ME6206
Low power consumption,Low ESR Cap.Compatible ME6206 Series
General Description
Features
ME6206 series are highly precise, low power
consumption, high voltage, positive voltage
regulators manufactured using CMOS and laser
trimming technologies .The series provides large
currents with a significantly small dropout voltage.
The series is compatible with low ESR ceramic
capacitors .The current limiter’s foldback circuit also
operates as a short protect for the output current
limiter and the output pin.
Selection Guide
l
l
l
l
l
l
l
l
l
Highly Accurate:±2%
Output voltage range:1.5V~5.0V ( selectable in 0.1V
steps)
Low power consumption:8uA(TYP.)
Large output current:300mA
Input voltage: up to 6 V
Dropout voltage:0.2V at 100mA and 0.40V at 200mA
Excellent Input Stability
Be available to regulator and reference voltage
Packages:SOT23-3,SOT89-3,SOT23,TO-92
Typical Application
l
l
l
l
l
l
l
Battery powered equipment
Communication tools
Mobile phones
Portable games
Portable AV systems
Cameras, Video systems
Reference voltage sources
Typical Application Circuit
V13
www.microne.com.cn
1
ME6206
Pin Configuration
Pin Assignment
ME6206Axx
Pin
Name
Function
1
Vss
Ground
2
3
Vout
Output
3
2
Vin
input
M3
P
P1
X
T
SOT23-3
SOT89-3
SOT89-3
SOT23
TO-92
1
1
2
1
2
3
1
3
2
3
Absolute Maximum Ratings
Parameter
Symbol
Description
Units
Input Voltage
VIN
6.5
V
Output Current
Iout
500
mA
Output Voltage
Vout
Vss-0.3 ~ Vout+0.3
V
SOT23-3
Pd
300
mW
SOT89-3
Pd
500
mW
SOT23
Pd
300
mW
TO-92
Pd
500
mW
Operating Ambient Temperature
TOpr
-25 ~ +85
Storage Temperature
Tstg
-40 ~ +125
Power Dissipation
V13
www.microne.com.cn
2
ME6206
Block Diagram
ME6206A15
O
(VIN=Vout+1V,Cin=Cout=1u,Ta=25 C Unless otherwise stated)
PARAMETER
SYMBOL
CONDITION
MIX
TYP
MAX
UNIT
Output Voltage
VOUT(E)
(Note 2)
IOUT=10mA,
VIN=Vout+1V
X 0.98
VOUT(T)
(Note 1)
X 1.02
V
Input Voltage
VIN
6
V
Maximum Output
Voltage
IOUT (max)
VIN=Vout+1V
100
mA
Load Regulation
∆VOUT
VIN=Vout+1V,
1mA≤IOUT≤80mA
10
mV
Dropout Voltage
(Note 3)
Vdif1
IOUT =20mA
180
mV
Vdif2
IOUT =50mA
360
mV
Supply Current
ISS
VIN=Vout+1V
7
μA
Line Regulations
∆VOUT
∆VIN •VOUT
IOUT =10mA
Vout+1V ≤VIN≤5V
0.1
%/V
Power Supply
Ripple Rejection
Ratio
PSRR
Vin= [Vout+1]V
+1Vp-pAC
IOUT =10mA,f=1kHz
45
dB
Short Circuit
Current
Ishort
Vin=Vout(T)+1.5V
Vout=Vss
mA
Over Current
Protection
I limit
300
mA
V13
www.microne.com.cn
3
ME6206
ME6206A18
(VIN=Vout+1V,Cin=Cout=1u,Ta=25OC Unless otherwise stated)
PARAMETER
SYMBOL
CONDITION
MIX
TYP
MAX
UNIT
Output Voltage
VOUT(E)
(Note 2)
IOUT=10mA,
VIN=Vout+1V
X 0.98
VOUT(T)
(Note 1)
X 1.02
V
Input Voltage
VIN
6
V
Maximum Output Voltage
IOUT (max)
VIN=Vout+1V
120
mA
Load Regulation
∆VOUT
VIN=Vout+1V,
1mA≤IOUT≤80mA
12
mV
Dropout Voltage
(Note 3)
Vdif1
IOUT =20mA
180
mV
Vdif2
IOUT =50mA
360
mV
Supply Current
ISS
VIN=Vout+1V
7
μA
IOUT =10mA
Vout+1V ≤VIN≤5V
0.1
%/V
45
dB
25
mA
400
mA
Line Regulations
∆VOUT
∆VIN •VOUT
Power Supply Ripple
Rejection Ratio
PSRR
Vin= [Vout+1]V
+1Vp-pAC
IOUT =10mA,f=1kHz
Short Circuit Current
Ishort
Vin=Vout(T)+1.5V
Vout=Vss
Over Current Protection
I limit
ME6206A28
PARAMETER
SYMBOL
CONDITION
MIX
TYP
MAX
UNIT
Output Voltage
VOUT(E)
(Note 2)
IOUT=10mA,
VIN=Vout+1V
X 0.98
VOUT(T)
(Note 1)
X 1.02
V
Input Voltage
VIN
6
V
IOUT (max)
VIN=Vout+1V
300
mA
Load Regulation
∆VOUT
VIN=Vout+1V
1mA≤IOUT≤100mA
14
mV
Dropout Voltage
(Note 3)
Vdif1
IOUT =80mA
180
mV
Vdif2
IOUT =200mA
380
mV
Supply Current
ISS
VIN=Vout+1V
8
μA
IOUT =40mA
Vout+1V ≤VIN≤6V
0.03
%/V
Vin= [Vout+1]V
+1Vp-pAC
IOUT =10mA,f=1kHz
50
dB
Line Regulations
Power Supply Ripple
Rejection Ratio
V13
∆VOUT
∆VIN •VOUT
PSRR
www.microne.com.cn
4
ME6206
I short
I limit
Vin=Vout(T)+1.5V
Vout=Vss
30
mA
500
mA
ME6206A30
O
PARAMETER
SYMBOL
CONDITION
MIX
TYP
MAX
UNIT
Output Voltage
VOUT(E)
(Note 2)
IOUT=10mA,
VIN=Vout+1V
X 0.98
VOUT(T)
(Note 1)
X 1.02
V
Input Voltage
VIN
6
V
IOUT (max)
VIN=Vout+1V
300
mA
Load Regulation
∆VOUT
VIN=Vout+1V
1mA≤IOUT≤100mA
14
mV
Dropout Voltage
(Note 3)
Vdif1
IOUT =80mA
180
mV
Vdif2
IOUT =200mA
380
mV
Supply Current
ISS
VIN=Vout+1V
8
μA
Line Regulations
∆VOUT
∆VIN •VOUT
IOUT =40mA
Vout+1V ≤VIN≤6V
0.03
%/V
Power Supply Ripple
Rejection Ratio
PSRR
Vin= [Vout+1]V
+1Vp-pAC
IOUT =10mA,f=1kHz
50
dB
I short
Vin=Vout(T)+1.5V
Vout=Vss
30
mA
I limit
500
mA
ME6206A33
PARAMETER
SYMBOL
CONDITION
MIX
TYP
MAX
UNIT
Output Voltage
VOUT(E)
(Note 2)
IOUT=10mA,
VIN=Vout+1V
X 0.98
VOUT(T)
(Note 1)
X 1.02
V
Input Voltage
VIN
6
V
IOUT (max)
VIN=Vout+1V
300
mA
Load Regulation
∆VOUT
VIN=Vout+1V
1mA≤IOUT≤100mA
14
mV
Dropout Voltage
(Note 3)
Vdif1
IOUT =80mA
180
mV
Vdif2
IOUT =200mA
380
mV
Supply Current
ISS
VIN=Vout+1V
9
μA
Line Regulations
∆VOUT
IOUT =40mA
0.03
%/V
V13
www.microne.com.cn
5
ME6206
∆VIN •VOUT
Vout+1V ≤VIN≤6V
Power Supply Ripple
Rejection Ratio
PSRR
Vin= [Vout+1]V
+1Vp-pAC
IOUT =10mA,f=1kHz
50
dB
I short
Vin=Vout(T)+1.5V
Vout=Vss
30
mA
I limit
500
mA
Note :
1. VOUT (T) :Specified Output Voltage
2.VOUT (E) :Effective Output Voltage ( le. The output voltage when “VOUT (T)+1.0V”is provided at the Vin pin while
maintaining a certain Iout value.)
3.Vdif :VIN1 –VOUT (E)’
VIN1 :The input voltage when VOUT(E)’ appears as input voltage is gradually decreased.
VOUT (E)’=A voltage equal to 98% of the output voltage whenever an amply stabilized Iout {VOUT (T)+1.0V}
is input.
V13
www.microne.com.cn
6
ME6206
Type Characteristics
(1) Output CurrentVS.Output Voltage(VIN=Vout+1, Ta = 25 °C)
ME6206A18PG
ME6206A28PG
3
Output Voltage(V)
Output Voltage(V)
2
1.9
1.8
1.7
1.6
1.5
1.4
1.3
1.2
1.1
1
2.9
2.8
2.7
2.6
2.5
100
150
200
250
50
ME6206A30PG
200
250
300
ME6206A33PG
4
4.3
3.8
4.1
3.6
3.9
Output Voltage (V)
Output Voltage (V)
150
Output Current(mA)
Output Current(mA)
3.4
3.2
3
2.8
2.6
2.4
2.2
3.7
3.5
3.3
3.1
2.9
2.7
2.5
2
2.3
100
150
200
250
300
Output Current(mA)
V13
100
50
100
150
200
250
300
Output Current(mA)
www.microne.com.cn
7
ME6206
(2)Input VoltageVS.Output Voltage(Ta = 25 °C)
ME6206A18PG
ME6206A28PG
2
3.6
1.8
3.2
1mA
1.4
Output Voltage(V)
Output Voltage(V)
1.6
1.2
1
10mA
0.8
0.6
100mA
0.4
2.8
2.4
1.6
0.8
0.4
2.5
3.5
4.5
5.5
10mA
1.2
0.2
0.5
1mA
2
6.5
100mA
0.5
1.5
ME6206A30PG
4.5
5.5
6.5
5.5
6.5
3.5
4
3
3.6
3.2
1mA
2.5
Output Voltage(V)
Output Voltage(V)
3.5
ME6206A33PG
2
10mA
1.5
1
100m
0.5
1mA
2.4
2
1.6
10mA
1.2
0.8
0.4
100mA
1.5
2.5
3.5
4.5
5.5
6.5
0.5
1.5
2.5
3.5
4.5
Input Voltage(V)
Input Voltage(V)
V13
2.5
Input Voltage(V)
Input Voltage(V)
www.microne.com.cn
8
ME6206
(3)Output Current VS.Droput Voltage(VIN=Vout+1V,Ta = 25 °C)
ME6206A18PG
ME6206A28PG
1000
900
800
700
600
450
400
Droput Voltage(mV)
Droput Voltage(mV)
Output Curre nt VS.Droput Voltage
500
400
300
200
100
300
250
200
150
100
50
100
150
200
50
ME6206A30PG
200
250
450
450
400
400
350
350
Droput Voltage(mV)
Droput Voltage(mV)
150
ME6206A33PG
300
250
200
150
100
50
300
250
200
150
100
50
100
150
200
250
100
150
200
250
Output Current (mA)
Output Current(mA)
V13
100
Output Current(mA)
Output Current(mA)
www.microne.com.cn
9
ME6206
(4)Input Voltage VS. Supply Current(Ta = 25 °C)
ME6206A18PG
ME6206A28PG
8
8
7
Supply Current(uA)
Supply Current(uA)
9
7
6
5
4
3
2
1
6
5
4
3
2
1
1
1.5
2
2.5
3
3.5
4
4.5
5
5.5
6
0.5
6.5
1
1.5
2
2.5
ME6206A30PG
4
4.5
5
5.5
6
6.5
Input Voltage VS. Supply Curre nt
8
7
7
6
6
Supply Current(uA)
Supply Current(uA)
3.5
ME6206A33PG
5
4
3
2
1
5
4
3
2
1
1
1.5
2
2.5
3
3.5
4
4.5
5
5.5
6
6.5
0.5
1
1.5
2
2.5
3
3.5
4
4.5
5
5.5
6
6.5
Input Voltage (V)
Input Voltage(V)
V13
3
Input Voltage(V)
Input Voltage(V)
www.microne.com.cn
10
ME6206
Packaging Information:
SOT89-3
SOT23-3
V13
www.microne.com.cn
11
ME6206
l
l
l
l
l
V13
The information described herein is subject to change without notice.
Nanjing Micro One Electronics Inc is not responsible for any problems caused by circuits or diagrams
described herein whose related industrial properties, patents, or other rights belong to third parties.
The application circuit examples explain typical applications of the products, and do not guarantee the
success of any specific mass-production design.
Use of the information described herein for other purposes and/or reproduction or copying without the
express permission of Nanjing Micro One Electronics Inc is strictly prohibited.
The products described herein cannot be used as part of any device or equipment affecting the human
body, such as exercise equipment, medical equipment, security systems, gas equipment, or any
apparatus installed in airplanes and other vehicles, without prior written permission of Nanjing Micro
One Electronics Inc.
Although Nanjing Micro One Electronics Inc exerts the greatest possible effort to ensure high quality
and reliability, the failure or malfunction of semiconductor products may occur. The user of these
products should therefore give thorough consideration to safety design, including redundancy,
fire-prevention measures, and malfunction prevention, to prevent any accidents, fires, or community
damage that may ensue.
www.microne.com.cn
12
很抱歉,暂时无法提供与“ME6206A28PG”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 10+0.48881
- 100+0.38621
- 300+0.33502
- 1000+0.28588
- 5000+0.25510
- 国内价格
- 10+0.44384
- 100+0.35074
- 300+0.30419
- 国内价格
- 1+0.43670
- 50+0.25630
- 1000+0.23100
