SSDC06-EC-H
SSDC06-EC-H
    MOONS'(鸣志)
    MODULE_130X77.5MM
    24-70V,最大输出连续电流6A/相(正弦峰值),瞬时电流7.5A(1.5s),可选编码器分辨率
SSDC06-EC-H 数据手册
Host Command Reference Q and SCL commands for servo, step-servo and stepper drives Includes RS-232, RS-485, Ethernet UDP, Ethernet TCP/IP and EtherNet/IP communication SHANGHAI AMP&MOONS’ AUTOMATION CO.,LTD. 920-0002 Rev. J 12/2014 Host Command Reference Contents Getting Started..............................................................................................9 Servo Drives......................................................................................9 Step-Servo.........................................................................................9 Stepper Drives...................................................................................9 Commands..................................................................................................11 Buffered Commands..........................................................................11 Stored Programs in Q Drives...........................................................11 Multi-tasking in Q Drives.................................................................11 Immediate Commands......................................................................11 Using Commands................................................................................11 Commands in Q drives......................................................................12 SCL Utility software............................................................................13 Command Summary............................................................................14 Motion Commands............................................................................15 Servo Commands..............................................................................16 Configuration Commands..................................................................17 I/O Commands..................................................................................19 Communications Commands............................................................20 Q Program Commands......................................................................20 Register Commands..........................................................................21 Command Listing.................................................................................22 AC - Acceleration Rate......................................................................23 AD - Analog Deadband.....................................................................24 AD - Analog Deadband (M2 drives)..................................................25 AF - Analog Filter...............................................................................26 AG - Analog Velocity Gain.................................................................27 AI - Alarm Reset Input ......................................................................28 AL - Alarm Code................................................................................31 AM - Max Acceleration......................................................................33 AN - Analog Torque Gain...................................................................34 AO - Alarm Output.............................................................................35 AP - Analog Position Gain.................................................................37 AR - Alarm Reset (Immediate)...........................................................38 AS - Analog Scaling...........................................................................39 AT - Analog Threshold.......................................................................40 AV - Analog Offset Value....................................................................41 AV - Analog Offset Value (M2 drives)................................................42 920-0002 Rev. J 12/2014 2 Host Command Reference AX - Alarm Reset (Buffered)..............................................................43 AZ - Analog Zero...............................................................................44 BD - Brake Disengage Delay.............................................................45 BE - Brake Engage Delay..................................................................46 BO - Brake Output.............................................................................47 BR - Baud Rate .................................................................................49 BS - Buffer Status...............................................................................50 CA - Change Acceleration Current....................................................51 CB – CANopen Baudrate..................................................................52 CC - Change Current.........................................................................53 CD - Idle Current Delay Time.............................................................55 CE - Communication Error.................................................................56 CF - Anti-resonance Filter Frequency................................................57 CG - Anti-resonance Filter Gain.........................................................58 CI - Change Idle Current...................................................................59 CJ - Commence Jogging...................................................................61 CM - Command Mode (AKA Control Mode)......................................62 CN - Secondary Control Mode..........................................................64 CO - Node ID/ IP address..................................................................65 CP - Change Peak Current................................................................67 CR - Compare Registers ...................................................................68 CS - Change Speed..........................................................................69 CT - Continue.....................................................................................70 DA - Define Address..........................................................................71 DC - Change Distance......................................................................72 DD - Default Display Item of LEDs.....................................................73 DE - Deceleration..............................................................................74 DI - Distance/Position........................................................................75 DL - Define Limits..............................................................................76 DL - Define Limits (Step-Servo and M2 drives).................................78 DP - Dumping Power.........................................................................79 DR - Data Register for Capture..........................................................80 DS - Switching Electronic Gearing....................................................81 ED - Encoder Direction......................................................................82 EF - Encoder Function.......................................................................83 EG - Electronic Gearing.....................................................................85 EH - Extended Homing......................................................................86 EI - Input Noise Filter.........................................................................88 EN - Numerator of Electronic Gearing Ratio......................................89 3 920-0002 Rev. J 12/2014 Host Command Reference EP - Encoder Position........................................................................90 ER - Encoder Resolution....................................................................91 ES - Single-Ended Encoder Usage...................................................92 EU - Denominator of Electronic Gearing Ratio..................................93 FA - Function of the Single-ended Analog Input...............................94 FC - Feed to Length with Speed Change..........................................95 FD - Feed to Double Sensor..............................................................97 FE - Follow Encoder...........................................................................98 FH - Find Home.................................................................................99 FI - Filter Input....................................................................................102 FL - Feed to Length...........................................................................106 FM - Feed to Sensor with Mask Distance..........................................107 FO - Feed to Length and Set Output.................................................108 FP - Feed to Position..........................................................................109 FS - Feed to Sensor...........................................................................110 FX - Filter select inputs......................................................................111 FY - Feed to Sensor with Safety Distance..........................................112 GC - Current Command.....................................................................113 GG - Controller Global Gain Selection...............................................114 HA - Homing Acceleration.................................................................115 HC - Hard Stop Current.....................................................................116 HD - Hard Stop Fault Delay...............................................................117 HG - 4th Harmonic Filter Gain...........................................................118 HL - Homing Deceleration.................................................................119 HO - Homing Offset...........................................................................120 HP - 4th Harmonic Filter Phase.........................................................121 HS - Hard Stop Homing.....................................................................122 HV - Homing Velocity.........................................................................124 HW - Hand Wheel..............................................................................125 Immediate Status Commands...........................................................126 IA - Immediate Analog.......................................................................127 IC - Immediate Current (Commanded)..............................................129 ID - Immediate Distance....................................................................130 IE - Immediate Encoder.....................................................................131 IF - Immediate Format.......................................................................132 IH - Immediate High Output...............................................................133 IL - Immediate Low Output................................................................134 IO - Output Status..............................................................................135 IP - Immediate Position......................................................................137 920-0002 Rev. J 12/2014 4 Host Command Reference IQ - Immediate Current (Actual)........................................................138 IS - Input Status.................................................................................139 IT - Immediate Temperature...............................................................143 IU - Immediate Voltage......................................................................145 IV - Immediate Velocity......................................................................146 IX - Immediate Position Error.............................................................147 JA - Jog Acceleration........................................................................148 JC - Velocity (Oscillator) mode second speed..................................149 JC - 8 Jog Velocities (M2 drives) ......................................................150 JD - Jog Disable................................................................................151 JE - Jog Enable.................................................................................152 JL - Jog Decel...................................................................................153 JM - Jog Mode...................................................................................154 JS - Jog Speed..................................................................................155 KC - Overall Servo Filter....................................................................156 KD - Differential Constant..................................................................157 KE - Differential Filter.........................................................................158 KF - Velocity Feedforward Constant..................................................159 KG – Secondary Global Gain............................................................160 KI - Integrator Constant.....................................................................161 KJ - Jerk Filter Frequency..................................................................162 KK - Inertia Feedforward Constant....................................................163 KP - Proportional Constant................................................................164 KV - Velocity Feedback Constant......................................................165 LA - Lead Angle Max Value...............................................................166 LM - Software Limit CCW...................................................................168 LP - Software Limit CW......................................................................169 LS - Lead Angle Speed.....................................................................170 LV - Low Voltage threshold................................................................171 MC - Motor Current, Rated................................................................172 MD - Motor Disable............................................................................173 ME - Motor Enable.............................................................................174 MN - Model Number..........................................................................175 MO - Motion Output...........................................................................176 MR - Microstep Resolution.................................................................179 MT - Multi-Tasking..............................................................................180 MS - Control Mode Selection.............................................................181 MV - Model & Revision......................................................................182 NO - No Operation.............................................................................184 5 920-0002 Rev. J 12/2014 Host Command Reference OF - On Fault.....................................................................................185 OI - On Input......................................................................................186 OP - Option board.............................................................................187 PA - Power-up Acceleration Current..................................................188 PB - Power-up Baud Rate .................................................................190 PC - Power-up Current.......................................................................191 PD - In-Position Counts......................................................................192 PE - In-Position Timing.......................................................................193 PF - Position Fault..............................................................................194 PH - Inhibition Of The Pulse Command ............................................195 PI - Power-up Idle Current.................................................................196 PK - Parameter Lock..........................................................................197 PL - Position Limit..............................................................................198 PM - Power-up Mode.........................................................................199 PN - Probe On Demand.....................................................................200 PP - Power-up Peak current...............................................................201 PR - Protocol......................................................................................202 PS - Pause.........................................................................................203 PT - Pulse Type..................................................................................204 PV - Secondary Electronic Gearing...................................................205 PW - Password...................................................................................206 QC - Queue Call................................................................................207 QD - Queue Delete............................................................................208 QE - Queue Execute..........................................................................209 QG - Queue Goto..............................................................................210 QJ - Queue Jump..............................................................................211 QK - Queue Kill..................................................................................212 QL - Queue Load...............................................................................213 QR - Queue Repeat...........................................................................214 QS - Queue Save...............................................................................215 QU - Queue Upload...........................................................................216 QX - Queue Load & Execute.............................................................217 RC - Register Counter.......................................................................218 RD - Register Decrement...................................................................220 RE - Restart or Reset.........................................................................221 RI - Register Increment......................................................................222 RL - Register Load - immediate.........................................................223 RM - Register Move...........................................................................224 RO - Anti-Resonance ON..................................................................225 RR - Register Read............................................................................226 920-0002 Rev. J 12/2014 6 Host Command Reference RS - Request Status...........................................................................227 RU - Register Upload........................................................................228 RV - Revision Level............................................................................229 RW - Register Write............................................................................230 RX - Register Load - buffered............................................................231 R+ - Register Add..............................................................................232 R- - Register Subtract........................................................................233 R* - Register Multiply.........................................................................234 R/ - Register Divide............................................................................235 R& - Register AND.............................................................................236 R| - Register OR.................................................................................237 SA - Save Parameters........................................................................238 SC - Status Code...............................................................................239 SD - Set Direction..............................................................................240 SF - Step Filter Frequency.................................................................241 SH - Seek Home................................................................................242 SI - Enable Input Usage....................................................................243 SJ - Stop Jogging .............................................................................245 SK - Stop & Kill..................................................................................246 SM - Stop Move.................................................................................247 SO - Set Output.................................................................................248 SP - Set Position................................................................................249 SS - Send String................................................................................250 ST - Stop............................................................................................251 TD - Transmit Delay...........................................................................252 TI - Test Input.....................................................................................253 TO - Tach Output...............................................................................254 TR - Test Register..............................................................................255 TS - Time Stamp................................................................................256 TT - Pulse Complete Timing...............................................................257 TV - Torque Ripple.............................................................................258 VC - Velocity Change.........................................................................259 VE - Velocity.......................................................................................260 VI - Velocity Integrator Constant........................................................261 VL - Voltage Limit...............................................................................262 VM - Maximum Velocity......................................................................263 VP - Velocity Mode Proportional Constant.........................................264 VR - Velocity Ripple...........................................................................265 WD - Wait Delay.................................................................................266 7 920-0002 Rev. J 12/2014 Host Command Reference WI - Wait for Input..............................................................................267 WM - Wait on Move............................................................................268 WP - Wait Position..............................................................................269 WT - Wait Time...................................................................................270 ZC - Regen Resistor Continuous Wattage.........................................271 ZR - Regen Resistor Value.................................................................272 ZT - Regen Resistor Peak Time.........................................................273 Data Registers...........................................................................................274 Read-Only data registers...................................................................274 Read/Write data registers..................................................................274 User-Defined data registers...............................................................274 Storage data registers.......................................................................274 Using Data Registers...........................................................................275 Loading (RL, RX)...............................................................................275 Uploading (RL, RU)...........................................................................276 Writing Storage registers (RW) (Q drives only)..................................276 Reading Storage registers (RR) (Q drives only)................................276 Moving data registers (RM) (Q drives only).......................................276 Incrementing/Decrementing (RI, RD) (Q drives only)........................276 Counting (RC, “I” register) (Q drives only)........................................276 Math & Logic (R+, R-, R*, R/, R&, R|) (Q drives only)........................276 Conditional Testing (CR, TR) (Q drives only).....................................277 Data Register Assignments.................................................................277 Read-Only data registers: a - z..........................................................277 Read/Write data registers: A - Z........................................................283 User-Defined data registers: 0 - 9, other characters.........................287 Appendices...............................................................................................288 Appendix A: Non-Volatile Memory in Q drives.....................................289 Appendix B: Host Serial Communications...........................................290 Appendix C: Host Serial Connections.................................................294 Appendix D: The PR Command...........................................................298 Appendix E: Alarm and Status Codes.................................................307 Appendix F: Working with Inputs and Outputs....................................314 Appendix G: eSCL (SCL over Ethernet) Reference.............................322 Appendix H: EtherNet/IP......................................................................336 Appendix I: Troubleshooting................................................................369 Appendix J: List of Supported Drives..................................................371 920-0002 Rev. J 12/2014 8 Host Command Reference Getting Started The basic procedures for integrating a MOONS’ drive into your application are the same for every drive offered. The first step is to configure and/or tune the drive using either ST Configurator (stepper) or SV Quick Tuner or M Servo Suite (Servo) or Step-Servo Quick Tuner (Step-Servo). Depending on the specific drive, the user may now use SCL Utility, Q Programmer or Mis Programmer software for testing and advanced programming. Servo Drives • This series includes all SV7, SVAC3, and M2 drives. • For Ethernet-enabled drives, see Appendix G of this document and your drive’s Hardware Manual for information regarding Ethernet communications. • Use SV Quick Tuner or M Servo Suite software to tune and configure your drive. See the SV Quick Tuner or M Servo Suite Software Manual for details on tuning servo drives. • For SCL applications choose the SCL Operating Mode; for Q applications choose either the SCL or Q Program Operating Mode. • For SCL applications, the SCL Setup Utility is a useful tool to gain familiarity with the SCL command syntax and to test commands that will be used in the final product. • For Q applications use Q Programmer both for creating stored programs and for sending commands to your drive. • For I applications use Mis Programmer for creating stored programs. • Note: SV7-I drives are not recommended for multi-drop communications over the RS-485 port. Step-Servo • This series includes all SSM, TSM, SS, SSAC and TXM drives. • For Ethernet-enabled drives, see Appendix G of this document and your drive’s Hardware Manual for information regarding Ethernet communications. • Use Step-Servo Quick Tuner software to tune and configure your drive. See the Step-Servo Quick Tuner Software Manual for details on tuning step-servo drives. • For SCL applications choose the SCL Operating Mode; for Q applications choose either the SCL or Q Program Operating Mode. • For SCL applications, the SCL Setup Utility is a useful tool to gain familiarity with the SCL command syntax and to test commands that will be used in the final product. • For Q applications use Q Programmer both for creating stored programs and for sending commands to your drive. Stepper Drives • This series includes all ST5/10, STM, SWM, STAC5 and STAC6 drives. • For Ethernet-enabled drives, see Appendix G of this document and your drive’s Hardware Manual for information regarding Ethernet communications. • Use ST Configurator software to define your motor, configure the operating mode and encoder (if applicable), as well as any application-specific I/O requirements. • For SCL applications choose the SCL Operating Mode; for Q applications choose either the SCL or Q Program Operating Mode. 9 920-0002 Rev. J 12/2014 Host Command Reference • For SCL applications, the SCL Setup Utility is a useful tool to gain familiarity with the SCL command syntax and to test commands that will be used in the final product. • For Q applications use Q Programmer both for creating stored programs and for sending commands to your drive. • For I applications use Mis Programmer for creating stored programs. • Note: ST5/10-I and STAC6-I drives are not recommended for multi-drop communications over the RS-485 port. • STAC5-Q, STAC6-Q, STAC6-QE, and STAC6-I drives can be used in Q applications. 920-0002 Rev. J 12/2014 10 Host Command Reference Commands There are two types of host commands available: buffered and immediate. Buffered commands are loaded into and executed out of the drive’s volatile command buffer, also known as the queue. Immediate commands are not buffered: when received by the drive they are executed immediately. Buffered Commands After being loaded into the command buffer of a drive, buffered commands are executed one at a time. (See “Multi-tasking in Q Drives” below for an exception to this rule). If you send two buffered commands to the drive in succession, like an FL (Feed to Length) command followed by an SS (Send String) command, the SS command sits in the command buffer and waits to execute until the FL command is completed. The command buffer can be filled up with commands for sequential execution without the host controller needing to wait for a specific command to execute before sending the next command. Special buffer commands, like PS (Pause) and CT (Continue), enable the buffer to be loaded and to pause execution until the desired time. Stored Programs in Q Drives Stored Q Programs, created with the Q Programmer application software, are created by using only buffered commands. Multi-tasking in Q Drives Multi-tasking allows for an exception to the “one at a time” rule of buffered commands. The multi-tasking feature of a Q drive allows you to initiate a move command (FL, FP, CJ, FS, etc.) and proceed to execute other commands without waiting for the move command to finish. Immediate Commands Immediate commands are executed right away, running in parallel with a buffered command if necessary. For example, this allows you to check the remaining space in the buffer using the BS (Buffer Status) command, or the immediate status of digital inputs using the IS (Input Status) command, while the drive is processing other commands. Immediate commands are designed to access the drive at any time. MOONS’ recommends waiting for an appropriate Ack/Nack response from the drive before sending subsequent commands. This adds limited overhead but ensures that the drive has received and executed the current command, preventing many common communication errors. If the Ack/Nack functionality cannot be used in the application for any reason, the user should allow a 10ms delay between commands to allow the drive sufficient time to receive and act on the last command sent. This approach allows a host controller to get information from the drive at a high rate, most often for checking drive status or motor position. Using Commands The basic structure of a command packet from the host to the drive is always a text string followed by a carriage return (no line feed required). The text string is always composed of the command itself, followed by any parameters used by the command. The carriage return denotes the end of transmission to the drive. Here is the basic syntax. YXXAB In the syntax above, “Y” symbolizes the drive’s RS-485 address, and is only required when using RS485 networking. “XX” symbolizes the command itself, which is always composed of two capital letters. “A” symbolizes the first of two possible parameters, and “B” symbolizes the second. Parameters 1 and 2 vary in length, can be letters or numbers, and are often optional. The “” symbolizes the carriage return which terminates the command string. How the carriage return is generated in your application will depend on your host software. Once a drive receives the it will determine whether or not it understood the preceding characters as 11 920-0002 Rev. J 12/2014 Host Command Reference a valid command. If it did understand the command the drive will either execute or buffer the command. If Ack/ Nack is turned on (see PR command), the drive will also send an Acknowledge character (Ack) back to the host. The Ack for an executed command is % (percent sign), and for a buffered command is * (asterisk). It is always recommended that the user program wait for an ACK/NACK character before subsequent commands are sent. If the ACK/NACK functionality cannot be used in the application, a 10ms delay is recommended between non-motion commands. If the drive did not understand the command it will do nothing. If Ack/Nack is turned on a Nack will be sent, which is signified by a ? (question mark). The Nack is usually accompanied by a numerical code that indicates a particular error. To see a list of these errors see the PR command details in the Appendix. Responses from the drive will be sent with a similar syntax to the associated SCL command. YXX=A In the syntax above, “Y” symbolizes the drive’s RS-485 address, and is only present when using RS485 networking. “XX” symbolizes the command itself, which is always composed of two capital letters. “A” symbolizes the requested data, and may be presented in either Decimal or Hexadecimal format (see the IF command). The “” symbolizes the carriage return which terminates the response string. Commands in Q drives Q drives have additional functionality because commands can also be composed into a stored program that the Q drive can run stand-alone. The syntax for commands stored in a Q program is the same as if the commands were being sent directly from the host, or “XXAB”. Q Programmer software is used to create stored Q programs and can be downloaded for free from www.moons.com.cn. The diagram below shows how commands sent from the host’s serial port interact with the volatile command buffer (AKA the Queue), and the drive’s non-volatile program memory storage. Loading and Uploading the Queue contents via the serial port are done with the QL and QU commands, respectively. Similarly, the Queue’s contents can be Loaded from NV memory using the QL and QX commands, and can be saved to NV memory with the QS command. Finally, commands currently in the Queue can be executed with the QE or QX command. 920-0002 Rev. J 12/2014 12 Host Command Reference The Q Programmer software automates many of the functions shown in the diagram above. SCL Utility software The SCL Utility software is an excellent application for familiarizing yourself with host commands. SCL Utility can be downloaded for free from www.moons.com.cn. To send commands to your drive from SCL Utility simply type a command in the Command Line and press the ENTER key to send it. (Remember that all commands are capital letters so pressing the Caps Lock key first is a good tip). Pressing the ENTER key while in SCL Utility does two things: it terminates the command with a carriage return and automatically sends the entire string. Try the example sequence below. In this example, note that means press the ENTER key on your keyboard, which is the same as terminating the command with a carriage return. IMPORTANT: We recommend practicing with SCL commands with no load attached to the motor shaft. You want the motor shaft to spin freely during startup to avoid damaging mechanical components in your system. AC25 Set accel rate to 25 rev/sec/sec. DE25 Set decel rate to 25 rev/sec/sec VE5 Set velocity to 5 rev/sec FL20000 Move the motor 20000 steps in the CW direction. If your motor didn’t move after sending the FL20000 check the LEDs on your drive to see if there is an error present. If so send the AR command (AR) to clear the alarm. If after clearing the alarm you see a solid green LED it means the drive is disabled. Enable the drive by sending the ME command (ME) and verify that the you see a steady, flashing green LED. Then try the above sequence again. Here is another sample sequence you can try. JA10 Set jog accel rate to 10 rev/sec/sec JL10 Set jog decel rate to 10 rev/sec/sec JS1 Set jog speed to 1 rev/sec CJ Commence jogging CS-1 Change jog speed to 1 rev/sec in CCW direction SJ Stop jogging In the above sequence notice that the motor ramps to the new speed set by CS. This ramp is affected by the JA and JL commands. Try the same sequence above with different JA, JL, JS, and CS values to see how the motion of the motor shaft is affected. 13 920-0002 Rev. J 12/2014 Host Command Reference Command Summary This section contains a set of tables that list all of the Host Commands available with your drive. In each table there are a number of columns that give information about each command. • “Command” shows the command’s two-letter Command Code. • “Description” shows the name of each command. • “NV” designates which commands are Non-volatile: that is, which commands are saved in non-volatile memory when the SA (Save) command is sent to the drive. Note that certain commands (PA, PB, PC, PI, and PM) save their parameter data to non-volatile memory immediately upon execution, and need not be followed by an SA command. • “Write only” or “Read only” is checked when a command is not both Read/Write compatible. • “Immediate” designates an immediate command (all other commands are buffered). • “Compatibility” shows which drives use each of the commands. The different categories for these tables - Motion, Servo, Configuration, I/O, Communications, Q Program, Register - are set up to aid you in finding particular commands quickly. • “Motion” commands have to do with the actual shaft rotation of the step or servo motor. • “Servo” commands cover servo tuning parameters, enabling / disabling the motor, and filter setup. • “Configuration” commands pertain to setting up the drive and motor for your application, including tuning parameters for your servo drive, step resolution and anti-resonance parameters for your step motor drive, etc. • “I/O” commands are used to control and configure the inputs and outputs of the drive. • “Communications” commands have to do with the configuration of the drive’s serial ports. • “Q Program” commands deal with programming functions when creating stored programs for your Q drive. • “Register” commands deal with data registers. Many of these commands are only compatible with Q drives. 920-0002 Rev. J 12/2014 14 Host Command Reference Motion Commands Command Description NV write only AC Accel Rate • All drives AM Accel Max • All drives CJ Commence Jogging DC Distance for FC, FM, FO, FY • All drives DE Decel Rate • All drives DI Distance or Position • All drives ED Encoder Direction • Servos and steppers with encoder feedback EF Encoder Function • Servos and steppers with encoder feedback EG Electronic Gearing • All drives EH Extended Homing EI Input Noise Filter EP Encoder Position FC Feed to Length with Speed Change • All drives FD Feed to Double Sensor • All drives FE Follow Encoder • All drives FH Find Home • All Step-Servo drives and M2 Servo drives FL Feed to Length • All drives FM Feed to Sensor with Mask Dist • All drives FO Feed to Length & Set Output • All drives FP Feed to Position • All drives FS Feed to Sensor • All drives FY Feed to Sensor with Safety Dist • All drives HA Homing Acceleration • All Step-Servo drives and M2 Servo drives HC Hard Stop Current • All Step-Servo drives HL Homing Deceleration • All Step-Servo drives and M2 Servo drives HO Homing Offset • All Step-Servo drives and M2 Servo drives HS Hard Stop Homing HV Homing Velocity HW Hand Wheel JA Jog Accel/Decel rate • All drives JC Velocity mode second speed • All drives JD Jog Disable • All drives JE Jog Enable • All drives • • • read Immediate Compatibility only All drives All Step-Servo drives and M2 Servo drives All drives Servos and steppers with encoder feedback • All Step-Servo drives All Step-Servo drives and M2 Servo drives • • 15 All drives 920-0002 Rev. J 12/2014 Host Command Reference Motion Commands (continued) JL Jog Decel rate • All drives JM Jog Mode • Al drives (see JM command) JS Jog Speed • All drives MD Motor Disable • All drives ME Motor Enable • All drives MR Microstep Resolution • Stepper drives only PA Power-up Accel Current • STM stepper drives only SD Set Direction • STM stepper drives with Flex I/O only SH Seek Home • SJ Stop Jogging • SM Stop the Move • SP Set Absolute Position ST Stop Motion VC Velocity for Speed Change (FC) • All drives VE Velocity Setting (For Feed Commands) • All drives VM Velocity Max • All drives WM Wait on Move • Q drives only WP Wait on Position • Q drives only All drives • All drives Q drives only All drives • • All drives Servo Commands Command Description CN Second Control Mode • M2 servo drives only CO Node ID/ IP Address Series Number • M2 servo drives only CP Change Peak Current • Servo drives only DD Default Display Item of LEDs • M2 servo drives only DS Switching Electronic Gearing • M2 servo drives only EN Numerator of Electronic Gearing Ratio • M2 servo drives only EP Encoder Position EU Denominator of Electronic Gearing Ratio • M2 servo drives only FA Function of the Single-ended Analog Input • M2 servo drives only GC Current Command • GG Controller Global Gain Selection • IC Immediate Current Command • • Servo drives only IE Immediate Encoder Position • • Servo drives only IQ Immediate Actual Current • • Servo drives only IX Immediate Position Error • • Servo drives only JC Eight Jog Velocities • M2 servo drives only KC Overall Servo Filter • Servo drives only KD Differential Constant • Servo drives only 920-0002 Rev. J 12/2014 NV write only read Immediate Compatibility only Servo drives only • Servo drives only M2 servo drives only 16 Host Command Reference KE Differential Filter • Servo drives only KF Velocity Feedforward Constant • Servo drives only KI Integrator Constant • Servo drives only KJ Jerk Filter Frequency • SV7 Servo drives only KK Inertia Feedforward Constant • Servo drives only KP Proportional Constant • Servo drives only KV Velocity Feedback Constant • Servo drives only MS Control Mode Selection • M2 servo drives only PF Position Fault • Servo drives, drives with encoder feedback PH Inhibition of the pulse command • M2 servo drives only PK Parameter Lock • M2 servo drives only PL Position Limit • Servo drives only PP Power-Up Peak Current • Servo drives only PV Second Electronic Gearing • M2 servo drives only TV Torque Ripple • M2 servo drives only VI Velocity Integrator Constant • Servo drives only VP Velocity Mode Proportional Constant • Servo drives only VR Velocity Ripple • M2 servo drives only Configuration Commands Command Description NV write only read Immediate Compatibility only AL Alarm Code AR Alarm Reset BD Brake Disengage Delay time • All drives BE Brake Engage Delay time • All drives BS Buffer Status CA Change Acceleration Current • STM stepper drives only CC Change Current • All drives CD Idle Current Delay • Stepper drives only CF Anti-resonance Filter Frequency • Stepper drives only CG Anti-resonance Filter Gain • Stepper drives only CI Change Idle Current • Stepper drives only CM Control mode • All drives CP Change peak current • Servo drives only DA Define Address • All drives DL Define Limits • All drives DP Dumping Power • DR Data Register for Capture ED Encoder Direction • Servo drives, drives with encoder feedback ER Encoder or Resolution • Servo drives, drives with encoder feedback HG 4th Harmonic Filter Gain • Stepper drives only • • • • All drives • All drives • All drives SS drives only • 17 Q servo drives only 920-0002 Rev. J 12/2014 Host Command Reference Configuration Commands (continued) HP 4th Harmonic Filter Phase IA Immediate Analog • • All drives ID immediate Distance • • All drives IE Immediate Encoder • • Servo drives, drives with encoder feedback IF Immediate Format • All drives IQ Immediate Current • • Servo drives only IP Immediate Position • • All drives IT Immediate Temperature • • All drives IU Immediate Voltage • • All drives IV Immediate Velocity • • All drives LP Software Limit CW All Step-Servo drives and M2 Servo drives LM Software Limit CCW All Step-Servo drives and M2 Servo drives LV Low Voltage Threshold MD Motor Disable • All drives ME Motor Enable • All drives MN Model Number • All drives MO Motion Output • All drives MR Microstep Resolution • All drives (deprecated - see EG command) MV Model & Revision OF On Fault • Q drives only OI On Input • Q drives only OP Option Board • PA Power-up Acceleration Current • PC Power up Current • All drives PD In Position Counts • All Step-Servo drives and M2 Servo drives PE In Position Timing • All Step-Servo drives and M2 Servo drives PF Position Fault • Servo drives, drives with encoder feedback PI Power up Idle Current • Stepper drives only PL In Position Limit • Servo drives only PM Power up Mode • All drives PP Power up peak current • Servo drives only PW Pass Word • RE Restart / Reset • RL Register Load RS Request Status RV Revision Level SA Save all NV Parameters 920-0002 Rev. J 12/2014 • Stepper drives only • • All drives • • • • 18 • • All drives except Blu servos All drives Q drives only • All drives • All drives • • All drives • • All drives All drives Host Command Reference Configuration Commands (continued) SC Status Code • SD Set Direction • STM stepper drives with Flex I/O only SF Step Filter Frequency • Stepper drives only SI Enable Input usage • All drives SK Stop & Kill TT Pulse Complete Timing • All Step-Servo drives and M2 Servo drives ZC Regen Resistor Continuous Wattage • BLuAC5 and STAC6 drives only ZR Regen Resistor Value • BLuAC5 and STAC6 drives only ZT Regen Resistor Peak Time • BLuAC5 and STAC6 drives only • • • All drives I/O Commands Command Description NV write only read Immediate Compatibility only AD Analog Deadband • All stepper drives and SV servo drives AF Analog Filter • All drives AG Analog Velocity Gain • All stepper drives and SV servo drives AI Alarm Input usage • All drives AN Analog Torque Gain • All Step-Servo drives and M2 Servo drives AO Alarm Output usage • All drives AP Analog Position Gain • All drives AS Analog Scaling • All stepper drives and SV servo drives AT Analog Threshold • All drives AV Analog Offset • AZ Analog Zero (Auto Zero) BD Brake Disengage Delay time • All drives BE Brake Engage Delay time • All drives BO Brake Output usage • All drives DL Define Limits • All drives EI Input Noise Filter • All drives FI Filter Input • All drives (Note: not NV on Blu servos) FX Filter Selected Inputs IH Immediate High Output • • All drives IL Immediate Low Output • • All drives IO Output Status • All drives IS Input Status request • All drives MO Motion Output OI On Input SI Enable Input usage All drives • All drives Blu, STAC5, STAC6, SVAC3 • • All drives • • Q drives only All drives 19 920-0002 Rev. J 12/2014 Host Command Reference I/O Commands (continued) SO Set Output • All drives TI Test Input • Q drives only TO Tach Output WI Wait on Input • TSM drives only • All drives Communications Commands Command Description NV write only read Immediate Compatibility only BR Baud Rate BS Buffer Status • All drives CE Communications Error • All drives IF Immediate Format • • All drives PB Power up Baud Rate • All drives PR Protocol • All drives TD Transmit Delay • All drives • All drives Q Program Commands Command Description AX Alarm Reset MT Multi-Tasking NO No Operation • Q drives only OF On Fault • Q drives only OI On Input • Q drives only PS Pause • All drives QC Queue Call • Q drives only QD Queue Delete • Q drives only QE Queue Execute • QG Queue Goto • Q drives only QJ Queue Jump • Q drives only QK Queue Kill • Q drives only QL Queue Load • QR Queue Repeat • QS Queue Save • QU Queue Upload QX Queue Load & Execute • Q drives only SM Stop Move • Q drives only SS Send String • All drives TI Test Input • Q drives only WD Wait Delay using Data Register • Q drives only WI Wait for Input • All drives WM Wait for Move to complete • Q drives only WP Wait for Position in complex move • Q drives only WT Wait Time • Q drives only 920-0002 Rev. J 12/2014 NV write only read Immediate Compatibility only • All drives Q drives only • • Q drives only Q drives only • 20 Q drives only • Q drives only • Q drives only Host Command Reference Register Commands Command Description NV write only read Immediate Compatibility only CR Compare Register • Q drives only DR Data Register for Capture • Q drives only RC Register Counter • Q drives only RD Register Decrement • Q drives only RI Register Increment • Q drives only RL Register Load RM Register Move • Q drives only RR Register Read • Q drives only RU Register Upload • RW Register Write • RX Register Load R+ Register Addition • Q drives only R- Register Subtraction • Q drives only R* Register Multiplication • Q drives only R/ Register Division • Q drives only R& Register Logical AND • Q drives only R| Register Logical OR • Q drives only TR Test Register • Q drives only TS Time Stamp read • Q drives only • Q drives only • Q drives only Q drives only 21 920-0002 Rev. J 12/2014 Host Command Reference Command Listing This section is an alphabetical listing of all the commands available with your drive. Each page in this section contains the details of one available command. Below is a sample of what these pages look like, with an explanation of the information you will find on each page. Title - shows the command’s two-letter code followed by the command’s name. Compatibility - shows which drives use this command. DI - Distance/Position Compatibility: Affects: See also: Affects - a summary of parameters or other commands the command affects. All drives All move commands AC, DC, DE and VE commands Sets or requests the move distance in encoder counts (servo) or steps (stepper). The sign of DI indicates move direction: no sign means CW and “-” means CCW. DI sets both the distance for relative moves, like FL, and the position for absolute moves, like FP. DI also sets the direction of rotation for jogging (CJ). Command Details: Structure DI{Parameter #1} Type BUFFERED Usage READ/WRITE Non-Volatile YES Register Access “D” (020) distance - units encoder counts (servo) or steps (stepper) - range -2,147,483,647 to 2,147,483,647 sign determines direction: “-” for CCW, no sign for CW Examples: Command DI20000 DI Drive sends DI=20000 Notes Set distance to 20000 counts in the CW direction DI-8000 FL - Set distance to 8000 counts in the CCW direction Initiate FL move Description- an explanation of what the command does and how it works. Command Details - shows the command’s Structure, Type, Usage, Non-Volatile status, and Register Access. Structure always shows the two-letter command code followed by the number of parameters it uses. Not all commands have parameters, some commands have optional parameters, and other commands always have a parameter. Optional parameters are designated by { }, and required parameters are designated by ( ). Type can be BUFFERED or IMMEDIATE. Usage can be Read Only, Read/Write, or Write Only. Non-Volatile will show if the command can be saved (YES) or not (NO). Saving Non-Volatile commands to memory requires the SA (Save) command. Register Access shows any data registers associated with the command. If the command transfers data to a register that is accessible via the RL and RX commands, that register will be shown here. Parameter Details: Parameter #1 See Also - related commands Parameter Details - shows a description, the units, and the range of the parameter(s) available with a given command. Some commands will also have a Response Details section which shows how the drive’s response to the given command is formatted. Examples - shows what to expect when you use this command. Under “Command” are the command strings you would send from a host controller or write into a stored program. Under “Drive Sends” are the responses from the drive: no response from the drive is denoted by “-”. “Notes” give additional information about the results of the command string. 920-0002 Rev. J 12/2014 19 22 Host Command Reference AC - Acceleration Rate Compatibility: All drives Affects: FC, FD, FE, FL, FM, FS, FP, FY, SH commands See also: AM, DE, DI, DC, VE commands Sets or requests the acceleration rate used in point-to-point move commands in rev/sec/sec. Command Details: Structure AC{Parameter #1} Type BUFFERED Usage READ/WRITE Non-Volatile YES Register Access “A” (017) Note: Units of AC command and “A” register are different. See Data Registers section for details of “A” register. Parameter Details: Parameter #1 Acceleration rate - units rev/sec/sec (rps/s) - range 0.167 to 5461.167 (resolution is 0.167 rps/s) Examples: Command Drive sends AC100 - AC AC=100 Notes Set Acceleration to 100 rev/sec/sec AC25 DE25 VE1.5 FL20000 Set acceleration rate to 25 rev/sec/sec Set deceleration rate to 25 rev/sec/sec Set velocity to 1.5 rev/sec Execute Feed to Length move of 20000 steps - - - - 23 920-0002 Rev. J 12/2014 Host Command Reference AD - Analog Deadband Compatibility: All stepper drives and SV servo drives Affects: Analog input See also: CM command Sets or requests the analog deadband value in millivolts. The deadband value is the zone around the “zeroed” value of the analog input. This deadband defines the area of the analog input range that the drive should interpret as “zero”. This zero point can be used as the zero velocity point in analog velocity mode, or as the zero position point in analog position mode (see CM command). The deadband is an absolute value that in usage is applied to either side of the zero point. Note that in Analog Positioning mode (CM22), the AD setting is used as a hysteresis value rather than a standard deadband setting. As such, it will work over the entire analog range, not just at zero volts. Command Details: Structure AD{Parameter #1} Type BUFFERED Usage READ/WRITE Non-Volatile YES Register Access Setting the AD command will affect the contents of the “a” (Analog Command) register Parameter Details: Parameter #1 Analog deadband value - units millivolts - range 0 - 255 Examples: Command Drive sends AD100 - AD AD=100 920-0002 Rev. J 12/2014 Notes Set analog deadband to 0.1 volts 24 Host Command Reference AD - Analog Deadband (M2 drives) Compatibility: M2 drives Affects: Analog inputs See also: AV, AF, AS commands Sets or requests the analog dead band value of the analog input in millivolts. The dead band value is the zone around the “zeroed” value of the analog input. This dead band defines the area of the analog input range that the drive should interpret as “zero”. The dead band is an absolute value that in usage is applied to either side of the zero point. The command has two parameters: the first parameter selects the analog channel (Range: 1~3); the second parameter set the dead band value of the selected analog channel (Range:0~255). 1 – select analog channel 1 2 – select analog channel 2 3 – select differential analog Command Details: Structure AD{Parameter #1}{Parameter #2} Type BUFFERED Usage READ/WRITE Non-Volatile YES Register Access NONE Parameter Details: Parameter #1 Analog channel - units None - range 1~3 Parameter #2 Analog dead band value - units millivolts - range 0~255 Default value 0 Examples: Command AD110 AD1 Drive sends % AD1=10 Notes Set the dead band of Ain1 to 10 mV The dead band of Ain1 is 10 mV 25 920-0002 Rev. J 12/2014 Host Command Reference AF - Analog Filter Compatibility: All drives Affects: All commands using the analog inputs See also: IA, CM commands Applies a digital filter to the analog input(s). This is a simple single pole filter that rolls off the analog input. The filter value of the AF command is related to the desired value of the analog filter in Hz by the following equation: Filter value = 72090 / [ (1400 / x ) + 2.2 ] where x = desired value of the analog filter in Hz Command Details: Structure AF{Parameter #1} Type BUFFERED Usage READ/WRITE Non-Volatile YES Register Access Setting the AF command will affect the responsiveness of the “a”, “j”, and “k” registers to changes in analog voltage Parameter Details: Parameter #1 Filter value - units integer (see formula above) - range 0 - 32767* (0 disables the filter) * An AF value of 28271 equates to 4000.425 Hz. Setting the AF command to anything higher than 28271 has a negligible effect on the analog filter. In other words, the maximum value of the filter is approximately 4000 Hz. Examples: Command Drive sends AF5000 - AF AF=5000 920-0002 Rev. J 12/2014 Notes Make the analog input bandwidth 114.585 Hz 26 Host Command Reference AG - Analog Velocity Gain Compatibility: All stepper drives and SV servo drives Affects: Analog velocity modes See also: CM command Sets or requests the gain value used in analog velocity / oscillator modes. The gain value is used to establish the relationship between the analog input and the motor speed. The units are 0.25 rpm. For example, if the analog input is scaled to 0 - 5 volt input and the gain is set to 2400, when 5 volts is read at the analog input the motor will spin at 10 rps. TIP: To set the analog velocity gain to the desired value, multiply the desired motor speed in rps by 240, or the desired motor speed in rpm by 4. Command Details: Structure AG{Parameter #1} Type BUFFERED Usage READ/WRITE Non-Volatile YES Register Access None Parameter Details: Parameter #1 Analog velocity gain value - units 0.25 rpm - range -32767 to 32767 Examples: Command Drive sends AG3000 - AG AG=3000 Notes Set top speed of analog velocity mode to 12.5 rps 27 920-0002 Rev. J 12/2014 Host Command Reference AI - Alarm Reset Input Compatibility: All drives, see below Affects: Alarm Reset input usage See also: AL, CM, DL, SI, SD commands BLu, SV, STAC6, ST-Q/Si Defines the function of the X4 input. This input can be used to clear a drive fault and reset the Alarm Code (see AL command). When the Alarm Reset function is not needed at input X4, such as when operating with a host controller where faults and alarms can be cleared via serial commands, it may be useful to reconfigure X4 as a general purpose input, which allows it to be used by other types of input commands. There are three Alarm Reset Input states that can be defined with the AI command: AI1: For normal operation the X4 input must be open (inactive, high). Alarm reset occurs when the input is closed (active, low). This is an edgetriggered event. If the switch is closed when an alarm is activated no reset will occur. The input must be opened (inactive, high) and then closed to reset the alarm. AI1 (high) (high) (low) time A B A B C C (low) D time A B Input is open, normal operation Alarm occurs Input closed, alarm is reset A B C D (high) (high) (low) (low) C D E Input is closed Alarm occurs Input opened, no reset occurs Input closed, alarm is reset AI2 time AI2: For normal operation the A B C D A B C D E X4 input must be closed (active, low). Alarm reset A Input is closed, normal operation A Input is open occurs when the input is B Alarm occurs B Alarm occurs opened (inactive, high). C Input opened, alarm is reset C Input closed, no reset occurs D Input opened, alarm is reset This is an edge-triggered event. If the switch is open when an alarm is activated no reset will occur. The input must be closed and then opened to reset the alarm. time AI3: Input is not used for Alarm Reset and can be used as a general purpose input. ST-S, STM17, STM23 Defines the EN input as an Alarm Reset Input. If you want to use the EN input as an Alarm Reset input you can define it as such in two ways, with the ST Configurator software, or with the AI command. AI takes no effect if the drive is set in Command Mode (CM) 13, 14, 17 or 18, because these modes use the EN input as a speed change input and take precedence over the AI command. Also, setting the SI command after setting the AI command reassigns the EN input to drive enable usage and turns off any alarm reset usage (AI3). In other words, the AI and SI commands, as well as Command Modes (CM) 13, 14, 17 and 18 each assign a usage to the EN input. Each of these must exclusively use the EN input. There are three Alarm Reset Input states that can be defined with the AI command: AI1: For normal operation the EN input must be open (inactive, high). Alarm reset occurs when the EN input is closed (active, low). This is an edge-triggered event. If the switch is closed when an alarm is activated no reset will occur. The input must be opened and then closed to reset the alarm. After the alarm is cleared, the drive will be enabled when the input is opened again. 920-0002 Rev. J 12/2014 28 Host Command Reference AI2 : For normal operation the EN input must be closed (active, low). Alarm reset occurs when the input is opened (inactive, high). This is an edge-triggered event. If the switch is open when an alarm is activated no reset will occur. The input must be closed and then opened to reset the alarm. After the alarm is cleared, the drive will be enabled when the input is closed again. AI3: The EN Input is not used for Alarm Reset and may be used as a general purpose input. AI will be automatically set to 3 if CM is set to 13, 14, 17, or 18 or if SI is set to either 1 or 2 after the AI command is set. AI1 (high) (high) (low) time A B A B C D C (low) D time A B Input is open, normal operation Alarm occurs Input closed, alarm is reset Input opened, drive is re-enabled A B C D E (high) (high) C D E Input is closed Alarm occurs Input opened, no reset occurs Input closed, alarm is reset Input opened, drive is re-enabled AI2 (low) time A B A B C D C (low) D time A B Input is closed, normal operation Alarm occurs Input opened, alarm is reset Input closed, drive is re-enabled A B C D E C D E Input is open Alarm occurs Input closed, no reset occurs Input opened, alarm is reset Input closed, drive is re-enabled STM24 Drives with Flex I/O allow a second parameter which allows the user to specify the I/O point used as the Alarm Reset input. Before an I/O point can be used as an Alarm Reset input it must first be configured as an input with the SD command. See the STM24 Hardware Manual for details of which inputs may be used as the Alarm Reset input. Possible uses for the AI command on the STM24 are as follows (‘n’ denotes the I/O point to be used): AI1n: For normal operation the designated input ‘n’ must be open (inactive, high). Alarm reset occurs when the input is closed (active, low). This is an edge-triggered event. If the switch is closed when an alarm is activated no reset will occur. The input must be opened (inactive, high) and then closed to reset the alarm. The drive will be enabled when the input is returned to the opened state (inactive, high), unless the SI command has been used to configure hardware enable functionality. AI1n (high) (high) (low) time A B A B C D C (low) D time A B Input is open, normal operation Alarm occurs Input closed, alarm is reset Input opened, drive is re-enabled A B C D E C D E Input is closed Alarm occurs Input opened, no reset occurs Input closed, alarm is reset Input opened, drive is re-enabled AI2n (high) (high) (low) time A B A B C D C (low) D Input is closed, normal operation Alarm occurs Input opened, alarm is reset Input closed, drive is re-enabled time A B A B C D E C D E Input is open Alarm occurs Input closed, no reset occurs Input opened, alarm is reset Input closed, drive is re-enabled AI2n: For normal operation the designated input ‘n’ input must be closed (active, low). Alarm reset occurs when the designated input is opened (de-energized). This is an edge-triggered event. If the switch is open when an alarm is activated no reset will occur. The input must be closed (energized) and then opened to reset the alarm. The drive will be enabled when the input is returned to the closed state 29 920-0002 Rev. J 12/2014 Host Command Reference (active, low), unless the SI command has been used to configure hardware enable functionality. AI3n: The designated input ‘n’ is not used for Alarm Reset and may be used as a general purpose input. NOTE: A rule of thumb when using the Alarm Reset function is to toggle the designated input twice whenever an alarm occurs. That is, if the input is normally open (inactive, high), it should be closed and then opened again. If the input is normally closed (active, low), it should be opened and then closed again. Command Details: Structure AI{Parameter #1}{Parameter #2 (Flex I/O only)} Type BUFFERED Usage READ/WRITE Non-Volatile YES Register Access None Parameter Details: Parameter #1 Input Usage - units integer code - range 1, 2, or 3 Parameter #2 (Flex I/O only) I/O Point (if applicable, see note below) - units Integer Code - range 2 or 4 (See STM24 Hardware Manual for details) NOTES: • For drives equipped with Flex I/O, the SD command must be executed to set an I/O point as an input before it can be used as the Alarm Reset Input. • Parameter #2 only applies to drives equipped with Flex I/O. Parameter #2 is not defined for drives equipped with standard I/O. Examples: All drives with standard I/O: Command Drive sends AI1 - AI AI=1 Drives with Flex I/O: Command Drive sends SD4I - AI14 - AI AI=14 Notes Enables input to reset alarm when closed (active, low) Notes Configures I/O 4 as input (see SD command for details) Assigns input 4 to reset the alarm when closed (active, low) NOTE: When working with digital inputs and outputs it is important to remember the designations low and high. If current is flowing into or out of an input or output, i.e. the circuit is energized, the logic state for that input/output is defined as low or closed. If no current is flowing, i.e. the circuit is de-energized, or the input/output is not connected, the logic state is high or open. A low state is represented by the “L” character in parameters of commands that affect inputs/outputs. For example, WI3L means “wait for input 3 low”, and SO1L means “set output 1 low”. A high state is represented by the “H” character. 920-0002 Rev. J 12/2014 30 Host Command Reference AL - Alarm Code Compatibility: All drives See also: AI, AR, AX commands, Appendix Reads back an equivalent hexadecimal value of the Alarm Code’s 16-bit binary word. Command Details: Structure AL Command Type IMMEDIATE Usage READ ONLY Non-Volatile NO Register Access “f” (054) Note: response to AL command is a different format than the response to the RLf command. See Appendix F for details. Units Hexadecimal value of 16-bit binary word (see below) Response Details: Hex Value BLu SV STAC6 ST 0001 Position Limit 0002 CCW Limit 0004 CW Limit 0008 Over Temp 0010 Excess Regen* Internal Voltage Under Voltage* Under Voltage Under Voltage Bad Hall Sensor Under Voltage Open Motor Winding Bad Encoder 0200 0400 Comm Error 0800 Bad Flash 1000 Wizard Failed 2000 Current Foldback 4000 8000 Under Voltage Over Current 0080 0100 Internal Voltage Internal Voltage Over Voltage 0020 0040 Excess Regen STM (not used) No Move Motor Resistance Out of Range (not used) (not used) Blank Q Segment No Move (not used) * BLuAC drives only NOTE: Items in bold italic represent Drive Faults, which automatically disable the motor. Use the OF command in a Q Program to branch on a Drive Fault. NOTE: See Appendix for more detailed information on Alarm Codes. Examples: Command AL AL AL Drive sends AL=0000 AL=0001 AL=0201 Notes No alarms Position limit alarm Position limit and bad encoder signal alarms 31 920-0002 Rev. J 12/2014 Host Command Reference Hex Value SSM/TSM/TXM SS 0001 Position Limit 0002 CCW Limit 0004 CW Limit 0008 Over Temp 0010 Internal Voltage 0020 Over Voltage 0040 Under Voltage Under Voltage Open Motor Winding Open Motor Winding 0200 Bad Encoder 0400 Comm Error 0800 Bad Flash 1000 No Move No Move 2000 Current Foldback 4000 Bland Q Segment 8000 Under Voltage Over Current 0080 0100 M2 NV Memory Double Error NV Memory Double Error Bad Hall Excess Regen No Move NOTE: Items in bold italic represent Drive Faults, which automatically disable the motor. Use the OF command in a Q Program to branch on a Drive Fault. NOTE: See Appendix for more detailed information on Alarm Codes. For SS and M2 drive, AL command has a optional parameter 1 to read back the higher 16 bit of alarm code. Response Details: Hex Value SS M2 0001 Excess Regen AC Power Phase Lost 0002 Reserved Safe Torque Off 0004 Reserved Reserved 0008 Reserved Velocity Limit 0010 Reserved Voltage Warning Examples: Command Drive sends Notes AL1 AL1=0000 No alarms AL1 AL1=0001 Excess Regen (For SS) 920-0002 Rev. J 12/2014 32 Host Command Reference AM - Max Acceleration Compatibility: All drives Affects: ST, SK , SM, QK commands; analog velocity and oscillator modes See also: VM command Sets or requests the maximum acceleration/deceleration allowed when using analog velocity and oscillator modes. Also sets the deceleration rate used when an end-of-travel limit is activated during a move or when an ST (Stop) or SK (Stop & Kill) command is sent. Command Details: Structure AM{Parameter #1} Type BUFFERED Usage READ/WRITE Non-Volatile YES Register Access None Parameter Details: Parameter #1 Maximum acceleration/deceleration - units rev/sec/sec (rps/s) - range 0.167 - 5461.167 (resolution is 0.167 rps/s) Examples: Command Drive sends AM2000 - AM AM=2000 Notes Set maximum acceleration/deceleration values to 2000 rev/sec/sec. 33 920-0002 Rev. J 12/2014 Host Command Reference AN - Analog Torque Gain Compatibility: SSM, TSM, TXM, SS, SSAC and M2 drives Affects: CM2, 3 and 4 (Analog Torque Command Mode) See also: AD, AF, AZ, CM, CC, SF commands Sets or requests the analog Input gain that relates to motor current when the drive is in analog Torque command mode (see CM command, parameter value 2, 3 or 4). Gain value sets the commanded current when the analog input is at the configured full scale value. Step-Servo Quick Tuner software can be used to configure the analog inputs for the desired input type, scaling and offsetting. The parameter of AN command should be not greater than the parameter of CC command. Command Details: Structure AN{Parameter #1} Type BUFFERED Usage READ/WRITE Non-Volatile YES Register Access NONE Parameter Details: Parameter #1 Analog Torque gain value - units amps (resolution is 0.01 amps) - range related to CC command Examples: Command Drive sends AN1 % AN AN=1 920-0002 Rev. J 12/2014 Notes Current range over full scale of analog input is 1A 34 Host Command Reference AO - Alarm Output Compatibility: All drives Affects: Alarm Output usage See also: AI, BO, MO, SD, SI commands BLu, SV, STAC6, ST-Q/Si, SVAC3-Q/S/IP, STAC5-Q/S/IP Defines usage of digital output Y3. Normally this output is used to indicate an Alarm caused by a Drive Fault. This output can being reconfigured as a general purpose output for use with other types of output commands. There are three states that can be defined: AO1: Output is closed (active, low) when a Drive Fault is present. AO2: Output is open (inactive, high) when an Drive Fault is present. AO3: Output is not used as an Alarm Output and can be used as a general purpose output. ST-S, STM17, STM23, STM24-C Defines the drive’s digital output as an Alarm Output. The output of a drive can be assigned to one of five functions: Alarm Output, Brake Output, Motion Output, Tach Output or General Purpose Output. Each of these functions must exclusively use the output, so only one function is allowed. There are two ways to define the function of this output: via the ST Configurator or via SCL commands. To set the output as an Alarm Output, use the AO command and one of the codes below. There are three Alarm Output states that can be defined with the AO command: AO1: Output is closed (active, low) when a Drive Fault is present. AO2: Output is open (inactive, high) when a Drive Fault is present. AO3: Output is not used as an Alarm Output and can be used for another automatic output function or as a general purpose output. STM24-SF/QF Drives with Flex I/O allow a second parameter which allows the user to specify the I/O point used. Before an I/O point can be used as an Alarm Output it must first be configured as an output with the SD command. Possible uses for the AO command on the STM24 are as follows (‘n’ denotes the I/O point to be used): AO1n: Designated output ‘n’ is closed (active, low) when a Drive Fault is present. AO2n: Designated output ‘n’ is open (inactive, high) when a Drive Fault is present. AO3n: Designated output ‘n’ is not used as an Alarm Output and can be used for another automatic output function or as a general purpose output. NOTE: Setting the AO command to 1 or 2 overrides previous assignments of this output’s function. Similarly, if you use the BO or MO command to set the function of the output after setting the AO command to 1 or 2, usage of the output will be reassigned and AO will be automatically set to 3. Command Details: Structure AO{Parameter #1}{Parameter #2 (Flex I/O only)} Type BUFFERED Usage READ/WRITE Non-Volatile YES Register Access None 35 920-0002 Rev. J 12/2014 Host Command Reference Parameter Details: Parameter #1 Output Usage (see above) - units integer code - range 1, 2 or 3 Parameter #2 (Flex I/O only) I/O Point (if applicable, see note below) - units integer code - range 1-4 NOTES: • For drives with Flex I/O, the SD command must be executed to set an I/O point as an input or output before that output can be designated as the Alarm Output. • Parameter #2 only applies to drives equipped with Flex I/O. This includes the STM24SF and STM24QF. Parameter #2 is not defined for drives equipped with standard I/O. Examples: All drives with standard I/O: Command Drive sends AO1 - AO AO=1 Drives with Flex I/O only: Command Drive sends SD4O - AO14 - AO AO=14 Notes Alarm Output will close when a Drive Fault occurs Notes Configures I/O 4 as output (see SD command for details) Alarm Output is mapped to output #4, and will close when a Drive Fault occurs. NOTE: When working with digital inputs and outputs it is important to remember the designations low and high. If current is flowing into or out of an input or output, i.e. the circuit is energized, the logic state for that input/output is defined as low or closed. If no current is flowing, i.e. the circuit is de-energized, or the input/output is not connected, the logic state is high or open. A low state is represented by the “L” character in parameters of commands that affect inputs/outputs. For example, WI3L means “wait for input 3 low”, and SO1L means “set output 1 low”. A high state is represented by the “H” character. 920-0002 Rev. J 12/2014 36 Host Command Reference AP - Analog Position Gain Compatibility: All drives Affects: CM22 (Analog Positioning Command Mode) See also: AD, AF, AZ, CM, SF commands Sets or requests the analog Input gain that relates to motor position when the drive is in analog position command mode (see CM command, parameter value 22). Gain value sets the commanded position when the analog input is at the configured full scale value. Quick Tuner (BLu, SV), STAC6 Configurator (STAC6), or ST Configurator (ST, STM) can be used to configure the analog inputs for the desired input type, scaling and offsetting. Command Details: Structure AP{Parameter #1} Type BUFFERED Usage READ/WRITE Non-Volatile YES Register Access “X” (040) Parameter Details: Parameter #1 Analog position gain value - units encoder counts - range 0 - 32767 Examples: Command Drive sends AP8000 - AP AP=8000 Notes Position range over full scale of analog input is 8000 steps 37 920-0002 Rev. J 12/2014 Host Command Reference AR - Alarm Reset (Immediate) Compatibility: All drives Affects: Alarm Code See also: AL, ME, MD commands Clears Alarms and Drive Faults. If an Alarm or Drive Fault condition persists after sending the AR command the Alarm is not cleared. NOTE: Does not re-enable the drive. Use ME (Motor Enable) command to re-enable drive. Command Details: Structure AR Type IMMEDIATE Usage WRITE ONLY Non-Volatile NO Register Access None Examples: Command AR 920-0002 Rev. J 12/2014 Drive sends - Notes Reset Drive Fault and clear Alarm Code (if possible) 38 Host Command Reference AS - Analog Scaling Compatibility: All stepper drives and SV servo drives Affects: Analog input See also: CM command Sets or requests the analog input scaling setting. This is a code that determines what type of analog input scaling is desired. The codes for selecting the various settings are in the Details table below. Command Details: Structure AS{Parameter #1} Type BUFFERED Usage READ/WRITE Non-Volatile YES Register Access None Parameter Details: Parameter #1 Code - units integer number - range 0 = single-ended +/- 10 volts 1 = single-ended 0 - 10 volts 2 = single-ended +/- 5 volts 3 = single-ended 0 - 5 volts 4 = differential +/- 10 volts 5 = differential 0 - 10 volts 6 = differential +/- 5 volts 7 = differential 0 - 5 volts - range (M2 only) 0 = single-ended +/-10 volts 1 = differential +/- 10 volts Examples: Command Drive sends AS2 - AS AS=2 Notes Analog input scaling set to single-ended +/- 5 volts 39 920-0002 Rev. J 12/2014 Host Command Reference AT - Analog Threshold Compatibility: All drives Affects: All “Feed to Sensor” type commands See also: AF, AZ, FS, FY, FD commands Sets or requests the Analog Input Threshold that is used by the “Feed to Sensor” command. The threshold value sets the Analog voltage that determines a sensor state or a trigger value. Command Details: Structure AT{Parameter #1} Type BUFFERED Usage READ/WRITE Non-Volatile YES Register Access “Y” (041) Parameter Details: Parameter #1 Analog threshold value - units volts - range BLu, SV, STAC6, ST-Q/Si, STAC5, SVAC3: -10.000 to 10.000 ST-S, STM: 0.000 to 5.000 Examples: Command Drive sends AT4.5 - AT AT=4.5 920-0002 Rev. J 12/2014 Notes Analog input threshold set to 4.5 volts 40 Host Command Reference AV - Analog Offset Value Compatibility: All drives (except M2) Affects: All Analog input functions See also: AF, AP, AZ, CM & Feed commands Sets or requests the analog offset value in volts. Command Details: Structure AV{Parameter #1} Type BUFFERED Usage READ/WRITE Non-Volatile YES Register Access “Z” (042) Note: Units of AV command are different than units of “Z” register; see Data Registers section for more details Parameter Details: Parameter #1 Analog offset value - units Volts - range BLu, SV, STAC6, ST-Q/Si, STAC5, SVAC3: -10.000 to 10.000 ST-S, STM: -5.000 to 5.000 Examples: Command Drive sends AV0.25 - AV AV=0.25 Notes Set analog offset to 0.25 Volts 41 920-0002 Rev. J 12/2014 Host Command Reference AV - Analog Offset Value (M2 drives) Compatibility: M2 drives Affects: analog inputs See also: AD, AF, AS commands Sets or requests the offset value of the analog input in volts. The command has two parameters: the first parameter selects the analog channel (Range: 1~3); the second parameter set the offset value of the selected analog channel (Range: -10~10). 1 – select analog channel 1 2 – select analog channel 2 3 – select differential analog Command Details: Structure AV{Parameter #1}{Parameter #2} Type BUFFERED Usage READ/WRITE Non-Volatile YES Register Access None Parameter Details: Parameter #1 Analog channel - units None - range 1~3 Parameter #2 Analog offset value - units volts - range 0~255 Default value 0 Examples: Command AV11 AV1 920-0002 Rev. J 12/2014 Drive sends % AV1=1 Notes set the offset of Ain1 to 1V the offset of Ain1 is 1V 42 Host Command Reference AX - Alarm Reset (Buffered) Compatibility: All drives Affects: Alarm Code See also: AR, ME, OF, WT Commands Clears Alarms and Drive Faults. This command functions the same as AR (Alarm Reset) but is a Buffered type command. Typically used in conjunction with OF within a Q program. Please note that while immediately executing AX will clear the alarm code, it does not guarantee that the condition that caused the alarm has been resolved. Therefore it is recommended to include a short delay or wait for user input before clearing the alarm and resuming normal operation. In addition to clearing alarms and faults, the AX command resets the LED blink timer. As such, if the AX command is used within a tight loop in a Q program, the LED may actually appear to be solid green. NOTE: Does not re-enable the drive. Use ME (Motor Enable) command to re-enable drive. Command Details: Structure AX Type BUFFERED Usage WRITE ONLY Non-Volatile NO Register Access None Examples: Command Drive sends Notes In segment 1 of a Q program... OF9 - When a drive fault occurs load and execute program segment 9 In segment 9 of the same Q program... WT0.1 - AX - ME - QX1 - Short delay to allow the system to settle Alarm reset Motor enable Load and execute segment 1, which will also reset the OF function. 43 920-0002 Rev. J 12/2014 Host Command Reference AZ - Analog Zero Compatibility: All drives Affects: All Analog input functions See also: AF, AP, AV, CM & Feed commands Activates the analog “auto offset” algorithm. It is useful in defining the current voltage present at the analog input as the zero reference point, or offset. Command Details: Structure AZ Type BUFFERED Usage WRITE ONLY Non-Volatile NO Register Access None Examples: Command AZ Drive sends - Notes Start analog offset algorithm Example: Apply 1 VDC across the AIN and GND terminals of the drive. Then send the AZ command to the drive. Next apply 4 VDC across the AIN and GND terminals. Send the IA command and the response will be very close to IA=3.00 (or 4 - 1 VDC). 920-0002 Rev. J 12/2014 44 Host Command Reference BD - Brake Disengage Delay Compatibility: All drives Affects: All “F” (Feed) and Jog commands. See also: BE command This command only takes effect if the BO command is set to 1 or 2. After a drive is enabled this is the time value that may delay a move waiting for the brake to disengage. When beginning a move the delay value must expire before a move can take place. The delay timer begins counting down immediately after the drive is enabled and the brake output is set. The BD command sets a time in milliseconds that a move may be delayed. Command Details: Structure BD{Parameter #1} Type BUFFERED Usage READ/WRITE Non-Volatile YES Register Access None Parameter Details: Parameter #1 Delay time - units seconds - range 0 - 32.767 Examples: Command Drive sends BD0.2 - BD BD=0.2 Notes Sets brake disengage delay to 200 ms 45 920-0002 Rev. J 12/2014 Host Command Reference BE - Brake Engage Delay Compatibility: All drives Affects: All “F” (Feed) and Jog commands. See also: BD command This command only takes effect if the BO command is set to 1 or 2. After a drive is commanded to be disabled, this is the time value that delays the actual disabling of the driver output. When using the dedicated brake output (see BO command) the output is activated immediately with the disable command, then the drive waits the delay time before turning off the motor current. Command Details: Structure BE{Parameter #1} Type BUFFERED Usage READ/WRITE Non-Volatile YES Register Access None Parameter Details: Parameter #1 Delay time - units seconds - range 0 - 32.767 Examples: Command Drive sends BE0.25 - BE BE=0.25 920-0002 Rev. J 12/2014 Notes Sets brake engage delay to 250 ms 46 Host Command Reference BO - Brake Output Compatibility: All drives Affects: Function of digital output See also: AI, AO, BD, ME, MD, MO, SD, SI commands NOTE: The digital output circuits available on MOONS’ drives are not sized for directly driving a typical holding brake. An external relay must be wired in circuit between the digital output of the drive and the holding brake. See the appropriate drive hardware manual for an example wiring diagram. BLu, SV, STAC6, ST-Q/Si Defines usage of digital output Y1 as the Brake Output, which can be used to automatically activate and deactivate a holding brake. Output Y1 can also be configured as a general purpose output for use with other types of output commands. There are three states that can be defined: BO1: Output is closed (energized) when drive is enabled, and open when the drive is disabled. BO2: Output is open (de-energized) when drive is enabled, and closed when the drive is disabled. BO3: Output is not used as a Brake Output and can be used as a general purpose output. ST-S, STM17, STM23, STM24-C Defines the drive’s digital output as a Brake Output. The output of a drive can be assigned to one of five functions: Alarm Output, Brake Output, Motion Output, Tach Output, or General Purpose Output. Each of these functions must exclusively use the output, so only one function is allowed. There are two ways to define the function of this output: via ST Configurator or via SCL commands. To set the output as a Brake Output, use the BO command and one of the codes below. BO1: Output is closed (active, low) when the drive is enabled, and open when the drives is disabled. BO2: Output is open (inactive, high) when the drive is enabled, and closed when the drive is disabled. BO3: Output is not used as a Brake Output and can be used for another automatic output function or as a general purpose output. STM24-SF/QF Drives with Flex I/O allow a second parameter which allows the user to specify the I/O point used. Before an I/O point can be used as a Brake Output it must first be configured as an output with the SD command. Possible uses for the BO command on the STM24 are as follows (‘n’ denotes the I/O point to be used): BO1n: Designated output ‘n’ is closed (active, low) when the drive is enabled and open when the drive is disabled. BO2n: Designated output ‘n’ is open (inactive, high) when the drive is enabled and closed when the drive is disabled. BO3n: Designated output ‘n’ is not used as a Brake Output and can be used for another automatic output function or as a general purpose output. STAC5-S, SVAC3-S Defines usage of digital output Y2 as the Brake Output, which can be used to automatically activate and deacti¬vate a holding brake. Output Y2 can also be configured as a Motion Output, a Tach Output, or a General Purpose output for use with other types of output commands. There are three states that can be defined: BO1: Output is closed (energized) when drive is enabled, and open when the drive is disabled. BO2: Output is open (de-energized) when drive is enabled, and closed when the drive is disabled. BO3: Output is not used as a Brake Output and can be used as a general purpose output. 47 920-0002 Rev. J 12/2014 Host Command Reference STAC5-Q/IP, SVAC3-Q/IP Defines usage of digital output Y2 as the Brake Output, which can be used to automatically activate and deactivate a holding brake. Output Y2 can also be configured as a Tach Output, or a General Purpose output for use with other types of output commands. There are three states that can be defined: BO1: Output is closed (energized) when drive is enabled, and open when the drive is disabled. BO2: Output is open (de-energized) when drive is enabled, and closed when the drive is disabled. BO3: Output is not used as a Brake Output and can be used as a general purpose output. NOTE: Setting the BO command to 1 or 2 overrides previous assignments of this output’s function. Similarly, if you use the AO or MO command to set the function of the output after setting the BO command to 1 or 2, usage of the output will be reassigned and BO will be automatically set to 3. Command Details: Structure BO{Parameter #1}{Parameter #2 (Flex I/O only} Type BUFFERED Usage READ/WRITE Non-Volatile YES Register Access None Parameter Details: Parameter #1 Output Usage (see above) - units integer code - range 1, 2 or 3 Parameter #2 (Flex I/O only) I/O Point (if applicable, see note below) - units integer code - range 1-4 NOTES: • For drives with Flex I/O, the SD command must be executed to set an I/O point as an output before that output can be assigned as the Brake Output. • Parameter #2 only applies to drives equipped with Flex I/O. This includes the STM24SF and STM24QF. Parameter #2 is not defined for drives equipped with standard I/O. Examples: All drives with standard I/O: Command Drive sends BO1 - BO BO=1 Notes Brake Output will be closed when drive is enabled Drives with Flex I/O only: Command Drive sends Notes SD4O - Configures I/O 4 as output (see SD command for details) BO14 - Brake Output is mapped to I/O point 4 and will be Closed when drive is enabled BO BO=14 920-0002 Rev. J 12/2014 48 Host Command Reference BR - Baud Rate Compatibility: All drives Affects: Serial communications See also: TD, PB, PM, PR commands Sets or requests the bit rate (baud) for serial communications. At power up a drive will send its power-up packet at 9600 baud. If a response from a host system (such as a software application from MOONS’) is not detected after 1 second and the drive is configured for SCL or Q operation (see PM command) the drive will set the baud rate according to the value stored in the Baud Rate NV parameter. A Host system can set the baud rate at anytime using this command. See Appendix B, “Host Serial Communications” for details. NOTE 1: Setting the value takes effect immediately. NOTE 2: Due to processor speed limitations, -Si drives can accept only parameter values 1, 2 or 3. -S and -Q drives will accept parameter values of 1-5. Command Details: Structure BR{Parameter #1} Type BUFFERED Usage READ/WRITE Non-Volatile YES Register Access None Parameter Details: Parameter #1 Baud rate (see above) - units integer code - range 1 = 9600 bps 2 = 19200 3 = 38400 4 = 57600 (-S and -Q drives only) 5 = 115200 (-S and -Q drives only) Examples: Command Drive sends BR2 - BR BR=2 Notes Baud rate is immediately set to 19200 49 920-0002 Rev. J 12/2014 Host Command Reference BS - Buffer Status Compatibility: All drives See also: CT, PS commands Requests from the drive the number of available command locations in the command buffer. This technique simplifies sending commands by eliminating the need to calculate if there is enough space in the buffer for a command. If the drive responds with at least a “1”, a command can be sent. If a drive responds to the BS command with the value “63” it means the buffer is empty. If a “0” is returned the buffer is full and no more buffered commands can be accepted (a buffer overflow will occur if another command is sent). Command Details: Structure BS Type IMMEDIATE Usage READ ONLY Non-Volatile NO Register Access None Units Empty command spaces in buffer Examples: Command BS 920-0002 Rev. J 12/2014 Drive sends BS=20 Notes There is room in the buffer for 20 more commands 50 Host Command Reference CA - Change Acceleration Current Compatibility: STM Integrated Step Motors Affects: Motor accel/decel current and torque See also: PA, CC, PC commands Sets or requests the accel/decel current setting (“peak of sine”) of the stepper drive, also known as the peak current. CA will only accept parameter values equal to or larger than the current CC setting. NOTE: CA has no effect in Command Mode 7 (CM7 - Step and Direction mode). Command Details: Structure CA{Parameter #1} Type BUFFERED Usage READ/WRITE Non-Volatile YES Register Access “M” (029) Note: The CA command uses different units than the “M” register; see Data Registers section for details Parameter Details: Parameter #1 Accel/Decel Current - units amps (resolution is 0.01 amps) - range STM23: 0 - 5.0 STM17: 0 - 2.0 Configurator software may also be used to set all current levels. Example: STM17, STM23 Command Drive Sends Notes CA1.75 - Set accel/decel current to 1.75 amps (peak of sine) CA CA=1.75 51 920-0002 Rev. J 12/2014 Host Command Reference CB – CANopen Baudrate Compatibility: M2 drives Affects: CANopen drives See Also: None Sets or requests the CANopen baudrate of CANopen type drives. 0 – 1 Mbps 1 – 800 kbps 2 – 500 kbps 3 – 250 kbps 4 – 125 kbps 5 – 50 kbps 6 – 20 kbps 7 – 12.5 kbps Command Details: Structure CB{Parameter #1} Type BUFFERED Usage READ/WRITE Non-Volatile Yes Register Access None Units Empty command spaces in buffer Parameter Details: Parameter #1 CANopen baudrate of C type drive - units Integer - range 0~7 Default value 0 Examples: Command CB1 CB 920-0002 Rev. J 12/2014 Drive sends % CB=1 Notes Set the baudrate of CANopen drive to 1 Mbps The baudrate of CANopen drive is 1 Mbps 52 Host Command Reference CC - Change Current Compatibility: All drives Affects: Motor current and torque See also: CA, CI, CP, PC commands BLu, SV Sets or requests the continuous (RMS) current setting of the servo drive. STAC6 Sets or requests the current setting (“peak of sine”) of the stepper drive, also known as the running current. The range of the CC command may be limited from the ranges shown in the Parameters table below based on the settings defined in the STAC6 Configurator software. Use STAC6 Configurator to select a motor and set the maximum current setting. Note that setting CC automatically sets CI to the same value if the new CC value is less than the starting CI value. ST-Q/Si, ST-S, STM Sets or requests the current setting (“peak of sine”) of the stepper drive, also known as the running current. The range of the CC command may be limited from the ranges shown in the Parameters table below based on the settings defined in the ST Configurator software. Use ST Configurator to select a motor and set the maximum current setting. Note that setting CC automatically sets CI to 50% of CC. If a CI value different than 50% of CC is needed be sure to always set CI after setting CC. Command Details: Structure CC{Parameter #1} Type BUFFERED Usage READ/WRITE Non-Volatile YES Register Access “N” (030) Note: The CC command uses different units than the “N” register; see Data Registers section for details Parameter Details: BLu, SV, SVAC3 Parameter #1 Continuous current setting - units amps rms (resolution is 0.01 amps) - range BLuDC4: 0 - 4.5 BLuDC9: 0 - 9.0 BLuAC5: 0 - 5.0 SV: 0 - 7.0 SVAC3 (120V): 0 - 3.5 SVAC3 (220V): 0 - 1.8 STAC6, ST-Q/Si, ST-S, STM, STAC5 Parameter #1 Running current - units amps (resolution is 0.01 amps) - range* STAC6: 0 - 6.0 ST5 : 0 - 5.0 ST10: 0 - 10.0 STM: 0 - 5.0 STAC5 (120): 0 - 5 STAC5 (220): 0 - 2.55 53 920-0002 Rev. J 12/2014 Host Command Reference *Current setting in stepper drives depends on the selected motor. Use Configurator software to select a motor and set the maximum current setting. Examples: BLu, SV, SVAC3 Command Drive sends CC4.50 - CC CC=4.5 Notes Set continuous current to 4.5 amps rms STAC6 Command Drive sends Notes CC4.50 - Set running current to 4.5 amps CI2 - Set idle current to 2.0 amps CC1.8 - Set idle current to 1.8 amps CC CC=1.8 CI CI=1.8 CI automatically set to 1.8 amps along with CC1.8 command ST-Q/Si, ST-S, STM, STAC5 Command Drive sends CC3 - CI CI=1.5 CI1 - 920-0002 Rev. J 12/2014 Notes Set running current to 3.0 amps CI automatically set to 1.5 amps along with CC3 command Set idle current to 1.0 amps 54 Host Command Reference CD - Idle Current Delay Time Compatibility: Stepper drives only Affects: Motor current at rest See also: CC, CI commands Sets or requests the amount of time the drive will delay before transitioning from full current (CC) to idle current (CI). This transition is made after a step motor takes the final step of a move. Operating in any form of pulse & direction mode the drive will reset the idle current delay timer each time a step pulse is received by the drive. Command Details: Structure CD{Parameter #1} Type BUFFERED Usage READ/WRITE Non-Volatile YES Register Access None Parameter Details: Parameter #1 Delay time - units seconds - range 0.00 to 10.00 Examples: Command Drive sends CD0.4 - CD CD=0.4 Notes Idle current delay time set to 0.4 seconds 55 920-0002 Rev. J 12/2014 Host Command Reference CE - Communication Error Compatibility: All drives See also: AL command Requests the hexadecimal equivalent of the communication error’s 8-bit binary word. The presence of a comm error will also be shown in the Alarm Code (AL command) as well as the status LEDs at the front of the drive (Appendix F). Bit assignments for the 8-bit word are shown in the Response Details table below. Command Details: Command Type IMMEDIATE Usage READ ONLY Non-Volatile NO Register Access None Response Details: Response Communication error code - units hexadecimal code - range bit 0 = parity flag error bit 1 = framing error bit 2 = noise flag error bit 3 = overrun error bit 4 = Rx buffer full bit 5 = Tx buffer full bit 6 = bad SPI op-code bit 7 = Tx time-out Examples: Command CE CE 920-0002 Rev. J 12/2014 Drive sends CE=0010 CE=0002 Notes Rx buffer full Framing error 56 Host Command Reference CF - Anti-resonance Filter Frequency Compatibility: Stepper drives only Affects: Mid-range performance of step motors See also: CG command Sets or requests the anti-resonance filter frequency setting. This setting is in Hz and works in conjunction with the anti-resonance filter gain setting (CG) to cancel instabilities due to mid-band resonance. NOTE: We strongly suggest using the appropriate Configurator software application to set this value by entering as accurate a load inertia value as possible in the motor settings window. Command Details: Structure CF{Parameter #1} Type BUFFERED Usage READ/WRITE Non-Volatile YES Register Access None Parameter Details: Parameter #1 Filter frequency - units Hz - range 1 - 2000 Examples: Command Drive sends CF1400 - CF CF=1400 Notes Set anti-resonance filter frequency to 1400 Hz 57 920-0002 Rev. J 12/2014 Host Command Reference CG - Anti-resonance Filter Gain Compatibility: Stepper drives only Affects: Mid-range performance of step motors See also: CF command Sets or requests the anti-resonance filter gain setting. This setting is unit-less and works in conjunction with the anti-resonance filter frequency setting (CF) to cancel instabilities due to mid-band resonance. NOTE: We strongly suggest using the appropriate Configurator software application to set this value by entering as accurate a load inertia value as possible in the motor settings window. Command Structure: CG{Parameter #1} Command Details: Structure CG{Parameter #1} Type BUFFERED Usage READ/WRITE Non-Volatile YES Register Access None Parameter Details: Parameter #1 Filter gain - units integer number - range 0 - 32767 Examples: Command Drive sends CG800 - CG CG=800 920-0002 Rev. J 12/2014 Notes Set anti-resonance filter gain to 800 58 Host Command Reference CI - Change Idle Current Compatibility: Stepper drives only Affects: Motor current at standstill, holding torque See also: CC, PI, CD commands Idle current is the level of current supplied to each motor phase when the motor is not moving. Using an idle current level lower than the running motor current level (see CC command) aids in motor cooling. A common level used for the idle current setting is 50% of the running current. After a motor move, there is a time delay after the motor takes its last step before the reduction to the idle current level takes place. This delay is set by the CD command. STAC6 CI cannot be greater than CC. If you attempt to set CI higher than CC it will be automatically limited to the CC value. Furthermore, setting CC automatically sets CI to the same value if the new CC value is less than the starting CI value. ST-Q/Si, ST-S, STM CI cannot be greater than 90% of CC. If you attempt to set CI to a higher value than this CI is automatically limited to 90% of CC. Furthermore, setting CC automatically sets CI to 50% of the CC value. If a CI value different than 50% of CC is needed be sure to always set CI after setting CC. Command Details: Structure CI{Parameter #1} Type BUFFERED Usage READ/WRITE Non-Volatile Yes Register Access “O” (031) Note: The CI command uses different units than the “O” register; see Data Registers section for more details Parameter Details: STAC6 Parameter #1 Idle current - units amps - range 0 - 100% of running current ST-Q/Si, ST-S, STM, STAC5 Parameter #1 Idle current - units amps - range 0 - 90% of running current Examples: STAC6 Command Drive sends Notes CI1.0 - Set idle current to 1.0 amps CI CI=1 CC0.5 - Set running current to 0.5 amps CI CI=0.5 CI automatically set 0.5 amps along with CC0.5 command 59 920-0002 Rev. J 12/2014 Host Command Reference ST-Q/Si, ST-S, STM, STAC5 Command Drive sends CI2 - CC2 - CI CI=1 CI1.8 - 920-0002 Rev. J 12/2014 Notes Set idle current to 2 amps Set running current to 2 amps CI automatically set to 1 amp to match 50% of CC2 command Set idle current to 1.8 amps, or 90% of last CC value 60 Host Command Reference CJ - Commence Jogging Compatibility: All drives See also: JS, JA, JL, SJ, CS and DI commands. Starts the motor jogging. The motor accelerates up to the jog speed (JS) at a rate defined by the jog accel (JA) command, then runs continuously until stopped. To stop jogging, use the SJ (Stop Jogging) command for a controlled decel rate (decel rate set by JL command). For a faster stop, use the ST command (decel rate set by AM command), but beware that if the speed or load inertia is high, the drive may miss steps, stall, or fault. The jogging direction is set by the last DI command. Use the CS command to change jog speed and direction while already jogging. CS does not affect JS. Use in Q Programs (Q drives only) Within a stored Q program jog moves are most commonly initiated with the CJ command. However, because the SJ and ST commands are immediate type they cannot be used within a Q program to stop the jog move. So the procedure to stop a jog move within a Q program involves both the MT (Multi-tasking) and SM (Stop Move) commands. See Examples below for a sample command sequence. Command Details: Structure CJ Type BUFFERED Usage WRITE ONLY Non-Volatile NO Register Access None Examples: Command JA10 JL25 JS1 CJ CS10 SJ Drive sends - - - - - - Notes Set jog accel to 10 rps/s Set jog decel to 25 rps/s Set jog speed to 1 rps Start jogging with speed set by last JS command Change jog speed to 10 rps Stop jogging using decel rate set by last JL command The following example changes the jog speed during program execution by directly loading a value into the “J” register. This method allows for dynamically calculated jog speeds, and does not affect the original JS or DI setting. CJ always starts a jog move using JS and DI, so this is the recommended method of changing speed dynamically during program execution. Sample Q program sequence MT1 Turn Multi-tasking ON FI58 Filter input X5 for 8 processor ticks (2 msec) WIX5L Wait for input X5 low CJ Commence jogging RLJ480 Change speed to 2 rev/sec by directly loading the J register. Note, units are 0.25rpm. WIX5H Wait for input X5 high SMD Stop Move using the decel ramp set by JL 61 920-0002 Rev. J 12/2014 Host Command Reference CM - Command Mode (AKA Control Mode) Compatibility: All drives Affects: Drive mode of operation See also: PM command Sets or requests the Command Mode that the drive operates in. For more automated setup of command modes use the appropriate Configurator or Quick Tuner software application. The most common command mode is Point-to-Point (21), in which all move commands can be executed. Move commands (like FL, FP, FS, and CJ) can still be executed when the command mode is set to Step & Direction (7), because the drive will temporarily switch to command mode 21 to execute the move, then revert back to command mode 7 when the move is finished. However move commands are either ignored or do not function properly when the command mode is set to any velocity mode (11-18) or the Analog Position mode (22). WARNING: Changing the Command Mode without proper care may cause the motor to spin at a high rate of speed or give other unexpected results. For this reason it is suggested that the appropriate Configurator or Quick Tuner software application be used to test specific Command Modes first before changing them in the application using the CM command. Command Details: Structure CM{Parameter #1} Type BUFFERED Usage READ/WRITE Non-Volatile YES Register Access “m” (061) Note: Because a drive can change Command Mode on it’s own to complete certain moves, the CM command and the “m” register may not always match. Parameter Details: Parameter #1 Command mode - units integer code - range 1 - Commanded Torque (servo and step-servo) 2 - Analog Torque (servo and step-servo) 3 - Analog Torque in CW Direction when DIR input is closed (servo and step-servo) 4 - Analog Torque in CW Direction when DIR input is open (servo and step-servo) 7 - Step & Direction 10 - Commanded Velocity (jog mode) 11 - Analog velocity 12 to 18 - (see below) 21 - Point-to-Point 22 - Analog Position NOTE: In Command Modes 11, 12, 13 and 14, input X2 will function to reverse the direction of motion. 920-0002 Rev. J 12/2014 62 Host Command Reference Command Modes 12 to 18 are for stepper drives and SV servo drives only: 12 - Analog velocity mode with input X1 as run/stop input 13 - Analog velocity mode with input X5 (X4 for STAC5 drives) as speed change input 14 - Analog velocity mode with input X1 as run/stop input and input X5 (X4 for STAC5 drives) as speed change input 15 - Velocity mode (JS for speed) 16 - Velocity mode (JS for speed) with input X1 as run/stop input 17 - Velocity mode (JS for speed) with input X5 (X4 for STAC5 drives) as speed change input 18 - Velocity mode (JS for speed) with input X1 as run/stop input and input X5 (X4 for STAC5 drives) as speed change input NOTE: It is recommended to use Configurator or Quick Tuner software for setting up velocity mode operation. Examples: Command Drive sends CM2 - the Notes Sets the servo drive to Analog Torque mode, at which time there is a linear relationship between the voltage at the drive’s analog input and CM7 - digital Sets the drive to Step & Direction input mode, which is used for all CM10 - and Sets the drive to Command Velocity, or jog mode, which in practice is very similar to Point-to-Point mode (CM21). When in CM21 and a jog command is issued, like CJ, the drive automatically switches to CM10 during the jog move and then back to CM21 when the jog move is stopped. Conversely, when in CM10 and a feed move is commanded, like FL, the drive automatically switches to CM21 during the move and then back to CM10 when the move is finished. CM10 is most useful with servo drives, and when the JM (Jog Mode) is set to 2. This puts the drive into a jog mode in which position error is ignored. Then, when the motor is at rest the drive acts somewhat like a constant friction device in that a certain amount of torque (set by CC CM11 - similar Sets the drive to Analog Velocity mode. In servo drives this will be CM22 - Sets the drive to Analog Positioning mode. In this mode it is also possible to control the position through the use of an external encoder. motor current. positioning schemes like Step (Pulse) & Direction, CW/CCW Pulse, and A/B Quadrature. Use the appropriate Configurator or Quick Tuner application to set the proper scheme within this mode. CP commands) is required to move the shaft. to the Analog Torque mode, where voltage level at the analog input relates to motor speed. In stepper drives this puts the drive into continuous oscillator mode, with speed set by the JS command. 63 920-0002 Rev. J 12/2014 Host Command Reference CN - Secondary Control Mode Compatibility: Affects: See Also: M2 drives All control mode CM, MS commands The second control Mode that the drive operates in. Refer to CM 1 - Commanded Torque 2 - Analog Torque 3 - Analog Torque with Input X2 as direction input 4 - Analog Torque with Input X2 as direction input 5 - Analog Torque with Input X1 as start/stop input 6 - Analog Torque with Input X1&X2 as start/stop & direction input 7 - Step & Direction 8 - Analog Torque with Input X1&X2 as start/stop & direction input 10 - Commanded Velocity (jog mode) 11 - Analog velocity 12 - Analog velocity mode with input X1 as run/stop input 13 - Analog velocity mode with input X10 X11 X12 as speed change input 14 - Analog velocity mode with input X1 as run/stop input and input X10~X12 as speed change input 15 - Velocity mode (JS for speed) 16 - Velocity mode (JS for speed) with input X1 as run/stop input 17 - Velocity mode (JS for speed) with input X10~X12 as speed change input 18 - Velocity mode (JS for speed) with input X1 as run/stop input and input X10~X12 as speed change input 21 - Point-to-Point 22 - Analog Position Command Details: Structure CN{Parameter #1} Type BUFFERED Usage READ/WRITE Non-Volatile Yes Register Access None Parameter Details: Parameter #1 The second control mode - units Integer - range 1~22 Default value 7 Examples: Command CN7 CN 920-0002 Rev. J 12/2014 Drive sends % CN=7 Notes Set the second control mode to Step & Direction The second control mode is Step & Direction 64 Host Command Reference CO - Node ID/ IP address Compatibility: M2 drives Affects: CANopen drives & Ethernet drives See Also: None Sets or requests the CANOpen Node ID of CANOpen type drives or the Ethernet IP address of Ethernet type drives. For the Ethernet type drives, CO command set the Ethernet IP address which can be defined by users. The default IP address of Ethernet type drives: 0 – 10.10.10.10 1 – 192.168.1.10 2 – 192.168.1.20 3 – 192.168.1.30 4 – 192.168.0.40 5 – 192.168.0.50 6 – 192.168.0.60 7 – 192.168.0.70 8 – 192.168.0.80 9 – 192.168.0.90 10 –192.168.0.100 11 –192.168.0.110 12 –192.168.0.120 13 –192.168.0.130 14 –192.168.0.140 15 –0.0.0.0(DHCP) Command Details: Structure CO{Parameter #1} Type BUFFERED Usage READ/WRITE Non-Volatile Yes Register Access None Parameter Details: STAC6 Parameter #1 Node ID of CANOpen type drives or the Ethernet IP address of Ethernet type drives - units Integer - range For CANOpen type drives 1~127 For Ethernet type drives 0~15 Default value For CANOpen type drives 1 For Ethernet type drives 0 Examples: 65 920-0002 Rev. J 12/2014 Host Command Reference Command CO1 Drive sends % CO CO=1 920-0002 Rev. J 12/2014 Notes Set the node ID to 1 of CANOpen drives or set the Ethernet IP address to 192.168.1.10(default IP Address list) The node ID of CANOpen drives is 1 or set the Ethernet IP address of Ethernet drive is 192.168.1.10 (default IP Address list) 66 Host Command Reference CP - Change Peak Current Compatibility: Servo drives only Affects: Motor current, especially during acceleration and deceleration See also: CC, PC, PP commands Sets or requests the peak (RMS) current setting of the servo drive. Peak current sets the maximum current that should be used with a given motor. When the motor position requires more than the continuous value, the peak current time calculation is done using I2/T which integrates current values for more accurate modeling of drive and motor heating. The servo drive will allow peak current for nor more than one second. After one second of operation at peak current the current is reduced to the continuous current setting (see CC command). Command Details: Structure CP{Parameter #1} Type BUFFERED Usage READ/WRITE Non-Volatile YES Register Access “O” (031) Note: The CP command uses different units than the “O” register; see Data Registers section for more details Parameter Details: Parameter #1 Peak current limit - units amps RMS - range BLuDC4: 0 - 13.5 A BLuDC9: 0 - 18.0 A BLuAC5: 0 - 15.0 A SV7: 0 - 14.0 A SVAC3 (120V): 0 - 7.5 SVAC3 (220V): 0 - 3.75 Examples: Command Drive sends CP9.0 - CP CP=9.0 Notes Peak current is set to 9.0 amps RMS 67 920-0002 Rev. J 12/2014 Host Command Reference CR - Compare Registers Compatibility: Q drives only Affects: Contents of condition code register “h” See also: RI, RD, RM, RL, QJ commands Compare the contents of two data registers. The first data register (Parameter #1) is tested by comparing it against the data value in the second data register (Parameter #2). The result is a condition code that can be used for program conditional processing (see QJ command). For Example, if the first data register is greater than the second the “greater than” flag is set and the QJGx command can be used to create a conditional jump. Command Details: Structure CR(Parameter #1)(Parameter #2) Type BUFFERED Usage WRITE ONLY Non-Volatile NO Register Access All data registers Parameter Details: Parameter #1 First data register assignment - units character - range All data register assignments Parameter #2 Second data register assignment - units character - range All data register assignments Examples: Command Drive sends CRE1 - QJG5 - 920-0002 Rev. J 12/2014 Notes Compare data register “E” to data register “1” If “E” register is greater than “1” register jump to line 5 of Q segment, otherwise proceed to next line. 68 Host Command Reference CS - Change Speed Compatibility: All drives Affects: Jog speed while jogging See also: CJ, JS, JA, JL commands Sets or requests the jogging speed in rev/sec while jogging. When Jogging using the CJ command the Jog speed can be changed dynamically by using this command. The sign of CS can be positive or negative allowing the direction of jogging to be changed dynamically also. Ramping between speeds is controlled by the JA and JL commands. Setting CS does not change JS or DI. Command Details: Structure CS{Parameter #1} Type IMMEDIATE Usage READ/WRITE Non-Volatile YES Register Access “J” (026) Note: The CS command uses different units than the “J” register; see Data Registers section for more details. Parameter Details: Parameter #1 Jog Speed - units rev/sec - range BLu, SV, STAC6, ST-Q/Si, ST-S, STAC5, SVAC3: -133.3333 to 133.3333 (resolution is 0.0042) STM: -80.0000 to 80.0000 (resolution is 0.0042) sign determines direction: “-“ for CCW, no sign for CW Examples: Command JS1 CJ CS2.5 CS CS-5 SJ Drive sends - - - CS=2.5 - - Notes Set base jog speed to 1 rev/sec Commence jogging Set jog speed to CW at 2.5 rev/sec Displays current Jog speed Set jog speed to CCW at 5 rev/sec Stop jogging 69 920-0002 Rev. J 12/2014 Host Command Reference CT - Continue Compatibility: All drives See also: PS, ST, SK commands Resume execution of buffered commands after a PS command has been sent. The PS (Pause) command allows you to pause execution of commands in the command buffer. After sending the PS command, subsequent commands are buffered in the command buffer until either a CT command is sent, at which time the buffered commands resume execution in the order they were received, or until the command buffer is full. Command Details: Structure CT Type IMMEDIATE Usage WRITE ONLY Non-Volatile NO Register Access None Examples: Command PS FL2000 WT.25 FL-2000 CT 920-0002 Rev. J 12/2014 Drive sends - - - - - Notes Pause command buffer CW move, 2000 counts Wait 0.25 seconds CCW move, 2000 counts Resume execution of buffered commands 70 Host Command Reference DA - Define Address Compatibility: All drives Affects: Drive address for multi-drop communications Sets individual drive address character for multi-drop RS-485 communications. This command is not required for single-axis (point-to-point) or RS-232 communications. Command Details: Structure DA{Parameter #1} Type BUFFERED Usage READ/WRITE Non-Volatile YES Register Access None Parameter Details: Parameter #1 RS-485 network address - units character - range Valid address characters are: !“#$%&‘()*+,-./0123456789:;?@ Examples: Command Drive sends DA1 - DA DA=1 Notes Set drive address to “1” 71 920-0002 Rev. J 12/2014 Host Command Reference DC - Change Distance Compatibility: All drives Affects: FC, FY, FO, FM commands. Sets or requests the change distance. The change distance is used by various move commands to define more than one distance parameter. All move commands use the DI command at some level, and many require DC as well. Examples are FC, FM, FO, and FY. The moves executed by these commands change their behavior after the change distance (DC) has been traveled. For example, FM is similar to FS, but in an FM move the sensor input is ignored until the motor has moved the number of steps set by DC. This is useful for masking unwanted switch or sensor triggers. Since DI sets move direction (CW or CCW), the sign of DC is ignored. Command Details: Structure DC{Parameter #1} Type BUFFERED Usage READ/WRITE Non-Volatile YES Register Access “C” (019) Parameter Details: Parameter #1 distance - units encoder counts - range 0 to 2,147,483,647 (the sign of negative values is ignored) Examples: Command Drive sends DC80000 - DC DC=80000 Notes Set change distance to 80000 counts DI-100000 DC50000 VE5 VC2 FC Set overall move distance to 100000 counts in CCW direction Set change distance to 50000 counts Set base move velocity to 5 rev/sec Set change velocity to 2 rev/sec Initiate FC command 920-0002 Rev. J 12/2014 - - - - - 72 Host Command Reference DD - Default Display Item of LEDs Compatibility: M2 drives Affects: LEDs display See Also: None Sets or requests the default monitor item of the driver’s LEDs display after power up. The item is defined as belows: 0 Velocity 1 Position Error 2 StepPosition 3 Encoder Position 4 Position Command 5 Temperature 6 DC_Bus_Voltage 7 Address 8 Alarm History 0 9 Alarm History 1 10 Alarm History 2 11 Alarm History 3 12 Alarm History 4 13 Alarm History 5 14 Alarm History 6 15 Alarm History 7 Command Details: Structure DD{Parameter #1} Type IMMEDIATE Usage READ/WRITE Non-Volatile Yes Register Access None Parameter Details: Parameter #1 Default display item of LEDs - units Integer - range 0~15 Default value 0 Examples: Command DD0 DD Drive sends % DD=0 Notes Set the default display item to immediate velocity The default display item is immediate velocity 73 920-0002 Rev. J 12/2014 Host Command Reference DE - Deceleration Compatibility: All drives Affects: FC, FD, FE, FL, FM, FO, FS, FP, FY, SH commands See also: AM, DE, DI, DC, VE commands Sets or requests the deceleration rate used in point-to-point move commands in rev/sec/sec. Command Details: Structure DE{Parameter #1} Type BUFFERED Usage READ/WRITE Non-Volatile YES Register Access “B” (018) Note: The DE command uses different units than the “B” register; see Data Registers section for details Parameter Details: Parameter #1 Deceleration rate - units rev/sec/sec (rps/s) - range 0.167 to 5461.167 (resolution is 0.167 rps/s) Examples: Command Drive sends DE125 - DE DE=125 920-0002 Rev. J 12/2014 Notes Set deceleration rate to 125 rev/sec/sec 74 Host Command Reference DI - Distance/Position Compatibility: All drives Affects: All move commands See also: AC, DC, DE and VE commands Sets or requests the move distance in encoder counts (servo) or steps (stepper). The sign of DI indicates move direction: no sign means CW and “-” means CCW. DI sets both the distance for relative moves, like FL, and the position for absolute moves, like FP. DI also sets the direction of rotation for jogging (CJ). Command Details: Structure DI{Parameter #1} Type BUFFERED Usage READ/WRITE Non-Volatile YES Register Access “D” (020) Parameter Details: Parameter #1 distance - units encoder counts (servo) or steps (stepper) - range -2,147,483,647 to 2,147,483,647 sign determines direction: “-” for CCW, no sign for CW Examples: Command Drive sends DI20000 - DI DI=20000 Notes Set distance to 20000 counts in the CW direction DI-8000 FL Set distance to 8000 counts in the CCW direction Initiate FL move - - 75 920-0002 Rev. J 12/2014 Host Command Reference DL - Define Limits Compatibility: All drives Affects: All move commands See also: AM command CW and CCW end-of-travel limits are available on all drives and can be used to define the boundaries of acceptable motion in a motor/drive system. If one of these inputs is activated while defined as an end-of-travel limit, motor rotation will stop in that direction, and an alarm code will show at the drive’s status LEDs. When defining these inputs as end-of-travel limits both inputs are defined together as either active low, active high, or not used. See below for details. BLu-S/Q, STAC6 Defines usage of inputs X6 and X7 as dedicated end-of-travel limits. X6 is the CCW limit input and X7 is the CW limit input. If not needed, X6 and X7 can be redefined as general purpose inputs. STAC5-S, SVAC3-S Defines usage of inputs X1 and X2 as dedicated end-of-travel limits. X1 is the CW limit input and X2 is the CCW limit input. If not needed, X1 and X2 can be redefined as general purpose inputs. STAC5-Q/IP, SVAC3-Q/IP Defines usage of inputs IN7 and IN8 as dedicated end-of-travel limits. IN7 is the CW limit input and IN8 is the CCW limit input. If not needed, IN7 and IN8 can be redefined as general purpose inputs. Blu-Si Defines usage of top-board inputs IN7 and IN8 as dedicated end-of-travel limits. IN7 is the CW limit input and IN8 is the CCW limit input. ST-Q/Si, SV Defines the usage of inputs X7 and X8 as dedicated end-of-travel limits. X7 is the CW limit input and X8 is the CCW limit input. If not needed, X7 and X8 can be redefined as general purpose inputs. ST-S, STM-17/23 Defines the STEP and DIR inputs as CW end-of-travel and CCW end-of-travel limit inputs, respectively. The STEP and DIR inputs can each be assigned to only one function in an application. If you want to use the STEP and DIR inputs as end-of-travel limit inputs you can define them as such in two ways, with the ST Configurator software, or with the DL command. DL takes no effect if the drive is set in Command Mode (CM) 7, 11, 12, 13, 14, 15, 16, 17 or 18, because these modes predefine these inputs and take precedence over the DL command. Also, setting the JE command after setting the DL command reassigns the STEP and DIR inputs as jog inputs and turns off any limit input usage (DL3). In other words, the DL and JE commands, as well as Command Modes (CM) 7, 11, 12, 13, 14, 15, 16, 17 and 18 each assign a usage to the STEP and DIR inputs. Each of these must exclusively use the STEP and DIR inputs. Command Modes are most dominant and will continually prevent DL and JE from using the inputs. DL and JE exclude each other by overwriting the usage of the STEP and DIR inputs. STM24-C Defines the usage of inputs IN1 and IN2 as dedicated end-of-travel limits. IN1 is the CW limit input and IN2 is the CCW limit input. If not needed, IN1 and IN2 can be redefined as general purpose inputs. STM24-SF/QF Drives with Flex I/O allow a user to configure a drives I/O (I/O1 through I/O4) to be either an input or an output by using the SD command. For the DL command, the drive uses inputs I/O3 and I/O4 as dedicated end-of-travel limits. I/O3 is the CW limit input and I/O4 is the CCW limit input. If not needed, I/O3 and I/O4 can be redefined as general purpose inputs. 920-0002 Rev. J 12/2014 76 Host Command Reference There are three end-of-travel limit input states that can be defined with the DL command: DL1: End-of-travel limit occurs when an input is closed (energized). Motion stops automatically at rate defined by AM command. DL2: End-of-travel limit occurs when an input is open (de-energized). Motion stops automatically at rated defined by AM command. DL3: Inputs are not used as end-of-travel limit inputs and can be used as a general purpose inputs. In the case of ST-S and STM drives, DL will be automatically set to 3 if CM is set to 7, 11, 12, 13, 14, 15, 16, 17, or 18, or if JE is executed after the DL command is set. Command Details: Structure DL{Parameter #1} Type BUFFERED Usage READ/WRITE Non-Volatile YES Register Access None Parameter Details: Parameter #1 Limit input state (see above) - units integer number - range 1, 2 or 3 Examples: Command Drive sends DL1 - DL DL=1 Notes Set limit inputs to work with normally open limit switches DL3 Set limit inputs to act as general purpose inputs - NOTE: When working with digital inputs and outputs it is important to remember the designations low and high. If current is flowing into or out of an input or output, i.e. the circuit is energized, the logic state for that input/output is defined as low or closed. If no current is flowing, i.e. the circuit is de-energized, or the input/output is not connected, the logic state is high or open. A low state is represented by the “L” character in parameters of commands that affect inputs/outputs. For example, WI3L means “wait for input 3 low”, and SO1L means “set output 1 low”. A high state is represented by the “H” character. 77 920-0002 Rev. J 12/2014 Host Command Reference DL - Define Limits (Step-Servo and M2 drives) Compatibility: SSM, TSM, TXM, SS, SSAC and M2 drives Affects: All move commands See also: AM command CW and CCW end-of-travel limits are available on all drives and can be used to define the boundaries of acceptable motion in a motor/drive system. If one of these inputs is activated while defined as an end-of-travel limit, motor rotation will stop in that direction, and an alarm code will show at the drive’s status LEDs. When defining these inputs as end-of-travel limits, individual or both inputs can be defined as either active low, active high, or not used. See below for details. DL1: End-of-travel limit occurs when an input is closed (energized). Motion stops automatically at rate defined by AM command. DL2: End-of-travel limit occurs when an input is open (de-energized). Motion stops automatically at rated defined by AM command. DL3: Inputs are not used as end-of-travel limit inputs and can be used as a general purpose inputs. In the case of ST-S and STM drives, DL will be automatically set to 3 if CM is set to 7, 11, 12, 13, 14, 15, 16, 17, or 18, or if JE is executed after the DL command is set. DL7: individually set end-of-travel in CW direction when CW Limit inputs is closed(energized). DL8: individually set end-of-travel in CW direction when CW Limit inputs is open (de-energized). DL9: individually set end-of-travel in CCW direction when CCW Limit inputs is closed(energized). DL10: individually set end-of-travel in CCW direction when CCW Limit inputs is open (de-energized). DL11~13, DL17~20: Swap the CW input and CCW input definition as above setting. Command Details: Structure DL{Parameter #1} Type BUFFERED Usage READ/WRITE Non-Volatile YES Register Access None Parameter Details: Parameter #1 Limit input state (see above) - units integer number - range 1 ~ 20 Examples: Command Drive sends DL1 - DL DL=1 Notes Set limit inputs to work with normally open limit switches DL3 Set limit inputs to act as general purpose inputs - NOTE: When working with digital inputs and outputs it is important to remember the designations low and high. If current is flowing into or out of an input or output, i.e. the circuit is energized, the logic state for that input/output is defined as low or closed. If no current is flowing, i.e. the circuit is de-energized, or the input/output is not connected, the logic state is high or open. A low state is represented by the “L” character in parameters of commands that affect inputs/outputs. For example, WI3L means “wait for input 3 low”, and SO1L means “set output 1 low”. A high state is represented by the “H” character. 920-0002 Rev. J 12/2014 78 Host Command Reference DP - Dumping Power Compatibility: SS drives Affects: DC power supply See Also: None Sets or requests the dumping power of SS drives. 0 – Do not use the inner dumping function. 1 ~ 5: Larger value means more powerful dumping function. Command Details: Structure DP{Parameter #1} Type BUFFERED Usage READ/WRITE Non-Volatile YES Register Access None Parameter Details: Parameter #1 Dumping power - units Integer - range 0~5 Default value 3 Examples: Command DP3 DP Drive sends % DP=3 Notes Set the dumping power of SS drive to level 3. The dumping power of SS is set to level 3 79 920-0002 Rev. J 12/2014 Host Command Reference DR - Data Register for Capture Compatibility: Q servo drives only (BLu-Q and SV-Q) Affects: Quick Tuner Data Capture Sets or requests the data register used in the register plot data source in Quick Tuner. Any data register can be selected for viewing when capturing data using Quick Tuner. Command Details: Command Type BUFFERED Usage WRITE ONLY Non-Volatile NO Register Access All data registers Parameter Details: Parameter #1 Data register assignment - units character - range All data register assignments Examples: Command DRa 920-0002 Rev. J 12/2014 Drive sends - Notes Set capture data register to “a” (Analog Command) register 80 Host Command Reference DS - Switching Electronic Gearing Compatibility: M2 drives Affects: control mode 7, electronic gearing, input #9 See also: EG, PV, EU, EN Defines the usage of input X9 as electronic gearing selecting. DS1: EG is selected when input X9 is open, and PV is selected when input X9 is closed. DS2: EG is selected when input X9 is closed, and PV is selected when input X9 is open. DS3: Input X9 is used as general purpose input. And EG is selected. Command Details: Structure DS{Parameter #1} Type BUFFERED Usage READ/WRITE Non-Volatile YES Register Access None Parameter Details: Parameter #1 (see above) - units integer number - range 1~3 Default value 3 Examples: Command DS1 DS Drive sends % DS=1 Notes set the usage of electronic gearing selecting to 1 he usage of input X9 as electronic gearing selecting is 1 81 920-0002 Rev. J 12/2014 Host Command Reference ED - Encoder Direction Compatibility: BLu, STAC5, STAC6, SV7, SVAC3 Affects: Encoder count direction See also: EF, EI commands BLu, STAC5, STAC6, SV7, SVAC3 Sets or requests the encoder count direction. Command Details: Structure ED {Parameter #1} Type BUFFERED Usage READ/WRITE Non-Volatile YES Register Access none Parameter Details: Parameter #1 Encoder Count Direction - units Binary flag (0 or 1) - range 0 = default behavior 1 = count in reverse Examples: Command Drive sends ED1 - ED ED=1 920-0002 Rev. J 12/2014 Notes Set encoder to count in reverse 82 Host Command Reference EF - Encoder Function Compatibility: Stepper drives with encoder feedback Affects: Stall Detection and Stall Prevention See also: CC, CI, ER, PF commands NOTE: The behavior of this function was updated subsequent to firmware rev 1.04L (STM17, 23). Most notably, a power-cycle was requried to initialize the drive with a new EF setting. Drives with more recent firmware perform a current probe and encoder alignment immediately following execution of the EF command, and do not require the drive to be reset. All descriptions shown here assume that the drive is running current firmware. ST-Q/Si, STM Sets or requests the decimal equivalent of the encoder function’s 3-bit word. The encoder function can be set through Configurator or by using the EF command. Only stepper drives with encoder inputs (optional on ST-Q/ Si, STAC5 and STM drives) running a step motor with a shaft-mounted encoder can utilize the Stall Detection and Stall Prevention functions. Note, this feature is NOT available on the STAC6. MOONS’ recommends an encoder with differential outputs and a resolution of at least 1000 lines (4000 counts/ rev). EF0: Disable Encoder Functionality EF1: Turn Stall Detection ON. EF2: Turn Stall Prevention ON. EF6: Turn Stall Prevention with time-out ON. The drive performs a full current probe for encoder alignment during power-up and after each EF command is sent. It is very important to raise the idle and continuous current settings to the maximum value and then execute the new EF setting after a 1 second delay. Once the EF command is completed, the current may be reset to its normal value. Command Details: Structure EF{Parameter #1} Type BUFFERED Usage READ/WRITE Non-Volatile YES Register Access None Parameter Details: Parameter #1 Encoder function setting - units decimal equivalent of 3-bit binary word - range 0 = Encoder function off 1 = Stall Detection 2 = Stall Prevention 6 = Stall Prevention with time-out 83 920-0002 Rev. J 12/2014 Host Command Reference Examples: Command Drive sends EF1 - EF EF=1 Notes Turn ON Stall Detection function EF6 - Enable Stall Prevention with time-out EF EF=6 Example encoder alignment sequence (STM24): CC6 CI5.4 EF1 CC3 CI2.4 Raise current to 6A Raise idle current to 5.4A* Enable Stall Detection feature Lower current to normal running level (application dependent) Lower idle current to normal running level (application dependent) If this is done through a Q program, add a short delay after raising current levels: CC6 CI5.4 WT1 EF1 CC3 CI2.4 Raise current to 6A Raise idle current to 5.4A* Short delay Enable Stall Detection feature Lower current to normal running level (application dependent) Lower idle current to normal running level (application dependent) * 90% of CC; see CI command for details 920-0002 Rev. J 12/2014 84 Host Command Reference EG - Electronic Gearing Compatibility: All drives Affects: Command Mode 7, FE and HW commands See also: CM, ER, FE and HW commands. BLu, SV Sets or requests the pulses per revolution for electronic gearing. For example, with an EG value of 20000 the servo drive will require 20000 pulses from the master pulse source to move the servo motor 1 revolution. STAC6, ST-Q/Si, ST-S, STM Sets or requests the desired step/microstep resolution of the step motor. Command Details: Structure EG{Parameter #1} Type BUFFERED Usage READ/WRITE Non-Volatile YES Register Access “R” (034) Note: With servo drives the EG command is equal to the “R” register. With stepper drives the EG command is equal to twice the “R” register. Parameter #1 Servo = electronic gearing ratio Stepper = step resolution - units Servo = counts/rev Stepper = steps/rev - range Servo = 200 - 32000 Stepper = 200 - 51200 Examples: Command Drive sends EG20000 - EG EG=20000 RLR RLR=20000 Notes Set electronic gearing resolution in servo drive to 20000 pulses/rev EG36000 - EG EG=36000 RLR RLR=18000 steps/rev Set microstep resolution to 36000 steps/rev in a stepper drive “R” register matches the EG setting in a servo drive “R” register contains 1/2 the EG setting in a stepper drive, or 18000 85 920-0002 Rev. J 12/2014 Host Command Reference EH - Extended Homing Compatibility: SSM, TSM, TXM, SS, SSAC and M2 drives Affects: DL, HA, HL, HV, HO commands Executes an Extended Homing command. Requires input number and condition for the home sensor. Speed is set by HV command, there are three velocity setting for different steps (see the detail as following description). Acceleration and deceleration are set by HA(Homing Accel) and HL(Homing Decel). The start direction comes from the sign of the HO command (“-” is CCW, no sign is CW). Here following the description for each commands and motor motion. HV1: Homing velocity for searching Limit Sensor and Home sensor. HV2: Homing velocity for moving the setting distance after(beyond) home sensor reached. HV3: Homing velocity for return back to home sensor after setting distance moving finished. HO: distance to move after home sensor reached. Here shows an example of Extended Homing operation as following. Condition: HO = 20000(no sign for CW direction) , DL = 2 Position A CW Limit Sensor B C D Home Sensor CCW Limit Sensor (1) When the motor is positioned at A (CW Limit Sensor triggered) -The motor searches the home sensor at high speed specified by HV1 value, with HA1/HL1 for acceleration/ deceleration. Once home sensor is reached, it will move to the distance specified by HO value with HV2 speed and HA2/HL2 acceleration/deceleration beyond home sensor in CCW direction. Finally, the motor approaches back with HV3 speed and HA3/HL3 acceleration/deceleration to home sensor. (2) When the motor is positioned at B (Motor Stop between CW Limit Sensor and Home Sensor) -The motor moves by CW direction to find CW limit sensor with HV1 speed and HA1/HL1 acceleration/ deceleration. -The CW limit sensor triggered and stopped. -Then the motor moves the same as above (1). (3) When the motor is positioned at C (Home Sensor triggered) -The motor moves to the distance specified by HO value with HV2 speed and HA2/HL2 acceleration/ deceleration beyond home sensor in CCW direction. Finally, the motor approaches back with HV3 speed and HA3/HL3 acceleration/deceleration to home sensor. (4) When the motor is positioned at D (Motor Stop between Home Sensor and CCW Limit Sensor) -The motor moves to home sensor with speed HV1 in CW direction. -After Home Sensor triggered, The motor moves the same as above (3) NOTE: If the HO value is negative, the motor will start at CCW direction. NOTE: This command is designed for use with three physical sensors or switches tied to three separate digital inputs of the drive: a home sensor, a CW end-of-travel limit, and a CCW end-of-travel limit. 920-0002 Rev. J 12/2014 86 Host Command Reference Command Details: Structure EH{Parameter #1} Type BUFFERED Usage WRITE ONLY Non-Volatile No Register Access None Parameter Details: Parameter #1 Input number, Input condition - units Integer, letter - range Integer: 0 = Encoder Index (if present), 1 = STEP, 2 = DIR, 3 = EN, 4 = AIN letter: L = low, H = high, F = falling edge, R = rising edge Examples: Command EH3L Drive sends % Notes Homing to home sensor as above description 87 920-0002 Rev. J 12/2014 Host Command Reference EI - Input Noise Filter Compatibility: ST, STM, SV7, SVAC3, STAC5 and STAC6 Affects: “Input Noise Filter” parameter See also: CM, ER, FE and HW commands. Sets or requests the Input Noise Filter parameter. This parameter acts as a low-pass filter, rejecting noise above the specified frequency. NOTE: On STAC5-S and SVAC3-S drives, this parameter setting affects inputs X1 - X4, and is an alternative to the FI command if input noise filtering is required. STM17 Given a cutoff frequency, an appropriate EI value may be calculated as follows (where ‘f’ is the target cutoff frequency): EI = 9,000,000 / f ST, STM23 / 24, SV7, SVAC3, STAC5, STAC6 Given a cutoff frequency, an appropriate EI value may be calculated as follows (where ‘f’ is the target cutoff frequency): EI = 15,000,000 / f Command Details: Structure EI {Parameter #1} Type BUFFERED Usage READ/WRITE Non-Volatile YES Register Access none Parameter Details: Parameter #1 Encoder Noise Filter Constant - units - range 0 - 255 Examples: Command Drive sends EI128 - EI128 - EI EI=128 920-0002 Rev. J 12/2014 Notes (STM17) Set encoder noise filter to 70.3 kHz (9,000,000 / 128) (STM23) Set encoder noise filter to 117.2 kHz (15,000,000 / 128) 88 Host Command Reference EN - Numerator of Electronic Gearing Ratio Compatibility: M2 drives Affects: control mode 7, electronic gearing See also: EG, PV, EU DS Defines the numerator of electronic gearing ratio. 0 – do not use the electronic gearing ratio. Command Details: Structure EN{Parameter #1} Type BUFFERED Usage READ/WRITE Non-Volatile YES Register Access None Parameter Details: Parameter #1 numerator of electronic gearing - units integer number - range 0 - 1000 Default value 1000 Examples: Command EN1000 EN Drive sends % EN=1000 Notes Set the numerator of electronic gearing ratio to 1000 the numerator of electronic gearing ratio is 1000 89 920-0002 Rev. J 12/2014 Host Command Reference EP - Encoder Position Compatibility: Servo, Step-Servo drives and stepper drives with encoder feedback Affects: Encoder position value See also: SP, MT, WM commands. The EP command allows the host to define the present encoder position. For example, if the encoder is at 4500 counts, and you would like to refer to this position as 0, send EP0. To ensure that the internal position counter resets properly, use SP immediately following EP. For example, to set the position to zero after a homing routine, send EP0 then SP0. Sending EP with no position parameter requests the present encoder position from the drive. For best results when using stepper systems, MOONS’ recommends setting both CC and CI to the motor’s maximum ratings before issuing an EP command. This will avoid any position error caused by the motor’s detent torque. Once EP has been changed, reset CC and CI to their running levels. WARNING: When in Multi-tasking mode (see MT command), the EP command should not be issued while the drive is simultaneously executing a move command (CJ, FL, FP, FS, etc.). A drive fault may result. Command Details: Structure EP{Parameter #1} Type BUFFERED Usage READ/WRITE Non-Volatile NO Register Access “e” (053) read only Parameter Details: Parameter #1 Encoder position value - units Counts - range -2,147,483,647 to 2,147,483,647 Examples: Command Drive sends Notes EP0 SP0 - - (Step 1) reset internal position counter (Step 2) reset internal position counter 920-0002 Rev. J 12/2014 90 Host Command Reference ER - Encoder Resolution Compatibility: Servo , Step-Servo drives and stepper drives with encoder feedback Affects: Motor Operation Sets or requests the encoder resolution in quadrature counts. For example, if the motor connected to the drive has an 8000 count (2000 line) per revolution encoder, set the encoder resolution to 8000. For Step-Servo drives, this command is read-only. WARNING: Changing this setting will affect motor commutation with servo drives. Use the Quick Tuner setup utility to change this setting, then run the ¡°Timing Wizard¡± in Quick Tuner to properly set up the motor commutation. Command Details: Structure ER{Parameter #1} Type BUFFERED Usage READ/WRITE(READ ONLY for Step-Servo Drives) Non-Volatile YES Register Access None Parameter Details: Parameter #1 Encoder resolution - units encoder counts/rev - range 200 - 128000 Examples: Command Drive sends ER8000 - ER ER=8000 Step-Servo drives ER ER=20000 Notes Set encoder resolution to 8000 counts/rev Read encoder resolution 91 920-0002 Rev. J 12/2014 Host Command Reference ES - Single-Ended Encoder Usage Compatibility: Servo and stepper drives with encoder feedback (except STM) Allow a single-ended encoder to be used for drive feedback and commutation. This command has the same function as the box marked “Single Ended” in the Encoder setup screens of ST Configurator or QuickTuner. While some applications require single-ended encoders to be used, differential signals are always recommended due to their superior noise immunity, Command Details: Structure ES{Parameter #1} Type BUFFERED Usage READ/WRITE Non-Volatile YES Register Access None Parameter Details: Parameter #1 Single Ended Encoder Usage Flag - units integer - range 0 = Differential encoder used (recommended) 1 = Single-ended encoder used Examples: Command Drive sends ES0 - ES ES=0 Notes Drive will use a differential encoder ES1 - Drive will use a single-ended encoder ES ES=1 920-0002 Rev. J 12/2014 92 Host Command Reference EU - Denominator of Electronic Gearing Ratio Compatibility: M2 drives Affects: control mode 7, electronic gearing See also: EG, PV, EN, DS Defines the denominator of electronic gearing ratio. 0 – do not use the electronic gearing ratio. Command Details: Structure EU{Parameter #1} Type BUFFERED Usage READ/WRITE Non-Volatile YES Register Access None Parameter Details: Parameter #1 Denominator of electronic gearing - units integer number - range 0 - 1000 Default value 1000 Examples: Command EU1000 EU Drive sends % EU=1000 Notes Set the denominator of electronic gearing ratio to 1000 the denominator of electronic gearing ratio is 1000 93 920-0002 Rev. J 12/2014 Host Command Reference FA - Function of the Single-ended Analog Input Compatibility: M2 drives Affects: Control mode relating to analog input See Also: CM, CN commands Defines the function of the single-ended analog input. The command has two parameters: the first parameter selects the analog channel; the second parameter set the function of the selected analog channel. 1 – select analog channel 1 2 – select analog channel 2 eg: FA11 Analog input Ain1 is used as velocity or position reference input. FA12 Not used. FA13: Analog input Ain1 is used as general purpose analog input. FA21 Not used. FA22 Analog input Ain2 is used as torque reference input. FA23: Analog input Ain2 is used as general purpose analog input. Command Details: Structure FA{Parameter #1}{Parameter #2} Type BUFFERED Usage READ/WRITE Non-Volatile YES Register Access NO. Parameter Details: Parameter #1 Single-ended analog input channel - units integer number - range 1~2 Parameter #2 Function of the selected analog channel - units integer number - range 1~3 Default value 3 Examples: Command FA11 Drive sends % FA1 FA1=1 920-0002 Rev. J 12/2014 Notes Set the Analog input Ain1 to be used as velocity or position reference input. The Analog input Ain1 is used as velocity or position reference input. 94 Host Command Reference FC - Feed to Length with Speed Change Compatibility: All drives, though Q drives have added functionality (see below) See also: VC, VE, DC, DI, SD, WP commands Executes a feed to length (relative move) with a speed change. Overall move distance and direction come from the last DI command. Accel and decel are from AC and DE commands, respectively. Initial speed is VE. After the motor has moved DC counts, the speed changes to VC. If DC is equal to or greater than DI, a speed change will not occur. Optionally, a parameter pair may be used with the FC command to designate a switch and polarity to use as a trigger for the final move segment. If a switch parameter is used, the motor will change speed at the DC distance and will maintain that speed until the input is triggered. Once this input condition is met, the drive will travel the full DI distance and decelerate to a stop per the DE ramp. In this scenario, the overall move distance is the sum of DC, DI and the distance between the DC change point and the point where the input is triggered. The overall distance then, depends on the location of the trigger input. Q drives only With Q drives there may be multiple VCs and DCs per FC command, allowing for more complex, multi-velocity moves. To make multi-velocity moves with more than one speed change, the WP (Wait Position) command is also required. A sample sequence is shown in the Examples section below. (Velocity) DE AC VE VC DC (Distance) DI FC used without optional parameter (Velocity) SWITCH EVENT DE AC VE VC (Distance) DC DI FC used with optional parameter 95 920-0002 Rev. J 12/2014 Host Command Reference Command Details: Structure FC{Parameter #1}{Parameter #2} Type BUFFERED Usage WRITE ONLY Non-Volatile NO Register Access None Parameter Details: (See Appendix F: Working With Inputs and Outputs) Examples: Command DI50000 VE5 DC40000 VC0.5 FC Drive sends - - - - - Notes Set distance to 50000 steps Set velocity to 5 rps Set change distance to 40000 steps Set change velocity to 0.5 rps Initiate move FC with I/O trigger DI50000 - VE5 - DC40000 - VC0.5 - FC1L - Set distance to 50000 steps Set velocity to 5 rps Set change distance to 40000 steps Set change velocity to 0.5 rps Initiate move, specifying that the drive will move 50000 steps beyond the point where input 1 goes LOW. For Q drives only MT1 DI50000 VE5 DC10000 VC10 FC WP DC20000 VC1 WP DC30000 VC0.5 Turn multi-tasking ON* Set overall move distance to 50000 steps Set initial velocity to 5 rps Set 1st change distance to 10000 steps Set 1st change velocity to 10 rps Initiate move Wait position Set 2nd change distance to 20000 steps Set 2nd change velocity to 1 rps Wait position Set 3rd change distance to 30000 steps Set 3rd change velocity to 0.5 rps - - - - - - - - - - - - * Because multi-tasking is required for the WP command to be used, only Q models can perform multisegment moves. 920-0002 Rev. J 12/2014 96 Host Command Reference FD - Feed to Double Sensor Compatibility: All drives See also: FM, FS, FY, VC commands; see AT command for using analog input as sensor input Accelerates the motor at rate AC to speed VE. When the first sensor is reached (first input condition is made), the motor decelerates at rate DE to speed VC. When the second sensor is reached (second input condition is made), the motor decelerates over the distance DI to a stop at rate DE. The sign of the DI register is used to determine both the direction of the move (CW or CCW), and the distance past the second sensor. If DI is long the motor may not begin decel immediately after the second sensor. If DI is short the motor may decelerate using a faster decel rate than DE. Both analog and digital inputs can be used as sensor inputs. BLu, STAC6, STAC5-Q/IP, SVAC3-Q/IP, STM Both sensor inputs must be from the same physical I/O connector of the drive. This means that both inputs used in this command must reside on the same I/O connector, either IN/OUT 1 or IN/OUT 2. In the case of BLuDC drives this means that both inputs must reside on the same connector, either the main driver board I/O connector (DB-25) or the top board connector (screw terminal). Command Details: Structure FD(Parameter #1)(Parameter #2) Type BUFFERED Usage WRITE ONLY Non-Volatile NO Register Access None Parameter Details: (See Appendix F: Working With Inputs and Outputs) Examples: Command FDX2F4H Drive sends Notes - Launch Feed to Double Sensor move: decel from VE to VC when input 2 changes from high to low (falling), then decel to a stop when input 4 is high AC50 DE50 DI-1 VE5 VC1 FD1F2H - Set accel rate to 50 rev/sec/sec - Set decel rate to 50 rev/sec/sec - Set move direction to CCW - Set initial velocity to 5 rev/sec - Set change velocity to 1 rev/sec - Launch Feed to Double Sensor move: decel from VE to VC when input 1 changes from high to low (falling), then decel to a stop when input 2 is high 97 920-0002 Rev. J 12/2014 Host Command Reference FE - Follow Encoder Compatibility: All drives See also: EG, MT, ST commands Puts drive in encoder following mode until the given digital or analog input condition is met. The master encoder channels A and B must be wired to the STEP/X1 and DIR/X2 inputs of the drive. Use the EG command before the FE command to set the following resolution, or use the “R” register to dynamically adjust the following resolution while following (Note that in stepper drives the “R” register is equal to 1/2 the EG command). The Step Smoothing Filter is active in FE mode; see the SF command for details. When the FE command is initiated, the acceleration rate AC is used to ramp the motor up to the following speed. (Doing this prevents extreme accelerations when the master encoder signal is already at its target velocity). The motor continues to follow the master encoder pulses until the input condition is met, at which time the motor decelerates at rate DE to a stop using the DI command as the overall decel distance. If DI is long the motor may not begin decel immediately after the input condition is met. If DI is short the motor may have to decelerate at a rate faster than DE. Before the input condition is met the motor will follow the master encoder pulses in both CW and CCW directions, regardless of the sign of the DI command. However, once the input condition is met the motor will only stop properly if moving in the direction set by the DI command. When done executing the drive returns to the mode it was in before executing the FE command. NOTE: You must use the appropriate configuration software - Quick Tuner for servos, Configurator for steppers - to set up the STEP/X1 and DIR/X2 inputs for encoder following. Do this by choosing A/B Quadrature in the Position mode settings. NOTE: Take care when changing the “R” register while following because some move parameters will be scaled as well and therefore the move may change unexpectedly. Command Details: Structure FE(Parameter #1) Type BUFFERED Usage WRITE ONLY Non-Volatile NO Register Access None Parameter Details: (See Appendix F: Working With Inputs and Outputs) Examples: Command AC500 DI8000 FE4L 920-0002 Rev. J 12/2014 Drive sends - - - Notes Limit acceleration in encoder following to 500 rps/s Set the stopping offset distance to 8000 counts Run in encoder following mode until input 4 is low 98 Host Command Reference FH - Find Home Compatibility: SSM, TSM, TXM, SS, SSAC and M2 drives See also: DL, AC, DE, VE and VC commands Find Home sensor following homing method described in CiA402 standard Homing method. Only support homing method 1 and 2. Homing Method 1 As shown above, the initial direction of movement shall be CW if the CW limit switch is inactive (here: low), the home position shall be at the first index pulse to the CCW direction where the CW limit switch becomes inactive. Firstly the motor moves in CW direction and stops when CW limit switch is triggered. Then it moves in CCW direction until index is firstly reached after the CW limit switch becomes inactive from active state. Velocity, acceleration and deceleration are set by VE, AC and DE respectively in the first move. Velocity, acceleration and deceleration are set by VC, AC and DE commands respectively in the second move. Index is masked until it moves in CCW direction and CW switch is changed to inactive state from active. DL command set the active signal state of limit switch, high level or low level. NOTE: DI (Distance) value has no effect on homing direction 99 920-0002 Rev. J 12/2014 Host Command Reference Homing Method 2 As shown above, the initial direction of movement shall be CCW if the CCW limit switch is inactive (here: low), the home position shall be at the first index pulse to the CW direction where the CCW limit switch becomes inactive. Firstly the motor moves in CCW direction and stops when CCW limit switch is triggered. Then it moves in CW direction until index is firstly reached after the CCW limit switch becomes inactive from active state. Velocity, acceleration and deceleration are set by VE, AC and DE respectively in the first move. Velocity, acceleration and deceleration are set by VC, AC and DE commands respectively in the second move. Index is masked until it moves in CW direction and CCW switch is changed to inactive state from active. DL command set the active signal state of limit switch, high level or low level. NOTE: DI (Distance) value has no effect on homing direction Command Details: Structure FH{Parameter #1} Type BUFFERED Usage WRITE ONLY Non-Volatile No Register Access None 920-0002 Rev. J 12/2014 100 Host Command Reference Parameter Details: Parameter #1 Homing Method - units Short - range 1-2 Examples: Command FH1 Drive sends % Notes Homing to the first index CCW after the CW limit switch is reached. 101 920-0002 Rev. J 12/2014 Host Command Reference FI - Filter Input Compatibility: Affects: See also: All drives (except STAC5-S) All commands using inputs FX, RC, SD, WI and all feed to sensor commands. See EI for hardware filter alternative, specifically on STAC5 drives. Applies a digital filter to the given input. The digital input must be at the same level for the time period specified by the FI command before the input state is updated. For example, if the time value is set to 100 the input must remain high for 100 processor cycles before high is updated as the input state. A value of “0” disables the filter. processor cycle All stepper except STAC5 Blu,SV, SVAC3, STAC5 Step-Servo M2 100µsec 125µsec 200µsec 250µsec BLu, STAC6 This command can be used to apply filters to low speed inputs X3 through X7 on the main driver board of all drives, and can also be used on top board inputs IN3 through IN7 of SE, QE, and Si drives. Reassigning the filters to top board inputs of SE, QE and Si drives is done with the FX command. SV, ST-Q/Si This command can be used to apply filters to low speed inputs X3 through X8. ST-S, STM17, STM23 , SSM This command can be used to apply filters to inputs STEP, DIR, and EN STM24-SF/QF For drives with Flex I/O, this command can be used to apply filters to any input. STM24-C This command can be used to apply filters to inputs IN1, IN2 and IN3. STAC5-Q/IP, SVAC3-Q/IP This command can be used to apply filters to inputs IN5 - IN8. TSM-P This command can be used to apply filters to inputs X1 - X4. TSM-S/Q/C This command can be used to apply filters to inputs X3 - X6. TXM-S/Q/IP This command can be used to apply filters to inputs X1 - X3. TXM-C This command can be used to apply filters to inputs X3 - X5. SS This command can be used to apply filters to inputs X5 - X8. M2 This command can be used to apply filters to inputs X9 - X12. 920-0002 Rev. J 12/2014 102 Host Command Reference Command Details: Structure FI{Parameter#1}{Parameter#2} Type BUFFERED Usage READ/WRITE Non-Volatile YES, except BLu servos Register Access None Parameter Details: (See Appendix F: Working With Inputs and Outputs) Examples: Command Drive sends FI4100 - change FI4 FI4=100 Notes Requires that input X4 (if FX=1) maintain the same state (low or high) for 100 total processor cycles before the drive registers the 103 920-0002 Rev. J 12/2014 Host Command Reference Digital Input Filters in Detail Drives have the capability to apply digital filters to selected digital inputs. With factory defaults, digital inputs are not filtered through any means other than the natural response time of the optical couplers used in the input circuits. Analog filtering has purposely not been implemented so as to not restrict the input circuit. However, digital filtering is available on select digital inputs to enhance the usage of those inputs. On occasion, electrical noise at digital inputs may create a false trigger or even a double-trigger. This can often happen when using mechanical switches that “bounce” when activated or de-activated. For this reason there may be a need to filter an input to eliminate the effects of these noise conditions. Digital filtering gives the greatest flexibility by allowing the user to select the amount of filtering required to eliminate the effects of noise or bounce. The digital filters work by continuously monitoring the level of the inputs to which filters have been applied using the FI command. During each processor cycle (servo and STAC5 = 125 µsec, other steppers = 100 µsec), internal counters associated with the filters are incremented or decremented depending on whether each input is high (open) or low (closed), respectively. When a command that accesses a digital input is executed, the state of the input requested by that command will be updated only after the internal counter for that input’s filter reaches a threshold value. This threshold value is also known as the filter value, and is set by the FI command. The flow chart to the right shows how a digital filter works. For example, if we apply a digital filter of 2 milliseconds to input 3 on a STAC6 stepper drive, it means we’d like the level of input 3 (low or high) to be true for a total of 2 milliseconds before the processor updates the state of input 3 to the state requested by the command currently being executed. If the command being executed is a WI3L command, which literally means “wait for input 3 low”, it means the processor will wait until the level of input 3 has been low for a total of 2 milliseconds before updating the state of the input as low and finishing the WI3L command. If by chance input 3 has already been low for the prerequisite 2 milliseconds when the WI3L command is initiated, there will be no delay in executing the command. On the other hand, if input 3 is high when the WI3L command is initiated, there will be an additional minimum delay of 2 milliseconds after the input changes state from high to low. It is important to understand that any fluctuation of the physical signal, by switch bounce or electrical noise, will contribute to a lag in the processed signal. To turn filtering of input 3 on we need to use the FI command. The FI command works in processor cycles and we’re using a STAC6 stepper drive in this example, so a value of 1 equals 100 microseconds. To filter the EN input for 2 milliseconds the value of the FI command would then be 2 msec divided by 100 usec, or 20. The correct syntax for the FI command would then be “FI320”. As can be seen from the example and flow chart above, the functioning of a digital input filter incorporates an averaging effect on the level of the input. This means that in the example above, if the level of the input 3 were fluctuating between low and high over a range of processor cycles (maybe due to electrical noise), the drive would not update the input state until the internal counter value went to zero (for a low state) or the filter value (for a high state). Another example of this averaging effect is if the input were connected to a pulse train from a signal generator with a duty cycle of 51% high and 49% low. The input state would eventually be set to a 920-0002 Rev. J 12/2014 104 Host Command Reference high state, depending on the time value used in the pulse train. Filter values are non-volatile for all but the BLu series of servo drives, if followed by an SA command. With a BLu servo drive, the filter values are lost at power-down and must be set each time the drive is powered on. NOTE: A side effect of the digital filter, which is true of any filter, is to cause a lag in the response to an input level. When an input changes state and is solid (no noise), the lag time will be the same as the filter value. When noise is present the lag may be longer. 105 920-0002 Rev. J 12/2014 Host Command Reference FL - Feed to Length Compatibility: All drives See also: AC, DE, DI, VE commands Executes a relative move command. Move distance and direction come from the last DI command. Speed, accel and decel are from the VE, AC and DE commands, respectively. Executing the FL command with no parameter initiates a feed to length move that uses the last DI command for direction and distance. Executing the FL command with a parameter uses the parameter settings for direction and distance without changing the DI command. Command Details: Structure FL{Parameter #1} Type BUFFERED Usage WRITE ONLY Non-Volatile NO Register Access None Parameter Details: Parameter #1 Relative distance - units counts or steps - range -2,147,483,647 to 2,147,483,647 sign determines direction: “-” for CCW, no sign for CW Examples: Command DI20000 FL Drive sends - - FL20000 - FL-400 - 920-0002 Rev. J 12/2014 Notes Set distance to 20000 counts in the CW direction Launch Feed to Length move Launch Feed to Length move of 20000 counts in the CW direction without affecting the DI command Launch Feed to Length move of 400 counts in the CCW direction without affecting the DI command 106 Host Command Reference FM - Feed to Sensor with Mask Distance Compatibility: All drives See also: FS command Executes a Feed to Sensor command (see FS command) except sensor is ignored for the first DC counts of the move. In other words the sensor is “masked” for a beginning portion of the move. This command is useful for ignoring noise from a mechanical switch or for clearing a part before sensing the next one. Command Details: Structure FM(Parameter #1) Type BUFFERED Usage WRITE ONLY Non-Volatile NO Register Access None Parameter Details: (See Appendix F: Working With Inputs and Outputs) Examples: Example: Parts are feeding on a conveyor which is being driven by the motor. A sensor detects the leading edge of the part and stops. If the part has a hole in it, which is common, when you attempt to feed the next part into position you may in fact stop after feeding the previous part only a short distance because the sensor will register the hole in the part rather than the leading edge of the next part. The solution is to use the FM command instead of the FS command, and to set the DC command for the size of the part (or greater). Example continued: The parts on a conveyor are 6 inches long. Your mechanical linkage provides 2000 steps per inch. You want the leading edge of the part to stop moving 1 inch past the sensor, and therefore 5 inches of the part will not have gone past the sensor yet. To avoid holes in the part and see the next part properly, we need to mask 5 inches or more of the move. Here are the commands you could use. Command Drive sends DI2000 - DC10200 - FM1F - Notes Set distance to stop past sensor at 1 inch (2000 steps) Set distance over which to ignore (mask) the sensor at 5.1 inches, enough to allow the previous part to completely clear the sensor Initiate FM move. Sensor is connected to input 1 and will close when it sees a part 107 920-0002 Rev. J 12/2014 Host Command Reference FO - Feed to Length and Set Output Compatibility: See Also: All drives DC, DI, AO, BO, MO commands Same as Feed to Length (FL) but changes the state of an output during the move. Overall move distance is defined by the DI command. Accel rate, decel rate, and velocity are set by the AC, DE and VE commands, respectively. Distance within overall move at which output condition should be set is defined by the DC command. If DC is equal to or greater than DI, the input condition will not be met during the move and the output will not be set. NOTE: Dedicated output functions - alarm output, brake output, motion output - must be configured as general purpose before the FO command can be used with the drive’s output. See AO, BO, and MO commands. Command Details: Structured FO(Parameter #1) Type BUFFERED Usage WRITE ONLY Non-Volatile NO Register Access None Parameter Details: (See Appendix F: Working With Inputs and Outputs) Examples: Example: You’re feeding parts to be cut to length. For maximum throughput, you want to trigger the cut-off knife as the part is nearing the final position. Command AC100 DE100 VE2.5 DI20000 DC15000 FO1L 920-0002 Rev. J 12/2014 Drive sends - - - - - - Notes Set accel rate to 100 rev/sec/sec Set decel rate to 100 rev/sec/sec Set velocity to 2.5 rev/sec Overall move distance set to 20000 steps Set output distance set to 15000 steps Initiate move and set output low at 15000 steps 108 Host Command Reference FP - Feed to Position Compatibility: All drives See also: AC, DE, DI, SP, VE commands Executes an absolute move command. Move position comes from the last DI command. Speed, accel and decel are from VE, AC and DE commands, respectively. Executing the FP command with no parameter initiates a feed to position move that uses the last DI command for position. Executing the FP command with a parameter uses the parameter for position without changing the DI command. Command Details: Structure FP{Parameter #1} Type BUFFERED Usage WRITE ONLY Non-Volatile NO Register Access None Parameter Details: Parameter #1 Absolute position - units counts or steps - range -2,147,483,647 to 2,147,483,647 Examples: Example: After homing the motor you want to zero the home position and move to an absolute position 8000 counts (or steps) from the new home position. Command SP0 DI8000 FP Drive sends - - - FP8000 - FP8000 - Notes Set current motor position as absolute zero Set move position to 8000 counts/steps Launch Feed to Position Launch Feed to Position to 8000 counts/steps without affecting the “D” register Motor is already at position 8000, no motion occurs. 109 920-0002 Rev. J 12/2014 Host Command Reference FS - Feed to Sensor Compatibility: All drives See also: FD, FM and FY commands; see AT command for using AIN as sensor input Executes a Feed to Sensor command. Requires input number and condition. The motor moves until a sensor triggers the specified input condition, then stops a precise distance beyond the sensor. The stop distance is defined by the DI command. The direction of rotation is defined by the sign of the DI command (“-” for CCW, no sign for CW). Speed, accel and decel are from the last VE, AC and DE commands, respectively. A motor moving at a given speed, with a given decel rate, needs a certain distance to stop. If you specify too short a distance for DI the drive may overshoot the target. Use the following formula to compute the minimum decel distance, given a velocity V (in rev/sec) and decel rate D (in rev/sec/sec.). R = steps/rev, which will equal the encoder resolution for a servo motor and the EG setting for a step motor. minimum decel distance = (V)2(R) 2(D) Note that it is possible to use an analog input (AIN) as a discrete sensor by configuring a threshold point. See the AT command for details. Command Details: Structure FS(Parameter #1) Type BUFFERED Usage WRITE ONLY Non-Volatile NO Register Access None Parameter Details: (See Appendix F: Working With Inputs and Outputs) Examples: Command Drive sends FS1L - FS3R - FSX5L - 920-0002 Rev. J 12/2014 Notes Launch move and decel to stop when sensor tied to input 1 is low Launch move and decel to stop when sensor tied to input 3 changes from low to high (rising edge) Launch move and decel to stop when sensor tied to input X5 is low 110 Host Command Reference FX - Filter select inputs Compatibility: All drives (except STAC5, SVAC3) Affects: FI command on SE, QE, and Si drives See also: FI command The FX command allows changing the target inputs of a drive’s digital input filters from the main board X3 through X7 inputs to the top board IN3 through IN7 inputs. This can only be done on SE, QE, and Si drives with firmware 1.53U or later. Command Details: Structure FX{Parameter #1} Type BUFFERED Usage READ/WRITE Non-Volatile NO Register Access None Parameter Details: Parameter #1 Digital inputs selector - units integer - range 0 = top board inputs of SE, QE, and Si drives 1 = main board inputs of all drives Examples: Command FX0 FX Drive sends Notes - Cause digital input filters set by FI command to affect top board inputs IN3 through IN7 of SE, QE, and Si drives. FX=1 Digital filters are set to be applied to main driver board inputs X3 through X7. 111 920-0002 Rev. J 12/2014 Host Command Reference FY - Feed to Sensor with Safety Distance Compatibility: All drives See also: DC, FD, FM and FS commands; see AT command for using AIN as sensor input Executes a Feed to Sensor move while monitoring a predefined safety distance DC. DI defines the direction of rotation and the stop distance to move after the sensor triggers the stop input condition. Accel rate, decel rate, and velocity are set by the AC, DE, and VE commands, respectively. Note that the maximum final motor position will be the safety distance plus the distance required to decelerate the load, which is dependent on the decel rate DE. NOTE: If the safety distance is exceeded, three things will happen. The motor is stopped, the drive sends the host an exclamation point (“!”) and adds a value of 1 to the Other Flags register (“F” register). This can occur if the sensor is not encountered before DC is reached, or if the DI value is set high enough that the total move distance would exceed the maximum of DC plus the deceleration distance determined by DE. This command is useful for avoiding machine jams or detecting the end of a roll of labels. For example, you are feeding labels and you want to stop each label 2000 steps after the sensor detects the leading edge. The labels are 60,000 steps apart. Therefore, if you move the roll more than 60,000 steps without detecting a new label, you must be at the end of the roll. NOTE: DI must be assigned a value greater than zero when used with the FY command. If DI is set to zero (DI0), the motor will not move. Command Details: Structure FY(Parameter #1) Type BUFFERED Usage WRITE ONLY Non-Volatile NO Register Access “F” (022) Executing the FY command will put a value of 2 in the “F” register when the sensor is successfully found, or a value of 1 in the “F” register if the safety distance is met. If you plan to use the “F” register for monitoring the success of the FY command you must zero the register before each FY command by executing RLF0. Parameter Details: (See Appendix F: Working With Inputs and Outputs) Examples: Command Drive sends DI2000 - DC60000 - FY2L - Notes Set distance to stop beyond sensor to 2000 counts/steps Set safety distance to 60000 counts/steps Launch Feed to Sensor: motor will stop when input 2 is low or when 60000 counts/steps are reached: whichever event comes first When using the SE, QE, or Si drives and needing to access the main driver board inputs... FYX2L - Launch Feed to Sensor: motor will stop when main driver board input 2 is low or when 60000 counts/steps are reached: whichever event comes first 920-0002 Rev. J 12/2014 112 Host Command Reference GC - Current Command Compatibility: Servo drives only Affects: Commanded motor current See also: CM command Sets or requests the immediate current command for the servo motor and drive when the servo drive is set for Command Mode 1 (CM1). NOTE: Setting this value may make the servo motor run to a very high speed, especially if there is no load on the motor. Take care when using this command. Command Details: Structure GC{Parameter #1} Type IMMEDIATE Usage READ/WRITE Non-Volatile Yes Register Access “G” (023) Command Details: Parameter #1 RMS Current - units 0.01 amps rms - range -2000 to +2000 (+/- 20 amps rms) Examples: Command CM1 GC100 GC-100 Drive sends - - - Notes Set servo drive to Commanded Current Command Mode Set current to motor at 1 A rms Set current to motor at -1 A rms (opposite direction) 113 920-0002 Rev. J 12/2014 Host Command Reference GG - Controller Global Gain Selection Compatibility: M2 drives Affects: Controller PID parameters, Input #7 See Also: KP, KG commands Defines the usage of input X7 for PID controller global gain selections. GG1: select KP when input X7 is open, and select KG when input X7 is closed. GG2: select KP when input X7 is closed, and select KG when input X7 is open. GG3: Input X7 is used as general purpose input. Select KP as global gain. Command Details: Structure GG{Parameter #1} Type BUFFERED Usage READ/WRITE Non-Volatile YES Register Access NO. Parameter Details: Parameter #1 See above - units integer number - range 1~3 Examples: Command GG1 GG 920-0002 Rev. J 12/2014 Drive sends % GG =1 Notes Set the usage of global gain selection to 1 The usage of global gain selection is 1 114 Host Command Reference HA - Homing Acceleration Compatibility: SSM, TSM, TXM, SS, SSAC and M2 drives See also: DL, HL, HV, HO, EH commands Sets or requests the acceleration rate used in Extended Homing Mode and Hard Stop Homing Mode commands in rev/sec/sec. NOTE: This command is designed for three steps Acceleration rate in the whole Extended Homing process. Please see the detail reference to EH command. Command Details: Structure HA{Parameter #1}{Parameter #2} Type BUFFERED Usage READ/WRITE Non-Volatile Yes Register Access None Parameter Details: Parameter #1 Select Step - units Integer - range 1~3 Parameter #2 Acceleration rate - units rev/sec/sec (rps/s) - range 0.167 to 5461.167 (resolution is 0.167 rps/s) Default value HA1: 100 rps/s HA2: 100 rps/s HA3: 10rps/s Examples: Command HA120 HA1 Drive sends % HA1=20 Notes Setting the homing acceleration to 20 rps/s for step 1 Reading Homing accel for step 1 115 920-0002 Rev. J 12/2014 Host Command Reference HC - Hard Stop Current Compatibility: SSM, TSM, TXM, SS, SSAC drives See also: HA, HS, HO, HL, HV commands Set or request the current in Hard Stop Homing mode, this will protect the user’s mechanical. This value should not exceed the running current value. Command Details: Structure HC{Parameter #1} Type BUFFERED Usage READ/WRITE Non-Volatile Yes Register Access None Parameter Details: Parameter #1 Current in Hard Stop Homing - units amps (resolution is 0.01 amps) - range 0.01 ~ CC Examples: Command Drive sends Notes HC1 - Set the hard stop current to 1 Amp HC HC=1 920-0002 Rev. J 12/2014 116 Host Command Reference HD - Hard Stop Fault Delay Compatibility: Stepper drives with Encoder Feedback See also: EF command Specifies the amount of time the drive will attempt to recover from a stall while in Stall Prevention mode. In Stall Prevention mode (See EF command), the drive will attempt to recover from a stall condition. This delay setting dictates the amount of time the drive will work to recover from such a stall before faulting. This allows the machine to recover from minor disruptions without unnecessarily working to recover from an unrecoverable state. Command Details: Structure HD{Parameter #1} Type BUFFERED Usage WRITE ONLY Non-Volatile YES Register Access None Parameter Details: Parameter #1 Hard Stop Fault Delay Time - units integer - range 1 - 32000 milliseconds Examples: Command Drive sends HD1000 - Notes In the event of a stall, instruct the drive to attempt to recover for 1000ms (1 second) before faulting. 117 920-0002 Rev. J 12/2014 Host Command Reference HG - 4th Harmonic Filter Gain Compatibility: Stepper drives only Affects: Low-speed performance of step motors See also: HP command Sets or requests the 4th harmonic filter gain setting. This setting works in conjunction with the 4th harmonic filter phase setting (HP) to reduce low-speed torque ripple in step motors. NOTE: We strongly suggest you set this value in the ST Configurator software application only. Command Details: Structure HG{Parameter #1} Type IMMEDIATE Usage READ/WRITE Non-Volatile YES only when set in Configurator software, otherwise NO Register Access None Parameter Details: Parameter #1 Filter gain - units integer number - range 0 - 32767 Examples: Command Drive sends HG8000 - HG HG=8000 920-0002 Rev. J 12/2014 Notes Set filter gain value to 8000 118 Host Command Reference HL - Homing Deceleration Compatibility: SSM, TSM, TXM, SS, SSAC and M2 drives See also: DL, HA, HV, HO, EH commands Sets or requests the deceleration rate used in point-to-point move commands in rev/sec/sec. NOTE: This command is designed for three steps Deceleration rate in the whole Extended Homing process. Please see the detail reference to EH command. Command Details: Structure HL{Parameter #1}{Parameter #2} Type BUFFERED Usage READ/WRITE Non-Volatile Yes Register Access None Parameter Details: Parameter #1 Select Step - units Integer - range 1~3 Parameter #2 Deceleration rate - units rev/sec/sec (rps/s) - range 0.167 to 5461.167 (resolution is 0.167 rps/s) Default value HL1: 100 rps/s HL2: 100 rps/s HL3: 10rps/s Examples: Command HL220 HL2 Drive sends % HL2=20 Notes Setting the homing deceleration to 20 rps/s for step 2 Reading Homing accel for step 2 119 920-0002 Rev. J 12/2014 Host Command Reference HO - Homing Offset Compatibility: SSM, TSM, TXM, SS, SSAC and M2 drives See also: DL, HA, HL, HV, EH commands Sets or requests the move distance in steps after the home sensor reached in Extended Homing Control Mode and Hard Stop Homing Mode. The sign of HO indicates move direction: no sign means CW and “-”means CCW. Command Details: Structure HO{Parameter #1} Type BUFFERED Usage READ/WRITE Non-Volatile Yes Register Access None Parameter Details: Parameter #1 Distance after Home sensor reached - units steps - range -2,147,483,647 to 2,147,483,647 sign determines direction: “-” for CCW, no sign for CW Default value 2000 Examples: Command Drive sends HO20000 % HO HO=20000 920-0002 Rev. J 12/2014 Notes Set home distance to 20000 counts in the CW direction 120 Host Command Reference HP - 4th Harmonic Filter Phase Compatibility: Stepper drives only Affects: Low-speed performance of step motors See also: HG command Sets or requests the 4th harmonic filter phase setting. This setting works in conjunction with the 4th harmonic filter gain setting (HG) to reduce low-speed torque ripple in step motors. NOTE: We strongly suggest you set this value in the ST Configurator software application only. Command Details: Structure HP{Parameter #1} Type IMMEDIATE Usage READ/WRITE Non-Volatile YES only when set in Configurator software, otherwise NO Register Access None Parameter Details: Parameter #1 Filter phase - units integer number - range -125 to +125 Examples: Command Drive sends HG105 - HG HG=105 Notes Set 4th harmonic filter gain to 105 121 920-0002 Rev. J 12/2014 Host Command Reference HS - Hard Stop Homing Compatibility: SSM, TSM, TXM, SS, SSAC drives See also: HA, HC, HO, HL, HV commands Executes an Hard Stop Homing command. Requires stop position with or without index pulse after reach the mechanical end. The max current to touching mechanical end is set by HC command, and speed is set by HV command, there are three velocities setting for different steps (see the detail as following description). Acceleration and deceleration are set by HA(Homing Accel) and HL(Homing Decel). The start direction comes from the sign of the HO command (“-” is CCW, no sign is CW). Here following the description for each commands and motor motion. 1: Moving toward one end Step Servo Moving direction V1 Home 2: Reaching one end Home 3: Searching for the first index position Return for first index position V3 Home 4: Reaching home Offset distance V2 Home HV1: Homing velocity for searching mechanical end. HV2: Homing velocity for moving offset distance set by HO if required. HV3: Homing velocity for return back to first encoder index if required. Command Details: Structure HS{Parameter #1} Type BUFFERED Usage WRITE 920-0002 Rev. J 12/2014 122 Host Command Reference Non-Volatile None Register Access None Parameter Details: Parameter #1 Hard Stop Home with or without index - units none - range 0 = without index 1 = with index Examples: Command HS1 Drive sends - Notes Do the hard stop homing process 123 920-0002 Rev. J 12/2014 Host Command Reference HV - Homing Velocity Compatibility: SSM, TSM, TXM, SS, SSAC and M2 drives See Also: DL, HA, HL, HO, EH commands Sets or requests the shaft speed used in the Extended Homing mode. HV1: Homing velocity for searching Limit Sensor and Home sensor. HV2: Homing velocity for moving the setting distance after(beyond) home sensor reached. HV3: Homing velocity for return back to home sensor aftersetting distance moving completed. Command Details: Structure HV{Parameter #1}{Parameter #2} Type BUFFERED Usage READ/WRITE Non-Volatile Yes Register Access None Parameter Details: Parameter #1 Select Step - units Integer - range 1~3 Parameter #2 Move velocity - units rev/sec (rps) - range 0.0042 - 80.0000 (resolution is 0.0042) Default value HV1: 10rps HV2: 5rps HV3: 0.5rps Examples: Command HV110 HV1 920-0002 Rev. J 12/2014 Drive sends % HV1=10 Notes Setting the homing velocity to 10 rps for step 1 Reading Homing velocity for step 1 124 Host Command Reference HW - Hand Wheel Compatibility: All drives See also: EG, FE, and MT commands; see AT command for using analog input as sensor input Puts drive in “hand wheel” mode until the given digital or analog input condition is met. Hand wheel mode is a kind of low speed following mode, where the motor follows master encoder signals as a hand wheel is manually turned. This command differs from the FE command in that the AC, DE, and DI commands are not used in any way. In other words, the motor will attempt to follow the master encoder signals without injecting any ramps to smoothly approach high frequency target speeds or to come to a stop when the stop input condition is met. BLu, SV, STAC6, ST-Q/Si, STAC5, SVAC3 Inputs X1 and X2 are used for connecting the A and B signals of the encoder-based handwheel. The EG (Electronic Gearing) command defines the following resolution of the motor. ST-S, STM17/23 Inputs STEP and DIR are used for connecting the A and B signals of the encoder-based handwheel. The EG (Electronic Gearing) command defines the following resolution of the step motor. Command Details: Structure HW(Parameter #1) Type BUFFERED Usage WRITE ONLY Non-Volatile NO Register Access None Parameter Details: (See Appendix F: Working With Inputs and Outputs) Examples: Command HWX4L Drive sends - Notes Run in hand wheel mode until input X4 low 125 920-0002 Rev. J 12/2014 Host Command Reference Immediate Status Commands The following section describes commands that return “Immediate” results when sent. These selected commands provide useful information for monitoring internal values from the drive. Data can be sent out in two different formats, Hexadecimal or Decimal. By default the data is returned in Hexadecimal because of its speed and efficiency. Conversion to ascii in the Decimal format is slower and causes a slight delay that varies in length. Hexadecimal minimizes the overhead required to convert the internal binary data to ascii form. This speeds up the process of sending out the requested data thus giving the most recent value. Typically, applications written on more powerful Host computers can easily convert a hexadecimal value to an integer value. The Immediate Format (IF) command sets the format of the returned data to hexadecimal or decimal. For cases where a slight delay is acceptable the data can be sent out in decimal form. Setting the format affects all of the “I” commands (except IH and IL). See IF command in the following pages. All the “I” commands can be used at any time and at the fastest rate possible limited only by the given Baud Rate (See BR and PB commands). As with any immediate type command it is acted upon as soon as it’s received. Regardless of format (hex or dec) there will be a slight delay in processing the command. “Real time” usage of the data must be carefully analyzed. 920-0002 Rev. J 12/2014 126 Host Command Reference IA - Immediate Analog Compatibility: All drives See Also: AD, AV, AZ and IF commands BLu, SV, STAC6, ST-Q/Si Requests present analog input value from the given source. There are three different analog values that can be accessed. With no parameter the IA command returns the Analog Command value which is derived from the analog inputs with gain and offset values applied as set in Quick Tuner or Configurator or via the AD, AV and/or AZ commands. When a parameter is given raw (unscaled) analog input values are returned. ST-S, STM Requests present analog input value. There are two different analog values that can be accessed. With no parameter the IA command returns the Analog Command value which is derived from the analog input with gain and offset values applied as set in ST Configurator or via the AD, AV and/or AZ commands. When a parameter is given raw (unscaled) analog input values are returned. Note: The output of the IA command is formatted by IF. See IF for further details. Command Details: Structure IA{Parameter #1} Type IMMEDIATE Usage READ ONLY Non-Volatile NO Register Access All drives... “a” (049) Analog Command BLu, SV, STAC6, ST-Q/Si... “j” (058) Analog input 1 (unscaled) “k” (059) Analog input 2 (unscaled) ST-S, STM... “j” (058) AIN (unscaled) Parameter Details: BLu, SV, STAC6, ST-Q/Si, STAC5, SVAC3 Parameter #1 Analog input - units integer - range No parameter or 0 = Analog command 1 = Analog input 1 (unscaled) 2 = Analog input 2 (unscaled) 3 = Expanded analog input (SE, QE, and Si models) ST-S, STM17-S/Q/C, STM23-Q Parameter #1 Analog input - units integer - range No parameter or 0 = Analog command 1 = AIN (unscaled) 127 920-0002 Rev. J 12/2014 Host Command Reference Examples: Command Drive sends Notes IFD - Return future Immediate command responses in Decimal format IA IA=2.5 Analog Command is at mid range when drive is set to 0-5 volt input. (In Decimal mode neither leading nor trailing zeros are used, so the response length is not strictly defined and may be up to four digits in length.) IFH - IA IA=1FEE 920-0002 Rev. J 12/2014 Return future Immediate command responses in Hexadecimal format. Analog Command represented as hexadecimal value. (Leading zeros are used for small values, so the response will always be four digits in length.) 128 Host Command Reference IC - Immediate Current (Commanded) Compatibility: All drives Servo drives Requests the present RMS current commanded by the servo loop. This may not be the actual current at the motor windings. Most AC servo motors are commutated using a sinusoidal current waveform that is a “peak” value and not directly represented by the commanded current. The commanded current is the average RMS current being asked of the driver. Typically with a well tuned current loop the RMS current in the servo motor is well represented by this value. Stepper drives Requests the present (peak-of-sine) current applied to each motor phase. This value will change depending on what the motor is doing at the moment the command is processed. If the motor is moving this value will equal the CA (STM only) or CC value. If the motor is not moving this value will equal the CI value. Command Details: Structure IC Type IMMEDIATE Usage READ ONLY Non-Volatile NO Register Access “c” (051) Units 0.01 amps Examples: Command IC IC Drive sends IC=015E IC=FEA2 Notes 3.5 amps -3.5 amps If the IF command is set with Parameter #1=D IFD - Set values to be read back in decimal IC IC=350 3.5 amps IC IC=-350 -3.5 amps 129 920-0002 Rev. J 12/2014 Host Command Reference ID - Immediate Distance Compatibility: All drives BLu, STAC6 Requests the total relative distance moved in the last completed move. SV, ST-Q/Si, ST-S, STM Requests the immediate relative distance traveled from the beginning of the last move. Once the move is finished the value will be equal to the relative distance of that last move until another move is initiated, at which time the value will zero and begin tracking the new relative distance moved. Command Details: Structure ID Type IMMEDIATE Usage READ ONLY Non-Volatile NO Register Access “d” (052) Units encoder counts (servo) steps (stepper) Examples: Command ID ID Drive sends ID=00002710 ID=FFFFD8F0 Notes 10000 (10000 counts into CW move) -10000 (10000 counts into CCW move) If the IF command is set with Parameter #1=D ID ID=10000 10000 counts into CW move ID ID=-10000 10000 counts into CCW move 920-0002 Rev. J 12/2014 130 Host Command Reference IE - Immediate Encoder Compatibility: Servo drives and stepper drives with encoder feedback Requests present encoder position. Command Details: Structure IE Type IMMEDIATE Usage READ ONLY Non-Volatile NO Register Access “e” (053) Units encoder counts Examples: Command IE IE Drive sends IE=00002710 IE=FFFFD8F0 Notes Encoder position is (+)10000 counts Encoder position is -10000 counts If the IF command is set with Parameter #1=D IE IE=10000 Encoder position is (+)10000 counts IE IE=-10000 Encoder position is -10000 counts 131 920-0002 Rev. J 12/2014 Host Command Reference IF - Immediate Format Compatibility: All drives Affects: Immediate Commands IA, IC, ID, IE, IP, IT, IU, IV and IX Sets the data format, hexadecimal or decimal, for data returned using all “I” commands (except IH, IL, IO and IS). Data can be requested from the drive in two formats: hexadecimal or decimal. By default data is returned in hexadecimal because of its speed and efficiency. Conversion to ascii in the decimal format is slower and causes a slight delay that varies in length. Hexadecimal minimizes the overhead required to convert the internal binary data to ascii form. This speeds up the process of sending out the requested data thus giving the most recent value. Typically, applications written on more powerful host computers can easily convert a hexadecimal value into a decimal value. All “I” commands can be used at any time and at the fastest rate possible limited only by the given baud rate (see BR and PB commands). Immediate commands are executed as they are received, regardless of what is in the drive’s command buffer. Regardless of format (hex or dec) there will be a slight delay in processing the response to an “I” command. “Real time” usage of the data must be carefully analyzed. Command Details: Structure IF{Parameter #1} Type IMMEDIATE Usage READ/WRITE Non-Volatile YES Register Access None Parameter Details: Parameter #1 Return format - units letter - range H (hexadecimal) or D (decimal) Examples: Command Drive sends IFH - ID ID=00002710 IF IF=H Notes Sets format to Hexadecimal Distance is 10000 counts IFD - ID ID=10000 IF IF=D Sets format to Decimal Distance is 10000 counts 920-0002 Rev. J 12/2014 132 Host Command Reference IH - Immediate High Output Compatibility: All drives See also: IL, SO commands Sets an output high (open) immediately. Use SO instead if you don’t want the output to change until a buffered command (like a move) is complete. Command Details: Structure IH(Parameter #1) Type IMMEDIATE Usage WRITE ONLY Non-Volatile NO Register Access None Parameter Details: (See Appendix F: Working With Inputs and Outputs) Examples: Command IH1 IH2 Drive sends - - Notes Output 1 goes high immediately Output 2 goes high immediately To force Outputs on main driver board when using an SE, QE or Si drive IHY1 - Output 1 of main driver board goes high immediately IHY2 - Output 2 of main driver board goes high immediately 133 920-0002 Rev. J 12/2014 Host Command Reference IL - Immediate Low Output Compatibility: All drives See also: IH, SO commands. Sets an output low (closed) immediately. Use SO instead if you don’t want the output to change until a buffered command (like a move) is complete. Command Details: Structure IL(Parameter #1) Type IMMEDIATE Usage WRITE ONLY Non-Volatile NO Register Access None Parameter Details: (See Appendix F: Working With Inputs and Outputs) Examples: Command IL1 IL2 Drive sends - - Notes Output 1 goes low immediately Output 2 goes low immediately To force Outputs on main driver board when using an SE, QE, or Si drive ILY1 - Output 1 of main driver board goes low immediately ILY2 - Output 2 of main driver board goes low immediately 920-0002 Rev. J 12/2014 134 Host Command Reference IO - Output Status Compatibility: All drives With no parameter this command requests the immediate status of the designated outputs. The status is displayed as an 8-bit binary number with output 1 in the far right position (bit 0). With a parameter this command sets the outputs high or low using the decimal equivalent of the same binary pattern. Logic zero (“0”) turns an output on by closing it. Command Details: Structure IO{Parameter #1} Type IMMEDIATE Usage READ/WRITE Non-Volatile NO Register Access None Parameter Details: (See Appendix F: Working With Inputs and Outputs) Examples: BLu and STAC6-S or -Q versions (optional “Y” character is not necessary) Command Drive sends Notes IO IO=00000000 All 3 outputs of IN/OUT1 or main board are low (closed) IO IO=00000111 All 3 outputs of IN/OUT1 or main board are high (open) IO0 - Sets all 3 outputs low (closed) IO7 - Sets all 3 outputs high (open) BLu and STAC6-QE or -Si versions Command Drive sends IO IO=00000000 IO IO=00001111 IO0 - IO15 - IOY IO=00000000 IOY IO=00000111 IOY0 - IOY7 - Notes All 4 outputs of IN/OUT2 or top board are low (closed) All 4 outputs of IN/OUT2 or top board are high (open) Sets all 4 outputs of IN/OUT2 or top board low (closed) Sets all 4 outputs of IN/OUT2 or top board high (open) All 3 outputs of IN/OUT1 or main board are low (closed) All 3 outputs of IN/OUT1 or main board are high (open) Sets all 3 outputs of IN/OUT1 or main board low (closed) Sets all 3 outputs of IN/OUT1 or main board high (open) STAC5-S, SVAC3-S Command Drive sends IOY IO=00000000 IOY IO=00000011 IOY0 IOY3 Notes (DB-15) Both outputs of IN/OUT1 are low (closed) Both outputs of IN/OUT1 are high (open) Sets both outputs of IN/OUT1 low (closed) Sets both outputs of IN/OUT1 high (open) STAC5-Q/IP, SVAC3-Q/IP Command Drive sends Notes (DB25) IO IO=00000000 All 4 outputs of IN/OUT2 are low (closed) IO IO=00001111 All 4 outputs of IN/OUT2 are high (open) IO0 Sets all 4 outputs of IN/OUT2 low (closed) IO15 Sets all 4 outputs of IN/OUT2 high (open) 135 920-0002 Rev. J 12/2014 Host Command Reference IO IOY IOY IOY0 IOY7 SV, ST-Q/Si Command IO IO IO0 IO7 IO=00001111 All 4 outputs of IN/OUT2 high (open) Notes (DB15) IO=00000000 Both outputs of IN/OUT1 low (closed) IO=00000011 Both outputs of IN/OUT1 high (open) Both outputs of IN/OUT1 low (closed) Both outputs of IN/OUT1 high (open) Drive sends IO=00000000 IO=00001111 - - Notes All 4 outputs are low (closed) All 4 outputs are high (open) Sets all 4 outputs low (closed) Sets all 4 outputs high (open) ST-S, STM17-S/Q/C, STM23-Q/C, STM24-C Command Drive Sends Notes IO IO=00000000 Output is low (closed) IO IO=00000001 Output is high (open) IO0 - Sets output low (closed) IO1 - Sets output high (open) STM24 – Flex I/O Command Drive sends IO IO=00000000 IO IO=00001111 IO0 IO15 IO IO=00001111 920-0002 Rev. J 12/2014 Notes All 4 outputs of IN/OUT2 are low (closed) All 4 outputs of IN/OUT2 are high (open) Sets all 4 outputs of IN/OUT2 low (closed) Sets all 4 outputs of IN/OUT2 high (open) All 4 outputs of IN/OUT2 high (open) 136 Host Command Reference IP - Immediate Position Compatibility: All drives Requests present absolute position. The position data is assigned a 32-bit value. When sent out in Hexadecimal it will be 8 characters long. When sent out in decimal it will range from 2147483647 to -2147483648. Command Details: Structure IP Type IMMEDIATE Usage READ ONLY Non-Volatile NO Register Access None Units encoder counts (servo) steps (stepper) Examples: Command IP IP Drive sends IP=00002710 IP=FFFFD8F0 Notes Absolute position is 10,000 counts (or steps) Absolute position is -10,000 counts (or steps) If the IF command is set with Parameter #1=D IP IP=10000 Absolute position is 10000 counts (or steps) IP IP=-10000 Absolute position is -10000 counts (or steps) 137 920-0002 Rev. J 12/2014 Host Command Reference IQ - Immediate Current (Actual) Compatibility: Servo drives only Requests present actual current. This current reading is the actual current measured by the drive. As with the Commanded Current this is an RMS value that represents the DC current in the motor windings. Command Details: Structure IQ Type IMMEDIATE Usage READ ONLY Non-Volatile NO Register Access None Units 0.01 Amps Examples: Command IQ IQ Drive sends IQ=015E IQ=FEA2 Notes 3.5 Amps -3.5 Amps If the IF command is set with Parameter #1=D IQ IQ=350 3.5 Amps IQ IQ=-350 -3.5 Amps 920-0002 Rev. J 12/2014 138 Host Command Reference IS - Input Status Compatibility: All drives Requests immediate status of all drive inputs. A closed input is represented by a “0” (zero), and an open input is represented by a “1” (one). Unused positions in the response are represented by “0” (zero). BLu, STAC6 On S and Q drives the IS command requests the status of IN/OUT1 or main driver board (DB-25) inputs X1 through X7 plus the encoder index channel (if present). On SE, QE, and Si drives the ISX command (IS command with parameter character X) is required to request status of IN/OUT1 or main driver board (DB-25) inputs X1 through X7 plus the encoder index channel (if present), while IS requests IN/OUT2 or top board (screw terminal) inputs 1 through 8. SV, ST-Q/Si The IS command requests the status of inputs X1 through X8 plus the encoder index channel (if present). ST-S, STM17-S/Q/C, STM23-Q/C, STM24-C The IS command requests the status of all three digital inputs, STEP, DIR, and EN, plus the encoder index channel (STM only, if present). STM17-C, STM24-C The IS command requests the status of all three digital inputs, IN1, IN2, and IN3, plus the encoder index channel, if present. SSM/TSM/TXM The IS command request the status of all inputs plus the encoder index channel. SS The IS command requests the status of inputs X1 - X8 plus the encoder index channel. M2 The IS command requests the status of inputs X1 - X12 plus the encoder index channel. Command Details: Structure IS{Parameter #1} Type IMMEDIATE Usage READ ONLY Non-Volatile NO Register Access None Parameter Details: BLu, STAC6 Parameter #1 Optional “X” character used to access driver board inputs with SE, QE, and Si drives. SV, ST-Q/Si, ST-S, STM17-S/Q/C, STM23-Q/C, STM24-C Parameter #1 “X” character ignored if used. 139 920-0002 Rev. J 12/2014 Host Command Reference SVAC3, STAC5 Parameter #1 Optional “X” character used to access driver board inputs with Q and IP drives. Response Details: BLu, STAC6 S and Q drives (“X” character is not required to designate main board inputs) SE, QE, and Si drives (“X” character is required to designate main board inputs) SV, ST-Q/Si ST-S, STM17-S/Q/C, STM23-Q/C, STM24-C STEP (IN1) DIR (IN2) EN (IN3) Encoder Index (STM only, if present) SVAC3, STAC5 IS = ISX = IN1 IN2 IN3 IN4 IN5 IN6 IN7 IN8 X1 X2 X3 X4 Encoder Index (if present) 920-0002 Rev. J 12/2014 140 Host Command Reference SSM/TXM-S/Q/IP TSM-P IS = IS = X1 X2 X3 X1 X2 X3 X4 X0 X0 TSM-S/Q/C, SS TXM-C IS = IS = X1 X2 X3 X4 X5 X6 X7 X8 X0 X3 X4 X5 X7 X8 X0 M2 IS = X1 X2 X3 X4 X5 X6 X7 X8 X9 X10 X11 X12 X0 141 920-0002 Rev. J 12/2014 Host Command Reference Examples: BLu and STAC6-S or -Q versions (optional “X” character is not necessary) Command Drive sends Notes IS IS=00000000 All 8 inputs are low (closed) IS IS=11111111 All 8 inputs are high (open) IS IS=11101100 Inputs 1, 2, and 5 are closed IS IS=10000101 Inputs 2, 4, 5, 6, and 7 are closed BLu and STAC6-SE, -QE, or -Si versions (optional “X” character necessary to access IN/OUT1 or main driver board (DB-25) inputs Command Drive sends Notes IS IS=11010011 Inputs 3, 4, and 6 are closed ISX IS=10101110 Inputs X1, X5, and X7 are closed SV, ST-Q/Si Command IS IS Drive sends IS=100110110 IS=011111111 Notes Inputs 1, 4, 7, and 8 are closed Encoder index channel is closed ST-S, STM17-S/Q/C, STM23-Q/C, STM24-C Command Drive Sends Notes IS IS=10000111 All inputs are open IS IS=00000111 Encoder index channel is closed IS IS=10000100 Inputs STEP and DIR are closed SVAC3, STAC5 Command Drive Sends IS IS=10001111 IS IS=10001111 Notes (S drive) No inputs are closed. (Q or IP drive) Inputs IN5 - IN7 are closed. IS IS IS=00000111 IS=00000111 (S drive) Encoder index and input X4 are closed. (Q or IP drive) Inputs IN4 - IN8 are closed. IS IS IS=10101110 IS=10101110 (S drive) Invalid response. (Q or IP drive) Inputs IN1, IN5 and IN7 are closed. ISX IS=10001010 Inputs X1 and X3 are closed. NOTE: When working with digital inputs and outputs it is important to remember the designations low and high. If current is flowing into or out of an input or output, i.e. the circuit is energized, the logic state for that input/output is defined as low or closed. If no current is flowing, i.e. the circuit is de-energized, or the input/output is not connected, the logic state is high or open. A low state is represented by the “L” character in parameters of commands that affect inputs/outputs. For example, WI3L means “wait for input 3 low”, and SO1L means “set output 1 low”. A high state is represented by the “H” character. 920-0002 Rev. J 12/2014 142 Host Command Reference IT - Immediate Temperature Compatibility: All drives Requests drive temperature, as measured by either an on-chip or board-mounted sensor. A parameter of 0 or 1 is used to specify which temperature reading is desired, depending on drive type (see Parameter Details). The temperature reads out in decivolts, or units of 0.1 degrees C. The drive will fault when the temperature reaches a specified maximum value. (See Parameter Details section below for details). If no parameter is supplied, IT0 is assumed. Command Details: Structure IT {Parameter #1} Type IMMEDIATE Usage READ ONLY Non-Volatile NO Register Access “t” (068) Range 0-1 Units 0.1 deg C Parameter Details: BLu, STAC6, STM17 Parameter #1 Optional. IT or IT0 returns the termperature as measured by an external, board-mounted sensor. Overtemp occurs at 85 degrees C. ST Parameter #1 Optional. IT or IT0 returns the termperature as measured by the internal, on-chip sensor. Overtemp occurs at 85 degrees C. SV7 Parameter #1 Optional. IT or IT0 returns the termperature as measured by the internal, on-chip sensor. Overtemp occurs at 100 degrees C. STM23, STM24 Parameter #1 0 = Returns the temperature as measured by the internal, on-chip sensor. 1 = Returns the temperature as measured by an external, board-mounted sensor. Overtemp occurs at 85 degrees C. 143 920-0002 Rev. J 12/2014 Host Command Reference SVAC3, STAC5 Parameter #1 0 = Returns the temperature as measured by an external, board-mounted sensor. Overtemp occurs at 85 degrees C. 1 = Returns the temperature as measured by the internal, on-chip sensor. Overtemp occurs at 100 degrees C. Examples: Command IT IT0 IT1 920-0002 Rev. J 12/2014 Drive sends IT=275 IT=310 IT=412 Notes Drive temperature is 27.5o C Drive temperature is 31.0o C Drive temperature is 41.2o C 144 Host Command Reference IU - Immediate Voltage Compatibility: All drives Requests present value of the DC bus voltage, +/-5%. The voltage reads out in 0.1 volts resolution. The drive will fault when the DC bus voltage reaches a specified maximum value. An Alarm will be set when the DC Bus voltage is less then a minimum value. (See hardware manuals for details). Command Details: Structure IU Type IMMEDIATE Usage READ ONLY Non-Volatile NO Register Access “u” (069) Units 0.1 Volts DC, +/-5% Examples: Command Drive sends Notes If the IF command is set with Parameter #1=H IU IU=01E2 DC supply voltage is 48.2 Volts IU IU=067E DC bus voltage is 166.2 Volts If the IF command is set with Parameter #1=D IU IU=482 DC supply voltage is 48.2 Volts IU IU=1662 DC bus voltage is 166.2 Volts 145 920-0002 Rev. J 12/2014 Host Command Reference IV - Immediate Velocity Compatibility: All drives Requests present velocity of the motor in rpm. There are two different velocities that can be read back: the motor’s actual velocity and the motor’s target velocity. Command Details: Structure IV(Parameter #1) Type IMMEDIATE Usage READ ONLY Non-Volatile NO Register Access “v” (070) Actual velocity (servo drives and stepper drives with encoder) “w” (071) Target velocity Parameter Details: Parameter #1 Velocity selector - units integer - range 0 = actual velocity request (servo drives and stepper drives with encoder) 1 = target velocity request Examples: Command IV0 IV1 920-0002 Rev. J 12/2014 Drive sends IV=1000 IV=1000 Notes Servo motor is running at 1000 rpm Target motor velocity is 1000 rpm 146 Host Command Reference IX - Immediate Position Error Compatibility: Servo drives and stepper drives with encoder feedback Requests present position error between motor and encoder. Command Details: Structure IX Type IMMEDIATE Usage READ ONLY Non-Volatile NO Register Access “x” (072) Units encoder counts Examples: Command IX Drive sends IX=10 Notes Position error is 10 counts 147 920-0002 Rev. J 12/2014 Host Command Reference JA - Jog Acceleration Compatibility: All drives Affects: CJ, WI (jogging) commands See also: CJ, CS, JD, JE, JL, JS, SJ Sets or requests the accel/decel rate for Jog moves in rev/sec/sec. Sending JA with no parameter causes drive to respond with present jog accel/decel rate. Setting JA overwrites the both the last JA and JL values. This means that to have different jog accel and jog decel values, you should first send JA to set the jog accel and then send JL to set the jog decel. The JA value cannot be changed while jogging. Command Details: Structure JA{Parameter #1} Type BUFFERED Usage READ/WRITE Non-Volatile Yes Register Access None Parameter Details: Parameter #1 Jog acceleration value - units rev/sec/sec (rps/s) - range 0.167 to 5461.167 (resolution is 0.167 rps/s) Examples: Command Drive sends JA100 - JA JA=100 920-0002 Rev. J 12/2014 Notes Set jog acceleration to 100 rev/sec/sec 148 Host Command Reference JC - Velocity (Oscillator) mode second speed Compatibility: Stepper drives and SV servo drives Affects: Analog velocity mode See also: AD, AG, CM commands Sets or requests the second speed used in velocity (oscillator) mode. This only applies to Command Modes (CM) 13, 14, 17, and 18. SV, STAC6, ST-Q/Si Input X5 is used to select the speed set by the JC command while in Command Mode 13, 14, 17 or 18. ST-S, STM The EN input is used to select the speed set by the JC command while in Command Mode 13, 14, 17 or 18. Command Details: Structure JC{Parameter #1} Type BUFFERED Usage READ/WRITE Non-Volatile YES Register Access None Parameter Details: Parameter #1 Analog velocity mode second speed - units rev/sec - range BLu, SV, STAC6, ST-Q/Si, ST-S: 0.0042 - 133.3333 (resolution is 0.0042) STM: 0.0042 - 80.0000 (resolution is 0.0042) Examples: Command Drive sends JC11 - JC JC=11 Notes Set second jog speed in analog velocity mode to 11 rps 149 920-0002 Rev. J 12/2014 Host Command Reference JC - 8 Jog Velocities (M2 drives) Compatibility: M2 drives Affects: Control mode 15,16,17,18 See Also: None Sets or requests the speed used in velocity mode. This only applies to control modes 15, 16, 17, and 18. The command has two parameters: the first parameter selects the velocity knee; the second parameter sets the velocity value of the selected velocity knee. Command Details: Structure JC{Parameter #1}{Parameter #2} Type BUFFERED Usage READ/WRITE Non-Volatile YES Register Access NO. Parameter Details: Parameter #1 The velocity knee - units integer number - range 1~8 Parameter #2 Jog velocity - units rps - range 1~136 Examples: Command JC110 JC1 920-0002 Rev. J 12/2014 Drive sends % JC1 =10 Notes Set the first jog velocity to 10rps The first jog velocity is 10rps 150 Host Command Reference JD - Jog Disable Compatibility: All drives Affects: Jogging during a WI command See also: JA, JE, JS, WI commands Disables jog inputs (which are active during a WI instruction if previously enabled by the JE command). Jog accel/decel and velocity are set using the JA and JS commands, respectively. Command Details: Structure JD Type BUFFERED Usage WRITE ONLY Non-Volatile NO Register Access None Examples: Command JD Drive sends - Notes Disable jog inputs while executing the WI command 151 920-0002 Rev. J 12/2014 Host Command Reference JE - Jog Enable Compatibility: All drives Affects: WI (jogging) command See also: JA, JD, JS, WI commands Enables jog inputs during a WI instruction. Jog accel, decel and velocity are set using the JA, JD and JS commands, respectively. BLu, STAC6-S, SE, Q, QE Inputs X1 and X2 are the designated jog inputs during a WI instruction. BLu, STAC6-Si Inputs 5 and 6 of IN/OUT2 or top board (screw terminal) connector are the designated jog inputs during a WI instruction. SV, ST-Q/Si Inputs X5 and X6 are the designated jog inputs during a WI instruction. ST-S, STM The STEP and DIR inputs are the designated jog inputs during a WI instruction. The STEP and DIR inputs can each be assigned to only one function in an application. If you want to use the STEP and DIR inputs as jog inputs you can define them as such with the JE command. JE takes no effect if the drive is set in Command Mode (CM) 7, 11, 12, 13, 14, 15, 16, 17 or 18, because these modes predefine these inputs and take precedence over the JE command. Also, setting the DL command (to 1 or 2) after setting the JE command reassigns the STEP and DIR inputs as end-of-travel limit inputs and turns off jogging functionality. In other words, the JE and DL commands, as well as Command Modes (CM) 7, 11, 12, 13, 14, 15, 16, 17 and 18 each assign a usage to the STEP and DIR inputs. Each of these must exclusively use the STEP and DIR inputs. Command Modes are most dominant and will continually prevent JE and DL from using the inputs. JE and DL exclude each other by overwriting the usage of the STEP and DIR inputs. To enable jogging with the STEP and DIR inputs simply execute the JE command with CM=21 or CM=22. Command Details: Structure JE Type BUFFERED Usage WRITE ONLY Non-Volatile NO Register Access None Examples: Command Drive sends JE - WIX4L - 920-0002 Rev. J 12/2014 Notes Enable jog inputs while executing the WI command Wait for input X4 to close. While waiting jog inputs are active, which means the motor can be jogged in the CW and CCW directions by closing the jog inputs. After input X4 closes the jog function stops, at least until the next WI command executes. 152 Host Command Reference JL - Jog Decel Compatibility: All drives Affects: Jogging during WI command, velocity (oscillator) modes, and CJ command See also: JA command Sets or requests the decel rate for Jog moves and velocity (oscillator) modes in rev/sec/sec. The JL value cannot be changed while jogging. To maintain compatibility with legacy products, JA sets both the JA and JL values, so when a different JL value is required set JA first, then set JL. Command Details: Structure JL{Parameter #1} Type BUFFERED Usage READ/WRITE Non-Volatile YES Register Access None Parameter Details: Parameter #1 Jog deceleration rate - units rev/sec/sec (rps/s) - range 0.167 - 5461.167 rps/s (resolution is 0.167 rps/s) Examples: Command Drive sends JL25 - JL JL=25 Notes Sets jog deceleration rate to 25 rps/s 153 920-0002 Rev. J 12/2014 Host Command Reference JM - Jog Mode Compatibility: All drives*, see below Affects: CJ command, and jogging during a WI command See also: CJ, JE, WI commands Sets or requests the Jog mode. There are two Jog modes available: *Stepper drives only utilize Jog Mode 1 (JM1), and therefore will ignore attempts to set JM2. Jog Mode 1: Servo and stepper drives For servo drives, Jog Mode 1 uses a “position-type” of servo control that moves the target position which causes the servo to move at the set velocity. Jog Mode 1 will cause the servo motor to always move the same distance over time. A drawback is that the servo can fault if the position error during the move exceeds the value set by the PF (Position Fault) command. For stepper drives, Jog Mode 1 causes the step motor to run at the set velocity (see JS and CS commands). Jog Mode 2: Servo drives only For servo drives only, Jog Mode 2 uses a “velocity-type” of servo control that applies torque to the motor to maintain velocity. This method functions better with high inertia loads because it ignores the value set by the PF (Position Fault) command. It also allows the drive to function in a “torque-limited velocity” mode or a “velocitylimited torque” mode. Jog Mode 2 also uses a different set of control parameters, VI and VP, for “tuning” the velocity mode. See VI & VP commands later in this guide. Command Details: Structure JM{Parameter #1} Type BUFFERED Usage READ/WRITE Non-Volatile YES Register Access None Parameter Details: Parameter #1 Jog mode - units integer - range 1 = position-type 2 = velocity-type Examples: Command Drive sends JM1 - JM2 - JM JM=2 920-0002 Rev. J 12/2014 Notes Put drive into position-type servo control when jogging Put drive into velocity-type servo control when jogging 154 Host Command Reference JS - Jog Speed Compatibility: All drives Affects: Jogging during WI command, velocity (oscillator) modes, and CJ command See also: CJ, CS, JA commands Sets or requests the speed for Jog moves in rev/sec. Sending JS with no parameter causes drive to respond with present jog speed. Command Details: Structure JS{Parameter #1} Type BUFFERED Usage READ/WRITE Non-Volatile Yes Register Access “J” (026) Note: The JS command uses different units than the “J” register. See Data Registers section for details. Parameter Details: Parameter #1 Move velocity - units rev/sec - range BLu, SV, STAC6, ST-Q/Si, ST-S: 0.0042 - 133.3333 (resolution is 0.0042) STM: 0.0042 - 80.0000 (resolution is 0.0042) Examples: Command Drive sends JS10.35 - JS JS=10.35 Notes Set jog speed to 10.35 rps 155 920-0002 Rev. J 12/2014 Host Command Reference KC - Overall Servo Filter Compatibility: Servo drives only Affects: Servo tuning and performance Sets or requests the servo control overall filter frequency. The filter is a simple one-pole, low-pass filter intended for attenuating high frequency oscillations. The value is a constant that must be calculated from the desired roll off frequency. See equation below. NOTE: It is recommended to use the Quick Tuner software for tuning and configuring your servo system. C = 72090 / (1400/F + 2.2) where C = Filter Value, F = desired filter Frequency in Hz Command Details: Structure KC{Parameter #1} Type BUFFERED Usage READ/WRITE Non-Volatile Yes Register Access None Parameter Details: Parameter #1 Filter Value - units integer - range 0 - 32767 (see above for calculations) Examples: Command Drive sends KC7836 - KC KC=7836 920-0002 Rev. J 12/2014 Notes Set servo filter to 200 Hz 156 Host Command Reference KD - Differential Constant Compatibility: Servo drives only Affects: Servo tuning and performance Sets or requests the servo control differential gain. Gain value is relative: “0” meaning no gain, “32767” meaning full gain. KD is part of the Damping servo parameters in Quick Tuner. It works to damp low speed oscillations. NOTE: It is recommended to use the Quick Tuner software for tuning and configuring your servo system. Command Details: Structure KD{Parameter #1} Type BUFFERED Usage READ/WRITE Non-Volatile Yes Register Access None Parameter Details: Parameter #1 Differential Gain value - units integer - range 0 - 32767 (0 = 0%, 32767 = 100%) Examples: Command Drive sends KD2000 - KD KD=2000 Notes Set differential gain to 2000 157 920-0002 Rev. J 12/2014 Host Command Reference KE - Differential Filter Compatibility: Servo drives only Affects: Servo tuning and performance Sets or requests the differential control parameter filter frequency. The filter is a simple one-pole, low-pass filter intended for attenuating high frequency oscillations. The value is a constant that must be calculated from the desired roll off frequency. See equation below. C = 72090 / (1400/F + 2.2) where C = Filter Value, K = desired filter Frequency in Hz NOTE: It is recommended to use the Quick Tuner software for tuning and configuring your servo system. Command Details: Structure KE{Parameter #1} Type BUFFERED Usage READ/WRITE Non-Volatile Yes Register Access None Parameter Details: Parameter #1 Filter Value - units integer - range 0 - 32767 Examples: Command KE7836 920-0002 Rev. J 12/2014 Drive sends - Notes Set differential filter to 200 Hz 158 Host Command Reference KF - Velocity Feedforward Constant Compatibility: Servo drives only Affects: Servo tuning and performance Sets or requests the servo control velocity feedforward gain. Gain value is relative: “0” meaning no gain, “32767” meaning full gain. KF is part of the Damping servo parameters in Quick Tuner. It counters the effects of the KV parameter which can cause large following error. KF is usually the same value as KV. NOTE: It is recommended to use the Quick Tuner software for tuning and configuring your servo system. Command Details: Structure KF{Parameter #1} Type BUFFERED Usage READ/WRITE Non-Volatile Yes Register Access None Parameter Details: Parameter #1 Velocity feedforward gain value - units integer - range 0 - 32767 (0 = 0%, 32767 = 100%) Examples: Command Drive sends KF4000 - KF KF=4000 Notes Set velocity feedforward gain to 4000 159 920-0002 Rev. J 12/2014 Host Command Reference KG – Secondary Global Gain Compatibility: M2 drives Affects: Servo tuning and performance Sets or requests the secondary global gain of PID controller. Command Details: Structure KG{Parameter #1} Type BUFFERED Usage READ/WRITE Non-Volatile YES Register Access NO. Parameter Details: Parameter #1 Global gain - units integer number - range 0~32767 Examples: Command KG10000 KG 920-0002 Rev. J 12/2014 Drive sends % KG =10000 Notes Set the secondary global gain to 10000 The secondary global gain is 10000 160 Host Command Reference KI - Integrator Constant Compatibility: Servo drives only Affects: Servo tuning and performance Sets or requests the servo control integrator gain term. Gain value is relative: “0” meaning no gain, “32767” meaning full gain. KI is part of the Stiffness servo parameters in Quick Tuner. It minimizes (or may even eliminate) position errors especially when holding position. NOTE: It is recommended to use the Quick Tuner software for tuning and configuring your servo system. Command Details: Structure KI{Parameter #1} Type BUFFERED Usage READ/WRITE Non-Volatile Yes Register Access None Parameter Details: Parameter #1 Integrator gain value - units integer - range 0 - 32767 (0 = 0%, 32767 = 100%) Examples: Command Drive sends KI5000 - KI KI=500 Notes Set integrator gain to 500 161 920-0002 Rev. J 12/2014 Host Command Reference KJ - Jerk Filter Frequency Compatibility: SV7 Servo drives only Affects: S-Curve Sets or requests the Jerk Filter frequency, in Hz. The parameter is set with in Quick Tuner, and can also be set with the SCL command KJ. The lower the frequency value the more pronounced the S-curve profile will be. Setting the value to 0 will disable the filter. S-curve acceleration/deceleration ramps are beneficial in positioning systems where instantaneous changes in speed may cause the load to jerk excessively. One example is when the load is connected to the motion actuator via a long moment arm. If the arm is not sufficiently rigid, changes in speed at the actuator can result in undesirable oscillations and increased settling time at the load. Smoothed transitions in speed changes, such as those provided by the jerk filter in Quick Tuner, can alleviate this unwanted motion and reduce settling time. NOTE: It is recommended to use the Quick Tuner software for tuning and configuring your servo system. Command Details: Structure KJ{Parameter #1} Type BUFFERED Usage READ/WRITE Non-Volatile Yes Register Access None Parameter Details: Parameter #1 Jerk Filter Frequency (Hz) - units integer - range 0 - 5000 (0 = disabled) Examples: Command Drive sends KJ500 - KJ KJ=500 920-0002 Rev. J 12/2014 Notes Set jerk filter frequency to 500Hz 162 Host Command Reference KK - Inertia Feedforward Constant Compatibility: Servo drives only Affects: Servo tuning and performance Sets or requests the servo control inertia feedforward gain. Gain value is relative: “0” meaning no gain, “32767” meaning full gain. KK is an Inertia servo parameter in Quick Tuner. KK improves acceleration control by compensating for the load inertia. NOTE: It is recommended to use the Quick Tuner software for tuning and configuring your servo system. Command Details: Structure KK{Parameter #1} Type BUFFERED Usage READ/WRITE Non-Volatile Yes Register Access None Parameter Details: Parameter #1 Inertia feedforward gain value - units integer - range 0 - 32767 (0 = 0%, 32767 = 100%) Examples: Command Drive sends KK500 - KK KK=500 Notes Set inertia feedforward gain to 500 163 920-0002 Rev. J 12/2014 Host Command Reference KP - Proportional Constant Compatibility: Servo drives only Affects: Servo tuning and performance Sets or requests the servo control proportional gain term. Gain value is relative: “0” meaning no gain, “32767” meaning full gain. KP is part of the Stiffness servo parameters in Quick Tuner. This parameter is the primary gain term for minimizing the position error. NOTE: It is recommended to use the Quick Tuner software for tuning and configuring your servo system. Command Details: Structure KP{Parameter #1} Type BUFFERED Usage READ/WRITE Non-Volatile Yes Register Access None Parameter Details: Parameter #1 Proportional gain value - units integer - range 0 - 32767 (0 = 0%, 32767 = 100%) Examples: Command Drive sends KP5000 - KP KP=5000 920-0002 Rev. J 12/2014 Notes Set proportional gain to 5000 164 Host Command Reference KV - Velocity Feedback Constant Compatibility: Servo drives only Affects: Servo tuning and performance Sets or requests the servo control velocity feedback gain term. Gain value is relative: “0” meaning no gain, “32767” meaning full gain. KV is part of the Damping servo parameters in Quick Tuner. It aids the KD command in damping system oscillation. This term helps to control larger inertial loads. NOTE: The Velocity Feedback (KV) and Velocity Feedforward (KF) constants are typically set to similar values. The Feedforward value may at times be set larger depending on the frictional content of the motor load. NOTE: It is recommended to use the Quick Tuner software for tuning and configuring your servo system. Command Details: Structure KV{Paramter #1} Type BUFFERED Usage READ/WRITE Non-Volatile Yes Register Access None Parameter Details: Parameter #1 Velocity feedback gain value - units integer - range 0 - 32767 (0 = 0%, 32767 = 100%) Examples: Command Drive sends KV4000 - KV KV=4000 Notes Set velocity feedback gain to 4000 165 920-0002 Rev. J 12/2014 Host Command Reference LA - Lead Angle Max Value Compatibility: Stepper drives (except STM) See also: EF, LS commands Returns the maximum lead angle setting for use in the Stall Prevention algorithm (see EF command for details). This value is reached at the speed set by the LS command. Lead Angle is the angular measurement between the internal magnetic field and the motor’s rotor. If the lead angle is too large, the magnetic attraction fades and the motor will stall. Too small of a value makes inefficient use of the magnetic attraction and the motor will not produce its maximum torque. Lead angle directly affects the magnetic forces acting on the rotor, and is thus directly related to the motor’s torque. An ideal setting for Lead Angle is essential for maximizing the motor’s torque output. During motion, the motor’s lead angle is constantly monitored and adjusted to keep it within a speed-dependent operational range and allow the drive to maintain control of the motor even in the event of a disturbance. The maximum lead angle (set by LA) is reached at the Lead Angle Speed specified by LS. This value is measured in electrical degrees. There are four physical motor steps (4 * 1.8 degrees = 7.2 degrees) per 360 degree electrical cycle. The relationship between electrical degrees and motor rotational displacement is given as follows: 360 electrical degrees / 7.2 rotational degrees 50 electrical degrees / rotational degree Alternatively, in terms of physical displacement, 1 rotational degree / 50 electrical degrees 0.02 rotational degrees / electrical degree The maximum effective setting for LA is 180 electrical degrees. If at any point the motor’s lead angle exceeds this value, a stall condition will occur. NOTE: While it is worthwhile to understand the meaning of the Lead Angle setting, it is intended that the ST Configurator software be used to configure this setting. Command Details: Structure LA{Parameter #1} Type BUFFERED Usage READ / WRITE Non-Volatile YES Register Access None Parameter Details: Parameter #1 Lead Angle Value - units integer - range 1 - 180 electrical degrees 920-0002 Rev. J 12/2014 166 Host Command Reference Examples: Command Drive sends LA120 - LA LA=120 Notes Set the target lead angle setting to 120 electrical degrees (default, optimal for most motors) 167 920-0002 Rev. J 12/2014 Host Command Reference LM - Software Limit CCW Compatibility: SSM, TSM, TXM, SS, SSAC and M2 drives See also: SP and AM commands Sets or requests software CCW limit values. Motor decelerates to stop when the absolute position (can be requested or set by SP command) decreases to software CCW limit value, Software limit does not work in CCW direction when software CCW limit parameter is set to zero. This parameter is volatile and the default value is zero when power-up. Command Details: Structure LM{Parameter #1} Type BUFFERED Usage READ/WRITE Non-Volatile NO Register Access NO. Parameter Details: Parameter #1 Software Limit Value - units Absolute position - range +/- 2,147,483,647 Examples: Command LM10000 LM LM0 920-0002 Rev. J 12/2014 Drive sends % LM =10000 % Notes Set software CCW limit value to 10000 counts. Request software CCW limit value. Turn off software limit function in CCW direction. 168 Host Command Reference LP - Software Limit CW Compatibility: SSM, TSM, TXM, SS, SSAC and M2 drives See also: SP and AM commands Sets or requests software CW limit values. Motor decelerates to stop when the absolute position (can be requested or set by SP command) increases to software CW limit value. Software limit does not work in CW direction when software CW limit parameter is set to zero. This parameter is volatile and the default value is zero when power-up. Command Details: Structure LP{Parameter #1} Type BUFFERED Usage READ/WRITE Non-Volatile NO Register Access NO. Parameter Details: Parameter #1 Software Limit Value - units Absolute position - range +/- 2,147,483,647 Examples: Command LP10000 LP LP0 Drive sends % LP =10000 % Notes Set software CW limit value to 10000 counts. Request software CW limit value. Turn off software limit function in CW direction 169 920-0002 Rev. J 12/2014 Host Command Reference LS - Lead Angle Speed Compatibility: Stepper drives (except STM) See also: EF, LA commands Specifies the speed at which the Lead Angle specified by the LA command will be applied. (See LA command for a detailed description of the Lead Angle concept.) During operation, the lead angle is continuously monitored and is dynamically adjusted to maintain maximum torque output. The optimal setting is dependent upon motor speed, with the maximum setting occurring at the speed specified by LS. NOTE: While it is worthwhile to understand the meaning of the Lead Angle Speed setting, it is intended that the ST Configurator software be used to configure this setting. Command Details: Structure LS{Parameter #1} Type BUFFERED Usage READ / WRITE Non-Volatile YES Register Access None Parameter Details: Parameter #1 Lead Angle Speed - units integer - range 1 - 80 rev/sec Examples: Command Drive sends Notes LS25 - Use maximum lead angle setting (LA) at 25 rps LS LS=25 920-0002 Rev. J 12/2014 170 Host Command Reference LV - Low Voltage threshold Compatibility: All drives Affects: Under voltage alarm and fault Sets or requests the low voltage threshold for under voltage alarm / fault conditions. In AC drives (e.g. BLuAC5 and STAC6) an under voltage condition causes a Drive Fault, which disables the motor outputs of the drive. In DC drives (SV, ST, and STM) an under voltage condition causes an Alarm. If desired, the user can change the low voltage threshold of the drive, however in most applications it is neither necessary nor recommended. The factory default for low voltage threshold is set to both protect the drive from damage and work with the widest range of supply voltages possible. Command Details: Structure LV{Parameter #1} Type BUFFERED Usage READ/WRITE Non-Volatile Yes Register Access None Parameter Details: Parameter #1 Low voltage threshold - units All drives except BLuAC5: 0.1 volts DC BLuAC5: 1 volt DC - range BLuDC: 18 to 40 BLuAC: 90 to 300 STAC6: 90 to 160 ST5: 12 to 75 ST10: 12 to 75 SV7: 12 to 75 STM: 10 to 75 Examples: Command LV LV200 Drive sends LV=180 - Notes Low voltage threshold of ST5 set at 18 VDC Set low voltage threshold of ST5 drive to 20 VDC LV LV=900 Low voltage threshold of STAC6 set at 90 VDC (bus voltage) LV LV=90 Low voltage threshold of BLuAC5 set at 90 VDC (bus voltage) 171 920-0002 Rev. J 12/2014 Host Command Reference MC - Motor Current, Rated Compatibility: Stepper drives (except STM) See also: CC, PN commands Specifies the maximum current that can be sent to the motor. This is the same value set in ST Configurator’s Custom Motor screen for Rated Current. This value serves as the upper ceiling for the CC command, preventing excessive current from being sent to the motor, potentially damaging it. It is also used when the motor is probed to determine its electrical characteristics (see PN command for details). Command Details: Structure MC{Parameter #1} Type BUFFERED Usage READ / WRITE Non-Volatile YES Register Access None Parameter Details: Parameter #1 Motor Rated Current - units amps - range 0 - 6.00 amps (STAC6 only) 0 - 10.00 amps (ST-S, ST-Q/Si) Examples: Command Drive sends Notes MC2.5 - Motor maximum current set to 2.5A. MC MC=2.5 920-0002 Rev. J 12/2014 172 Host Command Reference MD - Motor Disable Compatibility: All drives See also: BE, BO, ME commands Disables motor outputs (reduces motor current to zero). Disabling the motor also activates the Brake Output function (see BO command). Motor current is not reduced to zero until the Brake Engage (BE command) time has expired. Command Details: Structure MD Type BUFFERED Usage WRITE ONLY Non-Volatile No Register Access None Examples: Command MD Drive sends - Notes Drive turns off current to the motor 173 920-0002 Rev. J 12/2014 Host Command Reference ME - Motor Enable Compatibility: All drives See also: BD, BO, MD commands Restores drive current to motor. If the drive cannot be enabled due to the Enable Input (SI) state, the drive will respond with a “&” which indicates that the drive could not be enabled. Enabling the drive also deactivates the Brake Output function (see BO command). Enabling of the motor is delayed by the BD (Brake Disengage) time delay. WARNING: This command restores the previous mode of operation. If for example the drive is operating in Analog Velocity mode the motor may immediately start moving. External inputs to the drive must be sequenced properly to avoid unpredictable operation. Command Details: Structure ME Type BUFFERED Usage WRITE ONLY Non-Volatile NO Register Access None Examples: Command ME ME 920-0002 Rev. J 12/2014 Drive sends - & Notes Drive is enabled Drive is NOT enabled: check Servo Enable input (SI) for proper state 174 Host Command Reference MN - Model Number Compatibility: All drives NOTE: This command is deprecated. Please use MV to query the drive for model and revision information. Requests the drive’s Model Number. Drive returns a single character that is a code for the model number. Unlike most other commands that request data back from the drive, where the drive will send the original Command Code followed by an “=” and then a value, when the MN command is sent to a drive the drive only responds with the single character code. (See below). Command Details: Structure MN Type IMMEDIATE Usage READ ONLY Non-Volatile NO Register Access None Units character code (see below) Response Details: Model Number Character code BLuDC4-S* O BLuDC4-SE* o BLuDC4-Si* P BLuDC4-Q* W BLuDC4-QE* w BLuDC9-S* R BLuDC9-SE* r BLuDC9-Si* S BLuDC9-Q* X BLuDC9-QE* x BLuAC5-S T BLuAC5-SE t BLuAC5-Q U BLuAC5-QE u BLuAC5-Si V STAC6-S Y STAC6-SE y STAC6-Q Z STAC6-QE z STAC6-Si [ Model Number Character Code STAC6-220-S \ STAC6-220-SE | STAC6-220-Q ] STAC6-220-QE } STAC6-220-Si ^ ST5-S D ST10-S E ST5-Plus J ST10-Plus K ST5-Q F ST10-Q H ST5-Si G ST10-Si I STM23S-xxx a STM23Q-xxx b SV7-S ; SV7-Q < SV7-Si = * BLu100 and BLu200 series drives have been replaced by BLuDC4 and BLuDC9 series drives, respectively. BLu100 and BLu200 drives are still supported, but part numbers have been changed. Examples: Command MN Drive sends T Notes Connected drive is a BLuAC5-S 175 920-0002 Rev. J 12/2014 Host Command Reference MO - Motion Output Compatibility: All drives See also: AO, BO, PL, SD commands Defines the drive’s Motion Output digital output function. For all stepper drives there are 8 states available: MO1: Output is closed (energized) when motor is not moving. MO2: Output is open (de-energized) when motor is not moving. MO3: Output is not used as a Motion Output and can be used for another automatic output function or as a general purpose output. MO4: Output is used as a Tach Output at 100 pulses/rev with 1.8 degree step motor. MO5: Output is used as a Tach Output at 200 pulses/rev with 1.8 degree step motor. MO6: Output is used as a Tach Output at 400 pulses/rev with 1.8 degree step motor. MO7: Output is used as a Tach Output at 800 pulses/rev with 1.8 degree step motor. MO8: Output is used as a Tach Output at 1600 pulses/rev with 1.8 degree step motor. For SV servo drives there are 10 states available: MO1: Output is closed (energized) when motor is not moving. MO2: Output is open (de-energized) when motor is not moving. MO3: Output is not used as a Motion Output and can be used for another automatic output function or as a general purpose output. MO4: Output is used as a Tach Output at 64 pulses/rev with 8 pole motor (8 times number of poles) MO5: Output is used as a Tach Output at 128 pulses/rev with 8 pole motor (16 times number of poles) MO6: Output is used as a Tach Output at 256 pulses/rev with 8 pole motor (32 times number of poles) MO7: Output is used as a Tach Output at 512 pulses/rev with 8 pole motor (64 times number of poles) MO8: Output is used as a Tach Output at 1024 pulses/rev with 8 pole motor (128 times number of poles) MO9: Output is closed when in position based on encoder error MO10: Output is open when in position based on encoder error For SSM and TXM-S/Q/IP there are 11 states available: MO1: Output is open (de-energized) when static position error is less than set value. MO2: Output is closed (energized) when static position error is less than set value. MO3: Output is not used as a Motion Output and can be used for another automatic output function or as a general purpose output. MO4: Output is used as a Tach Output at 100 pulses/rev. MO5: Output is used as a Tach Output at 200 pulses/rev. MO6: Output is used as a Tach Output at 400 pulses/rev. MO7: Output is used as a Tach Output at 800 pulses/rev. MO8: Output is used as a Tach Output at 1600 pulses/rev. MO9: Output is closed (energized) when dynamic position error is less than set value. MO10: Output is open (de-energized) when dynamic position error is less than set value. MO11: Output is used as a Tach Output at 50 pulses/rev. For TSM there are 3 states available: MO3: Output is not used as a Motion Output and can be used for another automatic output function or as a general purpose output. MO9: Output is closed (energized) when dynamic position error is less than set value. MO10: Output is open (de-energized) when dynamic position error is less than set value. NOTE: for other Motion Output setting for TSM, please refer to TO command 920-0002 Rev. J 12/2014 176 Host Command Reference BLu, SV, STAC6, ST-Q/Si, STAC5-Q/IP, SVAC3-Q/IP Output Y2 is the designated Motion Output. ST-S, STM17-S/Q/C, STM23-Q/C, STM24-C The one output of these drives (OUT) can be assigned to one of the five available functions: alarm output, brake output, motion output, tach output, or general purpose output. Each of these functions must exclusively use the output, so only one function is allowed. There are two ways to define the function of this output: via the ST Configurator software or via the MO command. STM24-SF/QF Drives with Flex I/O allow a second parameter which allows the user to specify the I/O point used. Before an I/O point can be used as a Motion Output it must first be configured as an output with the SD command. Possible uses for the MO command on the STM24 are as follows (‘n’ denotes the I/O point to be used): MO1n: Output is closed (active, low) when a Drive Fault is present. MO2n: Output is open (inactive, high) when a Drive Fault is present. MO3n: Output is not used as an Alarm Output and can be used for another automatic output function or as a general purpose output. MO4n: Output is used as a Tach Output at 100 pulses/rev with 1.8 degree step motor. MO5n: Output is used as a Tach Output at 200 pulses/rev with 1.8 degree step motor. MO6n: Output is used as a Tach Output at 400 pulses/rev with 1.8 degree step motor. MO7n: Output is used as a Tach Output at 800 pulses/rev with 1.8 degree step motor. MO8n: Output is used as a Tach Output at 1600 pulses/rev with 1.8 degree step motor. NOTE: Setting the MO command to 1, 2, or 4 - 8 overrides previous assignments of this output’s function. Similarly, if you use the AO or BO command to set the function of the output after setting the MO command to 1 or 2, usage of the output will be reassigned and AO will be automatically set to 3. Command Details: Structure MO{Parameter #1}{Parameter #2 (Flex I/O only)} Type BUFFERED Usage READ/WRITE Non-Volatile YES Register Access None Parameter Details: Parameter #1 Output Usage (see above) - units integer code - range 1, 2 or 3 Parameter #2 (Flex I/O only) I/O Point (if applicable, see note below) - units integer code - range 1-4 NOTES: • The SD command must be executed to set an I/O point as an output before that output can be designated as the Motion Output. • Parameter #2 only applies to drives equipped with Flex I/O. This includes the STM24-S and -Q. Parameter #2 is not defined for drives equipped with standard I/O. 177 920-0002 Rev. J 12/2014 Host Command Reference Examples: All drives with standard I/O: Command Drive sends MO1 - MO MO=1 Notes Motion Output will close when the motor is not moing Drives with Flex I/O only: Command Drive sends SD4O - MO14 - MO MO=14 Notes Configures I/O 4 as output (see SD command for details) Motion Output is mapped to output #4, and will close when the motor is not moving STM24-S, -Q only Command Drive sends MO14 - MO MO=14 Notes I/O point 4 will be closed when motor is not moving NOTE: When working with digital inputs and outputs it is important to remember the designations low and high. If current is flowing into or out of an input or output, i.e. the circuit is energized, the logic state for that input/output is defined as low or closed. If no current is flowing, i.e. the circuit is de-energized, or the input/output is not connected, the logic state is high or open. A low state is represented by the “L” character in parameters of commands that affect inputs/outputs. For example, WI3L means “wait for input 3 low”, and SO1L means “set output 1 low”. A high state is represented by the “H” character. 920-0002 Rev. J 12/2014 178 Host Command Reference MR - Microstep Resolution Compatibility: All Stepper Drives Affects: Microstep Resolution See also: EG command The MR command allows the user to set or request the Microstep Resolution of the drive. NOTE: The MR command has been deprecated, and should no longer be used. It is included here solely for compatibility with older programs. New applications should make use of the EG command. Command Details: Structure MR{Parameter #1} Type BUFFERED Usage READ/WRITE Non-Volatile YES Register Access None Parameter Details: Parameter #1 Microstep Resolution (code) - units Integer - range 0 - 15: Code, steps/rev 0 = 200 1 = 400 3 = 2000 4 = 5000 5 = 10,000 6 = 12,800 7 = 18,000 8 = 20,000 9 = 21,600 10 = 25,000 11 = 25,400 12 = 25,600 13 = 36,000 14 = 50,000 15 = 50,800 Examples: Command Drive sends MR8 - MR MR=8 Notes Set the drive’s microstep resolution to 20,000 steps/rev 179 920-0002 Rev. J 12/2014 Host Command Reference MT - Multi-Tasking Compatibility: Q drives only Affects: All move commands See also: CJ, OI, QJ, TI, TR, and WM commands Sets or request the status of the multi-tasking function (on or off). When multi-tasking is enabled (on), commands such as FL (Feed to Length) or HW (Hand Wheel) do not block execution of subsequent commands in the queue or program segment. This allows executing other type of operations, such as setting outputs (SO), while a move is taking place. Command Details: Structure MT{Parameter #1} Type BUFFERED Usage READ/WRITE Non-Volatile No Register Access None Parameter Details: Parameter #1 Multi-tasking switch - units integer - range 0 = multi-tasking disabled 1 = multi-tasking enabled Examples: Command Drive sends MT1 - MT MT=1 920-0002 Rev. J 12/2014 Notes Enables multi-tasking 180 Host Command Reference MS - Control Mode Selection Compatibility: M2 drives Affects: Control mode, Input #8 See also: CM, CN commands Define the usage of input X8 for control mode selecting. MS1: CM is selected when input X8 is open, and CN is selected when input X8 is closed. MS2: CM is selected when input X8 is closed, and CN is selected when input X8 is open. MS3: Input X8 is used as general purpose input. Drive control mode is main mode. Command Details: Structure MS{Parameter #1} Type BUFFERED Usage READ/WRITE Non-Volatile YES Register Access None Parameter Details: Parameter #1 Control Mode Selection(see above) - units integer code - range 1~3 Default value: 3 Examples: Command MS1 MS Drive sends % MS=1 Notes set the usage of control mode selection to 1 the usage of control mode selection is 1 181 920-0002 Rev. J 12/2014 Host Command Reference MV - Model & Revision Compatibility: All drives except BLu servo drives See also: MN, RV commands Requests the connected drive’s DSP firmware version, model number code, and sub-model number code (if applicable). Not all drive series utilize the sub-model number code. The response from the drive is a single string of characters with no breaks or delimiters. The sequence of characters is firmware revision (3 numbers and 1 letter), model number code (3 numbers), sub-model number code (1 letter). See Response Details below. Command Details: Structure MV Type IMMEDIATE Usage READ ONLY Non-Volatile No Register Access None Response Details: Response will be in the format AAAABBBC, where AAAA is the firmware version, BBB is the model number code, and C is the sub-model number code. Model and sub-model number codes are listed below by drive, and Examples are given afterward. Drive Firmware Model No. Code SV7-S * 011 SV7-Q * 012 SV7-Si * 013 STAC6-S * 041 STAC6-Q * 042 STAC6-Si * 043 STAC6-220-S * 044 STAC6-220-Q * 045 STAC6-220-Si * 046 STAC6-C * 047 STAC6-220-C * 048 ST5-S * 020 ST5-Q * 022 ST5-Si * 023 ST5-Plus * 026 ST10-S * 021 ST10-Q * 024 ST10-Si * 025 ST10-Plus * 027 STM23S-2AN * 049 STM23S-2AE * 049 STM23S-2RN * 049 STM23S-2RE * 049 STM23S-3AN * 049 STM23S-3AE * 049 STM23S-3RN * 049 STM23S-3RE * 049 STM23Q-2AN * 050 STM23Q-2AE * 050 920-0002 Rev. J 12/2014 182 Sub-Model No. Code A E C G B F D H A E Host Command Reference STM23Q-2RN * STM23Q-2RE * STM23Q-3AN * STM23Q-3AE * STM23Q-3RN * STM23Q-3RE * 050 050 050 050 050 050 C G B F D H * See example below for format of firmware version. - Denotes no sub-model number code is used for this drive. Examples: Command Drive sends MV 100Q012 Notes Drive connected has DSP firmware version 1.00Q, and the drive model number is SV7-Q MV 103F042 Drive connected has DSP firmware version 1.03F, and the drive model number is STAC6-Q MV 102J049A Drive connected has DSP firmware version 1.03F, and the drive model number is STM23S-2AN 183 920-0002 Rev. J 12/2014 Host Command Reference NO - No Operation Compatibility: Q drives only Affects: Stored program flow Q programs halt execution at blank lines. If a “no op” line is required in a program, for comments or other purposes, rather than leave the line blank the NO command is used. Think of the NO command as leaving a blank line in the middle of a sequence of commands. This is useful if after creating a sequence of commands you would like to delete a command without the line numbers of the remaining commands changing. Instead of deleting the line with the unwanted command, replace the unwanted command with a NO command and the remaining commands in the sequence will maintain their respective line numbers. NOTE: NO commands are not required after the last command in a segment. Command Details: Structure NO Type BUFFERED Usage WRITE ONLY Non-Volatile NO Register Access None Examples: Command NO 920-0002 Rev. J 12/2014 Drive sends - Notes No operation takes place at this program line 184 Host Command Reference OF - On Fault Compatibility: Q drives only Affects: Stored program flow See also: AL, AX, AX, ME, OI commands When a drive fault occurs, the OF command causes a given program segment to immediately load from nonvolatile memory into the queue. The OF command acts as a kind of software switch in that when this function is turned on the drive’s response to a drive fault (loading the designated program segment) is automatic. Once a fault occurs the fault must be cleared (AX) and the motor re-enabled (ME) before continuing normal program execution. Please note that while immediately executing AX will clear the alarm code, it does not guarantee that the condition that caused the alarm has been resolved. Therefore it is recommended to include a short delay or wait for user input before clearing the alarm and resuming normal operation. Also, a drive fault will turn the OF function off, so after a fault the OF command must be executed again to reset the function. For this reason it is common to place the OF command in segment 1 of a Q program, and then load segment 1 (QX1) from the designated OF segment after the fault has been cleared and the motor re-enabled. A parameter value of “0” disables the On Fault function. See the AL (Alarm code) command for details of drive faults. Command Details: Structure OF(Parameter #1) Type BUFFERED Usage WRITE ONLY Non-Volatile No Register Access None Parameter Details: Parameter #1 program segment # - units integer - range 1 - 12 = segment 1 - 12 0 = disable On Fault function Examples: Command Drive sends In segment 1 of a Q program... OF9 - Notes When a drive fault occurs load and execute program segment 9 In segment 9 of the same Q program... WT0.1 - AX - ME - QX1 - Short delay to allow the system to settle Alarm reset Motor enable Load and execute segment 1, which will also reset the OF function. OF0 Disable the On Fault function - 185 920-0002 Rev. J 12/2014 Host Command Reference OI - On Input Compatibility: Q drives only Affects: Interrupt function and stored program flow See also: MT, OF command When the given input condition is met the OI command causes program segment 10 to immediately load from non-volatile memory into the queue. The OI command operates as a kind of software switch. Executing the command turns the interrupt function on. Responding to the interrupt input (by loading segment 10) turns the interrupt function off. Therefore after an interrupt condition is cleared in the system the OI command must be executed again to reset the interrupt function. One way to do this is place a copy of the OI command near the end of segment 10, before loading and executing another segment (QX command). Only one interrupt input can be defined at a time within a program. Executing the OI command with no parameter disables the interrupt function. If Multi-Tasking is disabled (MT0, default) when the input condition is met, any move in progress will be aborted and Segment 10 will be loaded immediately. If Multi-Tasking is enabled (MT1) when the input condition is met, the program will branch to Segment 10 without interrupting a move in progress. In this scenario a Stop Move (SM) command may be used to abort the move. Command Details: Structure OI{Parameter #1} Type BUFFERED Usage WRITE ONLY Non-Volatile No Register Access None Parameter Details: (See Appendix F: Working With Inputs and Outputs) Examples: Command Drive sends MT0 - OIX5F - Notes Turn Multi-Tasking off Load and execute program segment 10 when input X5 goes from high to low. If a move is in progress, abort it. MT1 - Turn Multi-Tasking on OIX5F - Load and execute program segment 10 when input X5 goes from high to low. Has no effect on a move already in progress. OI 920-0002 Rev. J 12/2014 - Disable interrupt function 186 Host Command Reference OP - Option board Compatibility: All drives See also: IF, MV commands Requests the decimal or hexadecimal equivalent (see IF command) of the option board’s 7-bit binary word. Since some drives - like the SV, ST-Q/Si, and STM drives - are available with different option boards, it is useful for the host to be able to request this information from the drive. The 7 bits in the option board’s binary word are shown below. Bit Value (Hex) SV7 SVAC3 ST STAC5 0 1 Encoder Board Encoder Board Encoder Board Encoder Board 1 2 RS-485 reserved RS-485 reserved 2 4 CANOpen reserved CANOpen reserved 3 8 reserved reserved reserved reserved 4 10 reserved reserved reserved reserved 5 20 MCF Board * reserved MCF Board * Expanded I/O 6 40 Ethernet Ethernet Ethernet 0 7 80 reserved Expanded I/O reserved reserved * This board includes encoder output so drives with this option will also have bit 0 set Command Details: Structure OP Type IMMEDIATE Usage READ ONLY Non-Volatile Yes Register Access None Examples: IF command set for decimal (IFD)... Command Drive sends OP OP3 OP OP4 OP OP33 Notes Drive has both encoder and RS-485 option boards installed Drive has CANOpen board installed Drive has MCF board installed (bits 0 and 5 are set) IF command set for hexadecimal (IFH)... Command Drive sends Notes OP OP0003 Drive has both encoder and RS-485 option boards installed OP OP0004 Drive has CANOpen board installed OP OP0021 Drive has MCF board installed 187 920-0002 Rev. J 12/2014 Host Command Reference PA - Power-up Acceleration Current Compatibility: STM Integrated Step Motors Affects: Motor accel/decel current and torque See also: PC, CC, CA, SA commands Sets or requests the power-up accel/decel current setting (“peak of sine”) of the stepper drive, also known as the peak current. PA is similar to the CA command in that a change to PA affects the current value of the accel/ decel current. However PA differs from CA in that a change to PA is automatically written to non-volatile memory at the time of the change. For a change in CA to be written to non-volatile memory an SA command must be executed afterwards. See below for more details. PA will only accept parameter values equal or larger than the current PC setting. Relationship of PA, CA, and “M” register: • A change to PA affects the current accel/decel current value and is automatically stored in non-volatile memory. • A change to PA automatically changes CA and the “M” register to the same value. • A change to CA or the “M” register only affects the current accel/decel current value, but does not automatically change PA to the same value. • A change to CA or the “M” register is stored in non-volatile memory only after an SA command is executed. When this occurs the PA command is also automatically changed to the new value. NOTE: PA has no effect in Command Mode 7 (CM7 - Step and Direction mode). Command Details: Structure PA{Parameter #1} Type BUFFERED Usage READ/WRITE Non-Volatile Yes (see note below) Register Access “M” (029) Note: The PA and CA commands use different units than the “M” register; see Data Registers section for details Parameter Details: Parameter #1 Power-up accel/decel current - units Amps (resolution is 0.01 amps) - range STM24: 0-6.0 STM23: 0-5.0 STM17: 0-2.0 Configurator software may also be used to set all current levels. NOTE: This data is saved to non-volatile memory immediately upon execution. It is not required to execute the SA command to save to non-volatile memory. 920-0002 Rev. J 12/2014 188 Host Command Reference Example: STM17, STM23, STM24 Command Drive sends PA1.2 - PA PA=1.2 Notes Set power-up accel/decel current to 1.2 amps (peak of sine) 189 920-0002 Rev. J 12/2014 Host Command Reference PB - Power-up Baud Rate Compatibility: All drives See also: BR, PR, TD commands Sets or requests the power-up baud rate for serial communications. When executed, this command sets the baud rate and immediately saves it to non-volatile memory. At power-up the drive defaults to 9600 baud. If an MOONS’ software application is not detected after 1 second and the drive is configured for host operation the drive will set the baud rate according to the value stored in the Power-up Baud Rate non-volatile parameter. A host system can change the baud rate at any time. NOTE: Setting the baud rate takes effect immediately. Command Details: Structure PB{Parameter #1} Type BUFFERED Usage READ/WRITE Non-Volatile Yes (see note below) Register Access None Parameter Details: Parameter #1 Baud rate code - units integer code - range 1 = 9600 2 = 19200 3 = 38400 4 = 57600 5 = 115200 NOTE: This data is saved to non-volatile memory immediately upon execution. It is not required to execute the SA command to save to non-volatile memory. Examples: Command Drive sends Notes PB2 - Power-up baud rate is set to 19200 and this value is immediately saved to non-volatile memory PB PB=2 920-0002 Rev. J 12/2014 190 Host Command Reference PC - Power-up Current Compatibility: All drives Affects: Motor current and torque See also: CC, PI, PP commands If using a stepper drive, PC sets or requests the continuous (RMS) current setting of the servo drive. If using a servo drive, PC sets or requests the current setting (“peak of sine”) of the stepper drive, also known as the running current. NOTE: This command is similar to CC. It differs only in that in addition to setting the continuous current of the drive, PC also immediately saves the setting to NV memory. See CC command for further details. Command Details: Structure PC{Parameter #1} Type BUFFERED Usage READ/WRITE Non-Volatile Yes (see note below) Register Access “N” (030) Note: The PC and CC commands use different units than the “N” register; see Data Registers section for details Parameter Details: BLu, SV, SVAC3 Parameter #1 Power-up continuous current setting - units amps rms (resolution is 0.01 amps) - range BLuDC4: 0 - 4.5 BLuDC9: 0 - 9.0 BLuAC5: 0 - 5.0 SV: 0 - 7.0 SVAC3 (120V): 0 - 3.5 SVAC3 (220V): 0 - 1.8 STAC6, ST-Q/Si, ST-S, STM, STAC5 Parameter #1 Running current - units amps (resolution is 0.01 amps) - range STAC6: 0 - 6.0 ST5 : 0 - 5.0 ST10: 0 - 10.0 STM17: 0 - 2.0 STM23: 0 - 5.0 STM24: 0 - 6.0 STAC5 (120V): 0 - 5 STAC5 (220V): 0 - 2.55 NOTE: MOONS’ recommends using Configurator software to select a motor and set the maximum current. Examples: Command Drive sends PC3.2 - PC PC=3.2 Notes Set power-up continuous current to 3.2 amps RMS for servo drive or 3.2 amps running current for stepper drive 191 920-0002 Rev. J 12/2014 Host Command Reference PD - In-Position Counts Compatibility: SSM, TSM, TXM, SS, SSAC and M2 drives See also: MO, TO, PE commands This parameter is used to set static in-position error range. For example, motor is in-position or in completion of rotating. The actual finish position is in the target In-position error range for the time that is longer than PE specified timing. Then the driver will define the motion complete or motor is in-position. Command Details: Structure PD{Parameter #1} Type BUFFERED Usage READ/WRITE Non-Volatile YES Register Access None Parameter Details: Parameter #1 In-position limit - units encoder counts - range 0~32767 -default Examples: Command Drive sends PD100 - PD PD=100 Notes Sets the static in-position limit to 100 encoder counts PD Target Position Actual Position PE TT In Motion In Position 920-0002 Rev. J 12/2014 192 Host Command Reference PE - In-Position Timing Compatibility: SSM, TSM, TXM, SS, SSAC and M2 drives See also: MO, TO, PD commands Sets or requests the timing counts for in range determination. For example, if In position error PD is defined. PE will set the time duration for in-position test condition. If it is always in-position within the time duration, driver will define motor as in-position. Time is counted as processor cycles, one cycle refers to 200µsec (250µsec for M2). Command Details: Structure PE{Parameter #1} Type BUFFERED Usage READ/WRITE Non-Volatile YES Register Access None Parameter Details: Parameter #1 In-position Timing - units 200µsec, (250µsec for M2) - range 0~30000 -default 10 Examples: Command Drive sends PE100 - PE PE=100 Notes Sets the static in-position timing to 20ms for in range determination. PD Target Position Actual Position PE TT In Motion In Position 193 920-0002 Rev. J 12/2014 Host Command Reference PF - Position Fault Compatibility: Servo drives and stepper drives with encoder feedback Servo drives Sets or requests the Position Fault limit in encoder counts. This value defines the limit threshold, in encoder counts, reached between actual position and commanded position before the system produces a position fault error. Stepper drives: Sets or requests the “percentage of torque” used in the Stall Prevention function for systems with an encoder installed on the motor. Making this setting with the PF command requires that an SA (Save) command be sent afterwards, then a power-down/power-up cycle before the change will take effect. It is recommended that the Configurator software be used to make this setting. Command Details: Structure PF{Parameter #1} Type BUFFERED Usage READ/WRITE Non-Volatile Yes Register Access None Parameter Details: Parameter #1 Servo: Position fault limit Stepper: Percentage of torque - units Servo: encoder counts Stepper: percentage of torque - range Servo: 1 - 32767 Stepper: 0 - 100 (percent) Examples: Command Drive sends PF2000 - PF PF=2000 Notes Set position fault limit to 2000 counts in servo drive PF50 - Set percentage of torque to 50% in stepper drive fitted with encoder and with the Stall Prevention function turned on PF PF=50 920-0002 Rev. J 12/2014 194 Host Command Reference PH - Inhibition Of The Pulse Command Compatibility: M2 drives Affects: Control mode 7, Input #10 See also: None Define the usage of input X10 as inhibiting the pulse input as position command. PH1: Inhibit the pulse input as position command when input X10 is closed. PH2: Inhibit the pulse input as position command when input X10 is open. PH3: Input X10 is used as general purpose input. Command Details: Structure PH{Parameter #1} Type BUFFERED Usage READ/WRITE Non-Volatile YES Register Access None Parameter Details: Parameter #1 Inhibition the pulse command - units Integer - range 1~3 -default value 3 Examples: Command PH1 PH Drive sends % PH=1 Notes Sets the usage of the inhibition of the pulse command to 1 The usage of the inhibition of the pulse command is 1 195 920-0002 Rev. J 12/2014 Host Command Reference PI - Power-up Idle Current Compatibility: Stepper drives only Affects: Motor current at standstill, holding torque See also: CC, CD, CI commands Idle current is the level of current supplied to each motor phase when the motor is not moving. Using an idle current level lower than the running motor current (see CC and PC commands) aids in motor cooling. A common level used for the idle current setting is 50% of the running current. After a motor move, there is a time delay after the motor takes its last step before the reduction to the idle current takes place. This delay is set by the CD command. This command is similar to the CI command. It differs only in that in addition to setting the idle current of the drive, PI also immediately saves the setting to NV memory. See CI command page for details. Command Details: Structure PI{Parameter #1} Type BUFFERED Usage READ/WRITE Non-Volatile Yes (see note below) Register Access “O” (031) Note: The CI command uses different units than the “O” register; see Data Registers section for more details Parameter Details: STAC6 Parameter #1 Idle current at power-up - units amps - range 0 - 100% of running current ST-Q/Si, ST-S, STM, STAC5 Parameter #1 Idle current at power-up - units amps - range 0 - 90% of running current NOTE: This data is saved to non-volatile memory immediately upon execution. It is not required to execute the SA command to save to non-volatile memory. Examples: Command Drive sends PI0.75 - PI PI=0.75 920-0002 Rev. J 12/2014 Notes Set power-up idle current to 0.75 amps 196 Host Command Reference PK - Parameter Lock Compatibility: M2 drives Affects: Keyboards operation See also: None This parameter determines whether the parameters of the driver can be modified directly through the push bottoms on the driver. 0 = can be modified 1 = can not be modified through the keyboard Command Details: Structure PK{Parameter #1} Type BUFFERED Usage READ/WRITE Non-Volatile YES Register Access None Parameter Details: Parameter #1 See above - units Integer - range 0~1 -default 0 Examples: Command PK0 PK Drive sends % PK=0 Notes Allow the parameters can be modified through the keyboard the parameters can be modified through the keyboard 197 920-0002 Rev. J 12/2014 Host Command Reference PL - Position Limit Compatibility: Servo drives only Affects: Motion Output function See also: MO command Sets or requests the count value used by the servo to determine if the motor is in position. This is used by the servo for determining the state of Motion Output (see MO command). When performing a move the Motion Output will be set to the designated condition until the servo is in position at the end of a move. The “In Position” status is set in the same way. Command Details: Structure PL{Parameter #1} Type BUFFERED Usage READ/WRITE Non-Volatile Yes Register Access None Parameter Details: Parameter #1 Positioning limit - units encoder counts - range 0 - 32767 Examples: Command Drive sends PL20 - PL PL=20 920-0002 Rev. J 12/2014 Notes Set position limit to 20 counts 198 Host Command Reference PM - Power-up Mode Compatibility: All drives See also: CM command Sets or requests the power-up mode of the drive. PM determines how the drive is configured for serial communications at power-up. For example, for SCL applications set PM=2 or PM=5. The power-up mode is also set when configuring the drive with Quick Tuner or Configurator. PM2 (Q / SCL) is the same as PM7 (Q Program Mode), except the program is not automatically executed at power up. Q drives When creating Q Programs for your Q drive, checking the “Execute “Q” at Power-up” box on the main screen of the Q Programmer software will change the power-up mode of the drive to 7 (PM7) with the next download. This will cause the drive to run its stored Q Program at power-up. You must download the program after checking this box for the change to take effect. Si drives An Si drive is set to PM1 automatically when an Si program is downloaded to the drive. If the drive is currently set to PM7 for operation in Q mode, simply uploading and executing a stored Si program will not change the power-up mode of the drive to PM1. The program may be uploaded and executed, but the drive will not power up and execute the Si program until after a download through the Si Programmer software. NOTE: If the drive is configured for power-up modes 1 or 3, it will not respond to SCL commands issued by a host device. If SCL communications are required in this scenario, the host device must recognize the drive’s power-up packet and issue the response “00” (double-zero, no carriage return) within two seconds to force the drive into SCL mode without altering the PM setting. See Appendix B for further information. Command Details: Structure PM {Parameter #1} Type BUFFERED Usage READ/WRITE Non-Volatile Yes (see note below) Register Access None Parameter Details: Parameter #1 Power on mode - units integer code - range 1 = Si Program (Si versions only) 2 = Q / SCL (drive enabled) 3 = Quick Tuner (servos) or Configurator (steppers) 4 = SiNet Hub 5 = Q / SCL (drive disabled) 6 = not used 7 = Q Program, Auto-execute (Q drives only) NOTE: This data is saved to non-volatile memory immediately upon execution. It is not required to execute the SA command to save to non-volatile memory. Examples: Command Drive sends PM2 - PM PM=2 Notes Drive will power up in Q / SCL mode (drive enabled) 199 920-0002 Rev. J 12/2014 Host Command Reference PN - Probe On Demand Compatibility: Stepper drives See also: EF, MC commands Perform a full-current probe of the motor. The motor’s maximum rated current is used as defined by the MC command. This allows the drive to dynamically measure electrical parameters such as inductance and resistance, which are used to optimize the drive’s control over the motor. This probe is automatically done on power-up and after an EF command is issued, but may be performed at any time using the PN command. NOTE: This operation will briefly energize the motor with full current. Use caution when executing the PN command as this may cause slight movement of the motor shaft. Command Details: Structure PN Type BUFFERED Usage WRITE ONLY Non-Volatile NO Register Access None Examples: Command PN 920-0002 Rev. J 12/2014 Drive sends - Notes Perform a full-current probe of the motor. 200 Host Command Reference PP - Power-up Peak current Compatibility: Servo drives only Affects: Motor current, especially during acceleration and deceleration See also: CC, CP, PC commands Sets or requests the power-up peak (RMS) current setting of the servo drive. This command differs from the CP command in that in addition to setting the peak current of the drive, PP also immediately saves the setting to NV memory. In other words, PP = CP + SA. Command Details: Structure PP{Parameter #1} Type BUFFERED Usage READ/WRITE Non-Volatile YES Register Access None Parameter Details: Parameter #1 Power-up peak current limit - units amps RMS (resolution is 0.01 amps) - range BLuDC4: 0 - 13.5 BLuDC9: 0 - 18.0 BLuAC5: 0 - 15.0 SV7: 0 - 7.0 SVAC3 (120V): 0 - 7.5 SVAC3 (220V): 0 - 3.75 Examples: Command Drive sends PP6 - PP PP=6 Notes Set power-up peak current to 6.0 amps RMS 201 920-0002 Rev. J 12/2014 Host Command Reference PR - Protocol Compatibility: All drives Affects: RS-232 & RS-485 Serial Communications See also: BR and PB commands Sets or requests the serial communication protocol settings. Sets or requests the serial communication protocol settings. There are a number of settings that can be turned on or off in the PR command. Each setting is assigned a bit in a 9 - bit binary word. The parameter of the PR command is the decimal equivalent of this word. If you send the PR command without a parameter the drive will respond with the decimal equivalent of the word as well. The different protocol settings and their bit assignments are shown below. Command Details: Structure PR{Parameter #1} Type BUFFERED Usage READ/WRITE Non-Volatile Yes Register Access None Parameter Details: Parameter #1 Protocol code - units decimal (integer) value of binary word - range 1 - 511 (000000001 - 111111111) bit 0 = Default (“Standard SCL”) bit 1 = Always use Address Character bit 2 = Ack/Nack bit 3 = Checksum bit 4 = (reserved) bit 5 = 3-digit numeric register addressing bit 6 = Checksum Type (step-servo and M2 only) bit 7 = Little/Big Endian in Modbus Mode bit 8 = Full Duplex in RS-422 *Bit 0 is only required when all other bits are set to 0. If any other bit in the word is set to 1, Bit 0 is ignored. For example, PR4 and PR5 provide the same protocol settings. Bit3 = 1: has checksum / 0: No checksum Bit6 = 1: STM type checksum / 0: SSM type checksum *For more details about STM type checksum and SSM type checksum, please refer to Appendix D. Bit7 = 1: Little Endian / 0: Big Endian Bit8 = 1: Full Duplex / 0: Half Duplex Examples: Command PR1 Drive sends - PR4 - PR PR=4 920-0002 Rev. J 12/2014 Notes Set to standard SCL protocol Turn Ack/Nack on 202 Host Command Reference PS - Pause Compatibility: All drives See also: BS, CT command Suspends execution of buffered commands until the next CT (Continue) command is executed. This can be useful for coordinating motion among axes by first pausing (PS) the drives, then loading the drives’ command buffers with commands, and then resuming command execution (CT) in all drives at once. PS can also be useful for holding a sequence of commands in the drive’s command buffer to time with an external event. Use the PS command to pause the command buffer, then send each (buffered type) command in the desired sequence to the drive. When the timing with the external event occurs, simply send the CT command which will trigger the execution of the already buffered sequence of commands. NOTE: It is possible to overflow the command buffer. Use the BS (Buffer Status) command to view how many command spaces are vacant in the buffer at any given time. Command Details: Structure PS Type BUFFERED Usage WRITE ONLY Non-Volatile NO Register Access None Examples: Command PS Drive sends - Notes Pause execution of buffered commands 203 920-0002 Rev. J 12/2014 Host Command Reference PT - Pulse Type Compatibility: All drives See also: CM, EG commands Sets or requests the type of incoming pulse used in CM7 (Pulse and Direction mode). The possible input signals are as follows: 0 = Step / Direction 1 = CW / CCW Pulse 2 = AB Quadrature (master encoder) 4 = Step / ~Direction (direction input is reversed from PT0) 6 = BA Quadrature (count direction is reverse of PT2) Command Details: Structure PT{Parameter #1} Type BUFFERED Usage READ / WRITE Non-Volatile YES Register Access None Parameter Details: Parameter #1 Pulse Type - units integer - range 0, 1, 2, 4, or 6 Examples: Command Drive sends Notes PT0 - Instruct the drive to follow step/direction pulses from a master controller. PT PT=0 PT2 - Instruct the drive to follow AB quadrature encoder pulses, typically from a master encoder. PT PT=2 920-0002 Rev. J 12/2014 204 Host Command Reference PV - Secondary Electronic Gearing Compatibility: M2 drives Affects: Control mode 7 See also: EG, DS Commands This parameter determines the second electronic gearing of M2 drives. Command Details: Structure PV{Parameter #1} Type BUFFERED Usage READ/WRITE Non-Volatile YES Register Access None Parameter Details: Parameter #1 See above - units Integer(counts/rev) - range 10~51200 -default 20000 Examples: Command PV20000 PV Drive sends % PV=20000 Notes set the second electronic gearing to 20000 counts/rev the second electronic gearing is 20000 counts/rev 205 920-0002 Rev. J 12/2014 Host Command Reference PW - Password Compatibility: Q drives only Normally the stored program of a Q drive can be uploaded and downloaded at will. This allows basically any user to access the stored program of a Q drive. To password-protect the stored program of a Q drive the PW command can be issued with a customized key code. The factory default key code is “1234”, which allows uploading and downloading programs freely. To passwordprotect a stored program the user should enter the PW command with a new key code. This new key code can be any 4 character alpha-numeric code (characters A-Z, a-z, and 0-9 are acceptable). After entering the new key code the user must enter the SA (Save) command for the new key code to be saved in the drive. Then, the next time the drive is powered up password-protection will take effect, which means the user must first “unlock” the drive by sending the PW command with the customized key code before being able to upload (QU), save (QS), or delete (QD) any part of the Q drive’s stored program. (All other immediate commands function even if the drive is not “unlocked”). Furthermore, every subsequent power-up of the drive will require the same key code to be entered before uploading. To change the key code, enter the present key code at power up and then use the PW command to enter a new key code followed by the SA command. To return the drive to the default state of no-password protection, unlock the drive first by using the present key code, then enter the default key code of “1234” followed by the SA command. NOTE: If the key code is forgotten or lost, re-entering the default code of “1234” will unlock the drive and ERASE THE CONTENTS OF THE DRIVE’S NON-VOLATILE MEMORY AT THE SAME TIME. Command Details: Structure PW(Parameter #1) Type IMMEDIATE Usage WRITE ONLY Non-Volatile Yes Register Access None Parameter Details: Parameter #1 4-digit alphanumeric key code - units upper and lower-case letters and numbers - range A-Z, a-z, 0-9 - default Default key code is “1234” Examples: Command PWak99 SA Drive sends - - Notes Password key code set to “ak99” New key code saved in drive PWak99 - Access to stored program unlocked at next power-up of drive 920-0002 Rev. J 12/2014 206 Host Command Reference QC - Queue Call Compatibility: Q drives only See also: QX, QE, QL commands Loads a program segment from non-volatile memory into the queue and begins executing at line #1. Loads the “calling” segment location and the line where the call occurred into a call “stack”. When a QC command without a parameter is encountered in the segment a “return” to the calling segment is activated. The “calling” segment is loaded from non-volatile memory back into the queue and begins executing at the line immediately following the line number of the original “calling” QC command. The call stack can go 5 calls deep which means you can nest up to 5 calls. If the number of calls before a “return” (QC with no parameter) is encountered exceeds 5 the “calling” QC command (with parameter) is ignored. If a “return” is encountered without a previous call, the return is ignored. Command Details: Structure QC{Parameter #1} Type BUFFERED Usage WRITE ONLY Non-Volatile NO Register Access None Parameter Details: Parameter #1 Program segment, no parameter means return to calling segment - units integer - range 1 - 12 = segment 1 - 12 no parameter = return to calling segment Examples: Command QC4 QC Drive sends - - Notes Call segment 4 Return to calling segment 207 920-0002 Rev. J 12/2014 Host Command Reference QD - Queue Delete Compatibility: Q drives only See also: QL, QS, PW commands Deletes the contents of the non-volatile memory location associated with a particular program segment. Command Details: Structure QD(Parameter #1) Type IMMEDIATE Usage WRITE ONLY Non-Volatile NO Register Access None Parameter Details: Parameter #1 Segment number - units integer number - range 1 - 12 Examples: Command QD5 920-0002 Rev. J 12/2014 Drive sends - Notes Delete program segment 5 from the drive’s non-volatile memory 208 Host Command Reference QE - Queue Execute Compatibility: Q drives only See also: QL, QX Begins executing a program segment previously loaded into the queue. Starts executing at line #1. A segment must have previously been loaded using the “QL” or “QX” commands. Command Details: Structure QE Type IMMEDIATE Usage WRITE ONLY Non-Volatile NO Register Access None Examples: Command QE Drive sends - Notes Begin execution of loaded segment 209 920-0002 Rev. J 12/2014 Host Command Reference QG - Queue Goto Compatibility: Q drives only See also: QJ, QR Causes program segment execution to jump to the given line number in the queue. Gotos directed to the same line number as the QG command or past the end of the queue are ignored. Command Details: Structure QG(Parameter #1) Type BUFFERED Usage WRITE ONLY Non-Volatile NO Register Access None Parameter Details: Parameter #1 Segment line number - units integer - range 1 - 62 Examples: Command QG10 920-0002 Rev. J 12/2014 Drive sends - Notes Cause a jump to line 10 in the segment 210 Host Command Reference QJ - Queue Jump Compatibility: Q drives only Affects: Program flow See also: QG, TI, TR, CR and all Math commands (“R” commands) Causes program segment execution to jump to the given line number in the queue based on a “condition code”. Jumps directed to the same line number as the QJ command or past the end of the queue are ignored. If the condition code is met the jump occurs, if not the program proceeds to the next line. Condition codes are set by previous commands such as the TI (Test Input) or TR (Test Register) commands. When using math commands (“R” commands) the condition code is set based on the result of the math operation. Command Details: Structure QJ(Parameter #1)(Parameter #2) Type BUFFERED Usage WRITE ONLY Non-Volatile NO Register Access None Parameter Details: Parameter #1 Condition code - units letter - range T = True F = False P = Positive G = Greater than L = Less than E = Equals U = Unequal Z = Zero Parameter #2 Segment line number - units integer - range 1 - 62 Examples: Command TI4L QJT15 Drive sends - - Notes Test input 4 to see if it’s low (active) Jump to line 15 if condition code is “True” (i.e. input 4 is low) 211 920-0002 Rev. J 12/2014 Host Command Reference QK - Queue Kill Compatibility: Q drives only Affects: Queue execution and program flow See also: SK Halts execution of the queue. The queue contents are not affected and can be executed again using the “QE” command. Command Details: Structure QK Type BUFFERED Usage WRITE ONLY Non-Volatile NO Register Access None Examples: Command QK 920-0002 Rev. J 12/2014 Drive sends - Notes Stop execution of the queue/program 212 Host Command Reference QL - Queue Load Compatibility: Q drives only Affects: Contents of command buffer See also: QE, QS, QX commands Initiates the loading of a command sequence into the queue. Loading can come from the serial port (host controller) or from non-volatile memory (stored program). When no parameter is sent with the command loading is done from the serial port. Loading is finished when a QS (Queue Save) or QE (Queue Execute) command is sent. When a parameter is sent with the command the parameter designates the non-volatile memory location of the desired program segment to be loaded into the queue. QL will cause an overwrite of any commands in the queue starting at line #1. Command Details: Structure QL{Parameter #1} Type IMMEDIATE Usage WRITE ONLY Non-Volatile NO Register Access None Parameter Details: Parameter #1 Program segment number - units integer - range 1 - 12 Examples: Command QL QL3 Drive sends - - Notes Initiates loading queue from serial port Loads segment from non-volatile memory into the queue 213 920-0002 Rev. J 12/2014 Host Command Reference QR - Queue Repeat Compatibility: Q drives only Affects: Selected data register See also: QJ, QG, RL, RX commands Causes program segment execution to jump to a previous line number in the queue for a given number of repeat counts. The repeat count is acquired from a selected Read/Write or User-Defined data register. Jumps past the end of the queue are ignored. Jumps to subsequent line numbers in the queue will not be repeated. If repeat count is set to “1” no Jump is performed. The data register selected for the repeat count must be set with the number of repeat counts prior to using the QR command: use the RX (Register Load - buffered) command to load the data register with the repeat count. The data register contents are affected by this command and must be re-loaded before each usage with the QR command. NOTE: Although data registers A - Z can be used with the QR command it is not recommended. The QR command eventually destructs the data in a register by decrementing its value each time a jump is made in the repeat loop and could therefore lead to unexpected results in other parts of the program that make use of data registers A - Z. Command Details: Structure QR(Parameter #1)(Parameter #2) Type BUFFERED Usage WRITE ONLY Non-Volatile NO Register Access None Parameter Details: Parameter #1 Data register - units register character - range A - Z and all user-defined registers (listed in the Data Registers section) Parameter #2 Segment line number - units integer - range 1 - 62 Examples: Command Drive sends RX120 - QR15 - 920-0002 Rev. J 12/2014 Notes Load user register #1 with the value 20 Cause a repeated jump to line 5 of the queue using the value (20) in data register #1 as the repeat count 214 Host Command Reference QS - Queue Save Compatibility: Q drives only Affects: None See also: QE, QL, QX, PW commands Saves a segment currently in the queue to a non-volatile memory location. Ends a QL (Queue Load) if one is in progress. See Appendix B for more details on this command, including its limitations. Command Details: Structure QS(Parameter #1) Type IMMEDIATE Usage WRITE ONLY Non-Volatile NO Register Access None Parameter Details: Parameter #1 Program segment location - units integer - range 1 - 12 Examples: Command QS2 Drive sends - Notes Save contents of queue to non-volatile memory location #2 215 920-0002 Rev. J 12/2014 Host Command Reference QU - Queue Upload Compatibility: Q drives only See also: QL, QE, QS, QX, PW commands Uploads a stored program segment from the drive’s non-volatile memory to the serial port. This command is used to retrieve stored program segments from the drive. When using this command the drive responds with either a “positive” or a “negative” response. A “positive” response consists of a normal acknowledge (“ack”) followed by the contents of the requested program segment with each line number separated by a carriage return. Program segments 1 to 12 can be uploaded, as well as the contents of the queue. A “negative” response from the drive consists of a normal acknowledge (“ack”) followed by one of four error codes: 0, -1, -2, or -3. A negative acknowledge (“nack” / “?”) will be sent from the drive if the command is not understood by the drive. See Appendix D for more information on acknowledge and negative acknowledge responses. Positive response format: “ack” (“%”) First line = “QU##” where “##” = the number of lines in the segment + 1 Second line = command at line 1 of the segment Next line = command at line 2 of the segment ... Last line = command at last line of segment Negative Responses: “ack” (“%”) QU0 = No segment at specified location QU-1 = Program Running (Cannot upload at this time) QU-2 = Upload currently in process QU-3 = Password Protected (Protection must be unlocked using PW command) Command Details: Structure QU(Parameter #1) Type IMMEDIATE Usage READ ONLY Non-Volatile NO Register Access None Parameter Details: Parameter #1 Program segment location - units integer - range 1 - 12, or 0 to upload queue Examples: Command QU0 QU3 920-0002 Rev. J 12/2014 Drive sends (queue contents) (segment #3 contents) location #3 Notes Uploads contents of queue to the serial port Uploads contents of segment from non-volatile memory 216 Host Command Reference QX - Queue Load & Execute Compatibility: Q drives only Affects: Stored program flow See also: QE, QL Loads a program segment from non-volatile memory into the queue. Begins executing the segment at line #1. This is the similar to the combination of a QL (Queue Load) and a QE (Queue Execute) command with the difference being the QX command can be written into a stored program segment. Use this command to “jump” from segment to segment. Command Details: Structure QX(Parameter #1) Type BUFFERED Usage WRITE ONLY Non-Volatile NO Register Access None Parameter Details: Parameter #1 Program segment location - units integer - range 1 - 12 Examples: Command QX2 Drive sends - Notes Loads segment #2 and begins execution 217 920-0002 Rev. J 12/2014 Host Command Reference RC - Register Counter Compatibility: Q drives only Affects: Data Register “I” (025) See also: RL, RX , RI, RD, TS commands This command enables a function that increments the “I” data register when the given input condition (determined by the RC command) is met. Typically the “R” or “F” input condition (see Details below) is used to trigger an increment. If however the “L” or “H” input condition is used the register will be incremented at a rate of 8000 times per second. In other words the “R” and “F” input conditions are used for true input counting while the “L” and “H” conditions act as input timers. Use the RL (Register Load - immediate) or RX (Register Load buffered) commands to preset or set the “I” data register to a predetermined value. Sending the RC command without a parameter disables the function. This command is also used in conjunction with the TS (Time Stamp) command. See the TS command for more details. Command Details: Structure RC{Parameter #1} Type BUFFERED Usage WRITE ONLY Non-Volatile NO Register Access “I” (025) Parameter Details: (See Appendix F: Working With Inputs and Outputs) Examples: Command RC4F Drive sends - low (falling edge) Notes Increment data register “I” each time input 4 changes from high to The sample Q program on the following page illustrates the interaction of the RC and TS commands. After initialization, the program waits for a falling edge event on input X3, at which point a 5 second timer begins counting down. During this delay, the user may trigger X3 an arbitrary number of times. After 5 seconds, the motor will execute a series of 5000-step moves, with the delay between each corresponding to the delay between switch closures on X3. That is, if the user trips X3 four times waiting 1 second between each event, the motor will execute four 5000-step moves with a 1 second dwell between each. 920-0002 Rev. J 12/2014 218 Host Command Reference Sample Q program for illustrating RC and TS interaction MT 1 Multi-tasking ON EG 20000 20,000 steps/rev AC 250 DE 250 VE 5 FI 3 200 Filter input 3 for 200 processor ticks RX I 0 Zero the “I” register RC X3F Setup the “I” register for input X3 WI X3F Wait for input X3 WT 5.00 Wait 5 seconds >>> trigger inpuxt X3 a few times TS Throw away first time stamp LABEL2 RD I Decrement “I” register FL 5000 Feed 5000 steps TR I 1 Test “I” against 1 QJ L #LABEL1 Jump to end if “I” less than 1 TS Time stamp RM W 1 Move “W” into “1” WD 1 Delay for “1” milliseconds QG #LABEL2 Go to Label 2 LABEL1 NO Stop program 219 920-0002 Rev. J 12/2014 Host Command Reference RD - Register Decrement Compatibility: Q drives only Affects: All data registers See also: RI, RM Decrements by 1 the value of the designated data register. Command Details: Structure RD(Parameter #1) Type BUFFERED Usage WRITE ONLY Non-Volatile NO Register Access All Read/Write and User-Defined data registers Parameter Details: Parameter #1 Data register assignment - units character - range all Read/Write and User-Defined data registers Examples: Command RDV 920-0002 Rev. J 12/2014 Drive sends - Notes Decrements the value of the velocity data register “V” 220 Host Command Reference RE - Restart or Reset Compatibility: All drives Restarts the drive by resetting fault conditions and re-initializing the drive with the startup parameters. Leaves the drive in a disabled state to prevent any movement after the restart is complete. Command Details: Structure RE Type IMMEDIATE Usage WRITE ONLY Non-Volatile NO Register Access None Examples: Command RE Drive sends - Notes Resets drive condition and parameters 221 920-0002 Rev. J 12/2014 Host Command Reference RI - Register Increment Compatibility: Q drives only Affects: All data registers See also: RD, RM commands Increments by 1 the value of the designated data register. Command Details: Structure RI(Parameter #1) Type BUFFERED Usage WRITE ONLY Non-Volatile NO Register Access All Read/Write and User-Defined data registers Parameter Details: Parameter #1 Data register assignment - units character - range all Read/Write and User-Defined data registers Examples: Command RIV 920-0002 Rev. J 12/2014 Drive sends - Notes Increments the value of the velocity data register “V” 222 Host Command Reference RL - Register Load - immediate Compatibility: All drives Affects: All data registers See also: RX, RI, RD, RM commands Sets a data register to the given immediate data value. The data value is checked and stored as a Long word. When setting a Short-word register with the given Long-word data value only the lower word of the Long value is used. Command Details: Structure RL(Paramter #1){Parameter #2} Type IMMEDIATE Usage READ/WRITE Non-Volatile NO Register Access All data registers Parameter Details: Parameter #1 Data register assignment - units character - range All Read/Write and User-Defined data registers; ReadOnly data registers can be read back when Parameter #2 is not included Parameter #2 Data register value - units integer - range +/- 2147483647 (long data registers) +/- 32767 (short data registers) Examples: Command RLA100 RLA Drive sends - RLA=100 When PR command Bit 5 is set RL017100 - RL017 RLA=100 Notes Set acceleration register to 1000 rpm/s Return acceleration register value Set Acceleration register to 1000 rpm/s Return acceleration register value NOTE: When setting a register no pre-processing of the data value is performed. Data is set to the internal raw value. For example, the internal raw acceleration value is in tens of rpm/s. See the “Data Register” section at the beginning of this manual for more details on data register assignments and units. Units Example: AC10 means 10 rps/s RLA10 means 10 * 10 rpm/s = 1.667 rps/s Multiply the desired rps/s value times 6 to convert to the “raw” acceleration value 223 920-0002 Rev. J 12/2014 Host Command Reference RM - Register Move Compatibility: Q drives only Affects: All data registers See also: RI, RD, RL, TR, RX commands Move the contents of a first data register into a second data register. Command Details: Structure RM(Parameter #1)(Parameter #2) Type BUFFERED Usage WRITE ONLY Non-Volatile NO Register Access All Read/Write and User-Defined data registers Parameter Details: Parameter #1 Source data register - units character - range all data register assignments Parameter #2 Destination data register - units character - range all Read/Write and User-Defined data registers Examples: Command Drive sends RMAB - 920-0002 Rev. J 12/2014 Notes Move contents of acceleration register “A” into the deceleration register “B” 224 Host Command Reference RO - Anti-Resonance ON Compatibility: Stepper drives Enables or disables the Anti-Resonance algorithm. This command has the same effect as the “Anti-Resonance off” check box in ST Configurator’s motor configuration dialog. Command Details: Structure RO{Parameter #1} Type BUFFERED Usage READ / WRITE Non-Volatile YES Register Access None Parameter Details: Parameter #1 Anti-Resonance Algorithm Status - units integer - range 0 (Anti-Resonance OFF) 1 (Anti-Resonance ON) Examples: Command Drive sends Notes RO1 - Enable Anti-Resonance algorithm RO RO=1 RO0 - RO RO=0 Disable Anti-Resonance algorithm 225 920-0002 Rev. J 12/2014 Host Command Reference RR - Register Read Compatibility: Q drives only Affects: All data registers See also: RI, RD, RL, RM, RW commands Reads a data value from a non-volatile memory location into a data register. The data value is read as a Long word. If the value being read is too large for the destination data register, the value is truncated. Command Details: Structure RR(Parameter #1)(Parameter #2) Type BUFFERED Usage WRITE ONLY Non-Volatile NO Register Access All Read/Write and User-Defined data registers Parameter Details: Parameter #1 Data register - units character - range all Read/Write and User-Defined data registers Parameter #2 Non-volatile memory location - units integer - range 1 - 100 Examples: Command RRV10 920-0002 Rev. J 12/2014 Drive sends - register “V” Notes Read data from non-volatile memory location #10 and place it in data 226 Host Command Reference RS - Request Status Compatibility: All drives See also: SC command Asks the drive to respond with what it’s doing. The drive has a number of different states of operation that are represented by character codes. The drive can send more than one code at a time to define its current status. Command Details: Structure RS Type IMMEDIATE Usage READ ONLY Non-Volatile NO Register Access None Examples: Command RS RS RS Drive sends RS=PR RS=AED RS=JR Notes Motor is in position, drive is enabled Alarm code is present, drive is faulted and disabled Motor is jogging, drive is enabled Status character codes: A = An Alarm code is present (use AL command to see code, AR command to clear code) D = Disabled (the drive is disabled) E = Drive Fault (drive must be reset by AR command to clear this fault) F = Motor moving H = Homing (SH in progress) J = Jogging (CJ in progress) M = Motion in progress (Feed & Jog Commands) P = In position R = Ready (Drive is enabled and ready) S = Stopping a motion (ST or SK command executing) T = Wait Time (WT command executing) W = Wait Input (WI command executing) 227 920-0002 Rev. J 12/2014 Host Command Reference RU - Register Upload Compatibility: Q drives only Affects: All data registers See also: PR, RL, RX commands Upload the contents of an array of data registers. Up to 16 registers can be read back with one RU command. Each reading is terminated with a carriage return. Command Details: Structure RU(Parameter #1)(Parameter #2) Type IMMEDIATE Usage WRITE ONLY Non-Volatile NO Register Access All data registers Parameter Details: Parameter #1 Data register assignment - units character - range all data registers Parameter #2 Number of consecutive data registers to upload - units integer - range 1 - 16 Examples: Command RUA5 Drive sends RUA=400 RUB=400 RUC=16000 RUD=8000 RUE=0 When PR command Bit 5 is set RU0175 RUA=400 RUB=400 RUC=16000 RUD=8000 RUE=0 Notes “A” The Acceleration value “B” The Deceleration value “C” The Distance Change value “D” The Distance value “E” The Encoder value “017” The Acceleration value “018” The Deceleration value “019” The Distance Change value “020” The Distance value “021” The Encoder value NOTE: All Data values are “raw” meaning the data is not scaled to the drive user units. For example the velocity value (“V”) will be returned as 0.25 rpm instead of rps: raw value of 2400 = 10 rps. 920-0002 Rev. J 12/2014 228 Host Command Reference RV - Revision Level Compatibility: All drives See also: MV command Requests the drive’s firmware version. Data is returned as a three digit value. To see the firmware version’s subletter as well (if applicable) use the MV command. Command Details: Structure RV Type IMMEDIATE Usage READ ONLY Non-Volatile NO Register Access None Units Drive firmware version Examples: Command RV Drive sends RV=150 Notes Drive is running firmware version 1.50 229 920-0002 Rev. J 12/2014 Host Command Reference RW - Register Write Compatibility: Q drives only Affects: All data registers See also: RI, RD, RL, RM, RW commands Writes the data value of a given data register into non-volatile memory. The data value is written as a Long word. See Appendix A for more details on this command, including its limitations. NOTE: The RW function writes information to flash memory, which has a useful life of 10,000 write cycles. Command Details: Structure RW(Parameter #1)(Parameter #2) Type BUFFERED Usage WRITE ONLY Non-Volatile NO Register Access All Read/Write and User-Defined data registers Parameter Details: Parameter #1 Data register assignment - units character - range all Read/Write and User-Defined data registers Parameter #2 Non-volatile memory location - units integer - range 1 - 100 Examples: Command RWV10 920-0002 Rev. J 12/2014 Drive sends - Notes Write data from data register “V” into non-volatile memory location #10 230 Host Command Reference RX - Register Load - buffered Compatibility: Q drives only Affects: All data registers See also: RL, RU, RM commands Sets a data register to the given immediate data value. The data value is checked and stored as a Long word. When loading a Short-word data register with the given Long-word data value only the lower word of the Long value is used. This command is the same as the RL command except it is a buffered command and therefore can be placed in a stored program. Command Details: Structure RX(Parameter #1)(Parameter #2) Type BUFFERED Usage READ/WRITE Non-Volatile NO Register Access All data registers Parameter Details: Parameter #1 Data register assignment - units character - range All Read/Write and User-Defined data registers; ReadOnly data registers can be used when Parameter #2 is not included (i.e. for reading back the contents of a ReadOnly data register) Parameter #2 Data register value - units integer - range +/- 2147483647 (long data registers) +/- 32767 (short data registers) Examples: Command Drive sends RXA100 - RXA RXA=100 Notes Set acceleration register “A” to 1000 rpm/s 231 920-0002 Rev. J 12/2014 Host Command Reference R+ - Register Add Compatibility: Q drives only Affects: All data registers See also: R-, R*, R/, R&, RD, RI, QJ commands Adds the contents of a first data register to a second data register and places the result in the accumulator data register, User-Defined register “0”. This is a 32-bit operation: adding two Long word values can cause an overflow. All math operations affect the “condition code” used by the QJ (Queue Jump) command. R+ can set condition codes T, F, N, P, and Z Command Details: Structure R+(Parameter #1)(Parameter #2) Type BUFFERED Usage WRITE ONLY Non-Volatile NO Register Access “0” (000), Accumulator Parameter Details: Parameter #1 First data register assignment - units character - range all data registers Parameter #2 Second data register assignment - units character - range all data registers Examples: Command R+D1 920-0002 Rev. J 12/2014 Drive sends Notes - Add contents of distance register “D” to user-defined register “1” and place the result in the accumulator register “0” 232 Host Command Reference R- - Register Subtract Compatibility: Q drives only Affects: All data registers See also: R+, R*, R/, R&, RD, RI, QJ commands Subtracts the contents of the second data register from the first data register and places the result in the accumulator data register, User-Defined register “0”. This is a 32-bit operation: subtracting two Long word values can cause an underflow. All math operations affect the “condition code” used by the QJ (Queue Jump) command. Can set condition codes T, F, N, P, and Z. Command Details: Structure R-(Parameter #1)(Parameter #2) Type BUFFERED Usage WRITE ONLY Non-Volatile NO Register Access “0” (000), Accumulator Parameter Details: Parameter #1 First data register assignment - units character - range all data registers Parameter #2 Second data register assignment - units character - range all data registers Examples: Command Drive sends R-D1 - Notes Subtract the contents of user-defined register “1” from the distance register “D” and place the result in the accumulator register “0” 233 920-0002 Rev. J 12/2014 Host Command Reference R* - Register Multiply Compatibility: Q drives only Affects: All data registers See also: R+, R-, R/, R&, RD, RI, QJ commands Multiply the contents of the first data register by the second data register and place the result in the accumulator data register, User-Defined register “0”. This is a 32-bit operation: multiplying two Long word values can cause an overflow. All math operations affect the “condition code” used by the QJ (Queue Jump) command. Can set condition codes T, F, N, P, and Z. Command Details: Structure R*(Parameter #1)(Parameter #2) Type BUFFERED Usage WRITE ONLY Non-Volatile NO Register Access “0” (000), Accumulator Parameter Details: Parameter #1 First data register assignment - units character - range all data registers Parameter #2 Second data register assignment - units character - range all data registers Examples: Command R*D1 920-0002 Rev. J 12/2014 Drive sends Notes - Multiply contents of distance register “D” by contents of user-defined register “1” and place result in accumulator register “0” 234 Host Command Reference R/ - Register Divide Compatibility: Q drives only Affects: All data registers See also: R+, R-, R*, R&, RD, RI, QJ commands Divide the contents of the first data register by the second data register and place the result in the accumulator data register, User-Defined register “0”. This is a 32-bit operation. A value of “zero” in the second data register will cause an illegal “divide by zero”, in which case the divide operation is ignored. All math operations affect the “condition code” used by the QJ (Queue Jump) command. Can set condition codes T, F, N, P, and Z. Command Details: Structure R/(Parameter #1)(Parameter #2) Type BUFFERED Usage WRITE ONLY Non-Volatile NO Register Access “0” (000), Accumulator Parameter Details: Parameter #1 First data register - units data register assignment - range All data registers Parameter #2 Second data register - units data register assignment - range All data registers Examples: Command Drive sends R/D1 - Notes Divide contents of distance register “D” by user-defined register “1” and place result in accumulator register “0” 235 920-0002 Rev. J 12/2014 Host Command Reference R& - Register AND Compatibility: Q drives only Affects: All data registers See also: R+, R-, R*, R/, RD, RI, QJ commands Do a “bit-wise” AND of the contents of the first data register with the contents of the second data register and place the result in the accumulator data register, User-Defined register “0”. This is a 32-bit operation. This operation affects the “condition code” use by the QJ (Queue Jump) command. All math operations affect the “condition code” used by the QJ (Queue Jump) command. Can set condition codes T, F, N, P, and Z. Command Details: Structure R&(Parameter #1)(Parameter #2) Type BUFFERED Usage WRITE ONLY Non-Volatile NO Register Access “0” (000), Accumulator Parameter Details: Parameter #1 First data register - units data register assignment - range All data registers Parameter #2 Second data register - units data register assignment - range All data registers Examples: Command R&s1 920-0002 Rev. J 12/2014 Drive sends Notes - AND the contents of status register “s” and user-defined register “1” and place the result in accumulator register “0” 236 Host Command Reference R| - Register OR Compatibility: Q drives only Affects: All data registers See also: R+, R-, R*, R/, R&, RD, RI, QJ commands Do a “bit-wise” OR of the contents of the first data register with the contents of the second data register and place the result in the accumulator data register, User-Defined register “0”. This is a 32-bit operation. All math operations affect the “condition code” used by the QJ (Queue Jump) command. Can set condition codes T, F, N, P, and Z. Command Details: Structure RI(Parameter #1)(Parameter #2) Type BUFFERED Usage WRITE ONLY Non-Volatile NO Register Access “0” (000), Accumulator Parameter Details: Parameter #1 First data register - units data register assignment - range All data registers Parameter #2 Second data register - units data register assignment - range All data registers Examples: Command Drive sends R|i1 - Notes OR the contents of inputs register “i” with user-defined register “1” and place the results in accumulator register “0” 237 920-0002 Rev. J 12/2014 Host Command Reference SA - Save Parameters Compatibility: All drives See Also: RE command Saves selected command parameters to non-volatile memory. This command is useful for setting up the drive configuration with the desired defaults at power-up. (See which commands are non-volatile in the Command Summary section.) Command Details: Structure SA Type BUFFERED Usage WRITE ONLY Non-Volatile NO Register Access None Examples: Command SA 920-0002 Rev. J 12/2014 Drive sends - Notes Save all Non-Volatile-designated data registers 238 Host Command Reference SC - Status Code Compatibility: All drives See also: RS command Requests the current drive status as the Hexadecimal equivalent of a binary word. Each bit in the binary word relates to a status condition (see assignments below). The representation of this binary word as a hexadecimal value is called the Status Code. Drives can have multiple status conditions at one time, and host systems can typically interpret a Hexadecimal code very quickly. See Appendix E for more details on the Status Code. Command Details: Structure SC Type IMMEDIATE Usage READ ONLY Non-Volatile NO Register Access None Units Hexadecimal equivalent of the binary status code word (see bit assignments below) Response Details: Hex Value Status Code bit definition 0001 Motor Enabled (Motor Disabled if this bit = 0) 0002 Sampling (for Quick Tuner) 0004 Drive Fault (check Alarm Code) 0008 In Position (motor is in position) 0010 Moving (motor is moving) 0020 Jogging (currently in jog mode) 0040 Stopping (in the process of stopping from a stop command) 0080 Waiting (for an input; executing a WI command) 0100 Saving (parameter data is being saved) 0200 Alarm present (check Alarm Code) 0400 Homing (executing an SH command) 0800 Waiting (for time; executing a WD or WT command) 1000 Wizard running (Timing Wizard is running) 2000 Checking encoder (Timing Wizard is running) 4000 Q Program is running 8000 Initializing (happens at power up) Examples: Command Drive sends SC SC=0009 SC SC=0004 SC SC=0209 Notes Drive is in position and enabled (hex values 0001 and 0008) Drive is faulted and disabled (hex value 0004) Drive has an alarm, is in position and enabled (hex values 0001, 0008, and 0200) 239 920-0002 Rev. J 12/2014 Host Command Reference SD - Set Direction Compatibility: Integrated Steppers with Flex I/O Affects: All input and output commands See Also: AI, AO, BO, DL, MO and SI The Flex I/O feature allows the user to specify the direction of each I/O point. That is, to configure each as either an input or output. SD may be used as a query if issued without a parameter. The drive will then report the direction of each I/O point. WARNING: The SD command allows dynamic changes to I/O behavior of the drive, and may cause unintended interactions with other machine components if not implemented properly. Extreme caution should be used. The SD command is documented here only for completeness; MOONS’ Products strongly recommends that the Configurator software be used to make changes to drive I/O behavior. Command Details: Structure SD{Parameter #1}{Parameter #2} Type BUFFERED Usage READ/WRITE Non-Volatile Yes Register Access None Parameter Details: Parameter #1 I/O point to configure - units Integer - range 1-4 Parameter #2 Direction (input or output) - units Single character - range ‘I’ or ‘O’ (letter ‘O’, not zero) NOTE: This command requires either the letter ‘I’ (input) or ‘O’ (output) as Parameter #2. The drive’s response however, is composed of the numbers 1 (one = input) or 0 (zero = output). Examples: Command SD2O SD4I SD 920-0002 Rev. J 12/2014 Drive sends Notes - Set I/O point 2 as an Output - Set I/O point 4 as an Input SD=00000111 Drive reports that I/O points 1, 2 and 3 are inputs, 4 is an output. (Note: on the STM24, I/O points 5-8 are unused) 240 Host Command Reference SF - Step Filter Frequency Compatibility: Stepper drives only Sets or requests the step filter frequency. The primary use of this filter is to introduce “microstep emulation” effects, which smooth out low resolution step pulses when the drive’s microstep/gearing resolution (EG command) is set to a low value. This command is exceptionally useful when using a low-resolution indexer and smooth motor shaft rotation is required. Command Details: Structure SF{Parameter #1} Type BUFFERED Usage READ/WRITE Non-Volatile Yes Register Access None Parameter Details: Parameter #1 Step filter frequency - units Hz - range 0 - 2500 Examples: Command Drive sends SF500 - SF SF=500 Notes Set step filter frequency to 500 Hz 241 920-0002 Rev. J 12/2014 Host Command Reference SH - Seek Home Compatibility: All drives See Also: DL, FD, FS, FY, MT commands Executes the seek home command. Requires input number and condition for the home sensor. Speed is set by the last VE command. Accel and decel are set by AC and DE. Direction comes from the sign of the last DI command (“-” is CCW, no sign is CW). It should be noted that the SH command is not affected by multitasking. It will execute as shown here regardless of the current MT setting. Please see the MT command for details. The SH command performs a number of operations all combined into one command. The basic operation acts like a combination of the FS (Feed to Sensor) and FP (Feed to Position) commands. First, an FS-like move is made that runs the motor until the drive “sees” the home sensor. When the drive sees this home sensor it does two things: it records the absolute position of the home sensor and it immediately starts decelerating the motor to a stop. After the motor has come to a stop the drive then does an FP-like move to move the motor back to the absolute position recorded for the home sensor. Another function of the SH command is that if an end-of-travel limit switch is encountered before the home sensor condition is met, the move direction is reversed until the opposite limit is found. After the opposite limit is found the move then returns to the original direction and again attempts to find the home sensor. This always ensures that the motor is moving in the desired direction when the drive sees the home sensor. NOTE: This command is designed for use with three physical sensors or switches tied to three separate digital inputs of the drive: a home sensor, a CW end-of travel limit, and a CCW end-of-travel limit. Command Details: Structure SH{Parameter #1} Type BUFFERED Usage WRITE ONLY Non-Volatile NO Register Access None Parameter Details: (See Appendix F: Working With Inputs and Outputs) Examples: Command SH1L SH3R SHX5L 920-0002 Rev. J 12/2014 Drive sends - - - Notes Seek home to input 1 low Seek home to input 3 rising edge Seek home to input X5 low (main driver board input) 242 Host Command Reference SI - Enable Input Usage Compatibility: All drives Affects: Enable input usage See also: AI, CM, SD commands BLu, SV, STAC6, ST-Q/Si Sets or requests the usage of the Enable input. Input X3 is the default Enable input on all drives, however IN3 on SE, QE and Si drives may also be designated as the Enable input (see below). If an external Enable function is not needed input X3 and/or IN3 can be defined solely as a general purpose input. In this scenario only the ME and MD commands will enable and disable the drive, respectively. When using the brake output (see BO, BD and BE commands) the disabling of the drive is delayed by the time value set using the BD command. There are five possible usage states for the Enable function: SI1: Drive is enabled when X3 is open (inactive, high). SI2: Drive is enabled when X3 is closed (active, low). SI3: Neither X3 nor IN3 is used for enabling/disabling the drive, but as general purpose inputs. SI4: Drive is enabled when IN3 is open (inactive, high). (SE, QE, and Si drives only). SI5: Drive is enabled when IN3 is closed (active, low). (SE, QE, and Si drives only). ST-S, STM17, STM23-Q/C, STM24-C Defines the EN input as an Enable Input. If you want to use the EN input as an Enable input you can define it as such in two ways, with the ST Configurator software, or with the SI command. SI takes no effect if the drive is set in Command Mode (CM) 13, 14, 17 or 18, because these modes use the EN input as a speed change input and take precedence over the SI command. Also, setting the AI command after setting the SI command reassigns the EN input to Alarm Reset usage and turns off any drive enable usage (SI3). In other words, the AI and SI commands, as well as Command Modes (CM) 13, 14, 17 and 18 each assign a usage to the EN input. Each of these must exclusively use the EN input. Note: The STM24-C drive uses IN3 for the Enable Input. There are three Enable input states that can be defined with the SI command: SI1: Drive is enabled when the EN input is open (inactive, high). SI2: Drive is enabled when the EN input is closed (active, low). SI3: The EN input is not used for Enable and can be used as a general purpose input. SI will be automatically set to 3 if CM is set to 13,14,17, or 18, or if AI is set to 1 or 2 after the SI command is set. STM24-SF/QF Drives with Flex I/O allow a second parameter which allows the user to specify the I/O point used. Before an I/O point can be used as the Drive Enable input it must first be configured as an input with the SD command. See the STM24 Hardware Manual for details of which inputs may be used as the Drive Enable input. Possible uses for the SI command on the STM24 are as follows (‘n’ denotes the I/O point to be used): SI1n: Drive is enabled when the designated input is open (inactive, high). SI2n: Drive is enabled when the designated input is closed (active, low). SI3n: The specified input (‘n’) is not used for Drive Enable and may be used as a general purpose input. STAC5-S, SVAC3-S 243 920-0002 Rev. J 12/2014 Host Command Reference Defines the X3 input as an Enable Input. If you want to use the X3 input as an Enable input you can define it as such in two ways, with the ST Configurator software, or with the SI command. SI takes no effect if the drive is set in Command Mode (CM) 13, 14, 17 or 18, because these modes use the X3 input as a speed change input and take precedence over the SI command. Also, setting the AI command after setting the SI command reassigns the X3 input to Alarm Reset usage and turns off any drive enable usage (SI3). In other words, the AI and SI com¬mands, as well as Command Modes (CM) 13, 14, 17 and 18 each assign a usage to the X3 input. Each of these must exclusively use the X3 input. There are three Enable input states that can be defined with the SI command: SI1: Drive is enabled when the X3 input is open (inactive, high). SI2: Drive is enabled when the X3 input is closed (active, low). SI3: The X3 input is not used for Enable and can be used as a general purpose input. SI will be automatically set to 3 if CM is set to 13, 14, 17, or 18, or if AI is set to 1 or 2 after the SI command is set. Command Details: Structure SI{Parameter #1} {Parameter #2 (Flex I/O only)} Type BUFFERED Usage READ/WRITE Non-Volatile Yes Register Access None Parameter Details: Parameter #1 Input Usage - units integer code - range 1 - 3 or 1 - 5 (see above) Parameter #2 (Flex I/O only) I/O Point (if applicable, see note below) - units Integer Code - range 1 or 3 (See STM24 Hardware Manual for details) NOTES: • For drives with Flex I/O, the SD command must be executed to set an I/O point as an input or output before it can have a dedicated function assigned to it. • Parameter #2 only applies to drives equipped with Flex I/O. This includes the STM24SFand STM24QF. Parameter #2 is not defined for drives equipped with standard I/O. Examples: All drives with standard I/O: Command Drive sends SI1 - SI SI=1 Notes Cause drive to be enabled when X3 / EN input is open Drives with Flex I/O: Command Drive sends SD3I - SI13 - SI SI=13 Notes Configures I/O 3 as input (see SD command for details) Cause drive to be enabled when Input 3 is open 920-0002 Rev. J 12/2014 244 Host Command Reference SJ - Stop Jogging Compatibility: All drives Affects: CJ command See Also: JA, CJ, ST, SK, SM commands Stops the motor when jogging (CJ starts jogging). Jog decel rate is defined by the JA command. Command Details: Structure SJ Type IMMEDIATE Usage WRITE ONLY Non-Volatile NO Register Access None Examples: Command SJ Drive sends - command Notes Stops jogging immediately using the deceleration rate set by the JA 245 920-0002 Rev. J 12/2014 Host Command Reference SK - Stop & Kill Compatibility: All drives See Also: AM, DE, JA, ST, SM commands Halts any buffered command in progress and removes any other buffered commands from the queue. When used to stop a move deceleration rate is controlled by the AM (Max Acceleration) parameter. If the “D” parameter is used deceleration rate is controlled by either DE (with “Feed” moves like FL, FP, SH) or JA (when jogging). Command Details: Structure SK{Parameter #1} Type IMMEDIATE Usage WRITE ONLY Non-Volatile NO Register Access None Parameter Details: Parameter #1 Deceleration rate - units letter - range D = deceleration rate set by DE or JA command no parameter = deceleration rate set by AM command Examples: Command Drive sends SK - SKD - 920-0002 Rev. J 12/2014 Notes Stop motion immediately using the deceleration rate set by the AM command and erase the contents of the queue Stop motion immediately using the deceleration rate set by the DE command (or JA if jogging) and erase the contents of the queue 246 Host Command Reference SM - Stop Move Compatibility: Q drives only See also: AM, DE, JL, SK, ST, QK commands Stops any type of move in progress* such as FL or CJ. This command acts like the ST (Stop) command except it will not stop a wait operation (like WD, WI, WP, or WT) and it can be part of a stored Q program. The contents of the queue are not affected by the SM command * = Exception: SH NOTE: Requires Multi-Tasking to be enabled (MT1). By default Motion-Tasking is disabled, which means the current move must complete before any subsequent buffered command (such as SM) can execute. With Multi-Tasking enabled, subsequent commands may be processed while a move is in progress and the SM command will execute properly. Command Details: Structure SM(Parameter #1) Type BUFFERED Usage WRITE ONLY Non-Volatile NO Register Access None Parameter Details: Parameter #1 Deceleration rate - units letter - range D = deceleration rate set by DE command or JL command (if jogging) M = deceleration rate set by AM command Examples: Command Drive sends SMD - Notes Stop motion immediately using the deceleration rate set by the DE command or the JL command (if jogging) SMM - Stop motion immediately using the deceleration rate set by the AM command 247 920-0002 Rev. J 12/2014 Host Command Reference SO - Set Output Compatibility: All drives See Also: IL, IH, IO commands Sets an output to the given condition. Care must be taken when using outputs on the main driver board because those outputs are by default programmed for dedicated purposes (Alarm, Brake, Motion). Use the AO, BO and MO commands to reconfigure main driver board output usage to general purpose before using the SO command with those outputs. Command Details: Structure SO(Parameter #1) Type BUFFERED Usage WRITE ONLY Non-Volatile NO Register Access None Parameter Details: (See Appendix F: Working With Inputs and Outputs) Examples: Command SO1L SO2H Drive sends - - Notes Set output 1 low (closed) Set output 2 high (open) SOY1L SOY2H - - Set main driver board output 1 low (closed) Set main driver board output 2 high (open) 920-0002 Rev. J 12/2014 248 Host Command Reference SP - Set Position Compatibility: All drives Affects: FP commands See Also: EP, FP commands Sets or requests the motor’s absolute position. To ensure that the internal position counter resets properly, use EP immediately prior to sending SP. For example, to set the position to zero after a homing routine, send EP0 immediately followed by SP0. Command Details: Structure SP{Parameter #1} Type BUFFERED Usage READ/WRITE Non-Volatile NO Register Access None Parameter Details: Parameter #1 Absolute position - units encoder counts - range +/- 2,147,483,647 Examples: Command Drive sends SP100 - SP SP=100 Notes Set absolute position offset to 100 encoder counts EP0 SP0 (Step 1) reset internal position counter (Step 2) reset internal position counter - - 249 920-0002 Rev. J 12/2014 Host Command Reference SS - Send String Compatibility: All drives with RS-232 communication Instructs drive to respond with the desired character string (up to 4 characters). This command is useful for letting the host system know via the serial port when a sequence of commands has finished executing. Multiple SS commands can be placed into the queue at any time, though care should be taken when using this command to avoid serial data collisions. For example, the host system should avoid sending commands to the drive while expecting a character string (from a previously buffered SS command). NOTE: Due to the possibility of data collisions related to unscheduled communication from slave devices, this command is nonfunctional for RS-485 drives. Command Details: Structure SS(Parameter #1) Type BUFFERED Usage WRITE ONLY Non-Volatile NO Register Access None Parameter Details: Parameter #1 String of characters - units any printable characters - range up to 4 characters Examples: Command SSdone 920-0002 Rev. J 12/2014 Drive sends done Notes String “done” sent when SS command is executed 250 Host Command Reference ST - Stop Compatibility: All drives See Also: SK, SM commands Halts the current buffered command being executed, but does not affect other buffered commands in the command buffer. When used to stop a move deceleration rate is controlled by the AM (Max Acceleration) command. If a “D” parameter is used deceleration rate is controlled by either the DE command (with “Feed” moves like FL, FP, and SH) or the JL* command (when jogging). *Note that setting the JA command also sets the JL command. If distinct JA and JL values are required always set JL after setting JA. Command Details: Structure ST{Parameter #1} Type IMMEDIATE Usage WRITE ONLY Non-Volatile NO Register Access None Parameter Details: Parameter #1 Deceleration rate - units letter - range D = deceleration rate set by DE or JA command no parameter = deceleration rate set by AM command Examples: Command ST STD Drive sends - command - JA command Notes Stop motion immediately using the deceleration rate set by the AM Stop motion immediately using the deceleration rate set by the DE or 251 920-0002 Rev. J 12/2014 Host Command Reference TD - Transmit Delay Compatibility: All drives Affects: RS-232 & RS-485 Serial Communications See Also: BR, PB & PR commands Sets or requests the time delay used by the drive when responding to a command that requests a response. Typically this is needed when using the 2-wire RS-485 interface (Half-duplex). Because the same wires are used for both receive and transmit a time delay is usually needed to allow transition time. The Host device’s RS-485 specification must be understood to determine the time delay needed. Command Details: Structure TD{Parameter #1} Type BUFFERED Usage READ/WRITE Non-Volatile Yes Register Access None Parameter Details: Parameter #1 Time value - units milliseconds - range 0 - 32767 - default 10 Examples: Command Drive sends TD10 - TD TD=10 920-0002 Rev. J 12/2014 Notes Set Tx time delay to 10 milliseconds 252 Host Command Reference TI - Test Input Compatibility: Q drives only Affects: Condition Code See also: QJ, TR commands Tests a digital or analog input against the given input state. If the input is in the state the condition code is set to “T” (true). If not the condition code is set to “F” (false). The condition code is found in read-only register ‘h’ and is most commonly used in conditional jump (QJ) commands. The input is tested, and the jump is performed only if that input is in a specific state. Command Details: Structure TI(Parameter #1) Type BUFFERED Usage WRITE ONLY Non-Volatile NO Register Access None Parameter Details: (See Appendix F: Working With Inputs and Outputs) Examples: Command TI4L QJT15 Drive sends - - Notes Test input 4 for a low state Jump to line 15 if the previously tested input is “True” 253 920-0002 Rev. J 12/2014 Host Command Reference TO - Tach Output Compatibility: TSM and M2 drives Defines the drive’s Motion Output digital output function. Note : This commands only support TSM drive, and MO command with parameters 4 to 8 is not useful any more for Tach output. For TSM-P output 3# and TMS-S/Q output 4#: 3: Output is not used as a Motion Output and can be used for a general purpose output. 4: Output is used as a Tach Output at 100 pulses/rev with 1.8 degree step motor. 5: Output is used as a Tach Output at 200 pulses/rev with 1.8 degree step motor. 6: Output is used as a Tach Output at 400 pulses/rev with 1.8 degree step motor. 7: Output is used as a Tach Output at 800 pulses/rev with 1.8 degree step motor. 8: Output is used as a Tach Output at 1600 pulses/rev with 1.8 degree step motor. 12: Output is closed (energized) when motor is not moving(static inposition). 13: Output is open (de-energized) when motor is not moving(static inposition). Command Details: Structure TO{Parameter #1} Type BUFFERED Usage READ/WRITE Non-Volatile YES Register Access None Parameter Details: Parameter #1 Output Usage (see above) - units integer code - range see above Examples: Command Drive sends TO12 - TO TO=12 920-0002 Rev. J 12/2014 Notes Motion Output will close when the motor is not moving 254 Host Command Reference TR - Test Register Compatibility: Q drives only Affects: All data registers See also: CR, TI, RI, RD, RM, RL, QJ commands Tests a data register against a given data value. The result of the test is the setting of the condition code, which can be used for conditional programming (see QJ command). All conditions codes can be set by this command. See “QJ” command for more details. Command Details: Structure TR(Parameter #1)(Parameter #2) Type BUFFERED Usage WRITE ONLY Non-Volatile NO Register Access All data registers Parameter Details: Parameter #1 Data register - units data register assignment - range All data registers Parameter #2 Test value - units integer - range +/- 2,147,483,647 (long data registers) +/- 32,767 (short data registers) Examples: Command TR15 Drive sends - Notes Test user-defined register “1” against the value 5 255 920-0002 Rev. J 12/2014 Host Command Reference TS - Time Stamp Compatibility: Q drives only Affects: Data Register “W” See also: RC, WD, All register commands Transfers the oldest Time Stamp value from the time stamp buffer into the “W” data register. The time stamp value is a time value in milliseconds, recorded between two input triggers when using the RC command. Each time a defined input condition is “True” (triggered), the elapsed time from the previous input is stored in the time stamp buffer. The time stamp buffer is 8 words deep and acts as a FIFO buffer. The “I” data register, used by the RC command, records when an input trigger has occurred. Sending the RC command clears the time stamp buffer. Executing the TS command removes the oldest time value from the time stamp buffer and places it in the “W” Data Register where it can be used. With each execution of the TS command a time value is transferred, until the end of the time stamp buffer is reached. If a TS is sent with no time values in the time stamp buffer a “0” is placed in the “W” data register. Command Details: Structure TS Type BUFFERED Usage WRITE ONLY Non-Volatile NO Register Access “W” (039) Units milliseconds Example: This sample Q program illustrates the interaction of the RC and TS commands. After initialization, the program waits for a falling edge event on input X3, at which point a 5 second timer begins counting down. During this delay, the user may trigger X3 an arbitrary number of times. After 5 seconds, the motor will execute a series of 5000-step moves, with the delay between each corresponding to the delay between switch closures on X3. That is, if the user trips X3 four times waiting 1 second between each event, the motor will execute four 5000-step moves with a 1 second dwell between each. LABEL2 LABEL1 920-0002 Rev. J 12/2014 MT 1 EG 20000 AC 250 DE 250 VE 5 FI 3 200 RX I 0 RC X3F WI X3F WT 5.00 TS RD I FL 5000 TR I 1 QJ L #LABEL1 TS RM W 1 WD 1 QG #LABEL2 NO Multi-tasking ON 20,000 steps/rev Filter input 3 for 200 processor ticks Zero the “I” register Setup the “I” register for input X3 Wait for input X3 Wait 5 seconds >>> trigger inpuxt X3 a few times Throw away first time stamp Decrement “I” register Feed 5000 steps Test “I” against 1 Jump to end if “I” less than 1 Time stamp Move “W” into “1” Delay for “1” milliseconds Go to Label 2 Stop program 256 Host Command Reference TT - Pulse Complete Timing Compatibility: SSM, TSM, TXM, SS, SSAC and M2 drives This parameter is used to define a time duration. It is used to determine whether the driver has finished receiving all pulses or not. If the driver has not receive any pulses for the period that is longer than TT defined time, then the driver will define no pulses is sent to drive. Command Details: Structure TT{Parameter #1} Type BUFFERED Usage READ/WRITE Non-Volatile YES Register Access None Parameter Details: Parameter #1 Pulse Complete Timing - units 50µsec, (125µsec for M2) - range 5~20000 -default 2000 - units integer - range +/- 2,147,483,647 (long data registers) +/- 32,767 (short data registers) Examples: Command TT1000 Drive sends - TT TT=1000 Notes Sets the pulse complete timing to 50ms for pulse receive complete determination. PD Target Position Actual Position PE TT In Motion In Position 257 920-0002 Rev. J 12/2014 Host Command Reference TV - Torque Ripple Compatibility: M2 drives Affects: Output #1 See also: MO, PE command The torque ripple value around the targeted torque. If the difference between the actual torque and targeted torque is always within the ripple value during the time duration specified by PE command, the driver will then define actual torque meets its target torque value. Command Details: Structure TV{Parameter #1} Type BUFFERED Usage READ/WRITE Non-Volatile YES Register Access None Parameter Details: Parameter #1 See above - units Amps - range 0~4.50 -default 0 Examples: Command TV1 TV 920-0002 Rev. J 12/2014 Drive sends % TV=1 Notes Set the torque ripple around the targeted torque to 1Amps The torque ripple around the targeted torque is 1Amps 258 Host Command Reference VC - Velocity Change Compatibility: All drives Affects: FC, FD commands Sets or requests the “change speed” for FC and FD moves.. Command Details: Structure VC{Parameter #1} Type BUFFERED Usage READ/WRITE Non-Volatile Yes Register Access “U” (037) Parameter Details: Parameter #1 Move velocity - units rev/sec - range BLu, SV, STAC6, ST-Q/Si, ST-S: 0.0042 - 133.3333 (resolution is 0.0042) STM: 0.0042 - 80.0000 (resolution is 0.0042) Examples: Command Drive sends VC5 - VC VC=5 Notes Set change velocity to 5 rev/sec 259 920-0002 Rev. J 12/2014 Host Command Reference VE - Velocity Compatibility: All drives Affects: FC, FD, FE, FL, FM, FS, FP, FY, SH commands Sets or requests shaft speed for point-to-point move commands like FL, FP, FS, FD, SH, etc. Command Details: Structure VE{Parameter #1} Type BUFFERED Usage READ/WRITE Non-Volatile Yes Register Access “V” (038) Parameter Details: Parameter #1 Move velocity - units rev/sec - range BLu, STAC6, : 0.0042 - 133.3333 (resolution is 0.0042) SV: 0.0042 - 136 (resolution is 0.0042) ST-Q/Si, ST-S , STM, STAC5: 0.0042 - 80.0000 (resolution is 0.0042) Examples: Command Drive sends VE2.525 - VE VE=2.525 920-0002 Rev. J 12/2014 Notes Set move velocity to 2.525 rev/sec 260 Host Command Reference VI - Velocity Integrator Constant Compatibility: Servo drives only Affects: Jog commands See also: VP & JM commands Sets or requests the velocity-mode (“JM2”) servo control integrator gain term. Gain value is relative: 0 = no gain, 32767 = full gain. VI minimizes steady state velocity errors. Command Details: Structure VI{Parameter #1} Type BUFFERED Usage READ/WRITE Non-Volatile Yes Register Access None Parameter Details: Parameter #1 Velocity integrator gain value - units integer (no specific units) - range 0 - 32767 (0% - 100%) Examples: Command Drive sends VI5000 - VI VI=5000 Notes Set velocity integrator gain to 5000 261 920-0002 Rev. J 12/2014 Host Command Reference VL - Voltage Limit Compatibility: High-voltage Stepper Drives (STAC5, STAC6 only) Specifies the maximum voltage that will be applied to the motor by the PWM outputs on the drive. Normally this is set to 100% for modern step motors. Some inexpensive motors are constructed with less robust winding insulation, and require this voltage to be limited. In these rare cases, VL may be lowered. This will directly impact motor performance, but will allow the drive to control a wider variety of motors. Command Details: Structure VL{Parameter #1} Type BUFFERED Usage READ / WRITE Non-Volatile YES Register Access None Parameter Details: Parameter #1 PWM Duty Cycle - units - range 10 - 1000 (1.0% - 100.0%) Examples: Command VL1000 VL Drive sends - VL = 1000 VL500 - VL VL=500 920-0002 Rev. J 12/2014 Notes Maximum voltage applied to the motor: 100.0% (default) Maximum voltage applied to the motor: 50.0% 262 Host Command Reference VM - Maximum Velocity Compatibility: Servo drives Affects: Analog Velocity mode See Also: AM, VC, VE commands Sets or requests the maximum motor velocity in rev/sec. Used in analog velocity mode to limit the maximum speed of the drive. Command Details: Structure VM{Parameter #1} Type BUFFERED Usage READ/WRITE Non-Volatile YES Register Access None Parameter Details: BLu, SV Parameter #1 Move velocity - units rev/sec (rps) - range 0.0042 - 133.3333 (resolution is 0.0042 rev/sec) Examples: Command Drive sends VM50 - VM VM=50 Notes Set maximum move velocity to 50 rev/sec 263 920-0002 Rev. J 12/2014 Host Command Reference VP - Velocity Mode Proportional Constant Compatibility: Servo drives only Affects: Jog commands See also: VI & JM commands Sets or requests the velocity-mode servo control Proportional gain term. Gain value is relative: 0 = no gain, 32767 = full gain. VP minimizes velocity error when in velocity mode 2 (see JM command). Command Details: Structure VP{Parameter #1} Type BUFFERED Usage READ/WRITE Non-Volatile Yes Register Access None Parameter Details: Parameter #1 Velocity mode proportional gain - units integer - range 0 - 32767 (0% - 100%) Examples: Command Drive sends VP5000 - VP VP=5000 920-0002 Rev. J 12/2014 Notes Set velocity mode proportional gain to 5000 264 Host Command Reference VR - Velocity Ripple Compatibility: M2 drives Affects: Output #2 See also: MO, PE commands The velocity ripple value around the targeted velocity. If the difference between the actual velocity and targeted velocity is always within the ripple value, the driver will then define actual velocity meets its target velocity value. Command Details: Structure VR{Parameter #1} Type BUFFERED Usage READ/WRITE Non-Volatile YES Register Access None Parameter Details: BLu, SV Parameter #1 Velocity Ripple (see above) - units rps - range 0~136 Examples: Command VR1 VR Drive sends % VR=1 Notes Set the velocity ripple around the targeted velocity to 1rps The velocity ripple around the targeted velocity is 1rps 265 920-0002 Rev. J 12/2014 Host Command Reference WD - Wait Delay Compatibility: Q drives only Affects: None See also: WI, RX commands Causes a time delay to occur using a time value from a given data register. The resolution is in milliseconds. Only up to 15 bits of the data register are used, giving a maximum wait time of 32 seconds. Command Details: Structure WD(Parameter #1) Type BUFFERED Usage WRITE ONLY Non-Volatile NO Register Access None Parameter Details: Parameter #1 Data register - units data register assignment - range All Read/Write and User-Defined data registers Examples: Command WD5 920-0002 Rev. J 12/2014 Drive sends Notes - Wait the number of milliseconds indicated by the value in userdefined data register “5” 266 Host Command Reference WI - Wait for Input Compatibility: All drives Affects: Use of “Jog” Inputs See Also: FI, JE, JD, WD, WM, TI commands Waits for an input to reach the given condition. Allows very precise triggering of moves if a WI command is followed by a move command. When JE (Jog Enable) is active the drive’s “jog” inputs can be used to jog the motor. JD disables jogging using inputs. (See your drive’s User’s Manual for designation of “jog” inputs). Command Details: Structure WI(Parameter #1) Type BUFFERED Usage WRITE ONLY Non-Volatile NO Register Access None Parameter Details: (See Appendix F: Working With Inputs and Outputs) Examples: Command Drive sends WI3R - Notes Wait for input 3 to go high (rising edge) before proceeding to the next command in the queue 267 920-0002 Rev. J 12/2014 Host Command Reference WM - Wait on Move Compatibility: Q drives only Affects: Queue execution See also: MT When in multi-tasking is turned on (see MT command) this command will block execution of subsequent commands until the previously initiated move is complete. This can be any type of move such as “Feeds”, “Jogging” or the “Hand Wheel” (encoder following). Command Details: Structure WM Type BUFFERED Usage WRITE ONLY Non-Volatile NO Register Access None Examples: Command WM 920-0002 Rev. J 12/2014 Drive sends - complete Notes Causes queue execution to wait until any move in progress is 268 Host Command Reference WP - Wait Position Compatibility: Q drives only Affects: Multi-velocity, or complex, move profiles See Also: FC, DC, VC, MT commands When multi-tasking is turned on (“MT1”), this command is used in conjunction with the DC command to block program execution until a specific position(s) is reached during a move. When the position(s) specified by the DC command is reached program execution continues. Common example: This command is used as a “separator” in changing the motor speed of multi-velocity move profiles created using the FC command. The normal FC command provides for one speed change using values determined by DC and VC commands executed prior to the FC command. Additional speed changes can be added after an FC command is initiated by using the WP command to separate additional DC and VC commands. See the example below. NOTE: This command, along with the ability to create multi-velocity move profiles with the FC command, is only available in BLu servo drive firmware revisions 1.53C or later. This command is available in all firmware revisions of STAC stepper drives. Command Details: Structure WP Type BUFFERED Usage WRITE ONLY Non-Volatile No Register Access None Examples: Command Drive sends DI100000 - VE10 - DC80000 - VC15 - FC - WP - DC60000 - VC9 - WP DC40000 - VC1 - WP - DC20000 - VC19 - Notes Overall move distance set to 100,000 counts Initial move speed set to 10 rps 1st change distance set to 80,000 counts 1st change speed set to 15 rps Initiate FC command (complex move) 2nd change distance set to 60,000 counts 2nd change speed set to 9 rps 3rd change distance set to 40,000 counts 3rd change speed set to 1 rps 4th change distance set to 20,000 counts 4th change speed set to 19 rps 269 920-0002 Rev. J 12/2014 Host Command Reference WT - Wait Time Compatibility: All drives Causes a time delay in seconds. The resolution is 0.01 seconds with the largest value being 320.00 seconds. Command Details: Structure WT(Parameter #1) Type BUFFERED Usage WRITE ONLY Non-Volatile NO Register Access None Parameter Details: Parameter #1 Time - units seconds - range 0.00 - 320.00 (resolution is 0.01 seconds) Examples: Command WT2.25 920-0002 Rev. J 12/2014 Drive sends - Notes Causes time delay of 2.25 seconds 270 Host Command Reference ZC - Regen Resistor Continuous Wattage Compatibility: BLuAC5 and STAC6 drives only Sets or requests the regeneration resistor wattage value. BLuAC and STAC drives dynamically calculate the continuous wattage induced into an external regeneration resistor and must know the continuous wattage rating of the regen resistor to do this effectively. Command Details: Structure ZC{Parameter #1} Type BUFFERED Usage READ/WRITE Non-Volatile Yes Register Access None Parameter Details: Parameter #1 Continuous wattage value of regen resistor - units Watts - range 1 - 1000 Examples: Command Drive sends ZC250 - Notes External regen resistor with value of 250 continuous watts is connected to the drive 271 920-0002 Rev. J 12/2014 Host Command Reference ZR - Regen Resistor Value Compatibility: BLuAC5 and STAC6 drives only Sets or requests the regeneration resistor value. BLuAC and STAC drives dynamically calculate the continuous wattage induced into an external regeneration resistor and must know the value of the regen resistor to do this effectively. Command Details: Structure ZR{Parameter #1} Type BUFFERED Usage READ/WRITE Non-Volatile Yes Register Access None Parameter Details: Parameter #1 Value of regen resistor - units Ohms - range 25 - 100 Examples: Command ZR50 920-0002 Rev. J 12/2014 Drive sends - Notes 50 ohm external regen resistor connected to drive 272 Host Command Reference ZT - Regen Resistor Peak Time Compatibility: BLuAC5 and STAC6 drives only Sets or requests the regeneration resistor time constant. Decides the peak time that the resistor can tolerate full regeneration voltage. When regeneration occurs the full regeneration voltage of 400 volts is applied across the resistor. The peak wattage is typically very high, for example with the built-in 40 ohm resistor the peak wattage is 4000 Watts. Power resistors will tolerate this for only a brief period of time. In the case of the built-in 40 ohm/ 50 Watt regen resistor it is only 0.3125 seconds. The ZT value provides the resistor time constant used to create the “filter” for calculating average wattage in the regen resistor. Command Details: Structure ZT{Parameter #1} Type BUFFERED Usage READ/WRITE Non-Volatile Yes Register Access None Parameter Details: Parameter #1 Maximum time for peak regen - units 0.25 milliseconds - range 1 - 32000 Examples: Command Drive sends ZT1250 - ZT ZT=1250 Notes Regen resistor peak time set to 0.3125 seconds 273 920-0002 Rev. J 12/2014 Host Command Reference Data Registers Many of the commands listed in this reference function by transferring data to a drive for later use. These data values are stored in data registers within the drive and remain there until new commands change the values or power is removed from the drive. For example, if you send the Velocity command “VE10”, a maximum move speed of 10 rev/sec is placed in the data register for velocity. You can then execute as many FL (Feed to Length), FP (Feed to Position) or FS (Feed to Sensor) move commands as you’d like without sending another VE command: the move speed of 10 rev/sec will remain in the velocity data register until you change it. In addition to the data register for velocity, there are registers for move acceleration (AC command, “A” register), deceleration (DE command, “B” register) and move distance (DI command, “D” register). There are also registers for limit sensors (DL command), motor current (CC command), encoder resolution (ER command), motor position (SP command) and encoder position (EP command). There are 75 data registers in all. See the following Data Register Assignments section for a complete listing of data registers available in your drive. Not all commands function by transferring a data value into a register. Conversely, not all data registers are associated with a command. To access data registers that are not associated with a command, you can use a register’s unique character assignment. See the Data Register Assignments on the following pages for a listing of data registers and their character assignments. When accessing a data register using its character assignment you use the RL (Register Load Immediate) or RX (Register Load Buffered) commands. These commands allow you to load data values into a register as well as read back the contents of a data register. For example, we set the move speed to 10 rev/sec in the first paragraph of this page by using the velocity command “VE10”. You can accomplish the same thing by using the RL command and the character assignment for the velocity data register, “V”. By sending “RLV2400” to the drive (see units of “V” register in Data Register Assignments section) you set the move speed to 10 rev/sec. There are four categories of data registers available with your drive: Read-Only, Read/Write, User-Defined, and Storage. The last two categories, User-Defined and Storage, are only for use with Q drives. Read-Only data registers Read-Only data registers are predefined registers that contain information about drive parameters, settings, and states. These include registers for commanded current, encoder position, analog input levels, drive temperature, internal bus voltage, and more. You cannot transfer data values to a Read-Only data register; you can only read the contents of them (see RL and RX commands). Read-Only registers are assigned to lowercase letters. Read/Write data registers Read/Write data registers are predefined registers that contain drive and move parameters that can be set by the user. These parameters include acceleration rate, velocity, move distance, continuous current setting, peak current setting, and more. Many of the Read/Write registers are associated with a particular command, so you can read their contents or load data into them with RL, RX, or that parameter’s particular command. Read/ Write registers are assigned to upper-case letters. User-Defined data registers User-Defined data registers are read/write registers that are not predefined. These registers are only used with Q drives. They allow you to create more flexible and powerful Q programs through math functions, incrementing and decrementing, conditional processing, and more. These registers are assigned to single-digit numbers and other ASCII characters. Storage data registers Each Q drive comes with 100 non-volatile Storage data registers, which can be used to save the contents of other data registers to non-volatile memory. For example, since none of the User-Defined data registers are non-volatile, a user may want to save the values of some of these registers to memory. This can be done by transferring their values to Storage registers (called Writing) before power down of the drive. Then at the next 920-0002 Rev. J 12/2014 274 Host Command Reference power up, these values can be loaded back into the User-Defined registers from the Storage registers (called Reading). Each Storage register can save one data register value, and the Storage registers are numbered 1 to 100. See the RR, RW, and SA commands as well as the Appendix for more information on accessing this section of memory. Using Data Registers The diagram below shows how a drive’s serial port accesses the different volatile (Read-Only, Read/Write, User-Defined) and non-volatile (Storage) data registers within a drive. The user can Load and Upload data register values using the RL, RX, and RU commands via the drive’s serial port(s). Read-Only data registers can be uploaded but not loaded. For Q drives only, non-volatile memory is available for data registers in the form of Storage registers. Moving the contents of the volatile data registers back and forth between the non-volatile Storage registers is done with the RW and RR commands. See below for more details. Loading (RL, RX) Accessing data registers is done by Loading data into a register, and Uploading data from a register. Loading a data register can be done from a host command line or from a line in a program. To load a register from a host command line use the RL (Register Load) command. This command can be executed at any time, even while a drive is running a program. The RL command is an immediate command. To load a register within a Q program use the RX command, which is a buffered version of Register Load. 275 920-0002 Rev. J 12/2014 Host Command Reference Uploading (RL, RU) Uploading data registers can only be done from a host command line, not within a program. There are two commands available for uploading register values. RL is used to upload one register value at a time, while RU can be used to upload a single register value or an array of register values. Both RL and RU are immediate commands, and therefore can be executed while a program is running. The RU command can request up to 10 data register values in sequence back from the drive. This is great when an array of information is required at one time. Writing Storage registers (RW) (Q drives only) Writing a data register allows the user to store data register values in non-volatile memory. To write a data register we use the RW (Register Write) command. There are 100 storage locations for data registers in NV memory. Note that the user must keep track of where data registers are stored because the NV memory locations are not associated with any specific data register. Reading Storage registers (RR) (Q drives only) Reading a data register allows the user to move data previously saved in NV memory into a data register. To read a data register we use the RR (Register Read) command. Reading is typically done in the midst of a Q program. The following sub-sections describe additional usage of data registers within Q drives only. Moving data registers (RM) (Q drives only) Data register values can be moved from one register to another. This is done with the RM (Register Move) command. When executing an RM command, the contents of the originating data register are retained. Contents of read-only registers can be moved into read/write registers and user-defined registers. However, as implied by its label, no register values can be moved into read-only registers. Attempting to do so will have no effect and no error code is generated. Incrementing/Decrementing (RI, RD) (Q drives only) Read/write and user-defined registers can be incremented and decrmented by “1”. Two commands are used for these functions: the RI (Register Increment) and RD (Register Decrement) command. NOTE: Incrementing past the range of a data register will cause the value to wrap around. Counting (RC, “I” register) (Q drives only) A special data register, the “I” register (Input Counter), is designated for counting input transitions and input state times of a selected digital input. The “I” register is a read/write register that can be used with all other register functions including math and conditional testing. The RC (Register Counter) command is used to assign digital inputs to register counting. There are four different input states that can be chosen and that have different effects on input counting. When using the “high” or “low” level states the counter acts as a “timer” with a resolution of 100 microseconds (SV servo drives and all stepper drives) or 125 microseconds (BLu servo drives). Edge type states like “falling” or ‘”rising” are used for input counting. (See details of the RC command in the Q Command Reference). Math & Logic (R+, R-, R*, R/, R&, R|) (Q drives only) Math and logic functions can be performed on data registers. Math is limited to integer values. Some of the math functions are also limited to 16-bit values. When doing math only one operation can be done per instruction. Math and logic results are stored in the Accumulator register, “0”. This register is part of the userdefined register set. Math functions include Add, Subtract, Multiply and Divide. Logic functions include Logical AND and Logical OR. 920-0002 Rev. J 12/2014 276 Host Command Reference Conditional Testing (CR, TR) (Q drives only) When constructing complex programs it is usually necessary to do some conditional processing to affect program flow. Two commands are available for evaluating a data register for conditional processing, the TR (Test Register) and CR (Compare Register) commands. The TR command will compare the “First” value of a given data register against a “Second” immediate value. The CR command compares the “First” value of a given data register against the “Second” value of another data register. When using the TR and CR commands an internal “Condition” register is set with the result. The result can be: “True” the “First” value is either positive or negative “False” the “First” value is not a value (it’s zero) “Zero” the “First” value equals “0” “Positive” the “First” value is “positive” “Negative” the “First” value is “negative” “Greater Than” the “First” value is more positive than the “Second” value “Less Than” the “First” value is more negative than the “Second” value “Equal to” the “First” and “Second” values are equal “Unequal to” the “First” and “Second’ values are not equal NOTE: The QJ (Queue Jump) command is designed to use the “Condition Codes” above for jumping. The Condition Code can also be accessed via the “h” register. Data Register Assignments What follows is a listing of all the data registers available with MOONS’ drives. In the tables below, “Ch.” denotes the data register’s character assignment, and “Description” gives the name of the data register. The column “3-digit” denotes the register’s 3-digit equivalent numerical assignment (see PR command, bit 5); “Data Type” designates whether the data register is a 16-bit word (Short) or a 32-bit word (Long); “Units” shows how a data register’s contents are used by the drive; and, “Compatibility” shows which drives can make use of the given register. NOTE: When programming a Q drive with the Q Programmer software only the character assignment of the register can be used. When communicating to a Q drive via one of its serial ports, either the character assignment or the 3-digit numerical assignment can be used. Read-Only data registers: a - z Many of the Read-Only data registers can be read with a specific command. In the tables below, associated commands are shown in parentheses in the “Description” column. Ch. Description a Analog Command value (IA) 3-digit 049 Data Type Units Short BLu, SV, STAC6, ST-Q/Si: 32760 = +10V; -32760 = -10V ST-S, STM: 16383 = +5V; 0 = 0V* Compatibility All drives *Note that the “a” register is affected by the AV (Analog Offset) command, so the range may vary beyond 0 to 16383. b Queue Line Number 050 Short Line # 1 - 62 277 Q drives only 920-0002 Rev. J 12/2014 Host Command Reference c Current Command (IC) 051 Short Servo: 0.01 amps RMS Stepper: 0.01 amps, peak-ofsine All drives d Relative Distance (ID) 052 Long Servo: encoder counts Stepper: steps All drives BLu, STAC6 The “d” register (as well as the ID command) contains the relative move distance used in the last move. This means that the “d” register is only updated at the end of every relative move. SV, ST-Q/Si, ST-S, STM The “d” register (as well as the ID command) contains the immediate relative distance moved since the start of the last or current relative move. This means the “d” register is updated during relative moves and can therefore be polled during a move to see where the motor is with respect to the overall relative move distance. e Encoder Position (IE, EP) 053 Long encoder counts Servo drives and stepper drives with encoders The “e” register can be zeroed by sending the command EP0. f Alarm Code (AL) 054 Long hexadecimal equivalent of binary Alarm Code word (See AL command for details) All drives g Sensor Position 055 Short Servo: encoder counts Stepper: steps All drives The “g” register contains the absolute position of the point at which the input condition is met during moves like FS, FE, SH, and other “sensor-type” moves. It is common practice to use the EP and SP commands to establish known absolute positions within an application or program, which will make the value of the “g” register most meaningful. Otherwise, the absolute position of the motor is zeroed at every power-up of the drive. h Condition Code 056 Short decimal equivalent of binary word (see below) Q drives only The response to the “RLh” command will be the decimal equivalent of the condition code’s binary word. Bit assignments and examples are shown below. Description Bit # TRUE (non-zero) 0 FALSE (zero) 1 POSITIVE 2 NEGATIVE 3 GREATER THAN 4 LESS THAN 5 EQUAL TO 6 UNEQUAL TO 7 920-0002 Rev. J 12/2014 Decimal Value 1 2 4 8 16 32 64 128 278 Host Command Reference Example: Command Drive Sends RLh RLh=149 i Driver Board Inputs (ISX) 057 Short Notes Bits 7 (UNEQUAL TO), 4 (GREATER THAN), 2 (POSITIVE) and 0 (TRUE) are set. Within a Q program the programmer will often have more than one condition to choose from when using the QJ command. The condition FALSE in Q Programmer is represented by bit 0 = 0 (opposite of TRUE). decimal equivalent of binary bit pattern (see below) All drives Details when executing the “RLi” command: BLu, STAC6 The bit pattern of the “i” register breaks down as follows: bit 0 is the state of the encoder’s index (Z) channel, also known as input X0; bits 1 - 7 represent the states of driver board inputs X1 - X7, respectively; bits 8 - 10 represent the states of driver board outputs Y1 - Y3, respectively; and, bits 11 - 15 are not used. For bits 0 - 7 (inputs X0 - X7), a state of “1” means the optically isolated input is open, and a state of “0” means the input is closed. It is the exact opposite for bits 8 - 10 (outputs Y1 - Y3), for which a state of “1” means the optically isolated output is closed, and a state of “0” means the output is open. SV, ST-Q/Si The bit pattern of the “i” register breaks down as follows: bits 0 - 7 represent inputs X1 - X8, respectively; bits 8 - 11 represent outputs Y1 - Y4, respectively; and, bit 12 is the encoder index channel (if present). For bits 0 - 7 and 12 (inputs X1 - X8 and the Index), a state of “1” means the optically isolated input is open, and a state of “0” means the input is closed. It is the exact opposite for bits 8 - 11 (outputs Y1 - Y4), for which a state of “1” means the optically isolated output is closed, and a state of “0” means the output is open. ST-S, STM The bit pattern of the “i” register breaks down as follows: bit 0 represents the encoder index channel (if present), bit 1 represents the STEP input, bit 2 the DIR input, and bit 3 the EN input. Bit 8 represents the drive’s single output, OUT. For bits 0 - 3 (Index, STEP, DIR, and EN inputs), a state of “1” means the optically isolated input is open, and a state of “0” means the input is closed. 279 920-0002 Rev. J 12/2014 Host Command Reference in pu ts se d tu tp ou no ut s se d tu no in no tu se d de x SVAC3, STAC5 The bit pattern of the “i” register breaks down as follows: bits 0-3 represent inputs X1-X4, respectively; bits 8 and 9 represent outputs Y1 and Y2, and bit 14 represents the encoder index channel (if present). For bits 0-3 and 14 (X1-X4 and the Index), a state of “1” means the optically isolated input is open, and a state of “0” means the input is closed. X X X X X X Y2 Y1 X X X X X4 X3 X2 X1 0 0 0000 0 0 00 00 0 0 0 0 Y1 0 in pu ts se d tu tp ou X X XXXXX 0 0 00000 no ut se d tu no de x in no tu se d SSM/TXM-S/Q/IP The bit pattern of the “i” register breaks down as follows: bits 0-2 represent inputs X1-X3 respectively; bit 8 represents output Y1; bit 14 represents the encoder index channel. XXXX X 00 00 0 X3 X2 X1 0 0 0 d ts pu in tu no ut tp ou se s d se tu no de x in no tu se d TSM-P The bit pattern of the “i” register breaks down as follows: bits 0-3 represent inputs X1-X4 respectively; bit 8-10 represents output Y1-Y3 respectively; bit 14 represents the encoder index channel. X X X X X Y3 Y2 Y1 X X X X X4 X3 X2 X1 0 0 000 0 0 0 00 00 0 0 0 0 s ts pu t tp u in ou no tu s in ed de x no tu se d TSM-S/Q/C The bit pattern of the “i” register breaks down as follows: bits 0-7 represent inputs X1-X8 respectively; bit 8-11 represents output Y1-Y4 respectively; bit 14 represents the encoder index channel. X X X X Y4 Y3 Y2 Y1 X8 X7 X6 X5 X4 X3 X2 X1 0 0 00 0 0 0 0 0 0 0 0 0 0 0 0 pu ts ut s in ou tp in de x no tu se d SS The bit pattern of the “i” register breaks down as follows: bits 0-7 represent inputs X1-X8 respectively; bit 8-11 represents output Y1-Y4 respectively; bit 12 represents the encoder index channel. X X X X Y4 Y3 Y2 Y1 X8 X7 X6 X5 X4 X3 X2 X1 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 920-0002 Rev. J 12/2014 280 Host Command Reference ts in pu in de x no tu se d M2 The bit pattern of the “i” register breaks down as follows: bits 0-11 represent inputs X1-X12 respectively; bit 12 represents the encoder index channel. X X X X X12 X11 X10 X9 X8 X7 X6 X5 X4 X3 X2 X1 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 j Analog Input 1 (IA1) 058 Short raw ADC counts, 0 - 32760 16383 = 0 volts for BLu, SV, STAC6, ST-Q/Si drives All drives k Analog Input 2 (IA2) 059 Short raw ADC counts, 0 - 32760 16383 = 0 volts BLu, SV, STAC6, ST-Q/Si only l Immediate Absolute Position 060 Long Encoder counts (servo), or motor steps (stepper). All drives m Command Mode (CM) 061 Short Mode # All drives n Velocity Move State 062 Short State # (see below) All drives Response details to the “RLn” command: Description Decimal Value WAITING 0 RUNNING 1 FAST STOPPING 2 STOPPING 3 ENDING 4 o Point-to-Point Move State 063 Short Comment In velocity mode waiting for a command Doing a velocity move (jogging) Stopping a velocity move (ST or SK with no parameter) Stopping a velocity move (SJ, STD, or SKD) Clean up at end of move (1 PWM cycle, 62 usec) State # (see below) All drives NOTE: The Point-to-Point Move State is only defined during FL, FP, and FS commands. Details when using “RLo” command: Description Decimal Value WAITING 0 WAITING ON BRAKE 1 CALCULATING 2 ACCELERATION 3 CHANGE VELOCITY 4 AT_VELOCITY 5 DECELERATION 6 FAST DECELERATION 7 POSITIONING 8 Comment In position mode waiting for command Waiting for brake to release Doing the calculations for the move Accelerating up to speed Changing the speed (accel or decel) At the desired speed Decelerating to a stop Doing a fast deceleration (ST or SK) Clean up at end of move (1 PWM cycle, 62 usec) p Segment Number 064 Short Segment # 1 - 12 Q drives only q Actual Motor Current (IQ) 065 Short 0.01 Amps Servo drives only r Average Clamp Power 066 Short Watts BLuAC5, STAC6 281 920-0002 Rev. J 12/2014 Host Command Reference s Status Code (SC) 067 Short hexadecimal equivalent of binary Status Code word (See SC command for details) All drives t Drive Temperature (IT) 068 Short 0.1 oC All drives u Bus Voltage (IU) 069 Short 0.1 Volts All drives v Actual Velocity (IV0) 070 Short 0.25 rpm Servo drives and stepper drives with encoder w Target Velocity (IV1) 071 Short 0.25 rpm All drives* *For stepper drives, the “w” register is only updated when Stall Detection or Stall Prevention is turned on. x Position Error (IX) 072 Long encoder counts Servo drives and stepper drives with encoder y Expanded Inputs (IS) 073 Short bit pattern BLu, STAC6 Details when executing the “RLy” command: BLu, STAC6, SVAC3 and STAC5 drives The bit pattern of the “y” register breaks down as follows: bits 0 - 7 represent the states of top board inputs 1 - 8, respectively; bits 8 - 11 represent the states of driver board outputs 1 - 4, respectively; and, bits 12 - 15 are not used. For all I/O bits 0 - 11 (inputs 1 - 8 and outputs 1 - 4), a state of “1” means the optically isolated input or output is open, and a state of “0” means the input or output is closed. Bit 15 represents the ID bit, which simply holds a 1 if the IN/OUT2 or screw terminal I/O board is present and a 0 of it’s not. In other words, for SE, QE and Si drives the ID bit will equal 1. For S and Q drives the ID bit will equal 0. For example, if top board inputs 3 and 5 and top board outputs 1 and 2 were all closed, the response of the drive to the command “RLi” would be “RLi=-29461” (1000 1100 1110 1011). For a more efficient use of the “y” register it is recommended to mask off the ID bit and the other three not used bits. This can be done by using the R& (Register AND) command with the “y” register and a User Defined register set with the value 4095 (0000 1111 1111 1111 1111). Following a register AND operation (&), this will reject the top 4 bits, leaving the rest of the data untouched. For example, the command sequence would look like this. RL14095 R&y1 RL0 z Phase Error 920-0002 Rev. J 12/2014 Load User Defined register “1” with the value 4095 Register AND the “y” and “1” registers Request the value stored in the Accumulator register “0” to which the drive’s response would be RL0=3307. 074 Short encoder counts 282 Servo drives only Host Command Reference Read/Write data registers: A - Z Many of the Read/Write data registers are associated with a specific command. In the tables below, associated commands are shown in parentheses in the “Description” column. NOTE: When using registers pay attention to units. In the case of some Read/Write registers, the units of the register when using the RL and RX command are different than when using the same register’s associated command. For example, the “V” register uses units of 0.25 rpm, but its associated command, VE, uses revs/sec (rps). The reason for this difference is that all registers operate with integer math. On the other hand, when using commands it is often possible to include decimal places which allow for more user-friendly units. Ch. Description 3-digit Data Type Units Compatibility A 017 Short All drives Acceleration (AC) 10 rpm/sec The “A” register units are 10 rpm/sec, which means that the value of the “A” register is equal to 6 times the AC command value. In other words, to achieve an acceleration value of 100 rev/sec/sec send the command RLA600. NOTE: Take care to ensure that this register is never set to zero. The drive may become stuck in a command mode or program loop and/ or refuse to move. See the RL, RM, and RX commands. B Deceleration (DE) 018 Short 10 rpm/sec All drives The “B” register units are 10 rpm/sec, which means that the value of the “B” register is equal to 6 times the DE command value. In other words, to achieve a deceleration value of 100 rev/sec/sec send the command RLB600. NOTE: Take care to ensure that this register is never set to zero. The drive may become stuck in a command mode or program loop and/ or refuse to move. See the RL, RM, and RX commands. C Change Distance (DC) 019 Long counts All drives D Distance (DI) 020 Long counts All drives E Position Offset 021 Long counts Drives with encoder feedback option The “E” register contains the difference between the encoder count and the motor position. This value is most useful with servo drives (Blu / SV) where the resolution of the motor and encoder are the same, and this offset can be useful when working with absolute positions. The register contains the difference in counts between the “e” register and the value set by the “SP” command. F Other Flags 022 Long bit pattern (see below) All drives BLu The value of the “F” register is a hexadecimal sum of various drive states, as shown below. Description Hex Value Decimal Value DISTANCE LIMIT FLAG 0x0001 1 SENSOR FOUND FLAG 0x0002 2 LOWSIDE OVERCURRENT 0x0004 4 HIGHSIDE OVERCURRENT 0x0008 8 Clear flags by sending “RLF0” to the drive. 283 920-0002 Rev. J 12/2014 Host Command Reference SV The value of the “F” register is a hexadecimal sum of various drive states, as shown below. Description Hex Value Decimal Value DISTANCE LIMIT FLAG 0x0001 1 SENSOR FOUND FLAG 0x0002 2 LOWSIDE OVERCURRENT 0x0004 4 HIGHSIDE OVERCURRENT 0x0008 8 OVER CURRENT READING 0x0010 16 BAD CURRENT OFFSET - Phase A 0x0020 32 BAD CURRENT OFFSET - Phase B 0x0040 64 BAD FLASH ERASE 0x4000 16384 BAD FLASH SAVE 0x8000 32768 Clear flags by sending “RLF0” to the drive. STAC6 The value of the “F” register is a hexadecimal sum of various drive states, as shown below. Description Hex Value Decimal Value DISTANCE LIMIT FLAG 0x0001 1 SENSOR FOUND FLAG 0x0002 2 HARDWARE OVERCURRENT 0x0004 4 SOFTWARE OVERCURRENT 0x0008 8 BAD CURRENT OFFSET - Phase A 0x0010 16 BAD CURRENT OFFSET - Phase B 0x0020 32 OPEN WINDING - Phase A 0x0040 64 OPEN WINDING - Phase B 0x0080 128 Clear flags by sending “RLF0” to the drive. ST-Q/Si, ST-S, STM The value of the “F” register is a hexadecimal sum of various drive states, as shown below. Description Hex Value Decimal Value DISTANCE LIMIT FLAG 0x0001 1 SENSOR FOUND FLAG 0x0002 2 LOWSIDE OVERCURRENT 0x0004 4 HIGHSIDE OVERCURRENT 0x0008 8 OVER CURRENT READING 0x0010 16 BAD CURRENT OFFSET - Phase A 0x0020 32 BAD CURRENT OFFSET - Phase B 0x0040 64 OPEN WINDING - Phase A 0x0080 128 OPEN WINDING - Phase B 0x0100 256 LOGIC SUPPLY 0x0200 512 GATE SUPPLY 0x0400 1024 BAD FLASH ERASE 0x4000 16384 BAD FLASH SAVE 0x8000 32768 Clear flags by sending “RLF0” to the drive. Step-Servo The value of the “F” register is a hexadecimal sum of various drive states, as shown below. Description Hex Value Decimal Value DISTANCE LIMIT FLAG 0x0001 1 SENSOR FOUND FLAG 0x0002 2 LOWSIDE OVER CURRENT 0x0004 4 HIGHSIDE OVER CURRENT 0x0008 8 OVER CURRENT READING 0x0010 16 BAD CURRENT OFFSET - Phase A 0x0020 32 BAD CURRENT OFFSET - Phase B 0x0040 64 920-0002 Rev. J 12/2014 284 Host Command Reference OPEN WINDING - Phase A OPEN WINDING - Phase B LOGIC SUPPLY GATE SUPPLY BAD FLASH ERASE BAD FLASH SAVE Clear flags by sending “RLF0” to the drive. 0x0080 0x0100 0x0200 0x0400 0x4000 0x8000 128 256 512 1024 16384 32768 M2 The value of the “F” register is a hexadecimal sum of various drive states, as shown below. Description Hex Value Decimal Value DISTANCE LIMIT FLAG 0x0001 1 SENSOR FOUND FLAG 0x0002 2 LOWSIDE OVER CURRENT 0x0004 4 HIGHSIDE OVER CURRENT 0x0008 8 OVER CURRENT READING 0x0010 16 BAD CURRENT OFFSET - Phase A 0x0020 32 BAD CURRENT OFFSET - Phase B 0x0040 64 OPEN WINDING - Phase A 0x0080 128 OPEN WINDING - Phase B 0x0100 256 SAMPLING ONE 0x0200 512 WIZARD FAILED 0x1000 4096 BAD FLASH ERASE 0x4000 16384 BAD FLASH SAVE 0x8000 32768 Clear flags by sending “RLF0” to the drive. G Current Command (GC) 023 Short 0.01 Amps Servo drives only H Analog Velocity Gain 024 Short +/- 32767 ADC counts BLu servo drives only The “H” register in BLu servo drives is similar to the AG command in all other drives. The “H” register is used to set the motor speed at a given DC voltage in analog velocity mode. It is recommended to make this setting in Quick Tuner, where it is labeled Speed in rev/sec at xx Volts, under the Velocity > Analog Operating Mode. I Input Counter 025 Long counts per edge Q drives only J Jog Velocity (JS) 026 Short 0.25 rpm All drives The “J” register units are 0.25 rpm, which means that the value of the “J” register is equal to 240 times the JS command value. In other words, to achieve a jog speed value of 7 rev/sec send the command RLJ1680. K RESERVED 027 - - - L RESERVED 028 - - - M Max Velocity (VM, servo) Accel/Decel Current (CA, STM Integrated Stepper) 029 Short Servo: 0.01 amps RMS Stepper: 0.01 amps, peak-ofsine Servo drives and STM Integrated Steppers 285 920-0002 Rev. J 12/2014 Host Command Reference N Continuous Current (CC, servo) Running Current (CC, stepper) 030 Short Servo: 0.01 amps RMS Stepper: 0.01 amps, peak-ofsine All drives O Peak Current (CP, servo) Idle Current (CI, stepper) 031 Short Servo: 0.01 Amps RMS Stepper: 0.01 amps, peak-ofsine All drives P Absolute Position Command 032 Long counts All drives Q RESERVED 033 - - - R Steps per Rev* 034 Short counts All drives * Note: R = EG for servo drives. R = EG/2 for stepper drives. S Pulse Counter 035 Long counts All drives The “S” register counts pulses coming into the STEP/X1 and DIR/X2 inputs of the drive. This is particularly useful when in Command Mode 7 (see CM command) or executing an FE (Follow Encoder) command. To zero the “S” register send the command RLS0. T Total Count 036 Long (see below) Q drives only The “T” register is automatically saved at power down and restored at power up. U Change Velocity (VC) 037 Short 0.25 rpm All drives The “U” register units are 0.25 rpm, which means that the value of the “U” register is equal to 240 times the VC command value. In other words, to achieve a change velocity value of 7 rev/sec send the command RLU1680. V Velocity (VE) 038 Short 0.25 rpm All drives The “V” register units are 0.25 rpm, which means that the value of the “V” register is equal to 240 times the VE command value. In other words, to achieve a velocity value of 7 rev/sec send the command RLV1680. W Time Stamp 039 Short 0.001 sec Q drives only X Analog Position Gain (AP) 040 Short Servo: ADC counts/encoder count Stepper: ADC counts/step All drives Y Analog Threshold (AT) 041 Short raw ADC counts All drives Z Analog Offset (AV) 042 Short raw ADC counts All drives 920-0002 Rev. J 12/2014 286 Host Command Reference User-Defined data registers: 0 - 9, other characters Ch. Description 0 Accumulator 3-digit Data Type Units Compatibility 000 Long Q drives only integer The Accumulator register “0” is, aside from being a User-defined data register, the register in which the result of every register math function is placed. For example, if the drive executes the register addition command “R+D1” the result of this operation (i.e. the sum of the values in data registers “D” and “1”) will be placed in the Accumulator “0” register. 1 User-defined 001 Long integer Q drives only 2 User-defined 002 Long integer Q drives only 3 User-defined 003 Long integer Q drives only 4 User-defined 004 Long integer Q drives only 5 User-defined 005 Long integer Q drives only 6 User-defined 006 Long integer Q drives only 7 User-defined 007 Long integer Q drives only 8 User-defined 008 Long integer Q drives only 9 User-defined 009 Long integer Q drives only : User-defined 010 Long integer Q drives only ; User-defined 011 Long integer Q drives only < User-defined 012 Long integer Q drives only = User-defined 013 Long integer Q drives only > User-defined 014 Long integer Q drives only ? User-defined 015 Long integer Q drives only @ User-defined 016 Long integer Q drives only [ RESERVED 043 - - - \ RESERVED 044 - - - ] RESERVED 045 - - - ^ RESERVED 046 - - - _ RESERVED 047 - - - ` RESERVED 048 - - - 287 920-0002 Rev. J 12/2014 Host Command Reference Appendices The following appendices detail various special topics in working with MOONS’ motor drives. Appendix A: Non-Volatile Memory in Q drives Appendix B: Host Serial Communications Appendix C: Host Serial Connections Appendix D: The PR Command Appendix E: Alarm and Status Codes Appendix F: Working with Inputs and Outputs Appendix G: Troubleshooting Appendix H: EtherNet/IP Communications 920-0002 Rev. J 12/2014 288 Host Command Reference Appendix A: Non-Volatile Memory in Q drives The non-volatile memory in Q drives is partitioned into 16 sections. The partitions are dedicated to various elements of a Q drive’s data, and are designated as follows: Partition 1........................... Q Program Segment 1 Partition 2........................... Segment 2 Partition 3........................... Segment 3 Partition 4........................... Segment 4 Partition 5........................... Segment 5 Partition 6........................... Segment 6 Partition 7........................... Segment 7 Partition 8........................... Segment 8 Partition 9........................... Segment 9 Partition 10......................... Segment 10 Partition 11......................... Segment 11 Partition 12......................... Segment 12 Partition 13......................... Drive Parameters Partition 14......................... Alarm History Partition 15......................... NV Data Register Storage Locations 1-100 Partition 16......................... RESERVED The separation of these partitions is important in understanding how the drive writes to non-volatile memory. For example, each time the SA command is executed by the drive, all of the Drive Parameters are re-written to non-volatile memory partition 13. Similarly, each time an RW command is executed by the drive, all of the one hundred NV Data Register Storage Locations are re-written in partition 15, even if only one of the locations is being updated with a new data register value. The significance of these operations becomes clear when we consider that the physical non-volatile memory of the Q drive is limited to approximately 10,000 write cycles. This means that after writing to any one of the 16 partitions 10,000 times, the integrity of the data stored in that memory partition cannot be insured. For this reason, it is not recommended to use the RW or SA commands in stored Q programs. For example, it might be tempting for a user to include an RW command or two in a stored program in such a manner that allows for various data register values to be written to non-volatile memory on a regular basis. The temptation of this is that there won’t be a need to reload register values manually in the case of a power down/up cycle: the register values can simply be loaded back into the program (using RR commands) from non-volatile memory. This is to be avoided, though, because using the RW command (or SA command) in this manner could result in the early failure of the non-volatile memory of the drive. The intended use of the RW command therefore is to be used in the early stages of an application, during startup and programming, to set up a series of nonvolatile register locations that can be read into a stored program using the RR command. The partitions designated for Q Program Segment storage are typically not going to be re-written in a manner similar to the RW and SA commands, as they are only accessed during program/segment downloads during startup and programming of an application. 289 920-0002 Rev. J 12/2014 Host Command Reference Appendix B: Host Serial Communications When a drive is operating in “host mode”, it means that a host device sends commands to the drive (or drives) over a serial connection (or network) and the drive executes the incoming commands. Here are some examples of typical host devices: • A Windows-based PC running MOONS’ software • An industrial PC running a custom-built or other proprietary software application • A PLC with an ASCII module/serial port for sending text strings • An HMI with a serial connection for sending text strings The aim of this appendix is to describe the following aspects of operating an MOONS’ Products motor drive in host mode. • General structure of host serial communications. • Hardware – wiring and connecting a host device to the serial ports of an MOONS’ drive. (Covered in detail in Appendix C). • COM Port Settings – UART settings and Bit Rate (Baud) settings. • Communications Protocol • Communication Details • Communication Errors General structure of host serial communications MOONS’’s host serial communications are based on the common ASCII character set transmitted using standard UARTs over an RS-232 or RS-485 hardware interface. The ASCII character set is used because it is common and well-understood, as well as easy to read. UART (Universal Asynchronous Receiver Transmitter) serial transceivers are available on many types of equipment, including most PCs, and provide a common form of serial communications interface. RS-232 and RS-485 hardware connections are commonly used with UARTs and also provide the easiest and most common form of connectivity. Hardware Details on drive terminals and connectors for wiring each of the available hardware configurations are shown in Appendix C. Below is an overview of the three available configurations. RS-232: This is the easiest method for drive serial communications. Using an MOONS’ supplied adapter/ programming cable (one supplied with each MOONS’ drive) a single drive can be connected directly to any PC with a standard 9-pin RS-232 serial port. Here are some RS-232 highlights: • Easiest to use • Configuration of choice for using MOONS’ software applications such as Q Programmer, Quick Tuner and STAC6 Configurator • Short Cable Lengths • Serial cable provided with each MOONS’ drive • Susceptible to EMI RS-422 (4-wire RS-485): RS-422 was originally designed for high reliability communications in point-topoint configurations. It usually requires a special adapter to work with a PC but is common on many types of controllers such as PLCs and HMIs. Our implementation allows for multi-drop communications with a single master (serial network). Here are some RS-422 highlights: • Relatively easy to use • NOT supported by MOONS’ software applications such as Quick Tuner or STAC6 Configurator. (Q 920-0002 Rev. J 12/2014 290 Host Command Reference Programmer does support RS-422 in a limited fashion). • Permits longer cable Lengths • May require special adaptor • Immune to EMI (when wired properly) RS-485 (2-wire RS-485): Designed for multi-drop serial networks, provides simple wiring, high reliability, and long cable lengths. Here are some RS-485 highlights: • More difficult to use • NOT supported by MOONS’ software applications such as Quick Tuner or Configurator. (Q Programmer does support RS-485 in a limited fashion). • Permits longest cable lengths: up to 1000 feet at low baud rates • May require special adaptor • Fewest wires, smaller cables • Immune to EMI (when wired properly) COM Port Settings UART Settings: We operate our UARTs with the following settings: 1 start bit, 8 data bits, 0 (no) parity bits, and 1 stop bit. Bit rate (baud) Settings: (BR and PB commands): All MOONS’ drives default to 9600 baud from the factory. In most cases this speed is adequate for setup, configuring, programming, as well as host mode communications. If higher baud rates are required the drives can be configured to operate with a different rate using the BR (Bit rate) or PB (Power-up Bit rate) command. In all cases the drive starts up at the factory rate, 9600, and will remain there if the “power-up packet” is acknowledged by the host (see “Drive Startup” below). When the power-up cycle is complete and if the drive has not received the power-up packet, the drive will activate the new baud rate. Selecting a baud rate higher than the default 9600 is dependent on the application. If there is a host device operating a number of drives on a network, a higher speed may be required in order to process all the communication needs. Communications Protocol In general, the protocol for communications between a host device and a drive is quite simple. The drives do not initiate communications on their own, so drives are normally in a state to receive packets from the host. A communications packet, or packet for short, includes all the characters required to complete a command (host to drive) or response (drive to host) transmission. In other words, a host initiates communication by sending a command packet, and the drive responds to that command (if necessary) by sending a response packet back to the host. Command Transmission (host to drive): The transmission of characters to the drive requires the host to send all the required characters that form a packet in a limited time frame. At the start of receiving a packet, the drive begins timing the space between characters. Each time a character is received an internal timer is reset to 200 milliseconds. If the timer reaches zero before the next character in the packet is received the drive will terminate its packet parsing (characters will still go into the receive buffer) and may send out an error response packet depending on the protocol setting. The purpose of the time-out feature is to allow the drive to purge its buffers automatically when a bad transmission occurs. NOTE: This time-out feature limits the usage of host devices such as the Windows application HyperTerminal. We recommend using MOONS’’s SCL Setup Utility instead. This utility sends out an entire command packet with the minimum delay between characters, and includes the packet’s terminating character (carriage return). Command packets are terminated by a Carriage Return (ASCII 13). Response Transmission (drive to host): In response to a command packet from the host a drive can send a response packet. The drive sends out its entire response packet with very limited space between 291 920-0002 Rev. J 12/2014 Host Command Reference characters. At 9600 baud the space between characters is less then 1 bit space (0.0001 seconds). The host system must be able to handle this speed. The space between characters can vary depending on the settings of the PR command (see below). Response packets are terminated by a Carriage Return (ASCII 13). Protocol Settings (PR Command): The PR (Protocol) command offers users the ability to add various features to the overall communications protocol, i.e. tailor the structure of command and response packets to best fit the needs of the application. In general, when a host device sends a command packet to a drive, the drive will either understand the command or not. If the drive understands the command the drive executes the command. If the drive doesn’t understand the command it cannot execute the command. In most cases the host device will want to know whether the drive has understood the command or not, and so the drive can be set to automatically send an Acknowledge (understood) or Negative Acknowledge (not understand) response packet to the host for every command packet received. Along with Acknowledge/Negative Acknowledge (Ack/Nack), the PR command controls a number of other protocol settings. See Appendix D for details on the PR command. Also, the PR command controls whether or not the drive will respond with error codes in the response packet when communications errors occur. Communication Details Transmit Delay: (TD Command): The TD command allows users to define a dwell time in a drive, which is used by the drive to delay the start of transmission of a response packet after the end of reception of a command packet. When using 2-wire RS-485 networks there are times when a drive’s response packet must be delayed until the network is ready for the drive to transmit. Why is this necessary? The answer is because RS-485 networks are by nature “half-duplex”, which means you cannot transmit and receive at the same time. Rather, a host must first transmit, stop, then wait to receive. This is because the host and drive transmitters share the same pair of wires. When transmitting, the device that has the transmission rights must assert its transmitter outputs and therefore take control of the pair. At the same time all other devices on the network must de-assert, or open, their transmitters so as not to interfere with the device that has the rights. Transmitters in this scenario have tri-state outputs: the three states are transmit, open, and receive. Some devices are not as quick in opening their transmitters as others. For this reason it may be necessary for other, faster devices on the network to dwell some time while the slower devices open their transmitters. MOONS’ drives de-assert their transmitters very quickly. Typically it is done within 100 microseconds (.0001 second) after the end of a packet transmission. However it is possible that the host device won’t be this fast, and so the TD command allows users to set the time delay that an MOONS’ drive will delay after receiving a command packet before sending a response packet. Communications Packet: A Communications Packet, or packet for short, includes all the characters required to complete a command or response transmission. This can vary depending on the settings of the PR command. See Appendix D for more on the PR command. All packets are terminated by a Carriage Return (ASCII 13). Drive Startup: At power-up, all MOONS’ drives send out what is called the “power-up packet”. This packet notifies a host of the drive’s presence. After sending the power-up packet the drive waits for a response from the host. This is one of the rare instances in which a drive will initiate communications with the host. This process is necessary for a number of MOONS’ software applications such as Quick Tuner and STAC6 Configurator. The power-up packet is an exception to the ASCII character rule in that all the characters in the packet are binary value. Even if the character is printable its binary value is what is important. The power-up packet consists of three binary characters with the first character being a binary 255 (255 is not a printable ASCII character). This character designates to the software application that the packet is a power-up packet. The following two characters are the firmware version number and the model number of the drive, respectively. Power-Up Packet = (255)(F/W Version)(Model No.) As an example, a BLuAC5-Si with f/w version 1.53 firmware will send out a power-up packet that looks like this: (255)(53)(38). To an ASCII terminal this packet may look like “ÿ5&”. The (255) is the power-up packet designator, the (53) actually stands for f/w version 1.53 (the “1” is implied), and the (38) is an internal model 920-0002 Rev. J 12/2014 292 Host Command Reference number for the “BLuAC5-Si” The power-up packet is always sent at 9600 baud, regardless of the bit rate set by the BR or PB command. If an MOONS’ software application is present it will respond to the power-up packet and communications will continue at 9600 baud. If an MOONS’ software application is not present, the drive’s request made by the power-up packet will time-out and the drive will begin communicating at the saved bit rate (BR or PB command), 9600 or otherwise. Interaction with PM parameter (Power-up Mode): If the drive is currently in power-up modes 1 or 3 (PM1 or PM3), it will be unable to respond to standard SCL commands. In these modes the drive is using a proprietary communication protocol used by Si Programmer (and its interface to the SiNet Hub units) as well as the QuickTuner and Configurator software programs. Standard SCL commands will not be recognized or acted upon by the drive in these modes. If the application requires it, the drive may be temporarily forced into SCL mode through the use of the “double zero.” Double Zero: When the drive initializes, it will send the power-up packet as detailed above. Typically this packet is used only by MOONS’ Products software, but a host device may also use it to force SCL communication in a drive otherwise not configured to do so. The host device must recognize the power-up packet and respond with a simple double zero (00). No carriage return is required. Note that this response must occur within 2 seconds of the power-up packet being sent, but must delay at least 2 milliseconds (0.002 sec). This will force the drive into standard SCL mode and enable serial communication without altering the PM setting of the drive. Communication Errors During the process of sending communication packets between the host and drive(s), two different types of communication errors can occur. Hardware errors: Hardware errors are displayed physically by a drive (via either LEDs or a 7-segment display on the drive, see Appendix F), but no response packet is automatically generated from the drive to the host. Therefore it is the responsibility of the host to check for hardware comm errors using the AL, RS, and/or SC commands. See Appendix F for more details on the AL and SC commands. Once the host has determined the presence of a hardware comm error, the nature of the error can be retrieved using the CE command. Parsing errors: Parsing errors happen when a drive receives a command packet but cannot properly interpret (parse) the command. Parsing errors can automatically generate a response packet from the drive to the host, depending on the settings of the PR command (see Appendix D, PR command, Bit 2). 293 920-0002 Rev. J 12/2014 Host Command Reference Appendix C: Host Serial Connections Introduction When communicating to a drive over its serial port you will always be using one of the following serial connections: RS-232, 2-wire RS-485, or 4-wire RS-485. Out of the box we suggest starting with RS-232 along with the programming cable and software that was supplied with your Q drive, so that you may be communicating to and familiarizing yourself with your drive as quickly as possible. All software from MOONS’ communicate to a drive via the supplied RS-232 programming cable. These software include: Quick Tuner-------------------------used for tuning and configuring servo drives Configurator------------------------used for configuring your stepper drives Q Programmer---------------------create and edit stored Q programs, emulate a host SCL Setup Utility------------------basic host terminal for host emulation If your project calls for a Q drive (or drives) running stored programs, you will use the supplied RS-232 programming cable along with Quick Tuner or Configurator and Q Programmer to setup, configure, and program your drive(s). If your project calls for your drive(s) only running stored programs, you can read up on the RS232 sub-section in this section and not read any more about the other serial connections. However, if your application calls for a serial host controller (PC, PLC, HMI, or other serial device that can act as a host) being able to communicate to the drive(s), you will need to choose one of the three available serial connections. Available Host Serial Connections: RS-232, 2-wire RS-485, 4-wire RS-485 When choosing the best serial connection for your project, the choice may be made for you based on the host controller you plan to use. For example, some devices only communicate via 2-wire RS-485. If you are not restricted by your host controller, here are two guidelines for choosing the best connection. Single or multi-axis If your project calls for communicating to only one drive you can consider any of the three options. If your project calls for communicating to more than one drive you should use 2-wire or 4-wire RS-485. Long communication cables In many applications, the limitation of 50 feet on RS-232 will be sufficient. In applications where the distance between drive and host controller will be more than 50 feet (up to 1000 feet), you will need to choose 2-wire or 4-wire RS-485. A Quick Summary of 2-wire and 4-wire RS-485 connections The 2-wire and 4-wire RS-485 protocols that the drives utilize are based on industry standard RS-485 and RS-422 protocols. Strictly defined, RS-485 is a 2-wire interface that allows multi-node connections limited to halfduplex serial communications. Up to 32 nodes that both transmit and receive can be connected to one network. On the other hand, RS-422 in the strictest definition is a 4-wire point-to-point connection that allows full-duplex serial communications when connected to a single node. RS-422 has one node that is the driver or transmitter and up to 10 nodes that are receivers. RS-422 was not designed for a true multi-node network. 2-wire interfaces require one more significant feature. A network node, master or slave, must be able to tristate its transmitter to allow other nodes to use the network when required. For high speed baud rates this must be done very quickly to avoid communication collisions. 4-wire interfaces can go beyond simple point-to-point communications and be used in multi-node networks if the slave nodes are capable of tri-stating their transmitters as required in the 2-wire networks. Some RS-485 devices (like MOONS’ drives) are set up to do this and can be used in a 4-wire, multi-node configuration. The drives are designed to work in a multi-node environment, and so they use both the standard 2-wire RS-485 connection, and a modified RS-422 (4-wire) connection that has been termed “4-wire RS-485”. This is because unlike the standard RS-422, which is designed for single-node connections, the 4-wire RS-485 used by 920-0002 Rev. J 12/2014 294 Host Command Reference MOONS’ drives allows multiple nodes. NOTE: In general we recommend using half-duplex communications with the drives. Even though the 4-wire RS-485 network can support full-duplex, there is now the capability to have multiple nodes and therefore data collisions might occur. For this reason we recommend limiting communications to half-duplex, even with the 4-wire RS-485 connections. Connecting to your Q drive’s serial port(s) Each drive comes with one or two physical connectors for connecting to a PC or other serial host controller device. One connector is an RJ11 connector (same as a 4-wire phone jack) that is used strictly for RS-232 communications. The second connector is a removable 5-position terminal block for use with 2-wire and 4-wire RS-485 connections. COM Port Settings When using software from MOONS’ Products to communicate to a drive there is no need to worry about COM port settings because the software will take care of them. In applications where a host serial controller will be communicating to a drive via one of it’s serial ports, the COM port settings should be set as follows: 8 data bits, no Parity, 1 stop bit. The default Baud rate is 9600, though this can be changed (see BR and PB commands). Connecting to a PC using RS-232 Each drive comes with a programming cable for use with the drive’s RS-232 port. This cable is made up of two parts, a 7 foot 4-wire cable (looks just like a 7 foot telephone cord), and an RJ11 to 9-pin DSUB adapter. This adapter allows you to connect to the COM port (serial port) of your PC. Here are the general directions for connecting your drive to your computer. • Locate your computer within 6 feet of the drive. • Plug the 9-pin end of the adapter supplied with your drive to the COM1 serial port of your PC. Secure the adapter with adapter’s two screws. If the COM1 port on your PC is already used by something else, you may use the COM2 port of your PC. On some PCs, COM2 will have a 25-pin connector rather than a 9-pin. If this is the case with your PC, and you must use COM2, you will have to purchase a 25 to 9 pin serial adapter at your local computer store. NOTE: If you are using a laptop computer that does not have any COM ports, you will have to use either a USB to Serial adapter or a PCMCIA Serial adapter. There are a variety on the market, and some work better than others. But in general, once you’ve installed one of the adapters your PC will assign the adapter a COM port number. Remember this number when you go to use your MOONS’ software. Also, if you are having troubles with your adapter, contact MOONS’ for help with recommended adapters. • Now take the 7 foot cable and plug one end into the adapter you just attached to your PCs COM port, and plug the other end into the RS-232 (RJ11) jack on the drive. If you need to locate your drive farther from the PC, you can replace the 7 foot cable with any 4-wire telephone cord. Do not exceed 50 feet. WARNING: Never connect an MOONS’ Products drive to a telephone circuit. It uses the same connectors and cords as telephones and modems, but the voltages are not compatible. Connecting to a host using 4-wire RS-485 An MOONS’ drive’s 4-wire RS-485 implementation is a multi-drop network with separate transmit and receive wires. One pair of wires connects the host’s TX+ and TX- signals to each drive’s RX+ and RX- terminals. Another pair connects the RX+ and RX- signals of the host to the TX+ and TX- terminals of each drive. A common ground terminal is provided on each drive and can be used to keep all drives at the same ground potential. This terminal connects internally to a drive’s ground connection, so if all the drives on the 4-wire network are powered form the same supply it is not necessary to connect the logic grounds. You should still connect one drive’s GND terminal to the host’s signal ground. Before wiring the entire system you’ll need to connect each drive individually to the host so that a unique address can be assigned to each drive. (See following sub-section “Before you connect the drive to your system”). Proceed as follows, using the figure below. 295 920-0002 Rev. J 12/2014 Host Command Reference 1. Connect the drive TX+ to the host RX+. 2. Connect the drive TX- to the host RX-. 3. Connect the drive RX+ to the host TX+. 4. Connect the drive RX- to the host TX-. 5. Connect GND to the host signal ground. 6. We recommend a 120 ohm terminating resistor be connected between the Rx+ and Rx- terminals of the drive farthest from the host. NOTE: Proper cable shielding is a must. High voltage, high frequency, high current signals that are present on the servo motor cables can emit a significant amount of electrical interference. Without proper shielding on the communications wiring this interference can disrupt even noise-tolerant differential line drivers. Getting and Connecting an RS-485 4-wire adapter to your PC. If you are using your computer to communicate to the drive(s) and therefore need an RS-485 adapter, model 117701 from Jameco Electronics (800-831-4242) works well. This adaptor is for a 25-pin serial port. If you are like most people and have a 9-pin serial port on your PC, you will also need to purchase Jameco cable 31721. Connect as follows: Adaptor Terminal Drive Terminal 1 RX+ 2 RX3 TX4 TX+ Set the switches on the Jameco adaptor for DCE and TxON, RxON. Don’t forget to plug in the DC power adapter that comes with the unit. Connecting to a host using 2-wire RS-485 An MOONS’ drive’s 2-wire RS-485 implementation is a multi-drop network with one pair of wires that is used for both transmit and receive. To make this type of connection you will first need to jumper the TX+ terminal of a drive to it’s own RX+ terminal, and then do the same with the TX- and RX- terminals. To then connect a drive to the host, you will need to connect the TX+/RX+ terminals of the drive to the host’s TX+/RX+ terminal, and then the TX-/RX- terminals of the drive to the host’s TX-/RX- terminal. We also recommend a 120 terminating resistor be connected between the Tx+ and Tx- terminals of the drive farthest from the host. Here is a diagram. 920-0002 Rev. J 12/2014 296 Host Command Reference Getting and Connecting an RS-485 2-wire adapter to your PC. If you are using your computer to communicate to the drive(s) and therefore need an RS-485 adaptor, model 485-25E from Integrity Instruments (800-450-2001) works well. It comes with everything you need. Connect as follows: Adaptor Terminal Drive Terminals A TX+/RX+ B TX-/RX- Before you connect the drive to your system If you plan to implement a 2-wire or 4-wire RS-485 network of drives, you will first need to address each drive individually. An easy way to do this is prior to hooking the drives up with one of the RS-485 implementations shown above, use the RS-232 cable that came with each drive and the SCL Setup Utility. If you’ve already connected your drive using one of the RS-485 implementations, completing this sub-section will allow you to test your connections. First connect your PC and drive. (See preceding sub-sections on connecting to a PC or host for help with this). Then launch the SCL Setup Utility on your PC. If you don’t have the SCL Setup Utility installed, you can get it either from the CD-ROM that came with your drive or from MOONS’’s web site, www.moons.com.cn. Once the SCL Setup Utility is launched, select the proper COM port of your PC, and then apply power to the drive. Press the Caps Lock key on your keyboard (because the drives only accept commands in uppercase). Type RV then press Enter. If the drive has power and is properly wired, it will respond with “RV=x”, where x is the firmware version of your drive. This confirms that communication has been established. If you don’t see the “RV=x” response, check your wiring and follow the above procedures again. Next, you must choose an address for each drive. Any of the “low ascii” characters (many of which appear above the number keys on a PC keyboard) are acceptable: !“#$%&‘()*+,-./0123456789:;?@ To find out which address is already in your drive, type DA then press Enter. The drive will respond with “DA=x”, where x is the address that was last stored. To change the address, type “DAy”, where y is the new address character, then press Enter. To test the new address, type “yRV” where y is the address you’ve just assigned to the drive, and then press Enter. For example, if you set the address to % and want to test the address, type “%RV” then press Enter. The drive should respond with “%RV=x” where x is the firmware version of the drive. Once each drive in your network has been given a unique address, you can proceed with wiring the whole network together. 297 920-0002 Rev. J 12/2014 Host Command Reference Appendix D: The PR Command Because of the intense nature of serial communications required in host mode applications, you are allowed to adjust a drive’s serial communications protocol to best fit your application. This adjusting of a drive’s serial communications protocol is done using the PR command. Typically the PR command is used one time when configuring a drive and saved as part of the startup parameters (use SA command to save startup parameters). However, it can be changed at any time to dynamically alter the serial communications. The PR command works by sending the decimal equivalent of a 9-bit binary “word”. Each bit in the word represents a different setting of the serial communications protocol. These settings are additive, meaning when you set a bit to “1”, or turn it on, you are adding the functionality of that setting to the serial protocol. Think of this 9-bit word as a bank of 9 dip switches. You can turn each dip switch on or off, and in doing so add or subtract a particular setting from the overall protocol. The PR command in detail The diagram to the right shows the assignments of each of the 9 bits in the protocol word. Remember that when you use the PR command the parameter that you send along with the command code (PR) is the decimal equivalent of this binary word. Below are the details of each of the bits and the settings they are assigned to. Bit 6 = Checksum Type (step-servo and M2 only) Bit 7 = Little/Big Endian in Modbus Mode Bit 8 = Full Duplex in RS-422 Bit 0 - Default (“Standard SCL”) PR cannot be set to 0, so if no other bits in the PR word are set to 1 then at least bit 0 must be set to 1. Setting Bit 0 to 1 when any other bits are also set to 1 has no effect on the communications protocol. For example, PR4 (bit 2 set to 1) is the same as PR5 (bits 0 and 2 set to one). With only bit 0 set to 1, when commands that do not request returned data are received by the drive no other response is sent from the drive. In other words, the drive will only send a response to commands that require a response. Send data Examples: Command DI8000 1DI8000 Drive Sends - - Notes Global set distance to 8000 counts or steps Drive with address “1” set distance to 8000 counts or steps Request data Examples: Command DI 1DI Drive Sends DI=8000 1DI=8000 Notes Global distance request Drive with address “1” responds with distance Bit 1 - Address Character (always send address character) With this option set (Bit 1=1) a drive’s address character will always be included in the response packet along with any requested data. Send data Examples: Command VE50 1VE50 920-0002 Rev. J 12/2014 Drive Sends - - Notes Global set velocity to 50 rps Drive with address “1” set velocity to 50 rps 298 Host Command Reference Request data Examples: Command Drive Sends VE 1VE=50 1VE 1VE=50 Notes Drive responds with address “1” and velocity to global velocity request Drive responds with address “1” and velocity to specific velocity request from drive at address “1” Bit 2 - Ack/Nack (always send acknowledge character) This option causes the drive to acknowledge every transmission from a host, whether the command is requesting data or not. If a host requests data (for example a DI command with no parameter), the response is considered the acknowledgement. However, if the host sends commands that do not request data from the drive, the drive will still respond with one of the following characters: “%” - The “percent” character is a Normal Acknowledge (Ack) character that means the drive accepted the command and executed it. “*” - The “asterisk” character is an Exception Acknowledge (Ack) character that means the drive accepted the command and buffered it into the queue. Depending on the status of the queue, execution of the exception acknowledged command(s) can occur at any time after the acknowledge. “?” - The “question mark” character is a Negative Acknowledge (Nack) character that means a parsing error occurred while the drive was receiving the command. A second character may follow the question mark, which provides an error code describing the type of parsing error. Here is the list of error codes: Negative Acknowledge Codes 1 2 3 4 5 6 7 8 9 10 11 12 13 14 Command timed out Parameter is too long Too few parameters Too many parameters Parameter out of range Command buffer (queue) full Cannot process command Program running Bad password Comm port error Bad character I/O point already used by current Command Mode, and cannot be changed (Flex I/O drives only) I/O point configured for incorrect use (i.e., input vs. output) (Flex I/O drives only) I/O point cannot be used for requested function - see HW manual for possible I/O function assignments. (Flex I/O drives only) Acknowledge characters are always sent out of the RS-232 port. When operating on a 2-wire or 4-wire RS485 network, the acknowledge characters are sent out under the following conditions: 1. An acknowledge character is sent when the received command has an address character at the beginning. 2. An acknowledge character is NOT sent when global commands (commands without addresses) that do not request data from the drive are used. 3. Global commands that request data will cause data to be returned from the drive(s). This can cause data collisions if there are more than one drive on a network. NOTE: Always use addresses with commands in multi-drop networks to avoid data collisions. NOTE: When possible avoid using Acknowledge characters (%, *, ?) as drive addresses in multi-drop networks to prevent confusion. 299 920-0002 Rev. J 12/2014 Host Command Reference Good command Example: Command Drive Sends DI8000 % 1DI8000 1% Notes Drive sends normal Ack (over RS-232 port only) in response to global set distance to 8000 Drive at address “1” sends normal Ack (over both ports) in response to address-specific set distance to 8000 Bad command Example: Command Drive Sends VE200 ?5 1VE200 1?5 Notes Drive sends Nack (over RS-232 port only) in response to global set velocity to 200 rps; error code 5 is sent because parameter “200” is out of range Drive at address “1” sends Nack (over both ports) and error code in response to address-specific set velocity to 200 rps Buffered command Example: Command Drive Sends AC10 * 1AC10 1* Notes Drive sends Exception Ack (over RS-232 port only) in response to global set acceleration to 10 rps/s Drive at address “1” sends Exception Ack and address (over both ports) in response to address-specific set acceleration Bit 3 - Checksum When this bit is 1, checksum is implemented. When this bit is 0, checksum is not implemented. Bit 4 - RS-485 Adapter mode Allows using a drive as an RS-232 to RS-485 adapter by letting the host communicate on an RS-485 network through the first drive’s RS-232 port. When the host sends commands with a “~” (tilde) at the beginning of the command to the first drive’s RS-232 port, the command is echoed out of both of that drive’s RS-232 and RS-485 ports. Drives connected on the RS-485 network will receive the same command with the “~” stripped off. Without the Bit 4 option (Bit 4=0), a drive will normally echo any addressed command out of the RS232 port only, whether the command was received from the drive’s RS-232 or RS-485 port. What the Bit 4 setting does (Bit 4=1), is force the drive to echo commands out the RS-485 port as well, allowing a host that is connected to a drive through its RS-232 port, to communicate to an RS-485 network of drives. NOTE: When both Bits 4 and 2 are set (Bit 4=1, Bit 2=1), the host will receive back both the echoed packet and the acknowledge packet. For example, two drives are connected in an RS-485 network, and they both have PR command Bits 4 and 2 set. The first drive, which is also connected to the host via its RS-232 port, is addressed “1”, and the second drive is addressed “2”. Here is what you will see: Send data Example: Command Drive Sends ~2DI8000 2DI8000 2% Notes Drive at address “1” echoes original command over both serial ports Drive at address “2” responds with ack. Request data Example: Command Drive Sends ~2DI 2DI 2DI8000 920-0002 Rev. J 12/2014 Notes Drive at address “1” echoes original command over both serial ports Drive at address “2” responds with distance 300 Host Command Reference Bit 5 - 3-digit numeric register addressing Each data register in a drive is normally accessed using its single letter, number, or other ascii character. With Bit 5 set (Bit 5=1), each of the data registers is instead accessed with a 3-digit number: 000 to 074. (See the Data Registers section for character and 3-digit numerical assignments). The Bit 5 option implements this specific usage for the RL (Register Load) and RU (Register Upload) commands. NOTE: When data is returned from a drive (whether Bit 5 is set or not set), the data register is always represented by its single character designation. RL Command Example: Command RL017100 RL017 Drive Sends - RLA=100 Notes Load register 017 (“A”) with the value 100 Drive sends contents of acceleration register RU command Example: Command Drive Sends RU0174 RUA=100 RUB=150 RUC=140 RUD=210 Notes Drive responds to register upload command by sending contents of 4 sequential data registers, starting with register 017 (“A”) Bit 6 - Checksum Type When this bit is 1, STM type checksum is implemented. When this bit is 0, SSM type checksum is implemented. 301 920-0002 Rev. J 12/2014 Host Command Reference SSM type Checksum Protocol Step-Servo (SSM/TSM/TXM/SS) and M2 drives support “SSM type” checksum protocol. When bit 3 in PR command is set to 1 and bit 6 in PR is set to 0, for example PR=13, then “SSM type” checksum protocol is implemented. Step-Servo (SSM/TSM/TXM/SS) and M2 drives can also support “STM type” checksum protocol. When both bit 3 and bit 6 in PR command are set to 1, for example PR=77, then “STM type” checksum protocol is implemented. ST/STM/SWM drives do not support “SSM type” checksum protocol. SSM type Checksum protocol and Data Frame This Checksum Protocol is based on 1’s complement, and added at the end of every “Command”. There is a delimiter “{” between the “Command” chars and the one byte Checksum. The Data Frame as the following: Example: “CC” Command Send Command (from Host): Host Request: CC{79 Chars “C” “C” “{” CHKsm: 0x79 (2 ASCII ) Hex 0x43 0x43 0x7B 0x37 “Carriage Return” 0x39 0x0D Receive back (from Drive): Drive Response: CC=5{07 Chars “C” “C” “=” “5” “{” CHKsm: 7 (2 ASCII) “Carriage Return” Hex 0x43 0x43 0x3D 0x35 0x7B 0x30 0x0D 0x37 If you get a Nack response “?10”, this is a comm port error that may be a bad checksum. To see what it is use the “CE” command which will give back an error code in “Hex”. 920-0002 Rev. J 12/2014 302 Host Command Reference Here is the list of Error codes for the “CE” command (the ones in BLUE are for the checksum) Command Hex Code Dec Code Description CE 0x0000 0 Communication is normal 0x0001 1 Communication Parity bit does not match 0x0002 2 Communication Framing Error 0x0004 4 noise on the receiver input 0x0008 8 Overflow error 0x0010 16 Receive Buffer is Full 0x0020 32 Transmit Buffer is Full 0x0040 64 Bad SPI opcode (this only for SPI interface comm) 0x0080 128 Transmit Time Out 0x0100 256 Receive Time Out 0x0200 512 Bad checksum on the receiver 0x0400 1024 Too many chars for the command How to using the checksum feature The checksum is a option feature for all drives. To use this feature, please set the bit3 in PR command. Example: For Ack (select by Bit2 of PR command) and checksum, set PR13 (Note: the Bit0 should be always set). If you want to know the detail of this command, please refer to the document “Host Command Reference”. Here is the format of the protocol: [optional] [Address] Command Parameter(s) (delimiters) (“{“, ASCII 123) Checksum (“Carriage Return”, ASCII 13) • The character “{“, ASCII 123, is used to delimit the main packet and the checksum. • The checksum value is 8-bit, 1’s complement (add up all the character from the “Address” to “Parameter” don’t include the “{“ character, “mask” off the lower byte (means grabbing the lower byte of the checksum) to restrict it to 8 bits, invert all the bits), and then convert the value to ASCII chars. NOTE 1: There is no checksum on the “Ack” or “Nack” packets. These are very simple responses that in the case of an “Ack” does not have data or the “Nack” has only an error code. NOTE 2: when checksumming is turned on, you are NOT allowed to send a packet without the checksum, otherwise it will return back “?12”(means no Checksum), In the other hand, when checksumming is turned off, but send command with checksum, it will return a “?4”(means too many parameters). 303 920-0002 Rev. J 12/2014 Host Command Reference STM type Checksum Protocol ST/STM/SWM drives support “STM type” checksum protocol. When bit 3 in PR command is set to 1, for example PR=13, then “STM type” checksum protocol is implemented. Step-Servo (SSM/TSM/TXM/SS) and M2 drives also support “STM type” checksum protocol. When both bit 3 and bit 6 in PR command are set to 1, for example PR=77, then “STM type” checksum protocol is implemented. Step-Servo (SSM/TSM/TXM/SS) and M2 drives can also support “SSM type” checksum protocol. When bit 3 in PR command is set to 1 and bit 6 in PR is set to 0, for example PR=13, then “SSM type” checksum protocol is implemented. STM type Checksum protocol and Data Frame This Checksum Protocol is based on 1’s complement, and added at the end of every “Command”. There is a delimiter “{” between the “Command” chars and the one byte Checksum. The Data Frame as the following: Example: “CC” Command Send Command (from Host): Host Request: CC Chars “C” “C” “{” CHKsm “Carriage Return” Hex 0x43 0x43 0x7B 0x79 0x0D Receive back (from Drive): Drive Response: CC=1.2 Chars “C” “C” “=” “1” “.” “2” Hex 0x43 0x43 0x3D 0x31 0x2E 0x32 “{” 0x7B CHKsm 0xAB “Carriage Return” 0x0D If you get a Nack response “?10”, this is a comm port error that may be a bad checksum. To see what it is use the “CE” command which will give back an error code in “Hex”. 920-0002 Rev. J 12/2014 304 Host Command Reference Here is the list of Error codes for the “CE” command (the ones in BLUE are for the checksum) Command Hex Code Dec Code Description CE 0x0000 0 Communication is normal 0x0001 1 Communication Parity bit does not match 0x0002 2 Communication Framing Error 0x0004 4 noise on the receiver input 0x0008 8 Overflow error 0x0010 16 Receive Buffer is Full 0x0020 32 Transmit Buffer is Full 0x0040 64 Bad SPI opcode (this only for SPI interface comm) 0x0080 128 Transmit Time Out 0x0100 256 Receive Time Out 0x0200 512 Bad checksum on the receiver 0x0400 1024 Too many chars for the command How to using the checksum feature The checksum is a option feature for all drives. To use this feature, please set the bit3 in PR command. Example: For Ack (select by Bit2 of PR command) and checksum, set PR13 (Note: the Bit0 should be always set). If you want to know the detail of this command, please refer to the document “Host Command Reference”. Here is the format of the protocol: [optional] [Address] Command Parameter(s) (delimiters) (“{“, ASCII 123) Checksum (“Carriage Return”, ASCII 13) • The character “{“, ASCII 123, is used to delimit the main packet and the checksum. • The checksum value is 8-bit, 1’s complement (add up all the character from the “Address” to “Parameter” don’t include the “{“ character, “mask” off the lower byte (means grabbing the lower byte of the checksum) to restrict it to 8 bits, invert all the bits), and then convert the value to ASCII chars. NOTE 1: There is no checksum on the “Ack” or “Nack” packets. These are very simple responses that in the case of an “Ack” does not have data or the “Nack” has only an error code. NOTE 2: when checksumming is turned on, you are NOT allowed to send a packet without the checksum, otherwise it will return back “?12”(means no Checksum), In the other hand, when checksumming is turned off, but send command with checksum, it will return a “?4”(means too many parameters). 305 920-0002 Rev. J 12/2014 Host Command Reference Bit 7 - Little/Big Endian in Modbus Mode When this bit is 1, Little Endian is used. When this bit is 0, Big Endian is used. Bit 8 - Full Duplex in RS-422 When this bit is 1, Full Duplex is used. When this bit is 0, Half Duplex is used. PR Command Examples Now that you know what the bits in the PR command’s 9-bit binary word mean, here are a couple examples showing how you would set the serial communications protocol of your drive. Example: Turn on Ack/Nack (Bit 2) and 3-digit numeric register addressing function (Bit 5) The 9-bit word for this combination is - 000100100 - and it’s decimal equivalent is 36. Therefore, to set your drive with this serial protocol, you would send the command “PR36” to your drive. Example: Turn on RS-485 adaptor function (Bit 4) The 9-bit word for this combination is - 000010000 - and it’s decimal equivalent is 16. Therefore, to set your drive with this serial protocol, you would send the command “PR16” to your drive. 920-0002 Rev. J 12/2014 306 Host Command Reference Appendix E: Alarm and Status Codes One of a drive’s diagnostic tools is its ability to send alarm and status codes back to a host. The AL (Alarm code) and SC (Status Code) commands can be used by a host to query a drive at any time. If a drive faults or sets an alarm, the AL command allows the host to find out what alarm, or alarms, has been set. Similarly, the SC command allows a host to find out what the status code of a drive is at any time during drive operation. A status code provides information as to whether the drive is running, in position, disabled, homing, and other conditions. Both alarm and status codes can be very useful when initially setting up and integrating a servo system into your machine. The Alarm and Status codes are hexadecimal equivalents of 16 bit binary “words”. Each bit in each binary word is assigned a meaning, and therefore a code word can actually show information about more than one alarm or status condition. Alarm Code Definitions AL command When a host sends the AL command, the response from the drive will be the Hexadecimal equivalent of a 16-bit word. This hexadecimal value is considered the Alarm Code, and the hexadecimal value for each of the bits in the Alarm Code is given below. Hex Value BLu SV STAC6 ST 0001 Position Limit 0002 CCW Limit 0004 CW Limit 0008 Over Temp 0010 Excess Regen* Internal Voltage Under Voltage* Under Voltage Under Voltage Under Voltage Under Voltage Over Current 0080 0100 Internal Voltage Internal Voltage Over Voltage 0020 0040 Excess Regen STM Bad Hall Sensor Open Motor Winding Bad Encoder 0200 0400 (not used) Comm Error 0800 Bad Flash 1000 Wizard Failed 2000 Current Foldback 4000 8000 No Move Motor Resistance Out of Range (not used) (not used) Blank Q Segment No Move (not used) * BLuAC drives only NOTE: Items in bold italic represent Drive Faults, which automatically disable the motor. Use the OF command in a Q Program to branch on a Drive Fault. Example: The drive has hit the CW limit (0004), there is an under voltage condition (0040), and an encoder wiring connection has been lost resulting in an encoder fault (0200). The resulting Alarm Code is 0244, and when the host sends the “AL” command the drive will respond with “AL=244”. “f” data register Another way to retrieve the Alarm Code is to use the “f” data register. If the host sends the RLf command, 307 920-0002 Rev. J 12/2014 Host Command Reference the response from the drive will be the decimal equivalent of the 16-bit Alarm Code word. The diagram below shows the 16 bit assignments for the Alarm Code (which of course match the hexadecimal values above). Example: The drive has hit the CW limit (bit 2), there is an under voltage condition (bit 6), and an encoder wiring connection has been lost resulting in an encoder fault (bit 9). The resulting Alarm Code binary word is 0000 0010 0100 0100. The decimal equivalent of this word is 580, so the response from the drive to the RLf command will be “RLf=580”. Status Code Definitions SC command When a host sends the SC command, the response from the drive will be the Hexadecimal equivalent of a 16-bit word. This hexadecimal value is considered the Status Code, and the hexadecimal value for each of the bits in the Status Code is given below. When a host sends the SC command, the response from the drive will actually be the Hexadecimal equivalent of this 16-bit word. This hexadecimal value is considered the Status Code, and the equivalent hexadecimal value for each of the bits is given below. Hex Value Status Code bit definition 0001 Motor Enabled (Motor Disabled if this bit = 0) 0002 Sampling (for Quick Tuner) 0004 Drive Fault (check Alarm Code) 0008 In Position (motor is in position) 0010 Moving (motor is moving) 0020 Jogging (currently in jog mode) 0040 Stopping (in the process of stopping from a stop command) 0080 Waiting for an input (executing WI command) 0100 Saving (parameter data is being saved) 0200 Alarm present (check Alarm Code) 920-0002 Rev. J 12/2014 308 Host Command Reference Hex Value Status Code bit definition 0400 Homing (executing an SH command) 0800 Wait Time (executing a WT command) 1000 Wizard running (Timing Wizard is running) 2000 Checking encoder (Timing Wizard is running) 4000 Q Program is running 8000 Initializing (happens at power up) Example: The drive is running a stored Q program (hex value 4000), it’s in position (hex value 0008), and it’s waiting for the input specified by the WI command (hex value 0080). The Status Code for this condition is 4088, and when the host sends the “SC” command the drive will respond with “SC=4088”. “s” data register Another way to retrieve the Status Code is to use the “s” data register. If the host sends the RLs command, the response from the drive will be the decimal equivalent of the 16-bit Status Code word. The diagram below shows the 16 bit assignments for the Status Code (which of course match the hexadecimal values above). Example: The drive is running a stored Q program (bit 14), it’s in position (bit 3), and it’s waiting for the input specified by the WI command (bit 7). The resulting Status Code binary word is 0100 0000 1000 1000. The decimal equivalent of this word 16,520, so the response from the drive to the RLs command will be “RLs=16520”. A useful tool for converting between binary, decimal, and hexadecimal. If you’re using a Windows-based PC as a host with your drive (which you’ll definitely be doing at some point during the project), you can use the Calculator utility that comes with Windows to convert Alarm and Status Codes between binary, decimal, and hexadecimal values. This utility is usually found in Start Menu, Programs, Accessories. Once open, make sure to choose Scientific view from the View menu of Calculator. This view provides radio buttons for Hex, Dec, and Bin. To figure out what your Alarm or Status Code is telling you, first select the appropriate radio button (Hex for 309 920-0002 Rev. J 12/2014 Host Command Reference the AL or SC commands, Dec for the “f” and “s” registers), then enter the response from the drive. Now you can toggle between Hex, Dec, and Bin to compare the values to the tables and diagrams above. Note: Calculator does not show leading zeros in a binary number, so you may see less than 16 bits when you select Bin. That’s OK, just start counting from the right with Bit 0 and you’ll be able to determine the conditions set in the codes. LED and 7-Segment Display codes In addition to the Alarm and Status codes, most drive alarms and faults as well as some status codes are displayed at the front of the drives, via either two-color flashing LED codes or 7-segment LED codes. The following tables show the various codes available with MOONS’ drives. BLuDC LED codes Items in bold italic are Drive Faults. DESCRIPTION - solid Motor disabled - flashing slowly Motor enabled - flashing quickly Q program running (Q drives only) 1 1 position limit 1 2 move attempted while disabled 2 1 CCW limit 2 2 CW limit 3 1 over temperature (> 85 deg C) 3 2 bad flash 4 1 over voltage (> 55 Vdc) 4 2 under voltage (< 18 Vdc) 5 1 over current / short circuit 5 2 current limit 6 1 bad hall 6 2 bad encoder 7 1 serial communication error BLuAC 7-Segment codes Items in bold italic are Drive Faults. Position Mode Over Temp Comm Error Velocity Mode Over Voltage Move attempted while disabled Torque Mode Under Voltage Drive Start-up 920-0002 Rev. J 12/2014 310 Host Command Reference Step Mode Over Current Bad Flash Si Mode Current Limit Comm Time-out Drive Disabled Hall Bad Stack Overflow Position Limit Bad Encoder Stack Underflow CCW Limit Memory Failed Q Program Running CW Limit Excess Regen Drive enabled when flashing SV LED codes Items in bold italic are Drive Faults. DESCRIPTION - solid Motor disabled - flashing slowly Motor enabled - flashing quickly Q program running (Q drives only) 1 1 position limit 1 2 move attempted while disabled 2 1 CCW limit 2 2 CW limit 3 1 over temp 3 2 internal voltage out of range 3 3 attempt to load blank Q segment 4 1 over voltage 4 2 under voltage 4 3 Bad Si program instruction 5 1 over current / short circuit 5 2 current limit 6 1 bad hall 6 2 bad encoder 7 1 serial communication error 7 2 bad flash STAC6 LED codes Items in bold italic are Drive Faults. 311 920-0002 Rev. J 12/2014 Host Command Reference DESCRIPTION - solid Motor disabled - flashing slowly Motor enabled - flashing quickly Q program running (Q drives only) 1 1 motor stall (w/ optional encoder only) 1 2 move attempted while disabled 2 1 CCW limit 2 2 CW limit 3 1 over temp 3 2 excess regen 4 1 over voltage 4 2 under voltage 4 3 Bad Si program instruction 5 1 over current / short circuit 5 2 motor resistance out of range 6 1 open motor winding 6 2 bad encoder signal (w/ optional encoder only) 7 1 serial communication error ST-Q/Si LED codes Items in bold italic are Drive Faults. DESCRIPTION - solid Motor disabled - flashing slowly Motor enabled - flashing quickly Q program running (Q drives only) 1 1 motor stall (w/ optional encoder only) 1 2 move attempted while disabled 2 1 CCW limit 2 2 CW limit 3 1 over temp 3 2 internal voltage out of range 4 1 over voltage 4 2 under voltage 4 3 Bad Si program instruction 5 1 over current / short circuit 6 1 open motor winding 6 2 bad encoder signal (w/ optional encoder only) 7 1 serial communication error ST-S LED codes 920-0002 Rev. J 12/2014 312 Host Command Reference Items in bold italic are Drive Faults. DESCRIPTION - solid Motor disabled - flashing slowly Motor enabled 1 2 move attempted while disabled 2 1 CCW limit 2 2 CW limit 3 1 over temp 3 2 internal voltage out of range 4 1 over voltage 4 2 under voltage 5 1 over current / short circuit 6 1 open motor winding 7 1 serial communication error STM LED codes Items in bold italic are Drive Faults. DESCRIPTION - solid Motor disabled - flashing slowly Motor enabled - flashing quickly Q program running (Q drives only) 1 1 motor stall (w/ optional encoder only) 1 2 move attempted while disabled 2 1 CCW limit 2 2 CW limit 3 1 over temp 3 2 internal voltage out of range 4 1 over voltage 4 2 under voltage 5 1 over current / short circuit 6 1 open motor winding 7 1 serial communication error 313 920-0002 Rev. J 12/2014 Host Command Reference Appendix F: Working with Inputs and Outputs This Appendix covers I/O usage on drives from MOONS’ Products. Low v. High When working with inputs and outputs it is important to remember the designations low and high. If current is flowing into or out of an input or output the logic state for that input/output is defined as low or closed. If no current is flowing, or the input/output is not connected, the logic state is high or open. A low state is represented by the “L” character in parameters of commands that affect inputs/outputs. For example, WIX4L means “wait for input X4 low”, and SO1L means “set output 1 low”. A high state is represented by the “H” character. When working with the analog inputs, “L” designates an analog value lower than the value set by the AT command. Similarly “H” designates an analog value greater than the value set by the AT command. “X” Marks The Spot When using a dual input command, both I/O points used must reside on the same connector. That is, if an “X” input such as X2 is used for the first input, the second input is assumed to use an “X” as well since it must reside on the same connector. Since it is not possible to mix I/O from different banks, there is no need for the “X” character on the second I/O point. See the “Parameter Details” section in the tables below for specific details. Parameter Details The following tables show general I/O details for commands as they relate to specific drives. There are exceptions to these general rules, so be sure to check the command pages for the specific SCL commands you wish to implement, as well as the list of exceptions at the end of this section. For specific voltage or wiring questions, consult your drive’s hardware manual. Input Parameter Details BLu-S, BLu-Q STAC6-S, STAC6-Q, STAC6-C Parameter #1 Optional “X”, input number, input condition NOTE: Including/omitting the optional “X” has no effect on the execution of the command. - units Optional “X”, integer, letter - range - integer: 0 (encoder index, if present), 1 - 7, 8 (Analog Command), 9 (AIN1), : (AIN2) - letter: L = Low, H = High, F = Falling Edge, R = Rising Edge Parameter #2 Input number, input condition - units integer, letter - range - integer: 0 (encoder index, if present), 1 - 7, 8 (Analog Command), 9 (AIN1), : (AIN2) - letter: L = Low, H = High, F = Falling Edge, R = Rising Edge 920-0002 Rev. J 12/2014 314 Host Command Reference BLu-SE, BLu-QE, BLu-Si STAC6-SE, STAC6-QE, STAC6-Si Parameter #1 Optional “X”, input number, input condition NOTE: Including the optional “X” indicates that the input(s) resides on the IN/OUT1 or main drive board connector. Omitting the “X” indicates that the input(s) resides on the IN/OUT2 or top board connector. - units Optional “X”, integer, letter - range - integer for IN/OUT1 or main drive board connector: X0 (encoder index, if present), X1 - X7, X8 (Analog Command), X9 (AIN1), X: (AIN2) -integer for IN/OUT2 or top board connector: 1 - 8 - letter: L = Low, H = High, F = Falling Edge, R = Rising Edge Parameter #2 Input number, input condition - units integer, letter - range - integer for IN/OUT1 or main drive board connector: 0 (encoder index, if present), 1 - 7, 8 (Analog Command), 9 (AIN1), : (AIN2) -integer for IN/OUT2 or top board connector: 1 - 8 - letter: L = Low, H = High, F = Falling Edge, R = Rising Edge STAC5-S, SVAC3-S Parameter #1 Optional “X”, input number, input condition NOTE: Including/omitting the optional “X” has no effect on the execution of the command. - units integer, letter - range - integer: 0 (encoder index, if present), 1 - 4, 8 (AIN) - letter: L = Low, H = High, F = Falling Edge, R = Rising Edge Parameter #2 input number, input condition - units integer, letter - range - integer: 0 (encoder index, if present), 1 - 4, 8 (AIN) - letter: L = Low, H = High, F = Falling Edge, R = Rising Edge 315 920-0002 Rev. J 12/2014 Host Command Reference STAC5-Q, STAC5-IP SVAC3-Q, SVAC3-IP Parameter #1 Optional “X”, input number, input condition NOTE: Including the optional “X” indicates that the input(s) resides on the IN/OUT1 connector (DB-15). Omitting the “X” indicates that the input(s) resides on the OPT2 connector (DB-25). - units Optional “X”, integer, letter - range - integer for IN/OUT1 connector: X0 (encoder index, if present), X1 - X4, X8 (AIN) - integer for OPT2 connector: 1 - 8 - letter: L = Low, H = High, F = Falling Edge, R = Rising Edge For those commands with Parameter #2 input number, input condition - units integer, letter - range - integer for IN/OUT1 connector: 0 (encoder index, if present), 1 - 4, 8 (AIN) - integer for OPT2 connector: 1 - 8 - letter: L = Low, H = High, F = Falling Edge, R = Rising Edge ST-Q, ST-Si, ST-C, ST-IP SV7-S, SV7-Q, SV7-Si, SV7-C, SV7-IP Parameter #1 Optional “X”, input number, input condition NOTE: Including/omitting the optional “X” has no effect on the execution of the command. - units integer, letter - range - integer: 0 (encoder index, if present), 1 - 8, 9 (Analog Command), : (AIN1), ; (AIN2) - letter: L = Low, H = High, F - Falling Edge, R = Rising Edge Parameter #2 input number, input condition - units integer, letter - range - integer: 0 (encoder index, if present), 1 - 8, 9 (Analog Command), : (AIN1), ; (AIN2) - letter: L = Low, H = High, F = Falling Edge, R = Rising Edge 920-0002 Rev. J 12/2014 316 Host Command Reference ST-S, ST-Plus STM17S, STM17Q STM23S, STM23Q Parameter #1 Optional “X”, input number, input condition NOTE: Including/omitting the optional “X” has no effect on the execution of the command. - units optional “X”, integer, letter - range - integer: 0 (encoder index, if present), 1 (STEP), 2 (DIR), 3 (EN), 4 (AIN) - letter: L = Low, H = High, F = Falling Edge, R = Rising Edge Parameter #2 input number, input condition - units integer, letter - range - integer: 0 (encoder index, if present), 1 (STEP), 2 (DIR), 3 (EN), 4 (AIN) - letter: L = Low, H = High, F = Falling Edge, R = Rising Edge STM17C Parameter #1 Optional “X”, input number, input condition NOTE: Including/omitting the optional “X” has no effect on the execution of the command. - units Optional “X”, integer, letter - range - integer: 0 (encoder index, if present), 1 - 3, 4 (AIN) - letter: L = Low, H = High, F = Falling Edge, R = Rising Edge Parameter #2 input number, input condition - units integer, letter - range - integer: 0 (encoder index, if present), 1 - 3, 4 (AIN) - letter: L = Low, H = High, F = Falling Edge, R = Rising Edge 317 920-0002 Rev. J 12/2014 Host Command Reference STM23C STM24C Parameter #1 Optional “X”, input number, input condition NOTE: Including/omitting the optional “X” has no effect on the execution of the command. - units Optional “X”, integer, letter - range - integer: 0 (encoder index, if present), 1 - 3 - letter: L = Low, H = High, F - Falling Edge, R = Rising Edge Parameter #2 input number, input condition - units integer, letter - range - integer: 0 (encoder index, if present), 1 - 3 - letter: L = Low, H = High, F = Falling Edge, R = Rising Edge STM24SF, STM24QF Drives with Flex I/O allow a user to configure I/O1 through I/O4 as either inputs or outputs by using the Set Direction (SD) command. Parameter #1 Optional “X”, input number, input condition NOTE: Including/omitting the optional “X” has no effect on the execution of the command. - units Optional “X”, integer, letter - range - integer: 0 (encoder index, if present), 1 - 4, 5 (AIN) - letter: L = Low, H = High, F - Falling Edge, R = Rising Edge Parameter #2 input number, input condition - units integer, letter - range - integer: 0 (encoder index, if present), 1 - 4, 5 (AIN) - letter: L = Low, H = High, F = Falling Edge, R = Rising Edge 920-0002 Rev. J 12/2014 318 Host Command Reference Exceptions: • When using the Follow Encoder or Hand Wheel commands (FE or HW, respectively), the master encoder channels A and B must be wired to drive inputs STEP/X1/IN1 and DIR/X2/IN2. In these modes, these inputs must not be used for sensor inputs. • Using the On Input (OI) command with no parameter will disable the interrupt function. • The Seek Home (SH) command makes use of the drive’s CW and CCW limit functions. As such, the home sensor may not be wired to the following inputs: STAC5-S: X1, X2 STM17-S/Q: STEP, DIR STAC5-Q/IP: IN7, IN8 STM17-C: IN1, IN2 SVAC3-S: X1, X2 STM23-S/Q: STEP, DIR SVAC3-Q/IP: IN7, IN8 STM23-C: IN1, IN2 BLu: X6, X7 STM24-SF/QF: I/O3, I/O4 STAC6: X6, X7 STM24-C: IN1, IN2 ST-S/Plus: STEP, DIR ST-Q/Si/C/IP: X7, X8 SV7: X7, X8 Output Parameter Details BLu-S, BLu-Q STAC6-S, STAC6-Q, STAC6-C Parameter #1 Optional “Y”, output number, output condition NOTE: Including/omitting the optional “Y” has no effect on the execution of the command. - units Optional “Y”, integer, letter - range - integer: 1 - 3 - letter: L = Low, H = High BLu-SE, BLu-QE, BLu-Si STAC6-SE, STAC6-QE, STAC6-Si Parameter #1 Optional “Y”, output number, output condition NOTE: Including the optional “Y” indicates that the output(s) resides on the IN/OUT1 or main drive board connector. Omitting the “Y” indicates that the output(s) resides on the IN/OUT2 or top board connector. - units Optional “Y”, integer, letter - range - integer for IN/OUT1 or main drive board connector: Y1 - Y3 - integer for IN/OUT2 or top board connector: 1 - 4 - letter: L = Low, H = High 319 920-0002 Rev. J 12/2014 Host Command Reference STAC5-S SVAC3-S Parameter #1 Optional “Y”, output number, output condition NOTE: Including/omitting the optional “Y” has no effect on the execution of the command. - units Optional “Y”, integer, letter - range - integer: 1 - 2 - letter: L = Low, H = High STAC5-Q, STAC5-IP SVAC3-Q, SVAC3-IP Parameter #1 Optional “Y”, output number, output condition NOTE: Including the optional “Y” indicates that the output(s) resides on the IN/OUT1 connector (DB-15). Omitting the “Y” indicates that the output(s) resides on the OPT2 connector (DB-25). - units Optional “Y”, integer, letter - range - integer for IN/OUT1 connector: Y1- Y2 - integer for OPT2 connector: 1 - 4 - letter: L = Low, H = High ST-Q, ST-Si, ST-C, ST-IP SV7-S-SV7-Q, SV7-Si, SV7-C, SV7-IP Parameter #1 Optional “Y”, output number, output condition NOTE: Including/omitting the optional “Y” has no effect on the execution of the command. - units Optional “Y”, integer, letter - range - integer: 1 - 4 - letter: L = Low, H = High 920-0002 Rev. J 12/2014 320 Host Command Reference ST-S, ST-Plus STM17S, STM17Q, STM17C STM23S, STM23Q, STM23C STM24C Parameter #1 Optional “Y”, output number, output condition NOTE: Including/omitting the optional “Y” has no effect on the execution of the command. - units Optional “Y”, integer, letter - range - integer: 1 - letter: L = Low, H = High STM24SF, STM24QF Drives with Flex I/O allow a user to configure I/O1 through I/O4 as either inputs or outputs by using the Set Direction (SD) command. Parameter #1 Optional “Y”, output number, output condition NOTE: Including/omitting the optional “Y” has no effect on the execution of the command. - units Optional “Y”, integer, letter - range - integer: 1 - 4 - letter: L = Low, H = High, F - Falling Edge, R = Rising Edge 321 920-0002 Rev. J 12/2014 Host Command Reference Appendix G: eSCL (SCL over Ethernet) Reference Introduction eSCL is MOONS’ Products’ language for commanding and querying motion control products over Ethernet. It is supported by several motion control devices, including the ST5-Q-E, ST10-Q-E and SV7-Q-E. In addition to sending commands to a drive from a host in real time, you can also use our Q Programmer software to embed sequences of commands, called Q Programs, in a drive. These programs can be set to execute automatically at power up, or can be triggered by commands sent from the host. This guide is intended to help you connect and configure your drive and to help you start writing your own eSCL host application. Getting Started There are three steps required to create an eSCL application with your new MOONS’ Products motor driver. Each of these is explained in a separate section of this manual. • Connect the drive to your PC. This includes getting the drive physically connected to your network (or directly to the PC), setting the drive’s IP address, and setting the appropriate networking properties on your PC. • Configure the drive for your motor and application. For step motor drives, you’ll need to use a suitable version of our Configurator software. For servos, use Quick Tuner. • Create your own application. This guide includes code examples in Visual Basic and C# to help you get started. You can download the example in their entirety, from our website, but we recommend reading the explanations in the guide first. Connecting a Drive to Your PC This process requires three steps Point of Interest • Get the drive physically connected to your network (or directly to the PC) • Set the drive’s IP address • Set the appropriate networking properties on your PC. Addresses, Subnets, and Ports Every device on an Ethernet network must have a unique IP address. In order for two devices to communicate with each other, they must both be connected to the network and they must have IP addresses that are on the same subnet. A subnet is a logical division of a larger network. Members of one subnet are generally not able to communicate with the members of another. Subnets are defined by the choices of IP addresses and subnet masks. If you want to know the IP address and subnet mask of your PC, select Start…All Programs…Accessories…Command Prompt. Then type “ipconfig” and press Enter. You should see something like this: 920-0002 Rev. J 12/2014 322 MOONS’ recommends performing all Ethernet configuration of the drive while connected directly to a PC via a CAT-5 Ethernet cable. This avoids many potential communication problems associated with frequent IP address changes on a larger network. Once fully configured, the drive may be used on a plant network without issue. See the section titled “ARP Tables the Ghost in the Machine” below for further information. Host Command Reference 0 12 345 EF 10.10.10.10 192.168.1.10 192.168.1.20 192.168.1.30 192.168.0.40 192.168.0.50 192.168.0.60 192.168.0.70 192.168.0.80 192.168.0.90 192.168.0.100 192.168.0.110 192.168.0.120 192.168.0.130 192.168.0.140 DHCP BCD 0 1 2 3 4 5 6 7 8 9 A B C D E F 89A Your drive includes a 16 position rotary switch for setting its IP address. The factory default address for each switch setting is shown in the table to the right. IP Address* 67 If your PC’s subnet mask is set to 255.255.255.0, a common setting known as a Class C subnet mask, then your machine can only talk to another network device whose IP address matches yours in the first three octets. (The numbers between the dots in an IP address are called octets.) For example, if your PC is on a Class C subnet and has an IP address of 192.168.0.20, it can talk to a device at 192.168.0.40, but not one at 192.168.1.40. If you change your subnet mask to 255.255.0.0 (Class B) you can talk to any device whose first two octets match yours. Be sure to ask your system administrator before doing this. You network may be segmented for a reason. Settings 1 through E can be changed using the STAC Configurator software (use Quick Tuner for servo drives). Setting 0 is always “10.10.10.10”, the universal recovery address. If someone were to change the other settings and not write it down or tell anyone (I’m not naming names here, but you know who I’m talking about) then you will not be able to communicate with your drive. The only way to “recover” it is to use the universal recovery address. Setting F is “DHCP”, which commands the drive to get an IP address from a DHCP server on the network. The IP address automatically assigned by the DHCP server may be “dynamic” or “static” depending on how the administrator has configured DHCP. The DHCP setting is reserved for advanced users. Your PC, or any other device that you use to communicate with the drive, will also have a unique address. On the drive, switch settings 1 through E use the standard class B subnet mask (i.e. “255.255.0.0”). The mask for the universal recovery address is the standard class A (i.e. “255.0.0.0”). One of the great features of Ethernet is the ability for many applications to share the network at the same time. Ports are used to direct traffic to the right application once it gets to the right IP address. The UDP eSCL port in our drives is 7775. To send and receive commands using TCP, use port number 7776. You’ll need to know this when you begin to write your own application. You will also need to choose an open (unused) port number for your application. Our drive doesn’t care what that is; when the first command is sent to the drive, the drive will make note of the IP address and port number from which it originated and direct any responses there. The drive will also refuse any traffic from other IP addresses that is headed for the eSCL port. The first application to talk to a drive “owns” the drive. This lock is only reset when the drive powers down. If you need help choosing a port number for your application, you can find a list of commonly used port numbers at http://www.iana.org/assignments/port-numbers. One final note: Ethernet communication can use one or both of two “transport protocols”: UDP and TCP. eSCL commands can be sent and received using either protocol. UDP is simpler and more efficient than TCP, but TCP is more reliable on large or very busy networks where UDP packets might occasionally be dropped. 323 920-0002 Rev. J 12/2014 Host Command Reference Option 1: Connect a Drive to Your Local Area Network NIC LAN PC SWITCH or ROUTER DRIVE If you have a spare port on a switch or router and if you are able to set your drive to an IP address that is compatible with your network, and not used by anything else, this is a simple way to get connected. This technique also allows you to connect multiple drives to your PC. If you are on a corporate network, please check with your system administrator before connecting anything new to the network. He or she should be able assign you a suitable address and help you get going. If you are not sure which addresses are already used on your network, you can find out using “Angry IP scanner”, which can be downloaded free from http://www.angryip.org/w/Download. But be careful: an address might appear to be unused because a computer or other device is currently turned off. And many networks use dynamic addressing where a DHCP server assigns addresses “on demand”. The address you choose for your drive might get assigned to something else by the DHCP server at another time. Once you’ve chosen an appropriate IP address for your drive, set the rotary switch according the address table above. If none of the default addresses are acceptable for your network, you can enter a new table of IP addresses using Configurator. If your network uses addresses starting with 192.168.0, the most common subnet, you will want to choose an address from switch settings 4 through E. Another common subnet is 192.168.1. If your network uses addresses in this range, the compatible default selections are 1, 2 and 3. If your PC address is not in one of the above private subnets, you will have to change your subnet mask to 255.255.0.0 in order to talk to your drive. To change your subnet mask: 1. On Windows XP, right click on “My Network Places” and select properties. On Windows 7, click Computer. Scroll down the left pane until you see “Network”. Right click and select properties. Select “Change adapter settings” 2. You should see an icon for your network interface card (NIC). Right click and select properties. 3. Scroll down until you see “Internet Properties (TCP/IP)”. Select this item and click the Properties button. On Windows 7 and Vista, look for “(TCP/IPv4)” 920-0002 Rev. J 12/2014 324 Host Command Reference 4. If the option “Obtain an IP address automatically” is selected, your PC is getting an IP address and a subnet mask from the DHCP server. Please cancel this dialog and proceed to the next section of this manual: “Using DHCP”. 5. If the option “Use the following IP address” is selected, life is good. Change the subnet mask to “255.255.0.0” and click OK. Using DCHP If you want to use your drive on a network that where all or most of the devices use dynamic IP addresses supplied by a DHCP server, set the rotary switch to “F”. When the drive is connected to the network and powered on, it will obtain an IP address and a subnet mask from the server that is compatible with your PC. The only catch is that you won’t know what address the server assigns to your drive. Ethernet Configurator can find your drive using the Drive Discovery feature, as long as your network isn’t too large. With the drive connected to the network and powered on, select Drive Discovery from the Drive menu. You will see a dialog such as this: Normally, Drive Discovery will only detect one network interface card (NIC), and will select it automatically. If you are using a laptop and have both wireless and wired network connections, second NIC may appear. Please select the NIC that you use to connect to the network to which you’ve connected your drive. Then click OK. Drive Discovery will notify you as soon as it has detected a drive. a If you think this is the correct drive, click Yes. If you’re not sure, click Not Sure and Drive Discovery will look for additional drives on you network. Once you’ve told Drive Discovery which drive is yours, it will automatically enter that drive’s IP address in the IP address text box so that you are ready to communicate. 325 920-0002 Rev. J 12/2014 Host Command Reference Option 2: Connect a Drive Directly to Your PC 1. Connect one end of a CAT5 Ethernet cable into the LAN card (NIC) on your PC and the other into the drive. 2. Set the IP address on the drive to “10.10.10.10” by setting the rotary switch at “0”. 3. To set the IP address of your PC: a. On Windows XP, right click on “My Network Places” and select properties. b. On Windows 7, click Computer. Scroll down the left pane until you see “Network”. Right click and select properties. Select “Change adapter settings” 4. You should see an icon for your network interface card (NIC). Right click and select properties. a. Scroll down until you see “Internet Properties (TCP/IP)”. Select this item and click the Properties button. b. On Windows 7 and Vista, look for “(TCP/IPv4)” 5. Select the option “Use the following IP address”. Then enter the address “10.10.10.11”. This will give your PC an IP address that is on the same subnet as the drive. Windows will know to direct any traffic intended for the drive’s IP address to this interface card. 6. Next, enter the subnet mask as “255.255.255.0”. 7. Be sure to leave “Default gateway” blank. This will prevent your PC from looking for a router on this subnet. 8. Because you are connected directly to the drive, anytime the drive is not powered on your PC may annoy you with a small message bubble in the corner of your screen saying “The network cable is unplugged.” 920-0002 Rev. J 12/2014 326 Host Command Reference Option 3: Use Two Network Interface Cards (NICs) LAN NIC1 PC NIC2 DRIVE This technique allows you to keep your PC connected to your LAN, but keeps the drive off the LAN, preventing possible IP conflicts or excessive traffic. 1. If you use a desktop PC and have a spare card slot, install a second NIC and connect it directly to the drive using a CAT5 cable. You don’t need a special “crossover cable”; the drive will automatically detect the direct connection and make the necessary physical layer changes. 2. If you use a laptop and only connect to your LAN using wireless networking, you can use the built-in RJ45 Ethernet connection as your second NIC. 3. Set the IP address on the drive to “10.10.10.10” by setting the rotary switch at “0”. 4. To set the IP address of the second NIC: a. On Windows XP, right click on “My Network Places” and select properties. b. On Windows 7, click Computer. Scroll down the left pane until you see “Network”. Right click and select properties. Select “Change adapter settings” 5. You should see an icon for your newly instated NIC. Right click again and select properties. a. Scroll down until you see “Internet Properties (TCP/IP)”. Select this item and click the Properties button. b. On Windows 7 and Vista, look for “(TCP/IPv4)” 6. Select the option “Use the following IP address”. Then enter the address “10.10.10.11”. This will give your PC an IP address that is on the same subnet as the drive. Windows will know to direct any traffic intended for the drive’s IP address to this interface card. 7. Next, enter the subnet mask as “255.255.255.0”. Be sure to leave “Default gateway” blank. This will prevent your PC from looking for a router on this subnet. 8. Because you are connected directly to the drive, anytime the drive is not powered on your PC will annoy you with a small message bubble in the corner of your screen saying “The network cable is unplugged.” 327 920-0002 Rev. J 12/2014 Host Command Reference ARP Tables - The Ghost in the Machine ARP, which stands for “Address Resolution Protocol”, is a low-level router function that enables traffic to be correctly routed on the Ethernet network. It is handled automatically by the router and is normally transparent to the user. All network devices need to have two things: a MAC ID and an IP address. • • The MAC ID is a unique identifier that is assigned to the chip on the network interface device. You can think of it as a network serial number. The IP address is just that - an address. Like a street address on your house. IP addresses can be changed - MAC ID’s cannot. The following diagram shows a basic network. Note that each device has both a MAC ID and IP address. The router maintains an ARP table, which is really just a list that matches MAC ID’s to IP addresses. An entry is created for every device on the network. ARP TABLE MAC ID: 08:A4:C3:10:0E:00 MAC ID: A2:FB:3D:21:7A:01 MAC ID: 03:C8:11:2B:DE:02 IP: 192.168.1.100 IP: 192.168.1.101 IP: 192.168.1.102 Se ria l No S T 5 -Q MAC ID: 08:A4:C3:10:0E:00 IP: 192.168.1.100 n ree d d o C D E L V+ VA+ A- B+ X8 X8 / CC X7 / CC X7 / W WLIM / CWCW LIM IT LIM LIM IT IT+ 25 IT+ Y4 24 Y +5 Y4 23 CO V GN 22 Y2 Y3 MM OU D + 13 21 Y1 / MO/ FA ON T 12 20 11 19 / BR TIOUL 10 T 18 GN AK N 17 9 X1 D E 16 8 X1 / 15 7 X2 / ST 14 6 X2 / ST EP 5 X / DI EP + 4 X3 CO DI R+ 3 X4 / MM R 2 X5 / EN ON 1 X6 / AL AB / CCCW AR LE AN JO M AN AL WJ G RE AL OG OG SE T OG IN IN 2 1 B- MAC ID: A2:FB:3D:21:7A:01 IP: 192.168.1.101 EN es ST EP DR M IV OT ER OR =G GR RD GR =ReID GRE 1 RD RD SOL GR-+ + 2 2 RDRD GR- GR 1 GR + + 1 3 RDRD 1 GR 2 GR + + 4 4 RDRD 2 GR EDD 1 GR + + 5 5 RDRD 1 GR ABL ED) BLE 2 GR + + 6 6 RDRD DIS LL 1 GR ABL ENA 2 GR + + 7 STAIT 1 GR TOR (DIS P 2 GR MO TOR VE TEM 1 H MO TOR LIM ITMO R SE T MO LIM NAL ’T OVEE HIG CCW LOW REN S PHA CW SIG CAN VETAG E DRI TAG CUROHM TOR R R VOL MO ODE OR VOL OVE TOR N ENC ERR MO M OPE BAD COM MAC ID: 03:C8:11:2B:DE:02 IP: 192.168.1.102 It should be noted that computers maintain a local ARP table as well, tracking other devices they’ve interacted with. This is an important point because the ARP table on a PC will typically refresh more frequently than those on a network router or switch. So why do we care? Your application will probably require changing the IP address of a drive. The ARP table must then be refreshed to show the same MAC ID with a different IP address. This is usually not an issue if the drive is directly connected to the PC used to configure it, because the local ARP table will likely refresh quickly enough to catch the new IP address and re-establish a connection. The problem comes when the drive is connected through a router during configuration. In this scenario it is entirely possible for IP address changes to happen more frequently than the ARP table can refresh itself. Most routers do not allow users to refresh the ARP table directly, as this poses a significant network security risk. The router must actually be rebooted to force a reset of the ARP table and allow a connection with the new IP address. Obviously this is not an ideal solution. For this reason we recommend that all configuration be performed while directly connected to a PC. Do not use a router for drive configuration. Once an IP address is assigned the drive may be placed on the plant network without worry. NOTE: If you find that you are changing IP addresses often and the connection becomes unreliable, it may be necessary to force a refresh of your PC’s local ARP table. This can be accomplished by opening a command window and using the command arp -d. You must have administrator privileges on your PC to do this. 920-0002 Rev. J 12/2014 328 Host Command Reference Configuring Your Drive Three Windows programs are available from MOONS’ Products for use with our Ethernet drives. These programs are included on the CD that accompanies each drive and the most recent version is always available at www.moons.com.cn. ST Configurator is used to configure your stepper drive and motor. It can also be used to change the selection of drive IP addresses. ST Configurator includes extensive built-in help screens and manuals. Quick Tuner is used to configure and tune servo drives. The Quick Tuner Manual is automatically installed in the MOONS’ Products program menu when you install Quick Tuner. Q Programmer will be needed if you want to embed programs in the non-volatile memory of your drive, either to run automatically at power up or to be triggered by commands sent from a host. 329 920-0002 Rev. J 12/2014 Host Command Reference Creating Your Own Application To create your own application, you will need to choose a programming language, learn how SCL commands and responses are encapsulated in UDP packets, and learn to use your programming language’s interface to the network. UDP Packet Format eSCL is based on MOONS’’s Serial Command Language (SCL), an ASCII-based language with roots in RS-232 and RS-485 communication. eSCL drives support the full SCL and Q command sets, and utilize the speed and reliability of Ethernet. Commands and responses are encapsulated in the payload of User Datagram Protocol (UDP) packets, and are transmitted using standard Ethernet hardware and standard TCL/IP stacks. Sending Commands to a Drive An eSCL UDP packet consists of three parts, the header (binary 07), the SCL string (a sequence of ASCII encoded characters) and the SCL terminator (ASCII carriage return, 13) header SCL string Example: Sending “RV” • • • • SCL Header = 07 (two bytes) R = ASCII 82 V = ASCII 86 (ASCII carriage return) = 13 header 0 “RV” 7 82 86 13 Receiving Responses from a Drive A typical response to “RV” would be “RV=103” which would be formatted as header 0 “RV=103” 7 920-0002 Rev. J 12/2014 82 86 61 49 48 51 330 13 Host Command Reference Example Programs Both example programs are available for download at www.moons.com.cn. You should still read this section so that you understand the key elements of the code and what tradeoffs you may encounter. Visual Basic 6 Even though VB6 is an older language, its refreshing simplicity makes it a compelling choice for quickly developing an Ethernet application. To communicate over Ethernet from VB6, you’ll need the Winsock control (MSWINSCK.OCX), which is included in the Professional and Enterprise editions of the language. To configure an instance of Winsock, you must specify the protocol as UDP, choose a local port number, and set the remote IP address and port number to match the drive. In the code example below, 7775 is the port of the drive. driveIPaddress is the IP address of the drive (“10.10.10.10” or “192.168.0.130” for example). 7777 is the port of the PC. Winsock1.RemotePort = 7775 Winsock1.RemoteHost = driveIPaddress Winsock1.Protocol = sckUDPProtocol Winsock1.Bind 7777 // if port 7777 is in use by another application, you will get an error. // that error should be trapped using the On Error statement // and an alternate port should be chosen. Sending “RV” command: Dim myPacket(0 to 4) as Byte ‘ declare a byte array just large enough myPacket(0) = 0 myPacket(1) = 7 myPacket(2) = “R” myPacket(3) = “V” myPacket(4) = vbCR Winsock1.SendData myPacket ‘ ‘ ‘ ‘ ‘ first byte of SCL opcode second byte of SCL opcode R V carriage return 331 920-0002 Rev. J 12/2014 Host Command Reference To receive a response, you will need to place some code in the Winsock_DataArrival event. This event is automatically declared as soon as you add a Winsock control to your form. The DataArrival event will automatically trigger each time a packet is received. The code below extracts the SCL response from the UDP payload and displays it in a message box. Private Sub Winsock1_DataArrival(ByVal bytesTotal As Long) Dim udpData() As Byte, n As Integer Dim hexbyte As String, packetID As Long, SCLrx As String Winsock1.GetData udpData ‘ remotehost gets clobbered when packet rec’d, ‘ next line fixes it Winsock1.RemoteHost = Winsock1.RemoteHostIP ‘ first 16 bits of packet are the ID (opcode) If UBound(udpData) >= 1 Then packetID = 256 * udpData(0) + udpData(1) If packetID = 7 then ‘ SCL response SCLrx = “” For n = 2 To UBound(udpData) SCLrx = SCLrx & Chr(udpData(n)) Next n MsgBox SCLrx End If End If End Sub C#.NET The .NET languages are Microsoft’s modern, object oriented Windows application building tools and include robust Ethernet support. We present this example in C#. Make sure your project includes this line, providing access to an Ethernet socket: using System.Net.Sockets; In your form header you must declare a UdpClient object and create an instance, which can be done in the same line. The local port number is included in the “new UdpClient” call. This is the port number that will be reserved on the PC for your application. static UdpClient udpClient = new UdpClient(7777); To open the connection, invoke the Connect method, specifying the drive’s IP address and port number: udpClient.Connect(“192.168.0.130”, 7775); To send “RV” to the drive: //create a string loaded with the SCL command Byte[] SCLstring = Encoding.ASCII.GetBytes(“RV”); // create a byte array that will be used for the actual // transmission Byte[] sendBytes = new Byte[SCLstring.Length + 3]; // insert opcode (07 is used for all SCL commands) sendBytes[0] = 0; sendBytes[1] = 7; // copy string to the byte array System.Array.Copy(SCLstring, 0, sendBytes, 2, SCLstring.Length); // insert terminator sendBytes[sendBytes.Length - 1] = 13; // CR 920-0002 Rev. J 12/2014 332 Host Command Reference // send it to the drive udpClient.Send(sendBytes, sendBytes.Length); Getting responses back from the drive in C# is a more complicated than VB6. You have two choices: poll for a response or create a callback function that will provide a true receive event. Polling is easier to code but less efficient because you must either sit in a loop waiting for an expected response or run a timer to periodically check for data coming in. Since the choice depends on your programming style and the requirements of your application, we preset both techniques. Polling for an incoming packet The same UdpClient object that you use to send packets can be used to retrieve incoming responses from the drive. The Available property will be greater than zero if a packet has been received. To retrieve a packet, assign the Receive property to a Byte array. You must create an IPEndPoint object in order to use the Receive property. private void UDPpoll() { } // you can call this from a timer event or a loop if (udpClient.Available > 0) // is there a packet ready? { IPEndPoint RemoteIpEndPoint = new IPEndPoint(IPAddress.Any, 0); try { // Get the received packet. Receive method blocks // until a message returns on this socket from a remote host, // so always check .Available to see if a packet is ready. Byte[] receiveBytes = udpClient.Receive(ref RemoteIpEndPoint); // strip opcode Byte[] SCLstring = new byte[receiveBytes.Length - 2]; for (int i = 0; i < SCLstring.Length; i++) SCLstring[i] = receiveBytes[i + 2]; string returnData = Encoding.ASCII.GetString(SCLstring); AddToHistory(returnData); } catch (Exception ex) { // put your error handler here Console.WriteLine(ex.ToString()); } } 333 920-0002 Rev. J 12/2014 Host Command Reference Creating a receive event using a call back function First, create a function to handle incoming packets. This function must contain two local objects: a UdpClient and an IPEndPoint. The call back function will be passed an IAsyncResult object that contains a reference to the UDP connection. The local IPEndPoint object is passed to the UDPClient’s EndReceive property to retrieve the packet. public void ReceiveCallback(IAsyncResult ar) { int opcode; UdpClient u = (UdpClient)((UdpState)(ar.AsyncState)).u; IPEndPoint e = (IPEndPoint)((UdpState)(ar.AsyncState)).e; Byte[] receiveBytes = u.EndReceive(ar, ref e); // get opcode opcode = 256 * receiveBytes[0] + receiveBytes[1]; if (opcode == 7) // SCL response { string receiveString = Encoding.ASCII.GetString(receiveBytes); Byte[] SCLstring = new Byte[receiveBytes.Length - 2]; // remove opcode System.Array.Copy(receiveBytes, 2, SCLstring, 0, SCLstring. Length); receiveString = Encoding.ASCII.GetString(SCLstring); AddToHistory(receiveString); } else if (opcode == 99) // ping response { MessageBox.Show(“Ping!”, “eSCL Utility”, MessageBoxButtons.OK, MessageBoxIcon.Information); } } The call back function will not be called unless it is “registered” with the UdpClient object using the BeginReceive method, as shown below. StartRecvCallback can be called from the Form Load event. It must also be re-registered each time it is called (this is to prevent recursion), which is most easily accomplished by making a call to StartRecvCallback each time you send a packet. private void StartRecvCallback() { UdpState s = new UdpState(); s.e = new IPEndPoint(IPAddress.Any, 0); s.u = udpClient; udpClient.BeginReceive(new AsyncCallback(ReceiveCallback), s); } This example requires that you declare a class called UdpState as described below. class UdpState { public UdpClient u; public IPEndPoint e; } As if this event driven technique wasn’t quirky enough, it also creates a threading error unless the following statement in included in the form load event // this must be so for callbacks which operate in a different thread CheckForIllegalCrossThreadCalls = false; 920-0002 Rev. J 12/2014 334 Host Command Reference Further Reading The following materials can be downloaded from www. Applied-motion.com. • The eSCL Utility will help you get familiar with the SCL language. • ST Configuration Ethernet is needed to configure the ST5-QE and ST10-QE step motor drives. This application also includes extensive help screens. • QuickTuner is used to configure and tune SV7 servo drives. . Quick Tuner also includes extensive help screens. • Visual Basic and C# example projects can be downloaded from the software page. To learn more about networking using Ethernet, we recommend reading Sams Teach Yourself TCP/IP in 24 Hours, available from amazon.com and other fine booksellers. 335 920-0002 Rev. J 12/2014 Host Command Reference Appendix H: EtherNet/IP EtherNet/IP products, designated by the letters “IP” in the model number, provide access to Q and SCL functionality over EtherNet/IP networks. This appendix details which commands are available and how to encapsulate them into EtherNet/IP and CIP packets. It is assumed that the user has a working knowledge of EtherNet/IP as it relates to the controller being used, as this chapter will not explain general EtherNet/IP implementation details. MOONS’ offers both Class 1 and Class 3 type connections, each of which are useful for specific tasks. Class 1 connections are useful for high bandwidth tasks such as monitoring specific functions of the drive, while Class 3 connections are used for sending targeted messages to directly control the drive. The latter is used to implement Explicit Messaging. Note that with EtherNet/IP, all data direction notation assumes the point of view of the network. In this way, data sent by the drive to the controller is referred to as an Input, while data sent by the controller down to the drive is referred to as an Output. The Class 1 Connection Class 1 connections use Connection Points, which can be thought of as addresses with predefined functions. To communicate with an MOONS’ drive using a Class 1 connection, the following connection points are available. Object ID Function Notes Hex Decimal 0x64 100 Input Assembly 0x66 102 Configuration Assembly 0x67 103 Heartbeat Input Only Assembly Zero-length message that tells the controller the drive is still active. 0x68 104 Heartbeat Listen Only Assembly Zero-length message that tells the drive the controller is still active. 920-0002 Rev. J 12/2014 Static Assembly Object for monitoring drive status & behavior (see below for details) Specifies parameters such as packet interval, data length. 336 Host Command Reference Input Assembly (0x64) This connection point is used to monitor the drive’s behavior. The 32 bytes of data sent by the drive are as follows: use. Field Descriptor Length (bytes) Sequence # 2 IP Address (Encoded in Internet Format) 4 Status Word 2 Alarm Word 2 Supply Voltage 2 Actual Current 2 Drive Temperature 2 Encoder Position (32-bit signed) 4 Absolute Position (32-bit signed) 4 Actual Velocity 2 Input Status (extended) 2 Input Status (main board) 2 Output Status 2 The data transmitted by the drive is sent in Little Endian format, so it will likely require rearranging before IP addresses said to be stored in “Internet Format” are simply encoded into hexadecimal notation and rearranged into Little Endian format. Each octet has a value from 0-255, and can be represented by a single byte. Standard IP address: 192.168.0.40 Convert to Hexadecimal: 192 = 0xC0 168 = 0xA8 0 = 0x00 40 = 0x28 Rearrange into Little Endian Format: C0 A8 00 28 -> 28 00 A8 C0 Converted IP address: 192.168.0.40 -> 0x2800A8C0 Note that all numbers are sent in Little Endian format, so the process for converting is the same for each piece of data. 337 920-0002 Rev. J 12/2014 Host Command Reference Thus, an example message might be organized as follows: Raw: E0032800A8C019000000E90100003802BAFCFFFFC72A0600C3FFFF40000F0F00 Grouped: [E003] [2800A8C0] [1900] [0000] [E901] [0000] [3802] [BAFCFFFF] [C72A0600] [C3FF] [FF40] [000F] [0F00] The data should be decoded as follows. Where possible, the values have been converted to humanreadable units. Please refer to the appropriate command page for further information. Note that Encoder Position, Absolute Position and Velocity are signed integers, and negative values will be represented in 2’s complement form. Sequence Number: 0xE003 IP Address: 0x2800A8C0 = 0xC0A80028 = 192.168.0.40 Status (see SC command): 0x1900 = 0x0019 = 0000 0000 0001 1001 Alarm (see AL command): 0x0000 Voltage: 0xE901 = 0x01E9 = 489 (48.9 V) Current (see IC command): 0x0000 Temp (see IT0 command): 0x3802 = 0x238 = 568 (56.8 degrees C) Encoder Position (see EP command): 0xBAFCFFFF = 0xFFFFFCBA = -838 Absolute Position (see SP command): 0xC72A0600 = 0x00062AC7 = 404167 Velocity (see IV command): 0XC3FF = 0xFFC3 = -61 Extended Inputs (see IS command): 0xFF40 = 0x40FF Main Board Inputs: (see ISX command): 0x000F = 0x0F00 Outputs (see IO command): 0x0F00 = 0x000F Configuration Assembly (0x66) This connection point is used by the EtherNet/IP protocol to configure various parameters including the Receive Packet Interval (RPI), data size, etc. It must be specified by the user. Heartbeat Input Only Assembly (0x67) This connection point represents a zero-length assembly object whose purpose is not to send data, but rather to simply inform the controller that the drive is still active and producing data. Heartbeat Listen Only Assembly (0x68) This connection point represents a zero-length assembly object whose purpose is not to send data, but rather to simply inform the drive that the controller is still active and receiving data. 920-0002 Rev. J 12/2014 338 Host Command Reference Explicit Messaging Point of Interest The MOONS’ EtherNet/IP implementation allows for Explicit To check the drive’s profile code and ARM Messaging using either a Class 3 connection or the Unconnected firmware version, use the standard “Get Attribute Message Manager (UCMM). The service code of this custom profile Single” service with the following parameters: is 0x3C and the class code is 0x64. Service 0x0E In addition to the custom profile, the following standard objects Class 0x64 and services are implemented: Instance 0x00 • Message Router Object (Volume 1, Section 5-3) Attribute • Connection Manager (Volume 1, Section 5-7) • Connection Configuration (Volume 1, Section 5-50) • Port (Volume 1, Section 3-7) • Ethernet Link Object (Volume 2, Chapter 5) • TCP/IP Object (Volume 2, Chapter 5) • Assembly (Volume 1, Section 5-37) • CIP Sync Object (Volume 1, Section 5-47.7) Documentation can be found in the following ODVA specifications (specific sections are noted above next to each object name): 0x08 To communicate with the drive via Explicit Messages, use the Vendor-Specific profile service with the following parameters: Volume One: Common Industrial Protocol (CIP™), edition 3.8 Volume Two: EtherNet/IP™ Adaptation of CIP, edition 1.9 Message Type CIP Generic Service Type Custom Service 0x3C Class 0x64 Instance 0x01 Attribute 0x01 Services Name Service Class 0x0E Profile Code & ARM Firmware Version Example response message: 00.75.00.07.41.5F.00.01.03.4A 0x00 = ARM (Ethernet board) firmware major revision, most significant byte 0x75 = ARM (Ethernet board) firmware major revision, least significant byte 0x00 = ARM (Ethernet board) firmware minor revision, most significant byte 0x07 = ARM (Ethernet board) firmware minor revision, least significant byte 0x41 = ASCII ‘A’, the profile code 0x5F = 95, Model Number (see table below) 0x00 = Sub-model Number (see table below) 0x01 = 1, Drive firmware major revision number (1.xx) 0x03 = 3, Drive firmware minor revision number (x.03) 0x4A = ASCII ‘J’, Drive firmware revision letter (x.xxJ) 0x64 Instance Attribute 0x00 0x01 (“Get Attribute Single”) ARM firmware : [major rev] . [minor rev] = [0x0075] . [0x0007] = 117.07 Drive Model Number Identification Table Model ID Sub-Model ID Hex [Dec] Hex [Dec] 0x0F [15] -- 0x11 [17] -- 0x13 [19] -- 0X32[50] Drive Model Number Model ID Sub-Model ID Hex [Dec] Hex [Dec] Drive Model Number SV7-IP 0X32 [50] 0x0C [12] STM23Q-3EE ST5-IP 0x53 [83] -- STAC5-IP ST10-IP 0x59 [89] -- STAC5-IP-220 0x09 [9] STM23Q-2EN 0x5F [95] -- SVAC3-IP 0X32[50] 0x0A [10] STM23Q-2EE 0x65 [101] -- SVAC3-IP-220 0X32[50] 0x0B [11] STM23Q-3EN 339 920-0002 Rev. J 12/2014 Host Command Reference Vendor-Specific Device Profile A 0x3C 0x64 0x01 0x01 Explicit Message Types Two types of explicit messages can be sent to MOONS’ EtherNet/IP drives. Type 1 messages include most of the buffered SCL and Q commands. However, unlike SCL and Q commands that are sent over RS-232, RS485 and standard Ethernet, Type 1 messages do not support queries. “Immediate” SCL commands cannot be encapsuated in Type 1 messages. Type 2 messages provide additional functionality not available with Type 1 messages, including the ability to read back settings and registers. Both types can be sent over a Class 3 connection, or they can be sent to the Unconnected Message Manager (UCMM). Both command message types result in a response message even when no data is requested. All numerical values are in two’s complement. Integers are sent big endian (most significant byte first). For detailed SCL and Q command descriptions, please see the main section of this manual. When reading the command descriptions in the main part of this manual, please be advised that the EtherNet/IP encapsulation often requires that different units, and a different range of acceptable values, be used. Type 1 Message Format See Table 1 for the complete list of commands. The response message will always echo back the opcode and register code (if present). Also contained in the response message is the drive’s status code, a bit pattern that indicates useful information such as whether there is a fault or if the motor is in motion. For more information, please see the section on the SC command earlier in this manual. Note: All numerical values are in two’s complement. Integers are sent big endian (most significant byte first). Command Message Format: Bit 7 Bit 6 Bit 5 Bit 4 Bit 3 Bit 2 Bit 1 Bit 0 B0 Reserved =0 Reserved =0 Reserved =0 Reserved =0 Reserved =0 Reserved =0 Reserved =0 Reserved =0 B1 Command Axis Number = 0x0 B2 Register, I/O or other code here for some commands (see Table 1, page 275). 0 for all others. B3 Opcode B4 Parameter1 B5 Parameter2 B6 Parameter3 B7 Parameter4 Command Message Type = 0x1 Response Message Format: Bit 7 Bit 6 Bit 5 Bit 4 Bit 3 Bit 2 Bit 1 Bit 0 B0 Reserved =0 Reserved =0 Reserved =0 Reserved =0 Reserved =0 Reserved =0 Reserved =0 Reserved =0 B1 Response Axis Number = 0x0 B2 Register code for commands QR, RR, RW and RX, 0 for all others B3 Opcode B4 Status Code MSB B5 Status Code LSB B6 Unused = 0 920-0002 Rev. J 12/2014 Response Message Type = 0x1 340 Host Command Reference B7 Unused = 0 Type 1 Message Examples Example 1: SCL commands required for Point to Point move AC100 set acceleration rate to 100 rev/sec/sec (6000 rpm/sec) opcode 0x001E from Table 1 operand 0x258 units are 10 rpm/sec, so 6000 rpm/sec is represented by 600 decimal = 258 hex Type 1 Command Message Payload Type 1 Response Message Payload byte 0 0 reserved byte 0 0 reserved byte 1 1 message type byte 1 1 message type byte 2 0 unused byte 2 0 unused byte 3 1E opcode byte 3 1E opcode byte 4 0 unused byte 4 ? Status Code MSB byte 5 0 unused byte 5 ? Status Code LSB byte 6 2 operand MSB byte 6 0 not used byte 7 58 operand LSB byte 7 0 not used DE100 set deceleration rate to 100 rev/sec/sec (6000 rpm/sec) opcode 0x001F from Table 1 operand 0x258 units are 10 rpm/sec, so 6000/sec is represented by 600 decimal = 258 hex Type 1 Command Message Payload Type 1 Response Message Payload byte 0 0 reserved byte 0 0 reserved byte 1 1 message type byte 1 1 message type byte 2 0 unused byte 2 0 unused byte 3 1F opcode byte 3 1F opcode byte 4 0 unused byte 4 ? Status Code MSB byte 5 0 unused byte 5 ? Status Code LSB byte 6 2 operand MSB byte 6 0 not used byte 7 58 operand LSB byte 7 0 not used VE5 set velocity to 5 rev/sec (300 rpm) opcode 0x001D from Table 1 operand 0x4B0 units are 0.25 rpm, so 300 rpm is represented by 1200 decimal = 4B0 hex 341 920-0002 Rev. J 12/2014 Host Command Reference Type 1 Command Message Payload Type 1 Response Message Payload byte 0 0 reserved byte 0 0 reserved byte 1 1 message type byte 1 1 message type byte 2 0 unused byte 2 0 unused byte 3 1D opcode byte 3 1D opcode byte 4 0 unused byte 4 ? Status Code MSB byte 5 0 unused byte 5 ? Status Code LSB byte 6 4 operand MSB byte 6 0 not used byte 7 B0 operand LSB byte 7 0 not used DI100000 set move distance to 100,000 steps opcode 0x00B6 from Table 1 operand 0x186A0 units are steps, so 100000 is represented by 186A0 hex Type 1 Command Message Payload Type 1 Response Message Payload byte 0 0 reserved byte 0 0 reserved byte 1 1 message type byte 1 1 message type byte 2 0 not used byte 2 0 not used byte 3 B6 opcode byte 3 B6 opcode byte 4 0 not used byte 4 ? Status Code MSB byte 5 1 operand MSB byte 5 ? Status Code LSB byte 6 86 operand 2nd LSB byte 6 0 not used byte 7 A0 operand LSB byte 7 0 not used FL start the “feed to length” move opcode 0x0066 from Table 1 operand 0 no operand Type 1 Command Message Payload Type 1 Response Message Payload byte 0 0 reserved byte 0 0 reserved byte 1 1 message type byte 1 1 message type byte 2 0 unused byte 2 0 unused byte 3 66 opcode byte 3 66 opcode byte 4 0 not used byte 4 ? Status Code MSB byte 5 0 not used byte 5 ? Status Code LSB byte 6 0 not used byte 6 0 not used byte 7 0 not used byte 7 0 not used Example 2: setting an output SO2L set output 2 low (closed) opcode 0x008B from Table 1 920-0002 Rev. J 12/2014 342 Host Command Reference operand 0x4CB2 LSB is “2” = 0xB2. MSB is “L” = 0x4C (see IO Encoding Table) Type 1 Command Message Payload Type 1 Response Message Payload byte 0 0 reserved byte 0 0 reserved byte 1 1 message type byte 1 1 message type byte 2 0 not used byte 2 0 not used byte 3 8B opcode byte 3 8B opcode byte 4 0 not used byte 4 ? Status Code MSB byte 5 0 not used byte 5 ? Status Code LSB byte 6 4C operand MSB byte 6 0 not used byte 7 B2 operand LSB byte 7 0 not used Example 3: enabling the motor ME motor enable opcode 0x009F from Table 1 operand 0 no operand Type 1 Command Message Payload Type 1 Response Message Payload byte 0 0 reserved byte 0 0 reserved byte 1 1 message type byte 1 1 message type byte 2 0 unused byte 2 0 unused byte 3 9F opcode byte 3 9F opcode byte 4 0 not used byte 4 ? Status Code MSB byte 5 0 not used byte 5 ? Status Code LSB byte 6 0 not used byte 6 0 not used byte 7 0 not used byte 7 0 not used Example 4: SCL commands required for Feed to Sensor move AC200 set acceleration rate to 200 rev/sec/sec (12000 rpm/sec) opcode 0x001E from Table 1 operand 0x4B0 units are 10 rpm/sec, so 12000 rpm/sec is represented by 1200 decimal = 4B0 hex Type 1 Command Message Payload Type 1 Response Message Payload byte 0 0 reserved byte 0 0 reserved byte 1 1 message type byte 1 1 message type byte 2 0 unused byte 2 0 unused byte 3 1E opcode byte 3 1E opcode byte 4 0 unused byte 4 ? Status Code MSB byte 5 0 unused byte 5 ? Status Code LSB byte 6 4 operand MSB byte 6 0 not used byte 7 B0 operand LSB byte 7 0 not used DE150 set deceleration rate to 150 rev/sec/sec (9000 rpm/sec) 343 920-0002 Rev. J 12/2014 Host Command Reference opcode 0x001F from Table 1 operand 0x384 units are 10 rpm/sec, so 9000/sec is represented by 900 decimal = 384 hex Type 1 Command Message Payload Type 1 Response Message Payload byte 0 0 reserved byte 0 0 reserved byte 1 1 message type byte 1 1 message type byte 2 0 unused byte 2 0 unused byte 3 1F opcode byte 3 1F opcode byte 4 0 unused byte 4 ? Status Code MSB byte 5 0 unused byte 5 ? Status Code LSB byte 6 3 operand MSB byte 6 0 not used byte 7 84 operand LSB byte 7 0 not used VE3 set velocity to 3 rev/sec (180 rpm) opcode 0x001D from Table 1 operand 0x2D0 units are 0.25 rpm, so 180 rpm is represented by 720 decimal = 2D0 hex Type 1 Command Message Payload Type 1 Response Message Payload byte 0 0 reserved byte 0 0 reserved byte 1 1 message type byte 1 1 message type byte 2 0 unused byte 2 0 unused byte 3 1D opcode byte 3 1D opcode byte 4 0 unused byte 4 ? Status Code MSB byte 5 0 unused byte 5 ? Status Code LSB byte 6 2 operand MSB byte 6 0 not used byte 7 D0 operand LSB byte 7 0 not used DI5000 set move distance to 5,000 steps (this is the distance beyond the sensor where motor will stop) opcode 0x00B6 from Table 1 operand 0x1388 units are steps, so 5000 is represented by 1388 hex Type 1 Command Message Payload Type 1 Response Message Payload byte 0 0 reserved byte 0 0 reserved byte 1 1 message type byte 1 1 message type byte 2 0 unused byte 2 0 unused byte 3 B6 opcode byte 3 B6 opcode byte 4 0 operand MSB byte 4 ? Status Code MSB byte 5 0 operand 2nd MSB byte 5 ? Status Code LSB byte 6 13 operand 2nd LSB byte 6 0 not used byte 7 88 operand LSB byte 7 0 not used FS2R start the “feed to sensor” move, stop 5000 steps after input 2 rising edge opcode 0x006B from Table 1 operand 0x52B2 LSB is “2” = 0xB2. MSB is “R” = 0x52 (see IO Encoding Table) 920-0002 Rev. J 12/2014 344 Host Command Reference Type 1 Command Message Payload Type 1 Response Message Payload byte 0 0 reserved byte 0 0 reserved byte 1 1 message type byte 1 1 message type byte 2 0 unused byte 2 0 unused byte 3 6B opcode byte 3 6B opcode byte 4 0 not used byte 4 ? Status Code MSB byte 5 0 not used byte 5 ? Status Code LSB byte 6 52 condition (R) byte 6 0 not used byte 7 B2 ionum (2) byte 7 0 not used 345 920-0002 Rev. J 12/2014 Host Command Reference Type 2 Message Format Message Type 2 commands provide functionality that is not available with Type 1 commands. This is the only way to read back information from the drive. All Type 2 commands require and 8 bit opcode and an 8 bit operand. Return values include a 16 or 32 bit response, as appropriate. The response message will always echo back the opcode and operand from the command message. Also contained in the response message is the drive’s status code, unless other information is requested (e.g. parameter read command). The status code is a bit pattern that indicates useful information such as whether there is a fault or if the motor is in motion. For more information, please see the section on the SC command earlier in this manual. Command Message Format: Bit 7 Bit 6 Bit 5 Bit 4 Bit 3 Bit 2 Bit 1 Bit 0 B0 Reserved =0 Reserved =0 Reserved =0 Reserved =0 Reserved =0 Reserved =0 Reserved =0 Reserved =0 B1 Command Axis Number = 0x0 B2 Opcode (see Table 2) B3 Operand (see Table 2) B4 Data MSB B5 Data LSB [Data 2nd MSB for opcode 0x9E] B6 Unused = 0 [Data 2nd LSB for opcode 0x9E] B7 Unused = 0 [Data LSB for opcode 0x9E] Command Message Type = 0x2 Response Message Format: Bit 7 Bit 6 Bit 5 Bit 4 Bit 3 Bit 2 Bit 1 Bit 0 B0 Reserved =0 Reserved =0 Reserved =0 Reserved =0 Reserved =0 Reserved =0 Reserved =0 Reserved =0 B1 Response Axis Number = 0x0 B2 Opcode (see Table 2) B3 Operand (see Table 2) B4 Status MSB [Data MSB for opcodes 0x84, 0x88, 0x89, 0x9F] B5 Status LSB [Data LSB for opcodes 0x84, 0x88, 0x89] [Data 2nd MSB for opcode 0x9F] B6 Unused = 0 [Data 2nd LSB for opcode 0x9F] B7 Unused = 0 [Data LSB for opcode 0x9F] 920-0002 Rev. J 12/2014 Response Message Type = 0x2 346 Host Command Reference Type 2 Message Examples Example 1: parameter write AC100 set acceleration rate to 100 rev/sec/sec (6000 rpm/sec) opcode 0x83 operand 0x1E data parameter write, from Table 2 from Table 3 0x258 units are 10 rpm/sec, so 6000/sec is represented by 600 decimal = 258 hex Type 2 Command Message Payload Type 2 Response Message Payload byte 0 0 reserved byte 0 0 reserved byte 1 2 message type byte 1 2 message type byte 2 83 opcode byte 2 83 opcode byte 3 1E operand byte 3 1E operand byte 4 2 data MSB byte 4 ? Status Code MSB byte 5 58 data LSB byte 5 ? Status Code LSB byte 6 0 not used byte 6 0 not used byte 7 0 not used byte 7 0 not used Example 2: parameter read AC read back the acceleration rate opcode 0x84 parameter read, from Table 2 operand 0x1E from Table 3 return value 0x258 units are 10 rpm/sec, so 6000/sec is represented by 600 decimal = 258 hex Type 2 Command Message Payload Type 2 Response Message Payload byte 0 0 reserved byte 0 0 reserved byte 1 2 message type byte 1 2 message type byte 2 84 opcode byte 2 84 opcode byte 3 1E operand byte 3 1E operand byte 4 0 not used byte 4 2 read data MSB byte 5 0 not used byte 5 58 read data LSB byte 6 0 not used byte 6 0 not used byte 7 0 not used byte 7 0 not used 347 920-0002 Rev. J 12/2014 Host Command Reference Example 3: read absolute position opcode 0x88 read 32 bit abs posn/enc posn, from Table 2 operand 1 from Table 2, indicates abs posn return value 0x87654321 Type 2 Command Message Payload Type 2 Response Message Payload byte 0 0 reserved byte 0 0 reserved byte 1 2 message type byte 1 2 message type byte 2 88 opcode byte 2 88 opcode byte 3 1 operand byte 3 1 operand byte 4 0 not used byte 4 87 read data MSB byte 5 0 not used byte 5 65 read data 2nd MSB byte 6 0 not used byte 6 43 read data 2nd LSB byte 7 0 not used byte 7 21 read data LSB Example 4: read encoder position opcode 0x88 read 32 bit abs posn/enc posn, from Table 2 operand 0 from Table 2, indicates enc posn return value 0x12345678 Type 2 Command Message Payload Type 2 Response Message Payload byte 0 0 reserved byte 0 0 reserved byte 1 2 message type byte 1 2 message type byte 2 88 opcode byte 2 88 opcode byte 3 0 operand byte 3 0 operand byte 4 0 not used byte 4 12 read data MSB byte 5 0 not used byte 5 34 read data 2nd MSB byte 6 0 not used byte 6 56 read data 2nd LSB byte 7 0 not used byte 7 78 read data LSB Example 5: read Q user register 3 opcode 0x9F read 32 bit Q register, from Table 2 operand 0x33 from Reg Code Table, indicates register ‘3’ return value 0x12345678 Type 2 Command Message Payload Type 2 Response Message Payload byte 0 0 reserved byte 0 0 reserved byte 1 2 message type byte 1 2 message type byte 2 9F opcode byte 2 9F opcode byte 3 33 operand byte 3 33 operand byte 4 0 not used byte 4 12 read data MSB byte 5 0 not used byte 5 34 read data 2nd MSB byte 6 0 not used byte 6 56 read data 2nd LSB byte 7 0 not used byte 7 78 read data LSB 920-0002 Rev. J 12/2014 348 Host Command Reference Example 6: read Q register D opcode 0x9F read 32 bit Q register, from Table 2 operand 0x44 from Reg Code Table, indicates register ‘D’ return value 0x12345678 Type 2 Command Message Payload Type 2 Response Message Payload byte 0 0 reserved byte 0 0 reserved byte 1 2 message type byte 1 2 message type byte 2 9F opcode byte 2 9F opcode byte 3 44 operand byte 3 44 operand byte 4 0 not used byte 4 12 read data MSB byte 5 0 not used byte 5 34 read data 2nd MSB byte 6 0 not used byte 6 56 read data 2nd LSB byte 7 0 not used byte 7 78 read data LSB Example 7: write Q register D opcode 0x9E operand 0x44 read 32 bit Q register, from Table 2 from Reg Code Table, indicates register ‘D’ data 0x12345678 Type 2 Command Message Payload Type 2 Response Message Payload byte 0 0 reserved byte 0 0 reserved byte 1 2 message type byte 1 2 message type byte 2 9E opcode byte 2 9E opcode byte 3 44 operand byte 3 44 operand byte 4 12 data MSB byte 4 ? status code MSB byte 5 34 data 2nd MSB byte 5 ? status code LSB byte 6 56 data 2nd LSB byte 6 0 not used byte 7 78 data LSB byte 7 0 not used Example 8: Disable IEEE-1588 protocol (for Class 1 connections) opcode 0xFE operand 0x1 IEEE-1588 control, from Table 2 Disable IEEE-1588 protocol. (0x0 will enable IEEE-1588) data 0x0 Type 2 Command Message Payload Type 2 Response Message Payload byte 0 0 reserved byte 0 0 reserved byte 1 2 message type byte 1 2 message type byte 2 FE opcode byte 2 FE opcode byte 3 1 operand byte 3 0 operand byte 4 0 not used byte 4 ? status code MSB byte 5 0 not used byte 5 ? status code LSB byte 6 0 not used byte 6 0 not used byte 7 0 not used byte 7 0 not used 349 920-0002 Rev. J 12/2014 Host Command Reference Table 1: Message Type 1 Command List Units MAX_ACCEL, 16 0 accel rate 1..32000 10 rpm/sec AX ALARM_RESET BA 0 CJ START_JOGGING 96 0 DC SET_CHNG_ DISTANCE B7 0 +/-2,147,483,647 steps DE P_TO_P_DECEL, 1F 0 1..32000 10 rpm/sec DI SET_REL_DISTANCE B6 0 +/-2,147,483,647 steps EF ENCODER_ FUNCTION D6 0 function 0,1,2 or 4 0 = Encoder function off 1 = Stall Detection 2 = Stall Prevention 4 = Stall prevention w/ time-out EG Steps/rev / 2 26 0 steps/rev EP ENCODER_POSITION 98 0 FC P_TO_P_CHANGE 6D 0 FD feed to double sensor 69 0 FE FOLLOW ENCODER CC 0 FL feed to length (relative 66 0 move) FM Feed to Sensor with mask distance FO Parameter 4 AM Parameter 3 10 rpm/sec Parameter 2 1..32000 Parameter 1 accel rate Reg code 1E 0 opcode (hex) P_TO_P_ACCEL, Description AC Command Range ST5 / ST10 / STAC5 For detailed SCL and Q command descriptions, please see the main section of this manual. When reading the command descriptions in the main part of this manual, please be advised that the EtherNet/IP encapsulation often requires that different units, and a different range of acceptable values, be used. Motion Commands 32 bit distance or position decel rate 32 bit distance or position 100..25600 steps/rev divided by 2 32 bit encoder position +/-2,147,483,647 counts cond io2 2 cond io1 1 ST: X0..X8, L/H/F/R STAC5: X0..X4, 1..8. L/H/F/R see IO Encoding Table cond io ST: X0..X8, L/H/F/R STAC5: X0..X4, 1..8. L/H/F/R see IO Encoding Table 6A 0 cond io ST: X0..X8, L/H/F/R STAC5: X0..X4, 1..8. L/H/F/R see IO Encoding Table feed and set output 68 0 cond io ST: Y1..Y4, L or H see IO Encoding Table STAC5: 1..4, Y1,Y2. L or H FP feed to position (absolute move) 67 0 FS Feed to Sensor 6B 0 cond io ST: X0..X8, L/H/F/R STAC5: X0..X4, 1..8. L/H/F/R 920-0002 Rev. J 12/2014 350 see IO Encoding Table FY Feed to Sensor with safety distance Units Range ST5 / ST10 / STAC5 Parameter 4 Parameter 3 Parameter 2 Parameter 1 Reg code opcode (hex) Description Command Host Command Reference 6C 0 cond io ST: X0..X8, L/H/F/R STAC5: X0..X4, 1..8. L/H/F/R see IO Encoding Table HW Hand wheel AB 0 cond io ST: X0..X8, L/H/F/R STAC5: X0..X4, 1..8. L/H/F/R see IO Encoding Table JA VM_ACCEL, 1B 0 jog accel rate 1..32000 10 rpm/sec JD JOG_DISABLE A3 0 JE JOG_ENABLE A2 0 direction 1=cw enable, 2=ccw enable, 3=both JL VM_DECEL, 1C 0 jog decel rate 1..32000 10 rpm/sec JS VM_VELOCITY, 1A 0 jog speed 0..32000 .25 rpm MD MOTOR_DISABLE 9E 0 ME MOTOR_ENABLE 9F 0 MT Multi Tasking A9 0 0 0 or 1 1=on, 0=off SH SEEK_HOME, ionum+cond 6E 0 cond io ST: X0..X8, L/H/F/R STAC5: X0..X4, 1..8. L/H/F/R see IO Encoding Table SM STOP_MOVING B5 0 decel code D (DE rate) or M (AM rate) SP SET_ABS_POSITION A5 0 VC CHANGE_VELOCITY, 4A 0 VE P_TO_P_VELOCITY, 1D 0 speed 1..32000 .25 rpm WI Wait for Input 70 0 cond io ST: X0..X8, L/H/F/R STAC5: X0..X4, 1..8. L/H/F/R see IO Encoding Table WM WAIT_ON_MOVE 0 or 1 32 bit abs position speed ‘D’ or ‘M’ +/-2,147,483,647 steps 1..32000 .25 rpm BC 0 WP WAIT_ON_POSITION Configuration Commands D0 0 -- RESTORE_DEFAULTS A6 AD Analog Deadband D2 0 dead band 0..255 351 millivolts 920-0002 Rev. J 12/2014 BD BRAKE RELEASE DELAY 40 0 brake release delay 1..32000 msec BE BRAKE ENGAGE DELAY 41 0 brake engage delay 1..32000 msec CA ACCEL_CURRENT, 61 0 accel current not supported 10 rpm/sec CC Running CURRENT 18 0 motor current when running 500 / 1000 / 500 .01 amps CD IDLE_CURRENT_ DELAY, 4F 0 delay time 1..32000 msec CI IDLE CURRENT 19 0 motor current when idle 500 / 1000 / 500 .01 amps CM CONTROL_MODE, 10 0 mode code 7, 10..18, 21, 22 EF Encoder Function D6 0 function code 0,1,2 or 4 0 = Encoder function off 1 = Stall detection 2 = Stall prevention 4 = Stall prevention w/ time-out ER ENCODER_ RESOLUTION, 20 0 encoder line count 50..32000 lines/rev (counts/rev/4) FI Filter Input C0 io filter value 0..32767 CPU cycles FX Filter Select Inputs D3 0 input bank 0 or 1 1=IN/OUT1, 0=IN/OUT2 920-0002 Rev. J 12/2014 352 Units 0 = single-ended +/- 10 volts 1 = single-ended 0 - 10 volts 2 = single-ended +/- 5 volts 3 = single-ended 0 - 5 volts 4 = differential +/- 10 volts 5 = differential 0 - 10 volts 6 = differential +/- 5 volts 7 = differential 0 - 5 volts Parameter 4 scale code 0..7 Parameter 3 D1 0 Parameter 2 opcode (hex) Analog Scaling Parameter 1 Description AS Reg code Command Range ST5 / ST10 / STAC5 Host Command Reference HP harmonic smoothing phase 5 0 phase +/-255 PA PU_ACCEL_ CURRENT D7 0 current STM only .01 amps PF POSITION_FAULT, 21 0 posn fault limit 1..32000 encoder counts PM OPERATION_MODE, 44 0 mode code 2 or 7 6 freq 100..25000 0.1 Hz SF STEP_FILTER_ FREQUENCY, I/O Commands 0 Units 0..32000 Parameter 4 gain Parameter 3 0 Parameter 2 4 Parameter 1 Reg code harmonic smoothing gain Description HG Command opcode (hex) Range ST5 / ST10 / STAC5 Host Command Reference AD ANALOG_DEADBAND D2 0 deadband 0..255 mV AF ANALOG_FILTER_ GAIN, freq 0..32000 Filter value = 72090 / [ (1400 / Hz ) + 2.2 ]. O=no filter AG ANALOG_VELOCITY_ 3B 0 GAIN, speed at full scale +/-32000 .25 rpm AI ALARM_RESET INPUT 46 0 state 1..3 AO FAULT OUTPUT 47 0 state 1..3 AP ANALOG_POSITION_ GAIN, 4B 0 posn at full 1..32000 scale steps AS ANALOG_SCALING D1 0 input range 0..7 0 = single-ended +/- 10 volts 1 = single-ended 0 - 10 volts 2 = single-ended +/- 5 volts 3 = single-ended 0 - 5 volts 4 = differential +/- 10 volts 5 = differential 0 - 10 volts 6 = differential +/- 5 volts 7 = differential 0 - 5 volts AT ANALOG_ THRESHOLD, 4D 0 threshold voltage +/-32767 ADC Counts 32767 = +10 volts -32767 = -10 volts AV ANALOG_OFFSET, 3C 0 offset +/-32000 ADC counts AZ AUTO_OFFSET A1 0 4C 0 353 920-0002 Rev. J 12/2014 Units BRAKE ENGAGE DELAY 41 0 brake engage delay 1..32000 msec BO BRAKE_OUTPUT, 48 0 state 1..3 DL DEFINE_LIMITS, 42 0 state 1..3 FI FILTER_INPUT C0 io filter value 0..32767 FX FILTER_SELECT_ INPUTS D3 0 input bank 0=extended, 1 = main board JD JOG_DISABLE A3 0 JE JOG_ENABLE A2 0 direction 1=cw enable, 2=ccw enable, 3=both 49 0 state 1..3 ST: X0..X8, L/H/F/R STAC5: X0..X4, 1..8. L/H/F/R MO MOVE_OUTPUT, Parameter 4 BE Parameter 3 msec Parameter 2 1..32000 Parameter 1 brake release delay Reg code 40 0 opcode (hex) BRAKE RELEASE DELAY Description BD Command Range ST5 / ST10 / STAC5 Host Command Reference CPU cycles OI ON_INPUT B9 0 cond io see IO encoding table SI ENABLE INPUT 45 0 state 1..3 SO Set Output 8B 0 cond io ST: Y1..Y4, L or H see IO Encoding Table STAC5: 1..4, Y1,Y2. L or H TI Test Input A8 0 cond io ST: X0..X8, L/H/F/R STAC5: X0..X4, 1..8. L/H/F/R see IO Encoding Table WI Wait for Input 70 0 cond io ST: X0..X8, L/H/F/R STAC5: X0..X4, 1..8. L/H/F/R see IO Encoding Table Register Commands CR Compare Registers BE 0 reg 1 reg 2 a..z or A..Z or 0..9 see register code table R+ Register add B2 2B reg 1 reg 2 a..z or A..Z or 0..9 see register code table R- Register subtract B2 2D reg 1 reg 2 a..z or A..Z or 0..9 see register code table R* Register multiply B2 2A reg 1 reg 2 a..z or A..Z or 0..9 see register code table R/ Register divide B2 2F reg 1 reg 2 a..z or A..Z or 0..9 see register code table R& Register and B2 26 reg 1 reg 2 a..z or A..Z or 0..9 see register code table 920-0002 Rev. J 12/2014 354 Units see IO Encoding Table AF 0 reg code A..Z or 0..9 see register code table Register Increment B0 0 reg code A..Z or 0..9 see register code table RM REGISTER MOVE B1 0 dest src reg reg source: a..z or A..Z or 0..9. dest: A..Z or 0..9 see register code table RR REGISTER_READ from mem B3 reg NV mem location reg: A..Z or 0..9. memory location: 1..100 see register code table RW REGISTER_WRITE to mem B4 reg NV mem location reg: a..z or A..Z or 0..9. memory location: 1..100 see register code table RX REGISTER_LOAD AE reg value (16 or 32 bits, depending on register type) reg: A..Z or 0..9 value: +/2147483647 (long data registers) +/32767 (short data registers) see register code table TR Test Register Immediate AC reg value (16 or 32 bits, reg: a..z or A..Z or 0..9 value: +/2147483647 (long data registers) +/32767 (short data registers) see register code table 0 or 1 1=on, 0=off B2 7C reg 1 reg 2 RC Register Counter BB 0 RD Register Decrement RI Parameter 2 Register or Parameter 1 R| Reg code Parameter 4 ST: X0..X8, L/H/F/R STAC5: X0..X4, 1..8. L/H/F/R Parameter 3 cond io opcode (hex) see register code table Description a..z or A..Z or 0..9 Command Range ST5 / ST10 / STAC5 Host Command Reference depending on register type) TS TIME_STAMP Q Program Commands C3 0 AX ALARM_RESET BA 0 MT Multi Tasking A9 0 OF ON_FAULT B8 0 segment OI ON_INPUT B9 0 cond QC Queue Call 74 0 segment 1..12 7E 0 line 1..62 QG Queue Goto 0 0 or 1 355 io 0..12 ST: X0..X8, L/H/F/R STAC5: X0..X4, 1..8. L/H/F/R see IO encoding table 920-0002 Rev. J 12/2014 cc (condition code): ASCII T = True F = False P = Positive G = Greater than L = Less than E = Equals U = Unequal Z = Zero QR Queue Repeat 79 reg segment reg code: 0..9 or A..Z. Segment: 1..12 see register code table QX Queue Load Execute 78 0 segment 1..12 NO NO_OP CE 0 TI TEST_INPUT A8 0 cond io ST: X0..X8, L/H/F/R STAC5: X0..X4, 1..8. L/H/F/R see IO Encoding Table WD WAIT_DELAY_ REGISTER BF reg a..z or A..Z or 0..9 see register code table WI WAIT_ON_INPUT, ionum+cond 70 0 cond io ST: X0..X8, L/H/F/R STAC5: X0..X4, 1..8. L/H/F/R see IO Encoding Table WM WAIT_ON_MOVE BC 0 WP WAIT_ON_POSITION D0 0 WT Wait Time 6F 0 delay time 1..32000 .01 seconds Units line: 1..62 Parameter 4 line Parameter 3 7F cc Parameter 2 opcode (hex) Queue Jump Parameter 1 Description QJ Reg code Command Range ST5 / ST10 / STAC5 Host Command Reference Table 2: Message Type 2 Commands Opcode Definition Operand Action 83 Parameter Write see Table 3 write a 16 bit parameter to a register. Add 128 (0x80) to operand for non-volatile (flash) write 84 Parameter read see Table 3 Returns the 16 bit parameter indicated by operand 87 Read alarm code 0 Returns alarm history value indicated by operand 88 Read Encoder/Abs Posn 0 Returns the 32 bit encoder position 1 Returns the 32 bit absolute position 8B* Set Output (immediate) bit 7 state, bits 0-6 output Set the given output to given state. 8E Clear Fault (AR) 0 Clear the drive fault. A motor enable must be sent to re-enable the motor 920-0002 Rev. J 12/2014 356 Host Command Reference 98 Stop Motion, Kill Buffer (SK) decel rate stops a move, purge all commands from buffer. 0=use quick decel (AM), 1=use normal decel (DE or JL) 9E** Write Q Register (RL) see Reg Encoding table write a 16 or 32 bit parameter to a Q register (A..Z or 0..9, etc) 9F Read Q Register (RL) see Reg Encoding table read a 16 or 32 bit Q register (a..z, A..Z or 0..9, etc) A1 Queue Load (QL) 0 load incoming Type 1 commands into Q buffer A2 Queue Save (QS) segment number 1..12 saves Q buffer as a Q segment A3 Stop Motion (ST) decel rate stops a move. 0=use quick decel (AM), 1=use normal decel (DE or JL) FE IEEE-1588 Control 0 Enables IEEE-1588 protocol, preventing Class 1 connection 1 Disable IEEE-1588 protocol, allowing Class 1 connection 0 Opens UDP port 7775 and listens for a new connection 1 Closes and resets UDP port 7775 FF UDP port reset 357 920-0002 Rev. J 12/2014 Host Command Reference *Type 2 Set Output Immediate (opcode 8B) operand table Operand 00 01 02 03 ST OUT1 OUT2 OUT3 OUT4 high high high high STAC5 Y1 high Y2 high 04 05 80 82 83 84 85 OUT1 OUT2 OUT3 OUT4 low low low low OUT1 OUT2 OUT3 OUT4 high high high high Y1 low **Q register writes are not range checked, so be careful before you write. 920-0002 Rev. J 12/2014 81 358 Y2 low OUT1 OUT2 OUT3 OUT4 low low low low Host Command Reference Table 3: Parameter read/write operands All values are HEX Command Description Index Q Register Char -- MISC_FLAGS 5B F -- ENCODER_ATTEMPTS, 62 AC P_TO_P_ACCEL, 1E AF ANALOG_FILTER_GAIN, 4C AG ANALOG_VELOCITY_GAIN, 3B AI ALARM_RESET, 46 AM MAX_ACCEL, 16 AO ALARM_OUTPUT, 47 AP ANALOG_POSITION_GAIN, 4B X AT ANALOG_THRESHOLD, 4D Y AV ANALOG_OFFSET, 3C Z BD BRAKE_DELAY, 40 BE BRAKE_DELAY_2, 41 BO BRAKE_OUTPUT, 48 CA ACCEL_CURRENT [STM only] 61 CC MAX_CURRENT 18 CD IDLE CURRENT DELAY 4F CF Anti-resonance Frequency 50 CG Anti-resonance Gain 51 CI IDLE CURRENT 19 CM CONTROL_MODE, 10 DE P_TO_P_DECEL, 1F DL DEFINE_LIMITS, 42 ED ENC_DIRECTION, 5F EG Steps/rev divided by 2 26 ER ENCODER_RESOLUTION, 20 HG HYPERBOLIC_GAIN, 4 HP HYPERBOLIC_PHASE, 5 JA VM_ACCEL, 1B K JL VM_DECEL, 1C L JS VM_VELOCITY, 1A M MO MOVE_OUTPUT, 49 MV ModelNum:F/W version 1 PF POSITION_FAULT, 21 PM OPERATION_MODE, 44 PR PROTOCOL, 59 SF STEP_FILTER_FREQUENCY, 6 Read/write 359 A H N O B R 920-0002 Rev. J 12/2014 Host Command Reference Command Description Index Q Register Char SI SERVO_ENABLE, 45 TD ACK_DELAY, 5A VC CHANGE_VELOCITY, 4A U VE P_TO_P_VELOCITY, 1D V -- DSP firmware letter 8E -- Hall Pattern (SV7 only) 8F -- Sub Model (STM only) 90 -- IsServo (ST/SV only: 1=servo, 0=stepper). Can be used to tell if drive is servo or stepper 91 AL alarm code 81 BS Buffer Status 94 EP encoder count upper 84 EP encoder count lower 85 IA command voltage (Ain) 83 a IC command current 88 c IO Output Status (reads back outputs) 95 IQ actual current 89 q IS IN/OUT 2 input status [STAC5 only, read as “F” on ST] 8D y ISX IN/OUT 1 input status 82 i IT drive temp 87 t IU supply voltage 86 u IV actual speed 8B v IV1 target speed 8C w IX position error 8A x OP DriveOptions – bit pattern indicating presence of option boards. Bit 0 = Encoder Bit 1 = RS-485 Bit 2 = CANopen Bit 3 = reserved Bit 4 = Resolver Bit 5 = MCF (encoder in and out – SV7 only) Bit 6 = Ethernet 92 SC status word 80 Read Only 920-0002 Rev. J 12/2014 360 f s Host Command Reference IO Encoding Table Useful ASCII values for IO commands On STAC5, inputs X1-X4 and outputs Y1 & Y2 are on the DB15 (IN/OUT 1) connector. Input X0 is the encoder index signal. Inputs 1-8 and outputs 1-4 are on the DB25 (IN/OUT 2) connector. Character hex code Signifies ST5 & ST10 STAC5 X0 0xB0 encoder index signal encoder index signal X1 or Y1 0xB1 input X1 or output Y1 input X1 or output Y1 X2 or Y2 0xB2 input X2 or output Y2 input X2 or output Y2 X3 or Y3 0xB3 input X3 or output Y3 input X3 X4 or Y4 0xB4 input X4 or output Y4 input X4 X5 0xB5 input X5 n/a X6 0xB6 input X6 n/a X7 0xB7 input X7 n/a X8 0xB8 input X8 n/a 1 0x31 n/a input 1 or output 1 2 0x32 n/a input 2 or output 2 3 0x33 n/a input 3 or output 3 4 0x34 n/a input 4 or output 4 5 0x35 n/a input 5 6 0x36 n/a input 6 7 0x37 n/a input 7 8 0x38 n/a input 8 L 0x4C low state (closed) low state (closed) H 0x48 high state (open) high state (open) R 0x52 rising edge rising edge F 0x46 falling edge falling edge 361 920-0002 Rev. J 12/2014 Host Command Reference Register Encoding Table Register Name Use 0 Code Size Accumulator 0x30 long 1 user defined 0x31 long 2 user defined 0x32 long 3 user defined 0x33 long 4 user defined 0x34 long 5 user defined 0x35 long 6 user defined 0x36 long 7 user defined 0x37 long 8 user defined 0x38 long 9 user defined 0x39 long : user defined 0x3A long ; user defined 0x3B long < user defined 0x3C long = user defined 0x3D long > user defined 0x3E long ? user defined 0x3F long @ user defined 0x40 long [ user defined 0x5B long \ user defined 0x5C long ] user defined 0x5D long ^ user defined 0x5E long _ user defined 0x5F long ` user defined 0x60 long a analog command 0x61 short yes b Q line number 0x62 short yes c current command IC 0x63 short yes d relative distance ID 0x64 long yes e encoder position IE, EP 0x65 long yes f alarm code AL 0x66 long yes g sensor position 0x67 short yes h condition code 0x68 short yes i X inputs (IN/OUT 1) ISX 0x69 short yes j analog IN1 IA1 0x6A short yes k analog IN2 IA2 0x6B short yes l absolute position 0x6C long yes m control mode 0x6D short yes n velocity mode state 0x6E short yes o point to point state 0x6F short yes 920-0002 Rev. J 12/2014 equivalent SCL command IA CM 362 Read Only Host Command Reference Register Name Use p Q segment q actual current r average regen power s status code t equivalent SCL command Code Size Read Only 0x70 short yes 0x71 short yes 0x72 short yes SC 0x73 short yes drive temperature IT 0x74 short yes u bus voltage IU 0x75 short yes v actual velocity IV0 0x76 short yes w target velocity IV1 0x77 short yes x position error IX 0x78 long yes y IN/OUT 2 inputs IS 0x79 short yes z phase error 0x7A short yes A accel rate AC 0x41 short B decel rate DE 0x42 short C change distance DC 0x43 long D distance DI 0x44 long E position offset 0x45 long F other (misc) flags 0x46 long G current command 0x47 short H analog velocity gain 0x48 short I input counter 0x49 long J jog speed 0x4A short K jog accel rate 0x4B short L jog decel rate 0x4C short M max velocity JS 0x4D short N continuous current CC 0x4E short O idle current CI 0x4F short P absolute position command 0x50 long Q reserved 0x51 R steps/rev S IQ GC EG 0x52 short pulse count 0x53 long T total count 0x54 long U change speed VC 0x55 short V velocity VE 0x56 short W time stamp 0x57 short X analog position gain AP 0x58 short Y analog threshold AT 0x59 short Z analog offset AV 0x5A short 363 920-0002 Rev. J 12/2014 Host Command Reference EtherNet/IP And Q Programs To provide additional functionality and autonomy, Q programs can be stored in EtherNet/IP drives. These programs can be started and stopped “on demand” using explicit messaging. The Q Programmer application is used to compose, download and test Q programs. Please avoid sending EtherNet/IP messages to the drive while the Q Programmer software is running. To start a Q program from an EtherNet/IP message, you must send a Type 1 message with opcode 0x78 (the QX command). You’ll need to specifiy the Q segment number, as shown in the example. This allows you to store up to 12 Q segments, or subprograms, and operate them independently. Q segments can also call each other once one has been started. Example: Starting Q Segment 1 QX1 start Q segment 1 opcode 0x0078 from Table 1 operand 0x1 segment 1 (up to 12 segments are allowed in a Q program) Type 2 Command Message Payload Type 2 Response Message Payload byte 0 0 reserved byte 0 0 reserved byte 1 2 message type byte 1 2 message type byte 2 78 opcode byte 2 78 opcode byte 3 1 operand byte 3 1 operand byte 4 0 unused byte 4 ? Status Code MSB byte 5 0 unused byte 5 ? Status Code LSB byte 6 0 unused byte 6 0 not used byte 7 1 segment number byte 7 0 not used Once a Q segment has begun, Type 1 messages are no longer permitted, because the CPU is busy executing the commands in the Q segment. To stop a Q program, you must use a Type 2 “SK” message (opcode 98, as shown in the next example). Q programs also stop running if they encounter a blank line in the segment. This makes it possible to launch a segment, have it complete a task, and stop by itself. Example: Stopping a Q Program SK stop the Q program opcode 0x98 from Table 2 operand decel rate (0 = use quick decel rate from AM, 1 = use normal decel rate from DE or JL) Type 2 Command Message Payload Type 2 Response Message Payload byte 0 0 reserved byte 0 0 reserved byte 1 2 message type byte 1 2 message type byte 2 98 opcode byte 2 98 opcode byte 3 0 operand byte 3 0 operand byte 4 0 not used byte 4 ? status code MSB byte 5 0 not used byte 5 ? status code LSB byte 6 0 not used byte 6 0 not used byte 7 0 not used byte 7 0 not used 920-0002 Rev. J 12/2014 364 Host Command Reference Communicating with a Q Program While It’s Running You can use Type 2 commands to read and write registers while a Q program is running. The Q program can send information to the host by changing a register that the host is polling. Registers 0 - 9 can be polled using the Type 2 User Register Read command (opcode 9A). The host can make changes to the Q program operation by writing to parameters that the program uses. For example, you could change the motor speed sending a parameter write message that alters VE (Type 2 message, opcode 83, operand 1D). The speed change will take effect on the next move. Changes that affect a Q program immediately can be made using the Write Q Register command (message type 2, opcode 9E). For example, if the motor is jogging after having been sent a CJ command, writing to register J will result in an immediate speed change. Please note that Q register writes are not range checked, so be careful before you write. How to Know if a Q Program Has Stopped Since a Q program can be launched and allowed to stop itself when it encounters a blank line, you may want to know when it stops. You can do this by polling for the status word and observing bit 14. This bit is a one if the program is executing. To fetch the status word, use the Type 2 Parameter Read command with operand 0x80 as shown below. Example: Checking Status While a Q Program is Running opcode 0x84 operand 0x80 parameter read, from Table 2 status code, from Table 3 Type 2 Command Message Payload Type 2 Response Message Payload byte 0 0 reserved byte 0 0 reserved byte 1 2 message type byte 1 2 message type byte 2 84 opcode byte 2 84 opcode byte 3 80 operand byte 3 80 operand byte 4 0 not used byte 4 ? status code MSB byte 5 0 not used byte 5 ? status code LSB byte 6 0 not used byte 6 0 not used byte 7 0 not used byte 7 0 not used Typical return values: 0001 Motor enabled, Q program not running 4001 Motor enabled, Q program running 4801 Motor enabled, Q running, Wait Time command executing 4019 Motor enabled, motor moving, Q running For more information about the status code, please read about the SC command in the main part of this manual. 365 920-0002 Rev. J 12/2014 Host Command Reference Can I Download a Q Program over EtherNet/IP? The preferred method for creating, downloading and testing Q programs is to use the Q Programmer software. Should you prefer to download a program over the EtherNet/IP interface instead, the procedure is as follows: 1. Develop and test your program using Q Programmer so that you know the final contents of the Q segments(s) you’ll need. Any Type 1 command can be used in a Q program. 2. Encode each command into a Type 1 message, according to Table 1. 3. Issue the QL (Queue Load) Type 2 command (see Table 2). 4. Begin sending the encoded Q commands that you want in this segment. They will be placed into the Q buffer. 5. After sending the entire contents of a segment, issue the Type 2 “QS” command, which instructs the drive to save the Q buffer as a Q segment. 6. Repeat steps 2 - 5 if you have additional Q segments. 7. When you have completed the download process for all segments (steps 1 - 6), upload your program using Q Programmer to make sure that there were no mistakes. EtherNet/IP on large networks Once a computer connects to an MOONS’ EtherNet/IP drive with MOONS’ software such as ST Configurator, STAC Configurator or Q Programmer, that connection is maintained until power is cycled. In most cases this will be acceptable because only one computer will ever need to connect to the drive for monitoring or Q program download. In large complex installations however, it may simply not be feasible to cycle power to the machine every time a new technician connects to the drive. To address this, we have implemented opcode 0xFF. Using an operand of 1 will allow the user to forcibly reset the maintenance port (UDP port 7775), effectively yielding control of the drive. Once reset, the port must be reinitialized, which requires opcode 0xFF to be sent again, this time with an operand of 0. This will instruct the drive to accept a new connection from the next computer that tries to connect using MOONS’ software. It is important to understand that only one host computer may be connected to the drive at any given time. To change hosts again, simply repeat the sequence. Example: Close and reset UDP port for access by another host opcode 0xFF operand 0x1 from Table 2 Close and reset UDP port 7775. Type 2 Command Message Payload Type 2 Response Message Payload byte 0 0 reserved byte 0 0 reserved byte 1 2 message type byte 1 2 message type byte 2 FF opcode byte 2 FF opcode byte 3 1 operand byte 3 1 operand byte 4 0 unused byte 4 ? Status Code MSB byte 5 0 unused byte 5 ? Status Code LSB byte 6 0 unused byte 6 0 not used byte 7 0 unused byte 7 0 not used Remember, this is a two step process. First the port must be closed and reset, as shown above. Once reset, the port must be opened for new connections, which may be accomplished by sending opcode FF again, but this time with an operand of 0. 920-0002 Rev. J 12/2014 366 Host Command Reference CIP General Status Codes The following table lists the Status Codes that may be present in the General Status Code field of an Error Response message. Note that the Extended Code Field is available for use in further describing any General Status Code. Extended Status Codes are unique to each General Status Code within each object. Each object shall manage the extended status values and value ranges (including vendor specific). All extended status values are reserved unless otherwise indicated within the object definition. General Status Code Status Name Description of Status (in hex) 00 Success Service was successfully performed by the object specified. 01 Connection failure A connection related service failed along the connection path. 02 Resource unavailable Resources needed for the object to perform the requested service were unavailable. 03 Invalid parameter value See Status Code 0x20, which is the preferred value to use for this condition. 04 Path segment error The path segment identifier or the segment syntax was not understood by the processing node. Path processing shall stop when a path segment error is encountered. 05 Path destination unknown The path is referencing an object class, instance or structure element that is not known or is not contained in the processing node. Path processing shall stop when a path destination unknown error is encountered. 06 Partial transfer Only part of the expected data was transferred. 07 Connection lost The messaging connection was lost. 08 Service not supported The requested service was not implemented or was not defined for this Object Class/ Instance. 09 Invalid attribute value Invalid attribute data detected 0A Attribute list error An attribute in the Get_Attribute_List or Set_Attribute_List response has a non-zero status. 0B Already in requested mode/ state The object is already in the mode/state being requested by the service. 0C Object state conflict The object cannot perform the requested service in its current mode/state. 0D Object already existst The requested instance of object to be created already exists. 0E Attribute not settable A request to modify a non-modifiable attribute was received. 0F Privilege violation A permission/privilege check failed. 10 Device state conflict The device’s current mode/state prohibits the execution of the requested service. 11 Reply data too large The data to be transmitted in the response buffer is larger than the allocated response buffer. 12 Fragmentation of a primitive value The service specified an operation that is going to fragment a primitive data value, i.e. half a REAL data type. 13 Not enough data The service did not supply enough data to perform the specified operation. 14 Attribute not supported The attribute specified in the request is not supported. 15 Too much data The service supplied more data than was expected. 16 Object does not exist The object specified does not exist in the device. 17 Service fragmentation sequence not in progress The fragmentation sequence for this service is not currently active for this data. 18 No stored attribute data The attribute data of this object was not saved prior to the requested service. 19 Store operation failure The attribute data of this object was not saved due to a failure during the attempt. 367 920-0002 Rev. J 12/2014 Host Command Reference General Status Code Status Name Description of Status (in hex) 1A Routing failure, request packet too large The service request packet was too large for transmission on a network in the path to the destination. The routing device was forced to abort the service. 1B Routing failure, response packet too large The service response packet was too large for transmission on a network in the path from the destination. The routing device was forced to abort the service. 1C Missing attribute list entry data The service did not supply an attribute in a list of attributes that was needed by the service to perform the requested behavior. 1D Invalid attribute value list The service is returning the list of attributes supplied with status information for those attributes that were invalid. 1E Embedded service error An embedded service resulted in an error 1F Vendor specific error A vendor specific error has been encountered. The Additional Code Field of the Error Response defines the particular error encountered. Use of this General Error Code should only be performed when none of the Error Codes presented in this table or within an Object Class definition accurately reflect the error. 20 Invalid Parameter A parameter associated with the request was invalid. This code is used when a parameter does not meet the requirements of this specification and/or the requirements defined in an Application Object Specification. 21 Write-once value or medium An attempt was made to write to a write-once medium (e.g. WORM drive, PROM) that already written has already been written, or to modify a value that cannot be changed once established. 22 Invalid Reply Received An invalid reply is received (e.g.reply service code does not match the request service code, or reply message is shorter than the minimum expected reply size). This status code can serve for other causes of invalid replies. 23 Buffer Overflow The message received is larger than the receiving buffer can handle. The entire message was discarded. 24 Message Format Error The format of the received message is not supported by the server. 25 Key Failure in path The Key Segment that was included as the first segment in the path does not match the destination module. The object specific status shall indicate which part of the key check failed. 26 Path Size Invalid The size of the path which was sent with the Service Request is either not large enough to allow the Request to be routed to an object or too much routing data was included. 27 Unexpected attribute in list An attempt was made to set an attribute that is not able to be set at this time. 28 Invalide Member ID The Member ID specified in the request does not exist in the specified Class/Instance/ Attribute. 29 Member not settable A request to modify a non-modifiable member was received. 2A Group 2 only server general failure This error code may only be reported by DeviceNet Group 2 Only servers with 4K or less code space and only in place of Service not supported, Attribute not supported and Attribute not settable. 2B Unknown Modbus Error A CIP to Modbus translator received an unknown Modbus Exception Code. 2C Attribute not gettable A request to read a non-readable attribute was received. 2D-CF D0-FF 920-0002 Rev. J 12/2014 Reserved by CIP for future extensions Reserved for Object Class and Service errors This range of error codes is to be used to indicate Object Class specific errors. Use of tihs range should only be performed when none of the Error Codes presented in this table accurately reflect the error that was encountered. 368 Host Command Reference Appendix I: Troubleshooting This Appendix addresses potential issues that may occur while using MOONS’ equipment. NOTE: Every drive must be configured with MOONS’ software prior to operation. For stepper systems, use the appropriate Configurator utility, while QuickTuner should be used for servos. It is never safe to assume that the configuration state of the drive is known when it is received. This step should not be considered optional. Error Message / Indication While streaming commands to the drive, it behaves erratically or does not send legible ACK / NACK responses. Explanation Solution The drive’s command buffer may be full, which may cause unpredictable behavior. It is recommended that the user receive and process the drive’s ACK / NACK character before sending the next command. This will ensure that the drive’s command buffer never overflows and the drive behaves normally. If this is not possible, a delay should be introduced between commands that are streamed to the drive. A delay of approximately 10ms should be sufficient for all commands that do not cause motion. The software is unable to communicate to the drive. There are four common causes for this error: 1 - The drive is not powered. 2 - The software is using the wrong COM port. 3 - The drive was already running before the software was launched. (wrong power-up sequence) “The drive is not responding. Is it connected to the right port and turned on?” 4 - The USB/Serial converter is faulty or not supported by MOONS’. If an onboard 9-pin COM port is not available, use a USB/Serial converter based on the FTDI chipset. The chipset used will be shown on the converter’s documentation. Contact MOONS’ for specific device recommendations. 1 - Apply power to the drive. 2 - Physical 9-pin COM ports are typically assigned COM1 or COM2. USB Adaptors are often assigned arbitrary COM port identifiers. Check your computer’s hardware settings in the Control Panel to verify which COM port your device is using. 3 - Ensure that the software is running and using the correct COM port. Then, cycle power on the drive. This will allow the software to intercept the drive’s power-up packet (as detailed in Appendix B) and initiate communications. Hint: If communications have been established, MOONS’ software will display the drive’s firmware revision along with the model number. If this box is empty, communications have not been established. 369 920-0002 Rev. J 12/2014 Host Command Reference Error Message / Indication Explanation Solution “You have not set the load inertia in the Motor Settings. The electronic damping and anti-resonance will work better if you set the load inertia accurately. Do you want to download your settings anyway?” The drive is missing important information used to properly configure the antiresonance features. The motor will run without this information, but it may not be as smooth as it otherwise could be. This is generally acceptable only for initial testing, and should be addressed before normal operation. Set the load inertia. Depending on the configuration software used, it is either possible to enter the actual calculated load inertia or a best-guess estimate of the inertia ratio (load : motor). For example, if the load inertia is five times that of the motor’s rotor, the ratio would be entered as 5 : 1. Drive’s LED blinks red and green An alarm or fault condition exists. The display consists of a specific number of red and green blinks, and will repeat continuously until resolved. Fault codes are drive-dependent. Consult Appendix E and your drive’s hardware manual for specific information. Drive’s LED shows solid red A firmware download was interrupted, and the drive is unable to boot properly. Cycle power on the drive and repeat the firmware download process. 920-0002 Rev. J 12/2014 370 Host Command Reference Appendix J: List of Supported Drives Drive Description Integrated Steppers STM17S-3AN NEMA 17 Integrated Stepper, RS-232 STM17S-3AE NEMA 17 Integrated Stepper, RS-232, Encoder STM17S-3RN NEMA 17 Integrated Stepper, RS-485 STM17S-3RE NEMA 17 Integrated Stepper, RS-485, Encoder STM17Q-3AN NEMA 17 Integrated Stepper, Q Programming, RS-232 STM17Q-3AE NEMA 17 Integrated Stepper, Q Programming, RS-232, Encoder STM17Q-3RN NEMA 17 Integrated Stepper, Q Programming, RS-485 STM17Q-3RE NEMA 17 Integrated Stepper, Q Programming, RS-485, Encoder STM17C-3CN NEMA 17 Integrated Stepper, CANOpen STM17C-3CE NEMA 17 Integrated Stepper, CANOpen, Encoder STM23S-2AN NEMA 23 Integrated Stepper, 2-stack motor, RS-232 STM23S-2AE NEMA 23 Integrated Stepper, 2-stack motor, RS-232, Encoder STM23S-2RN NEMA 23 Integrated Stepper, 2-stack motor, RS-485 STM23S-2RE NEMA 23 Integrated Stepper, 2-stack motor, RS-485, Encoder STM23Q-2AN NEMA 23 Integrated Stepper, 2-stack motor, Q Programming, RS-232 STM23Q-2AE NEMA 23 Integrated Stepper, 2-stack motor, Q Programming, RS-232, Encoder STM23Q-2RN NEMA 23 Integrated Stepper, 2-stack motor, Q Programming, RS-485 STM23Q-2RE NEMA 23 Integrated Stepper, 2-stack motor, Q Programming, RS-485, Encoder STM23S-3AN NEMA 23 Integrated Stepper, 3-stack motor, RS-232 STM23S-3AE NEMA 23 Integrated Stepper, 3-stack motor, RS-232, Encoder STM23S-3RN NEMA 23 Integrated Stepper, 3-stack motor, RS-485 STM23S-3RE NEMA 23 Integrated Stepper, 3-stack motor, RS-485, Encoder STM23Q-3AN NEMA 23 Integrated Stepper, 3-stack motor, Q Programming, RS-232 STM23Q-3AE NEMA 23 Integrated Stepper, 3-stack motor, Q Programming, RS-232, Encoder STM23Q-3RN NEMA 23 Integrated Stepper, 3-stack motor, Q Programming, RS-485 STM23Q-3RE NEMA 23 Integrated Stepper, 3-stack motor, Q Programming, RS-485, Encoder STM23C-3CN NEMA 23 Integrated Stepper, 3-stack motor, Q Programming, CANOpen STM23C-3CE NEMA 23 Integrated Stepper, 3-stack motor, Q Programming, CANOpen, Encoder STM24SF-3AN NEMA 24 Integrated Stepper, RS-232 STM24SF-3AE NEMA 24 Integrated Stepper, RS-232, Encoder STM24SF-3RN NEMA 24 Integrated Stepper, RS-485 STM24SF-3RE NEMA 24 Integrated Stepper, RS-485, Encoder STM24QF-3AN NEMA 24 Integrated Stepper, Q Programming, RS-232 STM24QF-3AE NEMA 24 Integrated Stepper, Q Programming, RS-232, Encoder STM24QF-3RN NEMA 24 Integrated Stepper, Q Programming, RS-485 STM24QF-3RE NEMA 24 Integrated Stepper, Q Programming, RS-485, Encoder STM24C-3CN NEMA 24 Integrated Stepper, CANOpen 371 920-0002 Rev. J 12/2014 Host Command Reference Drive Description STM24C-3CE NEMA 24 Integrated Stepper, CANOpen, Encoder ST Drives ST5-S 5A DC Stepper Drive, RS-232 ST5-Plus 5A DC Stepper Drive, Q Programming, RS-232 ST5-Q-NN 5A DC Stepper Drive, Q Programming, RS-232 ST5-Q-NE 5A DC Stepper Drive, Q Programming, RS-232, Encoder ST5-Q-RN 5A DC Stepper Drive, Q Programming, RS-485 ST5-Q-RE 5A DC Stepper Drive, Q Programming, RS-485, Encoder ST5-Q-EN 5A DC Stepper Drive, Q Programming, Ethernet ST5-Q-EE 5A DC Stepper Drive, Q Programming, Ethernet, Encoder ST5-IP-EN 5A DC Stepper Drive, Q Programming, EtherNet/IP ST5-IP-EE 5A DC Stepper Drive, Q Programming, EtherNet/IP, Encoder ST5-Si-NN 5A DC Stepper Drive, Si Programming, RS-232 ST5-Si-NE 5A DC Stepper Drive, Si Programming, RS-232, Encoder ST5-C-CN 5A DC Stepper Drive, CANOpen ST5-C-CE 5A DC Stepper Drive, CANOpen, Encoder ST10-S 10A DC Stepper Drive, RS-232 ST10-Plus 10A DC Stepper Drive, RS-232 ST10-Q-NN 10A DC Stepper Drive, Q Programming, RS-232 ST10-Q-NE 10A DC Stepper Drive, Q Programming, RS-232, Encoder ST10-Q-RN 10A DC Stepper Drive, Q Programming, RS-485 ST10-Q-RE 10A DC Stepper Drive, Q Programming, RS-485, Encoder ST10-Q-EN 10A DC Stepper Drive, Q Programming, Ethernet ST10-Q-EE 10A DC Stepper Drive, Q Programming, Ethernet, Encoder ST10-IP-EN 10A DC Stepper Drive, Q Programming, EtherNet/IP ST10-IP-EE 10A DC Stepper Drive, Q Programming, EtherNet/IP, Encoder ST10-Si-NN 10A DC Stepper Drive, Si Programming, RS-232 ST10-Si-NE 10A DC Stepper Drive, Si Programming, RS-232, Encoder ST10-C-CN 10A DC Stepper Drive, CANOpen ST10-C-CE 10A DC Stepper Drive, CANOpen, Encoder SV Drives SV7-S-AE 7A DC Servo Drive, RS-232, Encoder SV7-S-AF 7A DC Servo Drive, RS-232, Encoder, MCF Encoder Feedback Board SV7-S-RE 7A DC Servo Drive, RS-485, Encoder SV7-Q-AE 7A DC Servo Drive, Q Programming, RS-232, Encoder SV7-Q-AF 7A DC Servo Drive, Q Programming, RS-232, Encoder, MCF Encoder Feedback Board SV7-Q-RE 7A DC Servo Drive, Q Programming, RS-485, Encoder SV7-Q-EE 7A DC Servo Drive, Q Programming, Ethernet, Encoder SV7-IP-EE 7A DC Servo Drive, Q Programming, EtherNet/IP, Encoder SV7-Si-AE 7A DC Servo Drive, Si Programming, RS-232, Encoder SV7-Si-AF 920-0002 Rev. J 12/2014 7A DC Servo Drive, Si Programming, RS-232, Encoder, MCF Encoder Feedback Board 372 Host Command Reference Drive Description SV7-C-CE 7A DC Servo Drive, CANOpen, Encoder Blu Servo Drives BLuDC4-S 4A DC Servo Drive, RS-232 BLuDC4-SE 4A DC Servo Drive, RS-232, Expanded I/O BLuDC4-Q 4A DC Servo Drive, RS-232, Q Programming BLuDC4-QE 4A DC Servo Drive, RS-232, Q Programming, Expanded I/O BLuDC4-Si 4A DC Servo Drive, RS-232, Si Programming BLuDC9-S 9A DC Servo Drive, RS-232 BLuDC9-SE 9A DC Servo Drive, RS-232, Expanded I/O BLuDC9-Q 9A DC Servo Drive, RS-232, Q Programming BLuDC9-QE 9A DC Servo Drive, RS-232, Q Programming, Expanded I/O BLuDC9-Si 9A DC Servo Drive, RS-232, Si Programming BLuAC5-S 5A AC Servo Drive, RS-232 BLuAC5-SE 5A AC Servo Drive, RS-232, Expanded I/O BLuAC5-Q 5A AC Servo Drive, RS-232, Q Programming BLuAC5-QE 5A AC Servo Drive, RS-232, Q Programming, Expanded I/O BLuAC5-Si 5A AC Servo Drive, RS-232, Si Programming STAC5 Stepper Drives STAC5-S-N120 5A 120VAC Stepper Drive, Ethernet STAC5-S-N220 5A 220VAC Stepper Drive, Ethernet STAC5-S-E120 5A 120VAC Stepper Drive, Ethernet, Encoder STAC5-S-E220 5A 220VAC Stepper Drive, Ethernet, Encoder STAC5-Q-N120 5A 120VAC Stepper Drive, Ethernet, Q Programming STAC5-Q-N220 5A 220VAC Stepper Drive, Ethernet, Q Programming STAC5-Q-E120 5A 120VAC Stepper Drive, Ethernet, Q Programming, Encoder STAC5-Q-E220 5A 220VAC Stepper Drive, Ethernet, Q Programming, Encoder STAC5-IP-N120 5A 120VAC Stepper Drive, EtherNet/IP STAC5-IP-N220 5A 220VAC Stepper Drive, EtherNet/IP STAC5-IP-E120 5A 120VAC Stepper Drive, EtherNet/IP, Encoder STAC5-IP-E220 5A 220VAC Stepper Drive, EtherNet/IP, Encoder STAC6 Stepper Drives STAC6-S 6A 120VAC Stepper Drive, RS-232 STAC6-S-220 6A 220VAC Stepper Drive, RS-232 STAC6-SE 6A 120VAC Stepper Drive, RS-232, Expanded I/O STAC6-SE-220 6A 220VAC Stepper Drive, RS-232, Expanded I/O STAC6-Q 6A 120VAC Stepper Drive, RS-232, Q Programming STAC6-Q-220 6A 220VAC Stepper Drive, RS-232, Q Programming STAC6-QE 6A 120VAC Stepper Drive, RS-232, Q Programming, Expanded I/O 373 920-0002 Rev. J 12/2014 Host Command Reference Drive Description STAC6-QE-220 6A 220VAC Stepper Drive, RS-232, Q Programming, Expanded I/O STAC6-Si 6A 120VAC Stepper Drive, RS-232, Si Programming STAC6-Si-220 6A 220VAC Stepper Drive, RS-232, Si Programming STAC6-C 6A 120VAC Stepper Drive, CANOpen STAC6-C-220 6A 220VAC Stepper Drive, CANOpen SVAC3 Servo Drives SVAC3-S-E-120 3A 120VAC Servo Drive, Ethernet SVAC3-S-E-220 3A 220VAC Servo Drive, Ethernet SVAC3-Q-E-120 3A 120VAC Servo Drive, Ethernet, Q Programming SVAC3-Q-E-220 3A 220VAC Servo Drive, Ethernet, Q Programming SVAC3-IP-E-120 3A 120VAC Servo Drive, Ethernet, Q Programming, EtherNet/IP SVAC3-IP-E-220 3A 220VAC Servo Drive, Ethernet, Q Programming, EtherNet/IP 920-0002 Rev. J 12/2014 374 Host Command Reference (This page intentionally left blank) 375 920-0002 Rev. J 12/2014 SHANGHAI AMP&MOONS’ AUTOMATION CO.,LTD. No. 168 Mingjia Road Industrial Park North Minhang District Shanghai 201107, P.R. China Tel: +86(0)21-5263 4688 Fax: +86(0)21-6296 8682 www.moons.com.cn 920-0002 Rev. J 12/2014
SSDC06-EC-H 价格&库存
很抱歉,暂时无法提供与“SSDC06-EC-H”相匹配的价格&库存,您可以联系我们找货
