ME035A053AQ_CLKS
ME035A053AQ_CLKS
    MOONS'(鸣志)
    LED/照明驱动器 176~305VAC
ME035A053AQ_CLKS 数据手册
General-Outdoor ME035A053AQ_CLKS DWG NO. : MSSD-6755 A0 LED DRIVER SPECIFICATIONS Customer's Part Number: MOONS' Part Number: 4696350003556 ME035A053AQ_CLKS Model: P/N: CUSTOMER'S APPROVAL STAMP Please sign back after your approval. The specifications will come into force when we receive purchase order. DWG CHK STANDARD APPD Page 1 of 8 subject to change without notice SHANGHAI MOONS' AUTOMATION CONTROL CO., LTD. Add: No.168, Mingjia Road, Shanghai 201107, P.R.China Tel: +86 (0)21 52634688 Website: www.moons.com.cn General-Outdoor ME035A053AQ_CLKS DWG NO. : MSSD-6755 Rev. A0 Date 2017-2-20 Contents ECO NO. DWG CHK A0 APPR First release Page 2 of 8 subject to change without notice SHANGHAI MOONS' AUTOMATION CONTROL CO., LTD. Add: No.168, Mingjia Road, Shanghai 201107, P.R.China Tel: +86 (0)21 52634688 Website: www.moons.com.cn ME035A053AQ_CLKS General-Outdoor DWG NO. : MSSD-6755 ■ Features A0 · Input voltage: 176-305VAC · Built-in active PFC function: 0.99 Typ. · Low THD: 4% Typ. · High efficiency: 89% Typ. · High surge immunity · Support Time-shared dimming function · Compliance to worldwide safety regulations for lighting ■ Specification ME035A053AQ_CLKS Efficiency(220Vac)Note.1 89%(Typ.),87% Min at full load Voltage Range (V)Note.2 176~305Vac, OR 248~ 431Vdc Voltage Rated (V)Note.2 200-240Vac Frequency Range (Hz) Input Power Factor THD AC Current(Max) Inrush Current(Max.) Leakage Current(Max.) Output Voltage range (V) Rated Current(mA) Rated Power (W) Output Ripple Current 47~63 0.99(Typ.) with full load,at 220Vac >0.95,80%~100% load,at 220Vac 4%(Typ.) with full load,
ME035A053AQ_CLKS
物料型号:ME035A053AQ_CLKS
器件简介: - 这是一款通用户外LED驱动器,具有以下特点: - 输入电压范围:176-305VAC - 内置主动功率因数校正(PFC)功能,典型值为0.99 - 低总谐波失真(THD):4%(典型值) - 高效率:89%(典型值) - 高浪涌电压耐受性 - 支持时分调光功能 - 符合全球照明安全规范
引脚分配: - 调光接口包括: - Vaux 12V:9V-13.2V,用于被动调光器电源 - Dim+/Program:0-10V,用于调光/编程输入 - Dim:接地
参数特性: - 效率:89%(典型值)在220Vac全负载时 - 功率因数:大于0.95,在220Vac 80%-100%负载下 - THD:4%(典型值)在220Vac全负载时 - 输出电压范围:33-66V - 额定电流:530mA - 额定功率:35W - 保护:过电压保护、短路保护
功能详解: - 支持可编程驱动器,可通过特殊PC软件和编程模块进行编程。 - 调光接口描述,用户可以设置额定电流在10%到100%的最大电流之间。 - 支持PWM信号调光,用户可以设置PWM信号的正逻辑或负逻辑。 - 支持可调启动时间(AST)和渐变时间(FT)。
应用信息: - 集成的动态调光器允许根据夜间运行时间预设光输出水平,用户可以配置多达5个调光级别和时间间隔。
封装信息: - 尺寸:165x42.5x34.5毫米(长x宽x高) - 重量:典型值0.44公斤
附加信息: - 产品符合RoHS指令,即从电子产品中消除铅和其他有害物质。
ME035A053AQ_CLKS 价格&库存
很抱歉,暂时无法提供与“ME035A053AQ_CLKS”相匹配的价格&库存,您可以联系我们找货
ME035A053AQ_CLKS
