3R-5-S SERIES
Gas Discharge Tube (GDT) Data Sheet
Features
■ Provide ultra-fast response to surge voltage from slow-rising
surge of 100V/s to rapid-rising surge of 1KV/μs.
■ Stable breakdown voltage.
■ High insulation resistance.
■ Low capacitance (≤2pF)
■ High holdover voltage
■ Large absorbing transient current capability.
■ Micro-Gap Design
■ Size: 5.0mm*7.2mm
■ Storage and operating temperature: -40℃ ~ +85℃
■ Meets MSL level 1, per J-STD-020
■ Safety certification: UL: E244458
Applications
Repeaters, Modems.
Telephone Interface, Line cards.
Data communication equipment.
Line test equipment
Part Number Code
Marking
Revision:17-Feb-16
www.brightking.com
3R-5-S SERIES
Dimensions
Dimension (mm)
Symbol
Spec.
Tolerance
D
5.0
±0.1
T
7.2
±0.3
B
0.4
±0.1
B1
1.5
±0.2
d
4.8
±0.1
Minimum
Insulation
Resistance
Maximum
Capacitance
Electrical Characteristics
Part
Number
DC
Spark-over
Voltage
Maximum
Impulse
Spark-over
Voltage
Nominal
Impulse
Discharge
Current
Alternating
Discharge
Current
Impulse
Life
100V/s
1000V/μs
8/20μs
10times
50Hz,1sec
10/1000μs
100A
Test
Voltage
1MHz
Device
Marking
Code
(GΩ)
(V)
(V)
(KA)
(A)
(times)
DC(V)
3RL075M-5-S
75±20%
700
5
5
300
25
1.0
2.0
3SL075M
3RL090M-5-S
90±20%
600
5
5
300
50
1.0
2.0
3SL090M
3RL120M-5-S
120±20%
600
5
5
300
50
1.0
2.0
3SL120M
3RL150M-5-S
150±20%
600
5
5
300
100
1.0
2.0
3SL150M
3RL200M-5-S
200±20%
600
5
5
300
100
1.0
2.0
3SL200M
3RL230M-5-S
230±20%
650
5
5
300
100
1.0
2.0
3SL230M
3RL250M-5-S
250±20%
650
5
5
300
100
1.0
2.0
3SL250M
3RL300M-5-S
300±20%
800
5
5
300
100
1.0
2.0
3SL300M
3RL350M-5-S
350±20%
800
5
5
300
100
1.0
2.0
3SL350M
3RL400M-5-S
400±20%
900
5
5
300
100
1.0
2.0
3SL400M
3RL420M-5-S
420±20%
900
5
5
300
250
1.0
2.0
3SL420M
3RL470M-5-S
470±20%
900
5
5
300
250
1.0
2.0
3SL470M
3RL600M-5-S
600±20%
1000
5
5
300
250
1.0
2.0
3SL600M
Revision:17-Feb-16
(pF)
www.brightking.com
3R-5-S SERIES
Electrical Ratings
Items
Test Condition/Description
Requirement
DC Spark-over
Voltage
The voltage is measured with voltage ramp dv/dt=100V/s. Test is
between each side electrode and center electrode.
Maximum Impulse
Spark-over Voltage
The maximum impulse spark-over voltage is measured with voltage
ramp dv/dt=1000V/μs. Test is between each side electrode and
center electrode.
Maximum surge current that can be applied through center electrode
with 8/20μs waveform, for 10 times with 3min interval time, which will
be equally divided between each side electrode to center electrode,
without causing the DC breakdown voltage to change more than 25%
from its initial measured value.
Impulse
Discharge Current
To meet
the specified
value
Alternating
Discharge Current
Rated RMS value of AC current at 50Hz, 1 sec. for 10 times with
interval time 3 min. DC spark-over voltage shall not change more than
±25% from its initial value. Test is between each side electrode and
center electrode.
IR>108 ohms (-20%, +30% for 70~90V).
Insulation
Resistance
The resistance of gas tube shall be measured between each side
electrodes and center electrode.
Capacitance
The capacitance of gas tube shall be measured between each side
Test frequency: 1MHz
Revision:17-Feb-16
www.brightking.com
3R-5-S SERIES
Recommended Soldering Conditions
Reflow Soldering
Recommended Conditions
Profile Feature
Pb-Free Assembly
Average ramp-up rate (TL to TP)
3℃/second max.
Preheat
-Temperature Min (TS min)
-Temperature Max (TS max)
-Time (min to max) (ts)
150℃
200℃
60-180 seconds
TS max to TL
-Ramp-up Rate
3℃/second max.
Time maintained above:
-Temperature (TL)
-Time (tL)
217℃
60-150 seconds
Peak Temperature (TP)
260℃
Time within 5℃ of actual Peak Temperature (tP)
Ramp-down Rate
Time 25℃ to Peak Temperature
Revision:17-Feb-16
20-40 seconds
6℃/second max.
8 minutes max.
www.brightking.com
3R-5-S SERIES
Packaging
Tape
P2
D0
t0
B0
W
F
P0
E
Symbol
P1
K0
A0
Reel
Dimension (mm)
Spec.
Tolerance
W
16.00
±0.20
P0
4.00
±0.10
P1
12.00
±0.20
P2
2.00
±0.10
D0
1.55
±0.05
E
1.75
±0.10
F
7.50
±0.10
A0
7.40
±0.10
K0
5.50
±0.10
B0
5.40
±0.10
t0
0.50
±0.10
D
330.00
±1.00
d
13.00
±0.50
L
20.00
±0.50
t
2.00
±0.20
Quantity: 900pcs
Revision:17-Feb-16
www.brightking.com
很抱歉,暂时无法提供与“3RL090M-5-S”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+2.34283
- 10+1.84436
- 30+1.54527
- 100+1.34588
- 500+1.29603
- 900+1.25616
- 国内价格
- 10+5.06050
- 100+3.01870
- 300+2.11310
- 900+1.50940
- 1800+1.43390
- 9000+1.32820
