深圳市富满电子有限公司
SHENZHEN FUMAN ELECTRONICS CO., LTD.
74HC04/74HCT04(文件编号:S&CIC0463)
FEATURES
Complies with JEDEC standard no. 8-1A
ESD protection
HBM EIA/JESD22-A114-A exceeds 2000V
MM EIA/JESD22-A115-A exceeds 200V
Specified from –40 to +85℃ and –40 to +125℃
DESCRIPTION
The 74HC04/74HCT04 are high-speed Si-gate CMOS devices and are pin compatible with low power Schottky TTL
(LSTTL). They are specified in compliance with JEDEC standard no. 7A. The 74HC04/74HCT04 provide six inverting buffers.
QUICK REFERENCE DATA
GND = 0V; Tamb = 25℃; tf = tf≤6.0ns
SYMBOL
PARAMETER
CONDITIONS
TPLH/tPLH
Propagation delay nA to nY
CL = 15pF; VCC = 5V
CI
Input capacitance
CPD
Power dissipation capacitance per gate
TYPICAL
HCT04
7
8
ns
3.5
3.4
pF
21
24
pF
Notes 1 and 2
Notes
1. CPD is used to determine the dynamic power dissipation (PD in uW).
PD = CPD×VCC2×fi×N+Σ(CL×VCC2×fo)where:
fi = input frequency in MHz;
fo = output frequency in MHz;
CL = output load capacitance in pF;
VCC = supply voltage in volts;
N = total load switching outputs;
2. For 74HC04: the condition is VI = GND to VCC.
For 74HCT04: the condition is VI = GND to VCC-1.5V
FUNCTION TABLE
See note 1.
INPUT
OUTPUT
nA
nY
L
H
H
L
Note
1. H = HIGH voltage level;
L = LOW voltage level.
第 1 页 共 18 页
UNIT
HC04
深圳市富满电子有限公司
ORDERING INFORMATION
TYPE NUMBER
PACKAGE
TEMPERATURE RANGE
PINS
PACKAGE
MATERIAL
CODE
74HC04N
–40 to +125℃
14
DIP14
Plastic
SOT27-1
74HCT04N
–40 to +125℃
14
DIP14
Plastic
SOT27-1
74HC04D
–40 to +125℃
14
SO14
Plastic
SOT108-1
74HCT04D
–40 to +125℃
14
SO14
Plastic
SOT108-1
74HC04DB
–40 to +125℃
14
SSOP14
Plastic
SOT337-01
74HCT04DB
–40 to +125℃
14
SSOP14
Plastic
SOT337-01
74HC04PW
–40 to +125℃
14
TSSOP14
Plastic
SOT402-1
74HCT04PW
–40 to +125℃
14
TSSOP14
Plastic
SOT402-1
74HC04BQ
–40 to +125℃
14
DHVQF14
Plastic
SOT762-1
74HCT04BQ
–40 to +125℃
14
DHVQF14
Plastic
SOT762-1
1
PINNING
PIN
SYMBOL
DESCRIPTION
1
1A
Data input
2
1Y
Data output
3
2A
Data input
4
2Y
Data output
5
3A
Data input
6
3Y
Data output
7
GND
8
1A
1
14
VCC
1Y
2
13
6A
2A
3
12
6Y
2Y
4
11
5A
Ground (0V)
3A
5
10
5Y
4Y
Data output
3Y
6
9
4A
9
4A
Data input
10
5Y
Data output
GND 7
8
4Y
11
5A
Data input
12
6Y
Data output
13
6A
Data input
14
VCC
Supply votage
D
04
MNA340
Fig. 1 Pin configuration
DIP14,SO14 and (T)SSOP14.
C
第 2 页 共 18 页
深圳市富满电子有限公司
2
1A
VCC
1
14
1Y 2
13 6A
2A 3
12 6Y
GND(1)
2Y 4
4
11 5A
3A 5
10 5Y
3Y 6
Top view
3
9
7
8
GND
4Y
1
1A
1Y
2
3
2A
2Y
4
5
3A
3Y
6
9
4A
4Y
8
11
5A
5Y
10
13
6A
6Y
12
4A
MBL 760
(1) The die substrate is attached to this pad using
conductive die attach material.it can not be used as
a supply pin or input.
MNA342
Fig.3 Logic symbol.
Fig.2 Pin configuration DHVQFN14.
1
1
2
1
3
4
1
5
6
1
9
8
A
Y
MNA341
1
11
10
1
13
12
MNA343
Fig.4 IEC logic symbol.
Fig.5 Logic diagram(one inverter).
第 3 页 共 18 页
2
3
4
深圳市富满电子有限公司
RECOMMENDED OPERATING CONDITIONS
SYMBOL
PARAMETER
VCC
CONDITIONS
74HC04
74HCT04
UNIT
MIN
TYP
MAX
MIN
TYP
MAX
Supply voltage
2.0
5.0
6.0
4.5
5.0
5.5
V
VI
Input voltage
Vcc
Vcc
V
VO
Output voltage
Vcc
Vcc
V
See DC and AC
Characteristics per
Device
-40
+25
+125
-40
+25
+125
Vcc = 2.0V
1000
ns
Vcc = 4.5V
6.0
500
6.0
500
ns
Vcc = 6.0V
400
ns
Tamb
tr, tf
Ambient temperature
Input rise and fall times
LIMITING VALUES
In accordance with the absolute maximum rating system (IEC 60134); voltages are referenced to GND (fround = 0V)
SYMBOL
PARAMETER
Vcc
Suupply voltage
IIK
Input diode current
IOK
CONDITIONS
MIN
TYP
MAX
-0.5
+7.0
V
VI
很抱歉,暂时无法提供与“74HC04D”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 10+0.46268
- 100+0.37163
- 300+0.32616
- 1000+0.29204
- 4000+0.26471
- 8000+0.25100
- 国内价格
- 10+0.40698
- 100+0.32690
- 800+0.25688
- 1600+0.25303
- 4000+0.23285
- 国内价格
- 1+0.41800
- 200+0.26950
- 2000+0.23540
- 4000+0.20790
