FP7102
28V, 2A Buck Constant Current Switching Regulator
for White LED
General Description
The FP7102 is a PWM control buck converter designed to provide a simple, high efficiency
solution for driving high power LEDs. With a 0.25V reference voltage feedback control to minimize
power dissipation, an external resistor sets the current as needed for driving various types of LEDs.
The FP7102 includes a high current P-MOSFET to realize high efficiency and excellent transient
characteristics. The PWM control circuit is able to change the duty ratio linearly from 0 up to 100%.
Other features include user accessible EN pin for enabling, thermal shutdown, cycle-by-cycle current
limit and over current protection.
Features
Wide Supply Voltage Operating Range: 3.6 to 28V
Built-in P-MOSFET for 2A Loading Capability
Precision Feedback Reference Voltage: 0.25V (2%)
Low Current Consumption: 4mA
Internal Fixed Oscillator Frequency: 320KHz (Typ.)
Internal Soft-Start Function (SS)
Over Current Protection
Package: SOP-8L &SOP-8L(EP)
Typical Application Circuit
VIN
LX
V CC
LX
FP 7102
ON/OFF
EN
FB
COMP
GND
GND
This datasheet contains new product information. Feeling Technology reserves the rights to modify the product specification without notice.
No liability is assumed as a result of the use of this product. No rights under any patent accompany the sales of the product.
Rev. 0.93
Website: http://www.feeling-tech.com.tw
1/12
FP7102
Function Block Diagram
EN
VCC
Enable
Control
Reference
Regulator
Oscillator
2.50V
Over Current
Protection
36K
FB
0. 25V
Output Drive
Control Circuits
500
COMP
Thermal
Shutdown
Internal Soft Start
Circuit
GND
GND
LX
LX
Rev. 0.93
2/12
FP7102
Pin Descriptions
SOP- 8L
Name
No. I / O
Description
FP7102
9Fa-86L
FB
1
I
Error Amplifier Inverting Input
EN
2
I
Enable Control
COMP
3
O
Error Amplifier Compensation Output
VCC
4
P
IC Power Supply (PMOS Source)
LX
5
P
PMOS High Current Output
LX
6
P
GND
7
O
IC Ground
GND
8
O
IC Ground
SOP- 8L (EP)
Top View
FB
1
COMP
3
VCC
4
FP7102
2
9Fa-86L
EN
8
GND
Name
No. I / O
Description
FB
1
I
7
GND
EN
2
I
Enable Control
6
LX
COMP
3
O
5
LX
VCC
4
P
LX
5
P
LX
6
P
GND
7
O
IC Ground
GND
8
O
IC Ground
EP
9
P
Exposed PAD. Must connect to LX
Bottom View
EP
Rev. 0.93
3/12
FP7102
Marking Information
SOP- 8L & SOP-8L (EP)
Halogen Free: Halogen free product indicator
Lot Number: Wafer lot number’s last two digits
For Example: 132386TB 86
Internal ID: Internal Identification Code
Per-Half Month: Production period indicated in half month time unit
For Example: January → A (Front Half Month), B (Last Half Month)
February → C (Front Half Month), D (Last Half Month)
Year: Production year’s last digit
Rev. 0.93
4/12
FP7102
Ordering Information
Part Number
Operating Temperature
Package
MOQ
Description
FP7102DR-LF
-25°C ~ +85°C
SOP-8L
2500EA
Tape & Reel
FP7102XR-LF
-25°C ~ +85°C
SOP-8L (EP)
2500EA
Tape & Reel
Absolute Maximum Ratings
Parameter
Max.
Unit
28
V
2
A
+1.2
V
650
mW
θJA
+175
℃/W
θJC
+45
℃/W
Symbol
Power Supply Voltage
Conditions
Min.
Typ.
VIN
Output Source Current
-0.3
TA≦+25℃
Allowable Dissipation
Thermal Resistance Junction to
Ambient
Case
ESD Susceptibility
HBM (Human Body Mode)
MM (Machine Mode)
Storage Temperature
Lead Temperature (soldering, 10
sec)
-55
2
KV
200
V
+125
+260
IR Re-flow Soldering Curve
Rev. 0.93
5/12
FP7102
Recommended Operating Conditions
Parameter
Symbol
Supply Voltage
Conditions
VIN
Min.
Max.
Unit
3.6
Typ.
28
V
-25
85
DC Electrical Characteristics (VCC=6V, TA= 25℃, unless otherwise noted)
Parameter
Symbol
Conditions
Min.
Typ.
Max.
Unit
0.245
0.25
0.255
V
mV
Reference
Output Voltage
VREF
FB connected to COMP
Input Regulation
△VREF VCC=3.6 V to 25 V
2
12.5
Output Voltage Change with
Temperature
△VREF / TA=-25℃ to 25℃
VREF TA= 25℃ to 85℃
1
2
1
2
Oscillator Section
Oscillation Frequency
f
320
KHz
Frequency Change with Voltage
Δf / ΔV VCC=3.6V to 25V
5
Temperature
Δf / ΔT TA = -25℃ to +85℃
5
Error Amplifier Section
Input Bias Current
IB
Voltage Gain
Av
Frequency Bandwidth
BW
Output Voltage Swing Positive
VPOS
Output Voltage Swing Negative
VNEG
-1.0
Av=0 dB
1.7
ISINK
Vcomp=200mV
1.0
μA
100
V/V
6
MHz
2
V
0.1
ISOURCE Vcomp=200mV
Output Sink Current
-0.2
0.2
V
-15
-30
μA
15
30
μA
100
-20
V
-2
A
Idle Period Adjustment Section
Maximum Duty Cycle
TDUTY VFB =0.2V
Output Section
PMOS D-S Voltage
VDSS
PMOS Source Current
ID
PMOS On Resistance
RDS (ON)
Output Leakage Current
VCOMP=0.1V
VCC=5.0V, V FB=0V
70
150
VCC=10V, V FB=0V
42
90
IL
mΩ
5
μA
150
3
A
Thermal Shutdown Section
Thermal shutdown Temperature
Over Current Protection Section
PMOS OCP Current
IOCP
Rev. 0.93
6/12
FP7102
Parameter
Symbol
Conditions
IEN
EN pin Open
Min.
Typ.
Max.
Unit
μA
Total Device Section
EN Input Current
Upper Threshold Voltage (EN)
VUPPER
1.12
V
Lower Threshold Voltage (EN)
VLOW
0.87
V
Hysteresis
VHYS
250
mV
Average Supply Current
IAVE
4
ISHUTDOWN
15
VCC Shutdown
210
6
mA
μA
Rev. 0.93
7/12
FP7102
Detailed Description
Voltage Reference
A built-in 2.5V reference regulator supplies FP7102 internal circuits. Also, this 2.5V reference
voltage is divided down by an internal resistive divider to provide a 0.25V precision reference voltage to
the error amplifier non-inverting terminal.
Setting the LED Current
FP7102 is a constant current buck regulator. The LEDs are connected between VOUT and FB pin
as shown in the Typical Application Circuit section. The FB pin is 0.25V in regulation. Therefore, the
LEDs current IF is set by VFB and the resistor R2 connected between FB and ground by the following
equation:
IF
VFB
R2
IF should not exceed the 2A current capability of FP7102 and therefore R2 minimum value must
be approximately 0.13Ω.
Output Voltage
The output voltage is primarily determined by the number of LEDs(n) connected between VOUT
and FB pin. Therefore, VOUT can be written as:
VOUT ((n VF ) VFB )
Where VF is the forward voltage of one LED at the set LED current level (see LED manufacturer
datasheet for forward characteristics curve)
Oscillator
The fixed PWM frequency is generated by an internal oscillator. Its typical values are 320KHz.
Thermal Protection
The thermal protection is triggered when junction temperature is higher than 150℃ that may
occurs by an abnormal heavy current loading. When this happens, the FP7102 turns output off. Once
the junction temperature is cooled down to lower than 130℃, FP7102 starts again and turns the power
switch on.
Rev. 0.93
8/12
FP7102
The FP7102 uses cycle-by-cycle current limit to protect the internal power switch. During each
switching cycle, a current limit comparator detects if the power switch current exceeds the internal
setting current. If it does, over current protection function decrease the oscillator frequency to prevent
thermal issue.
Rev. 0.93
9/12
FP7102
Typical Application
FP7102 1W / 3W LED for DC Input Circuit
Dimming Control Circuit
Changing the duty cycle of PWM signal can get different LED current. The PWM signal is
recommended above 10kHz. The application circuit is shown in the following.
The LED current can be calculated by the following equation:
ILED
VFB
R4 ( VPWM Duty VFB )
R3 R5
R2
Rev. 0.93
10/12
FP7102
Package Outline
SOP-8L
UNIT: mm
Symbols
Min. (mm)
Max. (mm)
A
1.346
1.752
A1
0.101
0.254
A2
1.498
D
4.800
4.978
E
3.810
3.987
H
5.791
6.197
L
0.406
1.270
θ°
0°
8°
Note:
1.
Package dimensions are in compliance with JEDEC outline: MS-012 AC.
2.
Dimension “D” does not include molding flash, protrusions or gate burrs.
3.
Dimension “E” does not include inter-lead flash or protrusions.
Rev. 0.93
11/12
FP7102
SOP-8L (EP)
UNIT: mm
Symbols
Min. (mm)
Max. (mm)
A
1.346
1.752
A1
0.050
0.152
A2
1.498
D
4.800
4.978
E
3.810
3.987
H
5.791
6.197
L
0.406
1.270
θ°
0°
8°
Exposed PAD Dimensions:
Symbols
Min. (mm)
Max. (mm)
E1
2.184 REF
D1
2.971 REF
Note:
1.
Package dimensions are in compliance with JEDEC outline: MO-178 AA.
2.
Dimension ”D” does not include molding flash, protrusions or gate burrs.
3.
Rev. 0.93
12/12
很抱歉,暂时无法提供与“FP7102DR-LF”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+1.99999
- 30+1.93749
- 100+1.81249
- 500+1.68749
- 1000+1.62499
