S7D24.000000C20F30T
S7D24.000000C20F30T
    SCTF(星通时频)
    SMD7050_4P
    有源晶振 24MHz ±20ppm 2.8V SMD7050_4P
S7D24.000000C20F30T 数据手册
5x7 SMD OSCILLATOR(HCOMS/TTL) FEATURE ●  ●  ●  ● ● ●  ●  ●  ● CMOS compatible logic levels. Pin-compatible with standard 7.0×5.0mm packages. High precision characteristic covering up to high frequency range. Low jitter and tight stability with fundamental or overtone Design. Low power standby mode. Output Tri-state funtion. Embossed taping specification. Reflow soldering. Pb-free and RoHS/Green compliant. APPLICATIONS ● Ideally suited designed for discdrives,NB,Networking, GPS/Navigation,BlusTooth,Ethernet,ADSL,VDSL,Fiber channel hand-held electronic products. Pb Free ●Electrical Specifications 电气参数 ±20ppm to ±50ppm 输入电压 Supply Voltage 5.0V or 3.3V ±10% ※(See Notes) 工作温度范围 Operating Temperature Range -20℃ - +70℃ / -40℃ - +85℃ 储存温度范围 Storage Temperature Range -40℃ - +85℃/-55℃ - +125℃ 占空比 Symmetry(Duty Cycle) 40/60 Standard 输出 Output Load 15pF Hcmos 消耗电流 Current Consumption(15pf only) 1.000Mhz - 35.999Mhz=25mA max (5.0V) 5.08 36.000Mhz - 69.999Mhz=60mA max 1.000Mhz - 35.999Mhz=20mA max ( 1.8V 2.5V 2.85V 3.3V) 36.000Mhz - 69.999Mhz=40mA max 1 2 4 3 1.4 70.000Mhz - 150.000Mhz=80mA max Current Consumption(15pf only) 20 4.2 32.768KHz, 1.000 Mhz to 150.000 MHz Frequency Stability 1.8 Frequency Range 总频差 For Fundamental 1.2 频率范围 UNIT(单位):mm(毫米) 7±0.15 5±0.15 5x7mm SMD OSCILLATOR  1.4 MAX Holder Type 2.6 型号 ●Mechanical Dimensions 外型尺寸 2 5.08 70.000Mhz - 150.000Mhz=60mA max 上升/下降时间 Rise/Fall Time 5 nS max For Third Overtone 7±0.15 1.4 MAX 5±0.15 ※Notes:The supply voltage 1.8V,2.5V,2.85V also can be made by customer. Frequency Counter +Vs A 5.08 1 2 4 3 1.2 ●Test Circuit(测试电路) Power Supply 1 2 1.8 Oscillator 4 3 +Vs 4.2 2.6 1.4 Oscilloscope 2 5.08 V 0.1μF 15pF * suggested solder pad layout PIN FUNCTION 1 N/C or Tri-state 2 Ground 3 Output 4 Vdd The above specifications are standard for SCTF product If you have special requirement please Contact SCTF sales with your enquiries Tel:0086-0755-86097430,0086-0755-86097250 The above specifications are standard for HLX product Fax:0086-0755-86097259 If you have special requirement please Contact HLX sales with your en E-mail:sales@ sctf-crystal.com http://www.sctf-crystal.com Tel:0086-25-85238320,0086-25-85320830(Direct) Fax:0086-25-85315213,85301856
S7D24.000000C20F30T
物料型号:5x7 SMD OSCILLATOR
器件简介:该振荡器与CMOS逻辑电平兼容,引脚兼容标准7.0×5.0mm封装,具有高精度特性,覆盖高频范围,低抖动和高稳定性,低功耗待机模式,输出三态功能,符合RoHS/绿色标准。
引脚分配: - PIN 1: N/或三态 - PIN 2: 地(Ground) - PIN 3: 输出(Dutput) - Vdd: 电源电压
参数特性: - 频率范围:32.768KHz至150.000MHz - 总频差:±20ppm至±50ppm - 输入电压:5.0V或3.3V(±10%,详见说明) - 工作温度范围:-20°C至+70°C或-40°C至+85°C - 储存温度范围:-40°C至+85°C或-55°C至+125°C - 占空比:40/60标准 - 输出负载:15pF Hcmos - 消耗电流:在1.000MHz至35.999MHz时,最大25mA(5.0V),在36.000MHz至150.000MHz时,最大80mA(5.0V);在1.8V至3.3V时,相应频率范围内最大消耗电流分别为20mA和60mA - 上升/下降时间:最大5ns
功能详解:振荡器具有高稳定性和低功耗特性,适用于多种电子设备。
应用信息:适用于光盘驱动器、笔记本电脑、网络设备、GPS/导航、蓝牙、以太网、ADSL、VDSL、光纤通道和手持电子产品。
封装信息:5x7mm SMD封装,符合RoHS指令2002/95/EC,无铅。
S7D24.000000C20F30T 价格&库存
很抱歉,暂时无法提供与“S7D24.000000C20F30T”相匹配的价格&库存,您可以联系我们找货
