FP6161KR-LF
FP6161KR-LF
    FEELING(遠翔科技)
    SOT23-5
    1.5MHz,1A同步降压调节器 SOT23-5L
FP6161KR-LF 数据手册
FP6161 1.5MHz, 1A Synchronous Step-Down Regulator General Description The FP6161 is a high efficiency current mode synchronous buck PWM DC-DC regulator. The internal generated 0.6V precision feedback reference voltage is designed for low output voltage. Low RDS (ON) synchronous switch dramatically reduces conduction loss. To extend battery life for portable application, 100% duty cycle is supported for low-dropout operation. Shutdown mode also helps saving the current consumption. The FP6161 is packaged in DFN-6L, SOT23-5L, and TSOT23-5L to reduce PCB space. Features  Input Voltage Range: 2.5 to 5.5V  Precision Feedback Reference Voltage: 0.6V (±2%)  Output Current: 1A (Max.)  Duty Cycle: 0~100%  Internal Fixed PWM Frequency: 1.5MHz  Low Quiescent Current: 100μA  No Schottky Diode Required  Built-in Soft Start  Current Mode Operation  Over Temperature Protection  Package: DFN-6L (2x2mm), SOT23-5L, TSOT23-5L Applications  Cellular Telephone  Wireless and DSL Modems  Digital Still Cameras  Portable Products  MP3 Players Typical Application Circuit VIN VIN SW VOUT FP6161 RUN FB / VOUT GND This datasheet contains new product information. Feeling Technology reserves the rights to modify the product specification without notice. No liability is assumed as a result of the use of this product. No rights under any patent accompany the sales of the product. Rev. 0.67 Website: http://www.feeling-tech.com.tw 1/16 FP6161 Function Block Diagram VCC Current Sense Slope Compensation 0.6V FB/ VOUT UVLO 0.3V RUN + PWM Comparator - + Error Amp. - Current Limit OSC S Q R Q Switching Control Logic SR Latch Pre-Driver and Anti Shootthrough + FBUV Comparator - Reverse Reverse Current Detector Shutdown Control OTP SW Reference Voltage Generator GND Pin Descriptions DFN-6L ZYa 986 Name NC No. I / O 1 Description No Connect RUN 2 I Enable Pin VIN 3 P Power Supply SW 4 O Switch GND 5 P Ground FB / VOUT 6 I Feedback EP 7 P Exposed PAD – Must Connect to Ground SOT23-5L / TSOT23-5L Name No. I / O Description ZY986 RUN 1 I Enable GND 2 P Ground SW 3 O Switch VIN 4 P Power Supply FB / VOUT 5 I Feedback This datasheet contains new product information. Feeling Technology reserves the rights to modify the product specification without notice. No liability is assumed as a result of the use of this product. No rights under any patent accompany the sales of the product. Rev. 0.67 Website: http://www.feeling-tech.com.tw 2/16 FP6161 Marking Information DFN-6L SOT23-5L / TSOT23-5L Halogen Free: Halogen free product indicator Lot Number: Wafer lot number’s last two digits For Example: 132386TB  86 Part Number Code: Part number identification code for this product. It should be always “ZY”. Year: Production year’s last digit This datasheet contains new product information. Feeling Technology reserves the rights to modify the product specification without notice. No liability is assumed as a result of the use of this product. No rights under any patent accompany the sales of the product. Rev. 0.67 Website: http://www.feeling-tech.com.tw 3/16 FP6161 Ordering Information Part Number Code Operating Temperature Package MOQ Description 2500EA Tape & Reel FP6161dR-LF-ADJ ZY -40°C ~ +85°C DFN-6L (2x2mm) FP6161KR-LF-ADJ ZY -40°C ~ +85°C SOT23-5L 3000EA Tape & Reel FP6161iR-LF-ADJ ZY -40°C ~ +85°C TSOT23-5L 3000EA Tape & Reel Absolute Maximum Ratings Max. Unit -0.3 6 V -0.3 VIN V P-Channel Switch Source Current (DC) 1.5 A N-Channel Switch Source Current (DC) 1.5 A Parameter Input Supply Voltage Symbol Conditions VIN RUN, VFB, SW Pin Voltage Min. Peak SW Switch Sink and Source Current (AC) Thermal Resistance (Junction to Ambient) Thermal Resistance (Junction to Case) θJA θJC 2 A DFN-6L +165 °C / W SOT23-5L +250 °C / W TSOT23-5L +250 °C / W DFN-6L +20 °C / W SOT23-5L +90 °C / W TSOT23-5L +90 °C / W +150 °C +150 °C DFN-6L 750 mW SOT23-5L 500 mW TSOT23-5L 500 mW +260 °C Junction Temperature Storage Temperature Allowable Power Dissipation -65 PD Typ. Lead Temperature (soldering, 10 sec) Suggested IR Re-flow Soldering Curve This datasheet contains new product information. Feeling Technology reserves the rights to modify the product specification without notice. No liability is assumed as a result of the use of this product. No rights under any patent accompany the sales of the product. Rev. 0.67 Website: http://www.feeling-tech.com.tw 4/16 FP6161 Recommended Operating Conditions Parameter Symbol Supply Voltage Conditions VIN Operating Temperature Min. Typ. Max. Unit 2.5 5.5 V -40 +85 °C DC Electrical Characteristics (TA= 25°C, VIN=3.6V, unless otherwise noted) Parameter Symbol Regulated Feedback Voltage VFB Min. Typ. Max. Unit TA=25°C 0.588 0.6 0.612 V -40°C ~+85°C 0.582 0.6 0.618 V Conditions Line Regulation with VREF VFB VIN=2.5V to 5.5V 0.04 0.4 /V Output Voltage Line Regulation VOUT VIN=2.5 to 5.5V 0.04 0.4 %/V RDS (ON) of P-Channel FET RDS(ON) P ISW=100mA 0.28 0.35 Ω RDS (ON) of N-Channel FET RDS (ON) N ISW =-100mA 0.25 0.32 Ω ±0.01 ±1 µA 1.5 1.875 A Shutdown, VRUN=0V 0.1 1 µA Active, VFB=0.5V, VRUN=VIN 100 SW Leakage ILSW VRUN=0V, VIN=5V Peak Inductor Current IPK VFB=0.5V Quiescent Current ICC RUN Threshold VRUN RUN Leakage Current IRUN Oscillator Frequency FOSC 1.125 0.3 VFB=0.6V 1.2 µA 1 1.5 V ±0.01 ±1 µA 1.5 1.8 MHz This datasheet contains new product information. Feeling Technology reserves the rights to modify the product specification without notice. No liability is assumed as a result of the use of this product. No rights under any patent accompany the sales of the product. Rev. 0.67 Website: http://www.feeling-tech.com.tw 5/16 FP6161 Typical Operating Characteristics (TA= 25°C, VIN=3.6V, unless otherwise noted) Supply Current vs. VIN Supply Current vs. VIN 100 24 VFB=0.5V VFB=0.7V 23 Supply Current (µA) Supply Current (µA) 95 90 85℃ 85 -45℃ 80 25℃ 75 22 85℃ 21 25℃ 20 -45℃ 19 70 65 18 2 3 4 5 6 2 3 4 VIN (V) 5 6 VIN (V) Line Regulation Supply Current vs. VIN 0.61 18 TA=25℃ Shutdown Reference Voltage (V) Supply Current (nA) 16 14 12 85℃ 10 8 6 4 25℃ 2 0.6 0.595 0.59 -45℃ 0 2 0.605 3 4 5 0.585 6 2 3 4 VIN (V) Reference Voltage vs. Temperature 6 Frequency vs. VIN 0.605 1.56 VIN=3.6V 0.604 VI N=3.6V 1.54 0.603 0.602 Frequency (MHz) Reference Voltage (V) 5 VIN (V) 0.601 0.6 0.599 0.598 0.597 1.52 1.5 1.48 1.46 0.596 1.44 0.595 -60 -50 -40 -30 -20 -10 0 2 10 20 30 40 50 60 70 80 90 3 4 Temperature (℃) 6 Switch Leakage vs. Input Volatge Frequency vs. Temerature 1.58 1.2 TA=25℃ 1.56 TA=25℃ 1 Switch Leakage (nA) 1.54 Frequency (MHz) 5 VIN (V) 1.52 1.5 1.48 1.46 1.44 0.8 0.6 Synchronous Switch 0.4 Main Switch 0.2 1.42 0 1.4 -50 -40 -30 -20 -10 0 10 20 30 40 50 60 70 80 1 90 2 3 4 5 6 7 VIN (V) Temperature (℃) This datasheet contains new product information. Feeling Technology reserves the rights to modify the product specification without notice. No liability is assumed as a result of the use of this product. No rights under any patent accompany the sales of the product. Rev. 0.67 Website: http://www.feeling-tech.com.tw 6/16 FP6161 Function Description Control Loop The FP6161 is a high efficiency current mode synchronous buck regulator. Both the main (P-channel MOSFET) and synchronous (N-channel MOSFET) switches are built internally. With current mode operation, the PWM duty is controlled both by the error amplifier output and the peak inductor current. At the beginning of each cycle, the oscillator turn on the P-MOSFET switch to source current from VIN to SW output. Then, the chip starts to compare the inductor current with the error amplifier output. Once the inductor current is larger than the error amplifier output, the P-MOSFET switch is turned off. When the load current increases, the feedback voltage FB will slightly drop. This causes the error amplifier to output a higher current level until the prior mentioned peak inductor current reach the same level. The output voltage then can be sustained at the same. When the top P-MOSFET switch is off, the bottom synchronous N-MOSFET switch is turned on. Once the inductor current reverses, both top and bottom MOSFET will be turn off to leave the SW pin into high impedance state. The FP6161’s current mode control loop also includes slope compensation to suppress sub-harmonic oscillations at high duty cycles. This slope compensation is achieved by adding a compensation ramp to the inductor current signal. LDO Mode The FP6161’s maximum duty cycle can reach 100%. That means the driver’s main switch is turn on through out whole clock cycle. Once the duty reaches 100%, the feedback path no longer controls the output voltage. The output voltage will be the input voltage minus the main switch voltage drop. Over Current Protection FP6161 limits the peak main switch current cycle by cycle. When over current occurs, chip will turn off the main switch and turn the synchronous switch on until next cycle. Short Circuit Protection When the FB pin drops below 300mV, the chip will tri-state the output pin SW automatically. After 300us rest to avoid over heating, chip will re-initiate PWM operation with soft start. Thermal Protection FP6161 will shutdown automatically when the internal junction temperature reaches 150℃ to protect both the part and the system. This datasheet contains new product information. Feeling Technology reserves the rights to modify the product specification without notice. No liability is assumed as a result of the use of this product. No rights under any patent accompany the sales of the product. Rev. 0.67 Website: http://www.feeling-tech.com.tw 7/16 FP6161 Application Information Input Capacitor Selection The input capacitor must be connected to the VIN pin and GND pin of FP6161 to maintain steady input voltage and filter out the pulsing input current. The voltage rating of input capacitor must be greater than maximum input voltage plus ripple voltage. In switch mode, the input current is discontinuous in a buck converter. The source current waveform of the high-side MOSFET is a square wave. To prevent large voltage transients, a low ESR input capacitor sized for the maximum RMS current must be used. The RMS value of input capacitor current can be calculated by: IRMS  IOMAX VO VIN  V  1  O   VIN  It can be seen that when VO is half of VIN, CIN is under the worst current stress. The worst current stress on CIN is IO_MAX / 2. Inductor Selection The value of the inductor is selected based on the desired ripple current. Large inductance gives low inductor ripple current and small inductance result in high ripple current. However, the larger value inductor has a larger physical size, higher series resistance, and / or lower saturation current. In experience, the value is to allow the peak-to-peak ripple current in the inductor to be 10%~20% maximum load current. The inductance value can be calculated by: L ( VIN  VO ) VO ( VIN  VO ) VO  f  IL VIN f  2  (10% ~ 20%)IO  VIN The inductor ripple current can be calculated by: IL  V  VO   1  O  f L  VIN  Choose an inductor that does not saturate under the worst-case load conditions, which is the load current plus half the peak-to-peak inductor ripple current, even at the highest operating temperature. The peak inductor current is: IL _ PEAK  IO  IL 2 This datasheet contains new product information. Feeling Technology reserves the rights to modify the product specification without notice. No liability is assumed as a result of the use of this product. No rights under any patent accompany the sales of the product. Rev. 0.67 Website: http://www.feeling-tech.com.tw 8/16 FP6161 The inductors in different shape and style are available from manufacturers. Shielded inductors are small and radiate less EMI issue. But they cost more than unshielded inductors. The choice depends on EMI requirement, price and size. Inductor Value (µH) Dimensions Component Supplier Model 2.2 2.2 3.3 4.7 4.7 4.7 4.2×3.7×1.2 4.4×5.8×1.2 4.2×3.7×1.2 4.2×3.7×1.2 4.4×5.8×1.2 4.9×4.9×1.0 FENG-JUI Sumida FENG-JUI FENG-JUI Sumida Sumida TP4212-2R2M CMD4D11 2R2 TP4212-3R3M TP4212-4R7M CMD4D11 4R7 CLSD09 4R7 Output Capacitor Selection The output capacitor is required to maintain the DC output voltage. Low ESR capacitors are preferred to keep the output voltage ripple low. In a buck converter circuit, output ripple voltage is determined by inductor value, switching frequency, output capacitor value and ESR. The output ripple is determined by:  1 VO  IL   ESR COUT    8 f C OUT      Where f = operating frequency, COUT= output capacitance and ΔIL = ripple current in the inductor. For a fixed output voltage, the output ripple is highest at maximum input voltage since ΔIL increases with input voltage. Capacitor Value (µF) Case Size Component Supplier Model 4.7 10 10 22 0603 0805 0805 0805 1206 TDK Taiyo Yuden TDK TDK C1608JB0J475M JMK212BJ106MG C12012X5ROJ106K C2012JB0J226M Using Ceramic Input and Output Capacitors Care must be taken when ceramic capacitors are used at the input and the output. When a ceramic capacitor is used at the input and the power is supplied by a wall adapter through long wires, a load step at the output can induce ringing at the input, VIN. At best, this ringing can couple to the output and be mistaken as loop instability. At worst, a sudden inrush current through the long wires can potentially cause a voltage spike at VIN, which may large enough to damage the part. When choosing the input and output ceramic capacitors, choose the X5R or X7R specifications. Their dielectrics have the best temperature and voltage characteristics of all the ceramics for a given value and size. This datasheet contains new product information. Feeling Technology reserves the rights to modify the product specification without notice. No liability is assumed as a result of the use of this product. No rights under any patent accompany the sales of the product. Rev. 0.67 Website: http://www.feeling-tech.com.tw 9/16 FP6161 Output Voltage Programming In the adjustable version, the output voltage is set using a resistive voltage divider from the output voltage to FB. The output voltage is:  R  VO  0.6 V 1  1   R2  The recommended resistor value is summarized below: VOUT (V) R1 (Ω) R2 (Ω) C3 (F) 0.6 1.2 1.5 1.8 2.5 3.3 200k 200k 300k 200k 270k 306k Not Used 200k 200k 100k 85k 68k Not Used 10p 10p 10p 10p 10p PC Board Layout Checklist 1. The power traces, consisting of the GND, SW and VIN trace should be kept short, direct and wide. 2. Place CIN near VIN pin as closely as possible to maintain input voltage steady and filter out the pulsing input current. 3. The resistive divider R1 and R2 must be connected to FB pin directly and as closely as possible. 4. FB is a sensitive node. Please keep it away from switching node, SW. A good approach is to route the feedback trace on another PCB layer and have a ground plane between the top and feedback trace routing layer. This reduces EMI radiation on to the DC-DC converter its own voltage feedback trace. 5. Keep the GND plates of CIN and COUT as close as possible. Then connect this to the ground plane (if one is used) with several vias. This reduces ground plane noise by preventing the switching currents from circulating through the ground plane. It also reduces ground bounce at FP6161 by giving it a low impedance ground connection. This datasheet contains new product information. Feeling Technology reserves the rights to modify the product specification without notice. No liability is assumed as a result of the use of this product. No rights under any patent accompany the sales of the product. Rev. 0.67 Website: http://www.feeling-tech.com.tw 10/16 FP6161 Suggested Layout for SOT23-5L Suggested Layout for DFN-6L This datasheet contains new product information. Feeling Technology reserves the rights to modify the product specification without notice. No liability is assumed as a result of the use of this product. No rights under any patent accompany the sales of the product. Rev. 0.67 Website: http://www.feeling-tech.com.tw 11/16 FP6161 Typical Application L1 3.3uH VIN VIN 2.5V~5.5V SW R1 270K FP6161 C1 10µF 1 VOUT 2.5V/1A 3 4 RUN FB / VOUT C3 10pF C2 10µF 5 R2 85K GND 2 SOT23-5L / TSOT23-5L This datasheet contains new product information. Feeling Technology reserves the rights to modify the product specification without notice. No liability is assumed as a result of the use of this product. No rights under any patent accompany the sales of the product. Rev. 0.67 Website: http://www.feeling-tech.com.tw 12/16 FP6161 ILOAD: 200mA~1A ILOAD: 100mA~1A Ch1:VOUT Ch2: ISW Ch1: VOUT EN On waveform (VOUT: 1.8V) Ch2: ISW Efficiency (VOUT: 2.5V) Efficiency VS. Output Current 100 90 80 Efficiency (%) 70 60 Vin=2.7V 50 Vin=3.6V 40 Vin=4.2V 30 20 10 0 0.1 Ch1: EN Ch2: SW 1.0 10.0 Output Current (mA) 100.0 1000.0 Ch3: VOUT Ch4: ISW Efficiency (VIN: 5.3V) Efficiency VS Output Current 100 90 80 Efficiency (%) 70 60 Vout=3.3V 50 Vout=1.8V 40 Vout=1.2V 30 20 10 0 0.1 1.0 10.0 100.0 Output Current (mA) 1000.0 This datasheet contains new product information. Feeling Technology reserves the rights to modify the product specification without notice. No liability is assumed as a result of the use of this product. No rights under any patent accompany the sales of the product. Rev. 0.67 Website: http://www.feeling-tech.com.tw 13/16 FP6161 Package Outline DFN-6L Unit: MM Symbols Min. (mm) Max. (mm) A 0.700 0.800 A1 0.000 0.050 b 0.200 0.300 c 0.190 0.250 D 1.950 2.050 D2 1.350 1.450 E 1.950 2.050 E2 0.750 0.850 e 0.650 REF L 0.300 0.400 y 0.000 0.075 This datasheet contains new product information. Feeling Technology reserves the rights to modify the product specification without notice. No liability is assumed as a result of the use of this product. No rights under any patent accompany the sales of the product. Rev. 0.67 Website: http://www.feeling-tech.com.tw 14/16 FP6161 SOT23-5L Unit: MM Symbols Min. (mm) Max.(mm) A 1.050 1.350 A1 0.050 0.150 A2 1.000 1.200 b 0.250 0.500 c 0.080 0.200 D 2.700 3.000 E 2.600 3.000 E1 1.500 1.700 e 0.950 BSC e1 1.900 BSC L 0.300 0.550 L1 0.600 REF L2 0.250 BSC θ° 0° 10° θ1° 3° 7° θ2° 6° 10° Note: 1. Package dimensions are in compliance with JEDEC outline: MO-178 AA. 2. Dimension “D” does not include molding flash, protrusions or gate burrs. 3. Dimension “E1” does not include inter-lead flash or protrusions. This datasheet contains new product information. Feeling Technology reserves the rights to modify the product specification without notice. No liability is assumed as a result of the use of this product. No rights under any patent accompany the sales of the product. Rev. 0.67 Website: http://www.feeling-tech.com.tw 15/16 FP6161 TSOT23-5L Unit: MM Symbols Min.(mm) Max.(mm) A 0.750 0.800 A1 0.000 0.050 A2 0.700 0.775 b 0.350 0.500 c 0.100 0.200 D 2.800 3.000 E 2.600 3.000 E1 1.500 1.700 e 0.950 BSC e1 1.900 BSC L Note: 0.370 0.600 L1 0.600 REF L2 0.250 BSC R 0.100 R1 0.100 0.250 θ° 0° 8° θ1 4° 12° 1. Dimension “D” does not include molding flash, protrusions or gate burrs. 2. Dimension “E1” does not include inter-lead flash or protrusions. This datasheet contains new product information. Feeling Technology reserves the rights to modify the product specification without notice. No liability is assumed as a result of the use of this product. No rights under any patent accompany the sales of the product. Rev. 0.67 Website: http://www.feeling-tech.com.tw 16/16
FP6161KR-LF 价格&库存
很抱歉,暂时无法提供与“FP6161KR-LF”相匹配的价格&库存,您可以联系我们找货
FP6161KR-LF
  • 5+0.81600
  • 20+0.74400
  • 100+0.67200
  • 500+0.60000
  • 1000+0.56640
  • 2000+0.54240
库存:4
