OR-815
OR-815
    ORIENT(奥伦德)
    DIP-4
    DIP-4 单向光耦 Viso=5000Vrms VF(typ)=1.2V IF=50mA Vo=80V CTR=600-7500%
OR-815 数据手册
Shenzhen Orient Tech Ltd . Co ., Ltd ORPC-815 ORIENT Photocoupler Product Data Sheet Name: ORPC-815 Customer:_________________ Date:_________________ Add:Block A 3rd Floor No.4 Building Tian An Cyber Park Huang Ge Rd, Long Gang Dist, Shenzhen, Guangdong, 518172 Web: www.orient-opto.com Copyright© 2018 Orient .All rights Reserved 1 A1 Shenzhen Orient Tech Ltd . Co ., Ltd ORPC-815 1.Features (1) (2) (3) (4) High current transfer ratio ( CTR : MIN. 600% at IF = 1mA, VCE = 2V ) High input-output isolation voltage ( Viso = 5,000Vrms ) Response time ( tr : TYP. 60µs at VCE = 2V, IC =10mA, RL = 100Ω ) Safety approval UL approved (No.E323844) VDE approved (No.40029733) CQC approved (No.CQC09001029446 CQC13001086898) CE approved (No.AC/0431008) State Grid approved (No.SGCM013420170152 ) 2. Description (1) The ORPC-815 series of devices each consist of an infrared emitting diodes, optically coupled to a photo Darlington detector. (2) They are packaged in a 4-pin DIP package and available in wide-lead spacing and SMD option. 3. Applications (1) Telephone set,telephone exchangers (2) System appliances,measuring instruments (3)Sequence controllers (4)Signal transmission between circuits of different potentials and impedances 4.Absolute Maximum Ratings at Ta=25℃ Parameter Input Symbol Rated Value Unit Forward Current IF 50 mA Peak forward current (1μs pulse) VR 6 V Reverse Voltage P 70 mW Output Consume Power IFP 1 A Collector and emitter Voltage VCEO 80 V Emitter and collector Voltage VECO 6 V Collector Current IC 80 mA Consume Power PC 150 mW Ptot 200 mW Vrms Total Consume Power Viso 5,000 Max Insulation Voltage (Insulating oil test) TOPR -55 ~ + 125 Rated Impulse Insulation Voltage TSTG -55 ~ + 125 Working Temperature Tsol 260 *1 Insulation Voltage ℃ *1.AC For 1 Minute, R.H. = 40 ~ 60% Isolation voltage shall be measured using the following method. (1) Short between anode and cathode on the primary side and between collector and emitter on the secondary side. (2) The isolation voltage tester with zero-cross circuit shall be used. (3) The waveform of applied voltage shall be a sine wave. *2. Soldering time is 10 seconds Copyright© 2018 Orient .All rights Reserved 2 A1 Shenzhen Orient Tech Ltd . Co ., Ltd ORPC-815 5. Electro-Optical Characteristics (Ta=25℃ unless specified otherwise) Parameter Condition Forward Current VF IF=20mA --- 1.2 1.4 V Reverse Voltage IR VR=4V --- --- 10 μA Collector capacitance Ct V=0, f=1KHz --- 30 250 pF Collector to emitter Current ICEO VCE=10V, IF=0mA --- --- 1 uA Collector and Emitter attenuation Voltage BVCEO 80 --- --- V Emitter and Collector attenuation Voltage BVECO 6 --- --- V *1 Current conversion ratio CTR 600 --- 7500 % Collector Current IC 6 --- 75 mA Collector and Emitter Saturation Voltage VCE(sat) --- 0.8 1 V Insulation Impedance Riso --- Ω Floating Capacitance Cf V=0, f=1MHz --- 0.6 1.0 pF Cut-off Frequency fc VCE=5V, IC=2mA 1 6 --- kHz Rise Time tr VCE=2V, IC=10mA --- 60 300 μs Descend Time tf RL=100Ω --- 53 250 μs Input Output Transforming Characteristics Min Typ.* Max Symbol IC=0.1mA IF=0mA IE=10uA IF=0mA IF=1mA VCE=2V IF=20mA IC= 5mA DC500V 40~60%R.H. RL=100Ω, -3dB 5×1010 1×1011 Unit *1Current Conversion Ratio = IC / IF × 100% , CTR Tolerance:±3%. Copyright© 2018 Orient .All rights Reserved 3 A1 Shenzhen Orient Tech Ltd . Co ., Ltd ORPC-815 6. Naming Rule (1)ORPC denotes Shenzhen Orient Tech Ltd . Co ., Ltd. (2) denotes Shape Code. (3) denotes Rank code. (4) denotes Week code. (5) denotes Device Part Number. (6) denotes Year Code (7) Anode. (8) Unit:mm 7.Recommended Foot Print Patterns (Mount Pad) (Unit:mm) Copyright© 2018 Orient .All rights Reserved 4 A1 Shenzhen Orient Tech Ltd . Co ., Ltd ORPC-815 8. Package Dimension (Unit:mm) (1) ORPC-815 (2) ORPC-815M Copyright© 2018 Orient .All rights Reserved 5 A1 Shenzhen Orient Tech Ltd . Co ., Ltd ORPC-815 (3) ORPC-815S 9.Taping Dimensions (1) ORPC-815S-TA Copyright© 2018 Orient .All rights Reserved 6 A1 Shenzhen Orient Tech Ltd . Co ., Ltd ORPC-815 (2) ORPC-815S-TA1 Description Symbol Dimension in mm (inch) Tape wide W 16±0.3 (.63) Pitch of sprocket holes P0 4±0.1 (.15) F 7.5±0.1 (.295) P2 2±0.1 (.0079) P1 12±0.1 (.472) Distance of compartment Distance of compartment to compartment Copyright© 2018 Orient .All rights Reserved Package Type TA/TA1 Quantities(pcs) 1000 7 A1 Shenzhen Orient Tech Ltd . Co ., Ltd ORPC-815 (3) ORPC-815S-TP Description Symbol Dimension in mm (inch) Tape wide W 16±0.3 (.63) Pitch of sprocket holes P0 4±0.1 (.15) F 7.5±0.1 (.295) P2 2±0.1 (.0079) P1 8±0.1 (.472) Distance of compartment Distance of compartment to compartment Package Type TP Quantities(pcs) 2000 Copyright© 2018 Orient .All rights Reserved 8 A1 Shenzhen Orient Tech Ltd . Co ., Ltd ORPC-815 10.Temperature Profile Of Soldering (1).IR Reflow soldering (JEDEC-STD-020C compliant) One time soldering reflow is recommended within the condition of temperature and time profile shown below. Do not solder more than three times. Profile item Conditions Preheat - Temperature Min (TSmin ) 150˚C - Temperature Max (TSmax ) 200˚C - Time (min to max) (ts) Soldering zone 90±30 sec - Temperature (TL ) 217˚C - Time (tL ) 60 sec Peak Temperature(TP) 260˚C Ramp-up rate 3˚C / sec max. Ramp-down rate Copyright© 2018 Orient .All rights Reserved 3~6˚C / sec 9 A1 Shenzhen Orient Tech Ltd . Co ., Ltd ORPC-815 (2).Wave soldering (JEDEC22A111 compliant) One time soldering is recommended within the condition of temperature. Temperature 260+0/-5˚C Time 10 sec Preheat temperature 25 to 140˚C Preheat time 30 to 80 sec (3).Hand soldering by soldering iron Allow single lead soldering in every single process. One time soldering is recommended. Copyright© 2018 Orient .All rights Reserved Temperature 380+0/-5˚C Time 3 sec max 10 A1 Shenzhen Orient Tech Ltd . Co ., Ltd ORPC-815 11.Characteristics Curves Copyright© 2018 Orient .All rights Reserved 11 A1 Shenzhen Orient Tech Ltd . Co ., Ltd Copyright© 2018 Orient .All rights Reserved 12 ORPC-815 A1
OR-815 价格&库存
很抱歉,暂时无法提供与“OR-815”相匹配的价格&库存,您可以联系我们找货
