BAT46W-HAF
Surface Mount Schottky Barrier Diode
PIN
Features
• High breakdown voltage
• Low forward voltage
• Surface mount device
• Halogen and Antimony Free(HAF),
RoHS compliant
DESCRIPTION
1
Cathode
2
Anode
2
1
Top View
Simplified outline SOD-123 and symbol
Absolute Maximum Ratings (Ta = 25℃)
Parameter
Symbol
Value
Unit
VRRM
100
V
IF
150
mA
Repetitive Peak Forward Current (at tp < 1 s)
IFRM
350
mA
Surge Forward Current (at tp < 10 ms)
IFSM
750
mA
Power Dissipation
Ptot
200
mW
Tj
- 55 to + 125
Tstg
- 55 to + 150
Symbol
Max.
Unit
RθJA
500
℃/W
Repetitive Peak Reverse Voltage
Continuous Forward Current
Operating Junction Temperature Range
Storage Temperature Range
Thermal Characteristics
Parameter
Thermal Resistance from Junction to Ambient
1)
1)
Device mounted on FR-4 substrate PC board, 2oz copper, with minimum recommended pad layout.
1/4
Dated: 10/02/2023 Rev: 05
BAT46W-HAF
Characteristics at Ta = 25℃
Parameter
Reverse Breakdown Voltage
at IR = 100 µA
Forward Voltage
at IF = 0.1 mA
at IF = 10 mA
at IF = 250 mA
Symbol
Min.
Typ.
Max.
Unit
V(BR)R
100
V
0.25
0.45
1
0.5
0.8
2
5
5
7.5
15
6
40
35
VF
Reverse Current
at VR = 1.5 V
at VR = 10 V
at VR = 50 V
at VR = 75 V
at VR = 1.5 V, Tj = 60℃
at VR = 10 V, Tj = 60℃
at VR = 50 V, Tj = 60℃
at VR = 75 V, Tj = 60℃
IR
Total Capacitance
at VR = 0 V, f = 1 MHz
at VR = 1 V, f = 1 MHz
CT
2/4
V
µA
pF
BAT46W-HAF
Electrical Characteristics Curves
Fig 2. Forward Characteristics Curve
Reverse Current (µA)
Forward Current (mA)
Fig 1. Reverse Characteristics Curve
Forward Voltage (V)
Reverse Voltage (V)
Junction Capacitance (pF)
Fig 3. Junction Capacitance
Reverse Voltage (V)
3/4
BAT46W-HAF
PACKAGE OUTLINE
Plastic surface mounted package; 2 leads
SOD-123
c
A
∠ ALL ROUND
HE
A
bp
E
D
UNIT
A
bp
c
D
E
HE
v
mm
1.15
1.05
0.6
0.5
0.135
0.100
2.7
2.6
1.65
1.55
3.85
3.55
0.2
5
O
Recommended Soldering Footprint
3.05
0.85
1.2
Packing information
Package
Tape Width
(mm)
SOD-123
8
Pitch
Reel Size
mm
(inch)
mm
(inch)
4 ± 0.1
0.157 ± 0.004
178
7
Per Reel Packing Quantity
3,000
Marking information
" XH " = Part No.
" III " = Cathode line
" • " = HAF (Halogen and Antimony Free)
Font type: Arial
. XH
4/4
很抱歉,暂时无法提供与“BAT46W”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 20+0.14573
- 300+0.11850
- 1200+0.11732
- 3000+0.11497
- 15000+0.11152
- 30000+0.10706
- 国内价格
- 20+0.15898
- 200+0.12928
- 600+0.11276
- 国内价格
- 1+0.36960
- 200+0.12320
- 1500+0.07689
- 3000+0.06105
