PU012H070AQ
PU012H070AQ
    MOONS'(鸣志)
    ED/照明驱动器 90~305V 12W
PU012H070AQ 数据手册
General-Built-In PU012H070AQ DWG NO. : MSSD-4517 A1 LED DRIVER SPECIFICATIONS Customer's Part Number: MOONS' Part Number: 4696350001865 Model: PU012H070AQ P/N: CUSTOMER'S APPROVAL STAMP Please sign back after your approval. The specifications will come into force when we receive purchase order. DWG CHK STANDARD APPD Page 1 of 5 subject to change without notice SHANGHAI MOONS' AUTOMATION CONTROL CO., LTD. Add: No.168, Mingjia Road, Shanghai 201107, P.R.China Tel: +86 (0)21 52634688 Website: www.moons.com.cn General-Built-In PU012H070AQ DWG NO. : MSSD-4517 Rev. A0 A1 Date 2016-1-7 2016-9-29 Contents First release 更新铭牌 DWG CHK APPR 苏梁彪 万友根 冯振民 ECO16-0804DT 苏梁彪 万友根 冯振民 ECO NO. A1 Page 2 of 5 subject to change without notice SHANGHAI MOONS' AUTOMATION CONTROL CO., LTD. Add: No.168, Mingjia Road, Shanghai 201107, P.R.China Tel: +86 (0)21 52634688 Website: www.moons.com.cn PU012H070AQ General-Built-In DWG NO. : MSSD-4517 ■ Features 更新铭牌 A1 · Input voltage: 90-305VAC · Built-in active PFC function: 0.99 Typ. · Low THDECO16-0804DT · High efficiency: 81% Typ. · IP66 design for indoor installation · High surge immunity · Compliance to worldwide safety regulations for lighting · Suitable for dry/damp locations ■ Specification PU012H070AQ Efficiency(120Vac)Note.1 80%(Typ.) Efficiency(230Vac)Note.1 81%(Typ.) Voltage Range (V)Note.2 90~305Vac, Voltage Rated (V)Note.2 100-277Vac Frequency Range (Hz) 47~63 0.99 (Typ.)with 80%-100% load,at 120Vac Input Power Factor 0.96(Typ.) with 80%~100% load,at 230Vac >0.9 with100% load, at 100~277Vac THD AC Current(Max) Inrush Current(Max.) Leakage Current(Max.) 0.2A at 100VAC input, 0.08A at 230VAC 15A at 230Vac input 25℃ Cold Start ( time wide=500uS, measured at 50% Ipeak,Not applicable for the inrush current to Noise Filter for less than 0.2ms) 0.75mA at 277Vac/60Hz Output Voltage range (V) 25 Rated Current(mA) 700 Rated Power (W) Ripple Current Output
PU012H070AQ 价格&库存
很抱歉,暂时无法提供与“PU012H070AQ”相匹配的价格&库存,您可以联系我们找货
PU012H070AQ
