PU025H070AQ_CLKS
PU025H070AQ_CLKS
    MOONS'(鸣志)
    LED/照明驱动器 90~305V 25W
PU025H070AQ_CLKS 数据手册
General-Built-In PU025H070AQ_CLKS DWG NO. : MSSD-A5972 A1 LED DRIVER SPECIFICATIONS Customer's Part Number: MOONS' Part Number: 4696350002902 PU025H070AQ_CLKS Model: P/N: CUSTOMER'S APPROVAL STAMP Please sign back after your approval. The specifications will come into force when we receive purchase order. DWG CHK STANDARD APPD Page 1 of 8 subject to change without notice SHANGHAI MOONS' AUTOMATION CONTROL CO., LTD. Add: No.168, Mingjia Road, Shanghai 201107, P.R.China Tel: +86 (0)21 52634688 Website: www.moons.com.cn General-Built-In PU025H070AQ_CLKS DWG NO. : MSSD-A5972 Rev. A0 Date 2015-11-11 A1 2017-5-17 Contents First Release Update Nameplate and the format of Curve,add Programmable Plan ECO NO. DWG CHK A1 APPR Yongchao Zhang Zhenmin Feng Bilin Tu ECO16-2962DE Yongchao Zhang Zhenmin Feng Bilin Tu Page 2 of 8 subject to change without notice SHANGHAI MOONS' AUTOMATION CONTROL CO., LTD. Add: No.168, Mingjia Road, Shanghai 201107, P.R.China Tel: +86 (0)21 52634688 Website: www.moons.com.cn PU025H070AQ_CLKS General-Built-In DWG NO. : MSSD-A5972 ■ Features A1 · Input voltage: 90-305VAC · Built-in active PFC function: 0.99 Typ. · Low THD: 10% Typ. · High efficiency: 86% Typ. · IP66 design for indoor or outdoor installations · High surge immunity · Support Time-shared dimming function · Compliance to worldwide safety regulations for lighting ■ Specification PU025H070AQ_CLKS Efficiency(120Vac)Note.1 85%(Typ.) Efficiency(220Vac)Note.1 86%(Typ.) Voltage Range (V)Note.2 90~305Vac, OR 127~ 430Vdc Voltage Rated (V)Note.2 100-277Vac Frequency Range (Hz) 47~63 0.99 (Typ.)with 85%~100% load,at 120Vac Input Power Factor 0.97(Typ.) with 85%~100% load,at 220Vac >0.9 with 85%~100% load, at 100~277Vac THD AC Current(Max) Inrush Current(Max.) Leakage Current(Max.) Output Voltage range (V) Output 10% (Typ.), at 220Vac input, with 80%~100% load conditions
PU025H070AQ_CLKS 价格&库存
很抱歉,暂时无法提供与“PU025H070AQ_CLKS”相匹配的价格&库存,您可以联系我们找货
PU025H070AQ_CLKS
