RC0603FR-07356KL
RC0603FR-07356KL
    YAGEO(国巨)
    贴片电阻 0603 356KΩ ±1% 1/10W ±100ppm/℃
RC0603FR-07356KL 数据手册
Product specification – August 27, 2013 V.7 Supersedes Date of Mar. 06, 2003 DATA SHEET GENERAL PURPOSE CHIP RESISTORS RC0603 5%, 1%, 0.5% RoHS compliant Product specification Chip Resistor Surface Mount RC 0603 (RoHS Compliant) SERIES SCOPE ORDERING INFORMATION - GLOBAL PART NUMBER & 12NC This specification describes RC0603 series chip resistors with lead-free terminations made by thick film process. Both part numbers are identified by the series, size, tolerance, packing type, temperature coefficient, taping reel and resistance value. YAGEO BRAND ordering code GLOBAL PART NUMBER (PREFERRED ) APPLICATIONS  All general purpose application FEATURES  RoHS compliant - Products with lead free terminations meet RoHS requirements - Pb-glass contained in electrodes, resistor element and glass are exempted by RoHS  Reducing environmentally hazardous wastes  High component and equipment reliability  Saving of PCB space  None forbidden-materials used in products/production  Halogen Free Epoxy RC0603 2 9 X R - XX XXXX L (1) (2) (3) (4) (5) (6) (1) TOLERANCE D = ± 0.5% F = ± 1% J = ± 5% (for Jumper ordering, use code of J) (2) PACKAGING TYPE R = Paper / PE taping reel (3) TEMPERATURE COEFFICIENT OF RESISTANCE – = Base on spec (4) TAPING REEL 07 = 7 inch dia. Reel 10 = 10 inch dia. Reel 13 = 13 inch dia. Reel (5) RESISTANCE VALUE There are 2~4 digits indicated the resistor value. Letter R/K/M is decimal point, no need to mention the last zero after R/K/M, e.g.1K2, not 1K20. Detailed resistance rules show in table of “Resistance rule of global part number”. (6) DEFAULTCODE Letter L is the system default code for ordering only. (Note) Resistance rule of global part number Resistance code rule Example 0R 0R = Jumper XRXX (1 to 9.76 Ω) 1R = 1 Ω 1R5 = 1.5 Ω 9R76 = 9.76 Ω XXRX (10 to 97.6 Ω) 10R = 10 Ω 97R6 = 97.6 Ω XXXR (100 to 976 Ω) 100R = 100 Ω XKXX (1 to 9.76 KΩ) 1K = 1,000 Ω 9K76 = 9760 Ω XMXX (1 to 9.76 MΩ) 1M = 1,000,000 Ω 9M76= 9,760,000 Ω ORDERING EXAMPLE The ordering code of a RC0603 chip resistor, value 56 X with ± 1% tolerance, supplied in 7-inch tape reel is: RC0603FR-0756RL. NOTE 1. All our RSMD products meet RoHS compliant. "LFP" of the internal 2D reel label mentions "Lead Free Process" 2. On customized label, "LFP" or specific symbol printed and the optional "L" at the end of GLOBAL PART NUMBER / 12NC can be added (both are on customer request) www.yageo.com Aug. 27, 2013 V.7 Product specification Chip Resistor Surface Mount RC SERIES 0603 (RoHS Compliant) 3 9 PHYCOMP BRAND ordering codes Both GLOBAL PART NUMBER (preferred) and 12NC (traditional) codes are acceptable to order Phycomp brand products. GLOBAL PART NUMBER (PREFERRED ) For detailed information of GLOBAL PART NUMBER and ordering example, please refer to page 2. 12NC CODE 2322 / 2350 XXX XXXXX L (1) (2) (3) (4) PAPER / PE TAPE ON REEL (units) (2) TYPE/ START TOL. RESISTANCE 0603 IN (1) (%) RANGE 5,000 RC21 2322 ± 5% 1 to 10 MΩ 702 60xxx 702 70xxx 702 81xxx RC22 2322 ± 1% 1 to 10 MΩ 704 6xxxx 704 7xxxx 704 8xxxx HRC21 2350 ± 5% 11 to 22 MΩ 522 10xxx - - Jumper 2322 - 702 96001 702 97001 702 92002 0Ω 10,000/not preferred 20,000 (1) The resistors have a 12-digit ordering code starting with 2322 / 2350. (2) The subsequent 4 or 5 digits indicate the resistor tolerance and packaging. (3) The remaining 4 or 3 digits represent the resistance value with the last digit indicating the multiplier as shown in the table of “Last digit of 12NC”. (4) "L" is optional symbol (Note) . ORDERING EXAMPLE The ordering code of a RC22 resistor, value 56 X with ± 1% tolerance, supplied in tape of 5,000 units per reel is: 232270465609(L) or RC0603FR-0756R(L). Last digit of 12NC Resistance decade (3) 0.01 to 0.0976 X Last digit 0 0.1 to 0.976 X 7 1 to 9.76 X 8 10 to 97.6 X 9 100 to 976 X 1 1 to 9.76 KX 2 10 to 97.6 KX 3 100 to 976 KX 4 1 to 9.76 MX 5 10 to 97.6 MX 6 Example: 0.02 X 0.3 X = 0200 or 200 = 3007 or 307 1X = 1008 or 108 33 KX 10 MX = 3303 or 333 = 1006 or 106 NOTE 1. All our RSMD products are RoHS compliant. "LFP" of the internal 2D reel label mentions "Lead Free Process" 2. On customized label, "LFP" or specific symbol printed and the optional "L" at the end of GLOBAL PART NUMBER / 12NC can be add ed (both are on customer request) www.yageo.com Aug. 27, 2013 V.7 Product specification Chip Resistor Surface Mount RC SERIES 0603 (RoHS Compliant) 4 9 MARKING RC0603 No marking Fig. 1 For further marking information, please refer to data sheet “Chip resistors marking”. CONSTRUCTION The resistor is constructed on top of a high-grade ceramic body. Internal metal electrodes are added on each end to make the contacts to the thick film resistive element. The composition of the resistive element is a noble metal imbedded into a glass and covered by a second glass to prevent environment influences. The resistor is laser trimmed to the rated resistance value. The resistor is covered with a protective epoxy coat, finally the two external terminations (matte tin on Nibarrier) are added. See fig.4 OUTLINES For dimension see Table 1 DIMENSIONS Table 1 TYPE RC0603 L (mm) 1.60 ± 0.10 W (mm) 0.80 ± 0.10 H (mm) 0.45 ± 0.10 I1 (mm) 0.25 ± 0.15 I2 (mm) 0.25 ± 0.15 Fig. 2 Chip resistor outlines www.yageo.com Aug. 27, 2013 V.7 Product specification Chip Resistor Surface Mount RC SERIES 0603 (RoHS Compliant) ELECTRICAL CHARACTERISTICS Table 2 5 9 FOOTPRINT AND SOLDERING PROFILES RC0603 1/10 W CHARACTERISTICS Operating Temperature Range –55 °C to +155 °C Maximum Working Voltage 75 V Maximum Overload Voltage 150 V Dielectric Withstanding Voltage 100 V For recommended footprint and soldering profiles, please refer to data sheet “Chip resistors mounting”. 5% (E24) 1 Ω to 22 MΩ 1% (E24/E96) 1 Ω to 10 MΩ Resistance Range 0.5% (E24/E96) 10 Ω to 1 MΩ Zero Ohm Jumper < 0.05 Ω Temperature Coefficient 1 Ω ≤ R ≤ 10Ω ± 200 ppm/°C 10 MΩ < R ≤ 22 MΩ ± 200 ppm/°C 10 Ω < R ≤ 10 MΩ ± 100 ppm/°C Rated Current 1.0 A Maximum Current 2.0 A Jumper Criteria PACKING STYLE AND PACKAGING QUANTITY Table 3 Packing style and packaging quantity PRODUCT TYPE PACKING STYLE REEL DIMENSION QUANTITY PER REEL RC0603 Paper Taping Reel (R) 7" (178 mm) 5,000 units 10" (254 mm) 10,000 units 13" (330 mm) 20,000 units NOTE 1. For paper tape and reel specification/dimensions, please see the special data sheet “Chip resistors packing”. FUNCTIONAL DESCRIPTION POWER RATING RC0603 rated power at 70°C is 1/10 W RATED VOLTAGE The DC or AC (rms) continuous working voltage corresponding to the rated power is determined by the following formula: V=√(P X R) or max. working voltage whichever is less Where V=Continuous rated DC or AC (rms) working voltage (V) P=Rated power (W) R=Resistance value (X) Fig. 3 Maximum dissipation (P) in percentage of rated power as a function of the operating ambient temperature (T amb ) www.yageo.com Aug. 27, 2013 V.7 Product specification Chip Resistor Surface Mount RC SERIES 0603 (RoHS Compliant) 6 9 TESTS AND REQUIREMENTS Table 4 Test condition, procedure and requirements TEST TEST METHOD PROCEDURE REQUIREMENTS Temperature Coefficient of Resistance (T.C.R.) IEC 60115-1 4.8 At +25/–55 °C and +25/+125 °C Refer to table 2 Formula: R2–R1 T.C.R= ------------------------- × 106 (ppm/°C) R1(t2–t1) Where t1=+25 °C or specified room temperature t2=–55 °C or +125 °C test temperature R1=resistance at reference temperature in ohms R2=resistance at test temperature in ohms Life/Endurance IEC 60115-1 4.25.1 1,000 hours at 70± 5 °C applied RCWV 1.5 hours on, 0.5 hour off, still air required ±(1.0%+0.05 Ω) for 1%, 0.5% tol. ±(3.0%+0.05 Ω) for 5% tol.
RC0603FR-07356KL 价格&库存
很抱歉,暂时无法提供与“RC0603FR-07356KL”相匹配的价格&库存,您可以联系我们找货
