S3D31.000000B20F30T
S3D31.000000B20F30T
    SCTF(星通时频)
    SMD3225_4P
    有源晶振 3.3V ±20ppm 31MHz SMD3225_4P
S3D31.000000B20F30T 数据手册
5x7 SMDSMD Crystal 3.2x2.5 OSCILLATOR 深圳市星通时频电子有限公司 SHENZHEN SCTF ELECTRONICS CO.,LTD FEATURE ● ● ● ● ● ● ● Tight frequence tolerance. CMOS compatible logic levels. Pin-compatible with standard 3.2×2.5mm packages. Designed for standard reflow and washing techniques. Low power standby mode. Available on tape & reel,1000pcs per reel. Pb-free and RoHS/Green compliant. APPLICATIONS ● Ideally suited designed for use in Ethernet, network adapter cards,hard disk devices,blue tooth,PCMCIA Cards, Palmtop Computer, Portable Applications. Pb Free ●Electrical Specifications 电气参数 ●Mechanical Dimensions 外型尺寸 总频差 Frequency Stability ±20ppm to ±50ppm 输入电压 Supply Voltage 5.0V or 3.3V ±10%※(See Notes) 工作温度范围 Operating Temperature Range -10℃ - +60℃ to -40℃ - +85℃ 储存温度范围 Storage Temperature Range -40℃ - +85℃/-55℃ - +125℃ 占空比 Symmetry(Duty Cycle) 40/60 Standard 输出 Output Load 15pF Hcmos or 10 TTL 消耗电流 Current Consumption(15pf only) 1.000Mhz - 49.999Mhz=25mA max (5.0V) 50.000Mhz - 125.000Mhz=80mA max Current Consumption(15pf only) 1.000Mhz - 49.999Mhz=20mA max ( 1.8V 2.5V 2.85V 3.3V) 50.000Mhz - 125.000Mhz=60mA max Rise/Fall Time 5 nS max 上升/下降时间 UNIT(单位):mm(毫米) 3.2±0.1 4 3 1 2 22 0.65 3.2x2.5mm SMD OSCILLATOR  32.768KHz, 1.000 Mhz to 125.000 MHz 2.5±0.1 Holder Type Frequency Range 1.0MAX 型号 频率范围 1.2 0.1 1 2 2.3 0.9 4 3 0.8 1.3 1 ※Notes:The supply voltage 1.8V,2.5V,2.85V also can be made by customer. 1.8 2.54 ●Test Circuit(测试电路) suggested solder pad layout Frequency Counter +Vs A Oscillator 4 3 +Vs Power Supply 1 V 2 0.1μF Oscilloscope 15pF * PIN FUNCTION 1 N/C or Tri-state 2 Ground 3 Output 4 Vdd The above specifications are standard for SCTF product If you have special requirement please Contact SCTF sales with your enquiries Tel:0086-0755-86097430,0086-0755-86097250 The above specifications are standard for HLX product Fax:0086-0755-86097259 If you have special requirement please Contact HLX sales with your en E-mail:sales@ sctf-crystal.com http://www.sctf-crystal.com Tel:0086-25-85238320,0086-25-85320830(Direct) Fax:0086-25-85315213,85301856
S3D31.000000B20F30T
物料型号:3.2x2.5mm SMD振荡器
器件简介: - 具有紧凑的频率容差。 - 与CMOS兼容的逻辑电平。 - 引脚兼容标准3.2×2.5mm封装。 - 设计适用于标准的回流焊和清洗技术。 - 低功耗待机模式。 - 可提供卷带包装,每卷1000片。 - 无铅且符合RoHS/绿色标准。
引脚分配: - 引脚1:M/C或三态。 - 引脚2:地。 - 引脚3:输出。
参数特性: - 频率范围:32.768KHz至125.000MHz。 - 总频差:±20ppm至±50ppm。 - 输入电压:5.0V或3.3V(见注释)。 - 工作温度范围:-10°C至+60°C至-40°C至+85°C。 - 储存温度范围:-40°C至+85°C/-55°C至+125°C。 - 占空比:标准40/60。 - 输出负载:15pF HCMOS或10 TTL。 - 消耗电流:在1.000MHz至49.999MHz时,5.0V下最大25mA;1.8V、2.5V、2.85V或3.3V下最大20mA。在50.000MHz至125.000MHz时,5.0V下最大80mA;1.8V、2.5V、2.85V或3.3V下最大60mA。 - 上升/下降时间:最大5ns。
功能详解: - 测试电路建议的焊盘布局。 - 频率计数器和示波器用于测试。
应用信息: - 非常适合用于以太网、网络适配器卡、硬盘设备、蓝牙、PCMCIA卡、掌上电脑、便携式应用。
封装信息: - 电气规格和机械尺寸单位为毫米(mm)。
S3D31.000000B20F30T 价格&库存
很抱歉,暂时无法提供与“S3D31.000000B20F30T”相匹配的价格&库存,您可以联系我们找货
