OR-3052S
OR-3052S
    ORIENT(奥伦德)
    OC_7.14X6.5MM_SM
    SOP-6 单向光耦 Viso=5000Vrms VF(typ)=1.2V IF=50mA OC_7.14X6.5MM_SM
OR-3052S 数据手册
Shenzhen Orient Tech Ltd . Co ., Ltd MOC305X ORIENT Photocoupler Product Data Sheet Name: MOC305X Customer:_________________ Date:_________________ Add:Block A 3rd Floor No.4 Building Tian An Cyber Park Huang Ge Rd, Long Gang Dist, Shenzhen, Guangdong, 518172 Web: www.orient-opto.com Copyright© 2018 Orient .All rights Reserved 1 A0 Shenzhen Orient Tech Ltd . Co ., Ltd MOC305X 1. Features (1) Isolation voltage between input and output Viso : 5,000V rms (2) 6pin non zero-cross optoisolators triac driver output (3) High repetitive peak off-state voltage VDRM : Min. 600V (4) High critical rate of rise of off-state voltage( dV/dt : MIN. 1000V / s ) (5) Dual-in-line package : MOC3050, MOC3051, MOC3052, MOC3053 (6) Wide lead spacing package : MOC3050M, MOC3051M, MOC3052M,MOC3053M (7) Surface mounting package : MOC3050S, MOC3051S, MOC3052S, MOC3053S (8) Tape and reel packaging : MOC3050S-TA, MOC3051S-TA, MOC3052S-TA, MOC3053S-TA,MOC3050S-TA1, MOC3051S-TA1, MOC3052S-TA1, MOC3053S-TA1 2. Description The MOC305X consists of a non zero crossing photo triac, optically coupled to a gallium arsenide infrared emitting diode. The MOC305X is housed in the DIP6 package and guarantees insulation thickness.Therefore, the MOC305X meets the reinforced insulation class requirements of international safety standards. 3.Application Range •AC Motor Drives •AC Motor Starters •Static power switch •Lighting Controls •Solenoid/Valve Controls •Solid State Relays •Temperature Controls 4. Absolute Maximum Ratings (Ta=25℃) Parameter Input Forward Current Junction Temperature Reverse Voltage Power Dissipation Off-State Output Terminal Voltage Peak Repetitive Surge Current Output (PW=1ms,120 pps) Junction Temperature Collector Power Dissipation Total Power Dissipation *1 Insulation Voltage Working Temperature Deposit Temperature *2 Soldering Temperature Symbol Rated Value Unit IF TJ VR P 50 125 6 100 mA ℃ V mW V DRM 600 V ITSM 1 A TJ PC Ptot Viso Topr Tstg Tsol 125 300 330 5000 -40 ~ + 100 -55 ~ + 150 260 ℃ mW mW Vrms ℃ Notes: *1 AC for 1 minute, R.H.= 40 ~ 60% R.H. In this test, pins 1, 2&3 are shorted together, and pins 4, 6 are shorted together. * 2 For 10 seconds Copyright© 2018 Orient .All rights Reserved 2 A0 Shenzhen Orient Tech Ltd . Co ., Ltd MOC305X 5.Electrical Optical Characteristics at Ta=25°C Parameter Input Output Symbol Condition Min Typ.* Max Forward Voltage VF IF=20mA --- 1.2 1.6 V Reverse Current IR VR=6V --- 0.05 10 μA 1.Peak Blocking Current, Either Direction IDRM V DRM = 600V --- 10 100 nA Peak On-State Voltage, Either Direction VTM ITM=100mA Peak --- 1.7 3.0 V 2.Critical rate of Rise of Off-State Voltage dv/dt Vin=240Vrms 1000 --- --- V/us --- --- 30 --- --- 15 --- --- 10 --- --- 5 --- 200 --- MOC3050 3.Led Trigger Current,Current Couple Required to Latch Output, Either Direction MOC3051 MOC3052 IFT MOC3053 Holding Current, Either Direction IH Main Terminal Voltage = 3V Unit mA uA *1.Test voltage must be applied within dv/dt rating. *2. This is static dv/dt. Commutating dv/dt is a function of the load-driving thyristor(s) only. *3. All devices are guaranteed to trigger at an IF value less than or equal to max IFT . Therefore,recommended operating IF lies between max IFT , 30 mA for MOC3050, 15 mA for MOC3051, 10 mA for MOC3052, 5 mA for MOC3053, and absolute max IF (50mA). Copyright© 2018 Orient .All rights Reserved 3 A0 Shenzhen Orient Tech Ltd . Co ., Ltd MOC305X 6.Naming Rule NOTE: (1) Manufacturer denotes Shenzhen Orient Tech Ltd . Co ., Ltd. (2) denotes IFT Rank Code ,0=MOC3050;1=MOC3051;2=MOC3052;3=MOC3053. (3) denotes Week code. (4) denotes Year code. (5) denotes Anode. (6) MOC305 denotes Device Part Number. (7) Unit:mm Copyright© 2018 Orient .All rights Reserved 4 A0 Shenzhen Orient Tech Ltd . Co ., Ltd MOC305X 7. Package Dimension (1).MOC305X (2).MOC305X M Copyright© 2018 Orient .All rights Reserved 5 A0 Shenzhen Orient Tech Ltd . Co ., Ltd MOC305X (3).MOC305X S 8. Taping Dimensions (1).MOC305XS-TA Copyright© 2018 Orient .All rights Reserved 6 A0 Shenzhen Orient Tech Ltd . Co ., Ltd MOC305X 2.MOC305XS-TA1 Description Symbol Dimension in mm (inch) Tape wide W 16±0.3 (0.63) Pitch of sprocket holes P0 4±0.1 (0.15) F 7.5±0.1 (0.295) P2 2±0.1 (0.079) P1 12±0.1 (0.472) Distance of compartment Distance of compartment to compartment Package Type MOC305XS series(TA/TA1) Quantities(pcs) 1000 Copyright© 2018 Orient .All rights Reserved 7 A0 Shenzhen Orient Tech Ltd . Co ., Ltd MOC305X 9.Temperature Profile Of Soldering (1).IR Reflow soldering (JEDEC-STD-020C compliant) One time soldering reflow is recommended within the condition of temperature and time profile shown below. Do not solder more than three times. Profile item Conditions Preheat - Temperature Min (TSmin ) 150˚C - Temperature Max (TSmax ) 200˚C - Time (min to max) (ts) Soldering zone 90±30 sec - Temperature (TL ) 217˚C - Time (tL ) 60 sec Peak Temperature(TP) 260˚C Ramp-up rate 3˚C / sec max. Ramp-down rate Copyright© 2018 Orient .All rights Reserved 3~6˚C / sec 8 A0 Shenzhen Orient Tech Ltd . Co ., Ltd MOC305X (2) .Wave soldering (JEDEC22A111 compliant) One time soldering is recommended within the condition of temperature. Temperature 260+0/-5˚C Time 10 sec Preheat temperature 5 to 140˚C Preheat time 30 to 80 sec (3).Hand soldering by soldering iron Allow single lead soldering in every single process. One time soldering is recommended. Copyright© 2018 Orient .All rights Reserved Temperature 380+0/-5˚C Time 3 sec max 9 A0 Shenzhen Orient Tech Ltd . Co ., Ltd MOC305X 10.RRECOMMENDED FOOT PRINT PATTERNS (MOUNT PAD) Copyright© 2018 Orient .All rights Reserved 10 A0 Shenzhen Orient Tech Ltd . Co ., Ltd MOC305X 11. CHARACTERISTICS CURVES (TYPICAL PERFORMANCE) Copyright© 2018 Orient .All rights Reserved 11 A0 Shenzhen Orient Tech Ltd . Co ., Ltd Copyright© 2018 Orient .All rights Reserved 12 MOC305X A0
OR-3052S 价格&库存
很抱歉,暂时无法提供与“OR-3052S”相匹配的价格&库存,您可以联系我们找货
