 235 deg.C +/- 5 deg.C solder. (Use rosin type flux for solder.) 2.ENVIRONMENTAL ENDURANCE 2.1 HUMIDITY Two hours past at room temperature after following test, parts shall conform para.3-1-4. of this specifications. 240 hours +60 deg.C +/- 2 deg.C , relative humidity 85% +/- 5%. 2.2 LOW TEMPERATURE Two hours past at room temperature after following test, parts shall conform para.3-1-3. of this specifications. 240 hours -30 deg.C +/- 2 deg.C. 2.3 HIGH TEMPERATURE Two hours past at room temperature after following test, parts shall conform para.3-1-4. of this specifications. 240 hours +85 deg.C +/- 2 deg.C. 2.4 TEMPERATURE CYCLE Two hours past at room temperature after 25 cycles of following test, parts shall conform para.3-1-3. of this specifications. +85deg.C 30 min. 1 to 2 min. +25deg.C -55deg.C 30 min. 1 cycle 2.5 RESISTANCE TO SOLDERING HEAT 24 hours past at room temperature from following test, parts shall conform para.3-1-2. of this specifications. VPS:30 Seconds in FC-70 vapor(215 deg.C Boiling Point) TITLE Trigonometry Unit Scale Drawing No. Rev. Page Attached sheet DSX321G TYPE SURFACE MOUNT TYPE QUARTZ CRYSTAL SPECIFICATION Date 2004/06/18 3 / 4 DM-Z0008:Style-108 3.SPECIFICATION Frequency Variation and Equivalent Resistance shall be within Table-1 after the test. (Table-1) 3-1-1 3-1-2 3-1-3 3-1-4 Frequency Variation ±1[ppm] ±2[ppm] ±5[ppm] ±10[ppm] Equivalent Resistance ±10[%] or 1[ohm] max. (Use larger specification) ±15[%] or 2[ohm] max. (Use larger specification) ±20[%] or 3[ohm] max. (Use larger specification) ±20[%] or 3[ohm] max. (Use larger specification) TITLE Trigonometry Unit Scale Drawing No. Rev. Page Attached sheet DSX321G TYPE SURFACE MOUNT TYPE QUARTZ CRYSTAL SPECIFICATION Date 2004/06/18 4 / 4 DM-Z0008:Style-108 2004-0754 REVISION RECORD Rev.No Date - 2004/06/18 Reason Contents The first edition. Approved M.Iizuka Checked Drawn H.Matsuda M.Miyagawa DM-Z0002:Style-008
DSX321G 32MHz 12PF 10PPM 价格&库存
很抱歉,暂时无法提供与“DSX321G 32MHz 12PF 10PPM”相匹配的价格&库存,您可以联系我们找货
