DSX321G 25MHz 10PF 20PPM
    KDS(大真空)
    SMD3225_4P
    无源晶振 25MHz 50Ω 10pF ±20ppm -10℃~+85℃ SMD3225_4P
DSX321G 25MHz 10PF 20PPM 数据手册
Serial No. 2008-0110 DATE : 2008/01/23 Shanghai SiRF Technology Co.,Ltd. QUARTZ CRYSTAL ITEM : TYPE : DSX321G NOMINAL FREQUENCY : 25.000000MHz SPEC No. : 1B225000BC0J 1C225000BC0J USER PARTS NO . : Please acknowledge receipt of this specification by signing and returning a copy to us. RECEIPT DATE (signature) RECEIVED (name) General Manufacture of Quartz Devices DAISHINKU CORP. 1389 Shinzaike, Hiraoka-cho, Kakogawa, Hyogo 675-0194 Japan http://www.kds.info/index_en.htm Phone(81)79-425-3141 Fax (81)79-425-1134 C.ENG. ENG. Serial No. 2008-0110 1. ELECTRICAL CHARACTERISTICS (This test shall be performed under the conditions of temp.at 25 +/- 3deg. C, humidity 60% max.) 1-1 NOMINAL FREQUENCY 25.000000 MHz 1-2 OVERTONE ORDER 1-3 LOAD CAPACITANCE(CL) 1-4 FREQUENCY TOLERANCE +/- 20 ppm Max. at +25 deg.C +/- 3 deg.C 1-5 DRIVE LEVEL 10 uW +/- 1-6 SERIES RESISTANCE 50 ohms Max. / Series 1-7 OPERATING TEMPERATURE RANGE -10 1-8 FREQUENCY CHARACTERISTICS OVER TEMPERATURE +/- 30 ppm Max. / 1-9 SHUNT CAPACITANCE 2.0 pF Max. 1-10 INSULATION RESISTANCE 500 Mohms Min. / DC100V +/- 15V 1-11 STORAGE TEMPERATURE RANGE -40 Fundamental 10.0 pF deg.C deg.C 2 uW to +85 deg.C -10 deg.C to +85 deg.C (ref. +25deg.C) to +85 deg.C 2. CONSTRUCTION 2-1 HOLDER DSX321G Ceramic Base 2-2 DIMENSIONS AND MARKING Refer to Fig.-1 and Table-1. 3. OTHER SPECIFICATIONS 3-1 EMBOSS CARRIER TAPE & REEL Refer to Fig.-2,3,4,5 and Table-2. 3-2 PACKING Refer to Fig.-6. 3-3 REFLOW CONDITIONS (REFERENCE) Refer to Fig.-7. 3-4 LAND PATTERN (REFERENCE) Refer to Fig.-8. 4. Environmental and mechanical performance shall be specified by attached general specification. 5. USE OF FREON: This related product is not used with any ODC CLASS1. TITLE DSX321G TYPE SURFACE MOUNT TYPE QUARTZ CRYSTAL SPECIFICATION Date 2008/01/23 Remark Spec. No. 1B225000BC0J 1C225000BC0J DAISHINKU CORP. Rev. Page 1 / 7 DM-Z0002:Style-010 < DIMENSIONS AND MARKING > 3 .20+ / -0 .1 3 .20+ / -0 .1 D1 2 (1 ) (2 ) (3 ) F requenc y F requency Lo t No . Lo t No . 8 - (0 .10 ) 0 .75+ / -0 .15 Logo Logo 2 .50+ / -0 .1 2 .50+ / -0 .1 0 .15 ##11 #2 # ##34 ## 43 0 .70 (0 .90 ) 0 .70 C0 .30( I NDEX) 0 .90 (1 .20 ) < T O P V I EW > 0 .90 It is recommended that #2,4 is connected with mm un i t : m m GND. unit : mm Ma rk ing #2 ,#4 is no t connec ted w i th any th ing . le rance : + / -0 .1 Tolerance To : +/-0.1 # 4 # 3 # 1 # 2 (Fig.-1) Marking is Laser Marking: Marking should be printed as follows: Logo , Nominal Frequency , manufactured year & month Logo( 1 ), Nominal Frequency ( 2 ) and manufacturing location Producing District Our Specification.No. (1) Logo (2) Frequency Japan 1B225000BC0J D 25 Indonesia 1C225000BC0J ― D 25 Nominal Frequency ( 2 ) = Mark two digits from upper 25 ) ( ex. 25.000000 MHz --> Manufacturing lot No.( 3 ) (year) ex. (Month) ex. Jan. A Feb. B 2008 January shall be marked as ' 8 shall be marked as ' A (Table-1) Mar. Apr. C D May. E TITLE DSX321G TYPE SURFACE MOUNT TYPE QUARTZ CRYSTAL SPECIFICATION Date 2008/01/23 Jun. F Jul. G ' (The last digit of the year) ' (As shown in Table-1.) Aug. H Sep. J Oct. K Nov. L Dec. M Remark Spec. No. 1B225000BC0J 1C225000BC0J DAISHINKU CORP. Rev. Page 2 / 7 DM-Z0002:Style-010 1 . 7 5+ / - 0 . 1 < EMBOSS CARRIER TAPE & REEL > (1)Dimensions of embossed carrier tape 1 .55d ia .+/ -0 .05 2 . 0+ / -0 . 05 4 . 0+ / -0 . 1 3 . 5+ / - 0 . 0 5 0 . 25+ / -0 . 05 D249B 8 . 0+ / - 0 . 2 3 . 5+ / - 0 . 1 4 . 0+ / -0 . 1 1 .15d ia .+/ -0 .05 1 .0+/ -0 .1 User Direction of feed 2 .8+ / -0 .1 ( Un i t :mm ) (Fig.-2) Pin No.1 is located on the sprocket-hole side of the tape. U E q 2 F q F3 (2)Dimensions of tape reel V B A C F1 W1 W2 (Fig.-3) TITLE DSX321G TYPE SURFACE MOUNT TYPE QUARTZ CRYSTAL SPECIFICATION Date 2008/01/23 Remark Spec. No. 1B225000BC0J 1C225000BC0J DAISHINKU CORP. Rev. Page 3 / 7 DM-Z0002:Style-010 (Table-2) (UNIT:mm) Item Diameter Inside of Frange Outside of Frange Inside Diameter Flange Width Center Core Slit Center Core Length Angle Spindle Diameter Width Key Seats Length Angle Mark A W1 W2 B F1 F2 F3 V q C E U q Dimensions Angle 180 dia. +0.0 / -3.0 9.0 + / - 0.3 11.4 + / - 1.0 60 dia. +1.0 / -0.0 3.0 + / - 0.2 4.0 + / - 0.2 5.0 + / - 0.2 11.9 +0.5 / -0.0 120 deg. 13 dia. + / - 0.2 2.0 + / - 0.5 10.5 + / - 0.4 120 deg. (3)Storage condition Temperature : +40 deg.C Max. Relative Humidity : 80% Max. ( It is a guaranteed term because it obtains an excellent soldering: 6 months) (4)Standard packing quantity 3,000 pcs/reel for 180 dia. (5)Material of the tape Tape Carrier tape Cover tape Material Polystyrene+Carbon Polyester (6)Label contents Type Our specification No. Your Part No. Lot No. Nominal Frequency Quantity Our Company Name Producting Country Stick a label on the each reel. TITLE DSX321G TYPE SURFACE MOUNT TYPE QUARTZ CRYSTAL SPECIFICATION Date 2008/01/23 Remark Spec. No. 1B225000BC0J 1C225000BC0J DAISHINKU CORP. Rev. Page 4 / 7 DM-Z0002:Style-010 (7)Taping dimension Leader Cover-tape The length of cover-tape in the leader is more than 400mm including empty embossed area. Carrier-tape After all products were packaged, must remain more than twenty pieces or 400mm empty area, which should be sealed by cover-tape. Terminal Cover-tape The tip of cover-tape shall be fixed temporary by paper tape and roll around the core of reel one round. Carrier-tape The empty embossed area which are sealed by cover-tape must remain more than 40mm. Terminal Leader Component Empty Components Unreeling direction Empty Components Cover-tape Carrier-tape (Fig.-4) (8)Joint of tape The carrier-tape and cover-tape should not be jointed. (9)Release strength of cover tape It has to between 0.1N to 0.7N under following condition. Pulling direction 165 deg. to 180 deg. Speed 300mm/min. Otherwise unless specified. 165 to 180 deg. Pulling direction (Fig.-5) Other standards shall be based on JIS C 0806 -1990. TITLE DSX321G TYPE SURFACE MOUNT TYPE QUARTZ CRYSTAL SPECIFICATION Date 2008/01/23 Remark Spec. No. 1B225000BC0J 1C225000BC0J DAISHINKU CORP. Rev. Page 5 / 7 DM-Z0002:Style-010 < PACKING > (1)STORAGE METHOD Label contents The type of product Lot No. Specification Quantity Shipment Day Remark LABEL (Fig-6) (2)BOX SIZE From lot size packingsize shall be changed. In the upper and lower part and the opening in box it shall be protected products using aircushion sheets. TITLE DSX321G TYPE SURFACE MOUNT TYPE QUARTZ CRYSTAL SPECIFICATION Date 2008/01/23 Remark Spec. No. 1B225000BC0J 1C225000BC0J DAISHINKU CORP. Rev. Page 6 / 7 DM-Z0002:Style-010 < REFLOW CONDITIONS (REFERENCE) > During the solder reflow process, please complete within following temperature, period. Reflow soldering shall be allowed only 2 times. 260 +/- 5 [deg.C] 220 +/- 5 [deg.C] 160 to 180 [deg.C] 10 [s] 60 [s] 120 [s] Total time : 240 [s] Max. (Fig.-7) HANDSOLDERING METHOD : 350 +/- 10 [deg.C] , 3+1/-0[s] Each terminal once (Please take care so that a soldering iron should not touch a product directly.) < LAND PATTERN (REFERENCE) > 0 .8 1 .4 1 .2 0 .5 1 .2 1 .4 unit : mm (Fig.-8) TITLE DSX321G TYPE SURFACE MOUNT TYPE QUARTZ CRYSTAL SPECIFICATION Date 2008/01/23 Remark Spec. No. 1B225000BC0J 1C225000BC0J DAISHINKU CORP. Rev. Page 7 / 7 DM-Z0002:Style-010 1.MECHANICAL ENDURANCE 1.1 SHOCK (ACCELERATION) After the following test,parts shall conform specification 3-1-2. 1000[m/s2] by 6[ms] X,Y,Z each axis (6 directions) , 3cycles 1.2 SHOCK (MOUNTING DROP) After the following test,parts shall conform specification 3-1-2. 3cycles(18times) drop from 150 [cm] heights to concrete. Further,parts shall be solderd on substrate, fixed Aluminum materials(about 100[g]). Substrate materials : Glass Epoxy 1 cycle : each 1 times of 6 directions 1.3 VIBRATION After the following test,parts shall conform specification 3-1-2. and no abnormal appearance shall be observed. Frequency of Vibration : 10 to 500 to 10[Hz] Amplitude(p-p) : Sine waves of 1.5[mm ] or 100[m/s 2] Cycle : 11[min] Vibration axis : X.Y.Z Vibration period : 2 [h] for each axis 1.4 SEAL Less than 2.0×10-9 [Pa m 3/s]. by Helium leak detector. Also, no serial bubble is observed by Fluorocarbon tests. 1.5 SOLDERABILITY After the following test, more than 95[%] of terminal shall be covered by new solder. 3 +/- 0.5 [s] dip in 245 [deg.C] +/- 5 [deg.C] solder. (Solder composition : Sn-3Ag-0.5Cu) (Use rosin type flux for solder.) 1.6 RESISTANCE TO SOLDERING HEAT (REFLOW) 48 [h] past at room temperature from following test,parts shall conform specification 3-1-2. perform the attached Reflow conditions to reference. 1.7 RESISTANCE TO SOLDERING HEAT (HAND SOLDERING METHOD) 48 [h] past at room temperature from following test,parts shall conform specification 3-1-2. 350 ± 10 [deg.C] , 3+1/-0[s] Each terminal once 1.8 SUBSTRATE BENDING After the following test,parts shall conform specification 3-1-2. and no abnormality shall be observed in external appearance and sealing tightnen and others shall be based on ET-7403 of EIAJ. Mount the specimen on substrate. Apply the following pressure Direction : see Fig.-1 Speed : about 1.0 [mm/s] Hours : 5 +/- 1 [s] Amount of substrate : 3 [mm] Max. TITLE Remark DSX321G TYPE SURFACE MOUNT TYPE QUARTZ CRYSTAL SPECIFICATION Date Spec. No. 2008/01/23 1B225000BC0J 1C225000BC0J DAISHINKU CORP. 20 pressure jig R230 P.C.B. 45+/-2 45+/-2 (Fig.-1) Rev. Page Attached sheet 1 / 4 DM-Z0002:Style-010 1.9 SHEAR After the following test,parts shall conform specification 3-1-2. and no abnormality shall be observed in external appearance and sealing tightness and others shall be based on ET-7403 of EIAJ. Mount the specimen on substrate. Apply the following pressure Weight : 10 [N] Hours : 10 +/- 1 [s] Direction : see Fig.-2 P.C.B. pressure jig specimen R0.5 (Fig.-2) 1.10 BODY STRENGTH After the following test,parts shall conform specification 3-1-2. and no abnormality shall be observed in external appearance and sealing tightness and others shall be based on ET-7403 of EIAJ. Mount the specimen on substrate. Apply the following pressure Weight : 10 [N] Hours : 10 +/- 1 [s] Direction : see Fig.-3 pressure jig R0.5 specimen W L 0.5L L >= W L (Fig.-3) TITLE DSX321G TYPE SURFACE MOUNT TYPE QUARTZ CRYSTAL SPECIFICATION Date 2008/01/23 Remark Spec. No. 1B225000BC0J 1C225000BC0J DAISHINKU CORP. Rev. Page Attached sheet 2 / 4 DM-Z0002:Style-010 2.ENVIRONMENTAL ENDURANCE 2.1 LOW TEMPERATURE 2 [h] past at room temperature after following test, parts shall conform specification 3-1-2. 240 [h] -40 +/- 3 [deg.C]. 2.2 HUMIDITY 2 [h] past at room temperature after following test, parts shall conform specification 3-1-2. 240 [h] +85 +/- 2 [deg.C] , relative humidity 85 +/- 5[%]. 2.3 HIGH TEMPERATURE 2 [h] past at room temperature after following test, parts shall conform specification 3-1-2. 240 [h] +85 +/- 2 [deg.C]. 2.4 TEMPERATURE CYCLE 2 [h] past at room temperature after 25 cycles of following test, parts shall conform specification 3-1-2. 30min. +85[deg.C] +25[deg.C] Transport Time 2-3min. -40[deg.C] 30min. 1 cycle (Fig.-4) 3.SPECIFICATION Frequency Variation and Equivalent Resistance shall be within Table-1 after the test. (Table-1) 3-1-1 3-1-2 3-1-3 Frequency Variation ±2[ppm] ±5[ppm] ±10[ppm] Equivalent Resistance ±15[%] or 2[ohms] max. (Use larger specification) ±20[%] or 3[ohms] max. (Use larger specification) ±20[%] or 3[ohms] max. (Use larger specification) TITLE DSX321G TYPE SURFACE MOUNT TYPE QUARTZ CRYSTAL SPECIFICATION Date 2008/01/23 Remark Spec. No. 1B225000BC0J 1C225000BC0J DAISHINKU CORP. Rev. Page Attached sheet 3 / 4 DM-Z0002:Style-010 [ DSX321G SERIES , IN USE ] 1.SOLDERING Please perform the attached Reflow conditions to reference within 2 times. 2.MOUNT Crystal products are designed to be compatible with automatic mounting. Be sure to have a mounting test in advance by using the actual mounting machine and check that the characteristics of the products are not damaged by the automatic mounting. In the process where the boad is warped, such as board separation process, be careful that the warping does not influence the characteristics and soldering of crystal products. Since mounting by Ultrasonic welding and processing have a possibility of an excessive vibration spreading inside a crystal resonator and becoming the cause of characteristic deterioration and not oscillating, it does not recommend. 3.WASHING About use of the washing liquid of a basin system, an alcoholic system, and a chlorofluorocarbon-replacing material system, it is checking that it is satisfactory. However please consult in advance about other washing liquid. Although the check about ultrasonic washing is performed, since it is an examination with a simple substance, the check for the second time by the use state is recommended. 4.THE CAUTIONS ON USE The piece of crystal it is processed very smaller than the conventional thing inside DSX321G series crystal unit may be damaged, if excessive excitation electric power is applied. Please use it below with the value specified on a catalog and specifications. Please refrain from forming patterns under crystal resonators since there is a possibility to cause crack in base. If the temperature is higher than 280 [deg.C], there is a possibility for the sealing glass to remelt. Avoid using the product at temperature higher than specified. 5.HANDLING OF A PRODUCT DSX321G series has sufficient intensity to fall and vibration. However when too much shock is added according to a certain cause, the use after a characteristic check is recommended. 6.STORAGE Since the soldering nature of a terminal may be degraded, please avoid storage in high temperature and a humid place. Please keep it in the place which direct rays do not hit and dew condensation does not generate. TITLE DSX321G TYPE SURFACE MOUNT TYPE QUARTZ CRYSTAL SPECIFICATION Date 2008/01/23 Remark Spec. No. 1B225000BC0J 1C225000BC0J DAISHINKU CORP. Rev. Page Attached sheet 4 / 4 DM-Z0002:Style-010 2008-0110 REVISION RECORD Rev.No Date - 2008/01/23 Reason Contents The first edition. Approved Checked Drawn T. Miura H. Matsuda Y.Ogino DM-Z0002:Style-008
DSX321G 25MHz 10PF 20PPM 价格&库存
很抱歉,暂时无法提供与“DSX321G 25MHz 10PF 20PPM”相匹配的价格&库存,您可以联系我们找货
