SD103AW
SD103AW
    ST(先科)
    SOD-123
    肖特基二极管 Single VR=40V IF=350mA SOD123
SD103AW 数据手册
SD103AW…SD103CW Surface Mount Schottky Barrier Diodes PINNING DESCRIPTION PIN Features • Low Forward Voltage 1 Cathode 2 Anode 2 1 S4 Top View Marking Code: S4 Simplified outline SOD-123 and symbol Absolute Maximum Ratings (Ta = 25 OC) Parameter Peak Repetitive Reverse Voltage H C Symbol SD103AW SD103BW SD103CW SD103AW SD103BW SD103CW Value VRRM E T M E S Reverse Voltage VR Average Forward Rectified Current IF(AV) Non-Repetitive Peak Forward Surge Current at t = 1 s IFSM Power Dissipation Ptot Operating and Storage Temperature Range Tj, Tstg Unit 40 30 20 40 30 20 V V 350 mA 2 A 400 mW C - 65 to + 125 O Characteristics at Ta = 25 OC Symbol Min. Typ. Max. 40 30 20 - - - - 5 5 5 VF - - 0.37 0.6 V Total Capacitance at VR = 0 V, f = 1 MHz CT - 50 - pF Reverse Recovery Time at IF = IR = 200 mA, Irr = 0.1 IR, RL = 100 Ω trr - 10 - ns Parameter Reverse Breakdown Voltage at IR = 10 µA Reverse Leakage Current at VR = 30 V at VR = 20 V at VR = 10 V Forward Voltage at IF = 20 mA at IF = 200 mA SD103AW SD103BW SD103CW SD103AW SD103BW SD103CW V(BR)R IR Unit V µA SEMTECH ELECTRONICS LTD. Subsidiary of Sino-Tech International (BVI) Limited ® Dated : 04/11/2009 SD103AW…SD103CW H C E T M E S SEMTECH ELECTRONICS LTD. Subsidiary of Sino-Tech International (BVI) Limited ® Dated : 04/11/2009 SD103AW…SD103CW ACKAGE OUTLINE Plastic surface mounted package; 2 leads SOD-123 H C A ALL ROUND c E T M E S HE A bp E D UNIT A bp c D E HE v mm 1.15 1.05 0.6 0.5 0.135 0.100 2.7 2.6 1.65 1.55 3.85 3.55 0.2 5 O SEMTECH ELECTRONICS LTD. Subsidiary of Sino-Tech International (BVI) Limited ® Dated : 04/11/2009
SD103AW 价格&库存
很抱歉,暂时无法提供与“SD103AW”相匹配的价格&库存,您可以联系我们找货
SD103AW
  • 1+0.06345
  • 10+0.06110
  • 100+0.05546
  • 500+0.05264
