MU050S150BQI511
MU050S150BQI511
    MOONS'(鸣志)
    LED/照明驱动器 90~305V 50W
MU050S150BQI511 数据手册
UL TYPE EXAMINATION CERTIFICATE Certificate No. Page Date of Issue Applicant Manufacturer Product Sample Description Designation Ratings Product Sample Tested and found in compliance with Standard(s) Test Report Nos. Additional information Certification Manager Jan-Erik Storgaard Certification Body     UL TEC-00682 1/2 2017-11-17   SHANGHAI MOONS' AUTOMATION CONTROL CO LTD BLDG 29, 4TH FL CAOHEJING HI-TECH PARK 69 GUIQING RD SHANGHAI, 200233 China SHANGHAI MOONS' AUTOMATION CONTROL CO LTD BLDG 29, 4TH FL CAOHEJING HI-TECH PARK 69 GUIQING RD SHANGHAI, 200233 China Electronic Controlgear for LED modules MU050x150yQIz1z, MU030x070yQIz1z/R, MU030x070yQIz1z, MU030x150yQIz1z/R, MU030x150yQIz1z, MU050x150yQIz1z/R See Page 2 Input: 100-240 V~, 50/60 Hz, λ>0.9, ta 50°C, Output: 8-55 Vdc , SELV (see test report for variants) EN 61347-1:2008/A1:2011, EN 61347-1:2008/A2:2013, EN 61347-1:2008, EN 61347-2-13:2014 4787915359-3 issued on 2017-11-09 - This is to certify that the sample(s) of the Product described herein has been investigated and found to have been in compliance with the Standard(s) indicated on this Certificate, in accordance with the UL Type Examination Certificate Program Requirements. This certificate and test results obtained apply only to the product sample(s) submitted by the Applicant. UL did not select the sample(s) or determine whether the sample(s) provided were representative of other manufactured products. UL has not established Follow-Up Service or other surveillance of the product. The Applicant/ Manufacturer are solely and fully responsible for conformity of all products to all applicable Standard(s), specifications or requirements. The test results may not be used, in whole or in part, in any other document without UL’s prior written approval. UL International Demko A/S, Borupvang 5A, DK-2750 Ballerup, Denmark, Tel. +45 44 85 65 65, info.dk@ul.com www.ul-europe.com UL TYPE EXAMINATION CERTIFICATE Certificate No. Page Date of Issue UL TEC-00682 2/2 2017-11-17   Model Details: CODE NOMENCLATURE: x One letter indicates output dimming precision as follows: “S” – 0.1%, “E” – 1% y One Letter indicates output channel as follows: “A” – one output channel, “B” – two output channels z1z See below table for details “z1z” NOMENCLATURE: Number 0 1 First z represents dimming mode Single 0-10V dimming 0-10V CCT+DIM(Support Curve Customized) Last z No auxiliary power With 12V auxiliary output 2 0-10V CCT+DIM(no Curve customized) DALI with no 12V auxiliary output 3 4 5 6 Single DALI DT8 only DT8 DMX DALI with 12V auxiliary output - Certification Manager Jan-Erik Storgaard Certification Body     This is to certify that the sample(s) of the Product described herein has been investigated and found to have been in compliance with the Standard(s) indicated on this Certificate, in accordance with the UL Type Examination Certificate Program Requirements. This certificate and test results obtained apply only to the product sample(s) submitted by the Applicant. UL did not select the sample(s) or determine whether the sample(s) provided were representative of other manufactured products. UL has not established Follow-Up Service or other surveillance of the product. The Applicant/ Manufacturer are solely and fully responsible for conformity of all products to all applicable Standard(s), specifications or requirements. The test results may not be used, in whole or in part, in any other document without UL’s prior written approval. UL International Demko A/S, Borupvang 5A, DK-2750 Ballerup, Denmark, Tel. +45 44 85 65 65, info.dk@ul.com www.ul-europe.com
MU050S150BQI511 价格&库存
很抱歉,暂时无法提供与“MU050S150BQI511”相匹配的价格&库存,您可以联系我们找货
MU050S150BQI511
