MU260H720AQ1_CP
MU260H720AQ1_CP
    MOONS'(鸣志)
    LED/照明驱动器 90~305V 260W
MU260H720AQ1_CP 数据手册
00-IC-F0468 Issue #: 5.0_LVD UL TYPE EXAMINATION CERTIFICATE Low Voltage Directive 2014/35/EU Certificate No. Page Date of Issue UL TEC-00453 1/2 2016-10-27 Applicant SHANGHAI MOONS' AUTOMATION CONTROL CO LTD BLDG 29, 4TH FL, CAOHEJING HI-TECH PARK, 69 GUIQING RD, SHANGHAI , 200233, CHINA Manufacturer SHANGHAI MOONS' AUTOMATION CONTROL CO LTD BLDG 29, 4TH FL, CAOHEJING HI-TECH PARK, 69 GUIQING RD, SHANGHAI , 200233, CHINA Product Sample Description Designation Ratings Electronic Controlgear for LED modules MU260H420AQxy, MU260H520AQxy, MU260H600AQxy, MU260H720AQxy, See Page 2 Input: 120-240 V~, 50/60 Hz, 2.7 A max, 290 W max, ta 64°C, tc 87 °C, Output: 22-54VDC, 4800-7200 mA, 260 W max, SELV (see test report for variants) Product Sample Tested and found in compliance with Standard(s) Test Report Nos. Additional information Certification Manager Jan-Erik Storgaard EN 61347-2-13:2014, EN 61347-1:2008, EN 61347-1:2008/A1:2011, EN 61347-1:2008/ A2:2013 4787512273-1 issued on 2016-10-27 - This is to certify that the sample(s) of the Product described herein has been investigated and found to have been in compliance with the above mentioned harmonized Standard(s) per Article 12 of Directive 2014/35/EU of the European Parliament of the Council of 26 February 2014 on the harmonisation of the laws of Member States relating to the making available on the market of electrical equipment designed for use within certain voltage limits, in accordance with the UL Type Examination Certificate Program Requirements. As stated in Article 6 of Directive 2014/35/EU, "When placing their electrical equipment on the market, manufacturers shall ensure that it has been designed and manufactured in accordance with the safety objectives referred to in Article 3 and set out in Annex I" and “Manufacturers shall draw up the technical documentation referred to in Annex III and carry out the conformity assessment procedure referred to in Annex III or have it carried out”. This remains the responsibility of the manufacturer and is not covered as part of this certificate. This certificate and test results obtained apply only to the product sample(s) submitted by the Applicant. UL did not select the sample(s) or determine whether the sample(s) provided were representative of other manufactured products. UL has not established Follow-Up Service or other surveillance of the product. The Applicant/ Manufacturer are solely and fully responsible for any declaration of ongoing conformity of all products to all applicable Standard(s), specifications or requirements. The test results may not be used, in whole or in part, in any other document without UL’s prior written approval. Certification Body UL International Demko A/S, Borupvang 5A, DK-2750 Ballerup, Denmark, Tel. +45 44 85 65 65, info.dk@ul.com, www.ul-europe.com 00-IC-F0468 Issue #: 5.0_LVD UL TYPE EXAMINATION CERTIFICATE Low Voltage Directive 2014/35/EU Certificate No. Page Date of Issue UL TEC-00453 2/2 2016-10-27 Model Details: MU260H420AQxy,MU260H520AQxy,MU260H600AQxy,MU260H720AQxy The variant “xy" in model name to indicate different dimming function and enclosure construction noted as test report This is to certify that the sample(s) of the Product described herein has been investigated and found to have been in compliance with the above mentioned harmonized Standard(s) per Article 12 of Directive 2014/35/EU of the European Parliament of the Council of 26 February 2014 on the harmonisation of the laws of Member States relating to the making available on the market of electrical equipment designed for use within certain voltage limits, in accordance with the UL Type Examination Certificate Program Requirements. As stated in Article 6 of Directive 2014/35/EU, "When placing their electrical equipment on the market, manufacturers shall ensure that it has been designed and manufactured in accordance with the safety objectives referred to in Article 3 and set out in Annex I" and “Manufacturers shall draw up the technical documentation referred to in Annex III and carry out the conformity assessment procedure referred to in Annex III or have it carried out”. This remains the responsibility of the manufacturer and is not covered as part of this certificate. This certificate and test results obtained apply only to the product sample(s) submitted by the Applicant. UL did not select the sample(s) or determine whether the sample(s) provided were representative of other manufactured products. UL has not established Follow-Up Service or other surveillance of the product. The Applicant/ Manufacturer are solely and fully responsible for any declaration of ongoing conformity of all products to all applicable Standard(s), specifications or requirements. The test results may not be used, in whole or in part, in any other document without UL’s prior written approval. Certification Body UL International Demko A/S, Borupvang 5A, DK-2750 Ballerup, Denmark, Tel. +45 44 85 65 65, info.dk@ul.com, www.ul-europe.com 00-IC-F0468 Issue #: 5.0_LVD UL TYPE EXAMINATION CERTIFICATE Low Voltage Directive 2014/35/EU Certificate No. Page Date of Issue UL TEC-00454 1/2 2016-10-28 Applicant SHANGHAI MOONS' AUTOMATION CONTROL CO LTD BLDG 29, 4TH FL, CAOHEJING HI-TECH PARK, 69 GUIQING RD, SHANGHAI , 200233, CHINA Manufacturer SHANGHAI MOONS' AUTOMATION CONTROL CO LTD BLDG 29, 4TH FL, CAOHEJING HI-TECH PARK, 69 GUIQING RD, SHANGHAI , 200233, CHINA Product Sample Description Designation Ratings Electronic Controlgear for LED modules MU260H105AQxy, MU260H150AQxy, MU260H210AQxy, MU260H300AQxy, See Page 2 Input: 120-240 V~, 50/60 Hz, 2.7 A max, 290 W max, ta 64°C, tc 87 °C, Output: 149-371VDC, 700-1050 mA, 260 W max, (see test report for variants) Product Sample Tested and found in compliance with Standard(s) Test Report Nos. Additional information Certification Manager Jan-Erik Storgaard EN 61347-2-13:2014, EN 61347-1:2008, EN 61347-1:2008/A1:2011, EN 61347-1:2008/ A2:2013 4787512273-2 issued on 2016-10-26 - This is to certify that the sample(s) of the Product described herein has been investigated and found to have been in compliance with the above mentioned harmonized Standard(s) per Article 12 of Directive 2014/35/EU of the European Parliament of the Council of 26 February 2014 on the harmonisation of the laws of Member States relating to the making available on the market of electrical equipment designed for use within certain voltage limits, in accordance with the UL Type Examination Certificate Program Requirements. As stated in Article 6 of Directive 2014/35/EU, "When placing their electrical equipment on the market, manufacturers shall ensure that it has been designed and manufactured in accordance with the safety objectives referred to in Article 3 and set out in Annex I" and “Manufacturers shall draw up the technical documentation referred to in Annex III and carry out the conformity assessment procedure referred to in Annex III or have it carried out”. This remains the responsibility of the manufacturer and is not covered as part of this certificate. This certificate and test results obtained apply only to the product sample(s) submitted by the Applicant. UL did not select the sample(s) or determine whether the sample(s) provided were representative of other manufactured products. UL has not established Follow-Up Service or other surveillance of the product. The Applicant/ Manufacturer are solely and fully responsible for any declaration of ongoing conformity of all products to all applicable Standard(s), specifications or requirements. The test results may not be used, in whole or in part, in any other document without UL’s prior written approval. Certification Body UL International Demko A/S, Borupvang 5A, DK-2750 Ballerup, Denmark, Tel. +45 44 85 65 65, info.dk@ul.com, www.ul-europe.com 00-IC-F0468 Issue #: 5.0_LVD UL TYPE EXAMINATION CERTIFICATE Low Voltage Directive 2014/35/EU Certificate No. Page Date of Issue UL TEC-00454 2/2 2016-10-28 Model Details: MU260H105AQxy, MU260H150AQxy, MU260H210AQxy, MU260H300AQxy, The variant “xy" in model name to indicate different dimming function and enclosure construction noted as test report This is to certify that the sample(s) of the Product described herein has been investigated and found to have been in compliance with the above mentioned harmonized Standard(s) per Article 12 of Directive 2014/35/EU of the European Parliament of the Council of 26 February 2014 on the harmonisation of the laws of Member States relating to the making available on the market of electrical equipment designed for use within certain voltage limits, in accordance with the UL Type Examination Certificate Program Requirements. As stated in Article 6 of Directive 2014/35/EU, "When placing their electrical equipment on the market, manufacturers shall ensure that it has been designed and manufactured in accordance with the safety objectives referred to in Article 3 and set out in Annex I" and “Manufacturers shall draw up the technical documentation referred to in Annex III and carry out the conformity assessment procedure referred to in Annex III or have it carried out”. This remains the responsibility of the manufacturer and is not covered as part of this certificate. This certificate and test results obtained apply only to the product sample(s) submitted by the Applicant. UL did not select the sample(s) or determine whether the sample(s) provided were representative of other manufactured products. UL has not established Follow-Up Service or other surveillance of the product. The Applicant/ Manufacturer are solely and fully responsible for any declaration of ongoing conformity of all products to all applicable Standard(s), specifications or requirements. The test results may not be used, in whole or in part, in any other document without UL’s prior written approval. Certification Body UL International Demko A/S, Borupvang 5A, DK-2750 Ballerup, Denmark, Tel. +45 44 85 65 65, info.dk@ul.com, www.ul-europe.com Certificate No.: 2016-10-26-4787512273-2 Issue Date: 2016-10-26 Product: LED Control Gear Applicant: SHANGHAI MOONS' AUTOMATION CONTROL CO LTD BLDG 29, 4TH FL, CAOHEJING HI-TECH PARK, 69 GUIQING RD, SHANGHAI , 200233, CHINA Manufacturer: SHANGHAI MOONS' AUTOMATION CONTROL CO LTD BLDG 29, 4TH FL, CAOHEJING HI-TECH PARK, 69 GUIQING RD, SHANGHAI , 200233, CHINA Factory: SHANGHAI MOONS' AUTOMATION CONTROL CO LTD 168 MING JIA RD, MIN-HANG DISTRICT, SHANGHAI, 201107, CHINA Model/Type ref.: See appendix page Rating: See appendix page Standard(s): EN 61347-2-13:2014; EN 61347-1: 2008+A1:2011+A2:2013 Report no: 4787512273-3; 4787512273-4 UL-CCIC has determined that the sample(s) requirements of the above mentioned standard(s) tested conform with the The Member States of the EU shall presume compliance with the provision of the Low Voltage Directive (LVD) 2014/35/EU of 26 February 2014, the rules for CE conformity marking of the product within the LVD, when a Declaration of Conformity with the LVD has been completed and the additional requirements of Annex IV regarding internal production control and the presence of technical documentation, are complied with. EMF not included. This Statement is only valid for products, which are identical to the tested products, and manufactured at the above mentioned production site. This document contains 1 page. 2, Chengwan Road, Suzhou Industrial Park, Suzhou, 215122, China Tel: +86 512 6808 6400 Fax: +86 512 6808 4099 Jackie Xu Engineering Manager APPENDIX PAGE MODELS* Vin (V~) Freq Hz Iinput (A) Pinput (W) Vo (V ) MU260H420AQxy 120-240 50/60 2.7 290 37-93 MU260H520AQxy 120-240 50/60 2.7 290 30-50 MU260H600AQxy 120-240 50/60 2.7 290 26-65 MU260H720AQxy 120-240 50/60 2.7 290 22-54 MODELS* Vin (V~) Freq Hz Iinput (A) Pinput (W) Vo (V ) MU260H105AQxy 120-240 50/60 2.7 290 149-371 MU260H150AQxy 120-240 50/60 2.7 290 104-260 MU260H210AQxy 120-240 50/60 2.7 290 74-186 MU260H300AQxy 120-240 50/60 2.7 290 52-130 Io (mA) 28004200 520 5200 40006000 48007200 Io (mA) 7001050 10001500 14002100 20003000 Max Pout (W) Ta (°C) tc (°C) 260W 64 87 260W 64 87 260W 64 87 260W 64 87 Max Pout (W) Ta (°C) tc (°C) 260W 64 87 260W 64 87 260W 64 87 260W 64 87 (*)Note: The variant “xy” in model name to indicate different dimming function and enclosure construction noted as below: Suffix “x” Enclosure construction Black 1 Enclosure construction 1 Enclosure construction 2 Suffix “y” Dimming interface Blank _CP _CP/C _0-10V _DALI _CLKS _CLKS/C No dimming Programmed dimming Programmed dimming with connector and cap 0-10V dimming DALI dimming Time control Time control with connector and cap
MU260H720AQ1_CP
- 物料型号:MU260H420AQxy, MU260H520AQxy, MU260H600AQxy, MU260H720AQxy, MU260H105AQxy, MU260H150AQxy, MU260H210AQxy, MU260H300AQxy - 参数特性: - 输入电压:120-240V~, 50/60 Hz - 最大输入电流:2.7 A - 最大输入功率:290 W - 工作温度范围:ta 64°C, tc 87°C - 输出电压和电流:根据型号不同而变化,输出功率最大为260W - 功能详解:文档提到了不同的调光功能和外壳结构,用型号中的“xy”后缀表示。例如,“Black”表示一种外壳结构,“CP”代表有程序控制调光功能。 - 应用信息:文档为CE认证文件,说明这些产品符合低压指令2014/35/EU和相关欧洲标准EN 61347。 - 封装信息:文档中未提供详细的封装信息,但提到了不同的外壳结构和调光接口。
MU260H720AQ1_CP 价格&库存
很抱歉,暂时无法提供与“MU260H720AQ1_CP”相匹配的价格&库存,您可以联系我们找货
MU260H720AQ1_CP
