5x7 SMD OSCILLATOR(HCOMS/TTL)
FEATURE
CMOS compatible logic levels.
Pin-compatible with standard 7.0×5.0mm packages.
High precision characteristic covering up to high frequency range.
Low jitter and tight stability with fundamental or overtone Design.
Low power standby mode.
Output Tri-state funtion.
Embossed taping specification.
Reflow soldering.
Pb-free and RoHS/Green compliant.
APPLICATIONS
Ideally suited designed for discdrives,NB,Networking,
GPS/Navigation,BlusTooth,Ethernet,ADSL,VDSL,Fiber channel
hand-held electronic products.
Pb
Free
●Electrical Specifications 电气参数
±20ppm to ±50ppm
输入电压
Supply Voltage
5.0V or 3.3V ±10% ※(See Notes)
工作温度范围
Operating Temperature Range
-20℃ - +70℃ / -40℃ - +85℃
储存温度范围
Storage Temperature Range
-40℃ - +85℃/-55℃ - +125℃
占空比
Symmetry(Duty Cycle)
40/60 Standard
输出
Output Load
15pF Hcmos
消耗电流
Current Consumption(15pf only)
1.000Mhz - 35.999Mhz=25mA max
(5.0V)
5.08
36.000Mhz - 69.999Mhz=60mA max
1.000Mhz - 35.999Mhz=20mA max
( 1.8V 2.5V 2.85V 3.3V)
36.000Mhz - 69.999Mhz=40mA max
1
2
4
3
1.4
70.000Mhz - 150.000Mhz=80mA max
32.768KHz, 1.000 Mhz to 150.000 MHz
Frequency Stability
1.8
Frequency Range
总频差
For Fundamental
1.2
频率范围
UNIT(单位):mm(毫米)
7±0.15
5±0.15
5x7mm SMD OSCILLATOR
1.4 MAX
Holder Type
2.6
型号
●Mechanical Dimensions 外型尺寸
2
5.08
70.000Mhz - 150.000Mhz=60mA max
上升/下降时间
Rise/Fall Time
5 nS max
For Third Overtone
7±0.15
1.4 MAX
5±0.15
※Notes:The supply voltage 1.8V,2.5V,2.85V also can be made by customer.
Frequency
Counter
+Vs
A
5.08
1
2
4
3
1.2
●Test Circuit(测试电路)
Power
Supply
1
2
1.8
Oscillator
4
3
+Vs
4.2
2.6
1.4
Oscilloscope
2
5.08
V
0.1μF
15pF *
suggested solder pad layout
PIN
FUNCTION
1
N/C or Tri-state
2
Ground
3
Output
4
Vdd
The above specifications are standard for SCTF product
If you have special requirement please Contact SCTF sales with your enquiries
Tel:0086-0755-86097430,0086-0755-86097250
The above specifications are standard for HLX product
Fax:0086-0755-86097259
If you have special requirement please Contact HLX sales with your en
E-mail:sales@ sctf-crystal.com
http://www.sctf-crystal.com
Tel:0086-25-85238320,0086-25-85320830(Direct)
Fax:0086-25-85315213,85301856
S7D34.000000A20F30T 价格&库存
很抱歉,暂时无法提供与“S7D34.000000A20F30T”相匹配的价格&库存,您可以联系我们找货
